path: root/fs/ecryptfs
2011-12-09eCryptfs: Extend array bounds for all filename charsTyler Hicks
commit 0f751e641a71157aa584c2a2e22fda52b52b8a56 upstream. From mhalcrow's original commit message: Characters with ASCII values greater than the size of filename_rev_map[] are valid filename characters. ecryptfs_decode_from_filename() will access kernel memory beyond that array, and ecryptfs_parse_tag_70_packet() will then decrypt those characters. The attacker, using the FNEK of the crafted file, can then re-encrypt the characters to reveal the kernel memory past the end of the filename_rev_map[] array. I expect low security impact since this array is statically allocated in the text area, and the amount of memory past the array that is accessible is limited by the largest possible ASCII filename character. This patch solves the issue reported by mhalcrow but with an implementation suggested by Linus to simply extend the length of filename_rev_map[] to 256. Characters greater than 0x7A are mapped to 0x00, which is how invalid characters less than 0x7A were previously being handled. Signed-off-by: Tyler Hicks <tyhicks@canonical.com> Reported-by: Michael Halcrow <mhalcrow@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-09eCryptfs: Flush file in vma closeTyler Hicks
commit 32001d6fe9ac6b0423e674a3093aa56740849f3b upstream. Dirty pages weren't being written back when an mmap'ed eCryptfs file was closed before the mapping was unmapped. Since f_ops->flush() is not called by the munmap() path, the lower file was simply being released. This patch flushes the eCryptfs file in the vm_ops->close() path. https://launchpad.net/bugs/870326 Signed-off-by: Tyler Hicks <tyhicks@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-08-15eCryptfs: Return error when lower file pointer is NULLTyler Hicks
commit f61500e000eedc0c7a0201200a7f00ba5529c002 upstream. When an eCryptfs inode's lower file has been closed, and the pointer has been set to NULL, return an error when trying to do a lower read or write rather than calling BUG(). https://bugzilla.kernel.org/show_bug.cgi?id=37292 Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-08-15Ecryptfs: Add mount option to check uid of device being mounted = expect uidJohn Johansen
commit 764355487ea220fdc2faf128d577d7f679b91f97 upstream. Close a TOCTOU race for mounts done via ecryptfs-mount-private. The mount source (device) can be raced when the ownership test is done in userspace. Provide Ecryptfs a means to force the uid check at mount time. Signed-off-by: John Johansen <john.johansen@canonical.com> Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-08-04eCryptfs: Unlock keys needed by ecryptfsdTyler Hicks
commit b2987a5e05ec7a1af7ca42e5d5349d7a22753031 upstream. Fixes a regression caused by b5695d04634fa4ccca7dcbc05bb4a66522f02e0b Kernel keyring keys containing eCryptfs authentication tokens should not be write locked when calling out to ecryptfsd to wrap and unwrap file encryption keys. The eCryptfs kernel code can not hold the key's write lock because ecryptfsd needs to request the key after receiving such a request from the kernel. Without this fix, all file opens and creates will timeout and fail when using the eCryptfs PKI infrastructure. This is not an issue when using passphrase-based mount keys, which is the most widely deployed eCryptfs configuration. Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com> Acked-by: Roberto Sassu <roberto.sassu@polito.it> Tested-by: Roberto Sassu <roberto.sassu@polito.it> Tested-by: Alexis Hafner1 <haf@zurich.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-08-04ecryptfs: Make inode bdi consistent with superblock bdiThieu Le
commit 985ca0e626e195ea08a1a82b8dbeb6719747429a upstream. Make the inode mapping bdi consistent with the superblock bdi so that dirty pages are flushed properly. Signed-off-by: Thieu Le <thieule@chromium.org> Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-05-29eCryptfs: Remove ecryptfs_header_cache_2Tyler Hicks
