path: root/fs/dlm/lockspace.c
2009-05-07dlm: fix use count with multiple joinsDavid Teigland
When a lockspace was joined multiple times, the global dlm use count was incremented when it should not have been. This caused the global dlm threads to not be stopped when all lockspaces were eventually be removed. Signed-off-by: David Teigland <teigland@redhat.com>
2009-05-07dlm: Make name input parameter of {,dlm_}new_lockspace() constGeert Uytterhoeven
| fs/gfs2/lock_dlm.c:207: warning: passing argument 1 of 'dlm_new_lockspace' discards qualifiers from pointer target type Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: David Teigland <teigland@redhat.com>
2009-01-28dlm: Change rwlock which is only used in write mode to a spinlockSteven Whitehouse
The ls_dirtbl[].lock was an rwlock, but since it was only used in write mode a spinlock will suffice. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Signed-off-by: David Teigland <teigland@redhat.com>
2009-01-08dlm: change rsbtbl rwlock to spinlockDavid Teigland
The rwlock is almost always used in write mode, so there's no reason to not use a spinlock instead. Signed-off-by: David Teigland <teigland@redhat.com>
2008-11-13dlm: fix shutdown cleanupDavid Teigland
Fixes a regression from commit 0f8e0d9a317406612700426fad3efab0b7bbc467, "dlm: allow multiple lockspace creates". An extraneous 'else' slipped into a code fragment being moved from release_lockspace() to dlm_release_lockspace(). The result of the unwanted 'else' is that dlm threads and structures are not stopped and cleaned up when the final dlm lockspace is removed. Trying to create a new lockspace again afterward will fail with "kmem_cache_create: duplicate cache dlm_conn" because the cache was not previously destroyed. Signed-off-by: David Teigland <teigland@redhat.com>
2008-08-28dlm: fix locking of lockspace list in dlm_scandDavid Teigland
The dlm_scand thread needs to lock the list of lockspaces when going through it. Signed-off-by: David Teigland <teigland@redhat.com>
2008-08-28dlm: detect available userspace daemonDavid Teigland
If dlm_controld (the userspace daemon that controls the setup and recovery of the dlm) fails, the kernel should shut down the lockspaces in the kernel rather than leaving them running. This is detected by having dlm_controld hold a misc device open while running, and if the kernel detects a close while the daemon is still needed, it stops the lockspaces in the kernel. Knowing that the userspace daemon isn't running also allows the lockspace create/remove routines to avoid waiting on the daemon for join/leave operations. Signed-off-by: David Teigland <teigland@redhat.com>
2008-08-28dlm: allow multiple lockspace createsDavid Teigland
Add a count for lockspace create and release so that create can be called multiple times to use the lockspace from different places. Also add the new flag DLM_LSFL_NEWEXCL to create a lockspace with the previous behavior of returning -EEXIST if the lockspace already exists. Signed-off-by: David Teigland <teigland@redhat.com>
2008-04-30fs: replace remaining __FUNCTION__ occurrencesHarvey Harrison
2008-02-06dlm: add __init and __exit marks to init and exit functionsDenis Cheng
it moves 365 bytes from .text to .init.text, and 30 bytes from .text to .exit.text, saves memory. Signed-off-by: Denis Cheng <crquan@gmail.com> Signed-off-by: David Teigland <teigland@redhat.com>
2008-01-29dlm: use dlm prefix on alloc and free functionsDavid Teigland
The dlm functions in memory.c should use the dlm_ prefix. Also, use kzalloc/kfree directly for dlm_direntry's, removing the wrapper functions. Signed-off-by: David Teigland <teigland@redhat.com>
2008-01-29dlm: proper prototypesAdrian Bunk
This patch adds a proper prototype for some functions in fs/dlm/dlm_internal.h Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David Teigland <teigland@redhat.com>
2008-01-24Kobject: convert fs/* from kobject_unregister() to kobject_put()Greg Kroah-Hartman
There is no need for kobject_unregister() anymore, thanks to Kay's kobject cleanup changes, so replace all instances of it with kobject_put(). Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24Kobject: change GFS2 to use kobject_init_and_addGreg Kroah-Hartman
Stop using kobject_register, as this way we can control the sending of the uevent properly, after everything is properly initialized. Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24kobject: convert kernel_kset to be a kobjectGreg Kroah-Hartman
kernel_kset does not need to be a kset, but a much simpler kobject now that we have kobj_attributes. We also rename kernel_kset to kernel_kobj to catch all users of this symbol with a build error instead of an easy-to-ignore build warning. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24kset: convert kernel_subsys to use kset_createGreg Kroah-Hartman
Dynamically create the kset instead of declaring it statically. We also rename kernel_subsys to kernel_kset to catch all users of this symbol with a build error instead of an easy-to-ignore build warning. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24kset: convert dlm to use kset_createGreg Kroah-Hartman
