path: root/fs/dquot.c
2008-08-01[PATCH] fix races and leaks in vfs_quota_on() usersAl Viro
* new helper: vfs_quota_on_path(); equivalent of vfs_quota_on() sans the pathname resolution. * callers of vfs_quota_on() that do their own pathname resolution and checks based on it are switched to vfs_quota_on_path(); that way we avoid the races. * reiserfs leaked dentry/vfsmount references on several failure exits. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-25quota: implement sending information via netlink about user below quotaJan Kara
Sometimes it may be useful for userspace to know (e.g. for some hosting guys) that some user stopped exceeding his hardlimit or softlimit in quotas. Implement sending of such events to userspace via quota netlink protocol so that they don't have to poll for such events. Based on idea and initial implementation by Vladislav Bogdanov. Cc: Vladislav Bogdanov <slava@nsys.by> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25quota: rename quota functions from upper case, make bigger ones non-inlineJan Kara
Cleanup quotaops.h: Rename functions from uppercase to lowercase (and define backward compatibility macros), move larger functions to dquot.c and make them non-inline. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25quota: fix possible infinite loop in quota codeJan Kara
When quota structure is going to be dropped and it is dirty, quota code tries to write it. If the write fails for some reason (e. g. transaction cannot be started because the journal is aborted), we try writing again and again and again... Fix the problem by clearing the dirty bit even if the write failed. (akpm: for 2.6.27, 2.6.26.x and 2.6.25.x) Signed-off-by: Jan Kara <jack@suse.cz> Reviewed-by: dingdinghua <dingdinghua85@gmail.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-13quota: don't call sync_fs() from vfs_quota_off() when there's no quota turn offJan Kara
Sometimes, vfs_quota_off() is called on a partially set up super block (for example when fill_super() fails for some reason). In such cases we cannot call ->sync_fs() because it can Oops because of not properly filled in super block. So in case we find there's not quota to turn off, we just skip everything and return which fixes the above problem. [akpm@linux-foundation.org: fxi tpyo] Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28quota: quota core changes for quotaon on remountJan Kara
Currently, we just turn quotas off on remount of filesystem to read-only state. The patch below adds necessary framework so that we can turn quotas off on remount RO but we are able to automatically reenable them again when filesystem is remounted to RW state. All we need to do is to keep references to inodes of quota files when remounting RO and using these references to reenable quotas when remounting RW. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28quota: various style cleanupsJan Kara
Cleanups in quota code: Change __inline__ to inline. Change some macros to inline functions. Remove vfs_quota_off_mount() macro. DQUOT_OFF() should be (0) is CONFIG_QUOTA is disabled. Move declaration of mark_dquot_dirty and dirty_dquot from quota.h to dquot.c [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28quota: do not allow setting of quota limits to too high valuesAndrew Perepechko
We should check whether quota limits set via Q_SETQUOTA are not exceeding limits which quota format is able to handle. Signed-off-by: Andrew Perepechko <andrew.perepechko@sun.com> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-19quota: add possibly missing iput() when quotaon and quotaoff racesJan Kara
We should always put inode we have reference to, even if quota was reenabled in the mean time. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14Introduce path_put()Jan Blunck
* Add path_put() functions for releasing a reference to the dentry and vfsmount of a struct path in the right order * Switch from path_release(nd) to path_put(&nd->path) * Rename dput_path() to path_put_conditional() [akpm@linux-foundation.org: fix cifs] Signed-off-by: Jan Blunck <jblunck@suse.de> Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Acked-by: Christoph Hellwig <hch@lst.de> Cc: <linux-fsdevel@vger.kernel.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Steven French <sfrench@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14Embed a struct path into struct nameidata instead of nd->{dentry,mnt}Jan Blunck
This is the central patch of a cleanup series. In most cases there is no good reason why someone would want to use a dentry for itself. This series reflects that fact and embeds a struct path into nameidata. Together with the other patches of this series - it enforced the correct order of getting/releasing the reference count on <dentry,vfsmount> pairs - it prepares the VFS for stacking support since it is essential to have a struct path in every place where the stack can be traversed - it reduces the overall code size: without patch series: text data bss dec hex filename 5321639 858418 715768 6895825 6938d1 vmlinux with patch series: text data bss dec hex filename 5320026 858418 715768 6894212 693284 vmlinux This patch: Switch from nd->{dentry,mnt} to nd->path.{dentry,mnt} everywhere. [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: fix cifs] [akpm@linux-foundation.org: fix smack] Signed-off-by: Jan Blunck <jblunck@suse.de> Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Acked-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06quota: improve inode list scanning in add_dquot_ref()Jan Kara
