path: root/fs/ext2/file.c
2010-05-27ext2: convert to use the new truncate convention.npiggin@suse.de
I also have commented a possible bug in existing ext2 code, marked with XXX. Cc: linux-ext4@vger.kernel.org Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-27rename the generic fsync implementationsChristoph Hellwig
We don't name our generic fsync implementations very well currently. The no-op implementation for in-memory filesystems currently is called simple_sync_file which doesn't make too much sense to start with, the the generic one for simple filesystems is called simple_fsync which can lead to some confusion. This patch renames the generic file fsync method to generic_file_fsync to match the other generic_file_* routines it is supposed to be used with, and the no-op implementation to noop_fsync to make it obvious what to expect. In addition add some documentation for both methods. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-27drop unused dentry argument to ->fsyncChristoph Hellwig
2010-03-05dquot: cleanup dquot initialize routineChristoph Hellwig
Get rid of the initialize dquot operation - it is now always called from the filesystem and if a filesystem really needs it's own (which none currently does) it can just call into it's own routine directly. Rename the now static low-level dquot_initialize helper to __dquot_initialize and vfs_dq_init to dquot_initialize to have a consistent namespace. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2010-03-05dquot: move dquot initialization responsibility into the filesystemChristoph Hellwig
Currently various places in the VFS call vfs_dq_init directly. This means we tie the quota code into the VFS. Get rid of that and make the filesystem responsible for the initialization. For most metadata operations this is a straight forward move into the methods, but for truncate and open it's a bit more complicated. For truncate we currently only call vfs_dq_init for the sys_truncate case because open already takes care of it for ftruncate and open(O_TRUNC) - the new code causes an additional vfs_dq_init for those which is harmless. For open the initialization is moved from do_filp_open into the open method, which means it happens slightly earlier now, and only for regular files. The latter is fine because we don't need to initialize it for operations on special files, and we already do it as part of the namespace operations for directories. Add a dquot_file_open helper that filesystems that support generic quotas can use to fill in ->open. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2009-12-16ext2: report metadata errors during fsyncJan Kara
When an IO error happens while writing metadata buffers, we should better report it and call ext2_error since the filesystem is probably no longer consistent. Sometimes such IO errors happen while flushing thread does background writeback, the buffer gets later evicted from memory, and thus the only trace of the error remains as AS_EIO bit set in blockdevice's mapping. So we check this bit in ext2_fsync and report the error although we cannot be really sure which buffer we failed to write. Signed-off-by: Jan Kara <jack@suse.cz> Cc: Chris Mason <chris.mason@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-08ext[234]: move over to 'check_acl' permission modelLinus Torvalds
Don't implement per-filesystem 'extX_permission()' functions that have to be called for every path component operation, and instead just expose the actual ACL checking so that the VFS layer can now do it for us. Reviewed-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-11switch ext2 to simple_fsync()Al Viro
kill ext2_sync_file() (along with ext2/fsync.c), get rid of ext2_update_inode() - it's an alias of ext2_write_inode(). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-10-03generic block based fiemap implementationJosef Bacik
Any block based fs (this patch includes ext3) just has to declare its own fiemap() function and then call this generic function with its own get_block_t. This works well for block based filesystems that will map multiple contiguous blocks at one time, but will work for filesystems that only map one block at a time, you will just end up with an "extent" for each block. One gotcha is this will not play nicely where there is hole+data after the EOF. This function will assume its hit the end of the data as soon as it hits a hole after the EOF, so if there is any data past that it will not pick that up. AFAIK no block based fs does this anyway, but its in the comments of the function anyway just in case. Signed-off-by: Josef Bacik <jbacik@redhat.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: linux-fsdevel@vger.kernel.org
2008-02-06BKL-removal: convert ext2 over to use unlocked_ioctlAndi Kleen
I checked ext2_ioctl and could not find anything in there that would need the BKL. So convert it over to use unlocked_ioctl Signed-off-by: Andi Kleen <ak@suse.de> Cc: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17ext2 reservationsMartin J. Bligh
