path: root/fs/exportfs/expfs.c
2016-10-06exportfs: be careful to only return expected errors.NeilBrown
When nfsd calls fh_to_dentry, it expect ESTALE or ENOMEM as errors. In particular it can be tempting to return ENOENT, but this is not handled well by nfsd. Rather than requiring strict adherence to error code code filesystems, treat all unexpected error codes the same as ESTALE. This is safest. Signed-off-by: NeilBrown <neilb@suse.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2016-05-02introduce a parallel variant of ->iterate()Al Viro
New method: ->iterate_shared(). Same arguments as in ->iterate(), called with the directory locked only shared. Once all filesystems switch, the old one will be gone. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-05-02reconnect_one(): use lookup_one_len_unlocked()Al Viro
... and explain the non-obvious logics in case when lookup yields a different dentry. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-01-22wrappers for ->i_mutex accessAl Viro
parallel to mutex_{lock,unlock,trylock,is_locked,lock_nested}, inode_foo(inode) being mutex_foo(&inode->i_mutex). Please, use those for access to ->i_mutex; over the coming cycle ->i_mutex will become rwsem, with ->lookup() done with it held only shared. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-02-22VFS: (Scripted) Convert S_ISLNK/DIR/REG(dentry->d_inode) to d_is_*(dentry)David Howells
Convert the following where appropriate: (1) S_ISLNK(dentry->d_inode) to d_is_symlink(dentry). (2) S_ISREG(dentry->d_inode) to d_is_reg(dentry). (3) S_ISDIR(dentry->d_inode) to d_is_dir(dentry). This is actually more complicated than it appears as some calls should be converted to d_can_lookup() instead. The difference is whether the directory in question is a real dir with a ->lookup op or whether it's a fake dir with a ->d_automount op. In some circumstances, we can subsume checks for dentry->d_inode not being NULL into this, provided we the code isn't in a filesystem that expects d_inode to be NULL if the dirent really *is* negative (ie. if we're going to use d_inode() rather than d_backing_inode() to get the inode pointer). Note that the dentry type field may be set to something other than DCACHE_MISS_TYPE when d_inode is NULL in the case of unionmount, where the VFS manages the fall-through from a negative dentry to a lower layer. In such a case, the dentry type of the negative union dentry is set to the same as the type of the lower dentry. However, if you know d_inode is not NULL at the call site, then you can use the d_is_xxx() functions even in a filesystem. There is one further complication: a 0,0 chardev dentry may be labelled DCACHE_WHITEOUT_TYPE rather than DCACHE_SPECIAL_TYPE. Strictly, this was intended for special directory entry types that don't have attached inodes. The following perl+coccinelle script was used: use strict; my @callers; open($fd, 'git grep -l \'S_IS[A-Z].*->d_inode\' |') || die "Can't grep for S_ISDIR and co. callers"; @callers = <$fd>; close($fd); unless (@callers) { print "No matches\n"; exit(0); } my @cocci = ( '@@', 'expression E;', '@@', '', '- S_ISLNK(E->d_inode->i_mode)', '+ d_is_symlink(E)', '', '@@', 'expression E;', '@@', '', '- S_ISDIR(E->d_inode->i_mode)', '+ d_is_dir(E)', '', '@@', 'expression E;', '@@', '', '- S_ISREG(E->d_inode->i_mode)', '+ d_is_reg(E)' ); my $coccifile = "tmp.sp.cocci"; open($fd, ">$coccifile") || die $coccifile; print($fd "$_\n") || die $coccifile foreach (@cocci); close($fd); foreach my $file (@callers) { chomp $file; print "Processing ", $file, "\n"; system("spatch", "--sp-file", $coccifile, $file, "--in-place", "--no-show-diff") == 0 || die "spatch failed"; } [AV: overlayfs parts skipped] Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-11-03move d_rcu from overlapping d_child to overlapping d_aliasAl Viro
2014-10-31vfs: make first argument of dir_context.actor typedMiklos Szeredi
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-06-04fs/exportfs/expfs.c: kernel-doc warning fixesFabian Frederick
Fixing 2 typo in function comments. Signed-off-by: Fabian Frederick <fabf@skynet.be> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: "J. Bruce Fields" <bfields@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-09exportfs: fix quadratic behavior in filehandle lookupJ. Bruce Fields
