path: root/fs/eventpoll.c
2011-01-13epoll: convert max_user_watches to longRobin Holt
On a 16TB machine, max_user_watches has an integer overflow. Convert it to use a long and handle the associated fallout. Signed-off-by: Robin Holt <holt@sgi.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Davide Libenzi <davidel@xmailserver.org> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27epoll: make epoll_wait() use the hrtimer range featureShawn Bohrer
This make epoll use hrtimers for the timeout value which prevents epoll_wait() from timing out up to a millisecond early. This mirrors the behavior of select() and poll(). Signed-off-by: Shawn Bohrer <shawn.bohrer@gmail.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Davide Libenzi <davidel@xmailserver.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
All file_operations should get a .llseek operation so we can make nonseekable_open the default for future file operations without a .llseek pointer. The three cases that we can automatically detect are no_llseek, seq_lseek and default_llseek. For cases where we can we can automatically prove that the file offset is always ignored, we use noop_llseek, which maintains the current behavior of not returning an error from a seek. New drivers should normally not use noop_llseek but instead use no_llseek and call nonseekable_open at open time. Existing drivers can be converted to do the same when the maintainer knows for certain that no user code relies on calling seek on the device file. The generated code is often incorrectly indented and right now contains comments that clarify for each added line why a specific variant was chosen. In the version that gets submitted upstream, the comments will be gone and I will manually fix the indentation, because there does not seem to be a way to do that using coccinelle. Some amount of new code is currently sitting in linux-next that should get the same modifications, which I will do at the end of the merge window. Many thanks to Julia Lawall for helping me learn to write a semantic patch that does all this. ===== begin semantic patch ===== // This adds an llseek= method to all file operations, // as a preparation for making no_llseek the default. // // The rules are // - use no_llseek explicitly if we do nonseekable_open // - use seq_lseek for sequential files // - use default_llseek if we know we access f_pos // - use noop_llseek if we know we don't access f_pos, // but we still want to allow users to call lseek // @ open1 exists @ identifier nested_open; @@ nested_open(...) { <+... nonseekable_open(...) ...+> } @ open exists@ identifier open_f; identifier i, f; identifier open1.nested_open; @@ int open_f(struct inode *i, struct file *f) { <+... ( nonseekable_open(...) | nested_open(...) ) ...+> } @ read disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ read_no_fpos disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { ... when != off } @ write @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ write_no_fpos @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { ... when != off } @ fops0 @ identifier fops; @@ struct file_operations fops = { ... }; @ has_llseek depends on fops0 @ identifier fops0.fops; identifier llseek_f; @@ struct file_operations fops = { ... .llseek = llseek_f, ... }; @ has_read depends on fops0 @ identifier fops0.fops; identifier read_f; @@ struct file_operations fops = { ... .read = read_f, ... }; @ has_write depends on fops0 @ identifier fops0.fops; identifier write_f; @@ struct file_operations fops = { ... .write = write_f, ... }; @ has_open depends on fops0 @ identifier fops0.fops; identifier open_f; @@ struct file_operations fops = { ... .open = open_f, ... }; // use no_llseek if we call nonseekable_open //////////////////////////////////////////// @ nonseekable1 depends on !has_llseek && has_open @ identifier fops0.fops; identifier nso ~= "nonseekable_open"; @@ struct file_operations fops = { ... .open = nso, ... +.llseek = no_llseek, /* nonseekable */ }; @ nonseekable2 depends on !has_llseek @ identifier fops0.fops; identifier open.open_f; @@ struct file_operations fops = { ... .open = open_f, ... +.llseek = no_llseek, /* open uses nonseekable */ }; // use seq_lseek for sequential files ///////////////////////////////////// @ seq depends on !has_llseek @ identifier fops0.fops; identifier sr ~= "seq_read"; @@ struct file_operations fops = { ... .read = sr, ... +.llseek = seq_lseek, /* we have seq_read */ }; // use default_llseek if there is a readdir /////////////////////////////////////////// @ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier readdir_e; @@ // any other fop is used that changes pos struct file_operations fops = { ... .readdir = readdir_e, ... +.llseek = default_llseek, /* readdir is present */ }; // use default_llseek if at least one of read/write touches f_pos ///////////////////////////////////////////////////////////////// @ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read.read_f; @@ // read fops use offset struct file_operations fops = { ... .read = read_f, ... +.llseek = default_llseek, /* read accesses f_pos */ }; @ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, ... + .llseek = default_llseek, /* write accesses f_pos */ }; // Use noop_llseek if neither read nor write accesses f_pos /////////////////////////////////////////////////////////// @ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; identifier write_no_fpos.