Replace the ->check_acl method with a ->get_acl method that simply reads an
ACL from disk after having a cache miss. This means we can replace the ACL
checking boilerplate code with a single implementation in namei.c.
Since Ext4 has its own lseek we need to make sure it handles
SEEK_HOLE/SEEK_DATA. For now just do the same thing that is done in the generic
case, somebody else can come along and make it do fancy things later. Thanks,
Signed-off-by: Josef Bacik <josef@redhat.com>
Trivial conversion. Fixup one error handling case calling vmtruncate()
and remove ->truncate callback. We also fix a bug that IS_IMMUTABLE and
IS_APPEND files could not be truncated during failed writes. In fact, the
test can be completely removed as upper layers do necessary permission
checks for truncate in do_sys_[f]truncate() and may_open() anyway.
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
ext4 has a data corruption case when doing non-block-aligned
asynchronous direct IO into a sparse file, as demonstrated
by xfstest 240.
The root cause is that while ext4 preallocates space in the
hole, mappings of that space still look "new" and
dio_zero_block() will zero out the unwritten portions. When
more than one AIO thread is going, they both find this "new"
block and race to zero out their portion; this is uncoordinated
and causes data corruption.
Dave Chinner fixed this for xfs by simply serializing all
unaligned asynchronous direct IO. I've done the same here.
The difference is that we only wait on conversions, not all IO.
This is a very big hammer, and I'm not very pleased with
stuffing this into ext4_file_write(). But since ext4 is
DIO_LOCKING, we need to serialize it at this high level.
I tried to move this into ext4_ext_direct_IO, but by then
we have the i_mutex already, and we will wait on the
work queue to do conversions - which must also take the
i_mutex. So that won't work.
This was originally exposed by qemu-kvm installing to
a raw disk image with a normal sector-63 alignment. I've
tested a backport of this patch with qemu, and it does
avoid the corruption. It is also quite a lot slower
(14 min for package installs, vs. 8 min for well-aligned)
but I'll take slow correctness over fast corruption any day.
Mingming suggested that we can track outstanding
conversions, and wait on those so that non-sparse
files won't be affected, and I've implemented that here;
unaligned AIO to nonsparse files won't take a perf hit.
[tytso@mit.edu: Keep the mutex as a hashed array instead
of bloating the ext4 inode]
[tytso@mit.edu: Fix up namespace issues so that global
variables are protected with an "ext4_" prefix.]
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
Currently all filesystems except XFS implement fallocate asynchronously,
while XFS forced a commit. Both of these are suboptimal - in case of O_SYNC
I/O we really want our allocation on disk, especially for the !KEEP_SIZE
case where we actually grow the file with user-visible zeroes. On the
other hand always commiting the transaction is a bad idea for fast-path
uses of fallocate like for example in recent Samba versions. Given
that block allocation is a data plane operation anyway change it from
an inode operation to a file operation so that we have the file structure
available that lets us check for O_SYNC.
This also includes moving the code around for a few of the filesystems,
and remove the already unnedded S_ISDIR checks given that we only wire
up fallocate for regular files.
Replace the jbd2_inode structure (which is 48 bytes) with a pointer
and only allocate the jbd2_inode when it is needed --- that is, when
the file system has a journal present and the inode has been opened
for writing. This allows us to further slim down the ext4_inode_info
structure.
The llseek system call should return EINVAL if passed a seek offset
which results in a write error. What this maximum offset should be
depends on whether or not the huge_file file system feature is set,
and whether or not the file is extent based or not.
If the file has no "EXT4_EXTENTS_FL" flag, the maximum size which can be
written (write systemcall) is different from the maximum size which can be
sought (lseek systemcall).
