commit e705f4b8aa27a59f8933e8f384e9752f052c469c upstream.
Check err when partial == NULL is meaningless because
partial == NULL means getting branch successfully without
error.
CC: stable@vger.kernel.org
Link: https://lore.kernel.org/r/20191105045100.7104-1-cgxu519@mykernel.net
Signed-off-by: Chengguang Xu <cgxu519@mykernel.net>
commit 1c2d14212b15a60300a2d4f6364753e87394c521 upstream.
When ext2 filesystem is created with 64k block size, ext2_max_size()
will return value less than 0. Also, we cannot write any file in this fs
since the sb->maxbytes is less than 0. The core of the problem is that
the size of block index tree for such large block size is more than
i_blocks can carry. So fix the computation to count with this
possibility.
File size limits computed with the new function for the full range of
possible block sizes look like:
bits file_size
10 17247252480
11 275415851008
12 2196873666560
13 2197948973056
14 2198486220800
15 2198754754560
16 2198888906752
Reported-by: yangerkun <yangerkun@huawei.com>
commit ecebf55d27a11538ea84aee0be643dd953f830d5 upstream.
The function ext2_xattr_set calls brelse(bh) to drop the reference count
of bh. After that, bh may be freed. However, following brelse(bh),
it reads bh->b_data via macro HDR(bh). This may result in a
use-after-free bug. This patch moves brelse(bh) after reading field.
Signed-off-by: Pan Bian <bianpan2016@163.com>
commit 80660f20252d6f76c9f203874ad7c7a4a8508cf8 upstream.
The function return values are confusing with the way the function is
named. We expect a true or false return value but it actually returns
0/-errno. This makes the code very confusing. Changing the return values
to return a bool where if DAX is supported then return true and no DAX
support returns false.
Signed-off-by: Dave Jiang <dave.jiang@intel.com>
Signed-off-by: Ross Zwisler <ross.zwisler@linux.intel.com>
Reviewed-by: Darrick J. Wong <darrick.wong@oracle.com>
Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com>
commit ba23cba9b3bdc967aabdc6ff1e3e9b11ce05bb4f upstream.
Change bdev_dax_supported so it takes a bdev parameter. This enables
multi-device filesystems like xfs to check that a dax device can work for
the particular filesystem. Once that's in place, actually fix all the
parts of XFS where we need to be able to distinguish between datadev and
rtdev.
This patch fixes the problem where we screw up the dax support checking
in xfs if the datadev and rtdev have different dax capabilities.
[rez: Re-added __bdev_dax_supported() for !CONFIG_FS_DAX cases]
Reviewed-by: Eric Sandeen <sandeen@redhat.com>
commit 1e2e547a93a00ebc21582c06ca3c6cfea2a309ee upstream.
For anything NFS-exported we do _not_ want to unlock new inode
before it has grown an alias; original set of fixes got the
ordering right, but missed the nasty complication in case of
lockdep being enabled - unlock_new_inode() does
lockdep_annotate_inode_mutex_key(inode)
which can only be done before anyone gets a chance to touch
->i_mutex. Unfortunately, flipping the order and doing
unlock_new_inode() before d_instantiate() opens a window when
mkdir can race with open-by-fhandle on a guessed fhandle, leading
to multiple aliases for a directory inode and all the breakage
that follows from that.
Correct solution: a new primitive (d_instantiate_new())
combining these two in the right order - lockdep annotate, then
d_instantiate(), then the rest of unlock_new_inode(). All
combinations of d_instantiate() with unlock_new_inode() should
be converted to that.
Cc: stable@kernel.org # 2.6.29 and later
Tested-by: Mike Marshall <hubcap@omnibond.com>
Reviewed-by: Andreas Dilger <adilger@dilger.ca>
commit 5aa1437d2d9a068c0334bd7c9dafa8ec4f97f13b upstream.
open file, unlink it, then use ioctl(2) to make it immutable or
append only. Now close it and watch the blocks *not* freed...
Immutable/append-only checks belong in ->setattr().
Note: the bug is old and backport to anything prior to 737f2e93b972
("ext2: convert to use the new truncate convention") will need
these checks lifted into ext2_setattr().
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
Pull mount flag updates from Al Viro:
"Another chunk of fmount preparations from dhowells; only trivial
conflicts for that part. It separates MS_... bits (very grotty
mount(2) ABI) from the struct super_block ->s_flags (kernel-internal,
only a small subset of MS_... stuff).
