path: root/fs/f2fs/Kconfig
2012-12-11f2fs: resolve build failuresJaegeuk Kim
There exist two build failures reported by Randy Dunlap as follows. (on i386) a. (config-r8857) ERROR: "f2fs_xattr_advise_handler" [fs/f2fs/f2fs.ko] undefined! Key configs in (config-r8857) are as follows. CONFIG_F2FS_FS=m # CONFIG_F2FS_STAT_FS is not set CONFIG_F2FS_FS_XATTR=y # CONFIG_F2FS_FS_POSIX_ACL is not set The error was occurred due to the function location that we made a mistake. Recently we added a new functionality for users to indicate cold files explicitly through xattr operations (i.e., f2fs_xattr_advise_handler). This handler should have been added in xattr.c instead of acl.c in order to avoid an undefined operation like in this case where XATTR is set and ACL is not set. b. (config-r8855) fs/f2fs/file.c: In function 'f2fs_vm_page_mkwrite': fs/f2fs/file.c:97:2: error: implicit declaration of function 'block_page_mkwrite_return' Key config in (config-r8855) is CONFIG_BLOCK. Obviously, f2fs works on top of the block device so that we should consider carefully a sort of config dependencies. The reason why this error was occurred was that f2fs_vm_page_mkwrite() calls block_page_mkwrite_return() which is enalbed only if CONFIG_BLOCK is set. Reported-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net>
2012-12-11f2fs: update Kconfig and MakefileJaegeuk Kim
This adds Makefile and Kconfig for f2fs, and updates Makefile and Kconfig files in the fs directory. Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
