path: root/fs/ext4/balloc.c
2014-10-13ext4: move error report out of atomic context in ext4_init_block_bitmap()Dmitry Monakhov
Error report likely result in IO so it is bad idea to do it from atomic context. This patch should fix following issue: BUG: sleeping function called from invalid context at include/linux/buffer_head.h:349 in_atomic(): 1, irqs_disabled(): 0, pid: 137, name: kworker/u128:1 5 locks held by kworker/u128:1/137: #0: ("writeback"){......}, at: [<ffffffff81085618>] process_one_work+0x228/0x4d0 #1: ((&(&wb->dwork)->work)){......}, at: [<ffffffff81085618>] process_one_work+0x228/0x4d0 #2: (jbd2_handle){......}, at: [<ffffffff81242622>] start_this_handle+0x712/0x7b0 #3: (&ei->i_data_sem){......}, at: [<ffffffff811fa387>] ext4_map_blocks+0x297/0x430 #4: (&(&bgl->locks[i].lock)->rlock){......}, at: [<ffffffff811f3180>] ext4_read_block_bitmap_nowait+0x5d0/0x630 CPU: 3 PID: 137 Comm: kworker/u128:1 Not tainted 3.17.0-rc2-00184-g82752e4 #165 Hardware name: Intel Corporation W2600CR/W2600CR, BIOS SE5C600.86B.99.99.x028.061320111235 06/13/2011 Workqueue: writeback bdi_writeback_workfn (flush-1:0) 0000000000000411 ffff880813777288 ffffffff815c7fdc ffff880813777288 ffff880813a8bba0 ffff8808137772a8 ffffffff8108fb30 ffff880803e01e38 ffff880803e01e38 ffff8808137772c8 ffffffff811a8d53 ffff88080ecc6000 Call Trace: [<ffffffff815c7fdc>] dump_stack+0x51/0x6d [<ffffffff8108fb30>] __might_sleep+0xf0/0x100 [<ffffffff811a8d53>] __sync_dirty_buffer+0x43/0xe0 [<ffffffff811a8e03>] sync_dirty_buffer+0x13/0x20 [<ffffffff8120f581>] ext4_commit_super+0x1d1/0x230 [<ffffffff8120fa03>] save_error_info+0x23/0x30 [<ffffffff8120fd06>] __ext4_error+0xb6/0xd0 [<ffffffff8120f260>] ? ext4_group_desc_csum+0x140/0x190 [<ffffffff811f2d8c>] ext4_read_block_bitmap_nowait+0x1dc/0x630 [<ffffffff8122e23a>] ext4_mb_init_cache+0x21a/0x8f0 [<ffffffff8113ae95>] ? lru_cache_add+0x55/0x60 [<ffffffff8112e16c>] ? add_to_page_cache_lru+0x6c/0x80 [<ffffffff8122eaa0>] ext4_mb_init_group+0x190/0x280 [<ffffffff8122ec51>] ext4_mb_good_group+0xc1/0x190 [<ffffffff8123309a>] ext4_mb_regular_allocator+0x17a/0x410 [<ffffffff8122c821>] ? ext4_mb_use_preallocated+0x31/0x380 [<ffffffff81233535>] ? ext4_mb_new_blocks+0x205/0x8e0 [<ffffffff8116ed5c>] ? kmem_cache_alloc+0xfc/0x180 [<ffffffff812335b0>] ext4_mb_new_blocks+0x280/0x8e0 [<ffffffff8116f2c4>] ? __kmalloc+0x144/0x1c0 [<ffffffff81221797>] ? ext4_find_extent+0x97/0x320 [<ffffffff812257f4>] ext4_ext_map_blocks+0xbc4/0x1050 [<ffffffff811fa387>] ? ext4_map_blocks+0x297/0x430 [<ffffffff811fa3ab>] ext4_map_blocks+0x2bb/0x430 [<ffffffff81200e43>] ? ext4_init_io_end+0x23/0x50 [<ffffffff811feb44>] ext4_writepages+0x564/0xaf0 [<ffffffff815cde3b>] ? _raw_spin_unlock+0x2b/0x40 [<ffffffff810ac7bd>] ? lock_release_non_nested+0x2fd/0x3c0 [<ffffffff811a009e>] ? writeback_sb_inodes+0x10e/0x490 [<ffffffff811a009e>] ? writeback_sb_inodes+0x10e/0x490 [<ffffffff811377e3>] do_writepages+0x23/0x40 [<ffffffff8119c8ce>] __writeback_single_inode+0x9e/0x280 [<ffffffff811a026b>] writeback_sb_inodes+0x2db/0x490 [<ffffffff811a0664>] wb_writeback+0x174/0x2d0 [<ffffffff810ac359>] ? lock_release_holdtime+0x29/0x190 [<ffffffff811a0863>] wb_do_writeback+0xa3/0x200 [<ffffffff811a0a40>] bdi_writeback_workfn+0x80/0x230 [<ffffffff81085618>] ? process_one_work+0x228/0x4d0 [<ffffffff810856cd>] process_one_work+0x2dd/0x4d0 [<ffffffff81085618>] ? process_one_work+0x228/0x4d0 [<ffffffff81085c1d>] worker_thread+0x35d/0x460 [<ffffffff810858c0>] ? process_one_work+0x4d0/0x4d0 [<ffffffff810858c0>] ? process_one_work+0x4d0/0x4d0 [<ffffffff8108a885>] kthread+0xf5/0x100 [<ffffffff810990e5>] ? local_clock+0x25/0x30 [<ffffffff8108a790>] ? __init_kthread_worker+0x70/0x70 [<ffffffff815ce2ac>] ret_from_fork+0x7c/0xb0 [<ffffffff8108a790>] ? __init_kthread_work Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org> Signed-off-by: Theodore Ts'o <tytso@mit.edu> Cc: stable@vger.kernel.org
2014-09-04ext4: prepare to drop EXT4_STATE_DELALLOC_RESERVEDTheodore Ts'o
The EXT4_STATE_DELALLOC_RESERVED flag was originally implemented because it was too hard to make sure the mballoc and get_block flags could be reliably passed down through all of the codepaths that end up calling ext4_mb_new_blocks(). Since then, we have mb_flags passed down through most of the code paths, so getting rid of EXT4_STATE_DELALLOC_RESERVED isn't as tricky as it used to. This commit plumbs in the last of what is required, and then adds a WARN_ON check to make sure we haven't missed anything. If this passes a full regression test run, we can then drop EXT4_STATE_DELALLOC_RESERVED. Signed-off-by: Theodore Ts'o <tytso@mit.edu> Reviewed-by: Jan Kara <jack@suse.cz>
