commit 2d5b86e048780c5efa7f7d9708815555919e7b05 upstream.
As of v3.18, ext4 started rejecting a remount which changes the
journal_checksum option.
Prior to that, it was simply ignored; the problem here is that
if someone has this in their fstab for the root fs, now the box
fails to boot properly, because remount of root with the new options
will fail, and the box proceeds with a readonly root.
I think it is a little nicer behavior to accept the option, but
warn that it's being ignored, rather than failing the mount,
but that might be a subjective matter...
Reported-by: Cónräd <conradsand.arma@gmail.com>
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
Cc: Josh Boyer <jwboyer@fedoraproject.org>
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4
Pull ext4 bugfixes from Ted Ts'o:
"Revert a potential seek_data/hole regression which shows up when using
ext4 to handle ext3 file systems, plus two minor bug fixes"
* tag 'ext4_for_linus_stable' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4:
ext4: remove spurious KERN_INFO from ext4_warning call
Revert "ext4: fix suboptimal seek_{data,hole} extents traversial"
ext4: prevent online resize with backup superblock
Signed-off-by: Jakub Wilk <jwilk@jwilk.net>
This reverts commit 14516bb7bb6ffbd49f35389f9ece3b2045ba5815.
This was causing regression test failures with generic/285 with an ext3
filesystem using CONFIG_EXT4_USE_FOR_EXT23.
Prevent BUG or corrupted file systems after the following:
mkfs.ext4 /dev/vdc 100M
mount -t ext4 -o sb=40961 /dev/vdc /vdc
resize2fs /dev/vdc
We previously prevented online resizing using the old resize ioctl.
Move the code to ext4_resize_begin(), so the check applies for all of
the resize ioctl's.
Reported-by: Maxim Malkov <malkov@ispras.ru>
... and comparing get_fs() with KERNEL_DS used only to initialize that
Pull ext4 updates from Ted Ts'o:
"Lots of bugs fixes, including Zheng and Jan's extent status shrinker
fixes, which should improve CPU utilization and potential soft lockups
under heavy memory pressure, and Eric Whitney's bigalloc fixes"
* tag 'ext4_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (26 commits)
ext4: ext4_da_convert_inline_data_to_extent drop locked page after error
ext4: ext4_inline_data_fiemap should respect callers argument
ext4: prevent fsreentrance deadlock for inline_data
ext4: forbid journal_async_commit in data=ordered mode
jbd2: remove unnecessary NULL check before iput()
ext4: Remove an unnecessary check for NULL before iput()
ext4: remove unneeded code in ext4_unlink
ext4: don't count external journal blocks as overhead
ext4: remove never taken branch from ext4_ext_shift_path_extents()
ext4: create nojournal_checksum mount option
ext4: update comments regarding ext4_delete_inode()
ext4: cleanup GFP flags inside resize path
ext4: introduce aging to extent status tree
ext4: cleanup flag definitions for extent status tree
ext4: limit number of scanned extents in status tree shrinker
ext4: move handling of list of shrinkable inodes into extent status code
ext4: change LRU to round-robin in extent status tree shrinker
ext4: cache extent hole in extent status tree for ext4_da_map_blocks()
ext4: fix block reservation for bigalloc filesystems
Testcase:
xfstests generic/270
MKFS_OPTIONS="-q -I 256 -O inline_data,64bit"
Call Trace:
[<ffffffff81144c76>] lock_page+0x35/0x39 -------> DEADLOCK
[<ffffffff81145260>] pagecache_get_page+0x65/0x15a
[<ffffffff811507fc>] truncate_inode_pages_range+0x1db/0x45c
[<ffffffff8120ea63>] ? ext4_da_get_block_prep+0x439/0x4b6
[<ffffffff811b29b7>] ? __block_write_begin+0x284/0x29c