We restarted scan of sb->s_inodes list whenever we had to drop inode_lock in add_dquot_ref(). This leads to overall quadratic running time and thus add_dquot_ref() can take several minutes when called on a life filesystem. We fix the problem by using the fact that inode cannot be removed from s_inodes list while we hold a reference to it and thus we can safely restart the scan if we don't drop the reference. Here we use the fact that inodes freshly added to s_inodes list are already guaranteed to have quotas properly initialized and the ordering of inodes on s_inodes list does not change so we cannot skip any inode. Thanks goes to Nick <gentuu@gmail.com> for analyzing the problem and testing the fix. [akpm@linux-foundation.org: iput(NULL) is legal] Signed-off-by: Jan Kara <jack@suse.cz> Cc: Nick <gentuu@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-23Don't send quota messages repeatedly when hardlimit reachedJan Kara
We should send quota message to netlink only once when hardlimit is reached. Otherwise user could easily make the system busy by trying to exceed the hardlimit (and also the messages could be anoying if you cannot stop writing just now). Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-23Fix computation of SKB size for quota messagesJan Kara
Fix computation of size of skb needed for quota message. We should use netlink provided functions and not just an ad-hoc number. Also don't print the return value from nla_put_foo() as it is always -1. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-17Fix compilation warning in dquot.cJan Kara
Fix compilation warning about discarded const. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17quota: send messages via netlinkJan Kara
Implement sending of quota messages via netlink interface. The advantage is that in userspace we can better decide what to do with the message - for example display a dialogue in your X session or just write the message to the console. As a bonus, we can get rid of problems with console locking deep inside filesystem code once we remove the old printing mechanism. Signed-off-by: Jan Kara <jack@suse.cz> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17mm: clean up and kernelify shrinker registrationRusty Russell
I can never remember what the function to register to receive VM pressure is called. I have to trace down from __alloc_pages() to find it. It's called "set_shrinker()", and it needs Your Help. 1) Don't hide struct shrinker. It contains no magic. 2) Don't allocate "struct shrinker". It's not helpful. 3) Call them "register_shrinker" and "unregister_shrinker". 4) Call the function "shrink" not "shrinker". 5) Reduce the 17 lines of waffly comments to 13, but document it properly. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: David Chinner <dgc@sgi.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-17circular locking dependency found in QUOTA OFFJan Kara
i_mutex on quota files is special. Unlike i_mutexes for other inodes it is acquired under dqonoff_mutex. Tell lockdep about this lock ranking. Also comment and code in quota_sync_sb() seem to be bogus (as i_mutex for quota file can be acquired under dqonoff_mutex). Move truncate_inode_pages() call under dqonoff_mutex and save some problems with races... Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Introduce a handy list_first_entry macroPavel Emelianov
There are many places in the kernel where the construction like foo = list_entry(head->next, struct foo_struct, list); are used. The code might look more descriptive and neat if using the macro list_first_entry(head, type, member) \ list_entry((head)->next, type, member) Here is the macro itself and the examples of its usage in the generic code. If it will turn out to be useful, I can prepare the set of patches to inject in into arch-specific code, drivers, networking, etc. Signed-off-by: Pavel Emelianov <xemul@openvz.org> Signed-off-by: Kirill Korotaev <dev@openvz.org> Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Zach Brown <zach.brown@oracle.com> Cc: Davide Libenzi <davidel@xmailserver.org> Cc: John McCutchan <ttb@tentacle.dhs.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: john stultz <johnstul@us.ibm.com> Cc: Ram Pai <linuxram@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08make remove_inode_dquot_ref() staticAdrian Bunk
remove_inode_dquot_ref() can now become static. Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07mm: remove destroy_dirty_buffers from invalidate_bdev()Peter Zijlstra
