Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
Change clear_opt() and set_opt() to take a superblock pointer instead
of a pointer to EXT4_SB(sb)->s_mount_opt. This makes it easier for us
to support a second mount option field.
Commit 5c521830cf (ext4: Support discard requests when running in
no-journal mode) attempts to add sb_issue_discard() for data blocks
(in data=writeback mode) and in no-journal mode. Unfortunately, this
no longer works, because in commit dd3932eddf (block: remove
BLKDEV_IFL_WAIT), sb_issue_discard() only presents a synchronous
interface, and there are times when we call ext4_free_blocks() when we
are are holding a spinlock, or are otherwise in an atomic context.
For now, I've removed the call to sb_issue_discard() to prevent a
deadlock or (if spinlock debugging is enabled) failures like this:
BUG: scheduling while atomic: rc.sysinit/1376/0x00000002
Pid: 1376, comm: rc.sysinit Not tainted 2.6.36-ARCH #1
Call Trace:
[<ffffffff810397ce>] __schedule_bug+0x5e/0x70
[<ffffffff81403110>] schedule+0x950/0xa70
[<ffffffff81060bad>] ? insert_work+0x7d/0x90
[<ffffffff81060fbd>] ? queue_work_on+0x1d/0x30
[<ffffffff81061127>] ? queue_work+0x37/0x60
[<ffffffff8140377d>] schedule_timeout+0x21d/0x360
[<ffffffff812031c3>] ? generic_make_request+0x2c3/0x540
[<ffffffff81402680>] wait_for_common+0xc0/0x150
[<ffffffff81041490>] ? default_wake_function+0x0/0x10
[<ffffffff812034bc>] ? submit_bio+0x7c/0x100
[<ffffffff810680a0>] ? wake_bit_function+0x0/0x40
[<ffffffff814027b8>] wait_for_completion+0x18/0x20
[<ffffffff8120a969>] blkdev_issue_discard+0x1b9/0x210
[<ffffffff811ba03e>] ext4_free_blocks+0x68e/0xb60
[<ffffffff811b1650>] ? __ext4_handle_dirty_metadata+0x110/0x120
[<ffffffff811b098c>] ext4_ext_truncate+0x8cc/0xa70
[<ffffffff810d713e>] ? pagevec_lookup+0x1e/0x30
[<ffffffff81191618>] ext4_truncate+0x178/0x5d0
[<ffffffff810eacbb>] ? unmap_mapping_range+0xab/0x280
[<ffffffff810d8976>] vmtruncate+0x56/0x70
[<ffffffff811925cb>] ext4_setattr+0x14b/0x460
[<ffffffff811319e4>] notify_change+0x194/0x380
[<ffffffff81117f80>] do_truncate+0x60/0x90
[<ffffffff811e08fa>] ? security_inode_permission+0x1a/0x20
[<ffffffff811eaec1>] ? tomoyo_path_truncate+0x11/0x20
[<ffffffff81127539>] do_last+0x5d9/0x770
[<ffffffff811278bd>] do_filp_open+0x1ed/0x680
[<ffffffff8140644f>] ? page_fault+0x1f/0x30
[<ffffffff81132bfc>] ? alloc_fd+0xec/0x140
[<ffffffff81118db1>] do_sys_open+0x61/0x120
[<ffffffff81118e8b>] sys_open+0x1b/0x20
[<ffffffff81002e6b>] system_call_fastpath+0x16/0x1b
https://bugzilla.kernel.org/show_bug.cgi?id=22302
Reported-by: Mathias Burén <mathias.buren@gmail.com>
Cc: jiayingz@google.com
fs/ext4/inode.c
fs/ext4/mballoc.c
include/trace/events/ext4.h
These functions are only used within fs/ext4/mballoc.c, so move them
so they are used after they are defined, and then make them be static.
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
This is a cleanup to avoid namespace leaks out of fs/ext4
Walk through allocation groups and trim all free extents. It can be
invoked through FITRIM ioctl on the file system. The main idea is to
provide a way to trim the whole file system if needed, since some SSD's
may suffer from performance loss after the whole device was filled (it
does not mean that fs is full!).
It search for free extents in allocation groups specified by Byte range
start -> start+len. When the free extent is within this range, blocks
are marked as used and then trimmed. Afterwards these blocks are marked
as free in per-group bitmap.
