commit 1f0d5c911b64165c9754139a26c8c2fad352c132 upstream.
We expect 64-bit calculation result from below statement, however
in 32-bit machine, looped left shift operation on pgoff_t type
variable may cause overflow issue, fix it by forcing type cast.
page->index << PAGE_SHIFT;
Fixes: 26de9b117130 ("f2fs: avoid unnecessary updating inode during fsync")
Fixes: 0a2aa8fbb969 ("f2fs: refactor __exchange_data_block for speed up")
Signed-off-by: Chao Yu <yuchao0@huawei.com>
Signed-off-by: Jaegeuk Kim <jaegeuk@kernel.org>
[ Upstream commit 2a60637f06ac94869b2e630eaf837110d39bf291 ]
As Eric reported:
RENAME_EXCHANGE support was just added to fsstress in xfstests:
commit 65dfd40a97b6bbbd2a22538977bab355c5bc0f06
Author: kaixuxia <xiakaixu1987@gmail.com>
Date: Thu Oct 31 14:41:48 2019 +0800
fsstress: add EXCHANGE renameat2 support
This is causing xfstest generic/579 to fail due to fsck.f2fs reporting errors.
I'm not sure what the problem is, but it still happens even with all the
fs-verity stuff in the test commented out, so that the test just runs fsstress.
generic/579 23s ... [10:02:25]
[ 7.745370] run fstests generic/579 at 2019-11-04 10:02:25
_check_generic_filesystem: filesystem on /dev/vdc is inconsistent
(see /results/f2fs/results-default/generic/579.full for details)
[10:02:47]
Ran: generic/579
Failures: generic/579
Failed 1 of 1 tests
Xunit report: /results/f2fs/results-default/result.xml
Here's the contents of 579.full:
*** fsck.f2fs output ***
[ASSERT] (__chk_dots_dentries:1378) --> Bad inode number[0x24] for '..', parent parent ino is [0xd10]
The root cause is that we forgot to update directory's i_pino during
cross_rename, fix it.
Fixes: 32f9bc25cbda0 ("f2fs: support ->rename2()")
Tested-by: Eric Biggers <ebiggers@kernel.org>
[ Upstream commit 08ac9a3870f6babb2b1fff46118536ca8a71ef19 ]
Allow node type segments also to be GC'd via f2fs ioctl
F2FS_IOC_GARBAGE_COLLECT_RANGE.
Signed-off-by: Sahitya Tummala <stummala@codeaurora.org>
Reviewed-by: Chao Yu <yuchao0@huawei.com>
[ Upstream commit 67b0e42b768c9ddc3fd5ca1aee3db815cfaa635c ]
f2fs_ioc_gc_range skips blocks_per_seg each time, however, f2fs_gc moves
blocks of section each time, so fix it from segment to section.
Signed-off-by: Yunlong Song <yunlong.song@huawei.com>
[ Upstream commit d6c66cd19ef322fe0d51ba09ce1b7f386acab04a ]
When sbi->segs_per_sec > 1, and if some segno has 0 valid blocks before
gc starts, do_garbage_collect will skip counting seg_freed++, and this
will cause seg_freed < sbi->segs_per_sec and finally skip sec_freed++.
[ Upstream commit b32e019049e959ee10ec359893c9dd5d057dad55 ]
If user change inode's i_flags via ioctl, let's add it into global
dirty list, so that checkpoint can guarantee its persistence before
fsync, it can make checkpoint keeping strong consistency.
[ Upstream commit 2baf07818549c8bb8d7b3437e889b86eab56d38e ]
We need to drop PG_checked flag on page as well when we clear PG_uptodate
flag, in order to avoid treating the page as GCing one later.
Signed-off-by: Weichao Guo <guoweichao@huawei.com>
[ Upstream commit 61f7725aa148ee870436a29d3a24d5c00ab7e9af ]
This fixes overriding error number in f2fs_gc.
[ Upstream commit 4a1728cad6340bfbe17bd17fd158b2165cd99508 ]
Mark inode dirty explicitly in the end of recover_inode() to make sure
that all recoverable fields can be persisted later.
[ Upstream commit f4474aa6e5e901ee4af21f39f1b9115aaaaec503 ]
Testcase to reproduce this bug:
1. mkfs.f2fs -O extra_attr -O project_quota /dev/sdd
2. mount -t f2fs /dev/sdd /mnt/f2fs
3. touch /mnt/f2fs/file
4. sync
5. chattr -p 1 /mnt/f2fs/file
6. xfs_io -f /mnt/f2fs/file -c "fsync"
7. godown /mnt/f2fs
8. umount /mnt/f2fs
9. mount -t f2fs /dev/sdd /mnt/f2fs
10. lsattr -p /mnt/f2fs/file
0 -----------------N- /mnt/f2fs/file
But actually, we expect the correct result is:
1 -----------------N- /mnt/f2fs/file
The reason is we didn't recover inode.i_projid field during mount,
fix it.
[ Upstream commit dc4cd1257c86451cec3e8e352cc376348e4f4af4 ]
Step to reproduce this bug:
1. logon as root
2. mount -t f2fs /dev/sdd /mnt;
3. touch /mnt/file;
4. chown system /mnt/file; chgrp system /mnt/file;
5. xfs_io -f /mnt/file -c "fsync";
6. godown /mnt;
7. umount /mnt;
8. mount -t f2fs /dev/sdd /mnt;
After step 8) we will expect file's uid/gid are all system, but during
recovery, these two fields were not been recovered, fix it.
[ Upstream commit 4a70e255449c9a13eed7a6eeecc85a1ea63cef76 ]
In fill_super -> init_percpu_info, we should destroy percpu counter
in error path, otherwise memory allcoated for percpu counter will
leak.
[ Upstream commit 0e0667b625cf64243df83171bff61f9d350b9ca5 ]
After quota_off, we'll get some dirty blocks. If put_super don't have a chance
to flush them by checkpoint, it causes NULL pointer exception in end_io after
iput(node_inode). (e.g., by checkpoint=disable)
[ Upstream commit 38fb6d0ea34299d97b031ed64fe994158b6f8eb3 ]
The kernel mount_block_root() function expects -EACESS or -EINVAL for a
unmountable filesystem when trying to mount the root with different
filesystem types.
However, in 5.3-rc1 the behavior when F2FS code cannot find valid block
changed to return -EFSCORRUPTED(-EUCLEAN), and this error code makes
mount_block_root() fail when trying to probe F2FS.
When the magic number of the superblock mismatches, it has a high
probability that it's just not a F2FS. In this case return -EINVAL seems
to be a better result, and this return value can make mount_block_root()
probing work again.
Return -EINVAL when the superblock has magic mismatch, -EFSCORRUPTED in
other cases (the magic matches but the superblock cannot be recognized).
Fixes: 10f966bbf521 ("f2fs: use generic EFSBADCRC/EFSCORRUPTED")
Signed-off-by: Icenowy Zheng <icenowy@aosc.io>
[ Upstream commit 10f966bbf521bb9b2e497bbca496a5141f4071d0 ]
f2fs uses EFAULT as error number to indicate filesystem is corrupted
all the time, but generic filesystems use EUCLEAN for such condition,
we need to change to follow others.
This patch adds two new macros as below to wrap more generic error
code macros, and spread them in code.
EFSBADCRC EBADMSG /* Bad CRC detected */
EFSCORRUPTED EUCLEAN /* Filesystem is corrupted */
Reported-by: Pavel Machek <pavel@ucw.cz>
Acked-by: Pavel Machek <pavel@ucw.cz>
[ Upstream commit c854f4d681365498f53ba07843a16423625aa7e9 ]
As Jungyeon Reported in bugzilla:
https://bugzilla.kernel.org/show_bug.cgi?id=203233
- Reproduces
gcc poc_13.c
./run.sh f2fs
- Kernel messages
F2FS-fs (sdb): Bitmap was wrongly set, blk:4608
kernel BUG at fs/f2fs/segment.c:2133!