2014-07-15ext4: remove metadata reservation checksTheodore Ts'o
Commit 27dd43854227b ("ext4: introduce reserved space") reserves 2% of the file system space to make sure metadata allocations will always succeed. Given that, tracking the reservation of metadata blocks is no longer necessary. Signed-off-by: Theodore Ts'o <tytso@mit.edu>
2014-06-26ext4: decrement free clusters/inodes counters when block group declared badNamjae Jeon
We should decrement free clusters counter when block bitmap is marked as corrupt and free inodes counter when the allocation bitmap is marked as corrupt to avoid misunderstanding due to incorrect available size in statfs result. User can get immediately ENOSPC error from write begin without reaching for the writepages. Cc: Darrick J. Wong<darrick.wong@oracle.com> Reported-by: Amit Sahrawat <amit.sahrawat83@gmail.com> Signed-off-by: Namjae Jeon <namjae.jeon@samsung.com> Signed-off-by: Ashish Sangwan <a.sangwan@samsung.com>
2014-05-12ext4: make local functions staticStephen Hemminger
I have been running make namespacecheck to look for unneeded globals, and found these in ext4. Signed-off-by: Stephen Hemminger <stephen@networkplumber.org> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2014-05-12ext4: fix block bitmap validation when bigalloc, ^flex_bgDarrick J. Wong
On a bigalloc,^flex_bg filesystem, the ext4_valid_block_bitmap function fails to convert from blocks to clusters when spot-checking the validity of the bitmap block that we've just read from disk. This causes ext4 to think that the bitmap is garbage, which results in the block group being taken offline when it's not necessary. Add in the necessary EXT4_B2C() calls to perform the conversions. Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2014-05-12ext4: fix block bitmap initialization under sparse_super2Darrick J. Wong
The ext4_bg_has_super() function doesn't know about the new rules for where backup superblocks go on a sparse_super2 filesystem. Therefore, block bitmap initialization doesn't know that it shouldn't reserve space for backups in groups that are never going to contain backups. The result of this is e2fsck complaining about the block bitmap being incorrect (fortunately not in a way that results in cross-linked files), so fix the whole thing. Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2014-04-14ext4: fix ext4_count_free_clusters() with EXT4FS_DEBUG and bigalloc enabledAzat Khuzhin
With bigalloc enabled we must use EXT4_CLUSTERS_PER_GROUP() instead of EXT4_BLOCKS_PER_GROUP() otherwise we will go beyond the allocated buffer. $ mount -t ext4 /dev/vde /vde [ 70.573993] EXT4-fs DEBUG (fs/ext4/mballoc.c, 2346): ext4_mb_alloc_groupinfo: [ 70.575174] allocated s_groupinfo array for 1 meta_bg's [ 70.576172] EXT4-fs DEBUG (fs/ext4/super.c, 2092): ext4_check_descriptors: [ 70.576972] Checking group descriptorsBUG: unable to handle kernel paging request at ffff88006ab56000 [ 72.463686] IP: [<ffffffff81394eb9>] __bitmap_weight+0x2a/0x7f [ 72.464168] PGD 295e067 PUD 2961067 PMD 7fa8e067 PTE 800000006ab56060 [ 72.464738] Oops: 0000 [#1] SMP DEBUG_PAGEALLOC [ 72.465139] Modules linked in: [ 72.465402] CPU: 1 PID: 3560 Comm: mount Tainted: G W 3.14.0-rc2-00069-ge57bce1 #60 [ 72.466079] Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011 [ 72.466505] task: ffff88007ce6c8a0 ti: ffff88006b7f0000 task.ti: ffff88006b7f0000 [ 72.466505] RIP: 0010:[<ffffffff81394eb9>] [<ffffffff81394eb9>] __bitmap_weight+0x2a/0x7f [ 72.466505] RSP: 0018:ffff88006b7f1c00 EFLAGS: 00010206 [ 72.466505] RAX: 0000000000000000 RBX: 000000000000050a RCX: 0000000000000040 [ 72.466505] RDX: 0000000000000000 RSI: 0000000000080000 RDI: 0000000000000000 [ 72.466505] RBP: ffff88006b7f1c28 R08: 0000000000000002 R09: 0000000000000000 [ 72.466505] R10: 000000000000babe R11: 0000000000000400 R12: 0000000000080000 [ 72.466505] R13: 0000000000000200 R14: 0000000000002000 R15: ffff88006ab55000 [ 72.466505] FS: 00007f43ba1fa840(0000) GS:ffff88007f800000(0000) knlGS:0000000000000000 [ 72.466505] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b [ 72.466505] CR2: ffff88006ab56000 CR3: 000000006b7e6000 CR4: 00000000000006e0 [ 72.466505] Stack: [ 72.466505] ffff88006ab65000 0000000000000000 0000000000000000 0000000000010000 [ 72.466505] ffff88006ab6f400 ffff88006b7f1c58 ffffffff81396bb8 0000000000010000 [ 