Since fstrim is a long operation it is good to have an ability to
interrupt it by a signal. This was added by Dmitry Monakhov.
Thanks Dimitry.
Signed-off-by: Lukas Czerner <lczerner@redhat.com>
Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org>
Reviewed-by: Dmitry Monakhov <dmonakhov@openvz.org>
Use return value from sb_issue_discard() as return value in
ext4_issue_discard(). Since sb_issue_discard() may result in more
serious errors than just -EOPNOTSUPP it is worth to inform user of this
function about them to handle error cases properly.
Fail block allocation if sb_getblk() returns NULL. In that case,
sb_find_get_block() also likely to fail so that it should skip
calling ext4_forget().
Signed-off-by: Namhyung Kim <namhyung@gmail.com>
Also remove the SLAB_RECLAIM_ACCOUNT flag from the system zone kmem
cache. This slab tends to be fairly static, so it shouldn't be marked
as likely to have free pages that can be reclaimed.
Many tracepoints were populating an ext4_allocation_context
to pass in, but this requires a slab allocation even when
tracepoints are off. In fact, 4 of 5 of these allocations
were only for tracing. In addition, we were only using a
small fraction of the 144 bytes of this structure for this
purpose.
We can do away with all these alloc/frees of the ac and
simply pass in the bits we care about, instead.
I tested this by turning on tracing and running through
xfstests on x86_64. I did not actually do anything with
the trace output, however.
We can't hold the block group spinlock because we ext4_issue_discard()
calls wait and hence can get rescheduled.
Google-Bug-Id: 3017678
sb_issue_discard() is returning negative error code, so check for
-EOPNOTSUPP.
ext4_group_info structures are currently allocated with kmalloc().
With a typical 4K block size, these are 136 bytes each -- meaning
they'll each consume a 256-byte slab object. On a system with many
ext4 large partitions, that's a lot of wasted kernel slab space.
(E.g., a single 1TB partition will have about 8000 block groups, using
about 2MB of slab, of which nearly 1MB is wasted.)
This patch creates an array of slab pointers created as needed --
depending on the superblock block size -- and uses these slabs to
allocate the group info objects.
Google-Bug-Id: 2980809
Signed-off-by: Curt Wohlgemuth <curtw@google.com>
Instead of always assigning an increasing inode number in new_inode
move the call to assign it into those callers that actually need it.
For now callers that need it is estimated conservatively, that is
the call is added to all filesystems that do not assign an i_ino
by themselves. For a few more filesystems we can avoid assigning
any inode number given that they aren't user visible, and for others
it could be done lazily when an inode number is actually needed,
but that's left for later patches.
Signed-off-by: Dave Chinner <dchinner@redhat.com>
All the blkdev_issue_* helpers can only sanely be used for synchronous
caller. To issue cache flushes or barriers asynchronously the caller needs
to set up a bio by itself with a completion callback to move the asynchronous
state machine ahead. So drop the BLKDEV_IFL_WAIT flag that is always
specified when calling blkdev_issue_* and also remove the now unused flags
argument to blkdev_issue_flush and blkdev_issue_zeroout. For
blkdev_issue_discard we need to keep it for the secure discard flag, which
gains a more descriptive name and loses the bitops vs flag confusion.
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
ext4 already uses synchronous discards, no need to add I/O barriers.
We'll need to get rid of the BLKDEV_IFL_BARRIER flag, and to facilitate
that and to make the interface less confusing pass all flags explicitly.
Acked-by: Mike Snitzer <snitzer@redhat.com>
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (40 commits)
ext4: Adding error check after calling ext4_mb_regular_allocator()
ext4: Fix dirtying of journalled buffers in data=journal mode
ext4: re-inline ext4_rec_len_(to|from)_disk functions
jbd2: Remove t_handle_lock from start_this_handle()
jbd2: Change j_state_lock to be a rwlock_t
jbd2: Use atomic variables to avoid taking t_handle_lock in jbd2_journal_stop
ext4: Add mount options in superblock
ext4: force block allocation on quota_off
ext4: fix freeze deadlock under IO
ext4: drop inode from orphan list if ext4_delete_inode() fails
ext4: check to make make sure bd_dev is set before dereferencing it
jbd2: Make barrier messages less scary
ext4: don't print scary messages for allocation failures post-abort
ext4: fix EFBIG edge case when writing to large non-extent file
ext4: fix ext4_get_blocks references
ext4: Always journal quota file modifications
ext4: Fix potential memory leak in ext4_fill_super
ext4: Don't error out the fs if the user tries to make a file too big
ext4: allocate stripe-multiple IOs on stripe boundaries
ext4: move aio completion after unwritten extent conversion
Fix up conflicts in fs/ext4/inode.c as per Ted.
