path: root/fs/debugfs
2014-12-14Merge tag 'driver-core-3.19-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core update from Greg KH: "Here's the set of driver core patches for 3.19-rc1. They are dominated by the removal of the .owner field in platform drivers. They touch a lot of files, but they are "simple" changes, just removing a line in a structure. Other than that, a few minor driver core and debugfs changes. There are some ath9k patches coming in through this tree that have been acked by the wireless maintainers as they relied on the debugfs changes. Everything has been in linux-next for a while" * tag 'driver-core-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (324 commits) Revert "ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries" fs: debugfs: add forward declaration for struct device type firmware class: Deletion of an unnecessary check before the function call "vunmap" firmware loader: fix hung task warning dump devcoredump: provide a one-way disable function device: Add dev_<level>_once variants ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries ath: use seq_file api for ath9k debugfs files debugfs: add helper function to create device related seq_file drivers/base: cacheinfo: remove noisy error boot message Revert "core: platform: add warning if driver has no owner" drivers: base: support cpu cache information interface to userspace via sysfs drivers: base: add cpu_device_create to support per-cpu devices topology: replace custom attribute macros with standard DEVICE_ATTR* cpumask: factor out show_cpumap into separate helper function driver core: Fix unbalanced device reference in drivers_probe driver core: fix race with userland in device_add() sysfs/kernfs: make read requests on pre-alloc files use the buffer. sysfs/kernfs: allow attributes to request write buffer be pre-allocated. fs: sysfs: return EGBIG on write if offset is larger than file size ...
2014-11-26debugfs: add helper function to create device related seq_fileArend van Spriel
This patch adds a helper function that simplifies adding a so-called single_open sequence file for device drivers. The calling device driver needs to provide a read function and a device pointer. The field struct seq_file::private will reference the device pointer upon call to the read function so the driver can obtain his data from it and do its task of providing the file content using seq_printf() calls and alike. Using this helper function also gets rid of the need to specify file operations per debugfs file. Signed-off-by: Arend van Spriel <arend@broadcom.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-19Merge tag 'trace-seq-file-cleanup' of ↵Al Viro
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace into for-next Pull the beginning of seq_file cleanup from Steven: "I'm looking to clean up the seq_file code and to eventually merge the trace_seq code with seq_file as well, since they basically do the same thing. Part of this process is to remove the return code of seq_printf() and friends as they are rather inconsistent. It is better to use the new function seq_has_overflowed() if you want to stop processing when the buffer is full. Note, if the buffer is full, the seq_file code will throw away the contents, allocate a bigger buffer, and then call your code again to fill in the data. The only thing that breaking out of the function early does is to save a little time which is probably never noticed. I started with patches from Joe Perches and modified them as well. There's many more places that need to be updated before we can convert seq_printf() and friends to return void. But this patch set introduces the seq_has_overflowed() and does some initial updates."
2014-11-05debugfs: Have debugfs_print_regs32() return voidJoe Perches
The seq_printf() will soon just return void, and seq_has_overflowed() should be used instead to see if the seq can no longer accept input. As the return value of debugfs_print_regs32() has no users and the seq_file descriptor should be checked with seq_has_overflowed() instead of return values of functions, it is better to just have debugfs_print_regs32() also return void. Link: http://lkml.kernel.org/p/2634b19eb1c04a9d31148c1fe6f1f3819be95349.1412031505.git.joe@perches.com Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Joe Perches <joe@perches.com> [ original change only updated seq_printf() return, added return of void to debugfs_print_regs32() as well ] Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2014-11-03move d_rcu from overlapping d_child to overlapping d_aliasAl Viro
2014-07-09fs: debugfs: remove trailing whitespaceRahul Bedarkar
fixes checkpatch.pl trailing whitespace errors Signed-off-by: Rahul Bedarkar <rahulbedarkar89@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-09debugfs: Fix corrupted loop in debugfs_remove_recursiveSteven Rostedt