72.466505] 0000000000000000 ffff88007b869a90 ffff88006a48a000 ffff88006b7f1c70 [ 72.466505] Call Trace: [ 72.466505] [<ffffffff81396bb8>] memweight+0x5f/0x8a [ 72.466505] [<ffffffff811c3b19>] ext4_count_free+0x13/0x21 [ 72.466505] [<ffffffff811c396c>] ext4_count_free_clusters+0xdb/0x171 [ 72.466505] [<ffffffff811e3bdd>] ext4_fill_super+0x117c/0x28ef [ 72.466505] [<ffffffff81391569>] ? vsnprintf+0x1c7/0x3f7 [ 72.466505] [<ffffffff8114d8dc>] mount_bdev+0x145/0x19c [ 72.466505] [<ffffffff811e2a61>] ? ext4_calculate_overhead+0x2a1/0x2a1 [ 72.466505] [<ffffffff811dab1d>] ext4_mount+0x15/0x17 [ 72.466505] [<ffffffff8114e3aa>] mount_fs+0x67/0x150 [ 72.466505] [<ffffffff811637ea>] vfs_kern_mount+0x64/0xde [ 72.466505] [<ffffffff81165d19>] do_mount+0x6fe/0x7f5 [ 72.466505] [<ffffffff81126cc8>] ? strndup_user+0x3a/0xd9 [ 72.466505] [<ffffffff8116604b>] SyS_mount+0x85/0xbe [ 72.466505] [<ffffffff81619e90>] tracesys+0xdd/0xe2 [ 72.466505] Code: c3 89 f0 b9 40 00 00 00 55 99 48 89 e5 41 57 f7 f9 41 56 49 89 ff 41 55 45 31 ed 41 54 41 89 f4 53 31 db 41 89 c6 45 39 ee 7e 10 <4b> 8b 3c ef 49 ff c5 e8 bf ff ff ff 01 c3 eb eb 31 c0 45 85 f6 [ 72.466505] RIP [<ffffffff81394eb9>] __bitmap_weight+0x2a/0x7f [ 72.466505] RSP <ffff88006b7f1c00> [ 72.466505] CR2: ffff88006ab56000 [ 72.466505] ---[ end trace 7d051a08ae138573 ]--- Killed Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2013-10-31ext4: don't count free clusters from a corrupt block groupDarrick J. Wong
A bg that's been flagged "corrupt" by definition has no free blocks, so that the allocator won't be tempted to use the damaged bg. Therefore, we shouldn't count the clusters in the damaged group when calculating free counts. Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Reviewed-by: Zheng Liu <wenqing.lz@taobao.com>
2013-08-28ext4: mark group corrupt on group descriptor checksumDarrick J. Wong
If the group descriptor fails validation, mark the whole blockgroup corrupt so that the inode/block allocators skip this group. The previous approach takes the risk of writing to a damaged group descriptor; hopefully it was never the case that the [ib]bitmap fields pointed to another valid block and got dirtied, since the memset would fill the page with 1s. Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2013-08-28ext4: mark block group as corrupt on block bitmap errorDarrick J. Wong
When we notice a block-bitmap corruption (because of device failure or something else), we should mark this group as corrupt and prevent further block allocations/deallocations from it. Currently, we end up generating one error message for every block in the bitmap. This potentially could make the system unstable as noticed in some bugs. With this patch, the error will be printed only the first time and mark the entire block group as corrupted. This prevents future access allocations/deallocations from it. Also tested by corrupting the block bitmap and forcefully introducing the mb_free_blocks error: (1) create a largefile (2Gb) $ dd if=/dev/zero of=largefile oflag=direct bs=10485760 count=200 (2) umount filesystem. use dumpe2fs to see which block-bitmaps are in use by largefile and note their block numbers (3) use dd to zero-out the used block bitmaps $ dd if=/dev/zero of=/dev/hdc4 bs=4096 seek=14 count=8 oflag=direct (4) mount the FS and delete the largefile. (5) recreate the largefile. verify that the new largefile does not get any blocks from the groups marked as bad. Without the patch, we will see mb_free_blocks error for each bit in each zero'ed out bitmap at (4). With the patch, we only see the error once per blockgroup: [ 309.706803] EXT4-fs error (device sdb4): ext4_mb_generate_buddy:735: group 15: 32768 clusters in bitmap, 0 in gd. blk grp corrupted. [ 309.720824] EXT4-fs error (device sdb4): ext4_mb_generate_buddy:735: group 14: 32768 clusters in bitmap, 0 in gd. blk grp corrupted. [ 309.732858] EXT4-fs error (device sdb4) in ext4_free_blocks:4802: IO failure [ 309.748321] EXT4-fs error (device sdb4): ext4_mb_generate_buddy:735: group 13: 32768 clusters in bitmap, 0 in gd. blk grp corrupted. [ 309.760331] EXT4-fs error (device sdb4) in ext4_free_blocks:4802: IO failure [ 309.769695] EXT4-fs error (device sdb4): ext4_mb_generate_buddy:735: group 12: 32768 clusters in bitmap, 0 in gd. blk grp corrupted. [ 309.781721] EXT4-fs error (device sdb4) in ext4_free_blocks:4802: IO failure [ 309.798166] EXT4-fs error (device sdb4): ext4_mb_generate_buddy:735: group 11: 32768 clusters in bitmap, 0 in gd. blk grp corrupted. [ 309.810184] EXT4-fs error (device sdb4) in ext4_free_blocks:4802: IO failure [ 309.819532] EXT4-fs error (device sdb4): ext4_mb_generate_buddy:735: group 10: 32768 clusters in bitmap, 0 in gd. blk grp corrupted. Google-Bug-Id: 7258357 [darrick.wong@oracle.com] Further modifications (by Darrick) to make more obvious that this corruption bit applies to blocks only. Set the corruption flag if the block group bitmap verification fails. Original-author: Aditya Kali <adityakali@google.com> Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2013-08-28ext4: fix type declaration of ext4_validate_block_bitmapDarrick J. Wong