Now that ecryptfs_lookup_interpose() is no longer using ecryptfs_header_cache_2 to read in metadata, the kmem_cache can be removed and the ecryptfs_header_cache_1 kmem_cache can be renamed to ecryptfs_header_cache. Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
2011-05-29eCryptfs: Cleanup and optimize ecryptfs_lookup_interpose()Tyler Hicks
ecryptfs_lookup_interpose() has turned into spaghetti code over the years. This is an effort to clean it up. - Shorten overly descriptive variable names such as ecryptfs_dentry - Simplify gotos and error paths - Create helper function for reading plaintext i_size from metadata It also includes an optimization when reading i_size from the metadata. A complete page-sized kmem_cache_alloc() was being done to read in 16 bytes of metadata. The buffer for that is now statically declared. Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
2011-05-29eCryptfs: Return useful code from contains_ecryptfs_markerTyler Hicks
Instead of having the calling functions translate the true/false return code to either 0 or -EINVAL, have contains_ecryptfs_marker() return 0 or -EINVAL so that the calling functions can just reuse the return code. Also, rename the function to ecryptfs_validate_marker() to avoid callers mistakenly thinking that it returns true/false codes. Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
2011-05-29eCryptfs: Fix new inode race conditionTyler Hicks
Only unlock and d_add() new inodes after the plaintext inode size has been read from the lower filesystem. This fixes a race condition that was sometimes seen during a multi-job kernel build in an eCryptfs mount. https://bugzilla.kernel.org/show_bug.cgi?id=36002 Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com> Reported-by: David <david@unsolicited.net> Tested-by: David <david@unsolicited.net>
2011-05-29eCryptfs: Cleanup inode initialization codeTyler Hicks
The eCryptfs inode get, initialization, and dentry interposition code has two separate paths. One is for when dentry interposition is needed after doing things like a mkdir in the lower filesystem and the other is needed after a lookup. Unlocking new inodes and doing a d_add() needs to happen at different times, depending on which type of dentry interposing is being done. This patch cleans up the inode get and initialization code paths and splits them up so that the locking and d_add() differences mentioned above can be handled appropriately in a later patch. Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com> Tested-by: David <david@unsolicited.net>
2011-05-29eCryptfs: Consolidate inode functions into inode.cTyler Hicks
These functions should live in inode.c since their focus is on inodes and they're primarily used by functions in inode.c. Also does a simple cleanup of ecryptfs_inode_test() and rolls ecryptfs_init_inode() into ecryptfs_inode_set(). Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com> Tested-by: David <david@unsolicited.net>
2011-05-28Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (36 commits) Cache xattr security drop check for write v2 fs: block_page_mkwrite should wait for writeback to finish mm: Wait for writeback when grabbing pages to begin a write configfs: remove unnecessary dentry_unhash on rmdir, dir rename fat: remove unnecessary dentry_unhash on rmdir, dir rename hpfs: remove unnecessary dentry_unhash on rmdir, dir rename minix: remove unnecessary dentry_unhash on rmdir, dir rename fuse: remove unnecessary dentry_unhash on rmdir, dir rename coda: remove unnecessary dentry_unhash on rmdir, dir rename afs: remove unnecessary dentry_unhash on rmdir, dir rename affs: remove unnecessary dentry_unhash on rmdir, dir rename 9p: remove unnecessary dentry_unhash on rmdir, dir rename ncpfs: fix rename over directory with dangling references ncpfs: document dentry_unhash usage ecryptfs: remove unnecessary dentry_unhash on rmdir, dir rename hostfs: remove unnecessary dentry_unhash on rmdir, dir rename hfsplus: remove unnecessary dentry_unhash on rmdir, dir rename hfs: remove unnecessary dentry_unhash on rmdir, dir rename omfs: remove unnecessary dentry_unhash on rmdir, dir rneame udf: remove unnecessary dentry_unhash from rmdir, dir rename ...