For example, the following 2 cases demonstrates the differences
between the maximum size which can be written, versus the seek offset
allowed by the llseek system call:
#1: mkfs.ext3 <dev>; mount -t ext4 <dev>
#2: mkfs.ext3 <dev>; tune2fs -Oextent,huge_file <dev>; mount -t ext4 <dev>
Table. the max file size which we can write or seek
at each filesystem feature tuning and file flag setting
| \ File flag| | |
| \ | !EXT4_EXTENTS_FL | EXT4_EXTETNS_FL |
|case \| | |
| #1 | write: 2194719883264 | write: -------------- |
| | seek: 2199023251456 | seek: -------------- |
| #2 | write: 4402345721856 | write: 17592186044415 |
| | seek: 17592186044415 | seek: 17592186044415 |
The differences exist because ext4 has 2 maxbytes which are sb->s_maxbytes
(= extent-mapped maxbytes) and EXT4_SB(sb)->s_bitmap_maxbytes (= block-mapped
maxbytes). Although generic_file_llseek uses only extent-mapped maxbytes.
(llseek of ext4_file_operations is generic_file_llseek which uses
sb->s_maxbytes.)
Therefore we create ext4 llseek function which uses 2 maxbytes.
The new own function originates from generic_file_llseek().
If the file flag, "EXT4_EXTENTS_FL" is not set, the function alters
inode->i_sb->s_maxbytes into EXT4_SB(inode->i_sb)->s_bitmap_maxbytes.
Signed-off-by: Toshiyuki Okajima <toshi.okajima@jp.fujitsu.com>
Cc: Andreas Dilger <adilger.kernel@dilger.ca>
By running the following reproducer, we can confirm that the write
system call returns with 0 when it should return the error EFBIG.
#!/bin/sh
/bin/dd if=/dev/zero of=./img bs=1k count=1 seek=1024k > /dev/null 2>&1
/sbin/mkfs.ext3 -Fq ./img
/bin/mount -o loop -t ext4 ./img /mnt
/bin/touch /mnt/file
strace /bin/dd if=/dev/zero of=/mnt/file conv=notrunc bs=1k count=1 seek=$((2194719883264/1024)) 2>&1 | /bin/egrep "write.* 1024\) = "
/bin/umount /mnt
exit
Cc: Eric Sandeen <sandeen@redhat.com>
We don't need to set s_dirt in most of the ext4 code when journaling
is enabled. In ext3/4 some of the summary statistics for # of free
inodes, blocks, and directories are calculated from the per-block
group statistics when the file system is mounted or unmounted. As a
result the superblock doesn't have to be updated, either via the
journal or by setting s_dirt. There are a few exceptions, most
notably when resizing the file system, where the superblock needs to
be modified --- and in that case it should be done as a journalled
operation if possible, and s_dirt set only in no-journal mode.
This patch will optimize out some unneeded disk writes when using ext4
with a journal.
At several places we modify EXT4_I(inode)->i_flags without holding
i_mutex (ext4_do_update_inode, ...). These modifications are racy and
we can lose updates to i_flags. So convert handling of i_flags to use
bitops which are atomic.
https://bugzilla.kernel.org/show_bug.cgi?id=15792
Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org>
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6: (33 commits)
quota: stop using QUOTA_OK / NO_QUOTA
dquot: cleanup dquot initialize routine
dquot: move dquot initialization responsibility into the filesystem
dquot: cleanup dquot drop routine
dquot: move dquot drop responsibility into the filesystem
dquot: cleanup dquot transfer routine
dquot: move dquot transfer responsibility into the filesystem
dquot: cleanup inode allocation / freeing routines
dquot: cleanup space allocation / freeing routines
ext3: add writepage sanity checks
ext3: Truncate allocated blocks if direct IO write fails to update i_size
quota: Properly invalidate caches even for filesystems with blocksize < pagesize
quota: generalize quota transfer interface
quota: sb_quota state flags cleanup
jbd: Delay discarding buffers in journal_unmap_buffer
ext3: quota_write cross block boundary behaviour
quota: drop permission checks from xfs_fs_set_xstate/xfs_fs_set_xquota
quota: split out compat_sys_quotactl support from quota.c
quota: split out netlink notification support from quota.c
quota: remove invalid optimization from quota_sync_all
Fixed trivial conflicts in fs/namei.c and fs/ufs/inode.c
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (36 commits)
ext4: fix up rb_root initializations to use RB_ROOT