[ I'm currently running my tests on it now, and so far, after a few hours it has yet to blow up. I'll run it for 24 hours which it never succeeded in the past. ] The tracing code has a way to make directories within the debugfs file system as well as deleting them using mkdir/rmdir in the instance directory. This is very limited in functionality, such as there is no renames, and the parent directory "instance" can not be modified. The tracing code creates the instance directory from the debugfs code and then replaces the dentry->d_inode->i_op with its own to allow for mkdir/rmdir to work. When these are called, the d_entry and inode locks need to be released to call the instance creation and deletion code. That code has its own accounting and locking to serialize everything to prevent multiple users from causing harm. As the parent "instance" directory can not be modified this simplifies things. I created a stress test that creates several threads that randomly creates and deletes directories thousands of times a second. The code stood up to this test and I submitted it a while ago. Recently I added a new test that adds readers to the mix. While the instance directories were being added and deleted, readers would read from these directories and even enable tracing within them. This test was able to trigger a bug: general protection fault: 0000 [#1] PREEMPT SMP Modules linked in: ... CPU: 3 PID: 17789 Comm: rmdir Tainted: G W 3.15.0-rc2-test+ #41 Hardware name: To Be Filled By O.E.M. To Be Filled By O.E.M./To be filled by O.E.M., BIOS SDBLI944.86P 05/08/2007 task: ffff88003786ca60 ti: ffff880077018000 task.ti: ffff880077018000 RIP: 0010:[<ffffffff811ed5eb>] [<ffffffff811ed5eb>] debugfs_remove_recursive+0x1bd/0x367 RSP: 0018:ffff880077019df8 EFLAGS: 00010246 RAX: 0000000000000002 RBX: ffff88006f0fe490 RCX: 0000000000000000 RDX: dead000000100058 RSI: 0000000000000246 RDI: ffff88003786d454 RBP: ffff88006f0fe640 R08: 0000000000000628 R09: 0000000000000000 R10: 0000000000000628 R11: ffff8800795110a0 R12: ffff88006f0fe640 R13: ffff88006f0fe640 R14: ffffffff81817d0b R15: ffffffff818188b7 FS: 00007ff13ae24700(0000) GS:ffff88007d580000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: 0000003054ec7be0 CR3: 0000000076d51000 CR4: 00000000000007e0 Stack: ffff88007a41ebe0 dead000000100058 00000000fffffffe ffff88006f0fe640 0000000000000000 ffff88006f0fe678 ffff88007a41ebe0 ffff88003793a000 00000000fffffffe ffffffff810bde82 ffff88006f0fe640 ffff88007a41eb28 Call Trace: [<ffffffff810bde82>] ? instance_rmdir+0x15b/0x1de [<ffffffff81132e2d>] ? vfs_rmdir+0x80/0xd3 [<ffffffff81132f51>] ? do_rmdir+0xd1/0x139 [<ffffffff8124ad9e>] ? trace_hardirqs_on_thunk+0x3a/0x3c [<ffffffff814fea62>] ? system_call_fastpath+0x16/0x1b Code: fe ff ff 48 8d 75 30 48 89 df e8 c9 fd ff ff 85 c0 75 13 48 c7 c6 b8 cc d2 81 48 c7 c7 b0 cc d2 81 e8 8c 7a f5 ff 48 8b 54 24 08 <48> 8b 82 a8 00 00 00 48 89 d3 48 2d a8 00 00 00 48 89 44 24 08 RIP [<ffffffff811ed5eb>] debugfs_remove_recursive+0x1bd/0x367 RSP <ffff880077019df8> It took a while, but every time it triggered, it was always in the same place: list_for_each_entry_safe(child, next, &parent->d_subdirs, d_u.d_child) { Where the child->d_u.d_child seemed to be corrupted. I added lots of trace_printk()s to see what was wrong, and sure enough, it was always the child's d_u.d_child field. I looked around to see what touches it and noticed that in __dentry_kill() which calls dentry_free(): static void dentry_free(struct dentry *dentry) { /* if dentry was never visible to RCU, immediate free is OK */ if (!(dentry->d_flags & DCACHE_RCUACCESS)) __d_free(&dentry->d_u.d_rcu); else call_rcu(&dentry->d_u.d_rcu, __d_free); } I also noticed that __dentry_kill() unlinks the child->d_u.child under the parent->d_lock spin_lock. Looking back at the loop in debugfs_remove_recursive() it never takes the parent->d_lock to do the list walk. Adding more tracing, I was able to prove this was the issue: ftrace-t-15385 1.... 246662024us : dentry_kill <ffffffff81138b91>: free ffff88006d573600 rmdir-15409 2.... 246662024us : debugfs_remove_recursive <ffffffff811ec7e5>: child=ffff88006d573600 next=dead000000100058 The dentry_kill freed ffff88006d573600 just as the remove recursive was walking it. In order to fix this, the list walk needs to be modified a bit to take the parent->d_lock. The safe version is no longer necessary, as every time we remove a child, the parent->d_lock must be released and the list walk must start over. Each time a child is removed, even though it may still be on the list, it should be skipped by the first check in the loop: if (!debugfs_positive(child)) continue; Cc: stable@vger.kernel.org Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-04Merge tag 'ext4_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 Pull ext4 updates from Ted Ts'o: "Major changes for 3.14 include support for the newly added ZERO_RANGE and COLLAPSE_RANGE fallocate operations, and scalability improvements in the jbd2 layer and in xattr handling when the extended attributes spill over into an external block. Other