This does *not* convert the filesystems to new constants; only the
infrastructure is done here. The next step in that series is where the
conflicts would be; that's the conversion of filesystems. It's purely
mechanical and it's better done after the merge, so if you could run
something like
list=$(for i in MS_RDONLY MS_NOSUID MS_NODEV MS_NOEXEC MS_SYNCHRONOUS MS_MANDLOCK MS_DIRSYNC MS_NOATIME MS_NODIRATIME MS_SILENT MS_POSIXACL MS_KERNMOUNT MS_I_VERSION MS_LAZYTIME; do git grep -l $i fs drivers/staging/lustre drivers/mtd ipc mm include/linux; done|sort|uniq|grep -v '^fs/namespace.c$')
sed -i -e 's/\<MS_RDONLY\>/SB_RDONLY/g' \
-e 's/\<MS_NOSUID\>/SB_NOSUID/g' \
-e 's/\<MS_NODEV\>/SB_NODEV/g' \
-e 's/\<MS_NOEXEC\>/SB_NOEXEC/g' \
-e 's/\<MS_SYNCHRONOUS\>/SB_SYNCHRONOUS/g' \
-e 's/\<MS_MANDLOCK\>/SB_MANDLOCK/g' \
-e 's/\<MS_DIRSYNC\>/SB_DIRSYNC/g' \
-e 's/\<MS_NOATIME\>/SB_NOATIME/g' \
-e 's/\<MS_NODIRATIME\>/SB_NODIRATIME/g' \
-e 's/\<MS_SILENT\>/SB_SILENT/g' \
-e 's/\<MS_POSIXACL\>/SB_POSIXACL/g' \
-e 's/\<MS_KERNMOUNT\>/SB_KERNMOUNT/g' \
-e 's/\<MS_I_VERSION\>/SB_I_VERSION/g' \
-e 's/\<MS_LAZYTIME\>/SB_LAZYTIME/g' \
$list
and commit it with something along the lines of 'convert filesystems
away from use of MS_... constants' as commit message, it would save a
quite a bit of headache next cycle"
* 'work.mount' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
VFS: Differentiate mount flags (MS_*) from internal superblock flags
VFS: Convert sb->s_flags & MS_RDONLY to sb_rdonly(sb)
vfs: Add sb_rdonly(sb) to query the MS_RDONLY flag on s_flags
git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm
Pull libnvdimm from Dan Williams:
"A rework of media error handling in the BTT driver and other updates.
It has appeared in a few -next releases and collected some late-
breaking build-error and warning fixups as a result.
Summary:
- Media error handling support in the Block Translation Table (BTT)
driver is reworked to address sleeping-while-atomic locking and
memory-allocation-context conflicts.
- The dax_device lookup overhead for xfs and ext4 is moved out of the
iomap hot-path to a mount-time lookup.
- A new 'ecc_unit_size' sysfs attribute is added to advertise the
read-modify-write boundary property of a persistent memory range.
- Preparatory fix-ups for arm and powerpc pmem support are included
along with other miscellaneous fixes"
* tag 'libnvdimm-for-4.14' of git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm: (26 commits)
libnvdimm, btt: fix format string warnings
libnvdimm, btt: clean up warning and error messages
ext4: fix null pointer dereference on sbi
libnvdimm, nfit: move the check on nd_reserved2 to the endpoint
dax: fix FS_DAX=n BLOCK=y compilation
libnvdimm: fix integer overflow static analysis warning
libnvdimm, nd_blk: remove mmio_flush_range()
libnvdimm, btt: rework error clearing
libnvdimm: fix potential deadlock while clearing errors
libnvdimm, btt: cache sector_size in arena_info
libnvdimm, btt: ensure that flags were also unchanged during a map_read
libnvdimm, btt: refactor map entry operations with macros
libnvdimm, btt: fix a missed NVDIMM_IO_ATOMIC case in the write path
libnvdimm, nfit: export an 'ecc_unit_size' sysfs attribute
ext4: perform dax_device lookup at mount
ext2: perform dax_device lookup at mount
xfs: perform dax_device lookup at mount
dax: introduce a fs_dax_get_by_bdev() helper
libnvdimm, btt: check memory allocation failure
libnvdimm, label: fix index block size calculation
When servicing mmap() reads from file holes the current DAX code
allocates a page cache page of all zeroes and places the struct page
pointer in the mapping->page_tree radix tree.
This has three major drawbacks:
1) It consumes memory unnecessarily. For every 4k page that is read via
a DAX mmap() over a hole, we allocate a new page cache page. This
means that if you read 1GiB worth of pages, you end up using 1GiB of
zeroed memory. This is easily visible by looking at the overall
memory consumption of the system or by looking at /proc/[pid]/smaps:
7f62e72b3000-7f63272b3000 rw-s 00000000 103:00 12 /root/dax/data
Rss: 1048576 kB
Pss: 1048576 kB
Shared_Clean: 0 kB
Shared_Dirty: 0 kB
Private_Clean: 1048576 kB
Private_Dirty: 0 kB
Referenced: 1048576 kB
Anonymous: 0 kB
LazyFree: 0 kB
AnonHugePages: 0 kB
ShmemPmdMapped: 0 kB
Shared_Hugetlb: 0 kB
Private_Hugetlb: 0 kB
Swap: 0 kB
SwapPss: 0 kB
KernelPageSize: 4 kB
MMUPageSize: 4 kB
Locked: 0 kB
2) It is slower than using a common zero page because each page fault
has more work to do. Instead of just inserting a common zero page we
have to allocate a page cache page, zero it, and then insert it. Here
are the average latencies of dax_load_hole() as measured by ftrace on
a random test box:
Old method, using zeroed page cache pages: 3.4 us
New method, using the common 4k zero page: 0.8 us
This was the average latency over 1 GiB of sequential reads done by
this simple fio script:
[global]
size=1G
filename=/root/dax/data
fallocate=none
[io]
rw=read
ioengine=mmap
3) The fact that we had to check for both DAX exceptional entries and
for page cache pages in the radix tree made the DAX code more
complex.
Solve these issues by following the lead of the DAX PMD code and using a
common 4k zero page instead. As with the PMD code we will now insert a
DAX exceptional entry into the radix tree instead of a struct page
pointer which allows us to remove all the special casing in the DAX
code.
Note that we do still pretty aggressively check for regular pages in the
DAX radix tree, especially where we take action based on the bits set in
the page. If we ever find a regular page in our radix tree now that
most likely means that someone besides DAX is inserting pages (which has
happened lots of times in the past), and we want to find that out early
and fail loudly.