Suppose we're given the filehandle for a directory whose closest ancestor in the dcache is its Nth ancestor. The main loop in reconnect_path searches for an IS_ROOT ancestor of target_dir, reconnects that ancestor to its parent, then recommences the search for an IS_ROOT ancestor from target_dir. This behavior is quadratic in N. And there's really no need to restart the search from target_dir each time: once a directory has been looked up, it won't become IS_ROOT again. So instead of starting from target_dir each time, we can continue where we left off. This simplifies the code and improves performance on very deep directory heirachies. (I can't think of any reason anyone should need heirarchies a hundred or more deep, but the performance improvement may be valuable if only to limit damage in case of abuse.) Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-11-09exportfs: better variable nameJ. Bruce Fields
Replace another unhelpful acronym. Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-11-09exportfs: move most of reconnect_path to helper functionJ. Bruce Fields
Also replace 3 easily-confused three-letter acronyms by more helpful variable names. Just cleanup, no change in functionality, with one exception: the dentry_connected() check in the "out_reconnected" case will now only check the ancestors of the current dentry instead of checking all the way from target_dir. Since we've already verified connectivity up to this dentry, that should be sufficient. Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-11-09exportfs: eliminate unused "noprogress" counterJ. Bruce Fields
Note this counter is now being set to 0 on every pass through the loop, so it no longer serves any useful purpose. Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-11-09exportfs: stop retrying once we race with rename/removeJ. Bruce Fields
There are two places here where we could race with a rename or remove: - We could find the parent, but then be removed or renamed away from that parent directory before finding our name in that directory. - We could find the parent, and find our name in that parent, but then be renamed or removed before we look ourselves up by that name in that parent. In both cases the concurrent rename or remove will take care of reconnecting the directory that we're currently examining. Our target directory should then also be connected. Check this and clear DISCONNECTED in these cases instead of looping around again. Note: we *do* need to check that this actually happened if we want to be robust in the face of corrupted filesystems: a corrupted filesystem could just return a completely wrong parent, and we want to fail with an error in that case before starting to clear DISCONNECTED on non-DISCONNECTED filesystems. Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-11-09exportfs: clear DISCONNECTED on all parents soonerJ. Bruce Fields
Once we've found any connected parent, we know all our parents are connected--that's true even if there's a concurrent rename. May as well clear them all at once and be done with it. Reviewed-by: Cristoph Hellwig <hch@lst.de> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-11-09exportfs: more detailed comment for path_reconnectJ. Bruce Fields
2013-11-09exportfs: BUG_ON in crazy corner caseChristoph Hellwig
This would indicate a nasty bug in the dcache and has never triggered in the past 10 years as far as I know. Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-11-09exportfs: fix 32-bit nfsd handling of 64-bit inode numbersJ. Bruce Fields
Symptoms were spurious -ENOENTs on stat of an NFS filesystem from a 32-bit NFS server exporting a very large XFS filesystem, when the server's cache is cold (so the inodes in question are not in cache). Reviewed-by: Christoph Hellwig <hch@lst.de> Reported-by: Trevor Cordes <trevor@tecnopolis.ca> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-09-07exportfs: don't assume that ->iterate() won't feed us too long entriesAl Viro
On some filesystems it's impossible even with fs corruption, but we'd better not rely on that, what with memcpy() into on-stack array we are doing there. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-06-29[readdir] constify ->actorAl Viro
2013-06-29[readdir] ->readdir() is goneAl Viro
everything's converted to ->iterate() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-06-29[readdir] introduce ->iterate(), ctx->pos, dir_emit()Al Viro
New method - ->iterate(file, ctx). That's the replacement for ->readdir(); it takes callback from ctx->actor, uses ctx->pos instead of file->f_pos and calls dir_emit(ctx, ...) instead of filldir(data, ...). It does *not* update file->f_pos (or look at it, for that matter); iterate_dir() does the update. Note that dir_emit() takes the offset from ctx->pos (and eventually filldir_t will lose that argument). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-06-29[readdir] introduce iterate_dir() and dir_contextAl Viro