Fix up xfs conflicts as per earlier xfs merge.
If the bitmap block on disk is bad, ext4_mb_load_buddy() returns an
error. This error is returned to the caller,
ext4_mb_regular_allocator() and then to ext4_mb_new_blocks(). But
ext4_mb_new_blocks() did not check for the return value of
ext4_mb_regular_allocator() and would repeatedly try to load the
bitmap block. The fix simply catches the return value and exits out of
the 'repeat' loop after cleanup.
We also take the opportunity to clean up the error handling in
Google-Bug-Id: 2853530
Signed-off-by: Aditya Kali <adityakali@google.com>
I often get emails containing the "This should not happen!!" message,
conveniently trimmed to remove things like:
sd 0:0:0:0: [sda] Unhandled error code
sd 0:0:0:0: [sda] Result: hostbyte=DID_OK driverbyte=DRIVER_TIMEOUT
sd 0:0:0:0: [sda] CDB: Write(10): 2a 00 03 13 c9 70 00 00 28 00
end_request: I/O error, dev sda, sector 51628400
Aborting journal on device dm-0-8.
EXT4-fs error (device dm-0): ext4_journal_start_sb: Detected aborted journal
EXT4-fs (dm-0): Remounting filesystem read-only
I don't think there is any value to the verbosity if the reason is
due to a filesystem abort; it just obfuscates the root cause.
For some reason, today mballoc only allocates IOs which are exactly
stripe-sized on a stripe boundary. If you have a multiple (say, a
128k IO on a 64k stripe) you may end up unaligned.
It seems to me that a simple change to align stripe-multiple IOs
on stripe boundaries would be a very good idea, unless this breaks
some other mballoc heuristic for some reason...
Reported-by: Mike Snitzer <snitzer@redhat.com>
Issue discard request in ext4_free_blocks() when ext4 has no journal and
is mounted with discard option.
Signed-off-by: Jiaying Zhang <jiayingz@google.com>
The allocation_context pointer can be NULL.
Also use a macro definition so that __func__ and __LINE__ is implicit.
No real bugs found, just removed some dead code.
Found by gcc 4.6's new warnings.
We don't need to set s_dirt in most of the ext4 code when journaling
is enabled. In ext3/4 some of the summary statistics for # of free
inodes, blocks, and directories are calculated from the per-block
group statistics when the file system is mounted or unmounted. As a
result the superblock doesn't have to be updated, either via the
journal or by setting s_dirt. There are a few exceptions, most
notably when resizing the file system, where the superblock needs to
be modified --- and in that case it should be done as a journalled
operation if possible, and s_dirt set only in no-journal mode.
This patch will optimize out some unneeded disk writes when using ext4
with a journal.
This patch was generated using:
#!/usr/bin/perl -i
while (<>) {
s/[ ]+$//;
print;
At several places we modify EXT4_I(inode)->i_flags without holding
i_mutex (ext4_do_update_inode, ...). These modifications are racy and
we can lose updates to i_flags. So convert handling of i_flags to use
bitops which are atomic.
https://bugzilla.kernel.org/show_bug.cgi?id=15792
Fix ext4_mb_collect_stats() to use the correct test for s_bal_success; it
should be testing "best-extent.fe_len >= orig-extent.fe_len" , not
"orig-extent.fe_len >= goal-extent.fe_len" .
Signed-off-by: Curt Wohlgemuth <curtw@google.org>
This adds a new field in ext4_group_info to cache the largest available
block range in a block group; and don't load the buddy pages until *after*
we've done a sanity check on the block group.
With large allocation requests (e.g., fallocate(), 8MiB) and relatively full
partitions, it's easy to have no block groups with a block extent large
enough to satisfy the input request length. This currently causes the loop
during cr == 0 in ext4_mb_regular_allocator() to load the buddy bitmap pages
for EVERY block group. That can be a lot of pages. The patch below allows
us to call ext4_mb_good_group() BEFORE we load the buddy pages (although we
have check again after we lock the block group).