This solution also removes the extra memory consumption. Here is that
same /proc/[pid]/smaps after 1GiB of reading from a hole with the new
code:
7f2054a74000-7f2094a74000 rw-s 00000000 103:00 12 /root/dax/data
Rss: 0 kB
Pss: 0 kB
Shared_Clean: 0 kB
Shared_Dirty: 0 kB
Private_Clean: 0 kB
Private_Dirty: 0 kB
Referenced: 0 kB
Anonymous: 0 kB
LazyFree: 0 kB
AnonHugePages: 0 kB
Swap: 0 kB
SwapPss: 0 kB
MMUPageSize: 4 kB
Locked: 0 kB
Overall system memory consumption is similarly improved.
Another major change is that we remove dax_pfn_mkwrite() from our fault
flow, and instead rely on the page fault itself to make the PTE dirty
and writeable. The following description from the patch adding the
vm_insert_mixed_mkwrite() call explains this a little more:
"To be able to use the common 4k zero page in DAX we need to have our
PTE fault path look more like our PMD fault path where a PTE entry
can be marked as dirty and writeable as it is first inserted rather
than waiting for a follow-up dax_pfn_mkwrite() =>
finish_mkwrite_fault() call.
Right now we can rely on having a dax_pfn_mkwrite() call because we
can distinguish between these two cases in do_wp_page():
case 1: 4k zero page => writable DAX storage
case 2: read-only DAX storage => writeable DAX storage
This distinction is made by via vm_normal_page(). vm_normal_page()
returns false for the common 4k zero page, though, just as it does
for DAX ptes. Instead of special casing the DAX + 4k zero page case
we will simplify our DAX PTE page fault sequence so that it matches
our DAX PMD sequence, and get rid of the dax_pfn_mkwrite() helper.
We will instead use dax_iomap_fault() to handle write-protection
faults.
This means that insert_pfn() needs to follow the lead of
insert_pfn_pmd() and allow us to pass in a 'mkwrite' flag. If
'mkwrite' is set insert_pfn() will do the work that was previously
done by wp_page_reuse() as part of the dax_pfn_mkwrite() call path"
Link: http://lkml.kernel.org/r/20170724170616.25810-4-ross.zwisler@linux.intel.com
Cc: "Darrick J. Wong" <darrick.wong@oracle.com>
Cc: "Theodore Ts'o" <tytso@mit.edu>
Cc: Andreas Dilger <adilger.kernel@dilger.ca>
Cc: Dan Williams <dan.j.williams@intel.com>
Cc: Jonathan Corbet <corbet@lwn.net>
Cc: Matthew Wilcox <mawilcox@microsoft.com>
Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
The ->iomap_begin() operation is a hot path, so cache the
fs_dax_get_by_host() result at mount time to avoid the incurring the
hash lookup overhead on a per-i/o basis.
Reported-by: Christoph Hellwig <hch@lst.de>
When changing a file's acl mask, ext2_set_acl() will first set the group
bits of i_mode to the value of the mask, and only then set the actual
extended attribute representing the new acl.
If the second part fails (due to lack of space, for example) and the file
had no acl attribute to begin with, the system will from now on assume
that the mask permission bits are actual group permission bits, potentially
granting access to the wrong users.
Prevent this by only changing the inode mode after the acl has been set.
[JK: Rebased on top of "ext2: Don't clear SGID when inheriting ACLs"]
Signed-off-by: Ernesto A. Fernández <ernesto.mnd.fernandez@gmail.com>
When new directory 'DIR1' is created in a directory 'DIR0' with SGID bit
set, DIR1 is expected to have SGID bit set (and owning group equal to
the owning group of 'DIR0'). However when 'DIR0' also has some default
ACLs that 'DIR1' inherits, setting these ACLs will result in SGID bit on
'DIR1' to get cleared if user is not member of the owning group.
Fix the problem by creating __ext2_set_acl() function that does not call
posix_acl_update_mode() and use it when inheriting ACLs. That prevents
SGID bit clearing and the mode has been properly set by
posix_acl_create() anyway.
Fixes: 073931017b49d9458aa351605b43a7e34598caef
CC: linux-ext4@vger.kernel.org
Firstly by applying the following with coccinelle's spatch:
@@ expression SB; @@
-SB->s_flags & MS_RDONLY
+sb_rdonly(SB)
to effect the conversion to sb_rdonly(sb), then by applying:
@@ expression A, SB; @@
-(!sb_rdonly(SB)) && A
+!sb_rdonly(SB) && A
-A != (sb_rdonly(SB))
+A != sb_rdonly(SB)
-A == (sb_rdonly(SB))
+A == sb_rdonly(SB)
-!(sb_rdonly(SB))
+!sb_rdonly(SB)
-A && (sb_rdonly(SB))
+A && sb_rdonly(SB)
-A || (sb_rdonly(SB))
+A || sb_rdonly(SB)
-(sb_rdonly(SB)) != A
+sb_rdonly(SB) != A
-(sb_rdonly(SB)) == A
+sb_rdonly(SB) == A
-(sb_rdonly(SB)) && A
+sb_rdonly(SB) && A
-(sb_rdonly(SB)) || A
+sb_rdonly(SB) || A
@@ expression A, B, SB; @@
-(sb_rdonly(SB)) ? 1 : 0
+sb_rdonly(SB)
-(sb_rdonly(SB)) ? A : B
+sb_rdonly(SB) ? A : B
to remove left over excess bracketage and finally by applying:
-(A & MS_RDONLY) != sb_rdonly(SB)
+(bool)(A & MS_RDONLY) != sb_rdonly(SB)
-(A & MS_RDONLY) == sb_rdonly(SB)
+(bool)(A & MS_RDONLY) == sb_rdonly(SB)
to make comparisons against the result of sb_rdonly() (which is a bool)
work correctly.
