path: root/fs/ext2/ext2.h
2010-08-09merge ext2 delete_inode and clear_inode, switch to ->evict_inode()Al Viro
2010-08-09clean up write_begin usage for directories in pagecacheChristoph Hellwig
For filesystem that implement directories in pagecache we call block_write_begin with an already allocated page for this code, while the normal regular file write path uses the default block_write_begin behaviour. Get rid of the __foofs_write_begin helper and opencode the normal write_begin call in foofs_write_begin, while adding a new foofs_prepare_chunk helper for the directory code. The added benefit is that foofs_prepare_chunk has a much saner calling convention. Note that the interruptible flag passed into block_write_begin is always ignored if we already pass in a page (see next patch for details), and we never were doing truncations of exessive blocks for this case either so we can switch directly to block_write_begin_newtrunc. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-27ext2: convert to use the new truncate convention.npiggin@suse.de
I also have commented a possible bug in existing ext2 code, marked with XXX. Cc: linux-ext4@vger.kernel.org Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-27drop unused dentry argument to ->fsyncChristoph Hellwig
2010-03-05pass writeback_control to ->write_inodeChristoph Hellwig
This gives the filesystem more information about the writeback that is happening. Trond requested this for the NFS unstable write handling, and other filesystems might benefit from this too by beeing able to distinguish between the different callers in more detail. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-12-16ext2: report metadata errors during fsyncJan Kara
When an IO error happens while writing metadata buffers, we should better report it and call ext2_error since the filesystem is probably no longer consistent. Sometimes such IO errors happen while flushing thread does background writeback, the buffer gets later evicted from memory, and thus the only trace of the error remains as AS_EIO bit set in blockdevice's mapping. So we check this bit in ext2_fsync and report the error although we cannot be really sure which buffer we failed to write. Signed-off-by: Jan Kara <jack@suse.cz> Cc: Chris Mason <chris.mason@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-10ext2: Unify log messages in ext2Alexey Fisher
make messages produced by ext2 more unified. It should be easy to parse. dmesg before patch: [ 4893.684892] reservations ON [ 4893.684896] xip option not supported [ 4893.684961] EXT2-fs warning: mounting ext3 filesystem as ext2 [ 4893.684964] EXT2-fs warning: maximal mount count reached, running e2fsck is recommended [ 4893.684990] EXT II FS: 0.5b, 95/08/09, bs=1024, fs=1024, gc=2, bpg=8192, ipg=1280, mo=80010] dmesg after patch: [ 4893.684892] EXT2-fs (loop0): reservations ON [ 4893.684896] EXT2-fs (loop0): xip option not supported [ 4893.684961] EXT2-fs (loop0): warning: mounting ext3 filesystem as ext2 [ 4893.684964] EXT2-fs (loop0): warning: maximal mount count reached, running e2fsck is recommended [ 4893.684990] EXT2-fs (loop0): 0.5b, 95/08/09, bs=1024, fs=1024, gc=2, bpg=8192, ipg=1280, mo=80010] Signed-off-by: Alexey Fisher <bug-track@fisher-privat.net> Reviewed-by: Andreas Dilger <adilger@sun.com> Signed-off-by: Jan Kara <jack@suse.cz>
2009-06-24switch ext2 to inode->i_aclAl Viro
2009-06-18ext2: Do not update mtime of a moved directoryJan Kara
One of our users is complaining that his backup tool is upset on ext2 (while it's happy on ext3, xfs, ...) because of the mtime change. The problem is: mkdir foo mkdir bar mkdir foo/a Now under ext2: mv foo/a foo/b changes mtime of 'foo/a' (foo/b after the move). That does not really make sense and it does not happen under any other filesystem I've seen. More complicated is: mv foo/a bar/a This changes mtime of foo/a (bar/a after the move) and it makes some sense since we had to update parent directory pointer of foo/a. But again, no other filesystem does this. So after some thoughts I'd vote for consistency and change ext2 to behave the same as other filesystems. Do not update mtime of a moved directory. Specs don't say anything about it (neither that it should, nor that it should not be updated) and other common filesystems (ext3, ext4, xfs, reiserfs, fat, ...) don't do it. So let's become more consistent. Spotted by ronny.pretzsch@dfs.de, initial fix by Jörn Engel. Reported-by: <ronny.pretzsch@dfs.de> Cc: <hare@suse.de> Cc: Jörn Engel <joern@logfs.org> Signed-off-by: Jan Kara <jack@suse.cz> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-12trivial: ext2: fix a typo in comment in ext2.hAli Gholami Rudi