Addresses-Google-Bug: #2578108
Addresses-Google-Bug: #2704453
Turn off issuance of discard requests if the device does
not support it - similar to the action we take for barriers.
This will save a little computation time if a non-discardable
device is mounted with -o discard, and also makes it obvious
that it's not doing what was asked at mount time ...
This function cleans up after ext4_mb_load_buddy(), so the renaming
makes the code clearer.
Signed-off-by: Jing Zhang <zj.barak@gmail.com>
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4:
ext4: Issue the discard operation *before* releasing the blocks to be reused
ext4: Fix buffer head leaks after calls to ext4_get_inode_loc()
ext4: Fix possible lost inode write in no journal mode
Otherwise, we can end up having data corruption because the blocks
could get reused and then discarded!
https://bugzilla.kernel.org/show_bug.cgi?id=15579
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Documentation/filesystems/proc.txt
arch/arm/mach-u300/include/mach/debug-macro.S
drivers/net/qlge/qlge_ethtool.c
drivers/net/qlge/qlge_main.c
drivers/net/typhoon.c
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6: (33 commits)
quota: stop using QUOTA_OK / NO_QUOTA
dquot: cleanup dquot initialize routine
dquot: move dquot initialization responsibility into the filesystem
dquot: cleanup dquot drop routine
dquot: move dquot drop responsibility into the filesystem
dquot: cleanup dquot transfer routine
dquot: move dquot transfer responsibility into the filesystem
dquot: cleanup inode allocation / freeing routines
dquot: cleanup space allocation / freeing routines
ext3: add writepage sanity checks
ext3: Truncate allocated blocks if direct IO write fails to update i_size
quota: Properly invalidate caches even for filesystems with blocksize < pagesize
quota: generalize quota transfer interface
quota: sb_quota state flags cleanup
jbd: Delay discarding buffers in journal_unmap_buffer
ext3: quota_write cross block boundary behaviour
quota: drop permission checks from xfs_fs_set_xstate/xfs_fs_set_xquota
quota: split out compat_sys_quotactl support from quota.c
quota: split out netlink notification support from quota.c
quota: remove invalid optimization from quota_sync_all
Fixed trivial conflicts in fs/namei.c and fs/ufs/inode.c
ext4 uses rb_node = NULL; to zero rb_root at few places. Using
RB_ROOT as the initializer is more portable in case the underlying
implementation of rbtrees changes in the future.
Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
Cc: Eric Paris <eparis@redhat.com>
Get rid of the alloc_space, free_space, reserve_space, claim_space and
release_rsv dquot operations - they are always called from the filesystem
and if a filesystem really needs their own (which none currently does)
it can just call into it's own routine directly.
Move shared logic into the common __dquot_alloc_space,
dquot_claim_space_nodirty and __dquot_free_space low-level methods,
and rationalize the wrappers around it to move as much as possible
code into the common block for CONFIG_QUOTA vs not. Also rename
all these helpers to be named dquot_* instead of vfs_dq_*.
More cleanup to convert open-coded calculations of the first block
number of a free extent to use ext4_grp_offs_to_block() instead.
Cc: Andreas Dilger <adilger@sun.com>
This is a cleanup and simplification patch which takes some open-coded
calculations to calculate the first block number of a group and
converts them to use the (already defined) ext4_group_first_block_no()
function.
The ext4 multiblock allocator decides whether to use group or file
preallocation based on the file size. When the file size reaches
s_mb_stream_request (default is 16 blocks), it changes to use a
file-specific preallocation. This is cool, but it has a tiny problem.
See a simple script:
mkfs.ext4 -b 1024 /dev/sda8 1000000
mount -t ext4 -o nodelalloc /dev/sda8 /mnt/ext4
for((i=0;i<5;i++))
do
cat /mnt/4096>>/mnt/ext4/a #4096 is a file with 4096 characters.
cat /mnt/4096>>/mnt/ext4/b
done
debuge4fs -R 'stat a' /dev/sda8|grep BLOCKS -A 1
And you get
BLOCKS:
(0-14):8705-8719, (15):2356, (16-19):8465-8468
So there are 3 extents, a bit strange for the lonely 15th logical
block. As we write to the 16 blocks, we choose file preallocation in
ext4_mb_group_or_file, but in ext4_mb_normalize_request, we meet with
the 16*1024 range, so no preallocation will be carried. file b then
reserves the space after '2356', so when when write 16, we start from
another part.