[<ffffffff8120e62a>] ? ext4_change_inode_journal_flag+0x16b/0x16b
[<ffffffff81150af0>] truncate_inode_pages+0x12/0x14
[<ffffffff81247cb4>] ext4_truncate_failed_write+0x19/0x25
[<ffffffff812488cf>] ext4_da_write_inline_data_begin+0x196/0x31c
[<ffffffff81210dad>] ext4_da_write_begin+0x189/0x302
[<ffffffff810c07ac>] ? trace_hardirqs_on+0xd/0xf
[<ffffffff810ddd13>] ? read_seqcount_begin.clone.1+0x9f/0xcc
[<ffffffff8114309d>] generic_perform_write+0xc7/0x1c6
[<ffffffff810c040e>] ? mark_held_locks+0x59/0x77
[<ffffffff811445d1>] __generic_file_write_iter+0x17f/0x1c5
[<ffffffff8120726b>] ext4_file_write_iter+0x2a5/0x354
[<ffffffff81185656>] ? file_start_write+0x2a/0x2c
[<ffffffff8107bcdb>] ? bad_area_nosemaphore+0x13/0x15
[<ffffffff811858ce>] new_sync_write+0x8a/0xb2
[<ffffffff81186e7b>] vfs_write+0xb5/0x14d
[<ffffffff81186ffb>] SyS_write+0x5c/0x8c
[<ffffffff816f2529>] system_call_fastpath+0x12/0x17
Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org>
It is ridiculous practice to scan inode block by block, this technique
applicable only for old indirect files. This takes significant amount
of time for really large files. Let's reuse ext4_fiemap which already
traverse inode-tree in most optimal meaner.
TESTCASE:
ftruncate64(fd, 0);
ftruncate64(fd, 1ULL << 40);
/* lseek will spin very long time */
lseek64(fd, 0, SEEK_DATA);
lseek64(fd, 0, SEEK_HOLE);
Original report: https://lkml.org/lkml/2014/10/16/620
Currently ext4_inline_data_fiemap ignores requested arguments (start
and len) which may lead endless loop if start != 0. Also fix incorrect
extent length determination.
ext4_da_convert_inline_data_to_extent() invokes
grab_cache_page_write_begin(). grab_cache_page_write_begin performs
memory allocation, so fs-reentrance should be prohibited because we
are inside journal transaction.
Option journal_async_commit breaks gurantees of data=ordered mode as it
sends only a single cache flush after writing a transaction commit
block. Thus even though the transaction including the commit block is
fully stored on persistent storage, file data may still linger in drives
caches and will be lost on power failure. Since all checksums match on
journal recovery, we replay the transaction thus possibly exposing stale
user data.
To fix this data exposure issue, remove the possibility to use
journal_async_commit in data=ordered mode.
The iput() function tests whether its argument is NULL and then
returns immediately. Thus the test around the call is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring <elfring@users.sourceforge.net>
Setting retval to zero is not needed in ext4_unlink.
Remove unneeded code.
Signed-off-by: Namjae Jeon <namjae.jeon@samsung.com>
Signed-off-by: Ashish Sangwan <a.sangwan@samsung.com>
This was fixed for ext3 with:
e6d8fb3 ext3: Count internal journal as bsddf overhead in ext3_statfs
but was never fixed for ext4.
With a large external journal and no used disk blocks, df comes
out negative without this, as journal blocks are added to the
overhead & subtracted from used blocks unconditionally.
path[depth].p_hdr can never be NULL for a path passed to us (and even if
it could, EXT_LAST_EXTENT() would make something != NULL from it). So
just remove the branch.
Coverity-id: 1196498
Create a mount option to disable journal checksumming (because the
metadata_csum feature turns it on by default now), and fix remount not
to allow changing the journal checksumming option, since changing the
mount options has no effect on the journal.
Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com>
ext4_delete_inode() has been renamed for a long time, update
comments for this.
