commit 8335eafc2859e1a26282bef7c3d19f3d68868b8a upstream.
After calling into the lower filesystem to do a rename, the lower target
inode's attributes were not copied up to the eCryptfs target inode. This
resulted in the eCryptfs target inode staying around, rather than being
evicted, because i_nlink was not updated for the eCryptfs inode. This
also meant that eCryptfs didn't do the final iput() on the lower target
inode so it stayed around, as well. This would result in a failure to
free up space occupied by the target file in the rename() operation.
Both target inodes would eventually be evicted when the eCryptfs
filesystem was unmounted.
This patch calls fsstack_copy_attr_all() after the lower filesystem
does its ->rename() so that important inode attributes, such as i_nlink,
are updated at the eCryptfs layer. ecryptfs_evict_inode() is now called
and eCryptfs can drop its final reference on the lower inode.
http://launchpad.net/bugs/561129
Signed-off-by: Tyler Hicks <tyhicks@canonical.com>
Tested-by: Colin Ian King <colin.king@canonical.com>
commit 9fe79d7600497ed8a95c3981cbe5b73ab98222f0 upstream.
If the first attempt at opening the lower file read/write fails,
eCryptfs will retry using a privileged kthread. However, the privileged
retry should not happen if the lower file's inode is read-only because a
read/write open will still be unsuccessful.
The check for determining if the open should be retried was intended to
be based on the access mode of the lower file's open flags being
O_RDONLY, but the check was incorrectly performed. This would cause the
open to be retried by the privileged kthread, resulting in a second
failed open of the lower file. This patch corrects the check to
determine if the open request should be handled by the privileged
kthread.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Acked-by: Dan Carpenter <dan.carpenter@oracle.com>
commit 60d65f1f07a7d81d3eb3b91fc13fca80f2fdbb12 upstream.
Don't grab the daemon mutex while holding the message context mutex.
Addresses this lockdep warning:
ecryptfsd/2141 is trying to acquire lock:
(&ecryptfs_msg_ctx_arr[i].mux){+.+.+.}, at: [<ffffffffa029c213>] ecryptfs_miscdev_read+0x143/0x470 [ecryptfs]
but task is already holding lock:
(&(*daemon)->mux){+.+...}, at: [<ffffffffa029c2ec>] ecryptfs_miscdev_read+0x21c/0x470 [ecryptfs]
which lock already depends on the new lock.
the existing dependency chain (in reverse order) is:
-> #1 (&(*daemon)->mux){+.+...}:
[<ffffffff810a3b8d>] lock_acquire+0x9d/0x220
[<ffffffff8151c6da>] __mutex_lock_common+0x5a/0x4b0
[<ffffffff8151cc64>] mutex_lock_nested+0x44/0x50
[<ffffffffa029c5d7>] ecryptfs_send_miscdev+0x97/0x120 [ecryptfs]
[<ffffffffa029b744>] ecryptfs_send_message+0x134/0x1e0 [ecryptfs]
[<ffffffffa029a24e>] ecryptfs_generate_key_packet_set+0x2fe/0xa80 [ecryptfs]
[<ffffffffa02960f8>] ecryptfs_write_metadata+0x108/0x250 [ecryptfs]
[<ffffffffa0290f80>] ecryptfs_create+0x130/0x250 [ecryptfs]
[<ffffffff811963a4>] vfs_create+0xb4/0x120
[<ffffffff81197865>] do_last+0x8c5/0xa10
[<ffffffff811998f9>] path_openat+0xd9/0x460
[<ffffffff81199da2>] do_filp_open+0x42/0xa0
[<ffffffff81187998>] do_sys_open+0xf8/0x1d0
[<ffffffff81187a91>] sys_open+0x21/0x30
[<ffffffff81527d69>] system_call_fastpath+0x16/0x1b
-> #0 (&ecryptfs_msg_ctx_arr[i].mux){+.+.+.}:
[<ffffffff810a3418>] __lock_acquire+0x1bf8/0x1c50
[<ffffffff811887d3>] vfs_read+0xb3/0x180
[<ffffffff811888ed>] sys_read+0x4d/0x90
commit 8dc6780587c99286c0d3de747a2946a76989414a upstream.