Dynamically create the kset instead of declaring it statically. Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Steven Whitehouse <swhiteho@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24kobject: remove struct kobj_type from struct ksetGreg Kroah-Hartman
We don't need a "default" ktype for a kset. We should set this explicitly every time for each kset. This change is needed so that we can make ksets dynamic, and cleans up one of the odd, undocumented assumption that the kset/kobject/ktype model has. This patch is based on a lot of help from Kay Sievers. Nasty bug in the block code was found by Dave Young <hidave.darkstar@gmail.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Dave Young <hidave.darkstar@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/driver-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/gregkh/driver-2.6: (75 commits) PM: merge device power-management source files sysfs: add copyrights kobject: update the copyrights kset: add some kerneldoc to help describe what these strange things are Driver core: rename ktype_edd and ktype_efivar Driver core: rename ktype_driver Driver core: rename ktype_device Driver core: rename ktype_class driver core: remove subsystem_init() sysfs: move sysfs file poll implementation to sysfs_open_dirent sysfs: implement sysfs_open_dirent sysfs: move sysfs_dirent->s_children into sysfs_dirent->s_dir sysfs: make sysfs_root a regular directory dirent sysfs: open code sysfs_attach_dentry() sysfs: make s_elem an anonymous union sysfs: make bin attr open get active reference of parent too sysfs: kill unnecessary NULL pointer check in sysfs_release() sysfs: kill unnecessary sysfs_get() in open paths sysfs: reposition sysfs_dirent->s_mode. sysfs: kill sysfs_update_file() ...
2007-10-12Drivers: clean up direct setting of the name of a ksetGreg Kroah-Hartman
A kset should not have its name set directly, so dynamically set the name at runtime. This is needed to remove the static array in the kobject structure which will be changed in a future patch. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-10[DLM] block dlm_recv in recovery transitionDavid Teigland
Introduce a per-lockspace rwsem that's held in read mode by dlm_recv threads while working in the dlm. This allows dlm_recv activity to be suspended when the lockspace transitions to, from and between recovery cycles. The specific bug prompting this change is one where an in-progress recovery cycle is aborted by a new recovery cycle. While dlm_recv was processing a recovery message, the recovery cycle was aborted and dlm_recoverd began cleaning up. dlm_recv decremented recover_locks_count on an rsb after dlm_recoverd had reset it to zero. This is fixed by suspending dlm_recv (taking write lock on the rwsem) before aborting the current recovery. The transitions to/from normal and recovery modes are simplified by using this new ability to block dlm_recv. The switch from normal to recovery mode means dlm_recv goes from processing locking messages, to saving them for later, and vice versa. Races are avoided by blocking dlm_recv when setting the flag that switches between modes. Signed-off-by: David Teigland <teigland@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2007-07-09[DLM] don't require FS flag on all nodesDavid Teigland
Mask off the recently added DLM_LSFL_FS flag when setting the exflags. This way all the nodes in the lockspace aren't required to have the FS flag set, since we later check that exflags matches among all nodes. Signed-off-by: Patrick Caulfield <pcaulfie@redhat.com> Signed-off-by: David Teigland <teigland@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2007-07-09[DLM] variable allocationPatrick Caulfield
Add a new flag, DLM_LSFL_FS, to be used when a file system creates a lockspace. This flag causes the dlm to use GFP_NOFS for allocations instead of GFP_KERNEL. (This updated version of the patch uses gfp_t for ls_allocation.) Signed-Off-By: Patrick Caulfield <pcaulfie@redhat.com> Signed-Off-By: David Teigland <teigland@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2007-07-09[DLM] wait for config check during join [6/6]David Teigland
Joining the lockspace should wait for the initial round of inter-node config checks to complete before returning. This way, if there's a configuration mismatch between the joining node and the existing nodes, the join can fail and return an error to the application. Signed-off-by: David Teigland <teigland@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2007-07-09[DLM] fix new_lockspace error exit [5/6]David Teigland
Fix the error path when exiting new_lockspace(). It was kfree'ing the lockspace struct at the end, but that's only valid if it exits before kobject_register occured. After kobject_register we have to let the kobject do the freeing. Signed-off-by: David Teigland <teigland@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2007-07-09[DLM] add lock timeouts and warnings [2/6]David Teigland