Signed-off-by: Ali Gholami Rudi <ali@rudi.ir> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-06-11switch ext2 to simple_fsync()Al Viro
kill ext2_sync_file() (along with ext2/fsync.c), get rid of ext2_update_inode() - it's an alias of ext2_write_inode(). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-10-23[PATCH] get rid of on-stack dentry in ext2_get_parent()Al Viro
2008-10-03generic block based fiemap implementationJosef Bacik
Any block based fs (this patch includes ext3) just has to declare its own fiemap() function and then call this generic function with its own get_block_t. This works well for block based filesystems that will map multiple contiguous blocks at one time, but will work for filesystems that only map one block at a time, you will just end up with an "extent" for each block. One gotcha is this will not play nicely where there is hole+data after the EOF. This function will assume its hit the end of the data as soon as it hits a hole after the EOF, so if there is any data past that it will not pick that up. AFAIK no block based fs does this anyway, but its in the comments of the function anyway just in case. Signed-off-by: Josef Bacik <jbacik@redhat.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: linux-fsdevel@vger.kernel.org
2008-02-08ext2: remove unused ext2_put_inode prototypeChristoph Hellwig
Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07iget: stop EXT2 from using iget() and read_inode()David Howells
Stop the EXT2 filesystem from using iget() and read_inode(). Replace ext2_read_inode() with ext2_iget(), and call that instead of iget(). ext2_iget() then uses iget_locked() directly and returns a proper error code instead of an inode in the event of an error. ext2_fill_super() returns any error incurred when getting the root inode instead of EINVAL. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: "Theodore Ts'o" <tytso@mit.edu> Cc: <linux-ext4@vger.kernel.org> Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06BKL-removal: convert ext2 over to use unlocked_ioctlAndi Kleen
I checked ext2_ioctl and could not find anything in there that would need the BKL. So convert it over to use unlocked_ioctl Signed-off-by: Andi Kleen <ak@suse.de> Cc: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-29fix up ext2_fs.h for userspace after reservations backportTobias Poschwatta
In commit a686cd898bd999fd026a51e90fb0a3410d258ddb: "Val's cross-port of the ext3 reservations code into ext2." include/linux/ext2_fs.h got a new function whose return value is only defined if __KERNEL__ is defined. Putting #ifdef __KERNEL__ around the function seems to help, patch below. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17ext2 reservationsMartin J. Bligh
Val's cross-port of the ext3 reservations code into ext2. [mbligh@mbligh.org: Small type error for printk [akpm@linux-foundation.org: fix types, sync with ext3] [mbligh@mbligh.org: Bring ext2 reservations code in line with latest ext3] [akpm@linux-foundation.org: kill noisy printk] [akpm@linux-foundation.org: remember to dirty the gdp's block] [akpm@linux-foundation.org: cross-port the missed 5dea5176e5c32ef9f0d1a41d28427b3bf6881b3a] [akpm@linux-foundation.org: cross-port e6022603b9aa7d61d20b392e69edcdbbc1789969] [akpm@linux-foundation.org: Port the omitted 08fb306fe63d98eb86e3b16f4cc21816fa47f18e] [akpm@linux-foundation.org: Backport the missed 20acaa18d0c002fec180956f87adeb3f11f635a6] [akpm@linux-foundation.org: fixes] [cmm@us.ibm.com: fix reservation extension] [bunk@stusta.de: make ext2_get_blocks() static] [hugh@veritas.com: fix hang] [hugh@veritas.com: ext2_new_blocks should reset the reservation window size] [hugh@veritas.com: ext2 balloc: fix off-by-one against rsv_end] [hugh@veritas.com: grp_goal 0 is a genuine goal (unlike -1), so ext2_try_to_allocate_with_rsv should treat it as such] [hugh@veritas.com: rbtree usage cleanup] [pbadari@us.ibm.com: Fix for ext2 reservation] [bunk@kernel.org: remove fs/ext2/balloc.c:reserve_blocks()] [hugh@veritas.com: ext2 balloc: use io_error label] Cc: "Martin J. Bligh" <mbligh@mbligh.org> Cc: Valerie Henson <val_henson@linux.intel.com> Cc: Mingming Cao <cmm@us.ibm.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16ext2: convert to new aopsNick Piggin
Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08ext3: copy i_flags to inode flags on writeJan Kara
Propagate flags such as S_APPEND, S_IMMUTABLE, etc. from i_flags into ext2-specific i_flags. Hence, when someone sets these flags via a different interface than ioctl, they are stored correctly. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-09-30[PATCH] BLOCK: Move the Ext2 device ioctl compat stuff to the Ext2 driver ↵David Howells
[try #6] Move the Ext2 device ioctl compat stuff from fs/compat_ioctl.c to the Ext2 driver so that the Ext2 header file doesn't need to be included. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2006-06-28[PATCH] mark address_space_operations constChristoph Hellwig
Same as with already do with the file operations: keep them in .rodata and prevents people from doing runtime patching. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Steven French <sfrench@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] Make most file operations structs in fs/ constArjan van de Ven
This is a conversion to make the various file_operations structs in fs/ const. Basically a regexp job, with a few manual fixups The goal is both to increase correctness (harder to accidentally write to shared datastructures) and reducing the false sharing of cachelines with things that get dirty in .data (while .rodata is nicely read only and thus cache clean) Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] fs/ext2/: proper ext2_get_parent() prototypeAdrian Bunk
Add a proper prototype for ext2_get_parent(). Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-09[PATCH] mutex subsystem, semaphore to mutex: VFS, ->i_semJes Sorensen
This patch converts the inode semaphore to a mutex. I have tested it on XFS and compiled as much as one can consider on an ia64. Anyway your luck with it might be different. Modified-by: Ingo Molnar <mingo@elte.hu> (finished the conversion) Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2005-07-12[PATCH] ext2: fix mount options partingJan Kara
Restore old set of ext2 mount options when remounting of a filesystem fails. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] xip: ext2: execute in placeCarsten Otte
These are the ext2 related parts. Ext2 now uses the xip_* file operations along with the get_xip_page aop when mounted with -o xip. Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-16[PATCH] ext2 corruption - regression between 2.6.9 and 2.6.10Bernard Blackham
Whilst trying to stress test a Promise SX8 card, we stumbled across some nasty filesystem corruption in ext2. Our tests involved creating an ext2 partition, mounting, running several concurrent fsx's over it, umounting, and fsck'ing, all scripted[1]. The fsck would always return with errors. This regression was traced back to a change between 2.6.9 and 2.6.10, which moves the functionality of ext2_put_inode into ext2_clear_inode. The attached patch reverses this change, and eliminated the source of corruption. Mingming Cao <cmm@us.ibm.com> said: I think his patch for ext2 is correct. The corruption on ext3 is not the same issue he saw on ext2. I believe that's the race between discard reservation and reservation in-use that we already fixed it in 2.6.12- rc1. For the problem related to ext2, at the time when we design reservation for ext3, we decide we only need to discard the reservation at the last file close, so we have ext3_discard_reservation on iput_final- >ext3_clear_inode. The ext2 handle discard preallocation differently at that time, it discard the preallocation at each iput(), not in input_final(), so we think it's unnecessary to thrash it so frequently, and the right thing to do, as we did for ext3 reservation, discard preallocation on last iput(). So we moved the ext2_discard_preallocation from ext2_put_inode(0 to ext2_clear_inode. Since ext2 preallocation is doing pre-allocation on disk, so it is possible that at the unmount time, someone is still hold the reference of the inode, so the preallocation for a file is not discard yet, so we still mark those blocks allocated on disk, while they are not actually in the inode's block map, so fsck will catch/fix that error later. This is not a issue for ext3, as ext3 reservation(pre-allocation) is done in memory. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
