path: root/fs/ext4/file.c
2008-04-29ext4: move headers out of include/linuxChristoph Hellwig
Move ext4 headers out of include/linux. This is just the trivial move, there's some more thing that could be done later. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2008-04-29Convert ext4 to use unlocked_ioctlAndi Kleen
I checked ext4_ioctl and it looked largely safe to not be used without BKL. So convert it over to unlocked_ioctl. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Theodore Ts'o <tytso@mit.edu>
2008-01-28ext4: Convert truncate_mutex to read write semaphore.Aneesh Kumar K.V
We are currently taking the truncate_mutex for every read. This would have performance impact on large CPU configuration. Convert the lock to read write semaphore and take read lock when we are trying to read the file. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
2008-01-28ext4: store maxbytes for bitmapped files and return EFBIG as appropriateEric Sandeen
Calculate & store the max offset for bitmapped files, and catch too-large seeks, truncates, and writes in ext4, shortening or rejecting as appropriate. Signed-off-by: Eric Sandeen <sandeen@redhat.com>
2007-07-17fallocate support in ext4Amit Arora
This patch implements ->fallocate() inode operation in ext4. With this patch users of ext4 file systems will be able to use fallocate() system call for persistent preallocation. Current implementation only supports preallocation for regular files (directories not supported as of date) with extent maps. This patch does not support block-mapped files currently. Only FALLOC_ALLOCATE and FALLOC_RESV_SPACE modes are being supported as of now. Signed-off-by: Amit Arora <aarora@in.ibm.com>
2007-07-10sendfile: remove .sendfile from filesystems that use generic_file_sendfile()Jens Axboe
They can use generic_file_splice_read() instead. Since sys_sendfile() now prefers that, there should be no change in behaviour. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2006-12-08[PATCH] ext4: change uses of f_{dentry, vfsmnt} to use f_pathJosef "Jeff" Sipek
Change all the uses of f_{dentry,vfsmnt} to f_path.{dentry,mnt} in the ext4 filesystem. Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] jbd2: enable building of jbd2 and have ext4 use it rather than jbdMingming Cao
Reworked from a patch by Mingming Cao and Randy Dunlap Signed-off-By: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] ext4: rename ext4 symbols to avoid duplication of ext3 symbolsMingming Cao
Mingming Cao originally did this work, and Shaggy reproduced it using some scripts from her. Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] ext4: initial copy of files from ext3Dave Kleikamp
Start of the ext4 patch series. See Documentation/filesystems/ext4.txt for details. This is a simple copy of the files in fs/ext3 to fs/ext4 and /usr/incude/linux/ext3* to /usr/include/ex4* Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