RIP: 0010:update_sit_entry+0x35d/0x3e0
Call Trace:
f2fs_allocate_data_block+0x16c/0x5a0
do_write_page+0x57/0x100
f2fs_do_write_node_page+0x33/0xa0
__write_node_page+0x270/0x4e0
f2fs_sync_node_pages+0x5df/0x670
f2fs_write_checkpoint+0x364/0x13a0
f2fs_sync_fs+0xa3/0x130
f2fs_do_sync_file+0x1a6/0x810
do_fsync+0x33/0x60
__x64_sys_fsync+0xb/0x10
do_syscall_64+0x43/0x110
entry_SYSCALL_64_after_hwframe+0x44/0xa9
The testcase fails because that, in fuzzed image, current segment was
allocated with LFS type, its .next_blkoff should point to an unused
block address, but actually, its bitmap shows it's not. So during
allocation, f2fs crash when setting bitmap.
Introducing sanity_check_curseg() to check such inconsistence of
current in-used segment.
[ Upstream commit a37d0862d17411edb67677a580a6f505ec2225f6 ]
As Pavel Machek reported:
"We normally use -EUCLEAN to signal filesystem corruption. Plus, it is
good idea to report it to the syslog and mark filesystem as "needing
fsck" if filesystem can do that."
Still we need improve the original patch with:
- use unlikely keyword
- add message print
- return EUCLEAN
However, after rethink this patch, I don't think we should add such
condition check here as below reasons:
- We have already checked the field in f2fs_sanity_check_ckpt(),
- If there is fs corrupt or security vulnerability, there is nothing
to guarantee the field is integrated after the check, unless we do
the check before each of its use, however no filesystem does that.
- We only have similar check for bitmap, which was added due to there
is bitmap corruption happened on f2fs' runtime in product.
- There are so many key fields in SB/CP/NAT did have such check
after f2fs_sanity_check_{sb,cp,..}.
So I propose to revert this unneeded check.
This reverts commit 56f3ce675103e3fb9e631cfb4131fc768bc23e9a.
[ Upstream commit 1166c1f2f69117ad254189ca781287afa6e550b6 ]
As a part of the sanity checking while mounting, distinct segment number
assignment to data and node segments is verified. Fixing a small bug in
this verification between node and data segments. We need to check all
the data segments with all the node segments.
Fixes: 042be0f849e5f ("f2fs: fix to do sanity check with current segment number")
Signed-off-by: Surbhi Palande <csurbhi@gmail.com>
[ Upstream commit 56f3ce675103e3fb9e631cfb4131fc768bc23e9a ]
blkoff_off might over 512 due to fs corrupt or security
vulnerability. That should be checked before being using.
Use ENTRIES_IN_SUM to protect invalid value in cur_data_blkoff.
Signed-off-by: Ocean Chen <oceanchen@google.com>
[ Upstream commit e95bcdb2fefa129f37bd9035af1d234ca92ee4ef ]
As Jungyeon reported in bugzilla:
- Overview
When mounting the attached crafted image and running program, following errors are reported.
Additionally, it hangs on sync after running program.
The image is intentionally fuzzed from a normal f2fs image for testing.
Compile options for F2FS are as follows.
CONFIG_F2FS_FS=y
CONFIG_F2FS_STAT_FS=y
CONFIG_F2FS_FS_XATTR=y
CONFIG_F2FS_FS_POSIX_ACL=y
CONFIG_F2FS_CHECK_FS=y
- Reproduces
cc poc_13.c
mkdir test
mount -t f2fs tmp.img test
cp a.out test
cd test
sudo ./a.out
sync
- Kernel messages
kernel BUG at fs/f2fs/segment.c:2102!
RIP: 0010:update_sit_entry+0x394/0x410
Call Trace:
f2fs_allocate_data_block+0x16f/0x660
do_write_page+0x62/0x170
f2fs_write_checkpoint+0x372/0x1400
do_fsync+0x33/0x60
do_syscall_64+0x43/0xf0
sit.vblocks and sum valid block count in sit.valid_map may be
inconsistent, segment w/ zero vblocks will be treated as free
segment, while allocating in free segment, we may allocate a
free block, if its bitmap is valid previously, it can cause
kernel crash due to bitmap verification failure.
Anyway, to avoid further serious metadata inconsistence and
corruption, it is necessary and worth to detect SIT
inconsistence. So let's enable check_block_count() to verify
vblocks and valid_map all the time rather than do it only
CONFIG_F2FS_CHECK_FS is enabled.
[ Upstream commit 5e159cd349bf3a31fb7e35c23a93308eb30f4f71 ]
https://bugzilla.kernel.org/show_bug.cgi?id=203209
- Overview
When mounting the attached crafted image and running program, I got this error.
Additionally, it hangs on sync after the this script.
The image is intentionally fuzzed from a normal f2fs image for testing and I enabled option CONFIG_F2FS_CHECK_FS on.
- Reproduces
cc poc_01.c
./run.sh f2fs
sync
kernel BUG at fs/f2fs/f2fs.h:1788!
RIP: 0010:f2fs_truncate_data_blocks_range+0x342/0x350
Call Trace:
f2fs_truncate_blocks+0x36d/0x3c0
f2fs_truncate+0x88/0x110
f2fs_setattr+0x3e1/0x460
notify_change+0x2da/0x400
do_truncate+0x6d/0xb0
do_sys_ftruncate+0xf1/0x160
The reason is dec_valid_block_count() will trigger kernel panic due to
inconsistent count in between inode.i_blocks and actual block.
To avoid panic, let's just print debug message and set SBI_NEED_FSCK to
give a hint to fsck for latter repairing.
[Jaegeuk Kim: fix build warning and add unlikely]
[ Upstream commit 546d22f070d64a7b96f57c93333772085d3a5e6d ]
https://bugzilla.kernel.org/show_bug.cgi?id=203217
- Overview
Additionally, it hangs on sync after running the program.
- Reproduces
cc poc_test_05.c
mkdir test
sudo ./a.out
sync
- Messages
kernel BUG at fs/f2fs/inode.c:707!
RIP: 0010:f2fs_evict_inode+0x33f/0x3a0
Call Trace:
evict+0xba/0x180
f2fs_iget+0x598/0xdf0
f2fs_lookup+0x136/0x320
__lookup_slow+0x92/0x140
lookup_slow+0x30/0x50
walk_component+0x1c1/0x350
path_lookupat+0x62/0x200
filename_lookup+0xb3/0x1a0
do_readlinkat+0x56/0x110
__x64_sys_readlink+0x16/0x20
During inode loading, __recover_inline_status() can recovery inode status
and set inode dirty, once we failed in following process, it will fail
the check in f2fs_evict_inode, result in trigger BUG_ON().
Let's clear dirty inode in error path of f2fs_iget() to avoid panic.
[ Upstream commit 22d61e286e2d9097dae36f75ed48801056b77cac ]
https://bugzilla.kernel.org/show_bug.cgi?id=203227
- Overview
When mounting the attached crafted image, following errors are reported.
Additionally, it hangs on sync after trying to mount it.
CONFIG_F2FS_FS=y
- Reproduces
mkdir test
sync
- Messages
kernel BUG at fs/f2fs/recovery.c:549!