Remove the destroy_dirty_buffers argument from invalidate_bdev(), it hasn't been used in 6 years (so akpm says). find * -name \*.[ch] | xargs grep -l invalidate_bdev | while read file; do quilt add $file; sed -ie 's/invalidate_bdev(\([^,]*\),[^)]*)/invalidate_bdev(\1)/g' $file; done Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] sysctl: remove insert_at_head from register_sysctlEric W. Biederman
The semantic effect of insert_at_head is that it would allow new registered sysctl entries to override existing sysctl entries of the same name. Which is pain for caching and the proc interface never implemented. I have done an audit and discovered that none of the current users of register_sysctl care as (excpet for directories) they do not register duplicate sysctl entries. So this patch simply removes the support for overriding existing entries in the sys_sysctl interface since no one uses it or cares and it makes future enhancments harder. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: David Howells <dhowells@redhat.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Andi Kleen <ak@muc.de> Cc: Jens Axboe <axboe@kernel.dk> Cc: Corey Minyard <minyard@acm.org> Cc: Neil Brown <neilb@suse.de> Cc: "John W. Linville" <linville@tuxdriver.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Jan Kara <jack@ucw.cz> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Mark Fasheh <mark.fasheh@oracle.com> Cc: David Chinner <dgc@sgi.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Patrick McHardy <kaber@trash.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] remove sb->s_files and file_list_lock usage in dquot.cChristoph Hellwig
Iterate over sb->s_inodes instead of sb->s_files in add_dquot_ref. This reduces list search and lock hold time aswell as getting rid of one of the few uses of file_list_lock which Ingo identified as a scalability problem. Previously we called dq_op->initialize for every inode handing of a writeable file that wasn't initialized before. Now we're calling it for every inode that has a non-zero i_writecount, aka a writeable file descriptor refering to it. Thanks a lot to Jan Kara for running this patch through his quota test harness. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] move remove_dquot_ref to dqout.cChristoph Hellwig
Remove_dquot_ref can move to dqout.c instead of beeing in inode.c under #ifdef CONFIG_QUOTA. Also clean the resulting code up a tiny little bit by testing sb->dq_op earlier - it's constant over a filesystems lifetime. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Jan Kara <jack@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Transform kmem_cache_alloc()+memset(0) -> kmem_cache_zalloc().Robert P. J. Day
Replace appropriate pairs of "kmem_cache_alloc()" + "memset(0)" with the corresponding "kmem_cache_zalloc()" call. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Andi Kleen <ak@muc.de> Cc: Roland McGrath <roland@redhat.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Greg KH <greg@kroah.com> Acked-by: Joel Becker <Joel.Becker@oracle.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Jan Kara <jack@ucw.cz> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Stephen Smalley <sds@tycho.nsa.gov> Cc: James Morris <jmorris@namei.org> Cc: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-08[PATCH] VFS: change struct file to use struct pathJosef "Jeff" Sipek
This patch changes struct file to use struct path instead of having independent pointers to struct dentry and struct vfsmount, and converts all users of f_{dentry,vfsmnt} in fs/ to use f_path.{dentry,mnt}. Additionally, it adds two #define's to make the transition easier for users of the f_dentry and f_vfsmnt. Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] tty: ->signal->tty lockingPeter Zijlstra
Fix the locking of signal->tty. Use ->sighand->siglock to protect ->signal->tty; this lock is already used by most other members of ->signal/->sighand. And unless we are 'current' or the tasklist_lock is held we need ->siglock to access ->signal anyway. (NOTE: sys_unshare() is broken wrt ->sighand locking rules) Note that tty_mutex is held over tty destruction, so while holding tty_mutex any tty pointer remains valid. Otherwise the lifetime of ttys are governed by their open file handles. This leaves some holes for tty access from signal->tty (or any other non file related tty access). It solves the tty SLAB scribbles we were seeing. (NOTE: the change from group_send_sig_info to __group_send_sig_info needs to be examined by someone familiar with the security framework, I think it is safe given the SEND_SIG_PRIV from other __group_send_sig_info invocations) [schwidefsky@de.ibm.com: 3270 fix] [akpm@osdl.org: various post-viro fixes] Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Alan Cox <alan@redhat.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Prarit Bhargava <prarit@redhat.com> Cc: Chris Wright <chrisw@sous-sol.org> Cc: Roland McGrath <roland@redhat.com> Cc: Stephen Smalley <sds@tycho.nsa.gov> Cc: James Morris <jmorris@namei.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Jan Kara <jack@ucw.cz> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] slab: remove SLAB_NOFSChristoph Lameter