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, .read = read_f, ... +.llseek = noop_llseek, /* read and write both use no f_pos */ }; @ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write_no_fpos.write_f; @@ struct file_operations fops = { ... .write = write_f, ... +.llseek = noop_llseek, /* write uses no f_pos */ }; @ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; @@ struct file_operations fops = { ... .read = read_f, ... +.llseek = noop_llseek, /* read uses no f_pos */ }; @ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; @@ struct file_operations fops = { ... +.llseek = noop_llseek, /* no read or write fn */ }; ===== End semantic patch ===== Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Julia Lawall <julia@diku.dk> Cc: Christoph Hellwig <hch@infradead.org>
2010-05-11sched, wait: Use wrapper functionsChangli Gao
epoll should not touch flags in wait_queue_t. This patch introduces a new function __add_wait_queue_exclusive(), for the users, who use wait queue as a LIFO queue. __add_wait_queue_tail_exclusive() is introduced too instead of add_wait_queue_exclusive_locked(). remove_wait_queue_locked() is removed, as it is a duplicate of __remove_wait_queue(), disliked by users, and with less users. Signed-off-by: Changli Gao <xiaosuo@gmail.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Paul Menage <menage@google.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Davide Libenzi <davidel@xmailserver.org> Cc: <containers@lists.linux-foundation.org> LKML-Reference: <1273214006-2979-1-git-send-email-xiaosuo@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-22anonfd: Allow making anon files read-onlyRoland Dreier
It seems a couple places such as arch/ia64/kernel/perfmon.c and drivers/infiniband/core/uverbs_main.c could use anon_inode_getfile() instead of a private pseudo-fs + alloc_file(), if only there were a way to get a read-only file. So provide this by having anon_inode_getfile() create a read-only file if we pass O_RDONLY in flags. Signed-off-by: Roland Dreier <rolandd@cisco.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-11-18sysctl: Drop & in front of every proc_handler.Eric W. Biederman
For consistency drop & in front of every proc_handler. Explicity taking the address is unnecessary and it prevents optimizations like stubbing the proc_handlers to NULL. Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Joe Perches <joe@perches.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2009-11-12sysctl fs: Remove dead binary sysctl supportEric W. Biederman
Now that sys_sysctl is a generic wrapper around /proc/sys .ctl_name and .strategy members of sysctl tables are dead code. Remove them. Cc: Jan Harkes <jaharkes@cs.cmu.edu> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2009-06-18epoll: fix nested calls supportDavide Libenzi
This fixes a regression in 2.6.30. I unfortunately accepted a patch time ago, to drop the "current" usage from possible IRQ context, w/out proper thought over it. The patch switched to using the CPU id by bounding the nested call callback with a get_cpu()/put_cpu(). Unfortunately the ep_call_nested() function can be called with a callback that grabs sleepy locks (from own f_op->poll()), that results in epic fails. The following patch uses the proper "context" depending on the path where it is called, and on the kind of callback. This has been reported by Stefan Richter, that has also verified the patch is his previously failing environment. Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Reported-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-05-12epoll: fix size check in epoll_create()Davide Libenzi
Fix a size check WRT the manual pages. This was inadvertently broken by commit 9fe5ad9c8cef9ad5873d8ee55d1cf00d9b607df0 ("flag parameters add-on: remove epoll_create size param"). Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Cc: <Hiroyuki.Mach@gmail.com> Cc: rohit verma <rohit.170309@gmail.com> Cc: Ulrich Drepper <drepper@redhat.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01epoll keyed wakeups: teach epoll about hints coming with the wakeup keyDavide Libenzi
Use the events hint now sent by some devices, to avoid unnecessary wakeups for events that are of no interest for the caller. This code handles both devices that are sending keyed events, and the ones that are not (and event the ones that sometimes send events, and sometimes don't). [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: William Lee Irwin III <wli@movementarian.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01epoll: use real type instead of void *Tony Battersby
eventpoll.c uses void * in one place for no obvious reason; change it to use the real type instead. Signed-off-by: Tony Battersby <tonyb@cybernetics.com> Acked-by: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01epoll: clean up ep_modifyTony Battersby
