path: root/fs/eventpoll.c
2008-04-29epoll: avoid kmemcheck warningDavide Libenzi
Epoll calls rb_set_parent(n, n) to initialize the rb-tree node, but rb_set_parent() accesses node's pointer in its code. This creates a warning in kmemcheck (reported by Vegard Nossum) about an uninitialized memory access. The warning is harmless since the following rb-tree node insert is going to overwrite the node data. In any case I think it's better to not have that happening at all, and fix it by simplifying the code to get rid of a few lines that became superfluous after the previous epoll changes. Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Cc: Vegard Nossum <vegard.nossum@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05lockdep: annotate epollPeter Zijlstra
On Sat, 2008-01-05 at 13:35 -0800, Davide Libenzi wrote: > I remember I talked with Arjan about this time ago. Basically, since 1) > you can drop an epoll fd inside another epoll fd 2) callback-based wakeups > are used, you can see a wake_up() from inside another wake_up(), but they > will never refer to the same lock instance. > Think about: > > dfd = socket(...); > efd1 = epoll_create(); > efd2 = epoll_create(); > epoll_ctl(efd1, EPOLL_CTL_ADD, dfd, ...); > epoll_ctl(efd2, EPOLL_CTL_ADD, efd1, ...); > > When a packet arrives to the device underneath "dfd", the net code will > issue a wake_up() on its poll wake list. Epoll (efd1) has installed a > callback wakeup entry on that queue, and the wake_up() performed by the > "dfd" net code will end up in ep_poll_callback(). At this point epoll > (efd1) notices that it may have some event ready, so it needs to wake up > the waiters on its poll wait list (efd2). So it calls ep_poll_safewake() > that ends up in another wake_up(), after having checked about the > recursion constraints. That are, no more than EP_MAX_POLLWAKE_NESTS, to > avoid stack blasting. Never hit the same queue, to avoid loops like: > > epoll_ctl(efd2, EPOLL_CTL_ADD, efd1, ...); > epoll_ctl(efd3, EPOLL_CTL_ADD, efd2, ...); > epoll_ctl(efd4, EPOLL_CTL_ADD, efd3, ...); > epoll_ctl(efd1, EPOLL_CTL_ADD, efd4, ...); > > The code "if (tncur->wq == wq || ..." prevents re-entering the same > queue/lock. Since the epoll code is very careful to not nest same instance locks allow the recursion. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Tested-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Acked-by: Davide Libenzi <davidel@xmailserver.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-06Use wake_up_locked() in eventpollMatthew Wilcox
Replace the uses of __wake_up_locked with wake_up_locked Signed-off-by: Matthew Wilcox <matthew@wil.cx>
2007-10-19fs/eventpoll.c: use list_for_each_entry() instead of list_for_each()Matthias Kaehlcke
fs/eventpoll.c: use list_for_each_entry() instead of list_for_each() in ep_poll_safewake() Signed-off-by: Matthias Kaehlcke <matthias.kaehlcke@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18sparse pointer use of zero as nullStephen Hemminger
Get rid of sparse related warnings from places that use integer as NULL pointer. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Cc: Andi Kleen <ak@suse.de> Cc: Jeff Garzik <jeff@garzik.org> Cc: Matt Mackall <mpm@selenic.com> Cc: Ian Kent <raven@themaw.net> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Davide Libenzi <davidel@xmailserver.org> Cc: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-15epoll: move kfree inside ep_freeDavide Libenzi
Move the kfree() call inside the ep_free() function. Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-15epoll: fix some commentsDavide Libenzi
Fixes some epoll code comments. Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-15epoll locks changes and cleanupsDavide Libenzi
Changes the rwlock to a spinlock, and drops the use-count variable. Operations are always bound by the mutex now, so the use-count is no more needed. For the same reason, the rwlock can become a simple spinlock. Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-15fix epoll single pass code and add wait-exclusive flagDavide Libenzi
Fixes the epoll single pass code. During the unlocked event delivery (to userspace) code, the poll callback can re-issue new events, and we must receive them correctly. Since we loop in a lockless fashion, we want to be O(nready), and we don't want to flash on/off the spinlock for every event, we have the poll callback to use a secondary list to queue events while we're inside the event delivery loop. The rw_semaphore has been turned into a mutex. This patch also adds the wait-exclusive flag, as suggested by Davi Arnaut. Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-11epoll cleanups: epoll remove static pre-declarations and akpm-ize the codeDavide Libenzi
Re-arrange epoll code to avoid static functions pre-declarations, and apply akpm-filter on it. Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-11epoll cleanups: epoll no moduleDavide Libenzi