File operations on /dev/ecryptfs would BUG() when the operations were
performed by processes other than the process that originally opened the
file. This could happen with open files inherited after fork() or file
descriptors passed through IPC mechanisms. Rather than calling BUG(), an
error code can be safely returned in most situations.
In ecryptfs_miscdev_release(), eCryptfs still needs to handle the
release even if the last file reference is being held by a process that
didn't originally open the file. ecryptfs_find_daemon_by_euid() will not
be successful, so a pointer to the daemon is stored in the file's
private_data. The private_data pointer is initialized when the miscdev
file is opened and only used when the file is released.
https://launchpad.net/bugs/994247
Reported-by: Sasha Levin <levinsasha928@gmail.com>
Tested-by: Sasha Levin <levinsasha928@gmail.com>
commit 545d680938be1e86a6c5250701ce9abaf360c495 upstream.
After passing through a ->setxattr() call, eCryptfs needs to copy the
inode attributes from the lower inode to the eCryptfs inode, as they
may have changed in the lower filesystem's ->setxattr() path.
One example is if an extended attribute containing a POSIX Access
Control List is being set. The new ACL may cause the lower filesystem to
modify the mode of the lower inode and the eCryptfs inode would need to
be updated to reflect the new mode.
https://launchpad.net/bugs/926292
Reported-by: Sebastien Bacher <seb128@ubuntu.com>
Cc: John Johansen <john.johansen@canonical.com>
commit 684a3ff7e69acc7c678d1a1394fe9e757993fd34 upstream.
ecryptfs_write() can enter an infinite loop when truncating a file to a
size larger than 4G. This only happens on architectures where size_t is
represented by 32 bits.
This was caused by a size_t overflow due to it incorrectly being used to
store the result of a calculation which uses potentially large values of
type loff_t.
[tyhicks@canonical.com: rewrite subject and commit message]
Signed-off-by: Li Wang <liwang@nudt.edu.cn>
Signed-off-by: Yunchuan Wen <wenyunchuan@kylinos.com.cn>
Reviewed-by: Cong Wang <xiyou.wangcong@gmail.com>
commit 58ded24f0fcb85bddb665baba75892f6ad0f4b8a upstream.
If pages passed to the eCryptfs extent-based crypto functions are not
mapped and the module parameter ecryptfs_verbosity=1 was specified at
loading time, a NULL pointer dereference will occur.
Note that this wouldn't happen on a production system, as you wouldn't
pass ecryptfs_verbosity=1 on a production system. It leaks private
information to the system logs and is for debugging only.
The debugging info printed in these messages is no longer very useful
and rather than doing a kmap() in these debugging paths, it will be
better to simply remove the debugging paths completely.
https://launchpad.net/bugs/913651
commit a261a03904849c3df50bd0300efb7fb3f865137d upstream.
Most filesystems call inode_change_ok() very early in ->setattr(), but
eCryptfs didn't call it at all. It allowed the lower filesystem to make
the call in its ->setattr() function. Then, eCryptfs would copy the
appropriate inode attributes from the lower inode to the eCryptfs inode.
This patch changes that and actually calls inode_change_ok() on the
eCryptfs inode, fairly early in ecryptfs_setattr(). Ideally, the call
would happen earlier in ecryptfs_setattr(), but there are some possible
inode initialization steps that must happen first.
Since the call was already being made on the lower inode, the change in
functionality should be minimal, except for the case of a file extending
truncate call. In that case, inode_newsize_ok() was never being
called on the eCryptfs inode. Rather than inode_newsize_ok() catching
maximum file size errors early on, eCryptfs would encrypt zeroed pages
and write them to the lower filesystem until the lower filesystem's
write path caught the error in generic_write_checks(). This patch
introduces a new function, called ecryptfs_inode_newsize_ok(), which
checks if the new lower file size is within the appropriate limits when
the truncate operation will be growing the lower file.
In summary this change prevents eCryptfs truncate operations (and the
resulting page encryptions), which would exceed the lower filesystem
limits or FSIZE rlimits, from ever starting.