than that, the usual clean ups and minor bug fixes" * tag 'ext4_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (42 commits) ext4: fix premature freeing of partial clusters split across leaf blocks ext4: remove unneeded test of ret variable ext4: fix comment typo ext4: make ext4_block_zero_page_range static ext4: atomically set inode->i_flags in ext4_set_inode_flags() ext4: optimize Hurd tests when reading/writing inodes ext4: kill i_version support for Hurd-castrated file systems ext4: each filesystem creates and uses its own mb_cache fs/mbcache.c: doucple the locking of local from global data fs/mbcache.c: change block and index hash chain to hlist_bl_node ext4: Introduce FALLOC_FL_ZERO_RANGE flag for fallocate ext4: refactor ext4_fallocate code ext4: Update inode i_size after the preallocation ext4: fix partial cluster handling for bigalloc file systems ext4: delete path dealloc code in ext4_ext_handle_uninitialized_extents ext4: only call sync_filesystm() when remounting read-only fs: push sync_filesystem() down to the file system's remount_fs() jbd2: improve error messages for inconsistent journal heads jbd2: minimize region locked by j_list_lock in jbd2_journal_forget() jbd2: minimize region locked by j_list_lock in journal_get_create_access() ...
2014-03-13fs: push sync_filesystem() down to the file system's remount_fs()Theodore Ts'o
Previously, the no-op "mount -o mount /dev/xxx" operation when the file system is already mounted read-write causes an implied, unconditional syncfs(). This seems pretty stupid, and it's certainly documented or guaraunteed to do this, nor is it particularly useful, except in the case where the file system was mounted rw and is getting remounted read-only. However, it's possible that there might be some file systems that are actually depending on this behavior. In most file systems, it's probably fine to only call sync_filesystem() when transitioning from read-write to read-only, and there are some file systems where this is not needed at all (for example, for a pseudo-filesystem or something like romfs). Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: linux-fsdevel@vger.kernel.org Cc: Christoph Hellwig <hch@infradead.org> Cc: Artem Bityutskiy <dedekind1@gmail.com> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Evgeniy Dushistov <dushistov@mail.ru> Cc: Jan Kara <jack@suse.cz> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Anders Larsen <al@alarsen.net> Cc: Phillip Lougher <phillip@squashfs.org.uk> Cc: Kees Cook <keescook@chromium.org> Cc: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz> Cc: Petr Vandrovec <petr@vandrovec.name> Cc: xfs@oss.sgi.com Cc: linux-btrfs@vger.kernel.org Cc: linux-cifs@vger.kernel.org Cc: samba-technical@lists.samba.org Cc: codalist@coda.cs.cmu.edu Cc: linux-ext4@vger.kernel.org Cc: linux-f2fs-devel@lists.sourceforge.net Cc: fuse-devel@lists.sourceforge.net Cc: cluster-devel@redhat.com Cc: linux-mtd@lists.infradead.org Cc: jfs-discussion@lists.sourceforge.net Cc: linux-nfs@vger.kernel.org Cc: linux-nilfs@vger.kernel.org Cc: linux-ntfs-dev@lists.sourceforge.net Cc: ocfs2-devel@oss.oracle.com Cc: reiserfs-devel@vger.kernel.org
2014-02-19treewide: Fix typo in Documentation/DocBookMasanari Iida
This patch fix spelling typo in Documentation/DocBook. It is because .html and .xml files are generated by make htmldocs, I have to fix a typo within the source files. Signed-off-by: Masanari Iida <standby24x7@gmail.com> Acked-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-11-13debugfs: use list_next_entry() in debugfs_remove_recursive()Oleg Nesterov
Change debugfs_remove_recursive() to use list_next_entry(child), no changes in generated code. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Eilon Greenstein <eilong@broadcom.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-31debugfs: debugfs_remove_recursive() must not rely on list_empty(d_subdirs)Oleg Nesterov
debugfs_remove_recursive() is wrong, 1. it wrongly assumes that !list_empty(d_subdirs) means that this dir should be removed. This is not that bad by itself, but: 2. if d_subdirs does not becomes empty after __debugfs_remove() it gives up and silently fails, it doesn't even try to remove other entries. However ->d_subdirs can be non-empty because it still has the already deleted !debugfs_positive() entries. 3. simple_release_fs() is called even if __debugfs_remove() fails. Suppose we have dir1/ dir2/ file2 file1 and someone opens dir1/dir2/file2. Now, debugfs_remove_recursive(dir1/dir2) succeeds, and dir1/dir2 goes away. But debugfs_remove_recursive(dir1) silently fails and doesn't remove this directory. Because it tries to delete (the already deleted) dir1/dir2/file2 again and then fails due to "Avoid infinite loop" logic. Test-case: #!/bin/sh cd /sys/kernel/debug/tracing echo 'p:probe/sigprocmask sigprocmask' >> kprobe_events sleep 1000 < events/probe/sigprocmask/id & echo -n >| kprobe_events [ -d events/probe ] && echo "ERR!! failed to rm probe" And after that it is not possible to create another probe entry. With this patch debugfs_remove_recursive() skips !debugfs_positive() files although this is not strictly needed. The most important change is that it does not try to make ->d_subdirs empty, it simply scans the whole list(s) recursively and removes as much as possible. Link: http://lkml.kernel.org/r/20130726151256.GC19472@redhat.com Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2013-06-03debugfs: write_file_bool() - ensure strtobool() operates on valid dataMathias Krause
