path: root/fs/ext3/acl.c
2011-03-23userns: rename is_owner_or_cap to inode_owner_or_capableSerge E. Hallyn
And give it a kernel-doc comment. [akpm@linux-foundation.org: btrfs changed in linux-next] Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Daniel Lezcano <daniel.lezcano@free.fr> Acked-by: David Howells <dhowells@redhat.com> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-07ext2,3,4: provide simple rcu-walk ACL implementationNick Piggin
This simple implementation just checks for no ACLs on the inode, and if so, then the rcu-walk may proceed, otherwise fail it. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: provide rcu-walk aware permission i_opsNick Piggin
2010-06-25ext3: update ctime when changing the file's permission by setfaclMiao Xie
ext3 didn't update the ctime of the file when its permission was changed. Steps to reproduce: # touch aaa # stat -c %Z aaa 1275289822 # setfacl -m 'u::x,g::x,o::x' aaa # stat -c %Z aaa 1275289822 <- unchanged But, according to the spec of the ctime, ext3 must update it. Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Jan Kara <jack@suse.cz>
2010-05-21ext3: constify xattr handlersStephen Hemminger
Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-12-16sanitize xattr handler prototypesChristoph Hellwig
Add a flags argument to struct xattr_handler and pass it to all xattr handler methods. This allows using the same methods for multiple handlers, e.g. for the ACL methods which perform exactly the same action for the access and default ACLs, just using a different underlying attribute. With a little more groundwork it'll also allow sharing the methods for the regular user/trusted/secure handlers in extN, ocfs2 and jffs2 like it's already done for xfs in this patch. Also change the inode argument to the handlers to a dentry to allow using the handlers mechnism for filesystems that require it later, e.g. cifs. [with GFS2 bits updated by Steven Whitehouse <swhiteho@redhat.com>] Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: James Morris <jmorris@namei.org> Acked-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-09-08ext[234]: move over to 'check_acl' permission modelLinus Torvalds
Don't implement per-filesystem 'extX_permission()' functions that have to be called for every path component operation, and instead just expose the actual ACL checking so that the VFS layer can now do it for us. Reviewed-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-24helpers for acl caching + switch to thoseAl Viro
helpers: get_cached_acl(inode, type), set_cached_acl(inode, type, acl), forget_cached_acl(inode, type). ubifs/xattr.c needed includes reordered, the rest is a plain switchover. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-24switch ext3 to inode->i_aclAl Viro
2009-06-17ext3: avoid unnecessary spinlock in critical POSIX ACL pathLinus Torvalds
If a filesystem supports POSIX ACL's, the VFS layer expects the filesystem to do POSIX ACL checks on any files not owned by the caller, and it does this for every single pathname component that it looks up. That obviously can be pretty expensive if the filesystem isn't careful about it, especially with locking. That's doubly sad, since the common case tends to be that there are no ACL's associated with the files in question. ext3 already caches the ACL data so that it doesn't have to look it up over and over again, but it does so by taking the inode->i_lock spinlock on every lookup. Which is a noticeable overhead even if it's a private lock, especially on CPU's where the serialization is expensive (eg Intel Netburst aka 'P4'). For the special case of not actually having any ACL's, all that locking is unnecessary. Even if somebody else were to be changing the ACL's on another CPU, we simply don't care - if we've seen a NULL ACL, we might as well use it. So just load the ACL speculatively without any locking, and if it was NULL, just use it. If it's non-NULL (either because we had a cached entry, or because the cache hasn't been filled in at all), it means that we'll need to get the lock and re-load it properly. This is noticeable even on Nehalem, which does locking quite well (much better than P4). From lmbench: Processor, Processes - times in microseconds - smaller is better -------------------------------------------------------------------- Host OS Mhz null null open slct fork exec sh call I/O stat clos TCP proc proc proc --------- ------------- ---- ---- ---- ---- ---- ---- ---- ---- ---- - before: nehalem.l Linux 2.6.30- 3193 0.04 0.09 0.95 1.45 2.18 69.1 273. 1141 nehalem.l Linux 2.6.30- 3193 0.04 0.09 0.95 1.48 2.28 69.9 253. 1140 nehalem.l Linux 2.6.30- 3193 0.04 0.10 0.95 1.42 2.19 68.6 284. 1141 - after: nehalem.l Linux 2.6.30- 3193 0.04 0.09 0.92 1.44 2.12 68.3 282. 1094 nehalem.l Linux 2.6.30- 3193 0.04 0.09 0.92 1.39 2.20 67.0 308. 1123 nehalem.l Linux 2.6.30- 3193 0.04 0.09 0.92 1.39 2.36 67.4 293. 