path: root/fs/ecryptfs/inode.c
2015-04-15VFS: normal filesystems (and lustre): d_inode() annotationsDavid Howells
that's the bulk of filesystem drivers dealing with inodes of their own Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-02-22VFS: (Scripted) Convert S_ISLNK/DIR/REG(dentry->d_inode) to d_is_*(dentry)David Howells
Convert the following where appropriate: (1) S_ISLNK(dentry->d_inode) to d_is_symlink(dentry). (2) S_ISREG(dentry->d_inode) to d_is_reg(dentry). (3) S_ISDIR(dentry->d_inode) to d_is_dir(dentry). This is actually more complicated than it appears as some calls should be converted to d_can_lookup() instead. The difference is whether the directory in question is a real dir with a ->lookup op or whether it's a fake dir with a ->d_automount op. In some circumstances, we can subsume checks for dentry->d_inode not being NULL into this, provided we the code isn't in a filesystem that expects d_inode to be NULL if the dirent really *is* negative (ie. if we're going to use d_inode() rather than d_backing_inode() to get the inode pointer). Note that the dentry type field may be set to something other than DCACHE_MISS_TYPE when d_inode is NULL in the case of unionmount, where the VFS manages the fall-through from a negative dentry to a lower layer. In such a case, the dentry type of the negative union dentry is set to the same as the type of the lower dentry. However, if you know d_inode is not NULL at the call site, then you can use the d_is_xxx() functions even in a filesystem. There is one further complication: a 0,0 chardev dentry may be labelled DCACHE_WHITEOUT_TYPE rather than DCACHE_SPECIAL_TYPE. Strictly, this was intended for special directory entry types that don't have attached inodes. The following perl+coccinelle script was used: use strict; my @callers; open($fd, 'git grep -l \'S_IS[A-Z].*->d_inode\' |') || die "Can't grep for S_ISDIR and co. callers"; @callers = <$fd>; close($fd); unless (@callers) { print "No matches\n"; exit(0); } my @cocci = ( '@@', 'expression E;', '@@', '', '- S_ISLNK(E->d_inode->i_mode)', '+ d_is_symlink(E)', '', '@@', 'expression E;', '@@', '', '- S_ISDIR(E->d_inode->i_mode)', '+ d_is_dir(E)', '', '@@', 'expression E;', '@@', '', '- S_ISREG(E->d_inode->i_mode)', '+ d_is_reg(E)' ); my $coccifile = "tmp.sp.cocci"; open($fd, ">$coccifile") || die $coccifile; print($fd "$_\n") || die $coccifile foreach (@cocci); close($fd); foreach my $file (@callers) { chomp $file; print "Processing ", $file, "\n"; system("spatch", "--sp-file", $coccifile, $file, "--in-place", "--no-show-diff") == 0 || die "spatch failed"; } [AV: overlayfs parts skipped] Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-01-20fs: remove mapping->backing_dev_infoChristoph Hellwig
Now that we never use the backing_dev_info pointer in struct address_space we can simply remove it and save 4 to 8 bytes in every inode. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Reviewed-by: Tejun Heo <tj@kernel.org> Reviewed-by: Jan Kara <jack@suse.cz> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-10-11Merge tag 'ecryptfs-3.18-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tyhicks/ecryptfs Pull eCryptfs updates from Tyler Hicks: "Minor code cleanups and a fix for when eCryptfs metadata is stored in xattrs" * tag 'ecryptfs-3.18-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tyhicks/ecryptfs: ecryptfs: remove unneeded buggy code in ecryptfs_do_create() ecryptfs: avoid to access NULL pointer when write metadata in xattr ecryptfs: remove unnecessary break after goto ecryptfs: Remove unnecessary include of syscall.h in keystore.c fs/ecryptfs/messaging.c: remove null test before kfree ecryptfs: Drop cast Use %pd in eCryptFS
2014-10-06ecryptfs: remove unneeded buggy code in ecryptfs_do_create()Alexey Khoroshilov
There is a bug in error handling of lock_parent() in ecryptfs_do_create(): lock_parent() acquries mutex even if dget_parent() fails, so mutex should be unlocked anyway. But dget_parent() does not fail, so the patch just removes unneeded buggy code. Found by Linux Driver Verification project (linuxtesting.org). Signed-off-by: Alexey Khoroshilov <khoroshilov@ispras.ru> Signed-off-by: Tyler Hicks <tyhicks@canonical.com>
2014-10-05ecryptfs: avoid to access NULL pointer when write metadata in xattrChao Yu