iterate_dir(): new helper, replacing vfs_readdir(). struct dir_context: contains the readdir callback (and will get more stuff in it), embedded into whatever data that callback wants to deal with; eventually, we'll be passing it to ->readdir() replacement instead of (data,filldir) pair. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-02-27hlist: drop the node parameter from iteratorsSasha Levin
I'm not sure why, but the hlist for each entry iterators were conceived list_for_each_entry(pos, head, member) The hlist ones were greedy and wanted an extra parameter: hlist_for_each_entry(tpos, pos, head, member) Why did they need an extra pos parameter? I'm not quite sure. Not only they don't really need it, it also prevents the iterator from looking exactly like the list iterator, which is unfortunate. Besides the semantic patch, there was some manual work required: - Fix up the actual hlist iterators in linux/list.h - Fix up the declaration of other iterators based on the hlist ones. - A very small amount of places were using the 'node' parameter, this was modified to use 'obj->member' instead. - Coccinelle didn't handle the hlist_for_each_entry_safe iterator properly, so those had to be fixed up manually. The semantic patch which is mostly the work of Peter Senna Tschudin is here: @@ iterator name hlist_for_each_entry, hlist_for_each_entry_continue, hlist_for_each_entry_from, hlist_for_each_entry_rcu, hlist_for_each_entry_rcu_bh, hlist_for_each_entry_continue_rcu_bh, for_each_busy_worker, ax25_uid_for_each, ax25_for_each, inet_bind_bucket_for_each, sctp_for_each_hentry, sk_for_each, sk_for_each_rcu, sk_for_each_from, sk_for_each_safe, sk_for_each_bound, hlist_for_each_entry_safe, hlist_for_each_entry_continue_rcu, nr_neigh_for_each, nr_neigh_for_each_safe, nr_node_for_each, nr_node_for_each_safe, for_each_gfn_indirect_valid_sp, for_each_gfn_sp, for_each_host; type T; expression a,c,d,e; identifier b; statement S; @@ -T b; <+... when != b ( hlist_for_each_entry(a, - b, c, d) S | hlist_for_each_entry_continue(a, - b, c) S | hlist_for_each_entry_from(a, - b, c) S | hlist_for_each_entry_rcu(a, - b, c, d) S | hlist_for_each_entry_rcu_bh(a, - b, c, d) S | hlist_for_each_entry_continue_rcu_bh(a, - b, c) S | for_each_busy_worker(a, c, - b, d) S | ax25_uid_for_each(a, - b, c) S | ax25_for_each(a, - b, c) S | inet_bind_bucket_for_each(a, - b, c) S | sctp_for_each_hentry(a, - b, c) S | sk_for_each(a, - b, c) S | sk_for_each_rcu(a, - b, c) S | sk_for_each_from -(a, b) +(a) S + sk_for_each_from(a) S | sk_for_each_safe(a, - b, c, d) S | sk_for_each_bound(a, - b, c) S | hlist_for_each_entry_safe(a, - b, c, d, e) S | hlist_for_each_entry_continue_rcu(a, - b, c) S | nr_neigh_for_each(a, - b, c) S | nr_neigh_for_each_safe(a, - b, c, d) S | nr_node_for_each(a, - b, c) S | nr_node_for_each_safe(a, - b, c, d) S | - for_each_gfn_sp(a, c, d, b) S + for_each_gfn_sp(a, c, d) S | - for_each_gfn_indirect_valid_sp(a, c, d, b) S + for_each_gfn_indirect_valid_sp(a, c, d) S | for_each_host(a, - b, c) S | for_each_host_safe(a, - b, c, d) S | for_each_mesh_entry(a, - b, c, d) S ) ...+> [akpm@linux-foundation.org: drop bogus change from net/ipv4/raw.c] [akpm@linux-foundation.org: drop bogus hunk from net/ipv6/raw.c] [akpm@linux-foundation.org: checkpatch fixes] [akpm@linux-foundation.org: fix warnings] [akpm@linux-foudnation.org: redo intrusive kvm changes] Tested-by: Peter Senna Tschudin <peter.senna@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Gleb Natapov <gleb@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-20Merge branch 'for-3.8' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