ep_modify() doesn't need to set event.data from within the ep->lock spinlock as the comment suggests. The only place event.data is used is ep_send_events_proc(), and this is protected by ep->mtx instead of ep->lock. Also update the comment for mutex_lock() at the top of ep_scan_ready_list(), which mentions epoll_ctl(EPOLL_CTL_DEL) but not epoll_ctl(EPOLL_CTL_MOD). ep_modify() can also use spin_lock_irq() instead of spin_lock_irqsave(). Signed-off-by: Tony Battersby <tonyb@cybernetics.com> Acked-by: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01epoll: remove unnecessary xchgTony Battersby
xchg in ep_unregister_pollwait() is unnecessary because it is protected by either epmutex or ep->mtx (the same protection as ep_remove()). If xchg was necessary, it would be insufficient to protect against problems: if multiple concurrent calls to ep_unregister_pollwait() were possible then a second caller that returns without doing anything because nwait == 0 could return before the waitqueues are removed by the first caller, which looks like it could lead to problematic races with ep_poll_callback(). So remove xchg and add comments about the locking. Signed-off-by: Tony Battersby <tonyb@cybernetics.com> Acked-by: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01epoll: remember the event if epoll_wait returns -EFAULTTony Battersby
If epoll_wait returns -EFAULT, the event that was being returned when the fault was encountered will be forgotten. This is not a big deal since EFAULT will happen only if a buggy userspace program passes in a bad address, in which case what happens later usually doesn't matter. However, it is easy to remember the event for later, and this patch makes a simple change to do that. Signed-off-by: Tony Battersby <tonyb@cybernetics.com> Acked-by: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01epoll: don't use current in irq contextTony Battersby
ep_call_nested() (formerly ep_poll_safewake()) uses "current" (without dereferencing it) to detect callback recursion, but it may be called from irq context where the use of current is generally discouraged. It would be better to use get_cpu() and put_cpu() to detect the callback recursion. Signed-off-by: Tony Battersby <tonyb@cybernetics.com> Acked-by: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01epoll: remove debugging codeDavide Libenzi
Remove debugging code from epoll. There's no need for it to be included into mainline code. Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01epoll: fix epoll's own poll (update)Davide Libenzi
Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Cc: Pavel Pisa <pisa@cmp.felk.cvut.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01epoll: fix epoll's own pollDavide Libenzi
Fix a bug inside the epoll's f_op->poll() code, that returns POLLIN even though there are no actual ready monitored fds. The bug shows up if you add an epoll fd inside another fd container (poll, select, epoll). The problem is that callback-based wake ups used by epoll does not carry (patches will follow, to fix this) any information about the events that actually happened. So the callback code, since it can't call the file* ->poll() inside the callback, chains the file* into a ready-list. So, suppose you added an fd with EPOLLOUT only, and some data shows up on the fd, the file* mapped by the fd will be added into the ready-list (via wakeup callback). During normal epoll_wait() use, this condition is sorted out at the time we're actually able to call the file*'s f_op->poll(). Inside the old epoll's f_op->poll() though, only a quick check !list_empty(ready-list) was performed, and this could have led to reporting POLLIN even though no ready fds would show up at a following epoll_wait(). In order to correctly report the ready status for an epoll fd, the ready-list must be checked to see if any really available fd+event would be ready in a following epoll_wait(). Operation (calling f_op->poll() from inside f_op->poll()) that, like wake ups, must be handled with care because of the fact that epoll fds can be added to other epoll fds. Test code: /* * epoll_test by Davide Libenzi (Simple code to test epoll internals) * Copyright (C) 2008 Davide Libenzi * * This program is free software; you can redistribute it and/or modify * it under the terms of the GNU General Public License as published by * the Free Software Foundation; either version 2 of the License, or * (at your option) any later version. * * This program is distributed in the hope that it will be useful, * but WITHOUT ANY WARRANTY; without even the implied warranty of * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the * GNU General Public License for more details. * * You should have received a copy of the GNU General Public License * along with this program; if not, write to the Free Software * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA * * Davide Libenzi <davidel@xmailserver.org> * */ #include <sys/types.h> #include <unistd.h> #include <stdio.h> #include <stdlib.h> #include <string.h> #include <errno.h> #include <signal.h> #include <limits.h> #include <poll.h> #include <sys/epoll.h> #include <sys/wait.h> #define EPWAIT_TIMEO (1 * 1000) #ifndef POLLRDHUP #define POLLRDHUP 0x2000 #endif #define EPOLL_MAX_CHAIN 100L #define EPOLL_TF_LOOP (1 << 0) struct epoll_test_cfg { long size; long flags; }; static int xepoll_create(int n) { int epfd; if ((epfd = epoll_create(n)) == -1) { perror("epoll_create"); exit(2); } return epfd; } static void xepoll_ctl(int epfd, int cmd, int fd, struct epoll_event *evt) { if (epoll_ctl(epfd, cmd, fd, evt) < 0) { perror("epoll_ctl"); exit(3); } } static void xpipe(int *fds) { if (pipe(fds)) { perror("pipe"); exit(4); } } static pid_t xfork(void) { pid_t pid; if ((pid = fork()) == (pid_t) -1) { perror("pipe"); exit(5); } return pid; } static int run_forked_proc(int (*proc)(void *), void *data) { int status; pid_t pid; if ((pid = xfork()) == 0) exit((*proc)(data)); if (waitpid(pid, &status, 0) != pid) { perror("waitpid"); return -1; } return WIFEXITED(status) ? WEXITSTATUS(status): -2; } static int check_events(int fd, int timeo) { struct pollfd pfd; fprintf(stdout, "Checking events for fd %d\n", fd); memset(&pfd, 0, sizeof(pfd)); pfd.fd = fd; pfd.events = POLLIN | POLLOUT; if (poll(&pfd, 1, timeo) < 0) { perror("poll()"); return 0; } if (pfd.revents & POLLIN) fprintf(stdout, "\tPOLLIN\n"); if (pfd.revents & POLLOUT) fprintf(stdout, "\tPOLLOUT\n"); if (pfd.revents & POLLERR) fprintf(stdout, "\tPOLLERR\n"); if (pfd.revents & POLLHUP) fprintf(stdout, "\tPOLLHUP\n"); if (pfd.revents & POLLRDHUP) fprintf(stdout, "\tPOLLRDHUP\n"); return pfd.revents; } static int epoll_test_tty(void *data) { int epfd, ifd = fileno(stdin), res; struct epoll_event evt; if (check_events(ifd, 0) != POLLOUT) { fprintf(stderr, "Something is cooking on STDIN (%d)\n", ifd); return 1; } epfd = xepoll_create(1); fprintf(stdout, "Created epoll fd (%d)\n", epfd); memset(&evt, 0, sizeof(evt)); evt.events = EPOLLIN; xepoll_ctl(epfd, EPOLL_CTL_ADD, ifd, &evt); if (check_events(epfd, 0) & POLLIN) { res = epoll_wait(epfd, &evt, 1, 0); if (res == 0) { fprintf(stderr, "Epoll fd (%d) is ready when it shouldn't!\n", epfd); return 2; } } return 0; } static int epoll_wakeup_chain(void *data) { struct epoll_test_cfg *tcfg = data; int i, res, epfd, bfd, nfd, pfds[2]; pid_t pid; struct epoll_event evt; memset(&evt, 0, sizeof(evt)); evt.events = EPOLLIN; epfd = bfd = xepoll_create(1); for (i = 0; i < tcfg->size; i++) { nfd = xepoll_create(1); xepoll_ctl(bfd, EPOLL_CTL_ADD, nfd, &evt); bfd = nfd; } xpipe(pfds); if (tcfg->flags & EPOLL_TF_LOOP) { xepoll_ctl(bfd, EPOLL_CTL_ADD, epfd, &evt); /* * If we're testing for loop, we want that the wakeup * triggered by the write to the pipe done in the child * process, triggers a fake event. So we add the pipe * read size with EPOLLOUT events. This will trigger * an addition to the ready-list, but no real events * will be there. The the epoll kernel code will proceed * in calling f_op->poll() of the epfd, triggering the * loop we want to test. */ evt.events = EPOLLOUT; } xepoll_ctl(bfd, EPOLL_CTL_ADD, pfds[0], &evt); /* * The pipe write must come after the poll(2) call inside * check_events(). This tests the nested wakeup code in * fs/eventpoll.c:ep_poll_safewake() * By having the check_events() (hence poll(2)) happens first, * we have poll wait queue filled up, and the write(2) in the * child will trigger the wakeup chain. */ if ((pid = xfork()) == 0) { sleep(1); write(pfds[1], "w", 1); exit(0); } res = check_events(epfd, 2000) & POLLIN; if (waitpid(pid, NULL, 0) != pid) { perror("waitpid"); return -1; } return res; } static int epoll_poll_chain(void *data) { struct epoll_test_cfg *tcfg = data; int i, res, epfd, bfd, nfd, pfds[2]; pid_t pid; struct epoll_event evt; memset(&evt, 0, sizeof(evt)); evt.events = EPOLLIN; epfd = bfd = xepoll_create(1); for (i = 0; i < tcfg->size; i++) { nfd = xepoll_create(1); xepoll_ctl(bfd, EPOLL_CTL_ADD, nfd, &evt); bfd = nfd; } xpipe(pfds); if (tcfg->flags & EPOLL_TF_LOOP) { xepoll_ctl(bfd, EPOLL_CTL_ADD, epfd, &evt); /* * If we're testing for loop, we want that the wakeup * triggered by the write to the pipe done in the child * process, triggers a fake event. So we add the pipe * read size with EPOLLOUT events. This will trigger * an addition to the ready-list, but no real events * will be there. The the epoll kernel code will proceed * in calling f_op->poll() of the epfd, triggering the * loop we want to test. */ evt.events = EPOLLOUT; } xepoll_ctl(bfd, EPOLL_CTL_ADD, pfds[0], &evt); /* * The pipe write mush come before the poll(2) call inside * check_events(). This tests the nested f_op->poll calls code in * fs/eventpoll.c:ep_eventpoll_poll() * By having the pipe write(2) happen first, we make the kernel * epoll code to load the ready lists, and the following poll(2) * done inside check_events() will test nested poll code in * ep_eventpoll_poll(). */ if ((pid = xfork()) == 0) { write(pfds[1], "w", 1); exit(0); } sleep(1); res = check_events(epfd, 1000) & POLLIN; if (waitpid(pid, NULL, 0) != pid) { perror("waitpid"); return -1; } return res; } int main(int ac, char **av) { int error; struct epoll_test_cfg tcfg; fprintf(stdout, "\n********** Testing TTY events\n"); error = run_forked_proc(epoll_test_tty, NULL); fprintf(stdout, error == 0 ? "********** OK\n": "********** FAIL (%d)\n", error); tcfg.size = 3; tcfg.flags = 0; fprintf(stdout, "\n********** Testing short wakeup chain\n"); error = run_forked_proc(epoll_wakeup_chain, &tcfg); fprintf(stdout, error == POLLIN ? "********** OK\n": "********** FAIL (%d)\n", error); tcfg.size = EPOLL_MAX_CHAIN; tcfg.flags = 0; fprintf(stdout, "\n********** Testing long wakeup chain (HOLD ON)\n"); error = run_forked_proc(epoll_wakeup_chain, &tcfg); fprintf(stdout, error == 0 ? "********** OK\n": "********** FAIL (%d)\n", error); tcfg.size = 3; tcfg.flags = 0; fprintf(stdout, "\n********** Testing short poll chain\n"); error = run_forked_proc(epoll_poll_chain, &tcfg); fprintf(stdout, error == POLLIN ? "********** OK\n": "********** FAIL (%d)\n", error); tcfg.size = EPOLL_MAX_CHAIN; tcfg.flags = 0; fprintf(stdout, "\n********** Testing long poll chain (HOLD ON)\n"); error = run_forked_proc(epoll_poll_chain, &tcfg); fprintf(stdout, error == 0 ? "********** OK\n": "********** FAIL (%d)\n", error); tcfg.size = 3; tcfg.flags = EPOLL_TF_LOOP; fprintf(stdout, "\n********** Testing loopy wakeup chain (HOLD ON)\n"); error = run_forked_proc(epoll_wakeup_chain, &tcfg); fprintf(stdout, error == 0 ? "********** OK\n": "********** FAIL (%d)\n", error); tcfg.size = 3; tcfg.flags = EPOLL_TF_LOOP; fprintf(stdout, "\n********** Testing loopy poll chain (HOLD ON)\n"); error = run_forked_proc(epoll_poll_chain, &tcfg); fprintf(stdout, error == 0 ? "********** OK\n": "********** FAIL (%d)\n", error); return 0; } Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Cc: Pavel Pisa <pisa@cmp.felk.cvut.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-16Rename struct file->f_ep_lockJonathan Corbet
This lock moves out of the CONFIG_EPOLL ifdef and becomes f_lock. For now, epoll remains the only user, but a future patch will use it to protect f_flags as well. Cc: Davide Libenzi <davidel@xmailserver.org> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2009-01-29epoll: drop max_user_instances and rely only on max_user_watchesDavide Libenzi
Linus suggested to put limits where the money is, and max_user_watches already does that w/out the need of max_user_instances. That has the advantage to mitigate the potential DoS while allowing pretty generous default behavior. Allowing top 4% of low memory (per user) to be allocated in epoll watches, we have: LOMEM MAX_WATCHES (per user) 512MB ~178000 1GB ~356000 2GB ~712000 A box with 512MB of lomem, will meet some challenge in hitting 180K watches, socket buffers math teaches us. No more max_user_instances limits then. Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Cc: Willy Tarreau <w@1wt.eu> Cc: Michael Kerrisk <mtk.manpages@googlemail.com> Cc: Bron Gondwana <brong@fastmail.fm> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-14[CVE-2009-0029] System call wrappers part 23Heiko Carstens
2008-12-01epoll: introduce resource usage limitsDavide Libenzi
It has been thought that the per-user file descriptors limit would also limit the resources that a normal user can request via the epoll interface. Vegard Nossum reported a very simple program (a modified version attached) that can make a normal user to request a pretty large amount of kernel memory, well within the its maximum number of fds. To solve such problem, default limits are now imposed, and /proc based configuration has been introduced. A new directory has been created, named /proc/sys/fs/epoll/ and inside there, there are two configuration points: max_user_instances = Maximum number of devices - per user max_user_watches = Maximum number of "watched" fds - per user The current default for "max_user_watches" limits the memory used by epoll to store "watches", to 1/32 of the amount of the low RAM. As example, a 256MB 32bit machine, will have "max_user_watches" set to roughly 90000. That should be enough to not break existing heavy epoll users. The default value for "max_user_instances" is set to 128, that should be enough too. This also changes the userspace, because a new error code can now come out from EPOLL_CTL_ADD (-ENOSPC). The EMFILE from epoll_create() was already listed, so that should be ok. [akpm@linux-foundation.org: use get_current_user()] Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Cc: <stable@kernel.org> Cc: Cyrill Gorcunov <gorcunov@gmail.com> Reported-by: Vegard Nossum <vegardno@ifi.uio.no> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-26epoll: avoid double-inserts in case of EFAULTDavide Libenzi
In commit f337b9c58332bdecde965b436e47ea4c94d30da0 ("epoll: drop unnecessary test") Thomas found that there is an unnecessary (always true) test in ep_send_events(). The callback never inserts into ->rdllink while the send loop is performed, and also does the ~EP_PRIVATE_BITS test. Given we're holding the mutex during this time, the conditions tested inside the loop are always true. HOWEVER. The test "!ep_is_linked(&epi->rdllink)" wasn't there because we insert into ->rdllink, but because the send-events loop might terminate before the whole list is scanned (-EFAULT). In such cases, when the loop terminates early, and when a (leftover) file received an event while we're performing the lockless loop, we need such test to avoid to double insert the epoll items. The list_splice() done a few steps below, will correctly re-insert the ones that were left on "txlist". This should fix the kenrel.org bugzilla entry 11831. Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16epoll: drop unnecessary testDavide Libenzi
