path: root/fs/ext3/bitmap.c
2007-10-17fs: mark nibblemap constPhilippe De Muyter
Signed-off-by: Philippe De Muyter <phdm@macqel.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-09-27[PATCH] ext3 and jbd cleanup: remove whitespaceMingming Cao
Remove whitespace from ext3 and jbd, before we clone ext4. Signed-off-by: Mingming Cao<cmm@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25[PATCH] ext3: Fix debug logging-only compilation errorKirk True
When EXT3FS_DEBUG is #define-d, the compile breaks due to #include file issues. Signed-off-by: Kirk True <kernel@kirkandsheila.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] fs/ext3/: small cleanupsAdrian Bunk
This patch contains the following cleanups: - there's no need for ext3_count_free() #ifndef EXT3FS_DEBUG - having prototypes for ext3_count_free() in two different headers is nonsense Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] ext3: sparse fixesBen Dooks
Fix warnings from sparse due to un-declared functions that should either have a header file or have been declared static fs/ext2/bitmap.c:14:15: warning: symbol 'ext2_count_free' was not declared. Should it be static? fs/ext2/namei.c:92:15: warning: symbol 'ext2_get_parent' was not declared. Should it be static? fs/ext3/bitmap.c:15:15: warning: symbol 'ext3_count_free' was not declared. Should it be static? fs/ext3/namei.c:1013:15: warning: symbol 'ext3_get_parent' was not declared. Should it be static? fs/ext3/xattr.c:214:1: warning: symbol 'ext3_xattr_block_get' was not declared. Should it be static? fs/ext3/xattr.c:358:1: warning: symbol 'ext3_xattr_block_list' was not declared. Should it be static? fs/ext3/xattr.c:630:1: warning: symbol 'ext3_xattr_block_find' was not declared. Should it be static? fs/ext3/xattr.c:863:1: warning: symbol 'ext3_xattr_ibody_find' was not declared. Should it be static? Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
