commit 5dd214248f94d430d70e9230bda72f2654ac88a8 upstream.
The mount manpage says of the max_batch_time option,
This optimization can be turned off entirely
by setting max_batch_time to 0.
But the code doesn't do that. So fix the code to do
that.
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
commit ae0f78de2c43b6fadd007c231a352b13b5be8ed2 upstream.
Make it clear that values printed are times, and that it is error
since last fsck. Also add note about fsck version required.
Signed-off-by: Pavel Machek <pavel@ucw.cz>
Reviewed-by: Andreas Dilger <adilger@dilger.ca>
commit 61c219f5814277ecb71d64cb30297028d6665979 upstream.
The first time that we allocate from an uninitialized inode allocation
bitmap, if the block allocation bitmap is also uninitalized, we need
to get write access to the block group descriptor before we start
modifying the block group descriptor flags and updating the free block
count, etc. Otherwise, there is the potential of a bad journal
checksum (if journal checksums are enabled), and of the file system
becoming inconsistent if we crash at exactly the wrong time.
commit a93cd4cf86466caa49cfe64607bea7f0bde3f916 upstream.
Hole punching code for files with indirect blocks wrongly computed
number of blocks which need to be cleared when traversing the indirect
block tree. That could result in punching more blocks than actually
requested and thus effectively cause a data loss. For example:
fallocate -n -p 10240000 4096
will punch the range 10240000 - 12632064 instead of the range 1024000 -
10244096. Fix the calculation.
Fixes: 8bad6fc813a3a5300f51369c39d315679fd88c72
commit c5c7b8ddfbf8cb3b2291e515a34ab1b8982f5a2d upstream.
Error recovery in ext4_alloc_branch() calls ext4_forget() even for
buffer corresponding to indirect block it did not allocate. This leads
to brelse() being called twice for that buffer (once from ext4_forget()
and once from cleanup in ext4_ind_map_blocks()) leading to buffer use
count misaccounting. Eventually (but often much later because there
are other users of the buffer) we will see messages like:
VFS: brelse: Trying to free free buffer
Another manifestation of this problem is an error:
JBD2 unexpected failure: jbd2_journal_revoke: !buffer_revoked(bh);
inconsistent data on disk
The fix is easy - don't forget buffer we did not allocate. Also add an
explanatory comment because the indexing at ext4_alloc_branch() is
somewhat subtle.
commit b5b60778558cafad17bbcbf63e0310bd3c68eb17 upstream.
The variable "size" is expressed as number of blocks and not as
number of clusters, this could trigger a kernel panic when using
ext4 with the size of a cluster different from the size of a block.
Signed-off-by: Maurizio Lombardi <mlombard@redhat.com>
commit eeece469dedadf3918bad50ad80f4616a0064e90 upstream.
Tail of a page straddling inode size must be zeroed when being written
out due to POSIX requirement that modifications of mmaped page beyond
inode size must not be written to the file. ext4_bio_write_page() did
this only for blocks fully beyond inode size but didn't properly zero
blocks partially beyond inode size. Fix this.
The problem has been uncovered by mmap_11-4 test in openposix test suite
(part of LTP).
Reported-by: Xiaoguang Wang <wangxg.fnst@cn.fujitsu.com>
Fixes: 5a0dc7365c240
Fixes: bd2d0210cf22f
CC: stable@vger.kernel.org
commit 6e6358fc3c3c862bfe9a5bc029d3f8ce43dc9765 upstream.
We haven't taken i_mutex yet, so we need to use i_size_read().
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
commit ec4cb1aa2b7bae18dd8164f2e9c7c51abcf61280 upstream.