Pull nfsd update from Bruce Fields: "Included this time: - more nfsd containerization work from Stanislav Kinsbursky: we're not quite there yet, but should be by 3.9. - NFSv4.1 progress: implementation of basic backchannel security negotiation and the mandatory BACKCHANNEL_CTL operation. See http://wiki.linux-nfs.org/wiki/index.php/Server_4.0_and_4.1_issues for remaining TODO's - Fixes for some bugs that could be triggered by unusual compounds. Our xdr code wasn't designed with v4 compounds in mind, and it shows. A more thorough rewrite is still a todo. - If you've ever seen "RPC: multiple fragments per record not supported" logged while using some sort of odd userland NFS client, that should now be fixed. - Further work from Jeff Layton on our mechanism for storing information about NFSv4 clients across reboots. - Further work from Bryan Schumaker on his fault-injection mechanism (which allows us to discard selective NFSv4 state, to excercise rarely-taken recovery code paths in the client.) - The usual mix of miscellaneous bugs and cleanup. Thanks to everyone who tested or contributed this cycle." * 'for-3.8' of git://linux-nfs.org/~bfields/linux: (111 commits) nfsd4: don't leave freed stateid hashed nfsd4: free_stateid can use the current stateid nfsd4: cleanup: replace rq_resused count by rq_next_page pointer nfsd: warn on odd reply state in nfsd_vfs_read nfsd4: fix oops on unusual readlike compound nfsd4: disable zero-copy on non-final read ops svcrpc: fix some printks NFSD: Correct the size calculation in fault_inject_write NFSD: Pass correct buffer size to rpc_ntop nfsd: pass proper net to nfsd_destroy() from NFSd kthreads nfsd: simplify service shutdown nfsd: replace boolean nfsd_up flag by users counter nfsd: simplify NFSv4 state init and shutdown nfsd: introduce helpers for generic resources init and shutdown nfsd: make NFSd service structure allocated per net nfsd: make NFSd service boot time per-net nfsd: per-net NFSd up flag introduced nfsd: move per-net startup code to separated function nfsd: pass net to __write_ports() and down nfsd: pass net to nfsd_set_nrthreads() ...
2012-12-17fs, exportfs: add exportfs_encode_inode_fh() helperCyrill Gorcunov
We will need this helper in the next patch to provide a file handle for inotify marks in /proc/pid/fdinfo output. The patch is rather providing the way to use inodes directly when dentry is not available (like in case of inotify system). Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org> Acked-by: Pavel Emelyanov <xemul@parallels.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Andrey Vagin <avagin@openvz.org> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: James Bottomley <jbottomley@parallels.com> Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Matthew Helsley <matt.helsley@gmail.com> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com> Cc: Tvrtko Ursulin <tvrtko.ursulin@onelan.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17fs, exportfs: escape nil dereference if no s_export_op presentCyrill Gorcunov
This routine will be used to generate a file handle in fdinfo output for inotify subsystem, where if no s_export_op present the general export_encode_fh should be used. Thus add a test if s_export_op present inside exportfs_encode_fh itself. Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org> Acked-by: Pavel Emelyanov <xemul@parallels.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Andrey Vagin <avagin@openvz.org> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: James Bottomley <jbottomley@parallels.com> Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Matthew Helsley <matt.helsley@gmail.com> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com> Cc: Tvrtko Ursulin <tvrtko.ursulin@onelan.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-11-07exportfs: add FILEID_INVALID to indicate invalid fid_typeNamjae Jeon
This commit adds FILEID_INVALID = 0xff in fid_type to indicate invalid fid_type It avoids using magic number 255 Signed-off-by: Namjae Jeon <linkinjeon@gmail.com> Signed-off-by: Vivek Trivedi <vtrivedi018@gmail.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2012-07-23switch dentry_open() to struct path, make it grab references itselfAl Viro
2012-07-14vfs: switch i_dentry/d_alias to hlistAl Viro
2012-05-29->encode_fh() API changeAl Viro
pass inode + parent's inode or NULL instead of dentry + bool saying whether we want the parent or not. NOTE: that needs ceph fix folded in. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-15vfs: Add open by file handle supportAneesh Kumar K.V
[AV: duplicate of open() guts removed; file_open_root() used instead] Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-14exportfs: Return the minimum required handle sizeAneesh Kumar K.V
The exportfs encode handle function should return the minimum required handle size. This helps user to find out the handle size by passing 0 handle size in the first step and then redoing to the call again with the returned handle size value. Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-01-07fs: dcache per-inode inode alias lockingNick Piggin
