commit 8ded2bbc1845e19c771eb55209aab166ef011243 upstream.
Recently, glibc made a change to suppress sign-conversion warnings in
FD_SET (glibc commit ceb9e56b3d1). This uncovered an issue with the
kernel's definition of __NFDBITS if applications #include
<linux/types.h> after including <sys/select.h>. A build failure would
be seen when passing the -Werror=sign-compare and -D_FORTIFY_SOURCE=2
flags to gcc.
It was suggested that the kernel should either match the glibc
definition of __NFDBITS or remove that entirely. The current in-kernel
uses of __NFDBITS can be replaced with BITS_PER_LONG, and there are no
uses of the related __FDELT and __FDMASK defines. Given that, we'll
continue the cleanup that was started with commit 8b3d1cda4f5f
("posix_types: Remove fd_set macros") and drop the remaining unused
macros.
Additionally, linux/time.h has similar macros defined that expand to
nothing so we'll remove those at the same time.
Reported-by: Jeff Law <law@redhat.com>
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
Signed-off-by: Josh Boyer <jwboyer@redhat.com>
[ .. and fix up whitespace as per akpm ]
commit 4fe7efdbdfb1c7e7a7f31decfd831c0f31d37091 upstream.
do_exit() and exec_mmap() call sync_mm_rss() before mm_release() does
put_user(clear_child_tid) which can update task->rss_stat and thus make
mm->rss_stat inconsistent. This triggers the "BUG:" printk in check_mm().
Let's fix this bug in the safest way, and optimize/cleanup this later.
Reported-by: Markus Trippelsdorf <markus@trippelsdorf.de>
Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org>
Pull perf fixes from Ingo Molnar.
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
perf/x86/p4: Add format attributes
tracing, sched, vfs: Fix 'old_pid' usage in trace_sched_process_exec()
1. TRACE_EVENT(sched_process_exec) forgets to actually use the
old pid argument, it sets ->old_pid = p->pid.
2. search_binary_handler() uses the wrong pid number. tracepoint
needs the global pid_t from the root namespace, while old_pid
is the virtual pid number as it seen by the tracer/parent.
With this patch we have two pid_t's in search_binary_handler(),
not really nice. Perhaps we should switch to "struct pid*", but
in this case it would be better to cleanup the current code
first and move the "depth == 0" code outside.
Cc: David Smith <dsmith@redhat.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Link: http://lkml.kernel.org/r/20120330162636.GA4857@redhat.com
Pull x32 support for x86-64 from Ingo Molnar:
"This tree introduces the X32 binary format and execution mode for x86:
32-bit data space binaries using 64-bit instructions and 64-bit kernel
syscalls.
This allows applications whose working set fits into a 32 bits address
space to make use of 64-bit instructions while using a 32-bit address
space with shorter pointers, more compressed data structures, etc."
Fix up trivial context conflicts in arch/x86/{Kconfig,vdso/vma.c}
* 'x86-x32-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (71 commits)
x32: Fix alignment fail in struct compat_siginfo
x32: Fix stupid ia32/x32 inversion in the siginfo format
x32: Add ptrace for x32
x32: Switch to a 64-bit clock_t
x32: Provide separate is_ia32_task() and is_x32_task() predicates
x86, mtrr: Use explicit sizing and padding for the 64-bit ioctls
x86/x32: Fix the binutils auto-detect
x32: Warn and disable rather than error if binutils too old
x32: Only clear TIF_X32 flag once
x32: Make sure TS_COMPAT is cleared for x32 tasks
fs: Remove missed ->fds_bits from cessation use of fd_set structs internally
fs: Fix close_on_exec pointer in alloc_fdtable
x32: Drop non-__vdso weak symbols from the x32 VDSO
x32: Fix coding style violations in the x32 VDSO code
x32: Add x32 VDSO support
x32: Allow x32 to be configured
x32: If configured, add x32 system calls to system call tables
x32: Handle process creation
x32: Signal-related system calls
x86: Add #ifdef CONFIG_COMPAT to <asm/sys_ia32.h>
asm/system.h is a cause of circular dependency problems because it contains
commonly used primitive stuff like barrier definitions and uncommonly used
stuff like switch_to() that might require MMU definitions.
asm/system.h has been disintegrated by this point on all arches into the
following common segments:
(1) asm/barrier.h
Moved memory barrier definitions here.