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs
Pull ext2, udf, reiserfs fixes from Jan Kara:
"Several ext2, udf, and reiserfs fixes"
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs:
ext2: Fix memory leak when truncate races ext2_get_blocks
reiserfs: fix race in prealloc discard
reiserfs: don't preallocate blocks for extended attributes
udf: Convert udf_disk_stamp_to_time() to use mktime64()
udf: Use time64_to_tm for timestamp conversion
udf: Fix deadlock between writeback and udf_setsize()
udf: Use i_size_read() in udf_adinicb_writepage()
udf: Fix races with i_size changes during readpage
udf: Remove unused UDF_DEFAULT_BLOCKSIZE
Buffer heads referencing indirect blocks may not be released if the file
is truncated at the right time. This happens because ext2_get_branch()
returns NULL when it finds the whole chain of indirect blocks already
set, and when truncate alters the chain this value of NULL is
treated as the address of the last head to be released. Handle this in the
same way as it's done after the got_it label.
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4
Pull ext4 updates from Ted Ts'o:
"The first major feature for ext4 this merge window is the largedir
feature, which allows ext4 directories to support over 2 billion
directory entries (assuming ~64 byte file names; in practice, users
will run into practical performance limits first.) This feature was
originally written by the Lustre team, and credit goes to Artem
Blagodarenko from Seagate for getting this feature upstream.
The second major major feature allows ext4 to support extended
attribute values up to 64k. This feature was also originally from
Lustre, and has been enhanced by Tahsin Erdogan from Google with a
deduplication feature so that if multiple files have the same xattr
value (for example, Windows ACL's stored by Samba), only one copy will
be stored on disk for encoding and caching efficiency.
We also have the usual set of bug fixes, cleanups, and optimizations"
* tag 'ext4_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (47 commits)
ext4: fix spelling mistake: "prellocated" -> "preallocated"
ext4: fix __ext4_new_inode() journal credits calculation
ext4: skip ext4_init_security() and encryption on ea_inodes
fs: generic_block_bmap(): initialize all of the fields in the temp bh
ext4: change fast symlink test to not rely on i_blocks
ext4: require key for truncate(2) of encrypted file
ext4: don't bother checking for encryption key in ->mmap()
ext4: check return value of kstrtoull correctly in reserved_clusters_store
ext4: fix off-by-one fsmap error on 1k block filesystems
ext4: return EFSBADCRC if a bad checksum error is found in ext4_find_entry()
ext4: return EIO on read error in ext4_find_entry
ext4: forbid encrypting root directory
ext4: send parallel discards on commit completions
ext4: avoid unnecessary stalls in ext4_evict_inode()
ext4: add nombcache mount option
ext4: strong binding of xattr inode references
ext4: eliminate xattr entry e_hash recalculation for removes
ext4: reserve space for xattr entries/names
quota: add get_inode_usage callback to transfer multi-inode charges
ext4: xattr inode deduplication
git://git.kernel.org/pub/scm/linux/kernel/git/jlayton/linux
Pull Writeback error handling updates from Jeff Layton:
"This pile represents the bulk of the writeback error handling fixes
that I have for this cycle. Some of the earlier patches in this pile
may look trivial but they are prerequisites for later patches in the
series.
The aim of this set is to improve how we track and report writeback
errors to userland. Most applications that care about data integrity
will periodically call fsync/fdatasync/msync to ensure that their
writes have made it to the backing store.
For a very long time, we have tracked writeback errors using two flags
in the address_space: AS_EIO and AS_ENOSPC. Those flags are set when a
writeback error occurs (via mapping_set_error) and are cleared as a
side-effect of filemap_check_errors (as you noted yesterday). This
model really sucks for userland.
Only the first task to call fsync (or msync or fdatasync) will see the
error. Any subsequent task calling fsync on a file will get back 0
(unless another writeback error occurs in the interim). If I have
several tasks writing to a file and calling fsync to ensure that their
writes got stored, then I need to have them coordinate with one
another. That's difficult enough, but in a world of containerized
setups that coordination may even not be possible.
But wait...it gets worse!
The calls to filemap_check_errors can be buried pretty far down in the
call stack, and there are internal callers of filemap_write_and_wait
and the like that also end up clearing those errors. Many of those
callers ignore the error return from that function or return it to
userland at nonsensical times (e.g. truncate() or stat()). If I get
back -EIO on a truncate, there is no reason to think that it was
because some previous writeback failed, and a subsequent fsync() will
(incorrectly) return 0.
This pile aims to do three things:
1) ensure that when a writeback error occurs that that error will be
reported to userland on a subsequent fsync/fdatasync/msync call,
regardless of what internal callers are doing
2) report writeback errors on all file descriptions that were open at
the time that the error occurred. This is a user-visible change,
but I think most applications are written to assume this behavior
anyway. Those that aren't are unlikely to be hurt by it.
3) document what filesystems should do when there is a writeback
error. Today, there is very little consistency between them, and a
lot of cargo-cult copying. We need to make it very clear what
filesystems should do in this situation.
To achieve this, the set adds a new data type (errseq_t) and then
builds new writeback error tracking infrastructure around that. Once
all of that is in place, we change the filesystems to use the new
infrastructure for reporting wb errors to userland.
Note that this is just the initial foray into cleaning up this mess.