Christopher Head 2014-06-28 05:26:20 UTC described: "I tried to reproduce this on 3.12.21. Instead, when I do "echo hello > foo" in an ecryptfs mount with ecryptfs_xattr specified, I get a kernel crash: BUG: unable to handle kernel NULL pointer dereference at (null) IP: [<ffffffff8110eb39>] fsstack_copy_attr_all+0x2/0x61 PGD d7840067 PUD b2c3c067 PMD 0 Oops: 0002 [#1] SMP Modules linked in: nvidia(PO) CPU: 3 PID: 3566 Comm: bash Tainted: P O 3.12.21-gentoo-r1 #2 Hardware name: ASUSTek Computer Inc. G60JX/G60JX, BIOS 206 03/15/2010 task: ffff8801948944c0 ti: ffff8800bad70000 task.ti: ffff8800bad70000 RIP: 0010:[<ffffffff8110eb39>] [<ffffffff8110eb39>] fsstack_copy_attr_all+0x2/0x61 RSP: 0018:ffff8800bad71c10 EFLAGS: 00010246 RAX: 00000000000181a4 RBX: ffff880198648480 RCX: 0000000000000000 RDX: 0000000000000004 RSI: ffff880172010450 RDI: 0000000000000000 RBP: ffff880198490e40 R08: 0000000000000000 R09: 0000000000000000 R10: ffff880172010450 R11: ffffea0002c51e80 R12: 0000000000002000 R13: 000000000000001a R14: 0000000000000000 R15: ffff880198490e40 FS: 00007ff224caa700(0000) GS:ffff88019fcc0000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 0000000000000000 CR3: 00000000bb07f000 CR4: 00000000000007e0 Stack: ffffffff811826e8 ffff8800a39d8000 0000000000000000 000000000000001a ffff8800a01d0000 ffff8800a39d8000 ffffffff81185fd5 ffffffff81082c2c 00000001a39d8000 53d0abbc98490e40 0000000000000037 ffff8800a39d8220 Call Trace: [<ffffffff811826e8>] ? ecryptfs_setxattr+0x40/0x52 [<ffffffff81185fd5>] ? ecryptfs_write_metadata+0x1b3/0x223 [<ffffffff81082c2c>] ? should_resched+0x5/0x23 [<ffffffff8118322b>] ? ecryptfs_initialize_file+0xaf/0xd4 [<ffffffff81183344>] ? ecryptfs_create+0xf4/0x142 [<ffffffff810f8c0d>] ? vfs_create+0x48/0x71 [<ffffffff810f9c86>] ? do_last.isra.68+0x559/0x952 [<ffffffff810f7ce7>] ? link_path_walk+0xbd/0x458 [<ffffffff810fa2a3>] ? path_openat+0x224/0x472 [<ffffffff810fa7bd>] ? do_filp_open+0x2b/0x6f [<ffffffff81103606>] ? __alloc_fd+0xd6/0xe7 [<ffffffff810ee6ab>] ? do_sys_open+0x65/0xe9 [<ffffffff8157d022>] ? system_call_fastpath+0x16/0x1b RIP [<ffffffff8110eb39>] fsstack_copy_attr_all+0x2/0x61 RSP <ffff8800bad71c10> CR2: 0000000000000000 ---[ end trace df9dba5f1ddb8565 ]---" If we create a file when we mount with ecryptfs_xattr_metadata option, we will encounter a crash in this path: ->ecryptfs_create ->ecryptfs_initialize_file ->ecryptfs_write_metadata ->ecryptfs_write_metadata_to_xattr ->ecryptfs_setxattr ->fsstack_copy_attr_all It's because our dentry->d_inode used in fsstack_copy_attr_all is NULL, and it will be initialized when ecryptfs_initialize_file finish. So we should skip copying attr from lower inode when the value of ->d_inode is invalid. Signed-off-by: Chao Yu <chao2.yu@samsung.com> Cc: stable@vger.kernel.org # v3.2+: b59db43 eCryptfs: Prevent file create race condition Signed-off-by: Tyler Hicks <tyhicks@canonical.com>
2014-07-03ecryptfs: Drop castHimangi Saraogi
This patch does away with cast on void * and the if as it is unnecessary. The following Coccinelle semantic patch was used for making the change: @r@ expression x; void* e; type T; identifier f; @@ ( *((T *)e) | ((T *)x)[...] | ((T *)x)->f | - (T *) e ) Signed-off-by: Himangi Saraogi <himangi774@gmail.com> Signed-off-by: Tyler Hicks <tyhicks@canonical.com>
2014-04-01vfs: add renameat2 syscallMiklos Szeredi
Add new renameat2 syscall, which is the same as renameat with an added flags argument. Pass flags to vfs_rename() and to i_op->rename() as well. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Reviewed-by: J. Bruce Fields <bfields@redhat.com>
2014-01-25ecryptfs: fix failure handling in ->readlink()Al Viro
If ecryptfs_readlink_lower() fails, buf remains an uninitialized pointer and passing it nd_set_link() won't do anything good. Fixed by switching ecryptfs_readlink_lower() to saner API - make it return buf or ERR_PTR(...) and update callers. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-12-17Use %pd in eCryptFSDavid Howells
Use the new %pd printk() specifier in eCryptFS to replace passing of dentry name or dentry name and name length * 2 with just passing the dentry. Signed-off-by: David Howells <dhowells@redhat.com> cc: ecryptfs@vger.kernel.org Signed-off-by: Tyler Hicks <tyhicks@canonical.com>
2013-11-09locks: break delegations on any attribute modificationJ. Bruce Fields
NFSv4 uses leases to guarantee that clients can cache metadata as well as data. Cc: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz> Cc: David Howells <dhowells@redhat.com> Cc: Tyler Hicks <tyhicks@canonical.com> Cc: Dustin Kirkland <dustin.kirkland@gazzang.com> Acked-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-11-09locks: break delegations on linkJ. Bruce Fields
2013-11-09locks: break delegations on renameJ. Bruce Fields
