path: root/fs/exportfs
2009-10-27nfs: new subdir Documentation/filesystems/nfsJ. Bruce Fields
We're adding enough nfs documentation that it may as well have its own subdirectory. Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-12-25Merge branch 'next' into for-linusJames Morris
2008-12-08EXPORTFS: handle NULL returns from fh_to_dentry()/fh_to_parent()J. Bruce Fields
While 440037287c5 "[PATCH] switch all filesystems over to d_obtain_alias" removed some cases where fh_to_dentry() and fh_to_parent() could return NULL, there are still a few NULL returns left in individual filesystems. Thus it was a mistake for that commit to remove the handling of NULL returns in the callers. Revert those parts of 440037287c5 which removed the NULL handling. (We could, alternatively, modify all implementations to return -ESTALE instead of NULL, but that proves to require fixing a number of filesystems, and in some cases it's arguably more natural to return NULL.) Thanks to David for original patch and Linus, Christoph, and Hugh for review. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Cc: David Howells <dhowells@redhat.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-14CRED: Pass credentials through dentry_open()David Howells
Pass credentials through dentry_open() so that the COW creds patch can have SELinux's flush_unauthorized_files() pass the appropriate creds back to itself when it opens its null chardev. The security_dentry_open() call also now takes a creds pointer, as does the dentry_open hook in struct security_operations. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: James Morris <jmorris@namei.org> Signed-off-by: James Morris <jmorris@namei.org>
2008-10-23[PATCH] prepare vfs_readdir() callers to returning filldir resultAl Viro
It's not the final state, but it allows moving ->readdir() instances to passing filldir return value to caller of vfs_readdir(). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-10-23[PATCH] reduce the stack footprint of exportfs_decode_fh()Al Viro
no need to have _two_ 256-byte arrays on stack... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-10-23[PATCH] switch all filesystems over to d_obtain_aliasChristoph Hellwig
Switch all users of d_alloc_anon to d_obtain_alias. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-04-30fs: replace remaining __FUNCTION__ occurrencesHarvey Harrison
2007-10-22exportfs: update documentationChristoph Hellwig
Update documentation to the current state of affairs. Remove duplicated method descruptions in exportfs.h and point to Documentation/filesystems/ Exporting instead. Add a little file header comment in expfs.c describing what's going on and mentioning Neils and my copyright [1]. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Neil Brown <neilb@suse.de> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: <linux-ext4@vger.kernel.org> Cc: Dave Kleikamp <shaggy@austin.ibm.com> Cc: Anton Altaparmakov <aia21@cantab.net> Cc: David Chinner <dgc@sgi.com> Cc: Timothy Shimmin <tes@sgi.com> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Hugh Dickins <hugh@veritas.com> Cc: Chris Mason <mason@suse.com> Cc: Jeff Mahoney <jeffm@suse.com> Cc: "Vladimir V. Saveliev" <vs@namesys.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Mark Fasheh <mark.fasheh@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-22exportfs: make struct export_operations constChristoph Hellwig
Now that nfsd has stopped writing to the find_exported_dentry member we an mark the export_operations const Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Neil Brown <neilb@suse.de> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: <linux-ext4@vger.kernel.org> Cc: Dave Kleikamp <shaggy@austin.ibm.com> Cc: Anton Altaparmakov <aia21@cantab.net> Cc: David Chinner <dgc@sgi.com> Cc: Timothy Shimmin <tes@sgi.com> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Hugh Dickins <hugh@veritas.com> Cc: Chris Mason <mason@suse.com> Cc: Jeff Mahoney <jeffm@suse.com> Cc: "Vladimir V. Saveliev" <vs@namesys.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Mark Fasheh <mark.fasheh@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-22exportfs: remove old methodsChristoph Hellwig
Now that all filesystems are converted remove support for the old methods. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Neil Brown <neilb@suse.de> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: <linux-ext4@vger.kernel.org> Cc: Dave Kleikamp <shaggy@austin.ibm.com> Cc: Anton Altaparmakov <aia21@cantab.net> Cc: David Chinner <dgc@sgi.com> Cc: Timothy Shimmin <tes@sgi.com> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Hugh Dickins <hugh@veritas.com> Cc: Chris Mason <mason@suse.com> Cc: Jeff Mahoney <jeffm@suse.com> Cc: "Vladimir V. Saveliev" <vs@namesys.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Mark Fasheh <mark.fasheh@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-22exportfs: add new methodsChristoph Hellwig