Signed-off-by: Wang Shilong <wshilong@ddn.com>
We must use GFP_NOFS instead GFP_KERNEL inside ext4_mb_add_groupinfo
and ext4_calculate_overhead() because they are called from inside a
journal transaction. Call trace:
ioctl
->ext4_group_add
->journal_start
->ext4_setup_new_descs
->ext4_mb_add_groupinfo -> GFP_KERNEL
->ext4_flex_group_add
->ext4_update_super
->ext4_calculate_overhead -> GFP_KERNEL
->journal_stop
Introduce a simple aging to extent status tree. Each extent has a
REFERENCED bit which gets set when the extent is used. Shrinker then
skips entries with referenced bit set and clears the bit. Thus
frequently used extents have higher chances of staying in memory.
Currently flags for extent status tree are defined twice, once shifted
and once without a being shifted. Consolidate these definitions into one
place and make some computations automatic to make adding flags less
error prone. Compiler should be clever enough to figure out these are
constants and generate the same code.
Currently we scan extent status trees of inodes until we reclaim nr_to_scan
extents. This can however require a lot of scanning when there are lots
of delayed extents (as those cannot be reclaimed).
Change shrinker to work as shrinkers are supposed to and *scan* only
nr_to_scan extents regardless of how many extents did we actually
reclaim. We however need to be careful and avoid scanning each status
tree from the beginning - that could lead to a situation where we would
not be able to reclaim anything at all when first nr_to_scan extents in
the tree are always unreclaimable. We remember with each inode offset
where we stopped scanning and continue from there when we next come
across the inode.
Note that we also need to update places calling __es_shrink() manually
to pass reasonable nr_to_scan to have a chance of reclaiming anything and
not just 1.
Currently callers adding extents to extent status tree were responsible
for adding the inode to the list of inodes with freeable extents. This
is error prone and puts list handling in unnecessarily many places.
Just add inode to the list automatically when the first non-delay extent
is added to the tree and remove inode from the list when the last
non-delay extent is removed.
In this commit we discard the lru algorithm for inodes with extent
status tree because it takes significant effort to maintain a lru list
in extent status tree shrinker and the shrinker can take a long time to
scan this lru list in order to reclaim some objects.
We replace the lru ordering with a simple round-robin. After that we
never need to keep a lru list. That means that the list needn't be
sorted if the shrinker can not reclaim any objects in the first round.
Cc: Andreas Dilger <adilger.kernel@dilger.ca>
Signed-off-by: Zheng Liu <wenqing.lz@taobao.com>
Currently extent status tree doesn't cache extent hole when a write
looks up in extent tree to make sure whether a block has been allocated
or not. In this case, we don't put extent hole in extent cache because
later this extent might be removed and a new delayed extent might be
added back. But it will cause a defect when we do a lot of writes. If
we don't put extent hole in extent cache, the following writes also need
to access extent tree to look at whether or not a block has been
allocated. It brings a cache miss. This commit fixes this defect.
Also if the inode doesn't have any extent, this extent hole will be
cached as well.
For bigalloc filesystems we have to check whether newly requested inode
block isn't already part of a cluster for which we already have delayed
allocation reservation. This check happens in ext4_ext_map_blocks() and
that function sets EXT4_MAP_FROM_CLUSTER if that's the case. However if
ext4_da_map_blocks() finds in extent cache information about the block,
we don't call into ext4_ext_map_blocks() and thus we always end up
getting new reservation even if the space for cluster is already
reserved. This results in overreservation and premature ENOSPC reports.
Fix the problem by checking for existing cluster reservation already in
ext4_da_map_blocks(). That simplifies the logic and actually allows us
to get rid of the EXT4_MAP_FROM_CLUSTER flag completely.
ext4_ext_remove_space() can incorrectly free a partial_cluster if
EAGAIN is encountered while truncating or punching. Extent removal
should be retried in this case.
It also fails to free a partial cluster when the punched region begins
at the start of a file on that unaligned cluster and where the entire
file has not been punched. Remove the requirement that all blocks in
the file must have been freed in order to free the partial cluster.
Signed-off-by: Eric Whitney <enwlinux@gmail.com>
Add some casts and rearrange a few statements for improved readability.