When heavily exercising xattr code the assertion that
jbd2_journal_dirty_metadata() shouldn't return error was triggered:
WARNING: at /srv/autobuild-ceph/gitbuilder.git/build/fs/jbd2/transaction.c:1237
jbd2_journal_dirty_metadata+0x1ba/0x260()
CPU: 0 PID: 8877 Comm: ceph-osd Tainted: G W 3.10.0-ceph-00049-g68d04c9 #1
Hardware name: Dell Inc. PowerEdge R410/01V648, BIOS 1.6.3 02/07/2011
ffffffff81a1d3c8 ffff880214469928 ffffffff816311b0 ffff880214469968
ffffffff8103fae0 ffff880214469958 ffff880170a9dc30 ffff8802240fbe80
0000000000000000 ffff88020b366000 ffff8802256e7510 ffff880214469978
Call Trace:
[<ffffffff816311b0>] dump_stack+0x19/0x1b
[<ffffffff8103fae0>] warn_slowpath_common+0x70/0xa0
[<ffffffff8103fb2a>] warn_slowpath_null+0x1a/0x20
[<ffffffff81267c2a>] jbd2_journal_dirty_metadata+0x1ba/0x260
[<ffffffff81245093>] __ext4_handle_dirty_metadata+0xa3/0x140
[<ffffffff812561f3>] ext4_xattr_release_block+0x103/0x1f0
[<ffffffff81256680>] ext4_xattr_block_set+0x1e0/0x910
[<ffffffff8125795b>] ext4_xattr_set_handle+0x38b/0x4a0
[<ffffffff810a319d>] ? trace_hardirqs_on+0xd/0x10
[<ffffffff81257b32>] ext4_xattr_set+0xc2/0x140
[<ffffffff81258547>] ext4_xattr_user_set+0x47/0x50
[<ffffffff811935ce>] generic_setxattr+0x6e/0x90
[<ffffffff81193ecb>] __vfs_setxattr_noperm+0x7b/0x1c0
[<ffffffff811940d4>] vfs_setxattr+0xc4/0xd0
[<ffffffff8119421e>] setxattr+0x13e/0x1e0
[<ffffffff811719c7>] ? __sb_start_write+0xe7/0x1b0
[<ffffffff8118f2e8>] ? mnt_want_write_file+0x28/0x60
[<ffffffff8118c65c>] ? fget_light+0x3c/0x130
[<ffffffff8118f1f8>] ? __mnt_want_write+0x58/0x70
[<ffffffff811946be>] SyS_fsetxattr+0xbe/0x100
[<ffffffff816407c2>] system_call_fastpath+0x16/0x1b
The reason for the warning is that buffer_head passed into
jbd2_journal_dirty_metadata() didn't have journal_head attached. This is
caused by the following race of two ext4_xattr_release_block() calls:
CPU1 CPU2
ext4_xattr_release_block() ext4_xattr_release_block()
lock_buffer(bh);
/* False */
if (BHDR(bh)->h_refcount == cpu_to_le32(1))
} else {
le32_add_cpu(&BHDR(bh)->h_refcount, -1);
unlock_buffer(bh);
lock_buffer(bh);
/* True */
get_bh(bh);
ext4_free_blocks()
jbd2_journal_forget()
jbd2_journal_unfile_buffer()
-> JH is gone
error = ext4_handle_dirty_xattr_block(handle, inode, bh);
-> triggers the warning
We fix the problem by moving ext4_handle_dirty_xattr_block() under the
buffer lock. Sadly this cannot be done in nojournal mode as that
function can call sync_dirty_buffer() which would deadlock. Luckily in
nojournal mode the race is harmless (we only dirty already freed buffer)
and thus for nojournal mode we leave the dirtying outside of the buffer
lock.
Reported-by: Sage Weil <sage@inktank.com>
commit c06344939422bbd032ac967223a7863de57496b5 upstream.
Commit 9cb00419fa, which enables hole punching for bigalloc file
systems, exposed a bug introduced by commit 6ae06ff51e in an earlier
release. When run on a bigalloc file system, xfstests generic/013, 068,
075, 083, 091, 100, 112, 127, 263, 269, and 270 fail with e2fsck errors
or cause kernel error messages indicating that previously freed blocks
are being freed again.
The latter commit optimizes the selection of the starting extent in
ext4_ext_rm_leaf() when hole punching by beginning with the extent
supplied in the path argument rather than with the last extent in the
leaf node (as is still done when truncating). However, the code in
rm_leaf that initially sets partial_cluster to track cluster sharing on
extent boundaries is only guaranteed to run if rm_leaf starts with the
last node in the leaf. Consequently, partial_cluster is not correctly
initialized when hole punching, and a cluster on the boundary of a
punched region that should be retained may instead be deallocated.
Signed-off-by: Eric Whitney <enwlinux@gmail.com>
commit ce37c42919608e96ade3748fe23c3062a0a966c5 upstream.