Epoll is either compiled it, or not (if EMBEDDED). Remove the module code and use fs_initcall(). Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-11epoll: use anonymous inodesDavide Libenzi
Cut out lots of code from epoll, by reusing the anonymous inode source patch (fs/anon_inodes.c). Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Introduce a handy list_first_entry macroPavel Emelianov
There are many places in the kernel where the construction like foo = list_entry(head->next, struct foo_struct, list); are used. The code might look more descriptive and neat if using the macro list_first_entry(head, type, member) \ list_entry((head)->next, type, member) Here is the macro itself and the examples of its usage in the generic code. If it will turn out to be useful, I can prepare the set of patches to inject in into arch-specific code, drivers, networking, etc. Signed-off-by: Pavel Emelianov <xemul@openvz.org> Signed-off-by: Kirill Korotaev <dev@openvz.org> Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Zach Brown <zach.brown@oracle.com> Cc: Davide Libenzi <davidel@xmailserver.org> Cc: John McCutchan <ttb@tentacle.dhs.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: john stultz <johnstul@us.ibm.com> Cc: Ram Pai <linuxram@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08epoll: optimizations and cleanupsDavide Libenzi
Epoll is doing multiple passes over the ready set at the moment, because of the constraints over the f_op->poll() call. Looking at the code again, I noticed that we already hold the epoll semaphore in read, and this (together with other locking conditions that hold while doing an epoll_wait()) can lead to a smarter way [1] to "ship" events to userspace (in a single pass). This is a stress application that can be used to test the new code. It spwans multiple thread and call epoll_wait() and epoll_ctl() from many threads. Stress tested on my dual Opteron 254 w/out any problems. http://www.xmailserver.org/totalmess.c This is not a benchmark, just something that tries to stress and exploit possible problems with the new code. Also, I made a stupid micro-benchmark: http://www.xmailserver.org/epwbench.c [1] Considering that epoll must be thread-safe, there are five ways we can be hit during an epoll_wait() transfer loop (ep_send_events()): 1) The epoll fd going away and calling ep_free This just can't happen, since we did an fget() in sys_epoll_wait 2) An epoll_ctl(EPOLL_CTL_DEL) This can't happen because epoll_ctl() gets ep->sem in write, and we're holding it in read during ep_send_events() 3) An fd stored inside the epoll fd going away This can't happen because in eventpoll_release_file() we get ep->sem in write, and we're holding it in read during ep_send_events() 4) Another epoll_wait() happening on another thread They both can be inside ep_send_events() at the same time, we get (splice) the ready-list under the spinlock, so each one will get its own ready list. Note that an fd cannot be at the same time inside more than one ready list, because ep_poll_callback() will not re-queue it if it sees it already linked: if (ep_is_linked(&epi->rdllink)) goto is_linked; Another case that can happen, is two concurrent epoll_wait(), coming in with a userspace event buffer of size, say, ten. Suppose there are 50 event ready in the list. The first epoll_wait() will "steal" the whole list, while the second, seeing no events, will go to sleep. But at the end of ep_send_events() in the first epoll_wait(), we will re-inject surplus ready fds, and we will trigger the proper wake_up to the second epoll_wait(). 5) ep_poll_callback() hitting us asyncronously This is the tricky part. As I said above, the ep_is_linked() test done inside ep_poll_callback(), will guarantee us that until the item will result linked to a list, ep_poll_callback() will not try to re-queue it again (read, write data on any of its members). When we do a list_del() in ep_send_events(), the item will still satisfy the ep_is_linked() test (whatever data is written in prev/next, it'll never be its own pointer), so ep_poll_callback() will still leave us alone. It's only after the eventual smp_mb()+INIT_LIST_HEAD(&epi->rdllink) that it'll become visible to ep_poll_callback(), but at the point we're already past it. [akpm@osdl.org: 80 cols] Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-08[PATCH] VFS: change struct file to use struct pathJosef "Jeff" Sipek
This patch changes struct file to use struct path instead of having independent pointers to struct dentry and struct vfsmount, and converts all users of f_{dentry,vfsmnt} in fs/ to use f_path.{dentry,mnt}. Additionally, it adds two #define's to make the transition easier for users of the f_dentry and f_vfsmnt. Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] epoll_pwait()Davide Libenzi