New features: lock timeouts and time warnings. If the DLM_LKF_TIMEOUT flag is set, then the request/conversion will be canceled after waiting the specified number of centiseconds (specified per lock). This feature is only available for locks requested through libdlm (can be enabled for kernel dlm users if there's a use for it.) If the new DLM_LSFL_TIMEWARN flag is set when creating the lockspace, then a warning message will be sent to userspace (using genetlink) after a request/conversion has been waiting for a given number of centiseconds (configurable per node). The time warnings will be used in the future to do deadlock detection in userspace. Signed-off-by: David Teigland <teigland@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2007-07-09[DLM] block scand during recovery [1/6]David Teigland
Don't let dlm_scand run during recovery since it may try to do a resource directory removal while the directory nodes are changing. Signed-off-by: David Teigland <teigland@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2007-05-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-2.6-nmwLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-2.6-nmw: (34 commits) [GFS2] Uncomment sprintf_symbol calling code [DLM] lowcomms style [GFS2] printk warning fixes [GFS2] Patch to fix mmap of stuffed files [GFS2] use lib/parser for parsing mount options [DLM] Lowcomms nodeid range & initialisation fixes [DLM] Fix dlm_lowcoms_stop hang [DLM] fix mode munging [GFS2] lockdump improvements [GFS2] Patch to detect corrupt number of dir entries in leaf and/or inode blocks [GFS2] bz 236008: Kernel gpf doing cat /debugfs/gfs2/xxx (lock dump) [DLM] fs/dlm/ast.c should #include "ast.h" [DLM] Consolidate transport protocols [DLM] Remove redundant assignment [GFS2] Fix bz 234168 (ignoring rgrp flags) [DLM] change lkid format [DLM] interface for purge (2/2) [DLM] add orphan purging code (1/2) [DLM] split create_message function [GFS2] Set drop_count to 0 (off) by default ...
2007-05-02remove "struct subsystem" as it is no longer neededGreg Kroah-Hartman
We need to work on cleaning up the relationship between kobjects, ksets and ktypes. The removal of 'struct subsystem' is the first step of this, especially as it is not really needed at all. Thanks to Kay for fixing the bugs in this patch. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-05-01[DLM] overlapping cancel and unlockDavid Teigland
Full cancel and force-unlock support. In the past, cancel and force-unlock wouldn't work if there was another operation in progress on the lock. Now, both cancel and unlock-force can overlap an operation on a lock, meaning there may be 2 or 3 operations in progress on a lock in parallel. This support is important not only because cancel and force-unlock are explicit operations that an app can use, but both are used implicitly when a process exits while holding locks. Summary of changes: - add-to and remove-from waiters functions were rewritten to handle situations with more than one remote operation outstanding on a lock - validate_unlock_args detects when an overlapping cancel/unlock-force can be sent and when it needs to be delayed until a request/lookup reply is received - processing request/lookup replies detects when cancel/unlock-force occured during the op, and carries out the delayed cancel/unlock-force - manipulation of the "waiters" (remote operation) state of a lock moved under the standard rsb mutex that protects all the other lock state - the two recovery routines related to locks on the waiters list changed according to the way lkb's are now locked before accessing waiters state - waiters recovery detects when lkb's being recovered have overlapping cancel/unlock-force, and may not recover such locks - revert_lock (cancel) returns a value to distinguish cases where it did nothing vs cases where it actually did a cancel; the cancel completion ast should only be done when cancel did something - orphaned locks put on new list so they can be found later for purging - cancel must be called on a lock when making it an orphan - flag user locks (ENDOFLIFE) at the end of their useful life (to the application) so we can return an error for any further cancel/unlock-force - we weren't setting COMP/BAST ast flags if one was already set, so we'd lose either a completion or blocking ast - clear an unread bast on a lock that's become unlocked Signed-off-by: David Teigland <teigland@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2007-02-05[DLM] rename dlm_config_info fieldsDavid Teigland
Add a "ci_" prefix to the fields in the dlm_config_info struct so that we can use macros to add configfs functions to access them (in a later patch). No functional changes in this patch, just naming changes. Signed-off-by: David Teigland <teigland@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-11-30[DLM] don't accept replies to old recovery messagesDavid Teigland