Commit 3779473246 breaks the return of error codes from
ext4_ext_handle_uninitialized_extents() in ext4_ext_map_blocks(). A
portion of the patch assigns that function's signed integer return
value to an unsigned int. Consequently, negatively valued error codes
are lost and can be treated as a bogus allocated block count.
commit 00a1a053ebe5febcfc2ec498bd894f035ad2aa06 upstream.
Use cmpxchg() to atomically set i_flags instead of clearing out the
S_IMMUTABLE, S_APPEND, etc. flags and then setting them from the
EXT4_IMMUTABLE_FL, EXT4_APPEND_FL flags, since this opens up a race
where an immutable file has the immutable flag cleared for a brief
window of time.
Reported-by: John Sullivan <jsrhbz@kanargh.force9.co.uk>
commit dff6efc326a4d5f305797d4a6bba14f374fdd633 upstream.
Currently notify_change directly updates i_version for size updates,
which not only is counter to how all other fields are updated through
struct iattr, but also breaks XFS, which need inode updates to happen
under its own lock, and synchronized to the structure that gets written
to the log.
Remove the update in the common code, and it to btrfs and ext4,
XFS already does a proper updaste internally and currently gets a
double update with the existing code.
IMHO this is 3.13 and -stable material and should go in through the XFS
tree.
Acked-by: Jan Kara <jack@suse.cz>
Reviewed-by: Dave Chinner <dchinner@redhat.com>
Signed-off-by: Chris Mason <clm@fb.com>
Signed-off-by: Ben Myers <bpm@sgi.com>
commit 19ea80603715d473600cd993b9987bc97d042e02 upstream.
If the i_crtime field is not present in the inode, don't leave the
field uninitialized.
Fixes: ef7f38359 ("ext4: Add nanosecond timestamps")
Reported-by: Vegard Nossum <vegard.nossum@oracle.com>
Tested-by: Vegard Nossum <vegard.nossum@oracle.com>
commit 3d2660d0c9c2f296837078c189b68a47f6b2e3b5 upstream.
The set_flexbg_block_bitmap() function assumed that the number of
blocks in a blockgroup was sb->blocksize * 8, which is normally true,
but not always! Use EXT4_BLOCKS_PER_GROUP(sb) instead, to fix block
bitmap corruption after:
mke2fs -t ext4 -g 3072 -i 4096 /dev/vdd 1G
mount -t ext4 /dev/vdd /vdd
resize2fs /dev/vdd 8G
Reported-by: Jon Bernard <jbernard@tuxion.com>
commit b93c95353413041a8cebad915a8109619f66bcc6 upstream.
If a file system has a large number of inodes per block group, all of
the metadata blocks in a flex_bg may be larger than what can fit in a
single block group. Unfortunately, ext4_alloc_group_tables() in
resize.c was never tested to see if it would handle this case
correctly, and there were a large number of bugs which caused the
following sequence to result in a BUG_ON:
kernel bug at fs/ext4/resize.c:409!
call trace:
[<ffffffff81256768>] ext4_flex_group_add+0x1448/0x1830
[<ffffffff81257de2>] ext4_resize_fs+0x7b2/0xe80
[<ffffffff8123ac50>] ext4_ioctl+0xbf0/0xf00
[<ffffffff811c111d>] do_vfs_ioctl+0x2dd/0x4b0
[<ffffffff811b9df2>] ? final_putname+0x22/0x50
[<ffffffff811c1371>] sys_ioctl+0x81/0xa0
[<ffffffff81676aa9>] system_call_fastpath+0x16/0x1b
code: c8 4c 89 df e8 41 96 f8 ff 44 89 e8 49 01 c4 44 29 6d d4 0
rip [<ffffffff81254fa1>] set_flexbg_block_bitmap+0x171/0x180
This can be reproduced with the following command sequence:
mke2fs -t ext4 -i 4096 /dev/vdd 1G
To fix this, we need to make sure the right thing happens when a block
group's inode table straddles two block groups, which means the
following bugs had to be fixed:
1) Not clearing the BLOCK_UNINIT flag in the second block group in
ext4_alloc_group_tables --- the was proximate cause of the BUG_ON.
2) Incorrectly determining how many block groups contained contiguous
free blocks in ext4_alloc_group_tables().
3) Incorrectly setting the start of the next block range to be marked
in use after a discontinuity in setup_new_flex_group_blocks().
commit 23301410972330c0ae9a8afc379ba2005e249cc6 upstream.