Implement the epoll_pwait system call, that extend the event wait mechanism with the same logic ppoll and pselect do. The definition of epoll_pwait is: int epoll_pwait(int epfd, struct epoll_event *events, int maxevents, int timeout, const sigset_t *sigmask, size_t sigsetsize); The difference between the vanilla epoll_wait and epoll_pwait is that the latter allows the caller to specify a signal mask to be set while waiting for events. Hence epoll_pwait will wait until either one monitored event, or an unmasked signal happen. If sigmask is NULL, the epoll_pwait system call will act exactly like epoll_wait. For the POSIX definition of pselect, information is available here: http://www.opengroup.org/onlinepubs/009695399/functions/select.html Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Andi Kleen <ak@muc.de> Cc: Michael Kerrisk <mtk-manpages@gmx.net> Cc: Ulrich Drepper <drepper@redhat.com> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03[PATCH] fs/eventpoll: error handling micro-cleanupJeff Garzik
While reviewing the 'may be used uninitialized' bogus gcc warnings, I noticed that an error code assignment was only needed if an error had actually occured. Signed-off-by: Jeff Garzik <jeff@garzik.org> Cc: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-27[PATCH] eventpoll.c compile fixMasoud Asgharifard Sharbiani
Fix two compile failures in eventpoll.c code which would happen if DEBUG_EPOLL is bigger than zero. Signed-off-by: Masoud Sharbiani <masouds@google.com> Cc: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] sched: cleanup, remove task_t, convert to struct task_structIngo Molnar
cleanup: remove task_t and convert all the uses to struct task_struct. I introduced it for the scheduler anno and it was a mistake. Conversion was mostly scripted, the result was reviewed and all secondary whitespace and style impact (if any) was fixed up by hand. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] epoll: use unlocked wqueue operationsDavide Libenzi
A few days ago Arjan signaled a lockdep red flag on epoll locks, and precisely between the epoll's device structure lock (->lock) and the wait queue head lock (->lock). Like I explained in another email, and directly to Arjan, this can't happen in reality because of the explicit check at eventpoll.c:592, that does not allow to drop an epoll fd inside the same epoll fd. Since lockdep is working on per-structure locks, it will never be able to know of policies enforced in other parts of the code. It was decided time ago of having the ability to drop epoll fds inside other epoll fds, that triggers a very trick wakeup operations (due to possibly reentrant callback-driven wakeups) handled by the ep_poll_safewake() function. While looking again at the code though, I noticed that all the operations done on the epoll's main structure wait queue head (->wq) are already protected by the epoll lock (->lock), so that locked-style functions can be used to manipulate the ->wq member. This makes both a lock-acquire save, and lockdep happy. Running totalmess on my dual opteron for a while did not reveal any problem so far: http://www.xmailserver.org/totalmess.c Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Cc: Arjan van de Ven <arjan@linux.intel.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] VFS: Permit filesystem to override root dentry on mountDavid Howells
Extend the get_sb() filesystem operation to take an extra argument that permits the VFS to pass in the target vfsmount that defines the mountpoint. The filesystem is then required to manually set the superblock and root dentry pointers. For most filesystems, this should be done with simple_set_mnt() which will set the superblock pointer and then set the root dentry to the superblock's s_root (as per the old default behaviour). The get_sb() op now returns an integer as there's now no need to return the superblock pointer. This patch permits a superblock to be implicitly shared amongst several mount points, such as can be done with NFS to avoid potential inode aliasing. In such a case, simple_set_mnt() would not be called, and instead the mnt_root and mnt_sb would be set directly. The patch also makes the following changes: (*) the get_sb_*() convenience functions in the core kernel now take a vfsmount pointer argument and return an integer, so most filesystems have to change very little. (*) If one of the convenience function is not used, then get_sb() should normally call simple_set_mnt() to instantiate the vfsmount. This will always return 0, and so can be tail-called from get_sb(). (*) generic_shutdown_super() now calls shrink_dcache_sb() to clean up the dcache upon superblock destruction rather than shrink_dcache_anon(). This is required because the superblock may now have multiple trees that aren't actually bound to s_root, but that still need to be cleaned up. The currently called functions assume that the whole tree is rooted at s_root, and that anonymous dentries are not the roots of trees which results in dentries being left unculled. However, with the way NFS superblock sharing are currently set to be implemented, these assumptions are violated: the root of the filesystem is simply a dummy dentry and inode (the real inode for '/' may well be inaccessible), and all the vfsmounts are rooted on anonymous[*] dentries with child trees. [*] Anonymous until discovered from another tree. (*) The documentation has been adjusted, including the additional bit of changing ext2_* into foo_* in the documentation. [akpm@osdl.org: convert ipath_fs, do other stuff] Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Nathan Scott <nathans@sgi.com> Cc: Roland Dreier <rolandd@cisco.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-21[RBTREE] Update eventpoll.c to use rb_parent() accessor macro.David Woodhouse