Some code can also be simplified and made more readable if we set
partial_cluster to 0 rather than to a negative value when we can tell
we've hit the left edge of the punched region.
The fix in commit ad6599ab3ac9 ("ext4: fix premature freeing of
partial clusters split across leaf blocks"), intended to avoid
dereferencing an invalid extent pointer when determining whether a
partial cluster should be freed, wasn't quite good enough. Assure that
at least one extent remains at the start of the leaf once the hole has
been punched. Otherwise, the pointer to the extent to the right of the
hole will be invalid and a partial cluster will be incorrectly freed.
Set partial_cluster to 0 when we can tell we've hit the left edge of
the punched region within the leaf. This prevents incorrect freeing
of a partial cluster when ext4_ext_rm_leaf is called one last time
during extent tree traversal after the punched region has been removed.
Adjust comments to reflect code changes and a correction. Remove a bit
of dead code.
The partial_cluster variable is not always initialized correctly when
hole punching on bigalloc file systems. Although commit c06344939422
("ext4: fix partial cluster handling for bigalloc file systems")
addressed the case where the right edge of the punched region and the
next extent to its right were within the same leaf, it didn't handle
the case where the next extent to its right is in the next leaf. This
causes xfstest generic/300 to fail.
Fix this by replacing the code in c0634493922 with a more general
solution that can continue the search for the first cluster to the
right of the punched region into the next leaf if present. If found,
partial_cluster is initialized to this cluster's negative value.
There's no need to determine if that cluster is actually shared; we
simply record it so its blocks won't be freed in the event it does
happen to be shared.
Also, minimize the burden on non-bigalloc file systems with some minor
code simplification.
CC: linux-ext4@vger.kernel.org
Acked-by: "Theodore Ts'o" <tytso@mit.edu>
Acked-by: Christoph Hellwig <hch@lst.de>
Xiaoguang Wang has reported sporadic EBUSY failures of ext4/302
Unfortunetly there is nothing we can do if some other task holds BH's
refenrence. So we must return EBUSY in this case. But we can try
kicking the journal to see if the other task releases the bh reference
after the commit is complete. Also decrease false positives by
properly checking for ENOSPC and retrying the allocation after kicking
the journal --- which is done by ext4_should_retry_alloc().
[ Modified by tytso to properly check for ENOSPC. ]
ext4_ext_convert_to_initialized() can return more blocks than are
actually allocated from map->m_lblk in case where initial part of the
on-disk extent is zeroed out. Luckily this doesn't have serious
consequences because the caller currently uses the return value
only to unmap metadata buffers. Anyway this is a data
corruption/exposure problem waiting to happen so fix it.
Coverity-id: 1226848
When clearing inode journal flag, we call jbd2_journal_flush() to force
all the journalled data to their final locations. Currently we ignore
when this fails and continue clearing inode journal flag. This isn't a
big problem because when jbd2_journal_flush() fails, journal is likely
aborted anyway. But it can still lead to somewhat confusing results so
rather bail out early.
Coverity-id: 989044
When ext4_handle_dirty_dx_node() or ext4_handle_dirty_dirent_node()
fail, there's really something wrong with the fs and there's no point in
continuing further. Just return error from make_indexed_dir() in that
case. Also initialize frames array so that if we return early due to
error, dx_release() doesn't try to dereference uninitialized memory
(which could happen also due to error in do_split()).
Coverity-id: 741300
Cc: stable@vger.kernel.org
O_DIRECT flags can be toggeled via fcntl(F_SETFL). But this value checked
twice inside ext4_file_write_iter() and __generic_file_write() which
result in BUG_ON inside ext4_direct_IO.
Let's initialize iocb->private unconditionally.