RIP: 0010:recover_data+0x167a/0x1780
Call Trace:
f2fs_recover_fsync_data+0x613/0x710
f2fs_fill_super+0x1043/0x1aa0
mount_bdev+0x16d/0x1a0
mount_fs+0x4a/0x170
vfs_kern_mount+0x5d/0x100
do_mount+0x200/0xcf0
ksys_mount+0x79/0xc0
__x64_sys_mount+0x1c/0x20
During recovery, if ofs_of_node is inconsistent in between recovered
node page and original checkpointed node page, let's just fail recovery
instead of making kernel panic.
commit 0916878da355650d7e77104a7ac0fa1784eca852 upstream.
For a single device mount using a zoned block device, the zone
information for the device is stored in the sbi->devs single entry
array and sbi->s_ndevs is set to 1. This differs from a single device
mount using a regular block device which does not allocate sbi->devs
and sets sbi->s_ndevs to 0.
However, sbi->s_devs == 0 condition is used throughout the code to
differentiate a single device mount from a multi-device mount where
sbi->s_ndevs is always larger than 1. This results in problems with
single zoned block device volumes as these are treated as multi-device
mounts but do not have the start_blk and end_blk information set. One
of the problem observed is skipping of zone discard issuing resulting in
write commands being issued to full zones or unaligned to a zone write
pointer.
Fix this problem by simply treating the cases sbi->s_ndevs == 0 (single
regular block device mount) and sbi->s_ndevs == 1 (single zoned block
device mount) in the same manner. This is done by introducing the
helper function f2fs_is_multi_device() and using this helper in place
of direct tests of sbi->s_ndevs value, improving code readability.
Fixes: 7bb3a371d199 ("f2fs: Fix zoned block device support")
Cc: <stable@vger.kernel.org>
Signed-off-by: Damien Le Moal <damien.lemoal@wdc.com>
[ Upstream commit 042be0f849e5fc24116d0afecfaf926eed5cac63 ]
https://bugzilla.kernel.org/show_bug.cgi?id=200219
Reproduction way:
- mount image
- run poc code
- umount image
F2FS-fs (loop1): Bitmap was wrongly set, blk:15364
kernel BUG at /home/yuchao/git/devf2fs/segment.c:2061!
invalid opcode: 0000 [#1] PREEMPT SMP
CPU: 2 PID: 17686 Comm: umount Tainted: G W O 4.18.0-rc2+ #39
Hardware name: innotek GmbH VirtualBox/VirtualBox, BIOS VirtualBox 12/01/2006
EIP: update_sit_entry+0x459/0x4e0 [f2fs]
Code: e8 1c b5 fd ff 0f 0b 0f 0b 8b 45 e4 c7 44 24 08 9c 7a 6c f8 c7 44 24 04 bc 4a 6c f8 89 44 24 0c 8b 06 89 04 24 e8 f7 b4 fd ff <0f> 0b 8b 45 e4 0f b6 d2 89 54 24 10 c7 44 24 08 60 7a 6c f8 c7 44
EAX: 00000032 EBX: 000000f8 ECX: 00000002 EDX: 00000001
ESI: d7177000 EDI: f520fe68 EBP: d6477c6c ESP: d6477c34
DS: 007b ES: 007b FS: 00d8 GS: 00e0 SS: 0068 EFLAGS: 00010282
CR0: 80050033 CR2: b7fbe000 CR3: 2a99b3c0 CR4: 000406f0
Call Trace:
f2fs_allocate_data_block+0x124/0x580 [f2fs]
do_write_page+0x78/0x150 [f2fs]
f2fs_do_write_node_page+0x25/0xa0 [f2fs]
__write_node_page+0x2bf/0x550 [f2fs]
f2fs_sync_node_pages+0x60e/0x6d0 [f2fs]
? sync_inode_metadata+0x2f/0x40
? f2fs_write_checkpoint+0x28f/0x7d0 [f2fs]
? up_write+0x1e/0x80
f2fs_write_checkpoint+0x2a9/0x7d0 [f2fs]
? mark_held_locks+0x5d/0x80
? _raw_spin_unlock_irq+0x27/0x50
kill_f2fs_super+0x68/0x90 [f2fs]
deactivate_locked_super+0x3d/0x70
deactivate_super+0x40/0x60
cleanup_mnt+0x39/0x70
__cleanup_mnt+0x10/0x20
task_work_run+0x81/0xa0
exit_to_usermode_loop+0x59/0xa7
do_fast_syscall_32+0x1f5/0x22c
entry_SYSENTER_32+0x53/0x86
EIP: 0xb7f95c51
Code: c1 1e f7 ff ff 89 e5 8b 55 08 85 d2 8b 81 64 cd ff ff 74 02 89 02 5d c3 8b 0c 24 c3 8b 1c 24 c3 90 51 52 55 89 e5 0f 34 cd 80 <5d> 5a 59 c3 90 90 90 90 8d 76 00 58 b8 77 00 00 00 cd 80 90 8d 76
EAX: 00000000 EBX: 0871ab90 ECX: bfb2cd00 EDX: 00000000
ESI: 00000000 EDI: 0871ab90 EBP: 0871ab90 ESP: bfb2cd7c
DS: 007b ES: 007b FS: 0000 GS: 0033 SS: 007b EFLAGS: 00000246
Modules linked in: f2fs(O) crc32_generic bnep rfcomm bluetooth ecdh_generic snd_intel8x0 snd_ac97_codec ac97_bus snd_pcm snd_seq_midi snd_seq_midi_event snd_rawmidi snd_seq pcbc joydev aesni_intel snd_seq_device aes_i586 snd_timer crypto_simd snd cryptd soundcore mac_hid serio_raw video i2c_piix4 parport_pc ppdev lp parport hid_generic psmouse usbhid hid e1000 [last unloaded: f2fs]
---[ end trace d423f83982cfcdc5 ]---
The reason is, different log headers using the same segment, once
one log's next block address is used by another log, it will cause
panic as above.
Main area: 24 segs, 24 secs 24 zones
- COLD data: 0, 0, 0
- WARM data: 1, 1, 1
- HOT data: 20, 20, 20
- Dir dnode: 22, 22, 22
- File dnode: 22, 22, 22
- Indir nodes: 21, 21, 21
So this patch adds sanity check to detect such condition to avoid
this issue.
[ Upstream commit 9083977dabf3833298ddcd40dee28687f1e6b483 ]
Fix below warning coming because of using mutex lock in atomic context.
BUG: sleeping function called from invalid context at kernel/locking/mutex.c:98
in_atomic(): 1, irqs_disabled(): 0, pid: 585, name: sh
Preemption disabled at: __radix_tree_preload+0x28/0x130
Call trace:
dump_backtrace+0x0/0x2b4
show_stack+0x20/0x28
dump_stack+0xa8/0xe0
___might_sleep+0x144/0x194
__might_sleep+0x58/0x8c
mutex_lock+0x2c/0x48
f2fs_trace_pid+0x88/0x14c
f2fs_set_node_page_dirty+0xd0/0x184
Do not use f2fs_radix_tree_insert() to avoid doing cond_resched() with
spin_lock() acquired.