dcache_inode_lock can be replaced with per-inode locking. Use existing inode->i_lock for this. This is slightly non-trivial because we sometimes need to find the inode from the dentry, which requires d_inode to be stabilised (either with refcount or d_lock). Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: dcache rationalise dget variantsNick Piggin
dget_locked was a shortcut to avoid the lazy lru manipulation when we already held dcache_lock (lru manipulation was relatively cheap at that point). However, how that the lru lock is an innermost one, we never hold it at any caller, so the lock cost can now be avoided. We already have well working lazy dcache LRU, so it should be fine to defer LRU manipulations to scan time. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: dcache remove dcache_lockNick Piggin
dcache_lock no longer protects anything. remove it. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: scale inode alias listNick Piggin
Add a new lock, dcache_inode_lock, to protect the inode's i_dentry list from concurrent modification. d_alias is also protected by d_lock. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2010-10-25exportfs: use dget_parentChristoph Hellwig
Use dget_parent instead of opencoding it. This simplifies the code, but more importanly prepares for the more complicated locking for a parent dget in the dcache scale patch series. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-10-27nfs: new subdir Documentation/filesystems/nfsJ. Bruce Fields
We're adding enough nfs documentation that it may as well have its own subdirectory. Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-12-25Merge branch 'next' into for-linusJames Morris
2008-12-08EXPORTFS: handle NULL returns from fh_to_dentry()/fh_to_parent()J. Bruce Fields
While 440037287c5 "[PATCH] switch all filesystems over to d_obtain_alias" removed some cases where fh_to_dentry() and fh_to_parent() could return NULL, there are still a few NULL returns left in individual filesystems. Thus it was a mistake for that commit to remove the handling of NULL returns in the callers. Revert those parts of 440037287c5 which removed the NULL handling. (We could, alternatively, modify all implementations to return -ESTALE instead of NULL, but that proves to require fixing a number of filesystems, and in some cases it's arguably more natural to return NULL.) Thanks to David for original patch and Linus, Christoph, and Hugh for review. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Cc: David Howells <dhowells@redhat.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-14CRED: Pass credentials through dentry_open()David Howells
Pass credentials through dentry_open() so that the COW creds patch can have SELinux's flush_unauthorized_files() pass the appropriate creds back to itself when it opens its null chardev. The security_dentry_open() call also now takes a creds pointer, as does the dentry_open hook in struct security_operations. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: James Morris <jmorris@namei.org> Signed-off-by: James Morris <jmorris@namei.org>
2008-10-23[PATCH] prepare vfs_readdir() callers to returning filldir resultAl Viro
It's not the final state, but it allows moving ->readdir() instances to passing filldir return value to caller of vfs_readdir(). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-10-23[PATCH] reduce the stack footprint of exportfs_decode_fh()Al Viro
no need to have _two_ 256-byte arrays on stack... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-10-23[PATCH] switch all filesystems over to d_obtain_aliasChristoph Hellwig
Switch all users of d_alloc_anon to d_obtain_alias. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-04-30fs: replace remaining __FUNCTION__ occurrencesHarvey Harrison
2007-10-22exportfs: update documentationChristoph Hellwig
Update documentation to the current state of affairs. Remove duplicated method descruptions in exportfs.h and point to Documentation/filesystems/ Exporting instead. Add a little file header comment in expfs.c describing what's going on and mentioning Neils and my copyright [1]. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Neil Brown <neilb@suse.de> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: <linux-ext4@vger.kernel.org> Cc: Dave Kleikamp <shaggy@austin.ibm.com> Cc: Anton Altaparmakov <aia21@cantab.net> Cc: David Chinner <dgc@sgi.com> Cc: Timothy Shimmin <tes@sgi.com> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Hugh Dickins <hugh@veritas.com> Cc: Chris Mason <mason@suse.com> Cc: Jeff Mahoney <jeffm@suse.com> Cc: "Vladimir V. Saveliev" <vs@namesys.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Mark Fasheh <mark.fasheh@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-22exportfs: make struct export_operations constChristoph Hellwig