There is a lot of work remaining here:
1) convert the rest of the filesystems in a similar fashion. Once the
initial set is in, then I think most other fs' will be fairly
simple to convert. Hopefully most of those can in via individual
filesystem trees.
2) convert internal waiters on writeback to use errseq_t for
detecting errors instead of relying on the AS_* flags. I have some
draft patches for this for ext4, but they are not quite ready for
prime time yet.
This was a discussion topic this year at LSF/MM too. If you're
interested in the gory details, LWN has some good articles about this:
https://lwn.net/Articles/718734/
https://lwn.net/Articles/724307/"
* tag 'for-linus-v4.13-2' of git://git.kernel.org/pub/scm/linux/kernel/git/jlayton/linux:
btrfs: minimal conversion to errseq_t writeback error reporting on fsync
xfs: minimal conversion to errseq_t writeback error reporting
ext4: use errseq_t based error handling for reporting data writeback errors
fs: convert __generic_file_fsync to use errseq_t based reporting
block: convert to errseq_t based writeback error tracking
dax: set errors in mapping when writeback fails
Documentation: flesh out the section in vfs.txt on storing and reporting writeback errors
mm: set both AS_EIO/AS_ENOSPC and errseq_t in mapping_set_error
fs: new infrastructure for writeback error handling and reporting
lib: add errseq_t type and infrastructure for handling it
mm: don't TestClearPageError in __filemap_fdatawait_range
mm: clear AS_EIO/AS_ENOSPC when writeback initiation fails
jbd2: don't clear and reset errors after waiting on writeback
buffer: set errors in mapping at the time that the error occurs
fs: check for writeback errors after syncing out buffers in generic_file_fsync
buffer: use mapping_set_error instead of setting the flag
mm: fix mapping_set_error call in me_pagecache_dirty
ext2 currently does a test+clear of the AS_EIO flag, which is
is problematic for some coming changes.
What we really need to do instead is call filemap_check_errors
in __generic_file_fsync after syncing out the buffers. That
will be sufficient for this case, and help other callers detect
these errors properly as well.
With that, we don't need to twiddle it in ext2.
Suggested-by: Jan Kara <jack@suse.cz>
Signed-off-by: Jeff Layton <jlayton@redhat.com>
Reviewed-by: Matthew Wilcox <mawilcox@microsoft.com>
The callers all set it to 1.
Also, make it clear that this function will not set any sort of AS_*
error, and that the caller must do so if necessary. No existing caller
uses this on normal files, so none of them need it.
Also, add __must_check here since, in general, the callers need to handle
an error here in some fashion.
Link: http://lkml.kernel.org/r/20170525103303.6524-1-jlayton@redhat.com
Reviewed-by: Ross Zwisler <ross.zwisler@linux.intel.com>
There will be a second mb_cache instance that tracks ea_inodes. Make
existing names more explicit so that it is clear that they refer to
xattr block cache.
Signed-off-by: Tahsin Erdogan <tahsin@google.com>
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
Make names more generic so that mbcache usage is not limited to
block sharing. In a subsequent patch in the series
("ext4: xattr inode deduplication"), we start using the mbcache code
for sharing xattr inodes. With that patch, old mb_cache_entry.e_block
field could be holding either a block number or an inode number.
Tetsuo reports:
fs/built-in.o: In function `xfs_file_iomap_end':
xfs_iomap.c:(.text+0xe0ef9): undefined reference to `put_dax'
fs/built-in.o: In function `xfs_file_iomap_begin':
xfs_iomap.c:(.text+0xe1a7f): undefined reference to `dax_get_by_host'
make: *** [vmlinux] Error 1
$ grep DAX .config
CONFIG_DAX=m
# CONFIG_DEV_DAX is not set
# CONFIG_FS_DAX is not set
When FS_DAX=n we can/must throw away the dax code in filesystems.
Implement 'fs_' versions of dax_get_by_host() and put_dax() that are
nops in the FS_DAX=n case.
Cc: <linux-xfs@vger.kernel.org>
Cc: <linux-ext4@vger.kernel.org>
Cc: Jan Kara <jack@suse.com>
Cc: Ross Zwisler <ross.zwisler@linux.intel.com>
Tested-by: Tony Luck <tony.luck@intel.com>
Fixes: ef51042472f5 ("block, dax: move 'select DAX' from BLOCK to FS_DAX")
Reported-by: Tetsuo Handa <penguin-kernel@i-love.sakura.ne.jp>
Pull libnvdimm fixes from Dan Williams:
"Incremental fixes and a small feature addition on top of the main
libnvdimm 4.12 pull request:
- Geert noticed that tinyconfig was bloated by BLOCK selecting DAX.
The size regression is fixed by moving all dax helpers into the
dax-core and only specifying "select DAX" for FS_DAX and
dax-capable drivers. He also asked for clarification of the
NR_DEV_DAX config option which, on closer look, does not need to be
a config option at all. Mike also throws in a DEV_DAX_PMEM fixup
for good measure.
- Ben's attention to detail on -stable patch submissions caught a
case where the recent fixes to arch_copy_from_iter_pmem() missed a
condition where we strand dirty data in the cache. This is tagged
for -stable and will also be included in the rework of the pmem api
to a proposed {memcpy,copy_user}_flushcache() interface for 4.13.
- Vishal adds a feature that missed the initial pull due to pending
review feedback. It allows the kernel to clear media errors when
initializing a BTT (atomic sector update driver) instance on a pmem
namespace.
- Ross noticed that the dax_device + dax_operations conversion broke
__dax_zero_page_range(). The nvdimm unit tests fail to check this
path, but xfstests immediately trips over it. No excuse for missing
this before submitting the 4.12 pull request.