ext4: Code cleanup for EXT4_IOC_MOVE_EXT ioctl
ext4: Fix the NULL reference in double_down_write_data_sem()
ext4: Fix insertion point of extent in mext_insert_across_blocks()
ext4: consolidate in_range() definitions
ext4: cleanup to use ext4_grp_offs_to_block()
ext4: cleanup to use ext4_group_first_block_no()
ext4: Release page references acquired in ext4_da_block_invalidatepages
ext4: Fix ext4_quota_write cross block boundary behaviour
ext4: Convert BUG_ON checks to use ext4_error() instead
ext4: Use direct_IO_no_locking in ext4 dio read
ext4: use ext4_get_block_write in buffer write
ext4: mechanical rename some of the direct I/O get_block's identifiers
ext4: make "offset" consistent in ext4_check_dir_entry()
ext4: Handle non empty on-disk orphan link
ext4: explicitly remove inode from orphan list after failed direct io
ext4: fix error handling in migrate
ext4: deprecate obsoleted mount options
ext4: Fix fencepost error in chosing choosing group vs file preallocation.
jbd2: clean up an assertion in jbd2_journal_commit_transaction()
Get rid of the initialize dquot operation - it is now always called from
the filesystem and if a filesystem really needs it's own (which none
currently does) it can just call into it's own routine directly.
Rename the now static low-level dquot_initialize helper to __dquot_initialize
and vfs_dq_init to dquot_initialize to have a consistent namespace.
Currently various places in the VFS call vfs_dq_init directly. This means
we tie the quota code into the VFS. Get rid of that and make the
filesystem responsible for the initialization. For most metadata operations
this is a straight forward move into the methods, but for truncate and
open it's a bit more complicated.
For truncate we currently only call vfs_dq_init for the sys_truncate case
because open already takes care of it for ftruncate and open(O_TRUNC) - the
new code causes an additional vfs_dq_init for those which is harmless.
For open the initialization is moved from do_filp_open into the open method,
which means it happens slightly earlier now, and only for regular files.
The latter is fine because we don't need to initialize it for operations
on special files, and we already do it as part of the namespace operations
for directories.
Add a dquot_file_open helper that filesystems that support generic quotas
can use to fill in ->open.
path to mnt/mnt->mnt_root is no worse than that to
mnt->mnt_parent/mnt->mnt_mountpoint *and* needs no
pinning the sucker down (mnt is not going away and
mnt->mnt_root won't change)
At several places we modify EXT4_I(inode)->i_state without holding
i_mutex (ext4_release_file, ext4_bmap, ext4_journalled_writepage,
ext4_do_update_inode, ...). These modifications are racy and we can
lose updates to i_state. So convert handling of i_state to use bitops
which are atomic.
Cc: Jan Kara <jack@suse.cz>
* mark struct vm_area_struct::vm_ops as const
* mark vm_ops in AGP code
But leave TTM code alone, something is fishy there with global vm_ops
being used.
The syncing is now properly handled by generic_file_aio_write() so
no special ext4 code is needed.
CC: linux-ext4@vger.kernel.org
CC: tytso@mit.edu
Don't implement per-filesystem 'extX_permission()' functions that have
to be called for every path component operation, and instead just expose
the actual ACL checking so that the VFS layer can now do it for us.
Reviewed-by: James Morris <jmorris@namei.org>
Acked-by: Serge Hallyn <serue@us.ibm.com>
This field can be very helpful when a system administrator is trying
to sort through large numbers of block devices or filesystem images.
What is stored in this field can be ambiguous if multiple filesystem
namespaces are in play; what we store in practice is the mountpoint
interpreted by the process's namespace which first opens a file in the
filesystem.
With delayed allocation we should not/cannot discard inode prealloc
space during file close. We would still have dirty pages for which we
haven't allocated blocks yet. With this fix after each get_blocks
request we check whether we have zero reserved blocks and if yes and
we don't have any writers on the file we discard inode prealloc space.