If an ext4 file system is created by some tool other than mke2fs
(perhaps by someone who has a pathalogical fear of the GPL) that
doesn't set one or the other of the EXT2_FLAGS_{UN}SIGNED_HASH flags,
and that file system is then mounted read-only, don't try to modify
the s_flags field. Otherwise, if dm_verity is in use, the superblock
will change, causing an dm_verity failure.
commit 30d29b119ef01776e0a301444ab24defe8d8bef3 upstream.
In swap_inode_boot_loader() we forgot to release ->i_mutex and resume
unlocked dio for inode and inode_bl if there is an error starting the
journal handle. This commit fixes this issue.
Reported-by: Ahmed Tamrawi <ahmedtamrawi@gmail.com>
Cc: Andreas Dilger <adilger.kernel@dilger.ca>
Cc: Dr. Tilmann Bubeck <t.bubeck@reinform.de>
Signed-off-by: Zheng Liu <wenqing.lz@taobao.com>
commit 09c455aaa8f47a94d5bafaa23d58365768210507 upstream.
A missing cast means that when we are truncating a file which is less
than 60 bytes, we don't clear the correct area of memory, and in fact
we can end up truncating the next inode in the inode table, or worse
yet, some other kernel data structure.
Addresses-Coverity-Id: #751987
commit d0abafac8c9162f39c4f6b2f8141b772a09b3770 upstream.
Commit f5a44db5d2 introduced a regression on filesystems created with
the bigalloc feature (cluster size > blocksize). It causes xfstests
generic/006 and /013 to fail with an unexpected JBD2 failure and
transaction abort that leaves the test file system in a read only state.
Other xfstests run on bigalloc file systems are likely to fail as well.
The cause is the accidental use of a cluster mask where a cluster
offset was needed in ext4_ext_map_blocks().
Cc: Theodore Ts'o <tytso@mit.edu>
commit 8f9ff189205a6817aee5a1f996f876541f86e07c upstream.
When using FITRIM ioctl on a file system without journal it will
only trim the block group once, no matter how many times you invoke
FITRIM ioctl and how many block you release from the block group.
It is because we only clear EXT4_GROUP_INFO_WAS_TRIMMED_BIT in journal
callback. Fix this by clearing the bit in no journal mode as well.
Signed-off-by: Lukas Czerner <lczerner@redhat.com>
Reported-by: Jorge Fábregas <jorge.fabregas@gmail.com>
commit f5a44db5d2d677dfbf12deee461f85e9ec633961 upstream.
The missing casts can cause the high 64-bits of the physical blocks to
be lost. Set up new macros which allows us to make sure the right
thing happen, even if at some point we end up supporting larger
logical block numbers.
Thanks to the Emese Revfy and the PaX security team for reporting this
issue.
Reported-by: PaX Team <pageexec@freemail.hu>
Reported-by: Emese Revfy <re.emese@gmail.com>
commit 34cf865d54813aab3497838132fb1bbd293f4054 upstream.
Akira-san has been reporting rare deadlocks of his machine when running
xfstests test 269 on ext4 filesystem. The problem turned out to be in
ext4_da_reserve_metadata() and ext4_da_reserve_space() which called
ext4_should_retry_alloc() while holding i_data_sem. Since
ext4_should_retry_alloc() can force a transaction commit, this is a
lock ordering violation and leads to deadlocks.
Fix the problem by just removing the retry loops. These functions should
just report ENOSPC to the caller (e.g. ext4_da_write_begin()) and that
function must take care of retrying after dropping all necessary locks.
Reported-and-tested-by: Akira Fujita <a-fujita@rs.jp.nec.com>
Reviewed-by: Zheng Liu <wenqing.lz@taobao.com>
commit 30fac0f75da24dd5bb43c9e911d2039a984ac815 upstream.
When the filesystem doesn't support extents (like in ext2/3
compatibility modes), there is no need to reserve any clusters. Space
estimates for writing are exact, hole punching doesn't need new
metadata, and there are no unwritten extents to convert.
This fixes a problem when filesystem still having some free space when
accessed with a native ext2/3 driver suddently reports ENOSPC when
accessed with ext4 driver.
Reported-by: Geert Uytterhoeven <geert@linux-m68k.org>
Tested-by: Geert Uytterhoeven <geert@linux-m68k.org>
Reviewed-by: Lukas Czerner <lczerner@redhat.com>
commit 5946d089379a35dda0e531710b48fca05446a196 upstream.
