path: root/fs/ext3/dir.c
2011-01-10ext3: speed up file creates by optimizing rec_len functionsEric Sandeen
The addition of 64k block capability in the rec_len_from_disk and rec_len_to_disk functions added a bit of math overhead which slows down file create workloads needlessly when the architecture cannot even support 64k blocks, thanks to page size limits. Similar changes already exist in the ext4 codebase. The directory entry checking can also be optimized a bit by sprinkling in some unlikely() conditions to move the error handling out of line. bonnie++ sequential file creates on a 512MB ramdisk speeds up from about 77,000/s to about 82,000/s, about a 6% improvement. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: Jan Kara <jack@suse.cz>
2010-05-27ext3 uses rb_node = NULL; to zero rb_root.Venkatesh Pallipadi
The problem with this is that 17d9ddc72fb8bba0d4f678 ("rbtree: Add support for augmented rbtrees") in the linux-next tree adds a new field to that struct which needs to be NULLas well. This patch uses RB_ROOT as the intializer so all of the relevant fields will be NULL'd. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Cc: Eric Paris <eparis@redhat.com> Cc: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jan Kara <jack@suse.cz>
2009-07-15ext3: Get rid of extenddisksize parameter of ext3_get_blocks_handle()Jan Kara
Get rid of extenddisksize parameter of ext3_get_blocks_handle(). This seems to be a relict from some old days and setting disksize in this function does not make much sence. Currently it was set only by ext3_getblk(). Since the parameter has some effect only if create == 1, it is easy to check that the three callers which end up calling ext3_getblk() with create == 1 (ext3_append, ext3_quota_write, ext3_mkdir) do the right thing and set disksize themselves. Signed-off-by: Jan Kara <jack@suse.cz>
2009-04-02ext3: remove the BKL in ext3/ioctl.cCyrus Massoumi
Reformat ext3/ioctl.c to make it look more like ext4/ioctl.c and remove the BKL around ext3_ioctl(). Signed-off-by: Cyrus Massoumi <cyrusm@gmx.net> Cc: <linux-ext4@vger.kernel.org> Acked-by: Jan Kara <jack@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-25ext3: Fix duplicate entries returned from getdents() system callTheodore Ts'o
Fix a regression caused by commit 6a897cf4, "ext3: fix ext3_dx_readdir hash collision handling", where deleting files in a large directory (requiring more than one getdents system call), results in some filenames being returned twice. This was caused by a failure to update info->curr_hash and info->curr_minor_hash, so that if the directory had gotten modified since the last getdents() system call (as would be the case if the user is running "rm -r" or "git clean"), a directory entry would get returned twice to the userspace. This patch fixes the bug reported by Markus Trippelsdorf at: http://bugzilla.kernel.org/show_bug.cgi?id=11844 Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Tested-by: Markus Trippelsdorf <markus@trippelsdorf.de>
2008-10-20ext3: avoid printk floods in the face of directory corruptionEric Sandeen
A very large directory with many read failures (either due to storage problems, or due to invalid size & blocks from corruption) will generate a printk storm as the filesystem continues to try to read all the blocks. This flood of messages can tie up the box until it is complete - which may be a very long time, especially for very large corrupted values. This is fixed by only reporting the corruption once each time we try to read the directory. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: Eugene Teo <eugeneteo@kernel.sg> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20ext3: fix ext3_dx_readdir hash collision handlingEugene Dashevsky
This fixes a bug where readdir() would return a directory entry twice if there was a hash collision in an hash tree indexed directory. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Eugene Dashevsky <eugene@ibrix.com> Signed-off-by: Mike Snitzer <msnitzer@ibrix.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25ext3: improve some code in rb tree part of dir.cShen Feng
- remove unnecessary code in free_rb_tree_fname - rename free_rb_tree_fname to ext3_htree_create_dir_info since it and ext3_htree_free_dir_info are a pair - replace kmalloc with kzalloc in ext3_htree_free_dir_info Signed-off-by: Shen Feng <shen@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-14Fix 64KB blocksize in ext3 directoriesJan Kara
With 64KB blocksize, a directory entry can have size 64KB which does not fit into 16 bits we have for entry lenght. So we store 0xffff instead and convert value when read from / written to disk. The patch also converts some places to use ext3_next_entry() when we are changing them anyway. [akpm@linux-foundation.org: coding-style cleanups] Signed-off-by: Jan Kara <jack@suse.cz> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17ext3: remove #ifdef CONFIG_EXT3_INDEXEric Sandeen
