There is a bug when we are trying to verify that the reserve inode's
double indirect blocks point back to the primary gdt blocks. The fix is
obvious, we need to mod the gdb count by the addr's per block. This was
verified using the same testcase as with the ext3 equivalent of this
patch.
Signed-off-by: Josef Bacik <jbacik@redhat.com>
Signed-off-by: Mingming Cao <cmm@us.ibm.com>
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
Move ext4 headers out of include/linux. This is just the trivial move,
there's some more thing that could be done later.
This fixes the allocations with GFP_KERNEL while under a transaction problems
in ext4. This patch is the same as its ext3 counterpart, just switches these
to GFP_NOFS.
Cc: <linux-ext4@vger.kernel.org>
__FUNCTION__ is gcc-specific, use __func__
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
replace all:
little_endian_variable = cpu_to_leX(leX_to_cpu(little_endian_variable) +
expression_in_cpu_byteorder);
with:
leX_add_cpu(&little_endian_variable, expression_in_cpu_byteorder);
generated with semantic patch
Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com>
Cc: linux-ext4@vger.kernel.org
Cc: sct@redhat.com
Cc: adilger@clusterfs.com
Cc: Mingming Cao <cmm@us.ibm.com>
Add missing ext4_journal_stop() in error handling.
Cc: Stephen Tweedie <sct@redhat.com>
Stop the EXT4 filesystem from using iget() and read_inode(). Replace
ext4_read_inode() with ext4_iget(), and call that instead of iget().
ext4_iget() then uses iget_locked() directly and returns a proper error code
instead of an inode in the event of an error.
ext4_fill_super() returns any error incurred when getting the root inode
instead of EINVAL.
Acked-by: "Theodore Ts'o" <tytso@mit.edu>
Acked-by: Jan Kara <jack@suse.cz>
Acked-by: Christoph Hellwig <hch@lst.de>
Builds with EXT4FS_DEBUG defined (to enable ext4_debug()) fail
without these changes. Clean up some format warnings too.
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
In many places variables for block group are of type int, which limits the
maximum number of block groups to 2^31. Each block group can have up to
2^15 blocks, with a 4K block size, and the max filesystem size is limited to
2^31 * (2^15 * 2^12) = 2^58 -- or 256 PB
This patch introduces a new type ext4_group_t, of type unsigned long, to
represent block group numbers in ext4.
All occurrences of block group variables are converted to type ext4_group_t.
Signed-off-by: Avantika Mathur <mathur@us.ibm.com>
When resizing online, setup_new_group_blocks attempts to reserve a
potentially very large transaction, depending on the current filesystem
geometry. For some journal sizes, there may not be enough room for this
transaction, and the online resize will fail.
The patch below resizes & restarts the transaction as necessary while
setting up the new group, and should work with even the smallest journal.
Tested with something like:
[root@newbox ~]# dd if=/dev/zero of=fsfile bs=1024 count=32768
[root@newbox ~]# mkfs.ext3 -b 1024 fsfile 16384
[root@newbox ~]# mount -o loop fsfile mnt/
[root@newbox ~]# resize2fs /dev/loop0
resize2fs 1.40.2 (12-Jul-2007)
Filesystem at /dev/loop0 is mounted on /root/mnt; on-line resizing required
old desc_blocks = 1, new_desc_blocks = 1
Performing an on-line resize of /dev/loop0 to 32768 (1k) blocks.
resize2fs: No space left on device While trying to add group #2
[root@newbox ~]# dmesg | tail -n 1
JBD: resize2fs wants too many credits (258 > 256)
[root@newbox ~]#
With the below change, it works.
Acked-by: Andreas Dilger <adilger@clusterfs.com>
setup_new_group_blocks() manipulates the group descriptor block bh
under the block_bitmap bh's lock. It shouldn't matter since nobody
but resize should be touching these blocks, but it's worth fixing up.
In pass1 of e2fsck, every inode table in the fileystem is scanned and checked,
regardless of whether it is in use. This is this the most time consuming part
of the filesystem check. The unintialized block group feature can greatly
reduce e2fsck time by eliminating checking of uninitialized inodes.
With this feature, there is a a high water mark of used inodes for each block
group. Block and inode bitmaps can be uninitialized on disk via a flag in the
group descriptor to avoid reading or scanning them at e2fsck time. A checksum
of each group descriptor is used to ensure that corruption in the group
descriptor's bit flags does not cause incorrect operation.
The feature is enabled through a mkfs option
mke2fs /dev/ -O uninit_groups
A patch adding support for uninitialized block groups to e2fsprogs tools has
been posted to the linux-ext4 mailing list.
The patches have been stress tested with fsstress and fsx. In performance
tests testing e2fsck time, we have seen that e2fsck time on ext3 grows
linearly with the total number of inodes in the filesytem. In ext4 with the
uninitialized block groups feature, the e2fsck time is constant, based
solely on the number of used inodes rather than the total inode count.