Reviewed-by: Li Wang <liwang@nudt.edu.cn>
commit 5e6f0d769017cc49207ef56996e42363ec26c1f0 upstream.
ecryptfs_write() handles the truncation of eCryptfs inodes. It grabs a
page, zeroes out the appropriate portions, and then encrypts the page
before writing it to the lower filesystem. It was unkillable and due to
the lack of sparse file support could result in tying up a large portion
of system resources, while encrypting pages of zeros, with no way for
the truncate operation to be stopped from userspace.
This patch adds the ability for ecryptfs_write() to detect a pending
fatal signal and return as gracefully as possible. The intent is to
leave the lower file in a useable state, while still allowing a user to
break out of the encryption loop. If a pending fatal signal is detected,
the eCryptfs inode size is updated to reflect the modified inode size
and then -EINTR is returned.
commit 30373dc0c87ffef68d5628e77d56ffb1fa22e1ee upstream.
Print inode on metadata read failure. The only real
way of dealing with metadata read failures is to delete
the underlying file system file. Having the inode
allows one to 'find . -inum INODE`.
[tyhicks@canonical.com: Removed some minor not-for-stable parts]
Signed-off-by: Tim Gardner <tim.gardner@canonical.com>
commit db10e556518eb9d21ee92ff944530d84349684f4 upstream.
A malicious count value specified when writing to /dev/ecryptfs may
result in a a very large kernel memory allocation.
This patch peeks at the specified packet payload size, adds that to the
size of the packet headers and compares the result with the write count
value. The resulting maximum memory allocation size is approximately 532
bytes.
commit 0f751e641a71157aa584c2a2e22fda52b52b8a56 upstream.
From mhalcrow's original commit message:
Characters with ASCII values greater than the size of
filename_rev_map[] are valid filename characters.
ecryptfs_decode_from_filename() will access kernel memory beyond
that array, and ecryptfs_parse_tag_70_packet() will then decrypt
those characters. The attacker, using the FNEK of the crafted file,
can then re-encrypt the characters to reveal the kernel memory past
the end of the filename_rev_map[] array. I expect low security
impact since this array is statically allocated in the text area,
and the amount of memory past the array that is accessible is
limited by the largest possible ASCII filename character.
This patch solves the issue reported by mhalcrow but with an
implementation suggested by Linus to simply extend the length of
filename_rev_map[] to 256. Characters greater than 0x7A are mapped to
0x00, which is how invalid characters less than 0x7A were previously
being handled.
Reported-by: Michael Halcrow <mhalcrow@google.com>
commit 32001d6fe9ac6b0423e674a3093aa56740849f3b upstream.
Dirty pages weren't being written back when an mmap'ed eCryptfs file was
closed before the mapping was unmapped. Since f_ops->flush() is not
called by the munmap() path, the lower file was simply being released.
This patch flushes the eCryptfs file in the vm_ops->close() path.
https://launchpad.net/bugs/870326
commit f61500e000eedc0c7a0201200a7f00ba5529c002 upstream.
When an eCryptfs inode's lower file has been closed, and the pointer has
been set to NULL, return an error when trying to do a lower read or
write rather than calling BUG().
https://bugzilla.kernel.org/show_bug.cgi?id=37292
Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
commit 764355487ea220fdc2faf128d577d7f679b91f97 upstream.
Close a TOCTOU race for mounts done via ecryptfs-mount-private. The mount
source (device) can be raced when the ownership test is done in userspace.
Provide Ecryptfs a means to force the uid check at mount time.
Signed-off-by: John Johansen <john.johansen@canonical.com>
commit b2987a5e05ec7a1af7ca42e5d5349d7a22753031 upstream.
Fixes a regression caused by b5695d04634fa4ccca7dcbc05bb4a66522f02e0b
Kernel keyring keys containing eCryptfs authentication tokens should not
be write locked when calling out to ecryptfsd to wrap and unwrap file
encryption keys. The eCryptfs kernel code can not hold the key's write
lock because ecryptfsd needs to request the key after receiving such a
request from the kernel.