A corrupted ext4 may have out of order leaf extents, i.e.
extent: lblk 0--1023, len 1024, pblk 9217, flags: LEAF UNINIT
extent: lblk 1000--2047, len 1024, pblk 10241, flags: LEAF UNINIT
^^^^ overlap with previous extent
Reading such extent could hit BUG_ON() in ext4_es_cache_extent().
BUG_ON(end < lblk);
The problem is that __read_extent_tree_block() tries to cache holes as
well but assumes 'lblk' is greater than 'prev' and passes underflowed
length to ext4_es_cache_extent(). Fix it by checking for overlapping
extents in ext4_valid_extent_entries().
I hit this when fuzz testing ext4, and am able to reproduce it by
modifying the on-disk extent by hand.
Also add the check for (ee_block + len - 1) in ext4_valid_extent() to
make sure the value is not overflow.
Ran xfstests on patched ext4 and no regression.
Cc: Lukáš Czerner <lczerner@redhat.com>
Signed-off-by: Eryu Guan <guaneryu@gmail.com>
commit 4e8d2139802ce4f41936a687f06c560b12115247 upstream.
ext4_mb_put_pa should hold pa->pa_lock before accessing pa->pa_count.
While ext4_mb_use_preallocated checks pa->pa_deleted first and then
increments pa->count later, ext4_mb_put_pa decrements pa->pa_count
before holding pa->pa_lock and then sets pa->pa_deleted.
* Free sequence
ext4_mb_put_pa (1): atomic_dec_and_test pa->pa_count
ext4_mb_put_pa (2): lock pa->pa_lock
ext4_mb_put_pa (3): check pa->pa_deleted
ext4_mb_put_pa (4): set pa->pa_deleted=1
ext4_mb_put_pa (5): unlock pa->pa_lock
ext4_mb_put_pa (6): remove pa from a list
ext4_mb_pa_callback: free pa
* Use sequence
ext4_mb_use_preallocated (1): iterate over preallocation
ext4_mb_use_preallocated (2): lock pa->pa_lock
ext4_mb_use_preallocated (3): check pa->pa_deleted
ext4_mb_use_preallocated (4): increase pa->pa_count
ext4_mb_use_preallocated (5): unlock pa->pa_lock
ext4_mb_release_context: access pa
* Use-after-free sequence
[initial status] <pa->pa_deleted = 0, pa_count = 1>
[pa_count decremented] <pa->pa_deleted = 0, pa_count = 0>
[pa_count incremented] <pa->pa_deleted = 0, pa_count = 1>
[race condition!] <pa->pa_deleted = 1, pa_count = 1>
AddressSanitizer has detected use-after-free in ext4_mb_new_blocks
Bug report: http://goo.gl/rG1On3
Signed-off-by: Junho Ryu <jayr@google.com>
commit ae1495b12df1897d4f42842a7aa7276d920f6290 upstream.
While it's true that errors can only happen if there is a bug in
jbd2_journal_dirty_metadata(), if a bug does happen, we need to halt
the kernel or remount the file system read-only in order to avoid
further data loss. The ext4_journal_abort_handle() function doesn't
do any of this, and while it's likely that this call (since it doesn't
adjust refcounts) will likely result in the file system eventually
deadlocking since the current transaction will never be able to close,
it's much cleaner to call let ext4's error handling system deal with
this situation.
There's a separate bug here which is that if certain jbd2 errors
errors occur and file system is mounted errors=continue, the file
system will probably eventually end grind to a halt as described
above. But things have been this way in a long time, and usually when
we have these sorts of errors it's pretty much a disaster --- and
that's why the jbd2 layer aggressively retries memory allocations,
which is the most likely cause of these jbd2 errors.
commit dcb9917ba041866686fe152850364826c4622a36 upstream.
Reported-by: Dave Jones <davej@redhat.com>
commit 6e4ea8e33b2057b85d75175dd89b93f5e26de3bc upstream.
If we take the 2nd retry path in ext4_expand_extra_isize_ea, we
potentionally return from the function without having freed these
allocations. If we don't do the return, we over-write the previous
allocation pointers, so we leak either way.
Spotted with Coverity.
