path: root/fs/ext2/acl.c
2006-09-27[PATCH] fs: Removing useless castsPanagiotis Issaris
* Removing useless casts * Removing useless wrapper * Conversion from kmalloc+memset to kzalloc Signed-off-by: Panagiotis Issaris <takis@issaris.org> Acked-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-03[PATCH] Fix two ext[23] uninitialized warningsAndreas Gruenbacher
There is a code path that passed size to ext2_xattr_set (ext3_xattr_set_handle) before initializing it. The callees don't use the value in that case, but gcc cannot tell. Always initialize size to get rid of the warnings. Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-11[PATCH] capable/capability.h (fs/)Randy Dunlap
fs: Use <linux/capability.h> where capable() is used. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Acked-by: Tim Schmielau <tim@physik3.uni-rostock.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-09[PATCH] mutex subsystem, semaphore to mutex: VFS, ->i_semJes Sorensen
This patch converts the inode semaphore to a mutex. I have tested it on XFS and compiled as much as one can consider on an ia64. Anyway your luck with it might be different. Modified-by: Ingo Molnar <mingo@elte.hu> (finished the conversion) Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2005-11-07[PATCH] kfree cleanup: fsJesper Juhl
This is the fs/ part of the big kfree cleanup patch. Remove pointless checks for NULL prior to calling kfree() in fs/. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-23[PATCH] remove <linux/xattr_acl.h>Christoph Hellwig
This file duplicates <linux/posix_acl_xattr.h>, using slightly different names. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-16[PATCH] Fix acl Oopsakpm@osdl.org
) From: Andreas Gruenbacher <agruen@suse.de> ext[23]_get_acl will return an error when reading the attribute fails or out-of-memory occurs. Catch this case. Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