This patch just change the check in ext4_mb_group_or_file, so
that for the lonely 15 we will still use group preallocation.
After the patch, we will get:
BLOCKS:
(0-15):8705-8720, (16-19):8465-8468
Looks more sane. Thanks.
Signed-off-by: Tao Ma <tao.ma@oracle.com>
Just a pet peeve of mine; we had a mishash of calls with either __func__
or "function_name" and the latter tends to get out of sync.
I think it's easier to just hide the __func__ in a macro, and it'll
be consistent from then on.
Some misspelled occurences of 'octet' and some comments were also fixed
as I was on it.
Signed-off-by: Daniel Mack <daniel@caiaq.de>
Cc: Jiri Kosina <trivial@kernel.org>
Cc: Joe Perches <joe@perches.com>
Cc: Junio C Hamano <gitster@pobox.com>
We have to delay vfs_dq_claim_space() until allocation context destruction.
Currently we have following call-trace:
/* task is already holding ac->alloc_semp */
->ext4_mb_mark_diskspace_used
->vfs_dq_claim_space() /* acquire dqptr_sem here. Possible deadlock */
->ext4_mb_release_context() /* drop ac->alloc_semp here */
Let's move quota claiming to ext4_da_update_reserve_space()
[ INFO: possible circular locking dependency detected ]
2.6.32-rc7 #18
write-truncate-/3465 is trying to acquire lock:
(&s->s_dquot.dqptr_sem){++++..}, at: [<c025e73b>] dquot_claim_space+0x3b/0x1b0
but task is already holding lock:
(&meta_group_info[i]->alloc_sem){++++..}, at: [<c02ce962>] ext4_mb_load_buddy+0xb2/0x370
which lock already depends on the new lock.
the existing dependency chain (in reverse order) is:
-> #3 (&meta_group_info[i]->alloc_sem){++++..}:
[<c017d04b>] __lock_acquire+0xd7b/0x1260
[<c017d5ea>] lock_acquire+0xba/0xd0
[<c0527191>] down_read+0x51/0x90
[<c02d0c1c>] ext4_mb_free_blocks+0x46c/0x870
[<c029c9d3>] ext4_free_blocks+0x73/0x130
[<c02c8cfc>] ext4_ext_truncate+0x76c/0x8d0
[<c02a8087>] ext4_truncate+0x187/0x5e0
[<c01e0f7b>] vmtruncate+0x6b/0x70
[<c022ec02>] inode_setattr+0x62/0x190
[<c02a2d7a>] ext4_setattr+0x25a/0x370
[<c022ee81>] notify_change+0x151/0x340
[<c021349d>] do_truncate+0x6d/0xa0
[<c0221034>] may_open+0x1d4/0x200
[<c022412b>] do_filp_open+0x1eb/0x910
[<c021244d>] do_sys_open+0x6d/0x140
[<c021258e>] sys_open+0x2e/0x40
[<c0103100>] sysenter_do_call+0x12/0x32
-> #2 (&ei->i_data_sem){++++..}:
[<c02a5787>] ext4_get_blocks+0x47/0x450
[<c02a74c1>] ext4_getblk+0x61/0x1d0
[<c02a7a7f>] ext4_bread+0x1f/0xa0
[<c02bcddc>] ext4_quota_write+0x12c/0x310
[<c0262d23>] qtree_write_dquot+0x93/0x120
[<c0261708>] v2_write_dquot+0x28/0x30
[<c025d3fb>] dquot_commit+0xab/0xf0
[<c02be977>] ext4_write_dquot+0x77/0x90
[<c02be9bf>] ext4_mark_dquot_dirty+0x2f/0x50
[<c025e321>] dquot_alloc_inode+0x101/0x180
[<c029fec2>] ext4_new_inode+0x602/0xf00
[<c02ad789>] ext4_create+0x89/0x150
[<c0221ff2>] vfs_create+0xa2/0xc0