Without this fix, all file opens and creates will timeout and fail when
using the eCryptfs PKI infrastructure. This is not an issue when using
passphrase-based mount keys, which is the most widely deployed eCryptfs
configuration.
Acked-by: Roberto Sassu <roberto.sassu@polito.it>
Tested-by: Roberto Sassu <roberto.sassu@polito.it>
Tested-by: Alexis Hafner1 <haf@zurich.ibm.com>
commit 985ca0e626e195ea08a1a82b8dbeb6719747429a upstream.
Make the inode mapping bdi consistent with the superblock bdi so that
dirty pages are flushed properly.
Signed-off-by: Thieu Le <thieule@chromium.org>
Now that ecryptfs_lookup_interpose() is no longer using
ecryptfs_header_cache_2 to read in metadata, the kmem_cache can be
removed and the ecryptfs_header_cache_1 kmem_cache can be renamed to
ecryptfs_header_cache.
ecryptfs_lookup_interpose() has turned into spaghetti code over the
years. This is an effort to clean it up.
- Shorten overly descriptive variable names such as ecryptfs_dentry
- Simplify gotos and error paths
- Create helper function for reading plaintext i_size from metadata
It also includes an optimization when reading i_size from the metadata.
A complete page-sized kmem_cache_alloc() was being done to read in 16
bytes of metadata. The buffer for that is now statically declared.
Instead of having the calling functions translate the true/false return
code to either 0 or -EINVAL, have contains_ecryptfs_marker() return 0 or
-EINVAL so that the calling functions can just reuse the return code.
Also, rename the function to ecryptfs_validate_marker() to avoid callers
mistakenly thinking that it returns true/false codes.
Only unlock and d_add() new inodes after the plaintext inode size has
been read from the lower filesystem. This fixes a race condition that
was sometimes seen during a multi-job kernel build in an eCryptfs mount.
https://bugzilla.kernel.org/show_bug.cgi?id=36002
Reported-by: David <david@unsolicited.net>
Tested-by: David <david@unsolicited.net>
The eCryptfs inode get, initialization, and dentry interposition code
has two separate paths. One is for when dentry interposition is needed
after doing things like a mkdir in the lower filesystem and the other
is needed after a lookup. Unlocking new inodes and doing a d_add() needs
to happen at different times, depending on which type of dentry
interposing is being done.
This patch cleans up the inode get and initialization code paths and
splits them up so that the locking and d_add() differences mentioned
above can be handled appropriately in a later patch.
These functions should live in inode.c since their focus is on inodes
and they're primarily used by functions in inode.c.
Also does a simple cleanup of ecryptfs_inode_test() and rolls
ecryptfs_init_inode() into ecryptfs_inode_set().
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (36 commits)
Cache xattr security drop check for write v2
fs: block_page_mkwrite should wait for writeback to finish
mm: Wait for writeback when grabbing pages to begin a write
configfs: remove unnecessary dentry_unhash on rmdir, dir rename
fat: remove unnecessary dentry_unhash on rmdir, dir rename
hpfs: remove unnecessary dentry_unhash on rmdir, dir rename
minix: remove unnecessary dentry_unhash on rmdir, dir rename
fuse: remove unnecessary dentry_unhash on rmdir, dir rename
coda: remove unnecessary dentry_unhash on rmdir, dir rename
afs: remove unnecessary dentry_unhash on rmdir, dir rename
affs: remove unnecessary dentry_unhash on rmdir, dir rename
9p: remove unnecessary dentry_unhash on rmdir, dir rename
ncpfs: fix rename over directory with dangling references
ncpfs: document dentry_unhash usage
ecryptfs: remove unnecessary dentry_unhash on rmdir, dir rename
hostfs: remove unnecessary dentry_unhash on rmdir, dir rename
hfsplus: remove unnecessary dentry_unhash on rmdir, dir rename
hfs: remove unnecessary dentry_unhash on rmdir, dir rename
omfs: remove unnecessary dentry_unhash on rmdir, dir rneame
udf: remove unnecessary dentry_unhash from rmdir, dir rename
ecryptfs does not have problems with references to unlinked directories.
