path: root/fs/eventpoll.c
2006-10-11[PATCH] epoll_pwait()Davide Libenzi
Implement the epoll_pwait system call, that extend the event wait mechanism with the same logic ppoll and pselect do. The definition of epoll_pwait is: int epoll_pwait(int epfd, struct epoll_event *events, int maxevents, int timeout, const sigset_t *sigmask, size_t sigsetsize); The difference between the vanilla epoll_wait and epoll_pwait is that the latter allows the caller to specify a signal mask to be set while waiting for events. Hence epoll_pwait will wait until either one monitored event, or an unmasked signal happen. If sigmask is NULL, the epoll_pwait system call will act exactly like epoll_wait. For the POSIX definition of pselect, information is available here: http://www.opengroup.org/onlinepubs/009695399/functions/select.html Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Andi Kleen <ak@muc.de> Cc: Michael Kerrisk <mtk-manpages@gmx.net> Cc: Ulrich Drepper <drepper@redhat.com> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03[PATCH] fs/eventpoll: error handling micro-cleanupJeff Garzik
While reviewing the 'may be used uninitialized' bogus gcc warnings, I noticed that an error code assignment was only needed if an error had actually occured. Signed-off-by: Jeff Garzik <jeff@garzik.org> Cc: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-27[PATCH] eventpoll.c compile fixMasoud Asgharifard Sharbiani
Fix two compile failures in eventpoll.c code which would happen if DEBUG_EPOLL is bigger than zero. Signed-off-by: Masoud Sharbiani <masouds@google.com> Cc: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] sched: cleanup, remove task_t, convert to struct task_structIngo Molnar
cleanup: remove task_t and convert all the uses to struct task_struct. I introduced it for the scheduler anno and it was a mistake. Conversion was mostly scripted, the result was reviewed and all secondary whitespace and style impact (if any) was fixed up by hand. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] epoll: use unlocked wqueue operationsDavide Libenzi
A few days ago Arjan signaled a lockdep red flag on epoll locks, and precisely between the epoll's device structure lock (->lock) and the wait queue head lock (->lock). Like I explained in another email, and directly to Arjan, this can't happen in reality because of the explicit check at eventpoll.c:592, that does not allow to drop an epoll fd inside the same epoll fd. Since lockdep is working on per-structure locks, it will never be able to know of policies enforced in other parts of the code. It was decided time ago of having the ability to drop epoll fds inside other epoll fds, that triggers a very trick wakeup operations (due to possibly reentrant callback-driven wakeups) handled by the ep_poll_safewake() function. While looking again at the code though, I noticed that all the operations done on the epoll's main structure wait queue head (->wq) are already protected by the epoll lock (->lock), so that locked-style functions can be used to manipulate the ->wq member. This makes both a lock-acquire save, and lockdep happy. Running totalmess on my dual opteron for a while did not reveal any problem so far: http://www.xmailserver.org/totalmess.c Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Cc: Arjan van de Ven <arjan@linux.intel.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] VFS: Permit filesystem to override root dentry on mountDavid Howells
Extend the get_sb() filesystem operation to take an extra argument that permits the VFS to pass in the target vfsmount that defines the mountpoint. The filesystem is then required to manually set the superblock and root dentry pointers. For most filesystems, this should be done with simple_set_mnt() which will set the superblock pointer and then set the root dentry to the superblock's s_root (as per the old default behaviour). The get_sb() op now returns an integer as there's now no need to return the superblock pointer. This patch permits a superblock to be implicitly shared amongst several mount points, such as can be done with NFS to avoid potential inode aliasing. In such a case, simple_set_mnt() would not be called, and instead the mnt_root and mnt_sb would be set directly. The patch also makes the following changes: (*) the get_sb_*() convenience functions in the core kernel now take a vfsmount pointer argument and return an integer, so most filesystems have to change very little. (*) If one of the convenience function is not used, then get_sb() should normally call simple_set_mnt() to instantiate the vfsmount. This will always return 0, and so can be tail-called from get_sb(). (*) generic_shutdown_super() now calls shrink_dcache_sb() to clean up the dcache upon superblock destruction rather than shrink_dcache_anon(). This is required because the superblock may now have multiple trees that aren't actually bound to s_root, but that still need to be cleaned up. The currently called functions assume that the whole tree is rooted at s_root, and that anonymous dentries are not the roots of trees which results in dentries being left unculled. However, with the way NFS superblock sharing are currently set to be implemented, these assumptions are violated: the root of the filesystem is simply a dummy dentry and inode (the real inode for '/' may well be inaccessible), and all the vfsmounts are rooted on anonymous[*] dentries with child trees. [*] Anonymous until discovered from another tree. (*) The documentation has been adjusted, including the additional bit of changing ext2_* into foo_* in the documentation. [akpm@osdl.org: convert ipath_fs, do other stuff] Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Nathan Scott <nathans@sgi.com> Cc: Roland Dreier <rolandd@cisco.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-21[RBTREE] Update eventpoll.c to use rb_parent() accessor macro.David Woodhouse