CONFIG_EXT3_INDEX is not an exposed config option in the kernel, and it is unconditionally defined in ext3_fs.h. tune2fs is already able to turn off dir indexing, so at this point it's just cluttering up the code. Remove it. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17Fix f_version type: should be u64 instead of unsigned longMathieu Desnoyers
Fix f_version type: should be u64 instead of long There is a type inconsistency between struct inode i_version and struct file f_version. fs.h: struct inode u64 i_version; and struct file unsigned long f_version; Users do: fs/ext3/dir.c: if (filp->f_version != inode->i_version) { So why isn't f_version a u64 ? It becomes a problem if versions gets higher than 2^32 and we are on an architecture where longs are 32 bits. This patch changes the f_version type to u64, and updates the users accordingly. It applies to 2.6.23-rc2-mm2. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Martin Bligh <mbligh@google.com> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Cc: Al Viro <viro@ftp.linux.org.uk> Cc: <linux-ext4@vger.kernel.org> Cc: Mark Fasheh <mark.fasheh@oracle.com> Cc: Christoph Hellwig <hch@lst.de> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16readahead: combine file_ra_state.prev_index/prev_offset into prev_posFengguang Wu
Combine the file_ra_state members unsigned long prev_index unsigned int prev_offset into loff_t prev_pos It is more consistent and better supports huge files. Thanks to Peter for the nice proposal! [akpm@linux-foundation.org: fix shift overflow] Cc: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Fengguang Wu <wfg@mail.ustc.edu.cn> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19readahead: split ondemand readahead interface into two functionsRusty Russell
Split ondemand readahead interface into two functions. I think this makes it a little clearer for non-readahead experts (like Rusty). Internally they both call ondemand_readahead(), but the page argument is changed to an obvious boolean flag. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Fengguang Wu <wfg@mail.ustc.edu.cn> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19readahead: convert ext3/ext4 invocationsFengguang Wu
Convert ext3/ext4 dir reads to use on-demand readahead. Readahead for dirs operates _not_ on file level, but on blockdev level. This makes a difference when the data blocks are not continuous. And the read routine is somehow opaque: there's no handy info about the status of current page. So a simplified call scheme is employed: to call into readahead whenever the current page falls out of readahead windows. Signed-off-by: Fengguang Wu <wfg@mail.ustc.edu.cn> Cc: Steven Pratt <slpratt@austin.ibm.com> Cc: Ram Pai <linuxram@us.ibm.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-08[PATCH] ext3: change uses of f_{dentry, vfsmnt} to use f_pathJosef "Jeff" Sipek
Change all the uses of f_{dentry,vfsmnt} to f_path.{dentry,mnt} in the ext3 filesystem. Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] handle ext3 directory corruption betterEric Sandeen
I've been using Steve Grubb's purely evil "fsfuzzer" tool, at http://people.redhat.com/sgrubb/files/fsfuzzer-0.4.tar.gz Basically it makes a filesystem, splats some random bits over it, then tries to mount it and do some simple filesystem actions. At best, the filesystem catches the corruption gracefully. At worst, things spin out of control. As you might guess, we found a couple places in ext3 where things spin out of control :) First, we had a corrupted directory that was never checked for consistency... it was corrupt, and pointed to another bad "entry" of length 0. The for() loop looped forever, since the length of ext3_next_entry(de) was 0, and we kept looking at the same pointer over and over and over and over... I modeled this check and subsequent action on what is done for other directory types in ext3_readdir... (adding this check adds some computational expense; I am testing a followup patch to reduce the number of times we check and re-check these directory entries, in all cases. Thanks for the idea, Andreas). Next we had a root directory inode which had a corrupted size, claimed to be > 200M on a 4M filesystem. There was only really 1 block in the directory, but because the size was so large, readdir kept coming back for more, spewing thousands of printk's along the way. Per Andreas' suggestion, if we're in this read error condition and we're trying to read an offset which is greater than i_blocks worth of bytes, stop trying, and break out of the loop. With these two changes fsfuzz test survives quite well on ext3. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-30[PATCH] BLOCK: Move the Ext3 device ioctl compat stuff to the Ext3 driver ↵David Howells