2011-05-28ecryptfs: remove unnecessary dentry_unhash on rmdir, dir renameSage Weil
ecryptfs does not have problems with references to unlinked directories. CC: Tyler Hicks <tyhicks@linux.vnet.ibm.com> CC: Dustin Kirkland <kirkland@canonical.com> CC: ecryptfs-devel@lists.launchpad.net Signed-off-by: Sage Weil <sage@newdream.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-27Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ecryptfs/ecryptfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ecryptfs/ecryptfs-2.6: MAINTAINERS: Update eCryptfs mailing list eCryptfs: Allow 2 scatterlist entries for encrypted filenames eCryptfs: Clear i_nlink in rmdir
2011-05-27eCryptfs: Allow 2 scatterlist entries for encrypted filenamesTyler Hicks
The buffers allocated while encrypting and decrypting long filenames can sometimes straddle two pages. In this situation, virt_to_scatterlist() will return -ENOMEM, causing the operation to fail and the user will get scary error messages in their logs: kernel: ecryptfs_write_tag_70_packet: Internal error whilst attempting to convert filename memory to scatterlist; expected rc = 1; got rc = [-12]. block_aligned_filename_size = [272] kernel: ecryptfs_encrypt_filename: Error attempting to generate tag 70 packet; rc = [-12] kernel: ecryptfs_encrypt_and_encode_filename: Error attempting to encrypt filename; rc = [-12] kernel: ecryptfs_lookup: Error attempting to encrypt and encode filename; rc = [-12] The solution is to allow up to 2 scatterlist entries to be used. Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com> Cc: <stable@kernel.org>
2011-05-27eCryptfs: Clear i_nlink in rmdirTyler Hicks
eCryptfs wasn't clearing the eCryptfs inode's i_nlink after a successful vfs_rmdir() on the lower directory. This resulted in the inode evict and destroy paths to be missed. https://bugs.launchpad.net/ecryptfs/+bug/723518 Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com> Cc: <stable@kernel.org>
2011-05-26vfs: push dentry_unhash on rename_dir into file systemsSage Weil
Only a few file systems need this. Start by pushing it down into each rename method (except gfs2 and xfs) so that it can be dealt with on a per-fs basis. Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Sage Weil <sage@newdream.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-26vfs: push dentry_unhash on rmdir into file systemsSage Weil
Only a few file systems need this. Start by pushing it down into each fs rmdir method (except gfs2 and xfs) so it can be dealt with on a per-fs basis. This does not change behavior for any in-tree file systems. Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Sage Weil <sage@newdream.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-04-25eCryptfs: Flush dirty pages in setattrTyler Hicks
After 57db4e8d73ef2b5e94a3f412108dff2576670a8a changed eCryptfs to write-back caching, eCryptfs page writeback updates the lower inode times due to the use of vfs_write() on the lower file. To preserve inode metadata changes, such as 'cp -p' does with utimensat(), we need to flush all dirty pages early in ecryptfs_setattr() so that the user-updated lower inode metadata isn't clobbered later in writeback. https://bugzilla.kernel.org/show_bug.cgi?id=33372 Reported-by: Rocko <rockorequin@hotmail.com> Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
2011-04-25eCryptfs: Handle failed metadata read in lookupTyler Hicks
When failing to read the lower file's crypto metadata during a lookup, eCryptfs must continue on without throwing an error. For example, there may be a plaintext file in the lower mount point that the user wants to delete through the eCryptfs mount. If an error is encountered while reading the metadata in lookup(), the eCryptfs inode's size could be incorrect. We must be sure to reread the plaintext inode size from the metadata when performing an open() or setattr(). The metadata is already being read in those paths, so this adds minimal performance overhead. This patch introduces a flag which will track whether or not the plaintext inode size has been read so that an incorrect i_size can be fixed in the open() or setattr() paths. https://bugs.launchpad.net/bugs/509180 Cc: <stable@kernel.org> Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
2011-04-25eCryptfs: Add reference counting to lower filesTyler Hicks
For any given lower inode, eCryptfs keeps only one lower file open and multiplexes all eCryptfs file operations through that lower file. The lower file was considered "persistent" and stayed open from the first lookup through the lifetime of the inode. This patch keeps the notion of a single, per-inode lower file, but adds reference counting around the lower file so that it is closed when not currently in use. If the reference count is at 0 when an operation (such as open, create, etc.) needs to use the lower file, a new lower file is opened. Since the file is no longer persistent, all references to the term persistent file are changed to lower file. Locking is added around the sections of code that opens the lower file and assign the pointer in the inode info, as well as the code the fputs the lower file when all eCryptfs users are done with it. This patch is needed to fix issues, when mounted on top of the NFSv3 client, where the lower file is left silly renamed until the eCryptfs inode is destroyed. Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