TESTCASE: xfstest:generic/036 https://patchwork.ozlabs.org/patch/402445/
#TYPICAL STACK TRACE:
kernel BUG at fs/ext4/inode.c:2960!
invalid opcode: 0000 [#1] SMP
Modules linked in: brd iTCO_wdt lpc_ich mfd_core igb ptp dm_mirror dm_region_hash dm_log dm_mod
CPU: 6 PID: 5505 Comm: aio-dio-fcntl-r Not tainted 3.17.0-rc2-00176-gff5c017 #161
Hardware name: Intel Corporation W2600CR/W2600CR, BIOS SE5C600.86B.99.99.x028.061320111235 06/13/2011
task: ffff88080e95a7c0 ti: ffff88080f908000 task.ti: ffff88080f908000
RIP: 0010:[<ffffffff811fabf2>] [<ffffffff811fabf2>] ext4_direct_IO+0x162/0x3d0
RSP: 0018:ffff88080f90bb58 EFLAGS: 00010246
RAX: 0000000000000400 RBX: ffff88080fdb2a28 RCX: 00000000a802c818
RDX: 0000040000080000 RSI: ffff88080d8aeb80 RDI: 0000000000000001
RBP: ffff88080f90bbc8 R08: 0000000000000000 R09: 0000000000001581
R10: 0000000000000000 R11: 0000000000000000 R12: ffff88080d8aeb80
R13: ffff88080f90bbf8 R14: ffff88080fdb28c8 R15: ffff88080fdb2a28
FS: 00007f23b2055700(0000) GS:ffff880818400000(0000) knlGS:0000000000000000
CR2: 00007f23b2045000 CR3: 000000080cedf000 CR4: 00000000000407e0
Stack:
ffff88080f90bb98 0000000000000000 7ffffffffffffffe ffff88080fdb2c30
0000000000000200 0000000000000200 0000000000000001 0000000000000200
ffff88080f90bbc8 ffff88080fdb2c30 ffff88080f90be08 0000000000000200
Call Trace:
[<ffffffff8112ca9d>] generic_file_direct_write+0xed/0x180
[<ffffffff8112f2b2>] __generic_file_write_iter+0x222/0x370
[<ffffffff811f495b>] ext4_file_write_iter+0x34b/0x400
[<ffffffff811bd709>] ? aio_run_iocb+0x239/0x410
[<ffffffff810990e5>] ? local_clock+0x25/0x30
[<ffffffff810abd94>] ? __lock_acquire+0x274/0x700
[<ffffffff811f4610>] ? ext4_unwritten_wait+0xb0/0xb0
[<ffffffff811bd756>] aio_run_iocb+0x286/0x410
[<ffffffff810ac359>] ? lock_release_holdtime+0x29/0x190
[<ffffffff811bc05b>] ? lookup_ioctx+0x4b/0xf0
[<ffffffff811bde3b>] do_io_submit+0x55b/0x740
[<ffffffff811bdcaa>] ? do_io_submit+0x3ca/0x740
[<ffffffff811be030>] SyS_io_submit+0x10/0x20
[<ffffffff815ce192>] system_call_fastpath+0x16/0x1b
Code: 01 48 8b 80 f0 01 00 00 48 8b 18 49 8b 45 10 0f 85 f1 01 00 00 48 03 45 c8 48 3b 43 48 0f 8f e3 01 00 00 49 83 7c
24 18 00 75 04 <0f> 0b eb fe f0 ff 83 ec 01 00 00 49 8b 44 24 18 8b 00 85 c0 89
RIP [<ffffffff811fabf2>] ext4_direct_IO+0x162/0x3d0
RSP <ffff88080f90bb58>
Reported-by: Sasha Levin <sasha.levin@oracle.com>
If we can't load the journal, remove the procfs files for the extent
status information file to avoid leaking resources.
ext4 does not permit changing the metadata or journal checksum feature
flag while mounted. Until we decide to support that, don't allow a
remount to change the journal_csum flag (right now we silently fail to
change anything).
If metadata checksumming is turned on for the FS, we need to tell the
journal to use checksumming too.
When we fail to load block bitmap in __ext4_new_inode() we will
dereference NULL pointer in ext4_journal_get_write_access(). So check
for error from ext4_read_block_bitmap().