[ Upstream commit aadcef64b22f668c1a107b86d3521d9cac915c24 ]
As Jiqun Li reported in bugzilla:
https://bugzilla.kernel.org/show_bug.cgi?id=202883
sometimes, dead lock when make system call SYS_getdents64 with fsync() is
called by another process.
monkey running on android9.0
1. task 9785 held sbi->cp_rwsem and waiting lock_page()
2. task 10349 held mm_sem and waiting sbi->cp_rwsem
3. task 9709 held lock_page() and waiting mm_sem
so this is a dead lock scenario.
task stack is show by crash tools as following
crash_arm64> bt ffffffc03c354080
PID: 9785 TASK: ffffffc03c354080 CPU: 1 COMMAND: "RxIoScheduler-3"
>> #7 [ffffffc01b50fac0] __lock_page at ffffff80081b11e8
crash-arm64> bt 10349
PID: 10349 TASK: ffffffc018b83080 CPU: 1 COMMAND: "BUGLY_ASYNC_UPL"
>> #3 [ffffffc01f8cfa40] rwsem_down_read_failed at ffffff8008a93afc
PC: 00000033 LR: 00000000 SP: 00000000 PSTATE: ffffffffffffffff
crash-arm64> bt 9709
PID: 9709 TASK: ffffffc03e7f3080 CPU: 1 COMMAND: "IntentService[A"
>> #3 [ffffffc001e67850] rwsem_down_read_failed at ffffff8008a93afc
>> #8 [ffffffc001e67b80] el1_ia at ffffff8008084fc4
PC: ffffff8008274114 [compat_filldir64+120]
LR: ffffff80083584d4 [f2fs_fill_dentries+448]
SP: ffffffc001e67b80 PSTATE: 80400145
X29: ffffffc001e67b80 X28: 0000000000000000 X27: 000000000000001a
X26: 00000000000093d7 X25: ffffffc070d52480 X24: 0000000000000008
X23: 0000000000000028 X22: 00000000d43dfd60 X21: ffffffc001e67e90
X20: 0000000000000011 X19: ffffff80093a4000 X18: 0000000000000000
X17: 0000000000000000 X16: 0000000000000000 X15: 0000000000000000
X14: ffffffffffffffff X13: 0000000000000008 X12: 0101010101010101
X11: 7f7f7f7f7f7f7f7f X10: 6a6a6a6a6a6a6a6a X9: 7f7f7f7f7f7f7f7f
X8: 0000000080808000 X7: ffffff800827409c X6: 0000000080808000
X5: 0000000000000008 X4: 00000000000093d7 X3: 000000000000001a
X2: 0000000000000011 X1: ffffffc070d52480 X0: 0000000000800238
>> #9 [ffffffc001e67be0] f2fs_fill_dentries at ffffff80083584d0
PC: 0000003c LR: 00000000 SP: 00000000 PSTATE: 000000d9
X12: f48a02ff X11: d4678960 X10: d43dfc00 X9: d4678ae4
X8: 00000058 X7: d4678994 X6: d43de800 X5: 000000d9
X4: d43dfc0c X3: d43dfc10 X2: d46799c8 X1: 00000000
X0: 00001068
Below potential deadlock will happen between three threads:
Thread A Thread B Thread C
- f2fs_do_sync_file
- f2fs_write_checkpoint
- down_write(&sbi->node_change) -- 1)
- do_page_fault
- down_write(&mm->mmap_sem) -- 2)
- do_wp_page
- f2fs_vm_page_mkwrite
- getdents64
- f2fs_read_inline_dir
- lock_page -- 3)
- f2fs_sync_node_pages
- lock_page -- 3)
- __do_map_lock
- down_read(&sbi->node_change) -- 1)
- f2fs_fill_dentries
- dir_emit
- compat_filldir64
- do_page_fault
- down_read(&mm->mmap_sem) -- 2)
Since f2fs_readdir is protected by inode.i_rwsem, there should not be
any updates in inode page, we're safe to lookup dents in inode page
without its lock held, so taking off the lock to improve concurrency
of readdir and avoid potential deadlock.
Reported-by: Jiqun Li <jiqun.li@unisoc.com>
[ Upstream commit e4589fa545e0020dbbc3c9bde35f35f949901392 ]
When there is a failure in f2fs_fill_super() after/during
the recovery of fsync'd nodes, it frees the current sbi and
retries again. This time the mount is successful, but the files
that got recovered before retry, still holds the extent tree,
whose extent nodes list is corrupted since sbi and sbi->extent_list
is freed up. The list_del corruption issue is observed when the
file system is getting unmounted and when those recoverd files extent
node is being freed up in the below context.
list_del corruption. prev->next should be fffffff1e1ef5480, but was (null)
kernel BUG at kernel/msm-4.14/lib/list_debug.c:53!
lr : __list_del_entry_valid+0x94/0xb4
pc : __list_del_entry_valid+0x94/0xb4
Call trace:
__release_extent_node+0xb0/0x114
__free_extent_tree+0x58/0x7c
f2fs_shrink_extent_tree+0xdc/0x3b0
f2fs_leave_shrinker+0x28/0x7c
f2fs_put_super+0xfc/0x1e0
generic_shutdown_super+0x70/0xf4
kill_block_super+0x2c/0x5c
kill_f2fs_super+0x44/0x50
deactivate_locked_super+0x60/0x8c
deactivate_super+0x68/0x74
cleanup_mnt+0x40/0x78
__cleanup_mnt+0x1c/0x28
task_work_run+0x48/0xd0
do_notify_resume+0x678/0xe98
work_pending+0x8/0x14
Fix this by not creating extents for those recovered files if shrinker is
not registered yet. Once mount is successful and shrinker is registered,
those files can have extents again.
[ Upstream commit f6176473a0c7472380eef72ebeb330cf9485bf0a ]
When call f2fs_acl_create_masq() failed, the caller f2fs_acl_create()
should return -EIO instead of -ENOMEM, this patch makes it consistent
with posix_acl_create() which has been fixed in commit beaf226b863a
("posix_acl: don't ignore return value of posix_acl_create_masq()").
Fixes: 83dfe53c185e ("f2fs: fix reference leaks in f2fs_acl_create")
Signed-off-by: Tiezhu Yang <kernelpatch@126.com>
[ Upstream commit 2866fb16d67992195b0526d19e65acb6640fb87f ]
The following race could lead to inconsistent SIT bitmap:
Task A Task B
block_operations
f2fs_lock_all
down_write(node_change)
down_write(node_write)
... sync ...
up_write(node_change)
f2fs_file_write_iter
set_inode_flag(FI_NO_PREALLOC)
f2fs_write_begin(index=0, has inline data)
prepare_write_begin
__do_map_lock(AIO) => down_read(node_change)
f2fs_convert_inline_page => update SIT
__do_map_lock(AIO) => up_read(node_change)
f2fs_flush_sit_entries <= inconsistent SIT
finish write checkpoint
sudden-power-off
If SPO occurs after checkpoint is finished, SIT bitmap will be set
incorrectly.
Signed-off-by: Sheng Yong <shengyong1@huawei.com>
[ Upstream commit b61ac5b720146c619c7cdf17eff2551b934399e5 ]
This patch move dir data flush to write checkpoint process, by
doing this, it may reduce some time for dir fsync.
pre:
-f2fs_do_sync_file enter
-file_write_and_wait_range <- flush & wait
-write_checkpoint
-do_checkpoint <- wait all
-f2fs_do_sync_file exit
now:
-write_checkpoint
-block_operations <- flush dir & no wait
Signed-off-by: Yunlei He <heyunlei@huawei.com>
commit 0ea295dd853e0879a9a30ab61f923c26be35b902 upstream.
The function truncate_node frees the page with f2fs_put_page. However,
the page index is read after that. So, the patch reads the index before
freeing the page.
Fixes: bf39c00a9a7f ("f2fs: drop obsolete node page when it is truncated")
Signed-off-by: Pan Bian <bianpan2016@163.com>
Signed-off-by: Sudip Mukherjee <sudipm.mukherjee@gmail.com>
commit 88960068f25fcc3759455d85460234dcc9d43fef upstream.
Treat "block_count" from struct f2fs_super_block as 64-bit little endian
value in sanity_check_raw_super() because struct f2fs_super_block
declares "block_count" as "__le64".
This fixes a bug where the superblock validation fails on big endian
devices with the following error:
F2FS-fs (sda1): Wrong segment_count / block_count (61439 > 0)
F2FS-fs (sda1): Can't find valid F2FS filesystem in 1th superblock
F2FS-fs (sda1): Can't find valid F2FS filesystem in 2th superblock
As result of this the partition cannot be mounted.