2011-04-25eCryptfs: dput dentries returned from dget_parentTyler Hicks
Call dput on the dentries previously returned by dget_parent() in ecryptfs_rename(). This is needed for supported eCryptfs mounts on top of the NFSv3 client. Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
2011-04-25eCryptfs: Remove extra d_delete in ecryptfs_rmdirTyler Hicks
vfs_rmdir() already calls d_delete() on the lower dentry. That was being duplicated in ecryptfs_rmdir() and caused a NULL pointer dereference when NFSv3 was the lower filesystem. Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
2011-03-28eCryptfs: write lock requested keysRoberto Sassu
A requested key is write locked in order to prevent modifications on the authentication token while it is being used. Signed-off-by: Roberto Sassu <roberto.sassu@polito.it> Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
2011-03-28eCryptfs: move ecryptfs_find_auth_tok_for_sig() call before mutex_lockRoberto Sassu
The ecryptfs_find_auth_tok_for_sig() call is moved before the mutex_lock(s->tfm_mutex) instruction in order to avoid possible deadlocks that may occur by holding the lock on the two semaphores 'key->sem' and 's->tfm_mutex' in reverse order. Signed-off-by: Roberto Sassu <roberto.sassu@polito.it> Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
2011-03-28eCryptfs: verify authentication tokens before their useRoberto Sassu
Authentication tokens content may change if another requestor calls the update() method of the corresponding key. The new function ecryptfs_verify_auth_tok_from_key() retrieves the authentication token from the provided key and verifies if it is still valid before being used to encrypt or decrypt an eCryptfs file. Signed-off-by: Roberto Sassu <roberto.sassu@polito.it> [tyhicks: Minor formatting changes] Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
2011-03-28eCryptfs: modified size of keysig in the ecryptfs_key_sig structureRoberto Sassu
The size of the 'keysig' array is incremented of one byte in order to make room for the NULL character. The 'keysig' variable is used, in the function ecryptfs_generate_key_packet_set(), to find an authentication token with the given signature and is printed a debug message if it cannot be retrieved. Signed-off-by: Roberto Sassu <roberto.sassu@polito.it> Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
2011-03-28eCryptfs: removed num_global_auth_toks from ecryptfs_mount_crypt_statRoberto Sassu
This patch removes the 'num_global_auth_toks' field of the ecryptfs_mount_crypt_stat structure, used to count the number of items in the 'global_auth_tok_list' list. This variable is not needed because there are no checks based upon it. Signed-off-by: Roberto Sassu <roberto.sassu@polito.it> Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
2011-03-28eCryptfs: ecryptfs_keyring_auth_tok_for_sig() bug fixRoberto Sassu
The pointer '(*auth_tok_key)' is set to NULL in case request_key() fails, in order to prevent its use by functions calling ecryptfs_keyring_auth_tok_for_sig(). Signed-off-by: Roberto Sassu <roberto.sassu@polito.it> Cc: <stable@kernel.org> Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
2011-03-28eCryptfs: Unlock page in write_begin error pathTyler Hicks
Unlock the page in error path of ecryptfs_write_begin(). This may happen, for example, if decryption fails while bring the page up-to-date. Cc: <stable@kernel.org> Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
2011-03-28ecryptfs: modify write path to encrypt page in writepageThieu Le
Change the write path to encrypt the data only when the page is written to disk in ecryptfs_writepage. Previously, ecryptfs encrypts the page in ecryptfs_write_end which means that if there are multiple write requests to the same page, ecryptfs ends up re-encrypting that page over and over again. This patch minimizes the number of encryptions needed. Signed-off-by: Thieu Le <thieule@chromium.org> [tyhicks: Changed NULL .drop_inode sop pointer to generic_drop_inode] Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
2011-03-28eCryptfs: Remove ECRYPTFS_NEW_FILE crypt stat flagTyler Hicks
Now that grow_file() is not called in the ecryptfs_create() path, the ECRYPTFS_NEW_FILE flag is no longer needed. It helped ecryptfs_readpage() know not to decrypt zeroes that were read from the lower file in the grow_file() path. Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
2011-03-28eCryptfs: Remove unnecessary grow_file() functionTyler Hicks
When creating a new eCryptfs file, the crypto metadata is written out and then the lower file was being "grown" with 4 kB of encrypted zeroes. I suspect that growing the encrypted file was to prevent an information leak that the unencrypted file was empty. However, the unencrypted file size is stored, in plaintext, in the metadata so growing the file is unnecessary. Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
2011-02-21eCryptfs: Copy up lower inode attrs in getattrTyler Hicks
The lower filesystem may do some type of inode revalidation during a getattr call. eCryptfs should take advantage of that by copying the lower inode attributes to the eCryptfs inode after a call to vfs_getattr() on the lower inode. I originally wrote this fix while working on eCryptfs on nfsv3 support, but discovered it also fixed an eCryptfs on ext4 nanosecond timestamp bug that was reported. https://bugs.launchpad.net/bugs/613873 Cc: <stable@kernel.org> Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
