path: root/fs/dlm
2011-03-10dlm: use alloc_workqueue functionDavid Teigland
Replaces deprecated create_singlethread_workqueue(). Signed-off-by: David Teigland <teigland@redhat.com>
2011-03-10dlm: increase default hash table sizesDavid Teigland
Make all three hash tables a consistent size of 1024 rather than 1024, 512, 256. All three tables, for resources, locks, and lock dir entries, will generally be filled to the same order of magnitude. Signed-off-by: David Teigland <teigland@redhat.com>
2011-03-10dlm: record full callback stateDavid Teigland
Change how callbacks are recorded for locks. Previously, information about multiple callbacks was combined into a couple of variables that indicated what the end result should be. In some situations, we could not tell from this combined state what the exact sequence of callbacks were, and would end up either delivering the callbacks in the wrong order, or suppress redundant callbacks incorrectly. This new approach records all the data for each callback, leaving no uncertainty about what needs to be delivered. Signed-off-by: David Teigland <teigland@redhat.com>
2011-02-11dlm: use single thread workqueuesDavid Teigland
The recent commit to use cmwq for send and recv threads dcce240ead802d42b1e45ad2fcb2ed4a399cb255 introduced problems, apparently due to multiple workqueue threads. Single threads make the problems go away, so return to that until we fully understand the concurrency issues with multiple threads. Signed-off-by: David Teigland <teigland@redhat.com>
2011-01-16dlm: Make DLM depend on CONFIGFS_FSNicholas Bellinger
This patch fixes the following kconfig error after changing CONFIGFS_FS -> select SYSFS: fs/sysfs/Kconfig:1:error: recursive dependency detected! fs/sysfs/Kconfig:1: symbol SYSFS is selected by CONFIGFS_FS fs/configfs/Kconfig:1: symbol CONFIGFS_FS is selected by DLM fs/dlm/Kconfig:1: symbol DLM depends on SYSFS Signed-off-by: Nicholas A. Bellinger <nab@linux-iscsi.org> Cc: Joel Becker <jlbec@evilplan.org> Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: James Bottomley <James.Bottomley@suse.de>
2010-12-13dlm: sanitize work_start() in lowcomms.cNamhyung Kim
The create_workqueue() returns NULL if failed rather than ERR_PTR(). Fix error checking and remove unnecessary variable 'error'. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: David Teigland <teigland@redhat.com>
2010-11-12dlm: reduce cond_resched during sendBob Peterson
Calling cond_resched() after every send can unnecessarily degrade performance. Go back to an old method of scheduling after 25 messages. Signed-off-by: Bob Peterson <rpeterso@redhat.com> Signed-off-by: David Teigland <teigland@redhat.com>
2010-11-12dlm: use TCP_NODELAYDavid Teigland
Nagling doesn't help and can sometimes hurt dlm comms. Signed-off-by: David Teigland <teigland@redhat.com>
2010-11-12dlm: Use cmwq for send and receive workqueuesSteven Whitehouse
So far as I can tell, there is no reason to use a single-threaded send workqueue for dlm, since it may need to send to several sockets concurrently. Both workqueues are set to WQ_MEM_RECLAIM to avoid any possible deadlocks, WQ_HIGHPRI since locking traffic is highly latency sensitive (and to avoid a priority inversion wrt GFS2's glock_workqueue) and WQ_FREEZABLE just in case someone needs to do that (even though with current cluster infrastructure, it doesn't make sense as the node will most likely land up ejected from the cluster) in the future. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: David Teigland <teigland@redhat.com>
2010-11-11dlm: Handle application limited situations properly.David Miller
In the normal regime where an application uses non-blocking I/O writes on a socket, they will handle -EAGAIN and use poll() to wait for send space. They don't actually sleep on the socket I/O write. But kernel level RPC layers that do socket I/O operations directly and key off of -EAGAIN on the write() to "try again later" don't use poll(), they instead have their own sleeping mechanism and rely upon ->sk_write_space() to trigger the wakeup. So they do effectively sleep on the write(), but this mechanism alone does not let the socket layers know what's going on. Therefore they must emulate what would have happened, otherwise TCP cannot possibly see that the connection is application window size limited. Handle this, therefore, like SUNRPC by setting SOCK_NOSPACE and bumping the ->sk_write_count as needed when we hit the send buffer limits. This should make TCP send buffer size auto-tuning and the ->sk_write_space() callback invocations actually happen. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: David Teigland <teigland@redhat.com>