These all pass the nvdimm unit tests and an xfstests spot check. The
set has received a build success notification from the kbuild robot"
* 'libnvdimm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm:
filesystem-dax: fix broken __dax_zero_page_range() conversion
libnvdimm, btt: ensure that initializing metadata clears poison
libnvdimm: add an atomic vs process context flag to rw_bytes
x86, pmem: Fix cache flushing for iovec write < 8 bytes
device-dax: kill NR_DEV_DAX
block, dax: move "select DAX" from BLOCK to FS_DAX
device-dax: Tell kbuild DEV_DAX_PMEM depends on DEV_DAX
For configurations that do not enable DAX filesystems or drivers, do not
require the DAX core to be built.
Given that the 'direct_access' method has been removed from
'block_device_operations', we can also go ahead and remove the
block-related dax helper functions from fs/block_dev.c to
drivers/dax/super.c. This keeps dax details out of the block layer and
lets the DAX core be built as a module in the FS_DAX=n case.
Filesystems need to include dax.h to call bdev_dax_supported().
Cc: linux-xfs@vger.kernel.org
Reviewed-by: Jan Kara <jack@suse.com>
Reported-by: Geert Uytterhoeven <geert@linux-m68k.org>
Pull libnvdimm updates from Dan Williams:
"The bulk of this has been in multiple -next releases. There were a few
late breaking fixes and small features that got added in the last
couple days, but the whole set has received a build success
notification from the kbuild robot.
Change summary:
- Region media error reporting: A libnvdimm region device is the
parent to one or more namespaces. To date, media errors have been
reported via the "badblocks" attribute attached to pmem block
devices for namespaces in "raw" or "memory" mode. Given that
namespaces can be in "device-dax" or "btt-sector" mode this new
interface reports media errors generically, i.e. independent of
namespace modes or state.
This subsequently allows userspace tooling to craft "ACPI 6.1
Section 9.20.7.6 Function Index 4 - Clear Uncorrectable Error"
requests and submit them via the ioctl path for NVDIMM root bus
devices.
- Introduce 'struct dax_device' and 'struct dax_operations': Prompted
by a request from Linus and feedback from Christoph this allows for
dax capable drivers to publish their own custom dax operations.
This fixes the broken assumption that all dax operations are
related to a persistent memory device, and makes it easier for
other architectures and platforms to add customized persistent
memory support.
- 'libnvdimm' core updates: A new "deep_flush" sysfs attribute is
available for storage appliance applications to manually trigger
memory controllers to drain write-pending buffers that would
otherwise be flushed automatically by the platform ADR
(asynchronous-DRAM-refresh) mechanism at a power loss event.
Support for "locked" DIMMs is included to prevent namespaces from
surfacing when the namespace label data area is locked. Finally,
fixes for various reported deadlocks and crashes, also tagged for
-stable.
- ACPI / nfit driver updates: General updates of the nfit driver to
add DSM command overrides, ACPI 6.1 health state flags support, DSM
payload debug available by default, and various fixes.
Acknowledgements that came after the branch was pushed:
- commmit 565851c972b5 "device-dax: fix sysfs attribute deadlock":
Tested-by: Yi Zhang <yizhan@redhat.com>
- commit 23f498448362 "libnvdimm: rework region badblocks clearing"
Tested-by: Toshi Kani <toshi.kani@hpe.com>"
* tag 'libnvdimm-for-4.12' of git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm: (52 commits)
libnvdimm, pfn: fix 'npfns' vs section alignment
libnvdimm: handle locked label storage areas
libnvdimm: convert NDD_ flags to use bitops, introduce NDD_LOCKED
brd: fix uninitialized use of brd->dax_dev
block, dax: use correct format string in bdev_dax_supported
libnvdimm: restore "libnvdimm: band aid btt vs clear poison locking"
libnvdimm: fix nvdimm_bus_lock() vs device_lock() ordering
acpi, nfit: kill ACPI_NFIT_DEBUG
libnvdimm: fix clear length of nvdimm_forget_poison()
libnvdimm, pmem: fix a NULL pointer BUG in nd_pmem_notify
libnvdimm, region: sysfs trigger for nvdimm_flush()
libnvdimm: fix phys_addr for nvdimm_clear_poison
x86, dax, pmem: remove indirection around memcpy_from_pmem()
block: remove block_device_operations ->direct_access()
block, dax: convert bdev_dax_supported() to dax_direct_access()
filesystem-dax: convert to dax_direct_access()
Revert "block: use DAX for partition table reads"
ext2, ext4, xfs: retrieve dax_device for iomap operations
In preparation for converting fs/dax.c to use dax_direct_access()
instead of bdev_direct_access(), add the plumbing to retrieve the
dax_device associated with a given block_device.
Now that all places setting inode->i_flags that should be reflected in
on-disk flags are gone, we can remove ext2_get_inode_flags() call.
Currently immutable and noatime flags on quota files are set by quota
code which requires us to copy inode->i_flags to our on disk version of
quota flags in GETFLAGS ioctl and __ext2_write_inode(). Move to setting
/ clearing these on-disk flags directly to save that copying.
ext2_sync_fs() could be called without s_umount semaphore held when
called through ext2_write_super() from __ext2_write_inode(). This
function then calls dquot_writeback_dquots() which relies on s_umount to
be held for protection against other quota operations.
In fact __ext2_write_inode() does not need all the functionality
ext2_write_super() provides. It is enough to just write the superblock.
So use ext2_sync_super() instead.