[ Fixed by tytso to set is and bs to NULL after freeing these
pointers, in case in the retry loop we later end up triggering an
error causing a jump to cleanup, at which point we could have a double
free bug. -- Ted ]
Signed-off-by: Dave Jones <davej@fedoraproject.org>
Reviewed-by: Eric Sandeen <sandeen@redhat.com>
commit 5208386c501276df18fee464e21d3c58d2d79517 upstream.
Merge conditions in ext4_setattr() handling inode size changes, also
move ext4_begin_ordered_truncate() call somewhat earlier because it
simplifies error recovery in case of failure. Also add error handling in
case i_disksize update fails.
commit 91aa11fae1cf8c2fd67be0609692ea9741cdcc43 upstream.
When jbd2_journal_dirty_metadata() returns error,
__ext4_handle_dirty_metadata() stops the handle. However callers of this
function do not count with that fact and still happily used now freed
handle. This use after free can result in various issues but very likely
we oops soon.
The motivation of adding __ext4_journal_stop() into
__ext4_handle_dirty_metadata() in commit 9ea7a0df seems to be only to
improve error reporting. So replace __ext4_journal_stop() with
ext4_journal_abort_handle() which was there before that commit and add
WARN_ON_ONCE() to dump stack to provide useful information.
commit cde2d7a796f7e895e25b43471ed658079345636d upstream.
Previously we weren't swapping only some of the extent_status LRU
fields during the processing of the EXT4_IOC_SWAP_BOOT ioctl. The
much safer thing to do is to just completely flush the extent status
tree when doing the swap.
Cc: Zheng Liu <gnehzuil.liu@gmail.com>
commit 6ae6514b33f941d3386da0dfbe2942766eab1577 upstream.
Commit 5688978 ("ext4: improve handling of conflicting mount options")
introduced incorrect messages shown while choosing wrong mount options.
First of all, both cases of incorrect mount options,
"data=journal,delalloc" and "data=journal,dioread_nolock" result in
the same error message.
Secondly, the problem above isn't solved for remount option: the
mismatched parameter is simply ignored. Moreover, ext4_msg states
that remount with options "data=journal,delalloc" succeeded, which is
not true.
To fix it up, I added a simple check after parse_options() call to
ensure that data=journal and delalloc/dioread_nolock parameters are
not present at the same time.
Signed-off-by: Piotr Sarna <p.sarna@partner.samsung.com>
Acked-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
commit 59d9fa5c2e9086db11aa287bb4030151d0095a17 upstream.
Commit 26092bf ("ext4: use a table-driven handler for mount options")
wrongly disallows the specifying the mount options nodelalloc and
data=journal simultaneously. This is incorrect; it should have only
disallowed the combination of delalloc and data=journal
simultaneously.
Reported-by: Piotr Sarna <p.sarna@partner.samsung.com>
commit 94eec0fc3520c759831763d866421b4d60b599b4 upstream.
We tested for ENOMEM instead of -ENOMEM. Oops.
commit a34eb503742fd25155fd6cff6163daacead9fbc3 upstream.
When we try to allocate an inode, and there is a race between two
CPU's trying to grab the same inode, _and_ this inode is the last free
inode in the block group, make sure the group number is bumped before
we continue searching the rest of the block groups. Otherwise, we end
up searching the current block group twice, and we end up skipping
searching the last block group. So in the unlikely situation where
almost all of the inodes are allocated, it's possible that we will
return ENOSPC even though there might be free inodes in that last
block group.
commit dd12ed144e9797094c04736f97aa27d5fe401476 upstream.
Without this, module can't be reloaded.
[ 500.521980] kmem_cache_sanity_check (ext4_extent_status): Cache name already exists.
commit 8acd5e9b1217e58a57124d9e225afa12efeae20d upstream.
Previously ext4_ext_truncate() was ignoring potential error returns
from ext4_es_remove_extent() and ext4_ext_remove_space(). This can
lead to the on-diks extent tree and the extent status tree cache
getting out of sync, which is particuarlly bad, and can lead to file
system corruption and potential data loss.
commit e7676a704ee0a1ef71a6b23760b5a8f6896cb1a1 upstream.
The filesystem should not be marked inconsistent if ext4_free_blocks()
is not able to allocate memory. Unfortunately some callers (most
notably ext4_truncate) don't have a way to reflect an error back up to
the VFS. And even if we did, most userspace applications won't deal
with most system calls returning ENOMEM anyway.