Add the guts for the new filesystem API to exportfs. There's now a fh_to_dentry method that returns a dentry for the object looked for given a filehandle fragment, and a fh_to_parent operation that returns the dentry for the encoded parent directory in case the file handle contains it. There are default implementations for these methods that only take a callback for an nfs-enhanced iget variant and implement the rest of the semantics. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Neil Brown <neilb@suse.de> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: <linux-ext4@vger.kernel.org> Cc: Dave Kleikamp <shaggy@austin.ibm.com> Cc: Anton Altaparmakov <aia21@cantab.net> Cc: David Chinner <dgc@sgi.com> Cc: Timothy Shimmin <tes@sgi.com> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Hugh Dickins <hugh@veritas.com> Cc: Chris Mason <mason@suse.com> Cc: Jeff Mahoney <jeffm@suse.com> Cc: "Vladimir V. Saveliev" <vs@namesys.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Mark Fasheh <mark.fasheh@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-22exportfs: add fid typeChristoph Hellwig
This patchset is a medium scale rewrite of the export operations interface. The goal is to make the interface less complex, and easier to understand from the filesystem side, aswell as preparing generic support for exporting of 64bit inode numbers. This touches all nfs exporting filesystems, and I've done testing on all of the filesystems I have here locally (xfs, ext2, ext3, reiserfs, jfs) This patch: Add a structured fid type so that we don't have to pass an array of u32 values around everywhere. It's a union of possible layouts. As a start there's only the u32 array and the traditional 32bit inode format, but there will be more in one of my next patchset when I start to document the various filehandle formats we have in lowlevel filesystems better. Also add an enum that gives the various filehandle types human- readable names. Note: Some people might think the struct containing an anonymous union is ugly, but I didn't want to pass around a raw union type. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Neil Brown <neilb@suse.de> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: <linux-ext4@vger.kernel.org> Cc: Dave Kleikamp <shaggy@austin.ibm.com> Cc: Anton Altaparmakov <aia21@cantab.net> Cc: David Chinner <dgc@sgi.com> Cc: Timothy Shimmin <tes@sgi.com> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Hugh Dickins <hugh@veritas.com> Cc: Chris Mason <mason@suse.com> Cc: Jeff Mahoney <jeffm@suse.com> Cc: "Vladimir V. Saveliev" <vs@namesys.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Mark Fasheh <mark.fasheh@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17knfsd: exportfs: split out reconnecting a dentry from find_exported_dentryChristoph Hellwig
There's a clear subfunctionality of reconnecting a given dentry to the main dentry tree in find_exported_dentry, that can be called both for the dentry we're looking for or it's parent directory. This patch splits the subfunctionality out into a separate helper to make the code more readable and document it's intent. As a nice side-optimization we can avoid getting a superfluous dentry reference count in the case we need to reconnect a directory on it's own. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17knfsd: exportfs: add find_disconnected_root helperChristoph Hellwig
Break the loop that finds the root of a disconnected subtree into a helper of its own to make reading easier and document the intent. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17knfsd: exportfs: move acceptable check into find_acceptable_aliasChristoph Hellwig
All callers of find_acceptable_alias check if the current dentry is acceptable before looking for other acceptable aliases using find_acceptable_alias. Move the check into find_acceptable_alias to make the code a little more dense and add a comment to find_acceptable_alias that documents its intent. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17knfsd: exportfs: untangle ISDIR logic in find_exported_dentryChristoph Hellwig
Rework some logic in find_exported_dentry so that we only have a single S_ISDIR check and logic that makes clear to the reader what we're really doing here. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17knfsd: exportfs: remove CALL macroChristoph Hellwig
Currently exportfs uses a way to call methods very differently from the rest of the kernel. This patch changes it to the standard conventions for method calls. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17knfsd: exportfs: add procedural interface for NFSDChristoph Hellwig
Currently NFSD calls directly into filesystems through the export_operations structure. I plan to change this interface in various ways in later patches, and want to avoid the export of the default operations to NFSD, so this patch adds two simple exportfs_encode_fh/exportfs_decode_fh helpers for NFSD to call instead of poking into exportfs guts. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17knfsd: exportfs: remove iget abuseChristoph Hellwig