Coverity-id: 989065
When there are no meta block groups update_backups() will compute the
backup block in 32-bit arithmetics thus possibly overflowing the block
number and corrupting the filesystem. OTOH filesystems without meta
block groups larger than 16 TB should be rare. Fix the problem by doing
the counting in 64-bit arithmetics.
Coverity-id: 741252
CC: stable@vger.kernel.org
Reviewed-by: Lukas Czerner <lczerner@redhat.com>
Pull vfs updates from Al Viro:
"overlayfs merge + leak fix for d_splice_alias() failure exits"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
overlayfs: embed middle into overlay_readdir_data
overlayfs: embed root into overlay_readdir_data
overlayfs: make ovl_cache_entry->name an array instead of pointer
overlayfs: don't hold ->i_mutex over opening the real directory
fix inode leaks on d_splice_alias() failure exits
fs: limit filesystem stacking depth
overlay: overlay filesystem documentation
overlayfs: implement show_options
overlayfs: add statfs support
overlay filesystem
shmem: support RENAME_WHITEOUT
ext4: support RENAME_WHITEOUT
vfs: add RENAME_WHITEOUT
vfs: add whiteout support
vfs: export check_sticky()
vfs: introduce clone_private_mount()
vfs: export __inode_permission() to modules
vfs: export do_splice_direct() to modules
vfs: add i_op->dentry_open()
Add whiteout support to ext4_rename(). A whiteout inode (chrdev/0,0) is
created before the rename takes place. The whiteout inode is added to the
old entry instead of deleting it.
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
"A large number of cleanups and bug fixes, with some (minor) journal
optimizations"
[ This got sent to me before -rc1, but was stuck in my spam folder. - Linus ]
* tag 'ext4_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (67 commits)
ext4: check s_chksum_driver when looking for bg csum presence
ext4: move error report out of atomic context in ext4_init_block_bitmap()
ext4: Replace open coded mdata csum feature to helper function
ext4: delete useless comments about ext4_move_extents
ext4: fix reservation overflow in ext4_da_write_begin
ext4: add ext4_iget_normal() which is to be used for dir tree lookups
ext4: don't orphan or truncate the boot loader inode
ext4: grab missed write_count for EXT4_IOC_SWAP_BOOT
ext4: optimize block allocation on grow indepth
ext4: get rid of code duplication
ext4: fix over-defensive complaint after journal abort
ext4: fix return value of ext4_do_update_inode
ext4: fix mmap data corruption when blocksize < pagesize
vfs: fix data corruption when blocksize < pagesize for mmaped data
ext4: fold ext4_nojournal_sops into ext4_sops
ext4: support freezing ext2 (nojournal) file systems
ext4: fold ext4_sync_fs_nojournal() into ext4_sync_fs()
ext4: don't check quota format when there are no quota files
jbd2: simplify calling convention around __jbd2_journal_clean_checkpoint_list
jbd2: avoid pointless scanning of checkpoint lists
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu
Pull percpu consistent-ops changes from Tejun Heo:
"Way back, before the current percpu allocator was implemented, static
and dynamic percpu memory areas were allocated and handled separately
and had their own accessors. The distinction has been gone for many
years now; however, the now duplicate two sets of accessors remained
with the pointer based ones - this_cpu_*() - evolving various other
operations over time. During the process, we also accumulated other
inconsistent operations.
This pull request contains Christoph's patches to clean up the
duplicate accessor situation. __get_cpu_var() uses are replaced with
with this_cpu_ptr() and __this_cpu_ptr() with raw_cpu_ptr().
Unfortunately, the former sometimes is tricky thanks to C being a bit
messy with the distinction between lvalues and pointers, which led to
a rather ugly solution for cpumask_var_t involving the introduction of
this_cpu_cpumask_var_ptr().