(2) asm/cmpxchg.h
Moved xchg() and cmpxchg() here. #included in asm/atomic.h.
(3) asm/bug.h
Moved die() and similar here.
(4) asm/exec.h
Moved arch_align_stack() here.
(5) asm/elf.h
Moved AT_VECTOR_SIZE_ARCH here.
(6) asm/switch_to.h
Moved switch_to() here.
Merge first batch of patches from Andrew Morton:
"A few misc things and all the MM queue"
* emailed from Andrew Morton <akpm@linux-foundation.org>: (92 commits)
memcg: avoid THP split in task migration
thp: add HPAGE_PMD_* definitions for !CONFIG_TRANSPARENT_HUGEPAGE
memcg: clean up existing move charge code
mm/memcontrol.c: remove unnecessary 'break' in mem_cgroup_read()
mm/memcontrol.c: remove redundant BUG_ON() in mem_cgroup_usage_unregister_event()
mm/memcontrol.c: s/stealed/stolen/
memcg: fix performance of mem_cgroup_begin_update_page_stat()
memcg: remove PCG_FILE_MAPPED
memcg: use new logic for page stat accounting
memcg: remove PCG_MOVE_LOCK flag from page_cgroup
memcg: simplify move_account() check
memcg: remove EXPORT_SYMBOL(mem_cgroup_update_page_stat)
memcg: kill dead prev_priority stubs
memcg: remove PCG_CACHE page_cgroup flag
memcg: let css_get_next() rely upon rcu_read_lock()
cgroup: revert ss_id_lock to spinlock
idr: make idr_get_next() good for rcu_read_lock()
memcg: remove unnecessary thp check in page stat accounting
memcg: remove redundant returns
memcg: enum lru_list lru
sync_mm_rss() can only be used for current to avoid race conditions in
iterating and clearing its per-task counters. Remove the task argument
for it and its helper function, __sync_task_rss_stat(), to avoid thinking
it can be used safely for anything other than current.
Signed-off-by: David Rientjes <rientjes@google.com>
Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Pull vfs pile 1 from Al Viro:
"This is _not_ all; in particular, Miklos' and Jan's stuff is not there
yet."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (64 commits)
ext4: initialization of ext4_li_mtx needs to be done earlier
debugfs-related mode_t whack-a-mole
hfsplus: add an ioctl to bless files
hfsplus: change finder_info to u32
hfsplus: initialise userflags
qnx4: new helper - try_extent()
qnx4: get rid of qnx4_bread/qnx4_getblk
take removal of PF_FORKNOEXEC to flush_old_exec()
trim includes in inode.c
um: uml_dup_mmap() relies on ->mmap_sem being held, but activate_mm() doesn't hold it
um: embed ->stub_pages[] into mmu_context
gadgetfs: list_for_each_safe() misuse
ocfs2: fix leaks on failure exits in module_init
ecryptfs: make register_filesystem() the last potential failure exit
ntfs: forgets to unregister sysctls on register_filesystem() failure
logfs: missing cleanup on register_filesystem() failure
jfs: mising cleanup on register_filesystem() failure
make configfs_pin_fs() return root dentry on success
configfs: configfs_create_dir() has parent dentry in dentry->d_parent
configfs: sanitize configfs_create()
Pull kmap_atomic cleanup from Cong Wang.
It's been in -next for a long time, and it gets rid of the (no longer
used) second argument to k[un]map_atomic().
Fix up a few trivial conflicts in various drivers, and do an "evil
merge" to catch some new uses that have come in since Cong's tree.
* 'kmap_atomic' of git://github.com/congwang/linux: (59 commits)
feature-removal-schedule.txt: schedule the deprecated form of kmap_atomic() for removal
highmem: kill all __kmap_atomic() [swarren@nvidia.com: highmem: Fix ARM build break due to __kmap_atomic rename]
drbd: remove the second argument of k[un]map_atomic()
zcache: remove the second argument of k[un]map_atomic()
gma500: remove the second argument of k[un]map_atomic()
dm: remove the second argument of k[un]map_atomic()
tomoyo: remove the second argument of k[un]map_atomic()
sunrpc: remove the second argument of k[un]map_atomic()
rds: remove the second argument of k[un]map_atomic()
net: remove the second argument of k[un]map_atomic()
mm: remove the second argument of k[un]map_atomic()
lib: remove the second argument of k[un]map_atomic()
power: remove the second argument of k[un]map_atomic()
kdb: remove the second argument of k[un]map_atomic()
udf: remove the second argument of k[un]map_atomic()
ubifs: remove the second argument of k[un]map_atomic()
squashfs: remove the second argument of k[un]map_atomic()
reiserfs: remove the second argument of k[un]map_atomic()
ocfs2: remove the second argument of k[un]map_atomic()
ntfs: remove the second argument of k[un]map_atomic()
Just don't pass NULL to it - nobody does, anyway.