2010-10-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/teigland/dlm * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/teigland/dlm: dlm: Fix dlm lock status block comment in dlm.h dlm: Don't send callback to node making lock request when "try 1cb" fails
All file_operations should get a .llseek operation so we can make nonseekable_open the default for future file operations without a .llseek pointer. The three cases that we can automatically detect are no_llseek, seq_lseek and default_llseek. For cases where we can we can automatically prove that the file offset is always ignored, we use noop_llseek, which maintains the current behavior of not returning an error from a seek. New drivers should normally not use noop_llseek but instead use no_llseek and call nonseekable_open at open time. Existing drivers can be converted to do the same when the maintainer knows for certain that no user code relies on calling seek on the device file. The generated code is often incorrectly indented and right now contains comments that clarify for each added line why a specific variant was chosen. In the version that gets submitted upstream, the comments will be gone and I will manually fix the indentation, because there does not seem to be a way to do that using coccinelle. Some amount of new code is currently sitting in linux-next that should get the same modifications, which I will do at the end of the merge window. Many thanks to Julia Lawall for helping me learn to write a semantic patch that does all this. ===== begin semantic patch ===== // This adds an llseek= method to all file operations, // as a preparation for making no_llseek the default. // // The rules are // - use no_llseek explicitly if we do nonseekable_open // - use seq_lseek for sequential files // - use default_llseek if we know we access f_pos // - use noop_llseek if we know we don't access f_pos, // but we still want to allow users to call lseek // @ open1 exists @ identifier nested_open; @@ nested_open(...) { <+... nonseekable_open(...) ...+> } @ open exists@ identifier open_f; identifier i, f; identifier open1.nested_open; @@ int open_f(struct inode *i, struct file *f) { <+... ( nonseekable_open(...) | nested_open(...) ) ...+> } @ read disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ read_no_fpos disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { ... when != off } @ write @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ write_no_fpos @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { ... when != off } @ fops0 @ identifier fops; @@ struct file_operations fops = { ... }; @ has_llseek depends on fops0 @ identifier fops0.fops; identifier llseek_f; @@ struct file_operations fops = { ... .llseek = llseek_f, ... }; @ has_read depends on fops0 @ identifier fops0.fops; identifier read_f; @@ struct file_operations fops = { ... .read = read_f, ... }; @ has_write depends on fops0 @ identifier fops0.fops; identifier write_f; @@ struct file_operations fops = { ... .write = write_f, ... }; @ has_open depends on fops0 @ identifier fops0.fops; identifier open_f; @@ struct file_operations fops = { ... .open = open_f, ... }; // use no_llseek if we call nonseekable_open //////////////////////////////////////////// @ nonseekable1 depends on !has_llseek && has_open @ identifier fops0.fops; identifier nso ~= "nonseekable_open"; @@ struct file_operations fops = { ... .open = nso, ... +.llseek = no_llseek, /* nonseekable */ }; @ nonseekable2 depends on !has_llseek @ identifier fops0.fops; identifier open.open_f; @@ struct file_operations fops = { ... .open = open_f, ... +.llseek = no_llseek, /* open uses nonseekable */ }; // use seq_lseek for sequential files ///////////////////////////////////// @ seq depends on !has_llseek @ identifier fops0.fops; identifier sr ~= "seq_read"; @@ struct file_operations fops = { ... .read = sr, ... +.llseek = seq_lseek, /* we have seq_read */ }; // use default_llseek if there is a readdir /////////////////////////////////////////// @ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier readdir_e; @@ // any other fop is used that changes pos struct file_operations fops = { ... .readdir = readdir_e, ... +.llseek = default_llseek, /* readdir is present */ }; // use default_llseek if at least one of read/write touches f_pos ///////////////////////////////////////////////////////////////// @ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read.read_f; @@ // read fops use offset struct file_operations fops = { ... .read = read_f, ... +.llseek = default_llseek, /* read accesses f_pos */ }; @ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, ... + .llseek = default_llseek, /* write accesses f_pos */ }; // Use noop_llseek if neither read nor write accesses f_pos /////////////////////////////////////////////////////////// @ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; identifier write_no_fpos.