With this patch applied the superblock validation works fine and the
partition can be mounted again:
F2FS-fs (sda1): Mounted with checkpoint version = 7c84
My little endian x86-64 hardware was able to mount the partition without
this fix.
To confirm that mounting f2fs filesystems works on big endian machines
again I tested this on a 32-bit MIPS big endian (lantiq) device.
Fixes: 0cfe75c5b01199 ("f2fs: enhance sanity_check_raw_super() to avoid potential overflows")
Cc: stable@vger.kernel.org
Signed-off-by: Martin Blumenstingl <martin.blumenstingl@googlemail.com>
commit 91291e9998d208370eb8156c760691b873bd7522 upstream.
This patch adds f2fs_is_valid_blkaddr() in below functions to do sanity
check with block address to avoid pentential panic:
- f2fs_grab_read_bio()
- __written_first_block()
https://bugzilla.kernel.org/show_bug.cgi?id=200465
- Reproduce
- POC (poc.c)
#define _GNU_SOURCE
#include <sys/types.h>
#include <sys/mount.h>
#include <sys/mman.h>
#include <sys/stat.h>
#include <sys/xattr.h>
#include <dirent.h>
#include <errno.h>
#include <error.h>
#include <fcntl.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <unistd.h>
#include <linux/falloc.h>
#include <linux/loop.h>
static void activity(char *mpoint) {
char *xattr;
int err;
err = asprintf(&xattr, "%s/foo/bar/xattr", mpoint);
char buf2[113];
memset(buf2, 0, sizeof(buf2));
listxattr(xattr, buf2, sizeof(buf2));
int main(int argc, char *argv[]) {
activity(argv[1]);
return 0;
- kernel message
[ 844.718738] F2FS-fs (loop0): Mounted with checkpoint version = 2
[ 846.430929] F2FS-fs (loop0): access invalid blkaddr:1024
[ 846.431058] WARNING: CPU: 1 PID: 1249 at fs/f2fs/checkpoint.c:154 f2fs_is_valid_blkaddr+0x10f/0x160
[ 846.431059] Modules linked in: snd_hda_codec_generic snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep snd_pcm snd_timer snd input_leds joydev soundcore serio_raw i2c_piix4 mac_hid ib_iser rdma_cm iw_cm ib_cm ib_core configfs iscsi_tcp libiscsi_tcp libiscsi scsi_transport_iscsi autofs4 raid10 raid456 libcrc32c async_raid6_recov async_memcpy async_pq async_xor xor async_tx raid6_pq raid1 raid0 multipath linear qxl ttm crct10dif_pclmul crc32_pclmul drm_kms_helper ghash_clmulni_intel syscopyarea sysfillrect sysimgblt fb_sys_fops pcbc drm 8139too aesni_intel 8139cp floppy psmouse mii aes_x86_64 crypto_simd pata_acpi cryptd glue_helper
[ 846.431310] CPU: 1 PID: 1249 Comm: a.out Not tainted 4.18.0-rc3+ #1
[ 846.431312] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Ubuntu-1.8.2-1ubuntu1 04/01/2014
[ 846.431315] RIP: 0010:f2fs_is_valid_blkaddr+0x10f/0x160
[ 846.431316] Code: 00 eb ed 31 c0 83 fa 05 75 ae 48 83 ec 08 48 8b 3f 89 f1 48 c7 c2 fc 0b 0f 8b 48 c7 c6 8b d7 09 8b 88 44 24 07 e8 61 8b ff ff <0f> 0b 0f b6 44 24 07 48 83 c4 08 eb 81 4c 8b 47 10 8b 8f 38 04 00
[ 846.431347] RSP: 0018:ffff961c414a7bc0 EFLAGS: 00010282
[ 846.431349] RAX: 0000000000000000 RBX: ffffc5f787b8ea80 RCX: 0000000000000000
[ 846.431350] RDX: 0000000000000000 RSI: ffff89dfffd165d8 RDI: ffff89dfffd165d8
[ 846.431351] RBP: ffff961c414a7c20 R08: 0000000000000001 R09: 0000000000000248
[ 846.431353] R10: 0000000000000000 R11: 0000000000000248 R12: 0000000000000007
[ 846.431369] R13: ffff89dff5492800 R14: ffff89dfae3aa000 R15: ffff89dff4ff88d0
[ 846.431372] FS: 00007f882e2fb700(0000) GS:ffff89dfffd00000(0000) knlGS:0000000000000000
[ 846.431373] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 846.431374] CR2: 0000000001a88008 CR3: 00000001eb572000 CR4: 00000000000006e0
[ 846.431384] Call Trace:
[ 846.431426] f2fs_iget+0x6f4/0xe70
[ 846.431430] ? f2fs_find_entry+0x71/0x90
[ 846.431432] f2fs_lookup+0x1aa/0x390
[ 846.431452] __lookup_slow+0x97/0x150
[ 846.431459] lookup_slow+0x35/0x50
[ 846.431462] walk_component+0x1c6/0x470
[ 846.431479] ? memcg_kmem_charge_memcg+0x70/0x90
[ 846.431488] ? page_add_file_rmap+0x13/0x200
[ 846.431491] path_lookupat+0x76/0x230
[ 846.431501] ? __alloc_pages_nodemask+0xfc/0x280
[ 846.431504] filename_lookup+0xb8/0x1a0
[ 846.431534] ? _cond_resched+0x16/0x40
[ 846.431541] ? kmem_cache_alloc+0x160/0x1d0
[ 846.431549] ? path_listxattr+0x41/0xa0
[ 846.431551] path_listxattr+0x41/0xa0
[ 846.431570] do_syscall_64+0x55/0x100
[ 846.431583] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[ 846.431607] RIP: 0033:0x7f882de1c0d7
[ 846.431607] Code: f0 ff ff 73 01 c3 48 8b 0d be dd 2b 00 f7 d8 64 89 01 48 83 c8 ff c3 66 2e 0f 1f 84 00 00 00 00 00 66 90 b8 c2 00 00 00 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d 91 dd 2b 00 f7 d8 64 89 01 48
[ 846.431639] RSP: 002b:00007ffe8e66c238 EFLAGS: 00000202 ORIG_RAX: 00000000000000c2
[ 846.431641] RAX: ffffffffffffffda RBX: 0000000000000000 RCX: 00007f882de1c0d7
[ 846.431642] RDX: 0000000000000071 RSI: 00007ffe8e66c280 RDI: 0000000001a880c0
[ 846.431643] RBP: 00007ffe8e66c300 R08: 0000000001a88010 R09: 0000000000000000
[ 846.431645] R10: 00000000000001ab R11: 0000000000000202 R12: 0000000000400550
[ 846.431646] R13: 00007ffe8e66c400 R14: 0000000000000000 R15: 0000000000000000
[ 846.431648] ---[ end trace abca54df39d14f5c ]---
[ 846.431651] F2FS-fs (loop0): invalid blkaddr: 1024, type: 5, run fsck to fix.