Minor cleanup. de_thread()->setmax_mm_hiwater_rss() looks a bit
strange, move it into exec_mmap() which plays with old_mm.
exit_notify() checks "tsk->self_exec_id != tsk->parent_exec_id"
to handle the "we have changed execution domain" case.
We can change do_thread() to always set ->exit_signal = SIGCHLD
and remove this check to simplify the code.
We could change setup_new_exec() instead, this looks more logical
because it increments ->self_exec_id. But note that de_thread()
already resets ->exit_signal if it changes the leader, let's keep
both changes close to each other.
Note that we change ->exit_signal lockless, this changes the rules.
Thereafter ->exit_signal is not stable under tasklist but this is
fine, the only possible change is OLDSIG -> SIGCHLD. This can race
with eligible_child() but the race is harmless. We can race with
reparent_leader() which changes our ->exit_signal in parallel, but
it does the same change to SIGCHLD.
The noticeable user-visible change is that the execing task is not
"visible" to do_wait()->eligible_child(__WCLONE) right after exec.
To me this looks more logical, and this is consistent with mt case.
Acked-by: Benjamin LaHaise <bcrl@kvack.org>
Signed-off-by: Cong Wang <amwang@redhat.com>
Merge reason: We are going to queue up a dependent patch.
Now that CLONE_VFORK is killable, coredump_wait() no longer needs
complete_vfork_done(). zap_threads() should find and kill all tasks with
the same ->mm, this includes our parent if ->vfork_done is set.
mm_release() becomes the only caller, unexport complete_vfork_done().
Acked-by: Tejun Heo <tj@kernel.org>
No functional changes.
Move the clear-and-complete-vfork_done code into the new trivial helper,
tools/perf/builtin-record.c
tools/perf/builtin-top.c
tools/perf/perf.h
tools/perf/util/top.h
Merge reason: resolve these cherry-picking conflicts.
Added a minimal exec tracepoint. Exec is an important major event
in the life of a task, like fork(), clone() or exit(), all of
which we already trace.
[ We also do scheduling re-balancing during exec() - so it's useful
from a scheduler instrumentation POV as well. ]
If you want to watch a task start up, when it gets exec'ed is a good place
to start. With the addition of this tracepoint, exec's can be monitored
and better picture of general system activity can be obtained. This
tracepoint will also enable better process life tracking, allowing you to
answer questions like "what process keeps starting up binary X?".
This tracepoint can also be useful in ftrace filtering and trigger
conditions: i.e. starting or stopping filtering when exec is called.
Signed-off-by: David Smith <dsmith@redhat.com>
Link: http://lkml.kernel.org/r/4F314D19.7030504@redhat.com
Replace the fd_sets in struct fdtable with an array of unsigned longs and then
use the standard non-atomic bit operations rather than the FD_* macros.
This:
(1) Removes the abuses of struct fd_set:
(a) Since we don't want to allocate a full fd_set the vast majority of the
time, we actually, in effect, just allocate a just-big-enough array of
unsigned longs and cast it to an fd_set type - so why bother with the
fd_set at all?
(b) Some places outside of the core fdtable handling code (such as
SELinux) want to look inside the array of unsigned longs hidden inside
the fd_set struct for more efficient iteration over the entire set.
(2) Eliminates the use of FD_*() macros in the kernel completely.
(3) Permits the __FD_*() macros to be deleted entirely where not exposed to
userspace.
Link: http://lkml.kernel.org/r/20120216174954.23314.48147.stgit@warthog.procyon.org.uk
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
Wrap accesses to the fd_sets in struct fdtable (for recording open files and
close-on-exec flags) so that we can move away from using fd_sets since we
abuse the fd_set structs by not allocating the full-sized structure under
normal circumstances and by non-core code looking at the internals of the
fd_sets.
The first abuse means that use of FD_ZERO() on these fd_sets is not permitted,
since that cannot be told about their abnormal lengths.