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, .read = read_f, ... +.llseek = noop_llseek, /* read and write both use no f_pos */ }; @ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write_no_fpos.write_f; @@ struct file_operations fops = { ... .write = write_f, ... +.llseek = noop_llseek, /* write uses no f_pos */ }; @ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; @@ struct file_operations fops = { ... .read = read_f, ... +.llseek = noop_llseek, /* read uses no f_pos */ }; @ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; @@ struct file_operations fops = { ... +.llseek = noop_llseek, /* no read or write fn */ }; ===== End semantic patch ===== Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Julia Lawall <julia@diku.dk> Cc: Christoph Hellwig <hch@infradead.org>
2010-09-03dlm: Don't send callback to node making lock request when "try 1cb" failsSteven Whitehouse
When converting a lock, an lkb is in the granted state and also being used to request a new state. In the case that the conversion was a "try 1cb" type which has failed, and if the new state was incompatible with the old state, a callback was being generated to the requesting node. This is incorrect as callbacks should only be sent to all the other nodes holding blocking locks. The requesting node should receive the normal (failed) response to its "try 1cb" conversion request only. This was discovered while debugging a performance problem on GFS2, however this fix also speeds up GFS as well. In the GFS2 case the performance gain is over 10x for cases of write activity to an inode whose glock is cached on another, idle (wrt that glock) node. (comment added, dct) Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Tested-by: Abhijith Das <adas@redhat.com> Signed-off-by: David Teigland <teigland@redhat.com>
2010-08-05fs/dlm: Drop unnecessary null testJulia Lawall
hlist_for_each_entry binds its first argument to a non-null value, and thus any null test on the value of that argument is superfluous. The semantic patch that makes this change is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ iterator I; expression x,E,E1,E2; statement S,S1,S2; @@ I(x,...) { <... - (x != NULL) && E ...> } // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: David Teigland <teigland@redhat.com>
2010-08-05dlm: use genl_register_family_with_ops()Changli Gao
Signed-off-by: Changli Gao <xiaosuo@gmail.com> Signed-off-by: David Teigland <teigland@redhat.com>
2010-04-30dlm: fix ast ordering for user locksDavid Teigland
Commit 7fe2b3190b8b299409f13cf3a6f85c2bd371f8bb fixed possible misordering of completion asts (casts) and blocking asts (basts) for kernel locks. This patch does the same for locks taken by user space applications. Signed-off-by: David Teigland <teigland@redhat.com>
2010-04-30dlm: cleanup remove unused codeDan Carpenter
Smatch complains because "lkb" is never NULL. Looking at it, the original code actually adds the new element to the end of the list fine, so we can just get rid of the if condition. This code is four years old and no one has complained so it must work. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: David Teigland <teigland@redhat.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (56 commits) doc: fix typo in comment explaining rb_tree usage Remove fs/ntfs/ChangeLog doc: fix console doc typo doc: cpuset: Update the cpuset flag file Fix of spelling in arch/sparc/kernel/leon_kernel.c no longer needed Remove drivers/parport/ChangeLog Remove drivers/char/ChangeLog doc: typo - Table 1-2 should refer to "status", not "statm" tree-wide: fix typos "ass?o[sc]iac?te" -> "associate" in comments No need to patch AMD-provided drivers/gpu/drm/radeon/atombios.h devres/irq: Fix devm_irq_match comment Remove reference to kthread_create_on_cpu tree-wide: Assorted spelling fixes tree-wide: fix 'lenght' typo in comments and code drm/kms: fix spelling in error message doc: capitalization and other minor fixes in pnp doc devres: typo fix s/dev/devm/ Remove redundant trailing semicolons from macros fix typo "definetly" -> "definitely" in comment tree-wide: s/widht/width/g typo in comments ... Fix trivial conflict in Documentation/laptops/00-INDEX