Now that nfsd has stopped writing to the find_exported_dentry member we an mark the export_operations const Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Neil Brown <neilb@suse.de> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: <linux-ext4@vger.kernel.org> Cc: Dave Kleikamp <shaggy@austin.ibm.com> Cc: Anton Altaparmakov <aia21@cantab.net> Cc: David Chinner <dgc@sgi.com> Cc: Timothy Shimmin <tes@sgi.com> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Hugh Dickins <hugh@veritas.com> Cc: Chris Mason <mason@suse.com> Cc: Jeff Mahoney <jeffm@suse.com> Cc: "Vladimir V. Saveliev" <vs@namesys.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Mark Fasheh <mark.fasheh@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-22exportfs: remove old methodsChristoph Hellwig
Now that all filesystems are converted remove support for the old methods. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Neil Brown <neilb@suse.de> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: <linux-ext4@vger.kernel.org> Cc: Dave Kleikamp <shaggy@austin.ibm.com> Cc: Anton Altaparmakov <aia21@cantab.net> Cc: David Chinner <dgc@sgi.com> Cc: Timothy Shimmin <tes@sgi.com> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Hugh Dickins <hugh@veritas.com> Cc: Chris Mason <mason@suse.com> Cc: Jeff Mahoney <jeffm@suse.com> Cc: "Vladimir V. Saveliev" <vs@namesys.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Mark Fasheh <mark.fasheh@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-22exportfs: add new methodsChristoph Hellwig
Add the guts for the new filesystem API to exportfs. There's now a fh_to_dentry method that returns a dentry for the object looked for given a filehandle fragment, and a fh_to_parent operation that returns the dentry for the encoded parent directory in case the file handle contains it. There are default implementations for these methods that only take a callback for an nfs-enhanced iget variant and implement the rest of the semantics. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Neil Brown <neilb@suse.de> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: <linux-ext4@vger.kernel.org> Cc: Dave Kleikamp <shaggy@austin.ibm.com> Cc: Anton Altaparmakov <aia21@cantab.net> Cc: David Chinner <dgc@sgi.com> Cc: Timothy Shimmin <tes@sgi.com> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Hugh Dickins <hugh@veritas.com> Cc: Chris Mason <mason@suse.com> Cc: Jeff Mahoney <jeffm@suse.com> Cc: "Vladimir V. Saveliev" <vs@namesys.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Mark Fasheh <mark.fasheh@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-22exportfs: add fid typeChristoph Hellwig
This patchset is a medium scale rewrite of the export operations interface. The goal is to make the interface less complex, and easier to understand from the filesystem side, aswell as preparing generic support for exporting of 64bit inode numbers. This touches all nfs exporting filesystems, and I've done testing on all of the filesystems I have here locally (xfs, ext2, ext3, reiserfs, jfs) This patch: Add a structured fid type so that we don't have to pass an array of u32 values around everywhere. It's a union of possible layouts. As a start there's only the u32 array and the traditional 32bit inode format, but there will be more in one of my next patchset when I start to document the various filehandle formats we have in lowlevel filesystems better. Also add an enum that gives the various filehandle types human- readable names. Note: Some people might think the struct containing an anonymous union is ugly, but I didn't want to pass around a raw union type. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Neil Brown <neilb@suse.de> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: <linux-ext4@vger.kernel.org> Cc: Dave Kleikamp <shaggy@austin.ibm.com> Cc: Anton Altaparmakov <aia21@cantab.net> Cc: David Chinner <dgc@sgi.com> Cc: Timothy Shimmin <tes@sgi.com> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Hugh Dickins <hugh@veritas.com> Cc: Chris Mason <mason@suse.com> Cc: Jeff Mahoney <jeffm@suse.com> Cc: "Vladimir V. Saveliev" <vs@namesys.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Mark Fasheh <mark.fasheh@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