[ 846.431762] WARNING: CPU: 1 PID: 1249 at fs/f2fs/f2fs.h:2697 f2fs_iget+0xd17/0xe70
[ 846.431763] Modules linked in: snd_hda_codec_generic snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep snd_pcm snd_timer snd input_leds joydev soundcore serio_raw i2c_piix4 mac_hid ib_iser rdma_cm iw_cm ib_cm ib_core configfs iscsi_tcp libiscsi_tcp libiscsi scsi_transport_iscsi autofs4 raid10 raid456 libcrc32c async_raid6_recov async_memcpy async_pq async_xor xor async_tx raid6_pq raid1 raid0 multipath linear qxl ttm crct10dif_pclmul crc32_pclmul drm_kms_helper ghash_clmulni_intel syscopyarea sysfillrect sysimgblt fb_sys_fops pcbc drm 8139too aesni_intel 8139cp floppy psmouse mii aes_x86_64 crypto_simd pata_acpi cryptd glue_helper
[ 846.431797] CPU: 1 PID: 1249 Comm: a.out Tainted: G W 4.18.0-rc3+ #1
[ 846.431798] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Ubuntu-1.8.2-1ubuntu1 04/01/2014
[ 846.431800] RIP: 0010:f2fs_iget+0xd17/0xe70
[ 846.431801] Code: ff ff 48 63 d8 e9 e1 f6 ff ff 48 8b 45 c8 41 b8 05 00 00 00 48 c7 c2 d8 e8 0e 8b 48 c7 c6 1d b0 0a 8b 48 8b 38 e8 f9 b4 00 00 <0f> 0b 48 8b 45 c8 f0 80 48 48 04 e9 d8 f9 ff ff 0f 0b 48 8b 43 18
[ 846.431832] RSP: 0018:ffff961c414a7bd0 EFLAGS: 00010282
[ 846.431834] RAX: 0000000000000000 RBX: ffffc5f787b8ea80 RCX: 0000000000000006
[ 846.431835] RDX: 0000000000000000 RSI: 0000000000000096 RDI: ffff89dfffd165d0
[ 846.431836] RBP: ffff961c414a7c20 R08: 0000000000000000 R09: 0000000000000273
[ 846.431837] R10: 0000000000000000 R11: ffff89dfad50ca60 R12: 0000000000000007
[ 846.431838] R13: ffff89dff5492800 R14: ffff89dfae3aa000 R15: ffff89dff4ff88d0
[ 846.431840] FS: 00007f882e2fb700(0000) GS:ffff89dfffd00000(0000) knlGS:0000000000000000
[ 846.431841] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 846.431842] CR2: 0000000001a88008 CR3: 00000001eb572000 CR4: 00000000000006e0
[ 846.431846] Call Trace:
[ 846.431850] ? f2fs_find_entry+0x71/0x90
[ 846.431853] f2fs_lookup+0x1aa/0x390
[ 846.431856] __lookup_slow+0x97/0x150
[ 846.431858] lookup_slow+0x35/0x50
[ 846.431874] walk_component+0x1c6/0x470
[ 846.431878] ? memcg_kmem_charge_memcg+0x70/0x90
[ 846.431880] ? page_add_file_rmap+0x13/0x200
[ 846.431882] path_lookupat+0x76/0x230
[ 846.431884] ? __alloc_pages_nodemask+0xfc/0x280
[ 846.431886] filename_lookup+0xb8/0x1a0
[ 846.431890] ? _cond_resched+0x16/0x40
[ 846.431891] ? kmem_cache_alloc+0x160/0x1d0
[ 846.431894] ? path_listxattr+0x41/0xa0
[ 846.431896] path_listxattr+0x41/0xa0
[ 846.431898] do_syscall_64+0x55/0x100
[ 846.431901] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[ 846.431902] RIP: 0033:0x7f882de1c0d7
[ 846.431903] Code: f0 ff ff 73 01 c3 48 8b 0d be dd 2b 00 f7 d8 64 89 01 48 83 c8 ff c3 66 2e 0f 1f 84 00 00 00 00 00 66 90 b8 c2 00 00 00 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d 91 dd 2b 00 f7 d8 64 89 01 48
[ 846.431934] RSP: 002b:00007ffe8e66c238 EFLAGS: 00000202 ORIG_RAX: 00000000000000c2
[ 846.431936] RAX: ffffffffffffffda RBX: 0000000000000000 RCX: 00007f882de1c0d7
[ 846.431937] RDX: 0000000000000071 RSI: 00007ffe8e66c280 RDI: 0000000001a880c0
[ 846.431939] RBP: 00007ffe8e66c300 R08: 0000000001a88010 R09: 0000000000000000
[ 846.431940] R10: 00000000000001ab R11: 0000000000000202 R12: 0000000000400550
[ 846.431941] R13: 00007ffe8e66c400 R14: 0000000000000000 R15: 0000000000000000
[ 846.431943] ---[ end trace abca54df39d14f5d ]---
[ 846.432033] F2FS-fs (loop0): access invalid blkaddr:1024
[ 846.432051] WARNING: CPU: 1 PID: 1249 at fs/f2fs/checkpoint.c:154 f2fs_is_valid_blkaddr+0x10f/0x160
[ 846.432051] Modules linked in: snd_hda_codec_generic snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep snd_pcm snd_timer snd input_leds joydev soundcore serio_raw i2c_piix4 mac_hid ib_iser rdma_cm iw_cm ib_cm ib_core configfs iscsi_tcp libiscsi_tcp libiscsi scsi_transport_iscsi autofs4 raid10 raid456 libcrc32c async_raid6_recov async_memcpy async_pq async_xor xor async_tx raid6_pq raid1 raid0 multipath linear qxl ttm crct10dif_pclmul crc32_pclmul drm_kms_helper ghash_clmulni_intel syscopyarea sysfillrect sysimgblt fb_sys_fops pcbc drm 8139too aesni_intel 8139cp floppy psmouse mii aes_x86_64 crypto_simd pata_acpi cryptd glue_helper
[ 846.432085] CPU: 1 PID: 1249 Comm: a.out Tainted: G W 4.18.0-rc3+ #1
[ 846.432086] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Ubuntu-1.8.2-1ubuntu1 04/01/2014
[ 846.432089] RIP: 0010:f2fs_is_valid_blkaddr+0x10f/0x160
[ 846.432089] Code: 00 eb ed 31 c0 83 fa 05 75 ae 48 83 ec 08 48 8b 3f 89 f1 48 c7 c2 fc 0b 0f 8b 48 c7 c6 8b d7 09 8b 88 44 24 07 e8 61 8b ff ff <0f> 0b 0f b6 44 24 07 48 83 c4 08 eb 81 4c 8b 47 10 8b 8f 38 04 00
[ 846.432120] RSP: 0018:ffff961c414a7900 EFLAGS: 00010286
[ 846.432122] RAX: 0000000000000000 RBX: 0000000000000400 RCX: 0000000000000006
[ 846.432123] RDX: 0000000000000000 RSI: 0000000000000096 RDI: ffff89dfffd165d0
[ 846.432124] RBP: ffff89dff5492800 R08: 0000000000000001 R09: 000000000000029d
[ 846.432125] R10: ffff961c414a7820 R11: 000000000000029d R12: 0000000000000400
[ 846.432126] R13: 0000000000000000 R14: ffff89dff4ff88d0 R15: 0000000000000000
[ 846.432128] FS: 00007f882e2fb700(0000) GS:ffff89dfffd00000(0000) knlGS:0000000000000000
[ 846.432130] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 846.432131] CR2: 0000000001a88008 CR3: 00000001eb572000 CR4: 00000000000006e0
[ 846.432135] Call Trace:
[ 846.432151] f2fs_wait_on_block_writeback+0x20/0x110
[ 846.432158] f2fs_grab_read_bio+0xbc/0xe0
[ 846.432161] f2fs_submit_page_read+0x21/0x280
[ 846.432163] f2fs_get_read_data_page+0xb7/0x3c0
[ 846.432165] f2fs_get_lock_data_page+0x29/0x1e0
[ 846.432167] f2fs_get_new_data_page+0x148/0x550
[ 846.432170] f2fs_add_regular_entry+0x1d2/0x550
[ 846.432178] ? __switch_to+0x12f/0x460
[ 846.432181] f2fs_add_dentry+0x6a/0xd0
[ 846.432184] f2fs_do_add_link+0xe9/0x140
[ 846.432186] __recover_dot_dentries+0x260/0x280
[ 846.432189] f2fs_lookup+0x343/0x390
[ 846.432193] __lookup_slow+0x97/0x150
[ 846.432195] lookup_slow+0x35/0x50
[ 846.432208] walk_component+0x1c6/0x470
[ 846.432212] ? memcg_kmem_charge_memcg+0x70/0x90
[ 846.432215] ? page_add_file_rmap+0x13/0x200
[ 846.432217] path_lookupat+0x76/0x230
[ 846.432219] ? __alloc_pages_nodemask+0xfc/0x280
[ 846.432221] filename_lookup+0xb8/0x1a0
[ 846.432224] ? _cond_resched+0x16/0x40
[ 846.432226] ? kmem_cache_alloc+0x160/0x1d0
[ 846.432228] ? path_listxattr+0x41/0xa0
[ 846.432230] path_listxattr+0x41/0xa0
[ 846.432233] do_syscall_64+0x55/0x100
[ 846.432235] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[ 846.432237] RIP: 0033:0x7f882de1c0d7
[ 846.432237] Code: f0 ff ff 73 01 c3 48 8b 0d be dd 2b 00 f7 d8 64 89 01 48 83 c8 ff c3 66 2e 0f 1f 84 00 00 00 00 00 66 90 b8 c2 00 00 00 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d 91 dd 2b 00 f7 d8 64 89 01 48
[ 846.432269] RSP: 002b:00007ffe8e66c238 EFLAGS: 00000202 ORIG_RAX: 00000000000000c2
[ 846.432271] RAX: ffffffffffffffda RBX: 0000000000000000 RCX: 00007f882de1c0d7
[ 846.432272] RDX: 0000000000000071 RSI: 00007ffe8e66c280 RDI: 0000000001a880c0
[ 846.432273] RBP: 00007ffe8e66c300 R08: 0000000001a88010 R09: 0000000000000000
[ 846.432274] R10: 00000000000001ab R11: 0000000000000202 R12: 0000000000400550
[ 846.432275] R13: 00007ffe8e66c400 R14: 0000000000000000 R15: 0000000000000000
[ 846.432277] ---[ end trace abca54df39d14f5e ]---
[ 846.432279] F2FS-fs (loop0): invalid blkaddr: 1024, type: 5, run fsck to fix.
