path: root/fs/ext2/Makefile
2009-06-11switch ext2 to simple_fsync()Al Viro
kill ext2_sync_file() (along with ext2/fsync.c), get rid of ext2_update_inode() - it's an alias of ext2_write_inode(). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-06-25[PATCH] Make EXT2_DEBUG work againValerie Henson
This patch makes EXT2_DEBUG work again. Due to lack of proper include file, EXT2_DEBUG was undefined in bitmap.c and ext2_count_free() is left out. Moved to balloc.c and removed bitmap.c entirely. Second, debug versions of ext2_count_free_{inodes/blocks} reacquires superblock lock. Moved lock into callers. Signed-off-by: Val Henson <val_henson@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] xip: ext2: execute in placeCarsten Otte
These are the ext2 related parts. Ext2 now uses the xip_* file operations along with the get_xip_page aop when mounted with -o xip. Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