In case, userland writes an empty string to a bool debugfs file, buf[] will still be uninitialized when being passed to strtobool() making the outcome of that function purely random. Fix this by always zero-terminating the buffer. Signed-off-by: Mathias Krause <minipli@googlemail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-03debugfs: add get/set for atomic typesSeth Jennings
debugfs currently lack the ability to create attributes that set/get atomic_t values. This patch adds support for this through a new debugfs_create_atomic_t() function. Signed-off-by: Seth Jennings <sjenning@linux.vnet.ibm.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Acked-by: Mel Gorman <mgorman@suse.de> Acked-by: Rik van Riel <riel@redhat.com> Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-03fs: Limit sys_mount to only request filesystem modules.Eric W. Biederman
Modify the request_module to prefix the file system type with "fs-" and add aliases to all of the filesystems that can be built as modules to match. A common practice is to build all of the kernel code and leave code that is not commonly needed as modules, with the result that many users are exposed to any bug anywhere in the kernel. Looking for filesystems with a fs- prefix limits the pool of possible modules that can be loaded by mount to just filesystems trivially making things safer with no real cost. Using aliases means user space can control the policy of which filesystem modules are auto-loaded by editing /etc/modprobe.d/*.conf with blacklist and alias directives. Allowing simple, safe, well understood work-arounds to known problematic software. This also addresses a rare but unfortunate problem where the filesystem name is not the same as it's module name and module auto-loading would not work. While writing this patch I saw a handful of such cases. The most significant being autofs that lives in the module autofs4. This is relevant to user namespaces because we can reach the request module in get_fs_type() without having any special permissions, and people get uncomfortable when a user specified string (in this case the filesystem type) goes all of the way to request_module. After having looked at this issue I don't think there is any particular reason to perform any filtering or permission checks beyond making it clear in the module request that we want a filesystem module. The common pattern in the kernel is to call request_module() without regards to the users permissions. In general all a filesystem module does once loaded is call register_filesystem() and go to sleep. Which means there is not much attack surface exposed by loading a filesytem module unless the filesystem is mounted. In a user namespace filesystems are not mounted unless .fs_flags = FS_USERNS_MOUNT, which most filesystems do not set today. Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Acked-by: Kees Cook <keescook@chromium.org> Reported-by: Kees Cook <keescook@google.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2013-01-17Merge 3.9-rc4 into driver-core-nextGreg Kroah-Hartman
This is to fix up a build problem with a wireless driver due to the dynamic-debug patches in this branch. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-17debugfs: remove redundant initialization of dentrySasha Levin
We already initialize it to NULL when declaring it, no need to do that twice. Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11debugfs: convert gid= argument from decimal, not octalDave Reisner
This patch technically breaks userspace, but I suspect that anyone who actually used this flag would have encountered this brokenness, declared it lunacy, and already sent a patch. Signed-off-by: Dave Reisner <dreisner@archlinux.org> Reviewed-by: Vasiliy Kulikov <segoon@openwall.com> Acked-by: Kees Cook <keescook@chromium.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-15fs/debugsfs: remove unnecessary inode->i_private initializationYan Hong