[ 846.432376] WARNING: CPU: 1 PID: 1249 at fs/f2fs/f2fs.h:2697 f2fs_wait_on_block_writeback+0xb1/0x110
[ 846.432376] Modules linked in: snd_hda_codec_generic snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep snd_pcm snd_timer snd input_leds joydev soundcore serio_raw i2c_piix4 mac_hid ib_iser rdma_cm iw_cm ib_cm ib_core configfs iscsi_tcp libiscsi_tcp libiscsi scsi_transport_iscsi autofs4 raid10 raid456 libcrc32c async_raid6_recov async_memcpy async_pq async_xor xor async_tx raid6_pq raid1 raid0 multipath linear qxl ttm crct10dif_pclmul crc32_pclmul drm_kms_helper ghash_clmulni_intel syscopyarea sysfillrect sysimgblt fb_sys_fops pcbc drm 8139too aesni_intel 8139cp floppy psmouse mii aes_x86_64 crypto_simd pata_acpi cryptd glue_helper
[ 846.432410] CPU: 1 PID: 1249 Comm: a.out Tainted: G W 4.18.0-rc3+ #1
[ 846.432411] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Ubuntu-1.8.2-1ubuntu1 04/01/2014
[ 846.432413] RIP: 0010:f2fs_wait_on_block_writeback+0xb1/0x110
[ 846.432414] Code: 66 90 f0 ff 4b 34 74 59 5b 5d c3 48 8b 7d 00 41 b8 05 00 00 00 89 d9 48 c7 c2 d8 e8 0e 8b 48 c7 c6 1d b0 0a 8b e8 df bc fd ff <0f> 0b f0 80 4d 48 04 e9 67 ff ff ff 48 8b 03 48 c1 e8 37 83 e0 07
[ 846.432445] RSP: 0018:ffff961c414a7910 EFLAGS: 00010286
[ 846.432447] RAX: 0000000000000000 RBX: 0000000000000400 RCX: 0000000000000006
[ 846.432448] RDX: 0000000000000000 RSI: 0000000000000092 RDI: ffff89dfffd165d0
[ 846.432449] RBP: ffff89dff5492800 R08: 0000000000000000 R09: 00000000000002d1
[ 846.432450] R10: ffff961c414a7820 R11: ffff89dfad50cf80 R12: 0000000000000400
[ 846.432451] R13: 0000000000000000 R14: ffff89dff4ff88d0 R15: 0000000000000000
[ 846.432453] FS: 00007f882e2fb700(0000) GS:ffff89dfffd00000(0000) knlGS:0000000000000000
[ 846.432454] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 846.432455] CR2: 0000000001a88008 CR3: 00000001eb572000 CR4: 00000000000006e0
[ 846.432459] Call Trace:
[ 846.432463] f2fs_grab_read_bio+0xbc/0xe0
[ 846.432464] f2fs_submit_page_read+0x21/0x280
[ 846.432466] f2fs_get_read_data_page+0xb7/0x3c0
[ 846.432468] f2fs_get_lock_data_page+0x29/0x1e0
[ 846.432470] f2fs_get_new_data_page+0x148/0x550
[ 846.432473] f2fs_add_regular_entry+0x1d2/0x550
[ 846.432475] ? __switch_to+0x12f/0x460
[ 846.432477] f2fs_add_dentry+0x6a/0xd0
[ 846.432480] f2fs_do_add_link+0xe9/0x140
[ 846.432483] __recover_dot_dentries+0x260/0x280
[ 846.432485] f2fs_lookup+0x343/0x390
[ 846.432488] __lookup_slow+0x97/0x150
[ 846.432490] lookup_slow+0x35/0x50
[ 846.432505] walk_component+0x1c6/0x470
[ 846.432509] ? memcg_kmem_charge_memcg+0x70/0x90
[ 846.432511] ? page_add_file_rmap+0x13/0x200
[ 846.432513] path_lookupat+0x76/0x230
[ 846.432515] ? __alloc_pages_nodemask+0xfc/0x280
[ 846.432517] filename_lookup+0xb8/0x1a0
[ 846.432520] ? _cond_resched+0x16/0x40
[ 846.432522] ? kmem_cache_alloc+0x160/0x1d0
[ 846.432525] ? path_listxattr+0x41/0xa0
[ 846.432526] path_listxattr+0x41/0xa0
[ 846.432529] do_syscall_64+0x55/0x100
[ 846.432531] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[ 846.432533] RIP: 0033:0x7f882de1c0d7
[ 846.432533] Code: f0 ff ff 73 01 c3 48 8b 0d be dd 2b 00 f7 d8 64 89 01 48 83 c8 ff c3 66 2e 0f 1f 84 00 00 00 00 00 66 90 b8 c2 00 00 00 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d 91 dd 2b 00 f7 d8 64 89 01 48
[ 846.432565] RSP: 002b:00007ffe8e66c238 EFLAGS: 00000202 ORIG_RAX: 00000000000000c2
[ 846.432567] RAX: ffffffffffffffda RBX: 0000000000000000 RCX: 00007f882de1c0d7
[ 846.432568] RDX: 0000000000000071 RSI: 00007ffe8e66c280 RDI: 0000000001a880c0
[ 846.432569] RBP: 00007ffe8e66c300 R08: 0000000001a88010 R09: 0000000000000000
[ 846.432570] R10: 00000000000001ab R11: 0000000000000202 R12: 0000000000400550
[ 846.432571] R13: 00007ffe8e66c400 R14: 0000000000000000 R15: 0000000000000000
[ 846.432573] ---[ end trace abca54df39d14f5f ]---
[ 846.434280] BUG: unable to handle kernel NULL pointer dereference at 0000000000000008
[ 846.434424] PGD 80000001ebd3a067 P4D 80000001ebd3a067 PUD 1eb1ae067 PMD 0
[ 846.434551] Oops: 0000 [#1] SMP PTI
[ 846.434697] CPU: 0 PID: 44 Comm: kworker/u5:0 Tainted: G W 4.18.0-rc3+ #1
[ 846.434805] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Ubuntu-1.8.2-1ubuntu1 04/01/2014
[ 846.435000] Workqueue: fscrypt_read_queue decrypt_work
[ 846.435174] RIP: 0010:fscrypt_do_page_crypto+0x6e/0x2d0
[ 846.435351] Code: 00 65 48 8b 04 25 28 00 00 00 48 89 84 24 88 00 00 00 31 c0 e8 43 c2 e0 ff 49 8b 86 48 02 00 00 85 ed c7 44 24 70 00 00 00 00 <48> 8b 58 08 0f 84 14 02 00 00 48 8b 78 10 48 8b 0c 24 48 c7 84 24
[ 846.435696] RSP: 0018:ffff961c40f9bd60 EFLAGS: 00010206
[ 846.435870] RAX: 0000000000000000 RBX: ffffc5f787719b80 RCX: ffffc5f787719b80
[ 846.436051] RDX: ffffffff8b9f4b88 RSI: ffffffff8b0ae622 RDI: ffff961c40f9bdb8