2006-04-11[PATCH] uniform POLLRDHUP handling between epoll and poll/selectDavide Libenzi
As reported by Michael Kerrisk, POLLRDHUP handling was not consistent between epoll and poll/select, since in epoll it was unmaskeable. This patch brings uniformity in POLLRDHUP handling. Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Cc: Michael Kerrisk <mtk-manpages@gmx.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] Make most file operations structs in fs/ constArjan van de Ven
This is a conversion to make the various file_operations structs in fs/ const. Basically a regexp job, with a few manual fixups The goal is both to increase correctness (harder to accidentally write to shared datastructures) and reducing the false sharing of cachelines with things that get dirty in .data (while .rodata is nicely read only and thus cache clean) Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] Use __read_mostly on some hot fs variablesEric Dumazet
I discovered on oprofile hunting on a SMP platform that dentry lookups were slowed down because d_hash_mask, d_hash_shift and dentry_hashtable were in a cache line that contained inodes_stat. So each time inodes_stats is changed by a cpu, other cpus have to refill their cache line. This patch moves some variables to the __read_mostly section, in order to avoid false sharing. RCU dentry lookups can go full speed. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25[PATCH] POLLRDHUP/EPOLLRDHUP handling for half-closed devices notificationsDavide Libenzi
Implement the half-closed devices notifiation, by adding a new POLLRDHUP (and its alias EPOLLRDHUP) bit to the existing poll/select sets. Since the existing POLLHUP handling, that does not report correctly half-closed devices, was feared to be changed, this implementation leaves the current POLLHUP reporting unchanged and simply add a new bit that is set in the few places where it makes sense. The same thing was discussed and conceptually agreed quite some time ago: http://lkml.org/lkml/2003/7/12/116 Since this new event bit is added to the existing Linux poll infrastruture, even the existing poll/select system calls will be able to use it. As far as the existing POLLHUP handling, the patch leaves it as is. The pollrdhup-2.6.16.rc5-0.10.diff defines the POLLRDHUP for all the existing archs and sets the bit in the six relevant files. The other attached diff is the simple change required to sys/epoll.h to add the EPOLLRDHUP definition. There is "a stupid program" to test POLLRDHUP delivery here: http://www.xmailserver.org/pollrdhup-test.c It tests poll(2), but since the delivery is same epoll(2) will work equally. Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Michael Kerrisk <mtk-manpages@gmx.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] get_empty_filp tweaks, inline epoll_init_file()Benjamin LaHaise
Eliminate a handful of cache references by keeping current in a register instead of reloading (helps x86) and avoiding the overhead of a function call. Inlining eventpoll_init_file() saves 24 bytes. Also reorder file initialization to make writes occur more sequentially. Signed-off-by: Benjamin LaHaise <bcrl@linux.intel.com> Cc: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] sem2mutex: eventpollArjan van de Ven
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-28[PATCH] epoll: handle timeout overflowDavide Libenzi
Handle the timeout upper boundary for epoll. Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-17[PATCH] epoll: fix delayed initialization bugDavide Libenzi
Al found a potential problem in epoll_create(), where the file->private_data member was set after fd_install(). This is obviously wrong since another thread might do a close() on that fd# before we set the file->private_data member. This goes over 2.6.13 and passes a few basic tests I've done here. (akpm: snuck in a kzalloc() cleanup too) Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-23[PATCH] Remove eventpoll macro obfuscationPekka Enberg
This patch gets rid of some macro obfuscation from fs/eventpoll.c by removing slab allocator wrappers and converting macros to static inline functions. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-05[PATCH] make some things staticAdrian Bunk
This patch makes some needlessly global identifiers static. Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Arjan van de Ven <arjanv@infradead.org> Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