inode->i_private is promised to be NULL on allocation, no need to set it explicitly. Signed-off-by: Yan Hong <clouds.yan@gmail.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace Pull user namespace changes from Eric Biederman: "This is a mostly modest set of changes to enable basic user namespace support. This allows the code to code to compile with user namespaces enabled and removes the assumption there is only the initial user namespace. Everything is converted except for the most complex of the filesystems: autofs4, 9p, afs, ceph, cifs, coda, fuse, gfs2, ncpfs, nfs, ocfs2 and xfs as those patches need a bit more review. The strategy is to push kuid_t and kgid_t values are far down into subsystems and filesystems as reasonable. Leaving the make_kuid and from_kuid operations to happen at the edge of userspace, as the values come off the disk, and as the values come in from the network. Letting compile type incompatible compile errors (present when user namespaces are enabled) guide me to find the issues. The most tricky areas have been the places where we had an implicit union of uid and gid values and were storing them in an unsigned int. Those places were converted into explicit unions. I made certain to handle those places with simple trivial patches. Out of that work I discovered we have generic interfaces for storing quota by projid. I had never heard of the project identifiers before. Adding full user namespace support for project identifiers accounts for most of the code size growth in my git tree. Ultimately there will be work to relax privlige checks from "capable(FOO)" to "ns_capable(user_ns, FOO)" where it is safe allowing root in a user names to do those things that today we only forbid to non-root users because it will confuse suid root applications. While I was pushing kuid_t and kgid_t changes deep into the audit code I made a few other cleanups. I capitalized on the fact we process netlink messages in the context of the message sender. I removed usage of NETLINK_CRED, and started directly using current->tty. Some of these patches have also made it into maintainer trees, with no problems from identical code from different trees showing up in linux-next. After reading through all of this code I feel like I might be able to win a game of kernel trivial pursuit." Fix up some fairly trivial conflicts in netfilter uid/git logging code. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (107 commits) userns: Convert the ufs filesystem to use kuid/kgid where appropriate userns: Convert the udf filesystem to use kuid/kgid where appropriate userns: Convert ubifs to use kuid/kgid userns: Convert squashfs to use kuid/kgid where appropriate userns: Convert reiserfs to use kuid and kgid where appropriate userns: Convert jfs to use kuid/kgid where appropriate userns: Convert jffs2 to use kuid and kgid where appropriate userns: Convert hpfs to use kuid and kgid where appropriate userns: Convert btrfs to use kuid/kgid where appropriate userns: Convert bfs to use kuid/kgid where appropriate userns: Convert affs to use kuid/kgid wherwe appropriate userns: On alpha modify linux_to_osf_stat to use convert from kuids and kgids userns: On ia64 deal with current_uid and current_gid being kuid and kgid userns: On ppc convert current_uid from a kuid before printing. userns: Convert s390 getting uid and gid system calls to use kuid and kgid userns: Convert s390 hypfs to use kuid and kgid where appropriate userns: Convert binder ipc to use kuids userns: Teach security_path_chown to take kuids and kgids userns: Add user namespace support to IMA userns: Convert EVM to deal with kuids and kgids in it's hmac computation ...
2012-10-01Merge tag 'driver-core-3.6' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core merge from Greg Kroah-Hartman: "Here is the big driver core update for 3.7-rc1. A number of firmware_class.c updates (as you saw a month or so ago), and some hyper-v updates and some printk fixes as well. All patches that are outside of the drivers/base area have been acked by the respective maintainers, and have all been in the linux-next tree for a while. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>" * tag 'driver-core-3.6' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (95 commits) memory: tegra{20,30}-mc: Fix reading incorrect register in mc_readl() device.h: Add missing inline to #ifndef CONFIG_PRINTK dev_vprintk_emit memory: emif: Add ifdef CONFIG_DEBUG_FS guard for emif_debugfs_[init|exit] Documentation: Fixes some translation error in Documentation/zh_CN/gpio.txt Documentation: Remove 3 byte redundant code at the head of the Documentation/zh_CN/arm/booting Documentation: Chinese translation of Documentation/video4linux/omap3isp.txt device and dynamic_debug: Use dev_vprintk_emit and dev_printk_emit dev: Add dev_vprintk_emit and dev_printk_emit netdev_printk/netif_printk: Remove a superfluous logging colon netdev_printk/dynamic_netdev_dbg: Directly call printk_emit dev_dbg/dynamic_debug: Update to use printk_emit, optimize stack driver-core: Shut up dev_dbg_reatelimited() without DEBUG tools/hv: Parse /etc/os-release tools/hv: Check for read/write errors tools/hv: Fix exit() error code tools/hv: Fix file handle leak Tools: hv: Implement the KVP verb - KVP_OP_GET_IP_INFO Tools: hv: Rename the function kvp_get_ip_address() Tools: hv: Implement the KVP verb - KVP_OP_SET_IP_INFO Tools: hv: Add an example script to configure an interface ...