Thomas found that there is an unnecessary (always true) test in ep_send_events(). The callback never inserts into ->rdllink while the send loop is performed, and also does the ~EP_PRIVATE_BITS test. Given we're holding the mutex during this time, the conditions tested inside the loop are always true. This patch drops the test done inside the re-insertion loop. Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-12fs/eventpoll.c: fix sys_epoll_create1() commentAndrew Morton
The `size' argument was removed. Reported-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ulrich Drepper <drepper@redhat.com> Cc: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24flag parameters add-on: remove epoll_create size paramUlrich Drepper
Remove the size parameter from the new epoll_create syscall and renames the syscall itself. The updated test program follows. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ #include <fcntl.h> #include <stdio.h> #include <time.h> #include <unistd.h> #include <sys/syscall.h> #ifndef __NR_epoll_create2 # ifdef __x86_64__ # define __NR_epoll_create2 291 # elif defined __i386__ # define __NR_epoll_create2 329 # else # error "need __NR_epoll_create2" # endif #endif #define EPOLL_CLOEXEC O_CLOEXEC int main (void) { int fd = syscall (__NR_epoll_create2, 0); if (fd == -1) { puts ("epoll_create2(0) failed"); return 1; } int coe = fcntl (fd, F_GETFD); if (coe == -1) { puts ("fcntl failed"); return 1; } if (coe & FD_CLOEXEC) { puts ("epoll_create2(0) set close-on-exec flag"); return 1; } close (fd); fd = syscall (__NR_epoll_create2, EPOLL_CLOEXEC); if (fd == -1) { puts ("epoll_create2(EPOLL_CLOEXEC) failed"); return 1; } coe = fcntl (fd, F_GETFD); if (coe == -1) { puts ("fcntl failed"); return 1; } if ((coe & FD_CLOEXEC) == 0) { puts ("epoll_create2(EPOLL_CLOEXEC) set close-on-exec flag"); return 1; } close (fd); puts ("OK"); return 0; } ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Signed-off-by: Ulrich Drepper <drepper@redhat.com> Acked-by: Davide Libenzi <davidel@xmailserver.org> Cc: Michael Kerrisk <mtk.manpages@googlemail.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24flag parameters: check magic constantsUlrich Drepper
This patch adds test that ensure the boundary conditions for the various constants introduced in the previous patches is met. No code is generated. [akpm@linux-foundation.org: fix alpha] Signed-off-by: Ulrich Drepper <drepper@redhat.com> Acked-by: Davide Libenzi <davidel@xmailserver.org> Cc: Michael Kerrisk <mtk.manpages@googlemail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24flag parameters: epoll_createUlrich Drepper
This patch adds the new epoll_create2 syscall. It extends the old epoll_create syscall by one parameter which is meant to hold a flag value. In this patch the only flag support is EPOLL_CLOEXEC which causes the close-on-exec flag for the returned file descriptor to be set. A new name EPOLL_CLOEXEC is introduced which in this implementation must have the same value as O_CLOEXEC. The following test must be adjusted for architectures other than x86 and x86-64 and in case the syscall numbers changed. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ #include <fcntl.h> #include <stdio.h> #include <time.h> #include <unistd.h> #include <sys/syscall.h> #ifndef __NR_epoll_create2 # ifdef __x86_64__ # define __NR_epoll_create2 291 # elif defined __i386__ # define __NR_epoll_create2 329 # else # error "need __NR_epoll_create2" # endif #endif #define EPOLL_CLOEXEC O_CLOEXEC int main (void) { int fd = syscall (__NR_epoll_create2, 1, 0); if (fd == -1) { puts ("epoll_create2(0) failed"); return 1; } int coe = fcntl (fd, F_GETFD); if (coe == -1) { puts ("fcntl failed"); return 1; } if (coe & FD_CLOEXEC) { puts ("epoll_create2(0) set close-on-exec flag"); return 1; } close (fd); fd = syscall (__NR_epoll_create2, 1, EPOLL_CLOEXEC); if (fd == -1) { puts ("epoll_create2(EPOLL_CLOEXEC) failed"); return 1; } coe = fcntl (fd, F_GETFD); if (coe == -1) { puts ("fcntl failed"); return 1; } if ((coe & FD_CLOEXEC) == 0) { puts ("epoll_create2(EPOLL_CLOEXEC) set close-on-exec flag"); return 1; } close (fd); puts ("OK"); return 0; } ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Signed-off-by: Ulrich Drepper <drepper@redhat.com> Acked-by: Davide Libenzi <davidel@xmailserver.org> Cc: Michael Kerrisk <mtk.manpages@googlemail.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24flag parameters: anon_inode_getfd extensionUlrich Drepper
This patch just extends the anon_inode_getfd interface to take an additional parameter with a flag value. The flag value is passed on to get_unused_fd_flags in anticipation for a use with the O_CLOEXEC flag. No actual semantic changes here, the changed callers all pass 0 for now. [akpm@linux-foundation.org: KVM fix] Signed-off-by: Ulrich Drepper <drepper@redhat.com> Acked-by: Davide Libenzi <davidel@xmailserver.org> Cc: Michael Kerrisk <mtk.manpages@googlemail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-01[PATCH] sanitize anon_inode_getfd()Al Viro
a) none of the callers even looks at inode or file returned by anon_inode_getfd() b) any caller that would try to look at those would be racy, since by the time it returns we might have raced with close() from another thread and that file would be pining for fjords. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-04-30signals: use HAVE_SET_RESTORE_SIGMASKRoland McGrath