The block_group parameter to ext4_validate_block_bitmap is both used as a ext4_group_t inside the function and the same type is passed in by all callers. We might as well use the typedef consistently instead of open-coding the 'unsigned int'. Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2013-08-28ext4: error out if verifying the block bitmap failsDarrick J. Wong
The block bitmap verification code assumes that calling ext4_error() either panics the system or makes the fs readonly. However, this is not always true: when 'errors=continue' is specified, an error is printed but we don't return any indication of error to the caller, which is (probably) the block allocator, which pretends that the crud we read in off the disk is a usable bitmap. Yuck. A block bitmap that fails the check should at least return no bitmap to the caller. The block allocator should be told to go look in a different group, but that's a separate issue. The easiest way to reproduce this is to modify bg_block_bitmap (on a ^flex_bg fs) to point to a block outside the block group; or you can create a metadata_csum filesystem and zero out the block bitmaps. Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2013-07-05ext4: fix ext4_get_group_number()Theodore Ts'o
The function ext4_get_group_number() was introduced as an optimization in commit bd86298e60b8. Unfortunately, this commit incorrectly calculate the group number for file systems with a 1k block size (when s_first_data_block is 1 instead of zero). This could cause the following kernel BUG: [ 568.877799] ------------[ cut here ]------------ [ 568.877833] kernel BUG at fs/ext4/mballoc.c:3728! [ 568.877840] Oops: Exception in kernel mode, sig: 5 [#1] [ 568.877845] SMP NR_CPUS=32 NUMA pSeries [ 568.877852] Modules linked in: binfmt_misc [ 568.877861] CPU: 1 PID: 3516 Comm: fs_mark Not tainted 3.10.0-03216-g7c6809f-dirty #1 [ 568.877867] task: c0000001fb0b8000 ti: c0000001fa954000 task.ti: c0000001fa954000 [ 568.877873] NIP: c0000000002f42a4 LR: c0000000002f4274 CTR: c000000000317ef8 [ 568.877879] REGS: c0000001fa956ed0 TRAP: 0700 Not tainted (3.10.0-03216-g7c6809f-dirty) [ 568.877884] MSR: 8000000000029032 <SF,EE,ME,IR,DR,RI> CR: 24000428 XER: 00000000 [ 568.877902] SOFTE: 1 [ 568.877905] CFAR: c0000000002b5464 [ 568.877908] GPR00: 0000000000000001 c0000001fa957150 c000000000c6a408 c0000001fb588000 GPR04: 0000000000003fff c0000001fa9571c0 c0000001fa9571c4 000138098c50625f GPR08: 1301200000000000 0000000000000002 0000000000000001 0000000000000000 GPR12: 0000000024000422 c00000000f33a300 0000000000008000 c0000001fa9577f0 GPR16: c0000001fb7d0100 c000000000c29190 c0000000007f46e8 c000000000a14672 GPR20: 0000000000000001 0000000000000008 ffffffffffffffff 0000000000000000 GPR24: 0000000000000100 c0000001fa957278 c0000001fdb2bc78 c0000001fa957288 GPR28: 0000000000100100 c0000001fa957288 c0000001fb588000 c0000001fdb2bd10 [ 568.877993] NIP [c0000000002f42a4] .ext4_mb_release_group_pa+0xec/0x1c0 [ 568.877999] LR [c0000000002f4274] .ext4_mb_release_group_pa+0xbc/0x1c0 [ 568.878004] Call Trace: [ 568.878008] [c0000001fa957150] [c0000000002f4274] .ext4_mb_release_group_pa+0xbc/0x1c0 (unreliable) [ 568.878017] [c0000001fa957200] [c0000000002fb070] .ext4_mb_discard_lg_preallocations+0x394/0x444 [ 568.878025] [c0000001fa957340] [c0000000002fb45c] .ext4_mb_release_context+0x33c/0x734 [ 568.878032] [c0000001fa957440] [c0000000002fbcf8] .ext4_mb_new_blocks+0x4a4/0x5f4 [ 568.878039] [c0000001fa957510] [c0000000002ef56c] .ext4_ext_map_blocks+0xc28/0x1178 [ 568.878047] [c0000001fa957640] [c0000000002c1a94] .ext4_map_blocks+0x2c8/0x490 [ 568.878054] [c0000001fa957730] [c0000000002c536c] .ext4_writepages+0x738/0xc60 [ 568.878062] [c0000001fa957950] [c000000000168a78] .do_writepages+0x5c/0x80 [ 568.878069] [c0000001fa9579d0] [c00000000015d1c4] .