2012-09-21debugfs: fix u32_array race in format_array_allocLinus Torvalds
The format_array_alloc() function is fundamentally racy, in that it prints the array twice: once to figure out how much space to allocate for the buffer, and the second time to actually print out the data. If any of the array contents changes in between, the allocation size may be wrong, and the end result may be truncated in odd ways. Just don't do it. Allocate a maximum-sized array up-front, and just format the array contents once. The only user of the u32_array interfaces is the Xen spinlock statistics code, and it has 31 entries in the arrays, so the maximum size really isn't that big, and the end result is much simpler code without the bug. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-09-21debugfs: fix race in u32_array_read and allocate array at openDavid Rientjes
u32_array_open() is racy when multiple threads read from a file with a seek position of zero, i.e. when two or more simultaneous reads are occurring after the non-seekable files are created. It is possible that file->private_data is double-freed because the threads races between kfree(file->private-data); and file->private_data = NULL; The fix is to only do format_array_alloc() when the file is opened and free it when it is closed. Note that because the file has always been non-seekable, you can't open it and read it multiple times anyway, so the data has always been generated just once. The difference is that now it is generated at open time rather than at the time of the first read, and that avoids the race. Reported-by: Dave Jones <davej@redhat.com> Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Tested-by: Raghavendra <raghavendra.kt@linux.vnet.ibm.com> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-09-06userns: Convert debugfs to use kuid/kgid where appropriate.Eric W. Biederman
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-08-27debugfs: more tightly restrict default mount modeKees Cook
Since the debugfs is mostly only used by root, make the default mount mode 0700. Most system owners do not need a more permissive value, but they can choose to weaken the restrictions via their fstab. Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-16debugfs: make __create_file staticChris Wright
It's only used locally, no need to pollute global namespace. Signed-off-by: Chris Wright <chrisw@sous-sol.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-26Merge tag 'driver-core-3.6-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core changes from Greg Kroah-Hartman: "Here's the big driver core pull request for 3.6-rc1. Unlike 3.5, this kernel should be a lot tamer, with the printk changes now settled down. All we have here is some extcon driver updates, w1 driver updates, a few printk cleanups that weren't needed for 3.5, but are good to have now, and some other minor fixes/changes in the driver core. All of these have been in the linux-next releases for a while now. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>" * tag 'driver-core-3.6-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (38 commits) printk: Export struct log size and member offsets through vmcoreinfo Drivers: hv: Change the hex constant to a decimal constant driver core: don't trigger uevent after failure extcon: MAX77693: Add extcon-max77693 driver to support Maxim MAX77693 MUIC device sysfs: fail dentry revalidation after namespace change fix sysfs: fail dentry revalidation after namespace change extcon: spelling of detach in function doc extcon: arizona: Stop microphone detection if we give up on it extcon: arizona: Update cable reporting calls and split headset PM / Runtime: Do not increment device usage counts before probing kmsg - do not flush partial lines when the console is busy kmsg - export "continuation record" flag to /dev/kmsg kmsg - avoid warning for CONFIG_PRINTK=n compilations kmsg - properly print over-long continuation lines driver-core: Use kobj_to_dev instead of re-implementing it driver-core: Move kobj_to_dev from genhd.h to device.h driver core: Move deferred devices to the end of dpm_list before probing driver core: move uevent call to driver_register driver core: fix shutdown races with probe/remove(v3) Extcon: Arizona: Add driver for Wolfson Arizona class devices ...