When the exportfs interface was added the expectation was that filesystems provide an operation to convert from a file handle to an inode/dentry, but it kept a backwards compat option that still calls into iget. Calling into iget from non-filesystem code is very bad, because it gives too little information to filesystem, and simply crashes if the filesystem doesn't implement the ->read_inode routine. Fortunately there are only two filesystems left using this fallback: efs and jfs. This patch moves a copy of export_iget to each of those to implement the get_dentry method. While this is a temporary increase of lines of code in the kernel it allows for a much cleaner interface and important code restructuring in later patches. [akpm@linux-foundation.org: add jfs_get_inode_flags() declaration] Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17knfsd: exportfs: add exportfs.h headerChristoph Hellwig
currently the export_operation structure and helpers related to it are in fs.h. fs.h is already far too large and there are very few places needing the export bits, so split them off into a separate header. [akpm@linux-foundation.org: fix cifs build] Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Neil Brown <neilb@suse.de> Cc: Steven French <sfrench@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-03[PATCH] VFS: Make filldir_t and struct kstat deal in 64-bit inode numbersDavid Howells
These patches make the kernel pass 64-bit inode numbers internally when communicating to userspace, even on a 32-bit system. They are required because some filesystems have intrinsic 64-bit inode numbers: NFS3+ and XFS for example. The 64-bit inode numbers are then propagated to userspace automatically where the arch supports it. Problems have been seen with userspace (eg: ld.so) using the 64-bit inode number returned by stat64() or getdents64() to differentiate files, and failing because the 64-bit inode number space was compressed to 32-bits, and so overlaps occur. This patch: Make filldir_t take a 64-bit inode number and struct kstat carry a 64-bit inode number so that 64-bit inode numbers can be passed back to userspace. The stat functions then returns the full 64-bit inode number where available and where possible. If it is not possible to represent the inode number supplied by the filesystem in the field provided by userspace, then error EOVERFLOW will be issued. Similarly, the getdents/readdir functions now pass the full 64-bit inode number to userspace where possible, returning EOVERFLOW instead when a directory entry is encountered that can't be properly represented. Note that this means that some inodes will not be stat'able on a 32-bit system with old libraries where they were before - but it does mean that there will be no ambiguity over what a 32-bit inode number refers to. Note similarly that directory scans may be cut short with an error on a 32-bit system with old libraries where the scan would work before for the same reasons. It is judged unlikely that this situation will occur because modern glibc uses 64-bit capable versions of stat and getdents class functions exclusively, and that older systems are unlikely to encounter unrepresentable inode numbers anyway. [akpm: alpha build fix] Signed-off-by: David Howells <dhowells@redhat.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-21[PATCH] NFS server subtree_check returns dubious valuePeter Staubach
Address a problem found when a Linux NFS server uses the "subtree_check" export option. The "subtree_check" NFS export option was designed to prohibit a client from using a file handle for which it should not have permission. The algorithm used is to ensure that the entire path to the file being referenced is accessible to the user attempting to use the file handle. If some part of the path is not accessible, then the operation is aborted and the appropriate version of ESTALE is returned to the NFS client. The error, ESTALE, is unfortunate in that it causes NFS clients to make certain assumptions about the continued existence of the file. They assume that the file no longer exists and refuse to attempt to access it again. In this case, the file really does exist, but access was denied by the server for a particular user. A better error to return would be an EACCES sort of error. This would inform the client that the particular operation that it was attempting was not allowed, without the nasty side effects of the ESTALE error. Signed-off-by: Peter Staubach <staubach@redhat.com> Acked-By: NeilBrown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-18[PATCH] exportfs: add find_acceptable_alias helperChristoph Hellwig
find_exported_dentry contains two duplicate loops to find an alias that the acceptable callback likes. Split this out to a new helper and switch from list_for_each to list_for_each_entry to make it more readable. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: NeilBrown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-09[PATCH] mutex subsystem, semaphore to mutex: VFS, ->i_semJes Sorensen
This patch converts the inode semaphore to a mutex. I have tested it on XFS and compiled as much as one can consider on an ia64. Anyway your luck with it might be different. Modified-by: Ingo Molnar <mingo@elte.hu> (finished the conversion) Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