SLAB_NOFS is an alias of GFP_NOFS. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] dquot: add proper locking when using current->signal->ttyJan Kara
Dquot passes the tty to tty_write_message without locking Signed-off-by: Jan Kara <jack@suse.cz> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] use list_add_tail() instead of list_add()Akinobu Mita
This patch converts list_add(A, B.prev) to list_add_tail(A, &B) for readability. Acked-by: Karsten Keil <kkeil@suse.de> Cc: Jan Harkes <jaharkes@cs.cmu.edu> Acked-by: Jan Kara <jack@suse.cz> AOLed-by: David Woodhouse <dwmw2@infradead.org> Cc: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-02BUG_ON() Conversion in fs/dquot.cEric Sesterhenn
this changes if() BUG(); constructs to BUG_ON() which is cleaner and can better optimized away Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-03-24[PATCH] cpuset memory spread: slab cache formatPaul Jackson
Rewrap the overly long source code lines resulting from the previous patch's addition of the slab cache flag SLAB_MEM_SPREAD. This patch contains only formatting changes, and no function change. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] cpuset memory spread: slab cache filesystemsPaul Jackson
Mark file system inode and similar slab caches subject to SLAB_MEM_SPREAD memory spreading. If a slab cache is marked SLAB_MEM_SPREAD, then anytime that a task that's in a cpuset with the 'memory_spread_slab' option enabled goes to allocate from such a slab cache, the allocations are spread evenly over all the memory nodes (task->mems_allowed) allowed to that task, instead of favoring allocation on the node local to the current cpu. The following inode and similar caches are marked SLAB_MEM_SPREAD: file cache ==== ===== fs/adfs/super.c adfs_inode_cache fs/affs/super.c affs_inode_cache fs/befs/linuxvfs.c befs_inode_cache fs/bfs/inode.c bfs_inode_cache fs/block_dev.c bdev_cache fs/cifs/cifsfs.c cifs_inode_cache fs/coda/inode.c coda_inode_cache fs/dquot.c dquot fs/efs/super.c efs_inode_cache fs/ext2/super.c ext2_inode_cache fs/ext2/xattr.c (fs/mbcache.c) ext2_xattr fs/ext3/super.c ext3_inode_cache fs/ext3/xattr.c (fs/mbcache.c) ext3_xattr fs/fat/cache.c fat_cache fs/fat/inode.c fat_inode_cache fs/freevxfs/vxfs_super.c vxfs_inode fs/hpfs/super.c hpfs_inode_cache fs/isofs/inode.c isofs_inode_cache fs/jffs/inode-v23.c jffs_fm fs/jffs2/super.c jffs2_i fs/jfs/super.c jfs_ip fs/minix/inode.c minix_inode_cache fs/ncpfs/inode.c ncp_inode_cache fs/nfs/direct.c nfs_direct_cache fs/nfs/inode.c nfs_inode_cache fs/ntfs/super.c ntfs_big_inode_cache_name fs/ntfs/super.c ntfs_inode_cache fs/ocfs2/dlm/dlmfs.c dlmfs_inode_cache fs/ocfs2/super.c ocfs2_inode_cache fs/proc/inode.c proc_inode_cache fs/qnx4/inode.c qnx4_inode_cache fs/reiserfs/super.c reiser_inode_cache fs/romfs/inode.c romfs_inode_cache fs/smbfs/inode.c smb_inode_cache fs/sysv/inode.c sysv_inode_cache fs/udf/super.c udf_inode_cache fs/ufs/super.c ufs_inode_cache net/socket.c sock_inode_cache net/sunrpc/rpc_pipe.c rpc_inode_cache The choice of which slab caches to so mark was quite simple. I marked those already marked SLAB_RECLAIM_ACCOUNT, except for fs/xfs, dentry_cache, inode_cache, and buffer_head, which were marked in a previous patch. Even though SLAB_RECLAIM_ACCOUNT is for a different purpose, it marks the same potentially large file system i/o related slab caches as we need for memory spreading. Given that the rule now becomes "wherever you would have used a SLAB_RECLAIM_ACCOUNT slab cache flag before (usually the inode cache), use the SLAB_MEM_SPREAD flag too", this should be easy enough to maintain. Future file system writers will just copy one of the existing file system slab cache setups and tend to get it right without thinking. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] sem2mutex: quotaIngo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Jan Kara <jack@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] Fix oops in invalidate_dquots()Jan Kara
When quota is being turned off we assumed that all the references to dquots were already dropped. That need not be true as inodes being deleted are not on superblock's inodes list and hence we need not reach it when removing quota references from inodes. So invalidate_dquots() has to wait for all the users of dquots (as quota is already marked as turned off, no new references can be acquired and so this is bound to happen rather early). When we do this, we can also remove the iprune_sem locking as it was protecting us against exactly the same problem when freeing inodes icache memory. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-11[PATCH] capable/capability.h (fs/)Randy Dunlap
fs: Use <linux/capability.h> where capable() is used. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Acked-by: Tim Schmielau <tim@physik3.uni-rostock.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-09[PATCH] mutex subsystem, semaphore to mutex: VFS, ->i_semJes Sorensen