This converts most of the uses but not all. Christoph will follow up
with the remaining conversions in this merge window and hopefully
remove the obsolete accessors"
* 'for-3.18-consistent-ops' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (38 commits)
irqchip: Properly fetch the per cpu offset
percpu: Resolve ambiguities in __get_cpu_var/cpumask_var_t -fix
ia64: sn_nodepda cannot be assigned to after this_cpu conversion. Use __this_cpu_write.
Revert "powerpc: Replace __get_cpu_var uses"
percpu: Remove __this_cpu_ptr
clocksource: Replace __this_cpu_ptr with raw_cpu_ptr
sparc: Replace __get_cpu_var uses
avr32: Replace __get_cpu_var with __this_cpu_write
blackfin: Replace __get_cpu_var uses
tile: Use this_cpu_ptr() for hardware counters
tile: Replace __get_cpu_var uses
alpha: Replace __get_cpu_var
ia64: Replace __get_cpu_var uses
s390: cio driver &__get_cpu_var replacements
s390: Replace __get_cpu_var uses
mips: Replace __get_cpu_var uses
MIPS: Replace __get_cpu_var uses in FPU emulator.
arm: Replace __this_cpu_ptr with raw_cpu_ptr
Convert the ext4_has_group_desc_csum predicate to look for a checksum
driver instead of the metadata_csum flag and change the bg checksum
calculation function to look for GDT_CSUM before taking the crc16
path.
Without this patch, if we mount with ^uninit_bg,^metadata_csum and
later metadata_csum gets turned on by accident, the block group
checksum functions will incorrectly assume that checksumming is
enabled (metadata_csum) but that crc16 should be used
(!s_chksum_driver). This is totally wrong, so fix the predicate
and the checksum formula selection.
(Granted, if the metadata_csum feature bit gets enabled on a live FS
then something underhanded is going on, but we could at least avoid
writing garbage into the on-disk fields.)
Reviewed-by: Dmitry Monakhov <dmonakhov@openvz.org>
Error report likely result in IO so it is bad idea to do it from
atomic context.
This patch should fix following issue:
BUG: sleeping function called from invalid context at include/linux/buffer_head.h:349
in_atomic(): 1, irqs_disabled(): 0, pid: 137, name: kworker/u128:1
5 locks held by kworker/u128:1/137:
#0: ("writeback"){......}, at: [<ffffffff81085618>] process_one_work+0x228/0x4d0
#1: ((&(&wb->dwork)->work)){......}, at: [<ffffffff81085618>] process_one_work+0x228/0x4d0
#2: (jbd2_handle){......}, at: [<ffffffff81242622>] start_this_handle+0x712/0x7b0
#3: (&ei->i_data_sem){......}, at: [<ffffffff811fa387>] ext4_map_blocks+0x297/0x430
#4: (&(&bgl->locks[i].lock)->rlock){......}, at: [<ffffffff811f3180>] ext4_read_block_bitmap_nowait+0x5d0/0x630
CPU: 3 PID: 137 Comm: kworker/u128:1 Not tainted 3.17.0-rc2-00184-g82752e4 #165
Workqueue: writeback bdi_writeback_workfn (flush-1:0)
0000000000000411 ffff880813777288 ffffffff815c7fdc ffff880813777288
ffff880813a8bba0 ffff8808137772a8 ffffffff8108fb30 ffff880803e01e38
ffff880803e01e38 ffff8808137772c8 ffffffff811a8d53 ffff88080ecc6000
Call Trace:
[<ffffffff815c7fdc>] dump_stack+0x51/0x6d