CC: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
CC: Dustin Kirkland <kirkland@canonical.com>
CC: ecryptfs-devel@lists.launchpad.net
Signed-off-by: Sage Weil <sage@newdream.net>
git://git.kernel.org/pub/scm/linux/kernel/git/ecryptfs/ecryptfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ecryptfs/ecryptfs-2.6:
MAINTAINERS: Update eCryptfs mailing list
eCryptfs: Allow 2 scatterlist entries for encrypted filenames
eCryptfs: Clear i_nlink in rmdir
The buffers allocated while encrypting and decrypting long filenames can
sometimes straddle two pages. In this situation, virt_to_scatterlist()
will return -ENOMEM, causing the operation to fail and the user will get
scary error messages in their logs:
kernel: ecryptfs_write_tag_70_packet: Internal error whilst attempting
to convert filename memory to scatterlist; expected rc = 1; got rc =
[-12]. block_aligned_filename_size = [272]
kernel: ecryptfs_encrypt_filename: Error attempting to generate tag 70
packet; rc = [-12]
kernel: ecryptfs_encrypt_and_encode_filename: Error attempting to
encrypt filename; rc = [-12]
kernel: ecryptfs_lookup: Error attempting to encrypt and encode
The solution is to allow up to 2 scatterlist entries to be used.
Cc: <stable@kernel.org>
eCryptfs wasn't clearing the eCryptfs inode's i_nlink after a successful
vfs_rmdir() on the lower directory. This resulted in the inode evict and
destroy paths to be missed.
https://bugs.launchpad.net/ecryptfs/+bug/723518
Only a few file systems need this. Start by pushing it down into each
rename method (except gfs2 and xfs) so that it can be dealt with on a
per-fs basis.
Acked-by: Christoph Hellwig <hch@lst.de>
fs rmdir method (except gfs2 and xfs) so it can be dealt with on a per-fs
basis.
This does not change behavior for any in-tree file systems.
After 57db4e8d73ef2b5e94a3f412108dff2576670a8a changed eCryptfs to
write-back caching, eCryptfs page writeback updates the lower inode
times due to the use of vfs_write() on the lower file.
To preserve inode metadata changes, such as 'cp -p' does with
utimensat(), we need to flush all dirty pages early in
ecryptfs_setattr() so that the user-updated lower inode metadata isn't
clobbered later in writeback.
https://bugzilla.kernel.org/show_bug.cgi?id=33372
Reported-by: Rocko <rockorequin@hotmail.com>
When failing to read the lower file's crypto metadata during a lookup,
eCryptfs must continue on without throwing an error. For example, there
may be a plaintext file in the lower mount point that the user wants to
delete through the eCryptfs mount.
If an error is encountered while reading the metadata in lookup(), the
eCryptfs inode's size could be incorrect. We must be sure to reread the
plaintext inode size from the metadata when performing an open() or
setattr(). The metadata is already being read in those paths, so this
adds minimal performance overhead.
This patch introduces a flag which will track whether or not the
plaintext inode size has been read so that an incorrect i_size can be
fixed in the open() or setattr() paths.
https://bugs.launchpad.net/bugs/509180
For any given lower inode, eCryptfs keeps only one lower file open and
multiplexes all eCryptfs file operations through that lower file. The
lower file was considered "persistent" and stayed open from the first
lookup through the lifetime of the inode.
This patch keeps the notion of a single, per-inode lower file, but adds
reference counting around the lower file so that it is closed when not
currently in use. If the reference count is at 0 when an operation (such
as open, create, etc.) needs to use the lower file, a new lower file is
opened. Since the file is no longer persistent, all references to the
term persistent file are changed to lower file.
Locking is added around the sections of code that opens the lower file
and assign the pointer in the inode info, as well as the code the fputs
the lower file when all eCryptfs users are done with it.
This patch is needed to fix issues, when mounted on top of the NFSv3
client, where the lower file is left silly renamed until the eCryptfs
inode is destroyed.
Call dput on the dentries previously returned by dget_parent() in
ecryptfs_rename(). This is needed for supported eCryptfs mounts on top
of the NFSv3 client.
vfs_rmdir() already calls d_delete() on the lower dentry. That was being
duplicated in ecryptfs_rmdir() and caused a NULL pointer dereference
when NFSv3 was the lower filesystem.