Cc: David Howells <dhowells@redhat.com> Acked-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-11-09locks: break delegations on unlinkJ. Bruce Fields
We need to break delegations on any operation that changes the set of links pointing to an inode. Start with unlink. Such operations also hold the i_mutex on a parent directory. Breaking a delegation may require waiting for a timeout (by default 90 seconds) in the case of a unresponsive NFS client. To avoid blocking all directory operations, we therefore drop locks before waiting for the delegation. The logic then looks like: acquire locks ... test for delegation; if found: take reference on inode release locks wait for delegation break drop reference on inode retry It is possible this could never terminate. (Even if we take precautions to prevent another delegation being acquired on the same inode, we could get a different inode on each retry.) But this seems very unlikely. The initial test for a delegation happens after the lock on the target inode is acquired, but the directory inode may have been acquired further up the call stack. We therefore add a "struct inode **" argument to any intervening functions, which we use to pass the inode back up to the caller in the case it needs a delegation synchronously broken. Cc: David Howells <dhowells@redhat.com> Cc: Tyler Hicks <tyhicks@canonical.com> Cc: Dustin Kirkland <dustin.kirkland@gazzang.com> Acked-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-10-24new helper: kfree_put_link()Al Viro
duplicated to hell and back... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-10-24ecryptfs: get rid of ecryptfs_set_dentry_lower{,_mnt}Al Viro
2013-07-05helper for reading ->d_countAl Viro
2013-06-29ecryptfs: switch ecryptfs_decode_and_decrypt_filename() from dentry to sbAl Viro
2013-03-07Merge tag 'ecryptfs-3.9-rc2-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tyhicks/ecryptfs Pull ecryptfs fixes from Tyler Hicks: "Minor code cleanups and new Kconfig option to disable /dev/ecryptfs The code cleanups fix up W=1 compiler warnings and some unnecessary checks. The new Kconfig option, defaulting to N, allows the rarely used eCryptfs kernel to userspace communication channel to be compiled out. This may be the first step in it being eventually removed." Hmm. I'm not sure whether these should be called "fixes", and it probably should have gone in the merge window. But I'll let it slide. * tag 'ecryptfs-3.9-rc2-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tyhicks/ecryptfs: eCryptfs: allow userspace messaging to be disabled eCryptfs: Fix redundant error check on ecryptfs_find_daemon_by_euid() ecryptfs: ecryptfs_msg_ctx_alloc_to_free(): remove kfree() redundant null check eCryptfs: decrypt_pki_encrypted_session_key(): remove kfree() redundant null check eCryptfs: remove unneeded checks in virt_to_scatterlist() eCryptfs: Fix -Wmissing-prototypes warnings eCryptfs: Fix -Wunused-but-set-variable warnings eCryptfs: initialize payload_len in keystore.c
2013-02-26switch vfs_getattr() to struct pathAl Viro
2013-01-17eCryptfs: Fix -Wmissing-prototypes warningsTyler Hicks
Mark two inode operation fuctions as static. Fixes warnings when building with W=1. Signed-off-by: Tyler Hicks <tyhicks@canonical.com>
2012-09-14eCryptfs: Copy up attributes of the lower target inode after renameTyler Hicks
After calling into the lower filesystem to do a rename, the lower target inode's attributes were not copied up to the eCryptfs target inode. This resulted in the eCryptfs target inode staying around, rather than being evicted, because i_nlink was not updated for the eCryptfs inode. This also meant that eCryptfs didn't do the final iput() on the lower target inode so it stayed around, as well. This would result in a failure to free up space occupied by the target file in the rename() operation. Both target inodes would eventually be evicted when the eCryptfs filesystem was unmounted. This patch calls fsstack_copy_attr_all() after the lower filesystem does its ->rename() so that important inode attributes, such as i_nlink, are updated at the eCryptfs layer. ecryptfs_evict_inode() is now called and eCryptfs can drop its final reference on the lower inode. http://launchpad.net/bugs/561129 Signed-off-by: Tyler Hicks <tyhicks@canonical.com> Tested-by: Colin Ian King <colin.king@canonical.com> Cc: <stable@vger.kernel.org> [2.6.39+]