2012-07-14debugfs: get rid of useless arguments to debugfs_{mkdir,symlink}Al Viro
2012-07-14debugfs: fold debugfs_create_by_name() into the only callerAl Viro
2012-07-14debugfs: make sure that debugfs_create_file() gets used only for regularsAl Viro
It, debugfs_create_dir() and debugfs_create_link() use the common helper now. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-06-13debugfs: change parameter check in debugfs_remove() functionsArend van Spriel
The dentry parameter in debugfs_remove() and debugfs_remove_recursive() is checked being a NULL pointer. To make cleanup by callers easier this check is extended using the IS_ERR_OR_NULL macro instead because the debugfs_create_... functions can return a ERR_PTR() value. Signed-off-by: Arend van Spriel <arend@broadcom.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-17debugfs: Add support to print u32 array in debugfsSrivatsa Vaddagiri
Move the code from Xen to debugfs to make the code common for other users as well. Accked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Srivatsa Vaddagiri <vatsa@linux.vnet.ibm.com> Signed-off-by: Suzuki Poulose <suzuki@in.ibm.com> [v1: Fixed rebase issues] [v2: Fixed PPC compile issues] Signed-off-by: Raghavendra K T <raghavendra.kt@linux.vnet.ibm.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-04-05simple_open: automatically convert to simple_open()Stephen Boyd
Many users of debugfs copy the implementation of default_open() when they want to support a custom read/write function op. This leads to a proliferation of the default_open() implementation across the entire tree. Now that the common implementation has been consolidated into libfs we can replace all the users of this function with simple_open(). This replacement was done with the following semantic patch: <smpl> @ open @ identifier open_f != simple_open; identifier i, f; @@ -int open_f(struct inode *i, struct file *f) -{ ( -if (i->i_private) -f->private_data = i->i_private; | -f->private_data = i->i_private; ) -return 0; -} @ has_open depends on open @ identifier fops; identifier open.open_f; @@ struct file_operations fops = { ... -.open = open_f, +.open = simple_open, ... }; </smpl> [akpm@linux-foundation.org: checkpatch fixes] Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Julia Lawall <Julia.Lawall@lip6.fr> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-21Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs pile 1 from Al Viro: "This is _not_ all; in particular, Miklos' and Jan's stuff is not there yet." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (64 commits) ext4: initialization of ext4_li_mtx needs to be done earlier debugfs-related mode_t whack-a-mole hfsplus: add an ioctl to bless files hfsplus: change finder_info to u32 hfsplus: initialise userflags qnx4: new helper - try_extent() qnx4: get rid of qnx4_bread/qnx4_getblk take removal of PF_FORKNOEXEC to flush_old_exec() trim includes in inode.c um: uml_dup_mmap() relies on ->mmap_sem being held, but activate_mm() doesn't hold it um: embed ->stub_pages[] into mmu_context gadgetfs: list_for_each_safe() misuse ocfs2: fix leaks on failure exits in module_init ecryptfs: make register_filesystem() the last potential failure exit ntfs: forgets to unregister sysctls on register_filesystem() failure logfs: missing cleanup on register_filesystem() failure jfs: mising cleanup on register_filesystem() failure make configfs_pin_fs() return root dentry on success configfs: configfs_create_dir() has parent dentry in dentry->d_parent configfs: sanitize configfs_create() ...
2012-03-20debugfs-related mode_t whack-a-moleAl Viro
all of those should be umode_t... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-02-02Merge 3.3-rc2 into the driver-core-next branch.Greg Kroah-Hartman
This was done to resolve a merge and build problem with the drivers/acpi/processor_driver.c file. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-01-26debugfs: add mode, uid and gid optionsLudwig Nussel
Cautious admins may want to restrict access to debugfs. Currently a manual chown/chmod e.g. in an init script is needed to achieve that. Distributions that want to make the mount options configurable need to add extra config files. By allowing to set the root inode's uid, gid and mode via mount options no such hacks are needed anymore. Instead configuration becomes straight forward via fstab. Signed-off-by: Ludwig Nussel <ludwig.nussel@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-23kernel-doc: fix new warnings in debugfsRandy Dunlap
Fix new kernel-doc warnings: Warning(fs/debugfs/file.c:556): No description found for parameter 'nregs' Warning(fs/debugfs/file.c:556): Excess function parameter 'mregs' description in 'debugfs_print_regs32' Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Cc: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-08Merge branch 'for-linus2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs * 'for-linus2' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (165 commits) reiserfs: Properly display mount options in /proc/mounts vfs: prevent remount read-only if pending removes vfs: count unlinked inodes vfs: protect remounting superblock read-only vfs: keep list of mounts for each superblock vfs: switch ->show_options() to struct dentry * vfs: switch ->show_path() to struct dentry * vfs: switch ->show_devname() to struct dentry * vfs: switch ->show_stats to struct dentry * switch security_path_chmod() to struct path * vfs: prefer ->dentry->d_sb to ->mnt->mnt_sb vfs: trim includes a bit switch mnt_namespace ->root to struct mount vfs: take /proc/*/mounts and friends to fs/proc_namespace.c vfs: opencode mntget() mnt_set_mountpoint() vfs: spread struct mount - remaining argument of next_mnt() vfs: move fsnotify junk to struct mount vfs: move mnt_devname vfs: move mnt_list to struct mount vfs: switch pnode.h macros to struct mount * ...