Since typical ext4 filesystems only use 1-10% of their inodes, this feature can
greatly reduce e2fsck time for users. With performance improvement of 2-20
times, depending on how full the filesystem is.
The attached graph shows the major improvements in e2fsck times in filesystems
with a large total inode count, but few inodes in use.
In each group descriptor if we have
EXT4_BG_INODE_UNINIT set in bg_flags:
Inode table is not initialized/used in this group. So we can skip
the consistency check during fsck.
EXT4_BG_BLOCK_UNINIT set in bg_flags:
No block in the group is used. So we can skip the block bitmap
verification for this group.
We also add two new fields to group descriptor as a part of
uninitialized group patch.
__le16 bg_itable_unused; /* Unused inodes count */
__le16 bg_checksum; /* crc16(sb_uuid+group+desc) */
bg_itable_unused:
If we have EXT4_BG_INODE_UNINIT not set in bg_flags
then bg_itable_unused will give the offset within
the inode table till the inodes are used. This can be
used by fsck to skip list of inodes that are marked unused.
bg_checksum:
Now that we depend on bg_flags and bg_itable_unused to determine
the block and inode usage, we need to make sure group descriptor
is not corrupt. We add checksum to group descriptor to
detect corruption. If the descriptor is found to be corrupt, we
mark all the blocks and inodes in the group used.
Signed-off-by: Andreas Dilger <adilger@clusterfs.com>
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
s/percpu_counter_mod/percpu_counter_add/
Because its a better name, _mod implies modulo.
Remove includes of <linux/smp_lock.h> where it is not used/needed.
Suggested by Al Viro.
Builds cleanly on x86_64, i386, alpha, ia64, powerpc, sparc,
sparc64, and arm (all 59 defconfigs).
After Al Viro (finally) succeeded in removing the sched.h #include in module.h
recently, it makes sense again to remove other superfluous sched.h includes.
There are quite a lot of files which include it but don't actually need
anything defined in there. Presumably these includes were once needed for
macros that used to live in sched.h, but moved to other header files in the
course of cleaning it up.
To ease the pain, this time I did not fiddle with any header files and only
removed #includes from .c-files, which tend to cause less trouble.
Compile tested against 2.6.20-rc2 and 2.6.20-rc2-mm2 (with offsets) on alpha,
arm, i386, ia64, mips, powerpc, and x86_64 with allnoconfig, defconfig,
allmodconfig, and allyesconfig as well as a few randconfigs on x86_64 and all
configs in arch/arm/configs on arm. I also checked that no new warnings were
introduced by the patch (actually, some warnings are removed that were emitted
by unnecessarily included header files).
Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
fs/ext4/resize.c:72: warning: long long unsigned int format, __u64 arg (arg 4)
fs/ext4/resize.c:76: warning: long long unsigned int format, __u64 arg (arg 4)
fs/ext4/resize.c:81: warning: long long unsigned int format, __u64 arg (arg 4)
fs/ext4/resize.c:85: warning: long long unsigned int format, __u64 arg (arg 4)
fs/ext4/resize.c:89: warning: long long unsigned int format, __u64 arg (arg 4)
fs/ext4/resize.c:89: warning: long long unsigned int format, __u64 arg (arg 5)
fs/ext4/resize.c:93: warning: long long unsigned int format, __u64 arg (arg 4)
fs/ext4/resize.c:93: warning: long long unsigned int format, __u64 arg (arg 5)
fs/ext4/resize.c:98: warning: long long unsigned int format, __u64 arg (arg 4)
fs/ext4/resize.c:103: warning: long long unsigned int format, __u64 arg (arg 4)
fs/ext4/resize.c:109: warning: long long unsigned int format, __u64 arg (arg 4)
move '_hi' bits of block numbers in the larger part of the
block group descriptor structure
Signed-off-by: Alexandre Ratchov <alexandre.ratchov@bull.net>
Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
Change ext4 in-kernel block type (ext4_fsblk_t) from sector_t to unsigned
long long. Remove ext4 block type string micro E3FSBLK, replaced with "%llu"
[akpm@osdl.org: build fix]
In-kernel super block changes to support >32 bit free blocks numbers.
Signed-off-by: Laurent Vivier <Laurent.Vivier@bull.net>
Redefine ext3 in-kernel filesystem block type (ext3_fsblk_t) from unsigned
long to sector_t, to allow kernel to handle >32 bit ext3 blocks.
Reworked from a patch by Mingming Cao and Randy Dunlap
Signed-off-By: Randy Dunlap <rdunlap@xenotime.net>
Mingming Cao originally did this work, and Shaggy reproduced it using some
scripts from her.
Start of the ext4 patch series. See Documentation/filesystems/ext4.txt for
details.
This is a simple copy of the files in fs/ext3 to fs/ext4 and
/usr/incude/linux/ext3* to /usr/include/ex4*