[<ffffffff8108fb30>] __might_sleep+0xf0/0x100
[<ffffffff811a8d53>] __sync_dirty_buffer+0x43/0xe0
[<ffffffff811a8e03>] sync_dirty_buffer+0x13/0x20
[<ffffffff8120f581>] ext4_commit_super+0x1d1/0x230
[<ffffffff8120fa03>] save_error_info+0x23/0x30
[<ffffffff8120fd06>] __ext4_error+0xb6/0xd0
[<ffffffff8120f260>] ? ext4_group_desc_csum+0x140/0x190
[<ffffffff811f2d8c>] ext4_read_block_bitmap_nowait+0x1dc/0x630
[<ffffffff8122e23a>] ext4_mb_init_cache+0x21a/0x8f0
[<ffffffff8113ae95>] ? lru_cache_add+0x55/0x60
[<ffffffff8112e16c>] ? add_to_page_cache_lru+0x6c/0x80
[<ffffffff8122eaa0>] ext4_mb_init_group+0x190/0x280
[<ffffffff8122ec51>] ext4_mb_good_group+0xc1/0x190
[<ffffffff8123309a>] ext4_mb_regular_allocator+0x17a/0x410
[<ffffffff8122c821>] ? ext4_mb_use_preallocated+0x31/0x380
[<ffffffff81233535>] ? ext4_mb_new_blocks+0x205/0x8e0
[<ffffffff8116ed5c>] ? kmem_cache_alloc+0xfc/0x180
[<ffffffff812335b0>] ext4_mb_new_blocks+0x280/0x8e0
[<ffffffff8116f2c4>] ? __kmalloc+0x144/0x1c0
[<ffffffff81221797>] ? ext4_find_extent+0x97/0x320
[<ffffffff812257f4>] ext4_ext_map_blocks+0xbc4/0x1050
[<ffffffff811fa387>] ? ext4_map_blocks+0x297/0x430
[<ffffffff811fa3ab>] ext4_map_blocks+0x2bb/0x430
[<ffffffff81200e43>] ? ext4_init_io_end+0x23/0x50
[<ffffffff811feb44>] ext4_writepages+0x564/0xaf0
[<ffffffff815cde3b>] ? _raw_spin_unlock+0x2b/0x40
[<ffffffff810ac7bd>] ? lock_release_non_nested+0x2fd/0x3c0
[<ffffffff811a009e>] ? writeback_sb_inodes+0x10e/0x490
[<ffffffff811377e3>] do_writepages+0x23/0x40
[<ffffffff8119c8ce>] __writeback_single_inode+0x9e/0x280
[<ffffffff811a026b>] writeback_sb_inodes+0x2db/0x490
[<ffffffff811a0664>] wb_writeback+0x174/0x2d0
[<ffffffff811a0863>] wb_do_writeback+0xa3/0x200
[<ffffffff811a0a40>] bdi_writeback_workfn+0x80/0x230
[<ffffffff81085618>] ? process_one_work+0x228/0x4d0
[<ffffffff810856cd>] process_one_work+0x2dd/0x4d0
[<ffffffff81085c1d>] worker_thread+0x35d/0x460
[<ffffffff810858c0>] ? process_one_work+0x4d0/0x4d0
[<ffffffff8108a885>] kthread+0xf5/0x100
[<ffffffff8108a790>] ? __init_kthread_worker+0x70/0x70
[<ffffffff815ce2ac>] ret_from_fork+0x7c/0xb0
Besides the fact that this replacement improves code readability
it also protects from errors caused direct EXT4_S(sb)->s_es manipulation
which may result attempt to use uninitialized csum machinery.
#Testcase_BEGIN
IMG=/dev/ram0
MNT=/mnt
mkfs.ext4 $IMG
mount $IMG $MNT
#Enable feature directly on disk, on mounted fs
tune2fs -O metadata_csum $IMG
# Provoke metadata update, likey result in OOPS
touch $MNT/test
umount $MNT
#Testcase_END
# Replacement script
expression E;
- EXT4_HAS_RO_COMPAT_FEATURE(E, EXT4_FEATURE_RO_COMPAT_METADATA_CSUM)
+ ext4_has_metadata_csum(E)
https://bugzilla.kernel.org/show_bug.cgi?id=82201
In patch 'ext4: refactor ext4_move_extents code base', Dmitry Monakhov has
refactored ext4_move_extents' implementation, but forgot to update the
corresponding comments, this patch will try to delete some useless comments.
Signed-off-by: Xiaoguang Wang <wangxg.fnst@cn.fujitsu.com>