__filemap_fdatawrite_range+0x88/0xb0 [ 568.878078] [c0000001fa957aa0] [c00000000015d23c] .filemap_write_and_wait_range+0x50/0xfc [ 568.878085] [c0000001fa957b30] [c0000000002b8edc] .ext4_sync_file+0x220/0x3c4 [ 568.878092] [c0000001fa957be0] [c0000000001f849c] .vfs_fsync_range+0x64/0x80 [ 568.878098] [c0000001fa957c70] [c0000000001f84f0] .vfs_fsync+0x38/0x4c [ 568.878105] [c0000001fa957d00] [c0000000001f87f4] .do_fsync+0x54/0x90 [ 568.878111] [c0000001fa957db0] [c0000000001f8894] .SyS_fsync+0x28/0x3c [ 568.878120] [c0000001fa957e30] [c000000000009c88] syscall_exit+0x0/0x7c [ 568.878125] Instruction dump: [ 568.878130] 60000000 813d0034 81610070 38000000 7f8b4800 419e001c 813f007c 7d2bfe70 [ 568.878144] 7d604a78 7c005850 54000ffe 7c0007b4 <0b000000> e8a10076 e87f0090 7fa4eb78 [ 568.878160] ---[ end trace 594d911d9654770b ]--- In addition fix the STD_GROUP optimization so that it works for bigalloc file systems as well. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Reported-by: Li Zhong <lizhongfs@gmail.com> Reviewed-by: Lukas Czerner <lczerner@redhat.com> Cc: stable@vger.kernel.org # 3.10
2013-06-06ext4: optimize test_root()Theodore Ts'o
The test_root() function could potentially loop forever due to overflow issues. So rewrite test_root() to avoid this issue; as a bonus, it is 38% faster when benchmarked via a test loop: int main(int argc, char **argv) { int i; for (i = 0; i < 1 << 24; i++) { if (test_root(i, 7)) printf("%d\n", i); } } Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2013-04-20ext4: mark all metadata I/O with REQ_METATheodore Ts'o
As Dave Chinner pointed out at the 2013 LSF/MM workshop, it's important that metadata I/O requests are marked as such to avoid priority inversions caused by I/O bandwidth throttling. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2013-04-09ext4: introduce reserved spaceLukas Czerner
Currently in ENOSPC condition when writing into unwritten space, or punching a hole, we might need to split the extent and grow extent tree. However since we can not allocate any new metadata blocks we'll have to zero out unwritten part of extent or punched out part of extent, or in the worst case return ENOSPC even though use actually does not allocate any space. Also in delalloc path we do reserve metadata and data blocks for the time we're going to write out, however metadata block reservation is very tricky especially since we expect that logical connectivity implies physical connectivity, however that might not be the case and hence we might end up allocating more metadata blocks than previously reserved. So in future, metadata reservation checks should be removed since we can not assure that we do not under reserve. And this is where reserved space comes into the picture. When mounting the file system we slice off a little bit of the file system space (2% or 4096 clusters, whichever is smaller) which can be then used for the cases mentioned above to prevent costly zeroout, or unexpected ENOSPC. The number of reserved clusters can be set via sysfs, however it can never be bigger than number of free clusters in the file system. Note that this patch fixes the failure of xfstest 274 as expected. Signed-off-by: Lukas Czerner <lczerner@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Reviewed-by: Carlos Maiolino <cmaiolino@redhat.com>
2013-04-03ext4: introduce ext4_get_group_number()Lukas Czerner
Currently on many places in ext4 we're using ext4_get_group_no_and_offset() even though we're only interested in knowing the block group of the particular block, not the offset within the block group so we can use more efficient way to compute block group. This patch introduces ext4_get_group_number() which computes block group for a given block much more efficiently. Use this function instead of ext4_get_group_no_and_offset() everywhere where we're only interested in knowing the block group. Signed-off-by: Lukas Czerner <lczerner@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2013-04-03ext4: make ext4_block_in_group() much more efficientLukas Czerner