Fixes: 9d1ccbe70e0b14545caad12dc73adb3605447df0
Reported-by: Jan Beulich <jbeulich@suse.com>
Add #include <linux/cred.h> dependencies to all .c files rely on sched.h
doing that for them.
Note that even if the count where we need to add extra headers seems high,
it's still a net win, because <linux/sched.h> is included in over
2,200 files ...
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Since the introduction of FAULT_FLAG_SIZE to the vm_fault flag, it has
been somewhat painful with getting the flags set and removed at the
correct locations. More than one kernel oops was introduced due to
difficulties of getting the placement correctly.
Remove the flag values and introduce an input parameter to huge_fault
that indicates the size of the page entry. This makes the code easier
to trace and should avoid the issues we see with the fault flags where
removal of the flag was necessary in the fallback paths.
Link: http://lkml.kernel.org/r/148615748258.43180.1690152053774975329.stgit@djiang5-desk3.ch.intel.com
Tested-by: Dan Williams <dan.j.williams@intel.com>
Cc: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Nilesh Choudhury <nilesh.choudhury@oracle.com>
Patch series "1G transparent hugepage support for device dax", v2.
The following series implements support for 1G trasparent hugepage on
x86 for device dax. The bulk of the code was written by Mathew Wilcox a
while back supporting transparent 1G hugepage for fs DAX. I have
forward ported the relevant bits to 4.10-rc. The current submission has
only the necessary code to support device DAX.
Comments from Dan Williams: So the motivation and intended user of this
functionality mirrors the motivation and users of 1GB page support in
hugetlbfs. Given expected capacities of persistent memory devices an
in-memory database may want to reduce tlb pressure beyond what they can
already achieve with 2MB mappings of a device-dax file. We have
customer feedback to that effect as Willy mentioned in his previous
version of these patches [1].
[1]: https://lkml.org/lkml/2016/1/31/52
Comments from Nilesh @ Oracle:
There are applications which have a process model; and if you assume
10,000 processes attempting to mmap all the 6TB memory available on a
server; we are looking at the following:
processes : 10,000
memory : 6TB
pte @ 4k page size: 8 bytes / 4K of memory * #processes = 6TB / 4k * 8 * 10000 = 1.5GB * 80000 = 120,000GB
pmd @ 2M page size: 120,000 / 512 = ~240GB
pud @ 1G page size: 240GB / 512 = ~480MB
As you can see with 2M pages, this system will use up an exorbitant
amount of DRAM to hold the page tables; but the 1G pages finally brings
it down to a reasonable level. Memory sizes will keep increasing; so
this number will keep increasing.
An argument can be made to convert the applications from process model
to thread model, but in the real world that may not be always practical.
Hopefully this helps explain the use case where this is valuable.
This patch (of 3):
In preparation for adding the ability to handle PUD pages, convert
vm_operations_struct.pmd_fault to vm_operations_struct.huge_fault. The
vm_fault structure is extended to include a union of the different page
table pointers that may be needed, and three flag bits are reserved to
indicate which type of pointer is in the union.
[ross.zwisler@linux.intel.com: remove unused function ext4_dax_huge_fault()]
Link: http://lkml.kernel.org/r/1485813172-7284-1-git-send-email-ross.zwisler@linux.intel.com
[dave.jiang@intel.com: clear PMD or PUD size flags when in fall through path]
Link: http://lkml.kernel.org/r/148589842696.5820.16078080610311444794.stgit@djiang5-desk3.ch.intel.com
Link: http://lkml.kernel.org/r/148545058784.17912.6353162518188733642.stgit@djiang5-desk3.ch.intel.com
Signed-off-by: Matthew Wilcox <mawilcox@microsoft.com>
Cc: Dave Jiang <dave.jiang@intel.com>
->fault(), ->page_mkwrite(), and ->pfn_mkwrite() calls do not need to
take a vma and vmf parameter when the vma already resides in vmf.
Remove the vma parameter to simplify things.
[arnd@arndb.de: fix ARM build]
Link: http://lkml.kernel.org/r/20170125223558.1451224-1-arnd@arndb.de
Link: http://lkml.kernel.org/r/148521301778.19116.10840599906674778980.stgit@djiang5-desk3.ch.intel.com
Cc: Theodore Ts'o <tytso@mit.edu>
Cc: Darrick J. Wong <darrick.wong@oracle.com>
As reported by Arnd:
https://lkml.org/lkml/2017/1/10/756
Compiling with the following configuration:
# CONFIG_EXT2_FS is not set
# CONFIG_EXT4_FS is not set
# CONFIG_XFS_FS is not set
# CONFIG_FS_IOMAP depends on the above filesystems, as is not set
CONFIG_FS_DAX=y
generates build warnings about unused functions in fs/dax.c:
fs/dax.c:878:12: warning: `dax_insert_mapping' defined but not used [-Wunused-function]
static int dax_insert_mapping(struct address_space *mapping,
fs/dax.c:572:12: warning: `copy_user_dax' defined but not used [-Wunused-function]
static int copy_user_dax(struct block_device *bdev, sector_t sector, size_t size,
fs/dax.c:542:12: warning: `dax_load_hole' defined but not used [-Wunused-function]
static int dax_load_hole(struct address_space *mapping, void **entry,
fs/dax.c:312:14: warning: `grab_mapping_entry' defined but not used [-Wunused-function]
static void *grab_mapping_entry(struct address_space *mapping, pgoff_t index,
Now that the struct buffer_head based DAX fault paths and I/O path have
been removed we really depend on iomap support being present for DAX.
Make this explicit by selecting FS_IOMAP if we compile in DAX support.