This introduces six wrapper functions for setting, clearing and testing
close-on-exec flags and fd-is-open flags:
void __set_close_on_exec(int fd, struct fdtable *fdt);
void __clear_close_on_exec(int fd, struct fdtable *fdt);
bool close_on_exec(int fd, const struct fdtable *fdt);
void __set_open_fd(int fd, struct fdtable *fdt);
void __clear_open_fd(int fd, struct fdtable *fdt);
bool fd_is_open(int fd, const struct fdtable *fdt);
Note that I've prepended '__' to the names of the set/clear functions because
they require the caller to hold a lock to use them.
Note also that I haven't added wrappers for looking behind the scenes at the
the array. Possibly that should exist too.
Link: http://lkml.kernel.org/r/20120216174942.23314.1364.stgit@warthog.procyon.org.uk
Setting the task name is done within setup_new_exec() by accessing
bprm->filename. However this happens after flush_old_exec().
This may result in a use after free bug, flush_old_exec() may
"complete" vfork_done, which will wake up the parent which in turn
may free the passed in filename.
To fix this add a new tcomm field in struct linux_binprm which
contains the now early generated task name until it is used.
Fixes this bug on s390:
Unable to handle kernel pointer dereference at virtual kernel address 0000000039768000
Process kworker/u:3 (pid: 245, task: 000000003a3dc840, ksp: 0000000039453818)
Krnl PSW : 0704000180000000 0000000000282e94 (setup_new_exec+0xa0/0x374)
Call Trace:
([<0000000000282e2c>] setup_new_exec+0x38/0x374)
[<00000000002dd12e>] load_elf_binary+0x402/0x1bf4
[<0000000000280a42>] search_binary_handler+0x38e/0x5bc
[<0000000000282b6c>] do_execve_common+0x410/0x514
[<0000000000282cb6>] do_execve+0x46/0x58
[<00000000005bce58>] kernel_execve+0x28/0x70
[<000000000014ba2e>] ____call_usermodehelper+0x102/0x140
[<00000000005bc8da>] kernel_thread_starter+0x6/0xc
[<00000000005bc8d4>] kernel_thread_starter+0x0/0xc
Last Breaking-Event-Address:
[<00000000002830f0>] setup_new_exec+0x2fc/0x374
Kernel panic - not syncing: Fatal exception: panic_on_oops
Reported-by: Sebastian Ott <sebott@linux.vnet.ibm.com>
oom_score_adj is used for guarding processes from OOM-Killer. One of
problem is that it's inherited at fork(). When a daemon set oom_score_adj
and make children, it's hard to know where the value is set.
This patch adds some tracepoints useful for debugging. This patch adds
3 trace points.
- creating new task
- renaming a task (exec)
- set oom_score_adj
To debug, users need to enable some trace pointer. Maybe filtering is useful as
# EVENT=/sys/kernel/debug/tracing/events/task/
# echo "oom_score_adj != 0" > $EVENT/task_newtask/filter
# echo "oom_score_adj != 0" > $EVENT/task_rename/filter
# echo 1 > $EVENT/enable
# EVENT=/sys/kernel/debug/tracing/events/oom/
output will be like this.
# grep oom /sys/kernel/debug/tracing/trace
bash-7699 [007] d..3 5140.744510: oom_score_adj_update: pid=7699 comm=bash oom_score_adj=-1000
bash-7699 [007] ...1 5151.818022: task_newtask: pid=7729 comm=bash clone_flags=1200011 oom_score_adj=-1000
ls-7729 [003] ...2 5151.818504: task_rename: pid=7729 oldcomm=bash newcomm=ls oom_score_adj=-1000
bash-7699 [002] ...1 5175.701468: task_newtask: pid=7730 comm=bash clone_flags=1200011 oom_score_adj=-1000
grep-7730 [007] ...2 5175.701993: task_rename: pid=7730 oldcomm=bash newcomm=grep oom_score_adj=-1000
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Acked-by: David Rientjes <rientjes@google.com>
some stuff in there can actually become static; some belongs to pnode.h
as it's a private interface between namespace.c and pnode.c...
This removes mm->oom_disable_count entirely since it's unnecessary and
currently buggy. The counter was intended to be per-process but it's
currently decremented in the exit path for each thread that exits, causing
it to underflow.