2012-08-02Merge tag 'ecryptfs-3.6-rc1-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tyhicks/ecryptfs Pull ecryptfs fixes from Tyler Hicks: - Fixes a bug when the lower filesystem mount options include 'acl', but the eCryptfs mount options do not - Cleanups in the messaging code - Better handling of empty files in the lower filesystem to improve usability. Failed file creations are now cleaned up and empty lower files are converted into eCryptfs during open(). - The write-through cache changes are being reverted due to bugs that are not easy to fix. Stability outweighs the performance enhancements here. - Improvement to the mount code to catch unsupported ciphers specified in the mount options * tag 'ecryptfs-3.6-rc1-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tyhicks/ecryptfs: eCryptfs: check for eCryptfs cipher support at mount eCryptfs: Revert to a writethrough cache model eCryptfs: Initialize empty lower files when opening them eCryptfs: Unlink lower inode when ecryptfs_create() fails eCryptfs: Make all miscdev functions use daemon ptr in file private_data eCryptfs: Remove unused messaging declarations and function eCryptfs: Copy up POSIX ACL and read-only flags from lower mount
2012-07-29ecryptfs_lookup_interpose(): allocate dentry_info firstAl Viro
less work on failure that way Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-29sanitize ecryptfs_lookup()Al Viro
* ->lookup() never gets hit with . or .. * dentry it gets is unhashed, so unless we had gone and hashed it ourselves, there's no need to d_drop() the sucker. * wrong name printed in one of the printks (NULL, in fact) Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-23don't expose I_NEW inodes via dentry->d_inodeAl Viro
d_instantiate(dentry, inode); unlock_new_inode(inode); is a bad idea; do it the other way round... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-14don't pass nameidata * to vfs_create()Al Viro
all we want is a boolean flag, same as the method gets now Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-14don't pass nameidata to ->create()Al Viro
boolean "does it have to be exclusive?" flag is passed instead; Local filesystem should just ignore it - the object is guaranteed not to be there yet. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-14stop passing nameidata to ->lookup()Al Viro
Just the flags; only NFS cares even about that, but there are legitimate uses for such argument. And getting rid of that completely would require splitting ->lookup() into a couple of methods (at least), so let's leave that alone for now... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-13eCryptfs: Revert to a writethrough cache modelTyler Hicks
A change was made about a year ago to get eCryptfs to better utilize its page cache during writes. The idea was to do the page encryption operations during page writeback, rather than doing them when initially writing into the page cache, to reduce the number of page encryption operations during sequential writes. This meant that the encrypted page would only be written to the lower filesystem during page writeback, which was a change from how eCryptfs had previously wrote to the lower filesystem in ecryptfs_write_end(). The change caused a few eCryptfs-internal bugs that were shook out. Unfortunately, more grave side effects have been identified that will force changes outside of eCryptfs. Because the lower filesystem isn't consulted until page writeback, eCryptfs has no way to pass lower write errors (ENOSPC, mainly) back to userspace. Additionaly, it was reported that quotas could be bypassed because of the way eCryptfs may sometimes open the lower filesystem using a privileged kthread. It would be nice to resolve the latest issues, but it is best if the eCryptfs commits be reverted to the old behavior in the meantime. This reverts: 32001d6f "eCryptfs: Flush file in vma close" 5be79de2 "eCryptfs: Flush dirty pages in setattr" 57db4e8d "ecryptfs: modify write path to encrypt page in writepage" Signed-off-by: Tyler Hicks <tyhicks@canonical.com> Tested-by: Colin King <colin.king@canonical.com> Cc: Colin King <colin.king@canonical.com> Cc: Thieu Le <thieule@google.com>
2012-07-08eCryptfs: Initialize empty lower files when opening themTyler Hicks