1148 where you can see what appears to be a roughly 3% improvement in stat and open/close latencies from just the removal of the locking overhead. Of course, this only matters for files you don't own (the owner never needs to do the ACL checks), but that's the common case for libraries, header files, and executables. As well as for the base components of any absolute pathname, even if you are the owner of the final file. [ At some point we probably want to move this ACL caching logic entirely into the VFS layer (and only call down to the filesystem when uncached), but in the meantime this improves ext3 a bit. A similar fix to btrfs makes a much bigger difference (15x improvement in lmbench) due to broken caching. ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Acked-by: Jan Kara <jack@suse.cz> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-03-31New helper - current_umask()Al Viro
current->fs->umask is what most of fs_struct users are doing. Put that into a helper function. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-26[PATCH] sanitize ->permission() prototypeAl Viro
* kill nameidata * argument; map the 3 bits in ->flags anybody cares about to new MAY_... ones and pass with the mask. * kill redundant gfs2_iop_permission() * sanitize ecryptfs_permission() * fix remaining places where ->permission() instances might barf on new MAY_... found in mask. The obvious next target in that direction is permission(9) folded fix for nfs_permission() breakage from Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-03-19ext3: fix wrong gfp type under transactionJosef Bacik
There are several places where we make allocations with GFP_KERNEL while under a transaction, which could lead to an assertion panic or lockup if under memory pressure. This patch switches these problem areas to use GFP_NOFS to keep these problems from happening. Signed-off-by: Josef Bacik <jbacik@redhat.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17Introduce is_owner_or_cap() to wrap CAP_FOWNER use with fsuid checkSatyam Sharma
Introduce is_owner_or_cap() macro in fs.h, and convert over relevant users to it. This is done because we want to avoid bugs in the future where we check for only effective fsuid of the current task against a file's owning uid, without simultaneously checking for CAP_FOWNER as well, thus violating its semantics. [ XFS uses special macros and structures, and in general looked ... untouchable, so we leave it alone -- but it has been looked over. ] The (current->fsuid != inode->i_uid) check in generic_permission() and exec_permission_lite() is left alone, because those operations are covered by CAP_DAC_OVERRIDE and CAP_DAC_READ_SEARCH. Similarly operations falling under the purview of CAP_CHOWN and CAP_LEASE are also left alone. Signed-off-by: Satyam Sharma <ssatyam@cse.iitk.ac.in> Cc: Al Viro <viro@ftp.linux.org.uk> Acked-by: Serge E. Hallyn <serge@hallyn.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-09-27[PATCH] fs: Removing useless castsPanagiotis Issaris
* Removing useless casts * Removing useless wrapper * Conversion from kmalloc+memset to kzalloc Signed-off-by: Panagiotis Issaris <takis@issaris.org> Acked-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] ext3: More whitespace cleanupsDave Kleikamp
More white space cleanups in preparation of cloning ext4 from ext3. Removing spaces that precede a tab. Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-03[PATCH] Fix two ext[23] uninitialized warningsAndreas Gruenbacher
There is a code path that passed size to ext2_xattr_set (ext3_xattr_set_handle) before initializing it. The callees don't use the value in that case, but gcc cannot tell. Always initialize size to get rid of the warnings. Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-11[PATCH] capable/capability.h (fs/)Randy Dunlap
fs: Use <linux/capability.h> where capable() is used. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Acked-by: Tim Schmielau <tim@physik3.uni-rostock.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-09[PATCH] mutex subsystem, semaphore to mutex: VFS, ->i_semJes Sorensen
This patch converts the inode semaphore to a mutex. I have tested it on XFS and compiled as much as one can consider on an ia64. Anyway your luck with it might be different. Modified-by: Ingo Molnar <mingo@elte.hu> (finished the conversion) Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2005-06-24[PATCH] quota: ext3: Improve quota credit estimatesJan Kara
Use improved credits estimates for quota operations. Also reserve a space for a quota operation in a transaction only if filesystem was mounted with some quota options. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-23[PATCH] remove <linux/xattr_acl.h>Christoph Hellwig
This file duplicates <linux/posix_acl_xattr.h>, using slightly different names. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-16[PATCH] Fix acl Oopsakpm@osdl.org
) From: Andreas Gruenbacher <agruen@suse.de> ext[23]_get_acl will return an error when reading the attribute fails or out-of-memory occurs. Catch this case. Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