The count was originally intended to prevent oom killing threads that
share memory with threads that cannot be killed since it doesn't lead to
future memory freeing. The counter could be fixed to represent all
threads sharing the same mm, but it's better to remove the count since:
- it is possible that the OOM_DISABLE thread sharing memory with the
victim is waiting on that thread to exit and will actually cause
future memory freeing, and
- there is no guarantee that a thread is disabled from oom killing just
because another thread sharing its mm is oom disabled.
Reported-by: Oleg Nesterov <oleg@redhat.com>
Reviewed-by: Oleg Nesterov <oleg@redhat.com>
Cc: Ying Han <yinghan@google.com>
The patch http://lkml.org/lkml/2003/7/13/226 introduced an RLIMIT_NPROC
check in set_user() to check for NPROC exceeding via setuid() and
similar functions.
Before the check there was a possibility to greatly exceed the allowed
number of processes by an unprivileged user if the program relied on
rlimit only. But the check created new security threat: many poorly
written programs simply don't check setuid() return code and believe it
cannot fail if executed with root privileges. So, the check is removed
in this patch because of too often privilege escalations related to
buggy programs.
The NPROC can still be enforced in the common code flow of daemons
spawning user processes. Most of daemons do fork()+setuid()+execve().
The check introduced in execve() (1) enforces the same limit as in
setuid() and (2) doesn't create similar security issues.
Neil Brown suggested to track what specific process has exceeded the
limit by setting PF_NPROC_EXCEEDED process flag. With the change only
this process would fail on execve(), and other processes' execve()
behaviour is not changed.
Solar Designer suggested to re-check whether NPROC limit is still
exceeded at the moment of execve(). If the process was sleeping for
days between set*uid() and execve(), and the NPROC counter step down
under the limit, the defered execve() failure because NPROC limit was
exceeded days ago would be unexpected. If the limit is not exceeded
anymore, we clear the flag on successful calls to execve() and fork().
The flag is also cleared on successful calls to set_user() as the limit
was exceeded for the previous user, not the current one.
Similar check was introduced in -ow patches (without the process flag).
v3 - clear PF_NPROC_EXCEEDED on successful calls to set_user().
Reviewed-by: James Morris <jmorris@namei.org>
Signed-off-by: Vasiliy Kulikov <segoon@openwall.com>
Acked-by: NeilBrown <neilb@suse.de>
acct_arg_size() takes ->page_table_lock around add_mm_counter() if
!SPLIT_RSS_COUNTING. This is not needed after commit 172703b08cd0 ("mm:
delete non-atomic mm counter implementation").
Reviewed-by: Matt Fleming <matt.fleming@linux.intel.com>
Cc: Dave Hansen <dave@linux.vnet.ibm.com>
If CONFIG_MODULES=n, it makes no sense to retry the list of binary formats
handler because the list will not be modified by request_module().
Cc: Richard Weinberger <richard@nod.at>
Currently, search_binary_handler() tries to load binary loader module
using request_module() if a loader for the requested program is not yet
loaded. But second attempt of request_module() does not affect the result
of search_binary_handler().
If request_module() triggered recursion, calling request_module() twice
causes 2 to the power of MAX_KMOD_CONCURRENT (= 50) repetitions. It is
not an infinite loop but is sufficient for users to consider as a hang up.
Therefore, this patch changes not to call request_module() twice, making 1
to the power of MAX_KMOD_CONCURRENT repetitions in case of recursion.
Reported-by: Richard Weinberger <richard@nod.at>
Tested-by: Richard Weinberger <richard@nod.at>
Commit a8bef8ff6ea1 ("mm: migration: avoid race between
shift_arg_pages() and rmap_walk() during migration by not migrating
temporary stacks") introduced a BUG_ON() to ensure that VM_STACK_FLAGS
and VM_STACK_INCOMPLETE_SETUP do not overlap. The check is a compile
time one, so BUILD_BUG_ON is more appropriate.
do_coredump() assumes that if format_corename() fails it should return
-ENOMEM. This is not true, for example cn_print_exe_file() can propagate
the error from d_path. Even if it was true, this is too fragile. Change
the code to check "ispipe < 0".
Reviewed-by: Neil Horman <nhorman@tuxdriver.com>
Change every occurence of / in comm and hostname to !. If the process
changes its name to contain /, the core is not dumped (if the directory
tree doesn't exist like that). The same with hostname being something
like myhost/3. Fix this behaviour by using the escape loop used in %E.