Change all the #ifdef TIF_RESTORE_SIGMASK conditionals in non-arch code to #ifdef HAVE_SET_RESTORE_SIGMASK. If arch code defines it first, the generic set_restore_sigmask() using TIF_RESTORE_SIGMASK is not defined. Signed-off-by: Roland McGrath <roland@redhat.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30signals: add set_restore_sigmaskRoland McGrath
This adds the set_restore_sigmask() inline in <linux/thread_info.h> and replaces every set_thread_flag(TIF_RESTORE_SIGMASK) with a call to it. No change, but abstracts the details of the flag protocol from all the calls. Signed-off-by: Roland McGrath <roland@redhat.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29epoll: avoid kmemcheck warningDavide Libenzi
Epoll calls rb_set_parent(n, n) to initialize the rb-tree node, but rb_set_parent() accesses node's pointer in its code. This creates a warning in kmemcheck (reported by Vegard Nossum) about an uninitialized memory access. The warning is harmless since the following rb-tree node insert is going to overwrite the node data. In any case I think it's better to not have that happening at all, and fix it by simplifying the code to get rid of a few lines that became superfluous after the previous epoll changes. Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Cc: Vegard Nossum <vegard.nossum@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05lockdep: annotate epollPeter Zijlstra
On Sat, 2008-01-05 at 13:35 -0800, Davide Libenzi wrote: > I remember I talked with Arjan about this time ago. Basically, since 1) > you can drop an epoll fd inside another epoll fd 2) callback-based wakeups > are used, you can see a wake_up() from inside another wake_up(), but they > will never refer to the same lock instance. > Think about: > > dfd = socket(...); > efd1 = epoll_create(); > efd2 = epoll_create(); > epoll_ctl(efd1, EPOLL_CTL_ADD, dfd, ...); > epoll_ctl(efd2, EPOLL_CTL_ADD, efd1, ...); > > When a packet arrives to the device underneath "dfd", the net code will > issue a wake_up() on its poll wake list. Epoll (efd1) has installed a > callback wakeup entry on that queue, and the wake_up() performed by the > "dfd" net code will end up in ep_poll_callback(). At this point epoll > (efd1) notices that it may have some event ready, so it needs to wake up > the waiters on its poll wait list (efd2). So it calls ep_poll_safewake() > that ends up in another wake_up(), after having checked about the > recursion constraints. That are, no more than EP_MAX_POLLWAKE_NESTS, to > avoid stack blasting. Never hit the same queue, to avoid loops like: > > epoll_ctl(efd2, EPOLL_CTL_ADD, efd1, ...); > epoll_ctl(efd3, EPOLL_CTL_ADD, efd2, ...); > epoll_ctl(efd4, EPOLL_CTL_ADD, efd3, ...); > epoll_ctl(efd1, EPOLL_CTL_ADD, efd4, ...); > > The code "if (tncur->wq == wq || ..." prevents re-entering the same > queue/lock. Since the epoll code is very careful to not nest same instance locks allow the recursion. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Tested-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Acked-by: Davide Libenzi <davidel@xmailserver.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-06Use wake_up_locked() in eventpollMatthew Wilcox
Replace the uses of __wake_up_locked with wake_up_locked Signed-off-by: Matthew Wilcox <matthew@wil.cx>
2007-10-19fs/eventpoll.c: use list_for_each_entry() instead of list_for_each()Matthias Kaehlcke
fs/eventpoll.c: use list_for_each_entry() instead of list_for_each() in ep_poll_safewake() Signed-off-by: Matthias Kaehlcke <matthias.kaehlcke@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18sparse pointer use of zero as nullStephen Hemminger
Get rid of sparse related warnings from places that use integer as NULL pointer. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Cc: Andi Kleen <ak@suse.de> Cc: Jeff Garzik <jeff@garzik.org> Cc: Matt Mackall <mpm@selenic.com> Cc: Ian Kent <raven@themaw.net> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Davide Libenzi <davidel@xmailserver.org> Cc: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-15epoll: move kfree inside ep_freeDavide Libenzi
Move the kfree() call inside the ep_free() function. Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-15epoll: fix some commentsDavide Libenzi
Fixes some epoll code comments. Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-15epoll locks changes and cleanupsDavide Libenzi
Changes the rwlock to a spinlock, and drops the use-count variable. Operations are always bound by the mutex now, so the use-count is no more needed. For the same reason, the rwlock can become a simple spinlock. Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-15fix epoll single pass code and add wait-exclusive flagDavide Libenzi
Fixes the epoll single pass code. During the unlocked event delivery (to userspace) code, the poll callback can re-issue new events, and we must receive them correctly. Since we loop in a lockless fashion, we want to be O(nready), and we don't want to flash on/off the spinlock for every event, we have the poll callback to use a secondary list to queue events while we're inside the event delivery loop. The rw_semaphore has been turned into a mutex. This patch also adds the wait-exclusive flag, as suggested by Davi Arnaut. Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-11epoll cleanups: epoll remove static pre-declarations and akpm-ize the codeDavide Libenzi