This patch converts the inode semaphore to a mutex. I have tested it on XFS and compiled as much as one can consider on an ia64. Anyway your luck with it might be different. Modified-by: Ingo Molnar <mingo@elte.hu> (finished the conversion) Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2005-11-28[PATCH] Fix oops in vfs_quotaon_mount()Jan Kara
When quota file specified in mount options did not exist, we tried to dereference NULL pointer later. Fix it. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] saner handling of auto_acct_off() and DQUOT_OFF() in umountAl Viro
The way we currently deal with quota and process accounting that might keep vfsmount busy at umount time is inherently broken; we try to turn them off just in case (not quite correctly, at that) and a) pray umount doesn't fail (otherwise they'll stay turned off) b) pray nobody doesn anything funny just as we turn quota off Moreover, LSM provides hooks for doing the same sort of broken logics. The proper way to deal with that is to introduce the second kind of reference to vfsmount. Semantics: - when the last normal reference is dropped, all special ones are converted to normal ones and if there had been any, cleanup is done. - normal reference can be cloned into a special one - special reference can be converted to normal one; that's a no-op if we'd already passed the point of no return (i.e. mntput() had converted special references to normal and started cleanup). The way it works: e.g. starting process accounting converts the vfsmount reference pinned by the opened file into special one and turns it back to normal when it gets shut down; acct_auto_close() is done when no normal references are left. That way it does *not* obstruct umount(2) and it silently gets turned off when the last normal reference to vfsmount is gone. Which is exactly what we want... The same should be done by LSM module that holds some internal references to vfsmount and wants to shut them down on umount - it should make them special and security_sb_umount_close() will be called exactly when the last normal reference to vfsmount is gone. quota handling is even simpler - we don't use normal file IO anymore, so there's no need to hold vfsmounts at all. DQUOT_OFF() is done from deactivate_super(), where it really belongs. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] quota: small cleanupsAdrian Bunk
- "extern inline" -> "static inline" - every file should #include the headers containing the prototypes for it's global functions Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] reduce sizeof(struct file)Eric Dumazet
Now that RCU applied on 'struct file' seems stable, we can place f_rcuhead in a memory location that is not anymore used at call_rcu(&f->f_rcuhead, file_free_rcu) time, to reduce the size of this critical kernel object. The trick I used is to move f_rcuhead and f_list in an union called f_u The callers are changed so that f_rcuhead becomes f_u.fu_rcuhead and f_list becomes f_u.f_list Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-28[PATCH] gfp_t: fs/*Al Viro
- ->releasepage() annotated (s/int/gfp_t), instances updated - missing gfp_t in fs/* added - fixed misannotation from the original sweep caught by bitwise checks: XFS used __nocast both for gfp_t and for flags used by XFS allocator. The latter left with unsigned int __nocast; we might want to add a different type for those but for now let's leave them alone. That, BTW, is a case when __nocast use had been actively confusing - it had been used in the same code for two different and similar types, with no way to catch misuses. Switch of gfp_t to bitwise had caught that immediately... One tricky bit is left alone to be dealt with later - mapping->flags is a mix of gfp_t and error indications. Left alone for now. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] list_for_each_entry: fs-dquot.cDomen Puncer
Make code more readable with list_for_each_entry_safe. Signed-off-by: Domen Puncer <domen@coderock.org> Signed-off-by: Maximilian Attems <janitor@sternwelten.at> Signed-off-by: Domen Puncer <domen@coderock.org> Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-23[PATCH] quota: sanitize dentry handling in vfs_quota_on_mountChristoph Hellwig
Use lookup_one_len instead of opencoding a simplified lookup using lookup_hash with a fake hash. Also there's no need anymore for the d_invalidate as we have a completely valid dentry now. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-23[PATCH] quota: consolidate code surrounding vfs_quota_on_mountChristoph Hellwig
Move some code duplicated in both callers into vfs_quota_on_mount Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Jan Kara <jack@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-16[PATCH] quota: fix possible oops on quotaoffJan Kara
Remove dquot structures from quota file on quotaon - quota code does not expect them to be there. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