Reported-by: Nagachandra P <nagachandra@gmail.com>
commit ad065dd01662ae22138899e6b1c8eeb3a529964f upstream.
We now print mount options in a generic fashion in
ext4_show_options(), so we shouldn't be explicitly printing the
{usr,grp}quota options in ext4_show_quota_options().
Without this patch, /proc/mounts can look like this:
/dev/vdb /vdb ext4 rw,relatime,quota,usrquota,data=ordered,usrquota 0 0
commit 960fd856fdc3b08b3638f3f9b6b4bfceb77660c7 upstream.
The function ext4_get_group_number() was introduced as an optimization
in commit bd86298e60b8. Unfortunately, this commit incorrectly
calculate the group number for file systems with a 1k block size (when
s_first_data_block is 1 instead of zero). This could cause the
following kernel BUG:
[ 568.877799] ------------[ cut here ]------------
[ 568.877833] kernel BUG at fs/ext4/mballoc.c:3728!
[ 568.877840] Oops: Exception in kernel mode, sig: 5 [#1]
[ 568.877845] SMP NR_CPUS=32 NUMA pSeries
[ 568.877852] Modules linked in: binfmt_misc
[ 568.877861] CPU: 1 PID: 3516 Comm: fs_mark Not tainted 3.10.0-03216-g7c6809f-dirty #1
[ 568.877867] task: c0000001fb0b8000 ti: c0000001fa954000 task.ti: c0000001fa954000
[ 568.877873] NIP: c0000000002f42a4 LR: c0000000002f4274 CTR: c000000000317ef8
[ 568.877879] REGS: c0000001fa956ed0 TRAP: 0700 Not tainted (3.10.0-03216-g7c6809f-dirty)
[ 568.877884] MSR: 8000000000029032 <SF,EE,ME,IR,DR,RI> CR: 24000428 XER: 00000000
[ 568.877902] SOFTE: 1
[ 568.877905] CFAR: c0000000002b5464
[ 568.877908]
GPR00: 0000000000000001 c0000001fa957150 c000000000c6a408 c0000001fb588000
GPR04: 0000000000003fff c0000001fa9571c0 c0000001fa9571c4 000138098c50625f
GPR08: 1301200000000000 0000000000000002 0000000000000001 0000000000000000
GPR12: 0000000024000422 c00000000f33a300 0000000000008000 c0000001fa9577f0
GPR16: c0000001fb7d0100 c000000000c29190 c0000000007f46e8 c000000000a14672
GPR20: 0000000000000001 0000000000000008 ffffffffffffffff 0000000000000000
GPR24: 0000000000000100 c0000001fa957278 c0000001fdb2bc78 c0000001fa957288
GPR28: 0000000000100100 c0000001fa957288 c0000001fb588000 c0000001fdb2bd10
[ 568.877993] NIP [c0000000002f42a4] .ext4_mb_release_group_pa+0xec/0x1c0
[ 568.877999] LR [c0000000002f4274] .ext4_mb_release_group_pa+0xbc/0x1c0
[ 568.878004] Call Trace:
[ 568.878008] [c0000001fa957150] [c0000000002f4274] .ext4_mb_release_group_pa+0xbc/0x1c0 (unreliable)
[ 568.878017] [c0000001fa957200] [c0000000002fb070] .ext4_mb_discard_lg_preallocations+0x394/0x444
[ 568.878025] [c0000001fa957340] [c0000000002fb45c] .ext4_mb_release_context+0x33c/0x734
[ 568.878032] [c0000001fa957440] [c0000000002fbcf8] .ext4_mb_new_blocks+0x4a4/0x5f4
[ 568.878039] [c0000001fa957510] [c0000000002ef56c] .ext4_ext_map_blocks+0xc28/0x1178
[ 568.878047] [c0000001fa957640] [c0000000002c1a94] .ext4_map_blocks+0x2c8/0x490
[ 568.878054] [c0000001fa957730] [c0000000002c536c] .ext4_writepages+0x738/0xc60
[ 568.878062] [c0000001fa957950] [c000000000168a78] .do_writepages+0x5c/0x80
[ 568.878069] [c0000001fa9579d0] [c00000000015d1c4] .__filemap_fdatawrite_range+0x88/0xb0
[ 568.878078] [c0000001fa957aa0] [c00000000015d23c] .filemap_write_and_wait_range+0x50/0xfc
[ 568.878085] [c0000001fa957b30] [c0000000002b8edc] .ext4_sync_file+0x220/0x3c4
[ 568.878092] [c0000001fa957be0] [c0000000001f849c] .vfs_fsync_range+0x64/0x80
[ 568.878098] [c0000001fa957c70] [c0000000001f84f0] .vfs_fsync+0x38/0x4c
[ 568.878105] [c0000001fa957d00] [c0000000001f87f4] .do_fsync+0x54/0x90
[ 568.878111] [c0000001fa957db0] [c0000000001f8894] .SyS_fsync+0x28/0x3c
[ 568.878120] [c0000001fa957e30] [c000000000009c88] syscall_exit+0x0/0x7c
[ 568.878125] Instruction dump:
[ 568.878130] 60000000 813d0034 81610070 38000000 7f8b4800 419e001c 813f007c 7d2bfe70
[ 568.878144] 7d604a78 7c005850 54000ffe 7c0007b4 <0b000000> e8a10076 e87f0090 7fa4eb78
[ 568.878160] ---[ end trace 594d911d9654770b ]---
In addition fix the STD_GROUP optimization so that it works for
bigalloc file systems as well.