A requested key is write locked in order to prevent modifications on the
authentication token while it is being used.
Signed-off-by: Roberto Sassu <roberto.sassu@polito.it>
The ecryptfs_find_auth_tok_for_sig() call is moved before the
mutex_lock(s->tfm_mutex) instruction in order to avoid possible deadlocks
that may occur by holding the lock on the two semaphores 'key->sem' and
's->tfm_mutex' in reverse order.
Authentication tokens content may change if another requestor calls the
update() method of the corresponding key. The new function
ecryptfs_verify_auth_tok_from_key() retrieves the authentication token from
the provided key and verifies if it is still valid before being used to
encrypt or decrypt an eCryptfs file.
[tyhicks: Minor formatting changes]
The size of the 'keysig' array is incremented of one byte in order to make
room for the NULL character. The 'keysig' variable is used, in the function
ecryptfs_generate_key_packet_set(), to find an authentication token with
the given signature and is printed a debug message if it cannot be
retrieved.
This patch removes the 'num_global_auth_toks' field of the
ecryptfs_mount_crypt_stat structure, used to count the number of items in
the 'global_auth_tok_list' list. This variable is not needed because there
are no checks based upon it.
The pointer '(*auth_tok_key)' is set to NULL in case request_key()
fails, in order to prevent its use by functions calling
ecryptfs_keyring_auth_tok_for_sig().
Unlock the page in error path of ecryptfs_write_begin(). This may
happen, for example, if decryption fails while bring the page
up-to-date.
Change the write path to encrypt the data only when the page is written to
disk in ecryptfs_writepage. Previously, ecryptfs encrypts the page in
ecryptfs_write_end which means that if there are multiple write requests to
the same page, ecryptfs ends up re-encrypting that page over and over again.
This patch minimizes the number of encryptions needed.
[tyhicks: Changed NULL .drop_inode sop pointer to generic_drop_inode]
Now that grow_file() is not called in the ecryptfs_create() path, the
ECRYPTFS_NEW_FILE flag is no longer needed. It helped
ecryptfs_readpage() know not to decrypt zeroes that were read from the
lower file in the grow_file() path.
When creating a new eCryptfs file, the crypto metadata is written out
and then the lower file was being "grown" with 4 kB of encrypted zeroes.
I suspect that growing the encrypted file was to prevent an information
leak that the unencrypted file was empty. However, the unencrypted file
size is stored, in plaintext, in the metadata so growing the file is
unnecessary.
The lower filesystem may do some type of inode revalidation during a
getattr call. eCryptfs should take advantage of that by copying the
lower inode attributes to the eCryptfs inode after a call to
vfs_getattr() on the lower inode.
I originally wrote this fix while working on eCryptfs on nfsv3 support,
but discovered it also fixed an eCryptfs on ext4 nanosecond timestamp
bug that was reported.
https://bugs.launchpad.net/bugs/613873
read() calls against a file descriptor connected to a directory are
incorrectly returning EINVAL rather than EISDIR:
[EISDIR]
[XSI] [Option Start] The fildes argument refers to a directory and the
implementation does not allow the directory to be read using read()
or pread(). The readdir() function should be used instead. [Option End]
This occurs because we do not have a .read operation defined for
ecryptfs directories. Connect this up to generic_read_dir().
BugLink: http://bugs.launchpad.net/bugs/719691
Signed-off-by: Andy Whitcroft <apw@canonical.com>
Allow for NULL nameidata pointers in eCryptfs create, lookup, and
d_revalidate functions.
This reverts commit 21edad32205e97dc7ccb81a85234c77e760364c8 and commit
93c3fe40c279f002906ad14584c30671097d4394, which fixed a regression by
the former.
Al Viro pointed out bypassed dcache lookups in
ecryptfs_new_lower_dentry(), misuse of vfs_path_lookup() in
ecryptfs_lookup_one_lower() and a dislike of passing nameidata to the
lower filesystem.
Reported-by: Al Viro <viro@ZenIV.linux.org.uk>