2010-03-08Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: Documentation/filesystems/proc.txt arch/arm/mach-u300/include/mach/debug-macro.S drivers/net/qlge/qlge_ethtool.c drivers/net/qlge/qlge_main.c drivers/net/typhoon.c
2010-03-07Driver core: Constify struct sysfs_ops in struct kobj_typeEmese Revfy
Constify struct sysfs_ops. This is part of the ops structure constification effort started by Arjan van de Ven et al. Benefits of this constification: * prevents modification of data that is shared (referenced) by many other structure instances at runtime * detects/prevents accidental (but not intentional) modification attempts on archs that enforce read-only kernel data at runtime * potentially better optimized code as the compiler can assume that the const data cannot be changed * the compiler/linker move const data into .rodata and therefore exclude them from false sharing Signed-off-by: Emese Revfy <re.emese@gmail.com> Acked-by: David Teigland <teigland@redhat.com> Acked-by: Matt Domsch <Matt_Domsch@dell.com> Acked-by: Maciej Sosnowski <maciej.sosnowski@intel.com> Acked-by: Hans J. Koch <hjk@linutronix.de> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Jens Axboe <jens.axboe@oracle.com> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-02-26dlm: use bastmode in debugfs outputDavid Teigland
The bast mode that appears in the debugfs output should be useful on both master and process nodes. lkb_highbast is currently printed, and is only useful on the master node. lkb_bastmode is only useful on the process node. This patch sets lkb_bastmode on the master node as well, and uses that value in the debugfs print. Signed-off-by: David Teigland <teigland@redhat.com>
2010-02-26dlm: Send lockspace name with ueventsSteven Whitehouse
Although it is possible to get this information from the path, its much easier to provide the lockspace as a seperate env variable. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Signed-off-by: David Teigland <teigland@redhat.com>
2010-02-26dlm: send reply before bastDavid Teigland
When the lock master processes a successful operation (request, convert, cancel, or unlock), it will process the effects of the change before sending the reply for the operation. The "effects" of the operation are: - blocking callbacks (basts) for any newly granted locks - waiting or converting locks that can now be granted The cast is queued on the local node when the reply from the lock master is received. This means that a lock holder can receive a bast for a lock mode that is doesn't yet know has been granted. Signed-off-by: David Teigland <teigland@redhat.com>
2010-02-24dlm: fix ordering of bast and castDavid Teigland
When both blocking and completion callbacks are queued for lock, the dlm would always deliver the completion callback (cast) first. In some cases the blocking callback (bast) is queued before the cast, though, and should be delivered first. This patch keeps track of the order in which they were queued and delivers them in that order. This patch also keeps track of the granted mode in the last cast and eliminates the following bast if the bast mode is compatible with the preceding cast mode. This happens when a remotely mastered lock is demoted, e.g. EX->NL, in which case the local node queues a cast immediately after sending the demote message. In this way a cast can be queued for a mode, e.g. NL, that makes an in-transit bast extraneous. Signed-off-by: David Teigland <teigland@redhat.com>
2010-02-04Fix misspellings of "truly" in comments.Adam Buchbinder
Some comments misspell "truly"; this fixes them. No code changes. Signed-off-by: Adam Buchbinder <adam.buchbinder@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-12-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/teigland/dlm * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/teigland/dlm: dlm: always use GFP_NOFS
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-11-30dlm: always use GFP_NOFSDavid Teigland
Replace all GFP_KERNEL and ls_allocation with GFP_NOFS. ls_allocation would be GFP_KERNEL for userland lockspaces and GFP_NOFS for file system lockspaces. It was discovered that any lockspaces on the system can affect all others by triggering memory reclaim in the file system which could in turn call back into the dlm to acquire locks, deadlocking dlm threads that were shared by all lockspaces, like dlm_recv. Signed-off-by: David Teigland <teigland@redhat.com>