This allows us to remove conditional selections of FS_IOMAP when FS_DAX
was present for ext2 and ext4, and to remove an #ifdef in fs/dax.c.
Link: http://lkml.kernel.org/r/1484087383-29478-1-git-send-email-ross.zwisler@linux.intel.com
So far we did not return BH_New buffers from ext2_get_blocks() when we
allocated and zeroed-out a block for DAX inode to avoid racy zeroing in
DAX code. This zeroing is gone these days so we can remove the
workaround.
This was entirely automated, using the script by Al:
PATT='^[[:blank:]]*#[[:blank:]]*include[[:blank:]]*<asm/uaccess.h>'
sed -i -e "s!$PATT!#include <linux/uaccess.h>!" \
$(git grep -l "$PATT"|grep -v ^include/linux/uaccess.h)
to do the replacement at the end of the merge window.
Requested-by: Al Viro <viro@zeniv.linux.org.uk>
Pull quota, fsnotify and ext2 updates from Jan Kara:
"Changes to locking of some quota operations from dedicated quota mutex
to s_umount semaphore, a fsnotify fix and a simple ext2 fix"
quota: Fix bogus warning in dquot_disable()
fsnotify: Fix possible use-after-free in inode iteration on umount
ext2: reject inodes with negative size
quota: Remove dqonoff_mutex
ocfs2: Use s_umount for quota recovery protection
quota: Remove dqonoff_mutex from dquot_scan_active()
ocfs2: Protect periodic quota syncing with s_umount semaphore
quota: Use s_umount protection for quota operations
quota: Hold s_umount in exclusive mode when enabling / disabling quotas
fs: Provide function to get superblock with exclusive s_umount
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/vfs
Pull partial readlink cleanups from Miklos Szeredi.
This is the uncontroversial part of the readlink cleanup patch-set that
simplifies the default readlink handling.
Miklos and Al are still discussing the rest of the series.
* git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/vfs:
vfs: make generic_readlink() static
vfs: remove ".readlink = generic_readlink" assignments
vfs: default to generic_readlink()
vfs: replace calling i_op->readlink with vfs_readlink()
proc/self: use generic_readlink
ecryptfs: use vfs_get_link()
bad_inode: add missing i_op initializers
Pull fs meta data unmap optimization from Jens Axboe:
"A series from Jan Kara, providing a more efficient way for unmapping
meta data from in the buffer cache than doing it block-by-block.
Provide a general helper that existing callers can use"
* 'for-4.10/fs-unmap' of git://git.kernel.dk/linux-block:
fs: Remove unmap_underlying_metadata
fs: Add helper to clean bdev aliases under a bh and use it
ext2: Use clean_bdev_aliases() instead of iteration
ext4: Use clean_bdev_aliases() instead of iteration
direct-io: Use clean_bdev_aliases() instead of handmade iteration
fs: Provide function to unmap metadata for a range of blocks
If .readlink == NULL implies generic_readlink().
Generated by:
to_del="\.readlink.*=.*generic_readlink"
for i in `git grep -l $to_del`; do sed -i "/$to_del"/d $i; done
Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
Don't load an inode with a negative size; this causes integer overflow
problems in the VFS.
Currently the last user of ext2_get_blocks() for DAX inodes was
dax_truncate_page(). Convert that to iomap_zero_range() so that all DAX
IO uses the iomap path.
The recently added DAX functions that use the new struct iomap data
structure were named iomap_dax_rw(), iomap_dax_fault() and
iomap_dax_actor(). These are actually defined in fs/dax.c, though, so
should be part of the "dax" namespace and not the "iomap" namespace.
Rename them to dax_iomap_rw(), dax_iomap_fault() and dax_iomap_actor()
respectively.
Suggested-by: Dave Chinner <david@fromorbit.com>
Signed-off-by: Dave Chinner <david@fromorbit.com>
DAX PMD support was added via the following commit:
commit e7b1ea2ad658 ("ext2: huge page fault support")
I believe this path to be untested as ext2 doesn't reliably provide block
allocations that are aligned to 2MiB. In my testing I've been unable to
get ext2 to actually fault in a PMD. It always fails with a "pfn
unaligned" message because the sector returned by ext2_get_block() isn't
aligned.
I've tried various settings for the "stride" and "stripe_width" extended
options to mkfs.ext2, without any luck.
Since we can't reliably get PMDs, remove support so that we don't have an
untested code path that we may someday traverse when we happen to get an
aligned block allocation. This should also make 4k DAX faults in ext2 a
bit faster since they will no longer have to call the PMD fault handler
only to get a response of VM_FAULT_FALLBACK.
Use clean_bdev_aliases() instead of iterating through blocks one by one.
Signed-off-by: Jens Axboe <axboe@fb.com>
On ARM, we get this false-positive warning since the rework of
the ext2_get_blocks interface:
fs/ext2/inode.c: In function 'ext2_get_block':
include/linux/buffer_head.h:340:16: error: 'bno' may be used uninitialized in this function [-Werror=maybe-uninitialized]
The calling conventions for this function are rather complex, and it's
not surprising that the compiler gets this wrong, I spent a long time
trying to understand how it all fits together myself.
This change to avoid the warning makes sure the compiler sees that we
always set 'bno' pointer whenever we have a positive return code.
The transformation is correct because we always arrive at the 'got_it'
label with a positive count that gets used as the return value, while
any branch to the 'cleanup' label has a negative or zero 'err'.
Fixes: 6750ad71986d ("ext2: stop passing buffer_head to ext2_get_blocks")