(We extract it to a separate function.)
Now both with comm == myprocess/1 and hostname == myhost/1, the core is
dumped like (kernel.core_pattern='core.%p.%e.%h):
core.2349.myprocess!1.myhost!1
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
If we don't know the file corresponding to the binary (i.e. exe_file is
unknown), use "task->comm (path unknown)" instead of simple "(unknown)"
as suggested by ak.
The fallback is the same as %e except it will append "(path unknown)".
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (107 commits)
vfs: use ERR_CAST for err-ptr tossing in lookup_instantiate_filp
isofs: Remove global fs lock
jffs2: fix IN_DELETE_SELF on overwriting rename() killing a directory
fix IN_DELETE_SELF on overwriting rename() on ramfs et.al.
mm/truncate.c: fix build for CONFIG_BLOCK not enabled
fs:update the NOTE of the file_operations structure
Remove dead code in dget_parent()
AFS: Fix silly characters in a comment
switch d_add_ci() to d_splice_alias() in "found negative" case as well
simplify gfs2_lookup()
jfs_lookup(): don't bother with . or ..
get rid of useless dget_parent() in btrfs rename() and link()
get rid of useless dget_parent() in fs/btrfs/ioctl.c
fs: push i_mutex and filemap_write_and_wait down into ->fsync() handlers
drivers: fix up various ->llseek() implementations
fs: handle SEEK_HOLE/SEEK_DATA properly in all fs's that define their own llseek
Ext4: handle SEEK_HOLE/SEEK_DATA generically
Btrfs: implement our own ->llseek
fs: add SEEK_HOLE and SEEK_DATA flags
reiserfs: make reiserfs default to barrier=flush
Fix up trivial conflicts in fs/xfs/linux-2.6/xfs_super.c due to the new
shrinker callout for the inode cache, that clashed with the xfs code to
start the periodic workers later.
* 'ptrace' of git://git.kernel.org/pub/scm/linux/kernel/git/oleg/misc: (39 commits)
ptrace: do_wait(traced_leader_killed_by_mt_exec) can block forever
ptrace: fix ptrace_signal() && STOP_DEQUEUED interaction
connector: add an event for monitoring process tracers
ptrace: dont send SIGSTOP on auto-attach if PT_SEIZED
ptrace: mv send-SIGSTOP from do_fork() to ptrace_init_task()
ptrace_init_task: initialize child->jobctl explicitly
has_stopped_jobs: s/task_is_stopped/SIGNAL_STOP_STOPPED/
ptrace: make former thread ID available via PTRACE_GETEVENTMSG after PTRACE_EVENT_EXEC stop
ptrace: wait_consider_task: s/same_thread_group/ptrace_reparented/
ptrace: kill real_parent_is_ptracer() in in favor of ptrace_reparented()
ptrace: ptrace_reparented() should check same_thread_group()
redefine thread_group_leader() as exit_signal >= 0
do not change dead_task->exit_signal
kill task_detached()
reparent_leader: check EXIT_DEAD instead of task_detached()
make do_notify_parent() __must_check, update the callers
__ptrace_detach: avoid task_detached(), check do_notify_parent()
kill tracehook_notify_death()
make do_notify_parent() return bool
ptrace: s/tracehook_tracer_task()/ptrace_parent()/
Test-case:
void *tfunc(void *arg)
execvp("true", NULL);
return NULL;
int main(void)
int pid;
if (fork()) {
pthread_t t;
kill(getpid(), SIGSTOP);
pthread_create(&t, NULL, tfunc, NULL);
for (;;)
pause();
pid = getppid();
assert(ptrace(PTRACE_ATTACH, pid, 0,0) == 0);
while (wait(NULL) > 0)
ptrace(PTRACE_CONT, pid, 0,0);
return 0;
It is racy, exit_notify() does __wake_up_parent() too. But in the
likely case it triggers the problem: de_thread() does release_task()
and the old leader goes away without the notification, the tracer
sleeps in do_wait() without children/tracees.
Change de_thread() to do __wake_up_parent(traced_leader->parent).
Since it is already EXIT_DEAD we can do this without ptrace_unlink(),
EXIT_DEAD threads do not exist from do_wait's pov.
new helper: would_dump(bprm, file). Checks if we are allowed to
read the file and if we are not - sets ENFORCE_NODUMP. Exported,
used in places that previously open-coded the same logics.