Historically, eCryptfs has only initialized lower files in the ecryptfs_create() path. Lower file initialization is the act of writing the cryptographic metadata from the inode's crypt_stat to the header of the file. The ecryptfs_open() path already expects that metadata to be in the header of the file. A number of users have reported empty lower files in beneath their eCryptfs mounts. Most of the causes for those empty files being left around have been addressed, but the presence of empty files causes problems due to the lack of proper cryptographic metadata. To transparently solve this problem, this patch initializes empty lower files in the ecryptfs_open() error path. If the metadata is unreadable due to the lower inode size being 0, plaintext passthrough support is not in use, and the metadata is stored in the header of the file (as opposed to the user.ecryptfs extended attribute), the lower file will be initialized. The number of nested conditionals in ecryptfs_open() was getting out of hand, so a helper function was created. To avoid the same nested conditional problem, the conditional logic was reversed inside of the helper function. https://launchpad.net/bugs/911507 Signed-off-by: Tyler Hicks <tyhicks@canonical.com> Cc: John Johansen <john.johansen@canonical.com> Cc: Colin Ian King <colin.king@canonical.com>
2012-07-08eCryptfs: Unlink lower inode when ecryptfs_create() failsTyler Hicks
ecryptfs_create() creates a lower inode, allocates an eCryptfs inode, initializes the eCryptfs inode and cryptographic metadata attached to the inode, and then writes the metadata to the header of the file. If an error was to occur after the lower inode was created, an empty lower file would be left in the lower filesystem. This is a problem because ecryptfs_open() refuses to open any lower files which do not have the appropriate metadata in the file header. This patch properly unlinks the lower inode when an error occurs in the later stages of ecryptfs_create(), reducing the chance that an empty lower file will be left in the lower filesystem. https://launchpad.net/bugs/872905 Signed-off-by: Tyler Hicks <tyhicks@canonical.com> Cc: John Johansen <john.johansen@canonical.com> Cc: Colin Ian King <colin.king@canonical.com>
2012-05-29get rid of pointless allocations and copying in ecryptfs_follow_link()Al Viro
switch to generic_readlink(), while we are at it Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-02-16eCryptfs: Copy up lower inode attrs after setting lower xattrTyler Hicks
After passing through a ->setxattr() call, eCryptfs needs to copy the inode attributes from the lower inode to the eCryptfs inode, as they may have changed in the lower filesystem's ->setxattr() path. One example is if an extended attribute containing a POSIX Access Control List is being set. The new ACL may cause the lower filesystem to modify the mode of the lower inode and the eCryptfs inode would need to be updated to reflect the new mode. https://launchpad.net/bugs/926292 Signed-off-by: Tyler Hicks <tyhicks@canonical.com> Reported-by: Sebastien Bacher <seb128@ubuntu.com> Cc: John Johansen <john.johansen@canonical.com> Cc: <stable@vger.kernel.org>
2012-01-25eCryptfs: Check inode changes in setattrTyler Hicks
Most filesystems call inode_change_ok() very early in ->setattr(), but eCryptfs didn't call it at all. It allowed the lower filesystem to make the call in its ->setattr() function. Then, eCryptfs would copy the appropriate inode attributes from the lower inode to the eCryptfs inode. This patch changes that and actually calls inode_change_ok() on the eCryptfs inode, fairly early in ecryptfs_setattr(). Ideally, the call would happen earlier in ecryptfs_setattr(), but there are some possible inode initialization steps that must happen first. Since the call was already being made on the lower inode, the change in functionality should be minimal, except for the case of a file extending truncate call. In that case, inode_newsize_ok() was never being called on the eCryptfs inode. Rather than inode_newsize_ok() catching maximum file size errors early on, eCryptfs would encrypt zeroed pages and write them to the lower filesystem until the lower filesystem's write path caught the error in generic_write_checks(). This patch introduces a new function, called ecryptfs_inode_newsize_ok(), which checks if the new lower file size is within the appropriate limits when the truncate operation will be growing the lower file. In summary this change prevents eCryptfs truncate operations (and the resulting page encryptions), which would exceed the lower filesystem limits or FSIZE rlimits, from ever starting. Signed-off-by: Tyler Hicks <tyhicks@canonical.com> Reviewed-by: Li Wang <liwang@nudt.edu.cn> Cc: <stable@vger.kernel.org>
2012-01-03fs: propagate umode_t, misc bitsAl Viro
2012-01-03kill ecryptfs_create_underlying_file()Al Viro
it's a just a wrapper for vfs_create() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-01-03switch ->mknod() to umode_tAl Viro
2012-01-03switch ->create() to umode_tAl Viro