Currently in when getting the block group number for a particular block in ext4_block_in_group() we're using ext4_get_group_no_and_offset() which uses do_div() to get the block group and the remainer which is offset within the group. We don't need all of that in ext4_block_in_group() as we only need to figure out the group number. This commit changes ext4_block_in_group() to calculate group number directly. This shows as a big improvement with regards to cpu utilization. Measuring fallocate -l 15T on fresh file system with perf showed that 23% of cpu time was spend in the ext4_get_group_no_and_offset(). With this change it completely disappears from the list only bumping the occurrence of ext4_init_block_bitmap() which is the biggest user of ext4_block_in_group() by 4%. As the result of this change on my system the fallocate call was approx. 10% faster. However since there is '-g' option in mkfs which allow us setting different groups size (mostly for developers) I've introduced new per file system flag whether we have a standard block group size or not. The flag is used to determine whether we can use the bit shift optimization or not. Signed-off-by: Lukas Czerner <lczerner@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2013-03-02ext4: convert number of blocks to clusters properlyLukas Czerner
We're using macro EXT4_B2C() to convert number of blocks to number of clusters for bigalloc file systems. However, we should be using EXT4_NUM_B2C(). Signed-off-by: Lukas Czerner <lczerner@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: stable@vger.kernel.org
2013-02-22ext4: fix free clusters calculation in bigalloc filesystemLukas Czerner
ext4_has_free_clusters() should tell us whether there is enough free clusters to allocate, however number of free clusters in the file system is converted to blocks using EXT4_C2B() which is not only wrong use of the macro (we should have used EXT4_NUM_B2C) but it's also completely wrong concept since everything else is in cluster units. Moreover when calculating number of root clusters we should be using macro EXT4_NUM_B2C() instead of EXT4_B2C() otherwise the result might be off by one. However r_blocks_count should always be a multiple of the cluster ratio so doing a plain bit shift should be enough here. We avoid using EXT4_B2C() because it's confusing. As a result of the first problem number of free clusters is much bigger than it should have been and ext4_has_free_clusters() would return 1 even if there is really not enough free clusters available. Fix this by removing the EXT4_C2B() conversion of free clusters and using bit shift when calculating number of root clusters. This bug affects number of xfstests tests covering file system ENOSPC situation handling. With this patch most of the ENOSPC problems with bigalloc file system disappear, especially the errors caused by delayed allocation not having enough space when the actual allocation is finally requested. Signed-off-by: Lukas Czerner <lczerner@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: stable@vger.kernel.org
2013-01-12ext4: check bh in ext4_read_block_bitmap()Eryu Guan
Validate the bh pointer before using it, since ext4_read_block_bitmap_nowait() might return NULL. I've seen this in fsfuzz testing. EXT4-fs error (device loop0): ext4_read_block_bitmap_nowait:385: comm touch: Cannot get buffer for block bitmap - block_group = 0, block_bitmap = 3925999616 BUG: unable to handle kernel NULL pointer dereference at (null) IP: [<ffffffff8121de25>] ext4_wait_block_bitmap+0x25/0xe0 ... Call Trace: [<ffffffff8121e1e5>] ext4_read_block_bitmap+0x35/0x60 [<ffffffff8125e9c6>] ext4_free_blocks+0x236/0xb80 [<ffffffff811d0d36>] ? __getblk+0x36/0x70 [<ffffffff811d0a5f>] ? __find_get_block+0x8f/0x210 [<ffffffff81191ef3>] ? kmem_cache_free+0x33/0x140 [<ffffffff812678e5>] ext4_xattr_release_block+0x1b5/0x1d0 [<ffffffff812679be>] ext4_xattr_delete_inode+0xbe/0x100 [<ffffffff81222a7c>] ext4_free_inode+0x7c/0x4d0 [<ffffffff812277b8>] ? ext4_mark_inode_dirty+0x88/0x230 [<ffffffff8122993c>] ext4_evict_inode+0x32c/0x490 [<ffffffff811b8cd7>] evict+0xa7/0x1c0 [<ffffffff811b8ed3>] iput_final+0xe3/0x170 [<ffffffff811b8f9e>] iput+0x3e/0x50 [<ffffffff812316fd>] ext4_add_nondir+0x4d/0x90 [<ffffffff81231d0b>] ext4_create+0xeb/0x170 [<ffffffff811aae9c>] vfs_create+0xac/0xd0 [<ffffffff811ac845>] lookup_open+0x185/0x1c0 [<ffffffff8129e3b9>] ? selinux_inode_permission+0xa9/0x170 [<ffffffff811acb54>] do_last+0x2d4/0x7a0 [<ffffffff811af743>] path_openat+0xb3/0x480 [<ffffffff8116a8a1>] ? handle_mm_fault+0x251/0x3b0 [<ffffffff811afc49>] do_filp_open+0x49/0xa0 [<ffffffff811bbaad>] ? __alloc_fd+0xdd/0x150 [<ffffffff8119da28>] do_sys_open+0x108/0x1f0 [<ffffffff8119db51>] sys_open+0x21/0x30 [<ffffffff81618959>] system_call_fastpath+0x16/0x1b Also fix comment for ext4_read_block_bitmap_nowait() Signed-off-by: Eryu Guan <guaneryu@gmail.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: stable@vger.kernel.org