2006-04-11[PATCH] uniform POLLRDHUP handling between epoll and poll/selectDavide Libenzi
As reported by Michael Kerrisk, POLLRDHUP handling was not consistent between epoll and poll/select, since in epoll it was unmaskeable. This patch brings uniformity in POLLRDHUP handling. Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Cc: Michael Kerrisk <mtk-manpages@gmx.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] Make most file operations structs in fs/ constArjan van de Ven
This is a conversion to make the various file_operations structs in fs/ const. Basically a regexp job, with a few manual fixups The goal is both to increase correctness (harder to accidentally write to shared datastructures) and reducing the false sharing of cachelines with things that get dirty in .data (while .rodata is nicely read only and thus cache clean) Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] Use __read_mostly on some hot fs variablesEric Dumazet
I discovered on oprofile hunting on a SMP platform that dentry lookups were slowed down because d_hash_mask, d_hash_shift and dentry_hashtable were in a cache line that contained inodes_stat. So each time inodes_stats is changed by a cpu, other cpus have to refill their cache line. This patch moves some variables to the __read_mostly section, in order to avoid false sharing. RCU dentry lookups can go full speed. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25[PATCH] POLLRDHUP/EPOLLRDHUP handling for half-closed devices notificationsDavide Libenzi
Implement the half-closed devices notifiation, by adding a new POLLRDHUP (and its alias EPOLLRDHUP) bit to the existing poll/select sets. Since the existing POLLHUP handling, that does not report correctly half-closed devices, was feared to be changed, this implementation leaves the current POLLHUP reporting unchanged and simply add a new bit that is set in the few places where it makes sense. The same thing was discussed and conceptually agreed quite some time ago: http://lkml.org/lkml/2003/7/12/116 Since this new event bit is added to the existing Linux poll infrastruture, even the existing poll/select system calls will be able to use it. As far as the existing POLLHUP handling, the patch leaves it as is. The pollrdhup-2.6.16.rc5-0.10.diff defines the POLLRDHUP for all the existing archs and sets the bit in the six relevant files. The other attached diff is the simple change required to sys/epoll.h to add the EPOLLRDHUP definition. There is "a stupid program" to test POLLRDHUP delivery here: http://www.xmailserver.org/pollrdhup-test.c It tests poll(2), but since the delivery is same epoll(2) will work equally. Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Michael Kerrisk <mtk-manpages@gmx.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] get_empty_filp tweaks, inline epoll_init_file()Benjamin LaHaise
Eliminate a handful of cache references by keeping current in a register instead of reloading (helps x86) and avoiding the overhead of a function call. Inlining eventpoll_init_file() saves 24 bytes. Also reorder file initialization to make writes occur more sequentially. Signed-off-by: Benjamin LaHaise <bcrl@linux.intel.com> Cc: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] sem2mutex: eventpollArjan van de Ven
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-28[PATCH] epoll: handle timeout overflowDavide Libenzi
Handle the timeout upper boundary for epoll. Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-17[PATCH] epoll: fix delayed initialization bugDavide Libenzi
Al found a potential problem in epoll_create(), where the file->private_data member was set after fd_install(). This is obviously wrong since another thread might do a close() on that fd# before we set the file->private_data member. This goes over 2.6.13 and passes a few basic tests I've done here. (akpm: snuck in a kzalloc() cleanup too) Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-23[PATCH] Remove eventpoll macro obfuscationPekka Enberg
This patch gets rid of some macro obfuscation from fs/eventpoll.c by removing slab allocator wrappers and converting macros to static inline functions. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-05[PATCH] make some things staticAdrian Bunk
This patch makes some needlessly global identifiers static. Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Arjan van de Ven <arjanv@infradead.org> Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