2009-09-30dlm: fix socket fd translationDavid Teigland
The code to set up sctp sockets was not using the sockfd_lookup() and sockfd_put() routines to translate an fd to a socket. The direct fget and fput calls were resulting in error messages from alloc_fd(). Also clean up two log messages and remove a third, related to setting up sctp associations. Signed-off-by: David Teigland <teigland@redhat.com>
2009-09-30dlm: fix lowcomms_connect_node for sctpDavid Teigland
The recently added dlm_lowcomms_connect_node() from 391fbdc5d527149578490db2f1619951d91f3561 does not work when using SCTP instead of TCP. The sctp connection code has nothing to do without data to send. Check for no data in the sctp connection code and do nothing instead of triggering a BUG. Also have connect_node() do nothing when the protocol is sctp. Signed-off-by: David Teigland <teigland@redhat.com>
2009-09-23seq_file: constify seq_operationsJames Morris
Make all seq_operations structs const, to help mitigate against revectoring user-triggerable function pointers. This is derived from the grsecurity patch, although generated from scratch because it's simpler than extracting the changes from there. Signed-off-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Acked-by: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-18Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/teigland/dlm * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/teigland/dlm: dlm: use kernel_sendpage dlm: fix connection close handling dlm: fix double-release of socket in error exit path
2009-08-24dlm: use kernel_sendpagePaolo Bonzini
Using kernel_sendpage() is cleaner and safer than following sock->ops ourselves. Signed-off-by: Paolo Bonzini <bonzini@gnu.org> Signed-off-by: David Teigland <teigland@redhat.com>
2009-08-24dlm: fix connection close handlingLars Marowsky-Bree
Closing a connection to a node can create problems if there are outstanding messages for that node. The problems include dlm_send spinning attempting to reconnect, or BUG from tcp_connect_to_sock() attempting to use a partially closed connection. To cleanly close a connection, we now first attempt to send any pending messages, cancel any remaining workqueue work, and flag the connection as closed to avoid reconnect attempts. Signed-off-by: Lars Marowsky-Bree <lmb@suse.de> Signed-off-by: Christine Caulfield <ccaulfie@redhat.com> Signed-off-by: David Teigland <teigland@redhat.com>
2009-08-18dlm: fix double-release of socket in error exit pathCasey Dahlin
The last correction to the tcp_connect_to_sock error exit path, commit a89d63a159b1ba5833be2bef00adf8ad8caac8be, can free an already freed socket, due to collision with a previous (incomplete) attempt to fix the same issue, commit 311f6fc77c51926dbdfbeab0a5d88d70f01fa3f4. Signed-off-by: Casey Dahlin <cdahlin@redhat.com> Signed-off-by: David Teigland <teigland@redhat.com>
2009-08-12Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: arch/microblaze/include/asm/socket.h
2009-07-14dlm: free socket in error exit pathCasey Dahlin
In the tcp_connect_to_sock() error exit path, the socket allocated at the top of the function was not being freed. Signed-off-by: Casey Dahlin <cdahlin@redhat.com> Signed-off-by: David Teigland <teigland@redhat.com>
2009-07-12genetlink: make netns awareJohannes Berg
This makes generic netlink network namespace aware. No generic netlink families except for the controller family are made namespace aware, they need to be checked one by one and then set the family->netnsok member to true. A new function genlmsg_multicast_netns() is introduced to allow sending a multicast message in a given namespace, for example when it applies to an object that lives in that namespace, a new function genlmsg_multicast_allns() to send a message to all network namespaces (for objects that do not have an associated netns). The function genlmsg_multicast() is changed to multicast the message in just init_net, which is currently correct for all generic netlink families since they only work in init_net right now. Some will later want to work in all net namespaces because they do not care about the netns at all -- those will have to be converted to use one of the new functions genlmsg_multicast_allns() or genlmsg_multicast_netns() whenever they are made netns aware in some way. After this patch families can easily decide whether or not they should be available in all net namespaces. Many genl families us it for objects not related to networking and should therefore be available in all namespaces, but that will have to be done on a per family basis. Note that this doesn't touch on the checkpoint/restart problem where network namespaces could be used, genl families and multicast groups are numbered globally and I see no easy way of changing that, especially since it must be possible to multicast to all network namespaces for those families that do not care about netns. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-18dlm: fix plock use-after-freeDavid Teigland
Fix a regression from the original addition of nfs lock support 586759f03e2e9031ac5589912a51a909ed53c30a. When a synchronous (non-nfs) plock completes, the waiting thread will wake up and free the op struct. This races with the user thread in dev_write() which goes on to read the op's callback field to check if the lock is async and needs a callback. This check can happen on the freed op. The fix is to note the callback value before the op can be freed. Signed-off-by: David Teigland <teigland@redhat.com>
2009-06-17dlm: Fix uninitialised variable warning in lock.cSteven Whitehouse
CC [M] fs/dlm/lock.o fs/dlm/lock.c: In function ‘find_rsb’: fs/dlm/lock.c:438: warning: ‘r’ may be used uninitialized in this function Since r is used on the error path to set r_ret, set it to NULL. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Signed-off-by: David Teigland <teigland@redhat.com>
2009-05-15dlm: use more NOFS allocationDavid Teigland
Change some GFP_KERNEL allocations to use either GFP_NOFS or ls_allocation (when available) which the fs sets to GFP_NOFS. The point is to prevent allocations from going back into the cluster fs in places where that might lead to deadlock. Signed-off-by: David Teigland <teigland@redhat.com>
2009-05-15dlm: connect to nodes earlierChristine Caulfield
Make network connections to other nodes earlier, in the context of dlm_recoverd. This avoids connecting to nodes from dlm_send where we try to avoid allocations which could possibly deadlock if memory reclaim goes into the cluster fs which may try to do a dlm operation. Signed-off-by: Christine Caulfield <ccaulfie@redhat.com> Signed-off-by: David Teigland <teigland@redhat.com>
2009-05-07dlm: fix use count with multiple joinsDavid Teigland
When a lockspace was joined multiple times, the global dlm use count was incremented when it should not have been. This caused the global dlm threads to not be stopped when all lockspaces were eventually be removed. Signed-off-by: David Teigland <teigland@redhat.com>
2009-05-07dlm: Make name input parameter of {,dlm_}new_lockspace() constGeert Uytterhoeven
| fs/gfs2/lock_dlm.c:207: warning: passing argument 1 of 'dlm_new_lockspace' discards qualifiers from pointer target type Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: David Teigland <teigland@redhat.com>
2009-03-11dlm: fix length calculation in compat codeDavid Teigland
Using offsetof() to calculate name length does not work because it does not produce consistent results with with structure packing. This caused memcpy to corrupt memory by copying 4 extra bytes off the end of the buffer on 64 bit kernels with 32 bit userspace (the only case where this 32/64 compat code is used). The fix is to calculate name length directly from the start instead of trying to derive it later using count and offsetof. Signed-off-by: David Teigland <teigland@redhat.com>
2009-03-11dlm: ignore cancel on granted lockDavid Teigland
Return immediately from dlm_unlock(CANCEL) if the lock is granted and not being converted; there's nothing to cancel. Signed-off-by: David Teigland <teigland@redhat.com>
2009-03-11dlm: clear defunct cancel stateDavid Teigland
When a conversion completes successfully and finds that a cancel of the convert is still in progress (which is now a moot point), preemptively clear the state associated with outstanding cancel. That state could cause a subsequent conversion to be ignored. Also, improve the consistency and content of error and debug messages in this area. Signed-off-by: David Teigland <teigland@redhat.com>
2009-03-11dlm: replace idr with hash table for connectionsChristine Caulfield
Integer nodeids can be too large for the idr code; use a hash table instead. Signed-off-by: Christine Caulfield <ccaulfie@redhat.com> Signed-off-by: David Teigland <teigland@redhat.com>