2012-10-22ext4: Checksum the block bitmap properly with bigalloc enabledTao Ma
In mke2fs, we only checksum the whole bitmap block and it is right. While in the kernel, we use EXT4_BLOCKS_PER_GROUP to indicate the size of the checksumed bitmap which is wrong when we enable bigalloc. The right size should be EXT4_CLUSTERS_PER_GROUP and this patch fixes it. Also as every caller of ext4_block_bitmap_csum_set and ext4_block_bitmap_csum_verify pass in EXT4_BLOCKS_PER_GROUP(sb)/8, we'd better removes this parameter and sets it in the function itself. Signed-off-by: Tao Ma <boyu.mt@taobao.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Reviewed-by: Lukas Czerner <lczerner@redhat.com> Cc: stable@vger.kernel.org
2012-08-17ext4: don't call ext4_error while block group is lockedTheodore Ts'o
While in ext4_validate_block_bitmap(), if an block allocation bitmap is found to be invalid, we call ext4_error() while the block group is still locked. This causes ext4_commit_super() to call a function which might sleep while in an atomic context. There's no need to keep the block group locked at this point, so hoist the ext4_error() call up to ext4_validate_block_bitmap() and release the block group spinlock before calling ext4_error(). The reported stack trace can be found at: http://article.gmane.org/gmane.comp.file-systems.ext4/33731 Reported-by: Dave Jones <davej@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: stable@vger.kernel.org
2012-06-30ext4: pass a char * to ext4_count_free() instead of a buffer_head ptrTheodore Ts'o
Make it possible for ext4_count_free to operate on buffers and not just data in buffer_heads. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: stable@kernel.org
2012-06-07ext4: fix the free blocks calculation for ext3 file systems w/ uninit_bgTheodore Ts'o
Ext3 filesystems that are converted to use as many ext4 file system features as possible will enable uninit_bg to speed up e2fsck times. These file systems will have a native ext3 layout of inode tables and block allocation bitmaps (as opposed to ext4's flex_bg layout). Unfortunately, in these cases, when first allocating a block in an uninitialized block group, ext4 would incorrectly calculate the number of free blocks in that block group, and then errorneously report that the file system was corrupt: EXT4-fs error (device vdd): ext4_mb_generate_buddy:741: group 30, 32254 clusters in bitmap, 32258 in gd This problem can be reproduced via: mke2fs -q -t ext4 -O ^flex_bg /dev/vdd 5g mount -t ext4 /dev/vdd /mnt fallocate -l 4600m /mnt/test The problem was caused by a bone headed mistake in the check to see if a particular metadata block was part of the block group. Many thanks to Kees Cook for finding and bisecting the buggy commit which introduced this bug (commit fd034a84e1, present since v3.2). Reported-by: Sander Eikelenboom <linux@eikelenboom.it> Reported-by: Kees Cook <keescook@chromium.org> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Tested-by: Kees Cook <keescook@chromium.org> Cc: stable@kernel.org
2012-06-01Merge tag 'ext4_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 Pull Ext4 updates from Theodore Ts'o: "The major new feature added in this update is Darrick J Wong's metadata checksum feature, which adds crc32 checksums to ext4's metadata fields. There is also the usual set of cleanups and bug fixes." * tag 'ext4_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (44 commits) ext4: hole-punch use truncate_pagecache_range jbd2: use kmem_cache_zalloc wrapper instead of flag ext4: remove mb_groups before tearing down the buddy_cache ext4: add ext4_mb_unload_buddy in the error path ext4: don't trash state flags in EXT4_IOC_SETFLAGS ext4: let getattr report the right blocks in delalloc+bigalloc ext4: add missing save_error_info() to ext4_error() ext4: add debugging trigger for ext4_error() ext4: protect group inode free counting with group lock ext4: use consistent ssize_t type in ext4_file_write() ext4: fix format flag in ext4_ext_binsearch_idx() ext4: cleanup in ext4_discard_allocated_blocks() ext4: return ENOMEM when mounts fail due to lack of memory ext4: remove redundundant "(char *) bh->b_data" casts ext4: disallow hard-linked directory in ext4_lookup ext4: fix potential integer overflow in alloc_flex_gd() ext4: remove needs_recovery in ext4_mb_init() ext4: force ro mount if ext4_setup_super() fails ext4: fix potential NULL dereference in ext4_free_inodes_counts() ext4/jbd2: add metadata checksumming to the list of supported features ...