2012-01-03switch debugfs to umode_tAl Viro
2012-01-03vfs: for usbfs, etc. internal vfsmounts ->mnt_sb->s_root == ->mnt_rootAl Viro
2012-01-03debugfs: add missing #ifdef HAS_IOMEMHeiko Carstens
"debugfs: add tools to printk 32-bit registers" adds new functions which rely on IOMEM functionality which is not present on all architectures and therefore result in compile errors: fs/debugfs/file.c: In function 'debugfs_print_regs32': fs/debugfs/file.c:561:7: error: implicit declaration of function 'readl' [-Werror=implicit-function-declaration] Add an #ifdef CONFIG_HAS_IOMEM to fix this Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Acked-by: Alessandro Rubini <rubini@gnudd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-26debugfs: remove unneeded cast in debugfs_print_regs32()Dan Carpenter
The cast here causes a Sparse warning: fs/debugfs/file.c:561:42: warning: cast removes address space of expression fs/debugfs/file.c:561:42: warning: incorrect type in argument 1 (different address spaces) fs/debugfs/file.c:561:42: expected void const volatile [noderef] <asn:2>*addr fs/debugfs/file.c:561:42: got void *<noident> It's redundant to cast it to a (void *) anyway when it is already a (void __iomem *). Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-22debugfs: bugfix: include <linux/io.h> in file.cAlessandro Rubini
The regs32 machinery uses readl. I forgot the mandatory include and the code was not compiling on all archs. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Alessandro Rubini <rubini@gnudd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-18debugfs: print_regs32: make regs array a const pointerAlessandro Rubini
2011-11-18debugfs: add tools to printk 32-bit registersAlessandro Rubini
Some debugfs file I deal with are mostly blocks of registers, i.e. lines of the form "<name> = 0x<value>". Some files are only registers, some include registers blocks among other material. This patch introduces data structures and functions to deal with both cases. I expect more users of this over time. Signed-off-by: Alessandro Rubini <rubini@gnudd.com> Acked-by: Giancarlo Asnaghi <giancarlo.asnaghi@st.com> Cc: Felipe Balbi <balbi@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-08-22debugfs: Fix a comment mistakeHarry Wei
The file is fs/debugfs/inode.c but the comment says it is file.c. This patch can fix this little mistake. Signed-off-by: Harry Wei <harryxiyou@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-05-13debugfs: Silence DEBUG_STRICT_USER_COPY_CHECKS=y warningStephen Boyd
Enabling DEBUG_STRICT_USER_COPY_CHECKS causes the following warning: In file included from arch/x86/include/asm/uaccess.h:573, from include/linux/uaccess.h:5, from include/linux/highmem.h:7, from include/linux/pagemap.h:10, from fs/debugfs/file.c:18: In function 'copy_from_user', inlined from 'write_file_bool' at fs/debugfs/file.c:435: arch/x86/include/asm/uaccess_64.h:65: warning: call to 'copy_from_user_overflow' declared with attribute warning: copy_from_user() buffer size is not provably correct presumably due to buf_size being signed causing GCC to fail to see that buf_size can't become negative. Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-25debugfs: move to new strtoboolJonathan Cameron
No functional changes requires that we eat errors from strtobool. If people want to not do this, then it should be fixed at a later date. V2: Simplification suggested by Rusty Russell removes the need for additional variable ret. Signed-off-by: Jonathan Cameron <jic23@cam.ac.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-18debugfs: Fix filesystem reference counting on debugfs_remove() failureJan Kara
When __debugfs_remove() fails (because simple_rmdir() fails e.g. when a directory is not empty), we must not decrement use count of the filesystem as nothing was in fact deleted. This fixes use after free caused by debugfs in some cases. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