Val's cross-port of the ext3 reservations code into ext2. [mbligh@mbligh.org: Small type error for printk [akpm@linux-foundation.org: fix types, sync with ext3] [mbligh@mbligh.org: Bring ext2 reservations code in line with latest ext3] [akpm@linux-foundation.org: kill noisy printk] [akpm@linux-foundation.org: remember to dirty the gdp's block] [akpm@linux-foundation.org: cross-port the missed 5dea5176e5c32ef9f0d1a41d28427b3bf6881b3a] [akpm@linux-foundation.org: cross-port e6022603b9aa7d61d20b392e69edcdbbc1789969] [akpm@linux-foundation.org: Port the omitted 08fb306fe63d98eb86e3b16f4cc21816fa47f18e] [akpm@linux-foundation.org: Backport the missed 20acaa18d0c002fec180956f87adeb3f11f635a6] [akpm@linux-foundation.org: fixes] [cmm@us.ibm.com: fix reservation extension] [bunk@stusta.de: make ext2_get_blocks() static] [hugh@veritas.com: fix hang] [hugh@veritas.com: ext2_new_blocks should reset the reservation window size] [hugh@veritas.com: ext2 balloc: fix off-by-one against rsv_end] [hugh@veritas.com: grp_goal 0 is a genuine goal (unlike -1), so ext2_try_to_allocate_with_rsv should treat it as such] [hugh@veritas.com: rbtree usage cleanup] [pbadari@us.ibm.com: Fix for ext2 reservation] [bunk@kernel.org: remove fs/ext2/balloc.c:reserve_blocks()] [hugh@veritas.com: ext2 balloc: use io_error label] Cc: "Martin J. Bligh" <mbligh@mbligh.org> Cc: Valerie Henson <val_henson@linux.intel.com> Cc: Mingming Cao <cmm@us.ibm.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16ext2: fix a comment when ext2_release_file() is calledJan Kara
Signed-off-by: Jan Kara <jack@suse.cz> Acked-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-10xip sendfile removalCarsten Otte
This patch removes xip_file_sendfile, the sendfile implementation for xip without replacement. Those customers that use xip on s390 are not using sendfile() as far as we know, and so far s390 is the only platform this could potentially be used on so far. Having sendfile is not a popular feature for execute in place file systems, however we have a working implementation of splice_read() based on fs/splice.c if anyone asks for it. At this point in time, it does not seem preferable to merge splice_read() for xip because it causes extra maintenence effort due to code duplication and it requires struct page behind the xip memory segment. We'd like to get rid of that in favor of supporting flash based embedded platforms (Monta Vista work) soon. Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-07-10sendfile: remove .sendfile from filesystems that use generic_file_sendfile()Jens Axboe
They can use generic_file_splice_read() instead. Since sys_sendfile() now prefers that, there should be no change in behaviour. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2006-10-01[PATCH] Streamline generic_file_* interfaces and filemap cleanupsBadari Pulavarty
This patch cleans up generic_file_*_read/write() interfaces. Christoph Hellwig gave me the idea for this clean ups. In a nutshell, all filesystems should set .aio_read/.aio_write methods and use do_sync_read/ do_sync_write() as their .read/.write methods. This allows us to cleanup all variants of generic_file_* routines. Final available interfaces: generic_file_aio_read() - read handler generic_file_aio_write() - write handler generic_file_aio_write_nolock() - no lock write handler __generic_file_aio_write_nolock() - internal worker routine Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] Remove readv/writev methods and use aio_read/aio_write insteadBadari Pulavarty
This patch removes readv() and writev() methods and replaces them with aio_read()/aio_write() methods. Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-30[PATCH] BLOCK: Move the Ext2 device ioctl compat stuff to the Ext2 driver ↵David Howells
[try #6] Move the Ext2 device ioctl compat stuff from fs/compat_ioctl.c to the Ext2 driver so that the Ext2 header file doesn't need to be included. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2006-03-30[PATCH] Introduce sys_splice() system callJens Axboe
This adds support for the sys_splice system call. Using a pipe as a transport, it can connect to files or sockets (latter as output only). From the splice.c comments: "splice": joining two ropes together by interweaving their strands. This is the "extended pipe" functionality, where a pipe is used as an arbitrary in-memory buffer. Think of a pipe as a small kernel buffer that you can use to transfer data from one end to the other. The traditional unix read/write is extended with a "splice()" operation that transfers data buffers to or from a pipe buffer. Named by Larry McVoy, original implementation from Linus, extended by Jens to support splicing to files and fixing the initial implementation bugs. Signed-off-by: Jens Axboe <axboe@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] Make most file operations structs in fs/ constArjan van de Ven
This is a conversion to make the various file_operations structs in fs/ const. Basically a regexp job, with a few manual fixups The goal is both to increase correctness (harder to accidentally write to shared datastructures) and reducing the false sharing of cachelines with things that get dirty in .data (while .rodata is nicely read only and thus cache clean) Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] xip: reduce code duplicationCarsten Otte
This patch reworks filemap_xip.c with the goal to reduce code duplication from mm/filemap.c. It applies agains 2.6.12-rc6-mm1. Instead of implementing the aio functions, this one implements the synchronous read/write functions only. For readv and writev, the generic fallback is used. For aio, we rely on the application doing the fallback. Since our "synchronous" function does memcpy immediately anyway, there is no performance difference between using the fallbacks or implementing each operation. Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] xip: ext2: execute in placeCarsten Otte
These are the ext2 related parts. Ext2 now uses the xip_* file operations along with the get_xip_page aop when mounted with -o xip. Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