When multithreaded program execs under ptrace,
all traced threads report WIFEXITED status, except for
thread group leader and the thread which execs.
Unless tracer tracks thread group relationship between tracees,
which is a nontrivial task, it will not detect that
execed thread no longer exists.
This patch allows tracer to figure out which thread
performed this exec, by requesting PTRACE_GETEVENTMSG
in PTRACE_EVENT_EXEC stop.
Another, samller problem which is solved by this patch
is that tracer now can figure out which of the several
concurrent execs in multithreaded program succeeded.
Signed-off-by: Denys Vlasenko <vda.linux@googlemail.com>
Change de_thread() to set old_leader->exit_signal = -1. This is
good for the consistency, it is no longer the leader and all
sub-threads have exit_signal = -1 set by copy_process(CLONE_THREAD).
And this allows us to micro-optimize thread_group_leader(), it can
simply check exit_signal >= 0. This also makes sense because we
should move ->group_leader from task_struct to signal_struct.
Reviewed-by: Tejun Heo <tj@kernel.org>
At this point, tracehooks aren't useful to mainline kernel and mostly
just add an extra layer of obfuscation. Although they have comments,
without actual in-kernel users, it is difficult to tell what are their
assumptions and they're actually trying to achieve. To mainline
kernel, they just aren't worth keeping around.
This patch kills the following clone and exec related tracehooks.
tracehook_prepare_clone()
tracehook_finish_clone()
tracehook_report_clone()
tracehook_report_clone_complete()
tracehook_unsafe_exec()
The changes are mostly trivial - logic is moved to the caller and
comments are merged and adjusted appropriately.
The only exception is in check_unsafe_exec() where LSM_UNSAFE_PTRACE*
are OR'd to bprm->unsafe instead of setting it, which produces the
same result as the field is always zero on entry. It also tests
p->ptrace instead of (p->ptrace & PT_PTRACED) for consistency, which
also gives the same result.
This doesn't introduce any behavior change.
This patch kills the following trivial tracehooks.
* Ones testing whether task is ptraced. Replace with ->ptrace test.
tracehook_expect_breakpoints()
tracehook_consider_ignored_signal()
tracehook_consider_fatal_signal()
* ptrace_event() wrappers. Call directly.
tracehook_report_exec()
tracehook_report_exit()
tracehook_report_vfork_done()
* ptrace_release_task() wrapper. Call directly.
tracehook_finish_release_task()
* noop
tracehook_prepare_release_task()
tracehook_report_death()
____call_usermodehelper() now erases any credentials set by the
subprocess_inf::init() function. The problem is that commit
17f60a7da150 ("capabilites: allow the application of capability limits
to usermode helpers") creates and commits new credentials with
prepare_kernel_cred() after the call to the init() function. This wipes
all keyrings after umh_keys_init() is called.
The best way to deal with this is to put the init() call just prior to
the commit_creds() call, and pass the cred pointer to init(). That
means that umh_keys_init() and suchlike can modify the credentials
_before_ they are published and potentially in use by the rest of the
system.
This prevents request_key() from working as it is prevented from passing
the session keyring it set up with the authorisation token to
/sbin/request-key, and so the latter can't assume the authority to
instantiate the key. This causes the in-kernel DNS resolver to fail
with ENOKEY unconditionally.
Acked-by: Eric Paris <eparis@redhat.com>
Tested-by: Jeff Layton <jlayton@redhat.com>
VM_STACK_INCOMPLETE_SETUP"
This reverts commit 7f81c8890c15a10f5220bebae3b6dfae4961962a.
It turns out that it's not actually a build-time check on x86-64 UML,
which does some seriously crazy stuff with VM_STACK_FLAGS.
The VM_STACK_FLAGS define depends on the arch-supplied
VM_STACK_DEFAULT_FLAGS value, and on x86-64 UML we have
arch/um/sys-x86_64/shared/sysdep/vm-flags.h:
#define VM_STACK_DEFAULT_FLAGS \
(test_thread_flag(TIF_IA32) ? vm_stack_flags32 : vm_stack_flags)
#define VM_STACK_DEFAULT_FLAGS vm_stack_flags
(yes, seriously: two different #define's for that thing, with the first
one being inside an "#ifdef TIF_IA32")
It's possible that it is UML that should just be fixed in this area, but
for now let's just undo the (very small) optimization.