vfs_create() ignores everything outside of 16bit subset of its mode argument; switching it to umode_t is obviously equivalent and it's the only caller of the method Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-01-03switch vfs_mkdir() and ->mkdir() to umode_tAl Viro
vfs_mkdir() gets int, but immediately drops everything that might not fit into umode_t and that's the only caller of ->mkdir()... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-11-23eCryptfs: Prevent file create race conditionTyler Hicks
The file creation path prematurely called d_instantiate() and unlock_new_inode() before the eCryptfs inode info was fully allocated and initialized and before the eCryptfs metadata was written to the lower file. This could result in race conditions in subsequent file and inode operations leading to unexpected error conditions or a null pointer dereference while attempting to use the unallocated memory. https://launchpad.net/bugs/813146 Signed-off-by: Tyler Hicks <tyhicks@canonical.com> Cc: stable@kernel.org
2011-11-02filesystems: add set_nlink()Miklos Szeredi
Replace remaining direct i_nlink updates with a new set_nlink() updater function. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Tested-by: Toshiyuki Okajima <toshi.okajima@jp.fujitsu.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2011-07-28ecryptfs: Make inode bdi consistent with superblock bdiThieu Le
Make the inode mapping bdi consistent with the superblock bdi so that dirty pages are flushed properly. Signed-off-by: Thieu Le <thieule@chromium.org> Cc: <stable@kernel.org> [2.6.39+] Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
2011-07-20don't pass nameidata to vfs_create() from ecryptfs_create()Al Viro
Instead of playing with removal of LOOKUP_OPEN, mangling (and restoring) nd->path, just pass NULL to vfs_create(). The whole point of what's being done there is to suppress any attempts to open file by underlying fs, which is what nd == NULL indicates. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20ecryptfs_inode_permission() doesn't need to bail out on RCUAl Viro
... now that inode_permission() can take MAY_NOT_BLOCK and handle it properly. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20->permission() sanitizing: don't pass flags to ->permission()Al Viro
not used by the instances anymore. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-29eCryptfs: Cleanup and optimize ecryptfs_lookup_interpose()Tyler Hicks
ecryptfs_lookup_interpose() has turned into spaghetti code over the years. This is an effort to clean it up. - Shorten overly descriptive variable names such as ecryptfs_dentry - Simplify gotos and error paths - Create helper function for reading plaintext i_size from metadata It also includes an optimization when reading i_size from the metadata. A complete page-sized kmem_cache_alloc() was being done to read in 16 bytes of metadata. The buffer for that is now statically declared. Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
2011-05-29eCryptfs: Fix new inode race conditionTyler Hicks
Only unlock and d_add() new inodes after the plaintext inode size has been read from the lower filesystem. This fixes a race condition that was sometimes seen during a multi-job kernel build in an eCryptfs mount. https://bugzilla.kernel.org/show_bug.cgi?id=36002 Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com> Reported-by: David <david@unsolicited.net> Tested-by: David <david@unsolicited.net>
2011-05-29eCryptfs: Cleanup inode initialization codeTyler Hicks
The eCryptfs inode get, initialization, and dentry interposition code has two separate paths. One is for when dentry interposition is needed after doing things like a mkdir in the lower filesystem and the other is needed after a lookup. Unlocking new inodes and doing a d_add() needs to happen at different times, depending on which type of dentry interposing is being done. This patch cleans up the inode get and initialization code paths and splits them up so that the locking and d_add() differences mentioned above can be handled appropriately in a later patch. Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com> Tested-by: David <david@unsolicited.net>
2011-05-29eCryptfs: Consolidate inode functions into inode.cTyler Hicks
These functions should live in inode.c since their focus is on inodes and they're primarily used by functions in inode.c. Also does a simple cleanup of ecryptfs_inode_test() and rolls ecryptfs_init_inode() into ecryptfs_inode_set(). Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com> Tested-by: David <david@unsolicited.net>