2011-02-21ecryptfs: read on a directory should return EISDIR if not supportedAndy Whitcroft
read() calls against a file descriptor connected to a directory are incorrectly returning EINVAL rather than EISDIR: [EISDIR] [XSI] [Option Start] The fildes argument refers to a directory and the implementation does not allow the directory to be read using read() or pread(). The readdir() function should be used instead. [Option End] This occurs because we do not have a .read operation defined for ecryptfs directories. Connect this up to generic_read_dir(). BugLink: http://bugs.launchpad.net/bugs/719691 Signed-off-by: Andy Whitcroft <apw@canonical.com> Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
2011-02-21eCryptfs: Handle NULL nameidata pointersTyler Hicks
Allow for NULL nameidata pointers in eCryptfs create, lookup, and d_revalidate functions. Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
2011-02-17eCryptfs: Revert "dont call lookup_one_len to avoid NULL nameidata"Tyler Hicks
This reverts commit 21edad32205e97dc7ccb81a85234c77e760364c8 and commit 93c3fe40c279f002906ad14584c30671097d4394, which fixed a regression by the former. Al Viro pointed out bypassed dcache lookups in ecryptfs_new_lower_dentry(), misuse of vfs_path_lookup() in ecryptfs_lookup_one_lower() and a dislike of passing nameidata to the lower filesystem. Reported-by: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
2011-01-17ecryptfs: remove unnecessary decrypt when extending a fileFrank Swiderski
Removes an unecessary page decrypt from ecryptfs_begin_write when the page is beyond the current file size. Previously, the call to ecryptfs_decrypt_page would result in a read of 0 bytes, but still attempt to decrypt an entire page. This patch detects that case and merely zeros the page before marking it up-to-date. Signed-off-by: Frank Swiderski <fes@chromium.org> Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
2011-01-17ecryptfs: Fix ecryptfs_printk() size_t warningsTyler Hicks
Commit cb55d21f6fa19d8c6c2680d90317ce88c1f57269 revealed a number of missing 'z' length modifiers in calls to ecryptfs_printk() when printing variables of type size_t. This patch fixes those compiler warnings. Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
2011-01-17fs/ecryptfs: Add printf format/argument verification and fix falloutJoe Perches
Add __attribute__((format... to __ecryptfs_printk Make formats and arguments match. Add casts to (unsigned long long) for %llu. Signed-off-by: Joe Perches <joe@perches.com> [tyhicks: 80 columns cleanup and fixed typo] Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
2011-01-17ecryptfs: fixed testing of file descriptor flagsRoberto Sassu
This patch replaces the check (lower_file->f_flags & O_RDONLY) with ((lower_file & O_ACCMODE) == O_RDONLY). Signed-off-by: Roberto Sassu <roberto.sassu@polito.it> Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
2011-01-17ecryptfs: test lower_file pointer when lower_file_mutex is lockedRoberto Sassu
This patch prevents the lower_file pointer in the 'ecryptfs_inode_info' structure to be checked when the mutex 'lower_file_mutex' is not locked. Signed-off-by: Roberto Sassu <roberto.sassu@polito.it> Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
2011-01-17ecryptfs: missing initialization of the superblock 'magic' fieldRoberto Sassu
This patch initializes the 'magic' field of ecryptfs filesystems to ECRYPTFS_SUPER_MAGIC. Signed-off-by: Roberto Sassu <roberto.sassu@polito.it> [tyhicks: merge with 66cb76666d69] Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
2011-01-17ecryptfs: moved ECRYPTFS_SUPER_MAGIC definition to linux/magic.hRoberto Sassu
The definition of ECRYPTFS_SUPER_MAGIC has been moved to the include file 'linux/magic.h' to become available to other kernel subsystems. Signed-off-by: Roberto Sassu <roberto.sassu@polito.it> Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
2011-01-17ecryptfs: fix truncation error in ecryptfs_read_update_atimeEdward Shishkin
This is similar to the bug found in direct-io not so long ago. Fix up truncation (ssize_t->int). This only matters with >2G reads/writes, which the kernel doesn't permit. Signed-off-by: Edward Shishkin <edward.shishkin@gmail.com> Cc: Jeff Moyer <jmoyer@redhat.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Eric Sandeen <esandeen@redhat.com> Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
2011-01-13ecryptfs: fix broken buildLinus Torvalds
Stephen Rothwell reports that the vfs merge broke the build of ecryptfs. The breakage comes from commit 66cb76666d69 ("sanitize ecryptfs ->mount()") which was obviously not even build tested. Tssk, tssk, Al. This is the minimal build fixup for the situation, although I don't have a filesystem to actually test it with. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-12sanitize ecryptfs ->mount()Al Viro
kill ecryptfs_read_super(), reorder code allowing to use normal d_alloc_root() instead of opencoding it. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-01-07fs: provide rcu-walk aware permission i_opsNick Piggin
Signed-off-by: Nick Piggin <npiggin@kernel.dk>