We often abort a recovery after sending a status request to a remote node. We want to ignore any potential status reply we get from the remote node. If we get one of these unwanted replies, we've often moved on to the next recovery message and incremented the message sequence counter, so the reply will be ignored due to the seq number. In some cases, we've not moved on to the next message so the seq number of the reply we want to ignore is still correct, causing the reply to be accepted. The next recovery message will then mistake this old reply as a new one. To fix this, we add the flag RCOM_WAIT to indicate when we can accept a new reply. We clear this flag if we abort recovery while waiting for a reply. Before the flag is set again (to allow new replies) we know that any old replies will be rejected due to their sequence number. We also initialize the recovery-message sequence number to a random value when a lockspace is first created. This makes it clear when messages are being rejected from an old instance of a lockspace that has since been recreated. Signed-off-by: David Teigland <teigland@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-11-30[DLM] fix add_requestqueue checking nodes listDavid Teigland
Requests that arrive after recovery has started are saved in the requestqueue and processed after recovery is done. Some of these requests are purged during recovery if they are from nodes that have been removed. We move the purging of the requests (dlm_purge_requestqueue) to later in the recovery sequence which allows the routine saving requests (dlm_add_requestqueue) to avoid filtering out requests by nodeid since the same will be done by the purge. The current code has add_requestqueue filtering by nodeid but doesn't hold any locks when accessing the list of current nodes. This also means that we need to call the purge routine when the lockspace is being shut down since the add routine will not be rejecting requests itself any more. Signed-off-by: David Teigland <teigland@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-11-06[DLM] fix oops in kref_put when removing a lockspacePatrick Caulfield
Now that the lockspace struct is freed when the last sysfs object is released this patch prevents use of that lockspace by sysfs. We attempt to re-get the lockspace from the lockspace list and fail the request if it has been removed. Signed-Off-By: Patrick Caulfield <pcaulfie@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-11-06[DLM] Fix kref_put oopsPatrick Caulfield
This patch fixes the recounting on the lockspace kobject. Previously the lockspace was freed while userspace could have had a reference to one of its sysfs files, causing an oops in kref_put. Now the lockspace kfree is moved into the kobject release() function Signed-Off-By: Patrick Caulfield <pcaulfie@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-09-07[DLM] use snprintf in sysfs showDavid Teigland
Use snprintf(buf, PAGE_SIZE, ...) instead of sprintf in sysfs show methods. Signed-off-by: David Teigland <teigland@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-08-25[DLM] add new lockspace to list ealierDavid Teigland
When a new lockspace was being created, the recoverd thread was being started for it before the lockspace was added to the global list of lockspaces. The new thread was looking up the lockspace in the global list and sometimes not finding it due to the race with the original thread adding it to the list. We need to add the lockspace to the global list before starting the thread instead of after, and if the new thread can't find the lockspace for some reason, it should return an error. Signed-off-by: David Teigland <teigland@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-08-09[DLM] show nodeid for recovery messageDavid Teigland
To aid debugging, it's useful to be able to see what nodeid the dlm is waiting on for a message reply. Signed-off-by: David Teigland <teigland@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-07-26[DLM] more info through debugfsDavid Teigland
Display more information from debugfs, particularly locks waiting for a master lookup or operations waiting for a remote reply. Signed-off-by: David Teigland <teigland@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-07-13[DLM] dlm: user locksDavid Teigland
This changes the way the dlm handles user locks. The core dlm is now aware of user locks so they can be dealt with more efficiently. There is no more dlm_device module which previously managed its own duplicate copy of every user lock. Signed-off-by: Patrick Caulfield <pcaulfie@redhat.com> Signed-off-by: David Teigland <teigland@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-04-28[DLM] PATCH 3/3 dlm: show recover stateDavid Teigland
Expose the current recovery state in sysfs to help in debugging. Signed-off-by: David Teigland <teigland@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-01-20[DLM] Update DLM to the latest patch levelDavid Teigland
Signed-off-by: David Teigland <teigland@redhat.com> Signed-off-by: Steve Whitehouse <swhiteho@redhat.com>
2006-01-18[DLM] The core of the DLM for GFS2/CLVMDavid Teigland
This is the core of the distributed lock manager which is required to use GFS2 as a cluster filesystem. It is also used by CLVM and can be used as a standalone lock manager independantly of either of these two projects. It implements VAX-style locking modes. Signed-off-by: David Teigland <teigland@redhat.com> Signed-off-by: Steve Whitehouse <swhiteho@redhat.com>