[try #6] Move the Ext3 device ioctl compat stuff from fs/compat_ioctl.c to the Ext3 driver so that the Ext3 header file doesn't need to be included. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2006-09-27[PATCH] fs: Conversions from kmalloc+memset to k(z|c)allocPanagiotis Issaris
Conversions from kmalloc+memset to kzalloc. Signed-off-by: Panagiotis Issaris <takis@issaris.org> Jffs2-bit-acked-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] ext3: More whitespace cleanupsDave Kleikamp
More white space cleanups in preparation of cloning ext4 from ext3. Removing spaces that precede a tab. Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] ext3 and jbd cleanup: remove whitespaceMingming Cao
Remove whitespace from ext3 and jbd, before we clone ext4. Signed-off-by: Mingming Cao<cmm@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-21[RBTREE] Update ext3 to use rb_parent() accessor macro.David Woodhouse
2006-03-28[PATCH] Make most file operations structs in fs/ constArjan van de Ven
This is a conversion to make the various file_operations structs in fs/ const. Basically a regexp job, with a few manual fixups The goal is both to increase correctness (harder to accidentally write to shared datastructures) and reducing the false sharing of cachelines with things that get dirty in .data (while .rodata is nicely read only and thus cache clean) Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] ext3_get_blocks: Mapping multiple blocks at a onceMingming Cao
Currently ext3_get_block() only maps or allocates one block at a time. This is quite inefficient for sequential IO workload. I have posted a early implements a simply multiple block map and allocation with current ext3. The basic idea is allocating the 1st block in the existing way, and attempting to allocate the next adjacent blocks on a best effort basis. More description about the implementation could be found here: http://marc.theaimsgroup.com/?l=ext2-devel&m=112162230003522&w=2 The following the latest version of the patch: break the original patch into 5 patches, re-worked some logicals, and fixed some bugs. The break ups are: [patch 1] Adding map multiple blocks at a time in ext3_get_blocks() [patch 2] Extend ext3_get_blocks() to support multiple block allocation [patch 3] Implement multiple block allocation in ext3-try-to-allocate (called via ext3_new_block()). [patch 4] Proper accounting updates in ext3_new_blocks() [patch 5] Adjust reservation window size properly (by the given number of blocks to allocate) before block allocation to increase the possibility of allocating multiple blocks in a single call. Tests done so far includes fsx,tiobench and dbench. The following numbers collected from Direct IO tests (1G file creation/read) shows the system time have been greatly reduced (more than 50% on my 8 cpu system) with the patches. 1G file DIO write: 2.6.15 2.6.15+patches real 0m31.275s 0m31.161s user 0m0.000s 0m0.000s sys 0m3.384s 0m0.564s 1G file DIO read: 2.6.15 2.6.15+patches real 0m30.733s 0m30.624s user 0m0.000s 0m0.004s sys 0m0.748s 0m0.380s Some previous test we did on buffered IO with using multiple blocks allocation and delayed allocation shows noticeable improvement on throughput and system time. This patch: Add support of mapping multiple blocks in one call. This is useful for DIO reads and re-writes (where blocks are already allocated), also is in line with Christoph's proposal of using getblocks() in mpage_readpage() or mpage_readpages(). Signed-off-by: Mingming Cao <cmm@us.ibm.com> Cc: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] ext3_readdir: use generic readaheadAndrew Morton
Linus points out that ext3_readdir's readahead only cuts in when ext3_readdir() is operating at the very start of the directory. So for large directories we end up performing no readahead at all and we suck. So take it all out and use the core VM's page_cache_readahead(). This means that ext3 directory reads will use all of readahead's dynamic sizing goop. Note that we're using the directory's filp->f_ra to hold the readahead state, but readahead is actually being performed against the underlying blockdev's address_space. Fortunately the readahead code is all set up to handle this. Tested with printk. It works. I was struggling to find a real workload which actually cared. (The patch also exports page_cache_readahead() to GPL modules) Cc: "Stephen C. Tweedie" <sct@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