Reported-by: Randy Dunlap <randy.dunlap@oracle.com>
Acked-by: Andrew Morton <akpm@linux-foundation.org>
Commit a8bef8ff6ea1 ("mm: migration: avoid race between shift_arg_pages()
and rmap_walk() during migration by not migrating temporary stacks")
introduced a BUG_ON() to ensure that VM_STACK_FLAGS and
VM_STACK_INCOMPLETE_SETUP do not overlap. The check is a compile time
Unconditionally changing the address limit to USER_DS and not restoring
it to its old value in the error path is wrong because it prevents us
using kernel memory on repeated calls to this function. This, in fact,
breaks the fallback of hard coded paths to the init program from being
ever successful if the first candidate fails to load.
With this patch applied switching to USER_DS is delayed until the point
of no return is reached which makes it possible to have a multi-arch
rootfs with one arch specific init binary for each of the (hard coded)
probed paths.
Since the address limit is already set to USER_DS when start_thread()
will be invoked, this redundancy can be safely removed.
Signed-off-by: Mathias Krause <minipli@googlemail.com>
Cc: stable@kernel.org
JOBCTL_TRAPPING indicates that ptracer is waiting for tracee to
(re)transit into TRACED. task_clear_jobctl_pending() must be called
when either tracee enters TRACED or the transition is cancelled for
some reason. The former is achieved by explicitly calling
task_clear_jobctl_pending() in ptrace_stop() and the latter by calling
it at the end of do_signal_stop().
Calling task_clear_jobctl_trapping() at the end of do_signal_stop()
limits the scope TRAPPING can be used and is fragile in that seemingly
unrelated changes to tracee's control flow can lead to stuck TRAPPING.
We already have task_clear_jobctl_pending() calls on those cancelling
events to clear JOBCTL_STOP_PENDING. Cancellations can be handled by
making those call sites use JOBCTL_PENDING_MASK instead and updating
task_clear_jobctl_pending() such that task_clear_jobctl_trapping() is
called automatically if no stop/trap is pending.
This patch makes the above changes and removes the fallback
task_clear_jobctl_trapping() call from do_signal_stop().
This patch introduces JOBCTL_PENDING_MASK and replaces
task_clear_jobctl_stop_pending() with task_clear_jobctl_pending()
which takes an extra @mask argument.
JOBCTL_PENDING_MASK is currently equal to JOBCTL_STOP_PENDING but
future patches will add more bits. recalc_sigpending_tsk() is updated
to use JOBCTL_PENDING_MASK instead.
task_clear_jobctl_pending() takes @mask which in subset of
JOBCTL_PENDING_MASK and clears the relevant jobctl bits. If
JOBCTL_STOP_PENDING is set, other STOP bits are cleared together. All
task_clear_jobctl_stop_pending() users are updated to call
task_clear_jobctl_pending() with JOBCTL_STOP_PENDING which is
functionally identical to task_clear_jobctl_stop_pending().
This patch doesn't cause any functional change.
signal->group_stop currently hosts mostly group stop related flags;
however, it's gonna be used for wider purposes and the GROUP_STOP_
flag prefix becomes confusing. Rename signal->group_stop to
signal->jobctl and rename all GROUP_STOP_* flags to JOBCTL_*.
Bit position macros JOBCTL_*_BIT are defined and JOBCTL_* flags are
defined in terms of them to allow using bitops later.
While at it, reassign JOBCTL_TRAPPING to bit 22 to better accomodate
future additions.
This doesn't cause any functional change.
-v2: JOBCTL_*_BIT macros added as suggested by Linus.
Now, exe_file is not proc FS dependent, so we can use it to name core
file. So we add %E pattern for core file name cration which extract path
from mm_struct->exe_file. Then it converts slashes to exclamation marks
and pastes the result to the core file name itself.
This is useful for environments where binary names are longer than 16
character (the current->comm limitation). Also where there are binaries
with same name but in a different path. Further in case the binery itself
changes its current->comm after exec.
So by doing (s/$/#/ -- # is treated as git comment):
$ sysctl kernel.core_pattern='core.%p.%e.%E'
$ ln /bin/cat cat45678901234567890
$ ./cat45678901234567890
^Z
$ rm cat45678901234567890
$ fg
^\Quit (core dumped)
$ ls core*
we now get:
core.2434.cat456789012345.!root!cat45678901234567890 (deleted)
Reviewed-by: Andi Kleen <andi@firstfloor.org>