[<c02246e7>] do_filp_open+0x7a7/0x910
-> #1 (&sb->s_type->i_mutex_key#7/4){+.+...}:
[<c0526505>] mutex_lock_nested+0x65/0x2d0
[<c0260c9d>] vfs_load_quota_inode+0x4bd/0x5a0
[<c02610af>] vfs_quota_on_path+0x5f/0x70
[<c02bc812>] ext4_quota_on+0x112/0x190
[<c026345a>] sys_quotactl+0x44a/0x8a0
-> #0 (&s->s_dquot.dqptr_sem){++++..}:
[<c017d361>] __lock_acquire+0x1091/0x1260
[<c02cb95f>] ext4_mb_mark_diskspace_used+0x36f/0x380
[<c02d210a>] ext4_mb_new_blocks+0x34a/0x530
[<c02c83fb>] ext4_ext_get_blocks+0x122b/0x13c0
[<c02a5966>] ext4_get_blocks+0x226/0x450
[<c02a5ff3>] mpage_da_map_blocks+0xc3/0xaa0
[<c02a6ed6>] ext4_da_writepages+0x506/0x790
[<c01de272>] do_writepages+0x22/0x50
[<c01d766d>] __filemap_fdatawrite_range+0x6d/0x80
[<c01d7b9b>] filemap_flush+0x2b/0x30
[<c02a40ac>] ext4_alloc_da_blocks+0x5c/0x60
[<c029e595>] ext4_release_file+0x75/0xb0
[<c0216b59>] __fput+0xf9/0x210
[<c0216c97>] fput+0x27/0x30
[<c02122dc>] filp_close+0x4c/0x80
[<c014510e>] put_files_struct+0x6e/0xd0
[<c01451b7>] exit_files+0x47/0x60
[<c0146a24>] do_exit+0x144/0x710
[<c0147028>] do_group_exit+0x38/0xa0
[<c0159abc>] get_signal_to_deliver+0x2ac/0x410
[<c0102849>] do_notify_resume+0xb9/0x890
[<c01032d2>] work_notifysig+0x13/0x21
3 locks held by write-truncate-/3465:
#0: (jbd2_handle){+.+...}, at: [<c02e1f8f>] start_this_handle+0x38f/0x5c0
#1: (&ei->i_data_sem){++++..}, at: [<c02a57f6>] ext4_get_blocks+0xb6/0x450
#2: (&meta_group_info[i]->alloc_sem){++++..}, at: [<c02ce962>] ext4_mb_load_buddy+0xb2/0x370
stack backtrace:
Pid: 3465, comm: write-truncate- Not tainted 2.6.32-rc7 #18
Call Trace:
[<c0524cb3>] ? printk+0x1d/0x22
[<c017ac9a>] print_circular_bug+0xca/0xd0
[<c016bca2>] ? sched_clock_local+0xd2/0x170
[<c0178fd0>] ? trace_hardirqs_off_caller+0x20/0xd0
[<c025e73b>] ? dquot_claim_space+0x3b/0x1b0
[<c02c601d>] ? ext4_ext_find_extent+0x25d/0x280
[<c016be60>] ? sched_clock_cpu+0x120/0x160
[<c016beef>] ? cpu_clock+0x4f/0x60
[<c052712c>] ? down_write+0x8c/0xa0
[<c017908b>] ? trace_hardirqs_off+0xb/0x10
[<c01d69cc>] ? find_get_pages_tag+0x16c/0x180
[<c01d6860>] ? find_get_pages_tag+0x0/0x180
[<c02a73bd>] ? __mpage_da_writepage+0x16d/0x1a0
[<c01dfc4e>] ? pagevec_lookup_tag+0x2e/0x40
[<c01ddf1b>] ? write_cache_pages+0xdb/0x3d0
[<c02a7250>] ? __mpage_da_writepage+0x0/0x1a0
[<c02a69d0>] ? ext4_da_writepages+0x0/0x790
[<c017b163>] ? lock_release_holdtime+0x33/0x210
[<c0528137>] ? _spin_unlock_irq+0x27/0x30
[<c017babb>] ? trace_hardirqs_on+0xb/0x10
[<c0165b50>] ? autoremove_wake_function+0x0/0x50
[<c017ba54>] ? trace_hardirqs_on_caller+0x134/0x190
[<c0300ba4>] ? security_file_permission+0x14/0x20
[<c0215761>] ? vfs_write+0x131/0x190
[<c0214f50>] ? do_sync_write+0x0/0x120
[<c0103115>] ? sysenter_do_call+0x27/0x32
CC: Theodore Ts'o <tytso@mit.edu>