2012-05-15userns: Convert ext4 to user kuid/kgid where appropriateEric W. Biederman
Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-04-29ext4: make block group checksums use metadata_csum algorithmDarrick J. Wong
metadata_csum supersedes uninit_bg. Convert the ROCOMPAT uninit_bg flag check to a helper function that covers both, and make the checksum calculation algorithm use either crc16 or the metadata_csum chosen algorithm depending on which flag is set. Print a warning if we try to mount a filesystem with both feature flags set. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2012-04-29ext4: calculate and verify block bitmap checksumDarrick J. Wong
Compute and verify the checksum of the block bitmap; this checksum is stored in the block group descriptor. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2012-02-20ext4: fix balloc.c printk-format-warningHeiko Carstens
Get rid of this one: fs/ext4/balloc.c: In function 'ext4_wait_block_bitmap': fs/ext4/balloc.c:405:3: warning: format '%llu' expects argument of type 'long long unsigned int', but argument 6 has type 'sector_t' [-Wformat] Happens because sector_t is u64 (unsigned long long) or unsigned long dependent on CONFIG_64BIT. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2012-02-20ext4: fix race when setting bitmap_uptodate flagTheodore Ts'o
In ext4_read_{inode,block}_bitmap() we were setting bitmap_uptodate() before submitting the buffer for read. The is bad, since we check bitmap_uptodate() without locking the buffer, and so if another process is racing with us, it's possible that they will think the bitmap is uptodate even though the read has not completed yet, resulting in inodes and blocks potentially getting allocated more than once if we get really unlucky. Addresses-Google-Bug: 2828254 Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2012-01-04ext4: make more symbols staticEric Sandeen
A couple more functions can reasonably be made static if desired. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-11-21ext4: fix up a undefined error in ext4_free_blocks in debugging codeYongqiang Yang
sbi is not defined, so let ext4_free_blocks use EXT4_SB(sb) instead when EXT4FS_DEBUG is defined. Signed-off-by: Yongqiang Yang <xiaoqiangnk@gmail.com>
2011-09-09ext4: rename ext4_has_free_blocks() to ext4_has_free_clusters()Theodore Ts'o
Rename the function so it is more clear what is going on. Also rename the various variables so it's clearer what's happening. Also fix a missing blocks to cluster conversion when reading the number of reserved blocks for root. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-09-09ext4: rename ext4_claim_free_blocks() to ext4_claim_free_clusters()Theodore Ts'o
This function really claims a number of free clusters, not blocks, so rename it so it's clearer what's going on. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-09-09ext4: rename ext4_free_blocks_after_init() to ext4_free_clusters_after_init()Theodore Ts'o
This function really returns the number of clusters after initializing an uninitalized block bitmap has been initialized. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-09-09ext4: rename ext4_count_free_blocks() to ext4_count_free_clusters()Theodore Ts'o
This function really counts the free clusters reported in the block group descriptors, so rename it to reduce confusion. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-09-09ext4: Rename ext4_free_blks_{count,set}() to refer to clustersTheodore Ts'o
The field bg_free_blocks_count_{lo,high} in the block group descriptor has been repurposed to hold the number of free clusters for bigalloc functions. So rename the functions so it makes it easier to read and audit the block allocation and block freeing code. Note: at this point in bigalloc development we doesn't support online resize, so this also makes it really obvious all of the places we need to fix up to add support for online resize. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-09-09ext4: Fix bigalloc quota accounting and i_blocks valueAditya Kali
With bigalloc changes, the i_blocks value was not correctly set (it was still set to number of blocks being used, but in case of bigalloc, we want i_blocks to represent the number of clusters being used). Since the quota subsystem sets the i_blocks value, this patch fixes the quota accounting and makes sure that the i_blocks value is set correctly. Signed-off-by: Aditya Kali <adityakali@google.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-09-09ext4: convert s_{dirty,free}blocks_counter to s_{dirty,free}clusters_counterTheodore Ts'o
Convert the percpu counters s_dirtyblocks_counter and s_freeblocks_counter in struct ext4_super_info to be s_dirtyclusters_counter and s_freeclusters_counter. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-09-09ext4: convert block group-relative offsets to use clustersTheodore Ts'o
Certain parts of the ext4 code base, primarily in mballoc.c, use a block group number and offset from the beginning of the block group. This offset is invariably used to index into the allocation bitmap, so change the offset to be denominated in units of clusters. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-09-09ext4: bigalloc changes to block bitmap initialization functionsTheodore Ts'o
Add bigalloc support to ext4_init_block_bitmap() and ext4_free_blocks_after_init(). Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-09-09ext4: split out ext4_free_blocks_after_init()Theodore Ts'o
The function ext4_free_blocks_after_init() used to be a #define of ext4_init_block_bitmap(). This actually made it difficult to understand how the function worked, and made it hard make changes to support clusters. So as an initial cleanup, I've separated out the functionality of initializing block bitmap from calculating the number of free blocks in the new block group. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-09-09ext4: factor out block group accounting into functionsTheodore Ts'o
This makes it easier to understand how ext4_init_block_bitmap() works, and it will assist when we split out ext4_free_blocks_after_init() in the next commit. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-06-28ext4: refactor duplicated block placement codeEric Sandeen
I found that ext4_ext_find_goal() and ext4_find_near() share the same code for returning a coloured start block based on i_block_group. We can refactor this into a common function so that they don't diverge in the future. Thanks to adilger for suggesting the new function name. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-05-25ext4: add flag to ext4_has_free_blocksAllison Henderson
This patch adds an allocation request flag to the ext4_has_free_blocks function which enables the use of reserved blocks. This will allow a punch hole to proceed even if the disk is full. Punching a hole may require additional blocks to first split the extents. Because ext4_has_free_blocks is a low level function, the flag needs to be passed down through several functions listed below: ext4_ext_insert_extent ext4_ext_create_new_leaf ext4_ext_grow_indepth ext4_ext_split ext4_ext_new_meta_block ext4_mb_new_blocks ext4_claim_free_blocks ext4_has_free_blocks [ext4 punch hole patch series 1/5 v7] Signed-off-by: Allison Henderson <achender@us.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Reviewed-by: Mingming Cao <cmm@us.ibm.com>
2011-05-09ext4: move ext4_add_groupblocks() to mballoc.cAmir Goldstein
In preparation for the next patch, the function ext4_add_groupblocks() is moved to mballoc.c, where it could use some static functions. Signed-off-by: Amir Goldstein <amir73il@users.sf.net> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-05-01ext4: remove dead code in ext4_has_free_blocks()Shaohua Li
percpu_counter_sum_positive() never returns a negative value. Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