Reported-by: Li Zhong <lizhongfs@gmail.com>
commit 8af8eecc1331dbf5e8c662022272cf667e213da5 upstream.
The arithmetics adding delalloc blocks to the number of used blocks in
ext4_getattr() can easily overflow on 32-bit archs as we first multiply
number of blocks by blocksize and then divide back by 512. Make the
arithmetics more clever and also use proper type (unsigned long long
instead of unsigned long).
commit a60697f411eb365fb09e639e6f183fe33d1eb796 upstream.
On 32-bit architectures with 32-bit sector_t computation of data offset
in ext4_xattr_fiemap() can overflow resulting in reporting bogus data
location. Fix the problem by typing block number to proper type before
shifting.
commit e7293fd146846e2a44d29e0477e0860c60fb856b upstream.
ext4_lblk_t is just u32 so multiplying it by blocksize can easily
overflow for files larger than 4 GB. Fix that by properly typing the
block offsets before shifting.
commit eaf3793728d07d995f1e74250b2d0005f7ae98b5 upstream.
On 32-bit archs when sector_t is defined as 32-bit the logic computing
data offset in ext4_inline_data_fiemap(). Fix that by properly typing
the shifted value.
commit 42c832debbbf819f6c4ad8601baa559c44105ba4 upstream.
The function ext4_write_inline_data_end() can return an error. So we
need to assign it to a signed integer variable to check for an error
return (since copied is an unsigned int).
Cc: Zheng Liu <wenqing.lz@taobao.com>
commit 64cb927371cd2ec43758d8a094a003d27bc3d0dc upstream.
Both ext3 and ext4 htree_dirblock_to_tree() is just filling the
in-core rbtree for use by call_filldir(). All updates of ->f_pos are
done by the latter; bumping it here (on error) is obviously wrong - we
might very well have it nowhere near the block we'd found an error in.
commit 6ca792edc13c409e8d4eb9001e048264c6a2eb64 upstream.
Subtracting the number of the first data block places the superblock
backups one block too early, corrupting the file system. When the block
size is larger than 1K, the first data block is 0, so the subtraction
has no effect and no corruption occurs.
Signed-off-by: Maarten ter Huurne <maarten@treewalker.org>
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4
Pull ext4 update from Ted Ts'o:
"Fixed regressions (two stability regressions and a performance
regression) introduced during the 3.10-rc1 merge window.
Also included is a bug fix relating to allocating blocks after
resizing an ext3 file system when using the ext4 file system driver"
* tag 'ext4_for_linus_stable' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4:
jbd,jbd2: fix oops in jbd2_journal_put_journal_head()
ext4: revert "ext4: use io_end for multiple bios"
ext4: limit group search loop for non-extent files
ext4: fix fio regression
This reverts commit 4eec708d263f0ee10861d69251708a225b64cac7.
Multiple users have reported crashes which is apparently caused by
this commit. Thanks to Dmitry Monakhov for bisecting it.
Cc: Dmitry Monakhov <dmonakhov@openvz.org>
Cc: Jan Kara <jack@suse.cz>