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
When closing a file that had been previously truncated, force any
delay allocated blocks that to be allocated so that if the filesystem
is mounted with data=ordered, the data blocks will be pushed out to
disk along with the journal commit. Many application programs expect
this, so we do this to avoid zero length files if the system crashes
unexpectedly.
* Change EXT4_HAS_*_FEATURE to return a boolean
* Add a function prototype for ext4_fiemap() in ext4.h
* Make ext4_ext_fiemap_cb() and ext4_xattr_fiemap() be static functions
* Add lock annotations to mb_free_blocks()
The ext4 filesystem is getting stable enough that it's time to drop
the "dev" prefix. Also remove the requirement for the TEST_FILESYS
flag.
ext4_ext_walk_space() was reinstated to be used for iterating over file
extents with a callback; it is used by the ext4 fiemap implementation.
Cc: linux-ext4@vger.kernel.org
Cc: linux-fsdevel@vger.kernel.org
Right now i_blocks is not getting updated until the blocks are actually
allocaed on disk. This means with delayed allocation, right after files
are copied, "ls -sF" shoes the file as taking 0 blocks on disk. "du"
also shows the files taking zero space, which is highly confusing to the
user.
Since delayed allocation already keeps track of per-inode total
number of blocks that are subject to delayed allocation, this patch fix
this by using that to adjust the value returned by stat(2). When real
block allocation is done, the i_blocks will get updated. Since the
reserved blocks for delayed allocation will be decreased, this will be
keep value returned by stat(2) consistent.
Signed-off-by: Mingming Cao <cmm@us.ibm.com>
We would like to get notified when we are doing a write on mmap section.
This is needed with respect to preallocated area. We split the preallocated
area into initialzed extent and uninitialzed extent in the call back. This
let us handle ENOSPC better. Otherwise we get ENOSPC in the writepage and
that would result in data loss. The changes are also needed to handle ENOSPC
when writing to an mmap section of files with holes.
Acked-by: Jan Kara <jack@suse.cz>
Move ext4 headers out of include/linux. This is just the trivial move,
there's some more thing that could be done later.
I checked ext4_ioctl and it looked largely safe to not be used
without BKL. So convert it over to unlocked_ioctl.
Signed-off-by: Andi Kleen <ak@suse.de>
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
We are currently taking the truncate_mutex for every read. This would have
performance impact on large CPU configuration. Convert the lock to read write
semaphore and take read lock when we are trying to read the file.
Calculate & store the max offset for bitmapped files, and
catch too-large seeks, truncates, and writes in ext4, shortening
or rejecting as appropriate.
This patch implements ->fallocate() inode operation in ext4. With this
patch users of ext4 file systems will be able to use fallocate() system
call for persistent preallocation. Current implementation only supports
preallocation for regular files (directories not supported as of date)
with extent maps. This patch does not support block-mapped files currently.
Only FALLOC_ALLOCATE and FALLOC_RESV_SPACE modes are being supported as of
now.
Signed-off-by: Amit Arora <aarora@in.ibm.com>
They can use generic_file_splice_read() instead. Since sys_sendfile() now
prefers that, there should be no change in behaviour.
Many struct inode_operations in the kernel can be "const". Marking them const
moves these to the .rodata section, which avoids false sharing with potential
dirty data. In addition it'll catch accidental writes at compile time to
these shared resources.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
Change all the uses of f_{dentry,vfsmnt} to f_path.{dentry,mnt} in the ext4
filesystem.
Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu>
Reworked from a patch by Mingming Cao and Randy Dunlap
Signed-off-By: Randy Dunlap <rdunlap@xenotime.net>
Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
Mingming Cao originally did this work, and Shaggy reproduced it using some
scripts from her.
Start of the ext4 patch series. See Documentation/filesystems/ext4.txt for
details.
This is a simple copy of the files in fs/ext3 to fs/ext4 and
/usr/incude/linux/ext3* to /usr/include/ex4*