Re-arrange epoll code to avoid static functions pre-declarations, and apply akpm-filter on it. Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-11epoll cleanups: epoll no moduleDavide Libenzi
Epoll is either compiled it, or not (if EMBEDDED). Remove the module code and use fs_initcall(). Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-11epoll: use anonymous inodesDavide Libenzi
Cut out lots of code from epoll, by reusing the anonymous inode source patch (fs/anon_inodes.c). Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Introduce a handy list_first_entry macroPavel Emelianov
There are many places in the kernel where the construction like foo = list_entry(head->next, struct foo_struct, list); are used. The code might look more descriptive and neat if using the macro list_first_entry(head, type, member) \ list_entry((head)->next, type, member) Here is the macro itself and the examples of its usage in the generic code. If it will turn out to be useful, I can prepare the set of patches to inject in into arch-specific code, drivers, networking, etc. Signed-off-by: Pavel Emelianov <xemul@openvz.org> Signed-off-by: Kirill Korotaev <dev@openvz.org> Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Zach Brown <zach.brown@oracle.com> Cc: Davide Libenzi <davidel@xmailserver.org> Cc: John McCutchan <ttb@tentacle.dhs.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: john stultz <johnstul@us.ibm.com> Cc: Ram Pai <linuxram@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08epoll: optimizations and cleanupsDavide Libenzi
Epoll is doing multiple passes over the ready set at the moment, because of the constraints over the f_op->poll() call. Looking at the code again, I noticed that we already hold the epoll semaphore in read, and this (together with other locking conditions that hold while doing an epoll_wait()) can lead to a smarter way [1] to "ship" events to userspace (in a single pass). This is a stress application that can be used to test the new code. It spwans multiple thread and call epoll_wait() and epoll_ctl() from many threads. Stress tested on my dual Opteron 254 w/out any problems. http://www.xmailserver.org/totalmess.c This is not a benchmark, just something that tries to stress and exploit possible problems with the new code. Also, I made a stupid micro-benchmark: http://www.xmailserver.org/epwbench.c [1] Considering that epoll must be thread-safe, there are five ways we can be hit during an epoll_wait() transfer loop (ep_send_events()): 1) The epoll fd going away and calling ep_free This just can't happen, since we did an fget() in sys_epoll_wait 2) An epoll_ctl(EPOLL_CTL_DEL) This can't happen because epoll_ctl() gets ep->sem in write, and we're holding it in read during ep_send_events() 3) An fd stored inside the epoll fd going away This can't happen because in eventpoll_release_file() we get ep->sem in write, and we're holding it in read during ep_send_events() 4) Another epoll_wait() happening on another thread They both can be inside ep_send_events() at the same time, we get (splice) the ready-list under the spinlock, so each one will get its own ready list. Note that an fd cannot be at the same time inside more than one ready list, because ep_poll_callback() will not re-queue it if it sees it already linked: if (ep_is_linked(&epi->rdllink)) goto is_linked; Another case that can happen, is two concurrent epoll_wait(), coming in with a userspace event buffer of size, say, ten. Suppose there are 50 event ready in the list. The first epoll_wait() will "steal" the whole list, while the second, seeing no events, will go to sleep. But at the end of ep_send_events() in the first epoll_wait(), we will re-inject surplus ready fds, and we will trigger the proper wake_up to the second epoll_wait(). 5) ep_poll_callback() hitting us asyncronously This is the tricky part. As I said above, the ep_is_linked() test done inside ep_poll_callback(), will guarantee us that until the item will result linked to a list, ep_poll_callback() will not try to re-queue it again (read, write data on any of its members). When we do a list_del() in ep_send_events(), the item will still satisfy the ep_is_linked() test (whatever data is written in prev/next, it'll never be its own pointer), so ep_poll_callback() will still leave us alone. It's only after the eventual smp_mb()+INIT_LIST_HEAD(&epi->rdllink) that it'll become visible to ep_poll_callback(), but at the point we're already past it. [akpm@osdl.org: 80 cols] Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-08[PATCH] VFS: change struct file to use struct pathJosef "Jeff" Sipek
This patch changes struct file to use struct path instead of having independent pointers to struct dentry and struct vfsmount, and converts all users of f_{dentry,vfsmnt} in fs/ to use f_path.{dentry,mnt}. Additionally, it adds two #define's to make the transition easier for users of the f_dentry and f_vfsmnt. Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