[ 846.436261] RBP: 0000000000001000 R08: ffffc5f787719b80 R09: 0000000000001000
[ 846.436433] R10: 0000000000000018 R11: fefefefefefefeff R12: ffffc5f787719b80
[ 846.436562] R13: ffffc5f787719b80 R14: ffff89dff4ff88d0 R15: 0ffff89dfaddee60
[ 846.436658] FS: 0000000000000000(0000) GS:ffff89dfffc00000(0000) knlGS:0000000000000000
[ 846.436758] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 846.436898] CR2: 0000000000000008 CR3: 00000001eddd0000 CR4: 00000000000006f0
[ 846.437001] Call Trace:
[ 846.437181] ? check_preempt_wakeup+0xf2/0x230
[ 846.437276] ? check_preempt_curr+0x7c/0x90
[ 846.437370] fscrypt_decrypt_page+0x48/0x4d
[ 846.437466] __fscrypt_decrypt_bio+0x5b/0x90
[ 846.437542] decrypt_work+0x12/0x20
[ 846.437651] process_one_work+0x15e/0x3d0
[ 846.437740] worker_thread+0x4c/0x440
[ 846.437848] kthread+0xf8/0x130
[ 846.437938] ? rescuer_thread+0x350/0x350
[ 846.438022] ? kthread_associate_blkcg+0x90/0x90
[ 846.438117] ret_from_fork+0x35/0x40
[ 846.438201] Modules linked in: snd_hda_codec_generic snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep snd_pcm snd_timer snd input_leds joydev soundcore serio_raw i2c_piix4 mac_hid ib_iser rdma_cm iw_cm ib_cm ib_core configfs iscsi_tcp libiscsi_tcp libiscsi scsi_transport_iscsi autofs4 raid10 raid456 libcrc32c async_raid6_recov async_memcpy async_pq async_xor xor async_tx raid6_pq raid1 raid0 multipath linear qxl ttm crct10dif_pclmul crc32_pclmul drm_kms_helper ghash_clmulni_intel syscopyarea sysfillrect sysimgblt fb_sys_fops pcbc drm 8139too aesni_intel 8139cp floppy psmouse mii aes_x86_64 crypto_simd pata_acpi cryptd glue_helper
[ 846.438653] CR2: 0000000000000008
[ 846.438713] ---[ end trace abca54df39d14f60 ]---
[ 846.438796] RIP: 0010:fscrypt_do_page_crypto+0x6e/0x2d0
[ 846.438844] Code: 00 65 48 8b 04 25 28 00 00 00 48 89 84 24 88 00 00 00 31 c0 e8 43 c2 e0 ff 49 8b 86 48 02 00 00 85 ed c7 44 24 70 00 00 00 00 <48> 8b 58 08 0f 84 14 02 00 00 48 8b 78 10 48 8b 0c 24 48 c7 84 24
[ 846.439084] RSP: 0018:ffff961c40f9bd60 EFLAGS: 00010206
[ 846.439176] RAX: 0000000000000000 RBX: ffffc5f787719b80 RCX: ffffc5f787719b80
[ 846.440927] RDX: ffffffff8b9f4b88 RSI: ffffffff8b0ae622 RDI: ffff961c40f9bdb8
[ 846.442083] RBP: 0000000000001000 R08: ffffc5f787719b80 R09: 0000000000001000
[ 846.443284] R10: 0000000000000018 R11: fefefefefefefeff R12: ffffc5f787719b80
[ 846.444448] R13: ffffc5f787719b80 R14: ffff89dff4ff88d0 R15: 0ffff89dfaddee60
[ 846.445558] FS: 0000000000000000(0000) GS:ffff89dfffc00000(0000) knlGS:0000000000000000
[ 846.446687] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 846.447796] CR2: 0000000000000008 CR3: 00000001eddd0000 CR4: 00000000000006f0
- Location
https://elixir.bootlin.com/linux/v4.18-rc4/source/fs/crypto/crypto.c#L149
struct crypto_skcipher *tfm = ci->ci_ctfm;
Here ci can be NULL
Note that this issue maybe require CONFIG_F2FS_FS_ENCRYPTION=y to reproduce.
Reported-by Wen Xu <wen.xu@gatech.edu>
[bwh: Backported to 4.14: adjust context]
Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
commit 89d13c38501df730cbb2e02c4499da1b5187119d upstream.
This patch fixes missing up_read call.
Fixes: c9b60788fc76 ("f2fs: fix to do sanity check with block address in main area")
Cc: <stable@vger.kernel.org> # 4.19+
commit e494c2f995d6181d6e29c4927d68e0f295ecf75b upstream.
After fuzzing, cp_pack_start_sum could be corrupted, so current log's
summary info should be wrong due to loading incorrect summary block.
Then, if segment's type in current log is exceeded NR_CURSEG_TYPE, it
can lead accessing invalid dirty_i->dirty_segmap bitmap finally.
Add sanity check for cp_pack_start_sum to fix this issue.
https://bugzilla.kernel.org/show_bug.cgi?id=200419
- Reproduce
- Kernel message (f2fs-dev w/ KASAN)
[ 3117.578432] F2FS-fs (loop0): Invalid log blocks per segment (8)
[ 3117.578445] F2FS-fs (loop0): Can't find valid F2FS filesystem in 2th superblock
[ 3117.581364] F2FS-fs (loop0): invalid crc_offset: 30716
[ 3117.583564] WARNING: CPU: 1 PID: 1225 at fs/f2fs/checkpoint.c:90 __get_meta_page+0x448/0x4b0
[ 3117.583570] Modules linked in: snd_hda_codec_generic snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep snd_pcm snd_timer joydev input_leds serio_raw snd soundcore mac_hid i2c_piix4 ib_iser rdma_cm iw_cm ib_cm ib_core configfs iscsi_tcp libiscsi_tcp libiscsi scsi_transport_iscsi btrfs zstd_decompress zstd_compress xxhash raid10 raid456 async_raid6_recov async_memcpy async_pq async_xor async_tx xor raid6_pq libcrc32c raid1 raid0 multipath linear 8139too qxl ttm drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops drm crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcbc aesni_intel psmouse aes_x86_64 8139cp crypto_simd cryptd mii glue_helper pata_acpi floppy
[ 3117.584014] CPU: 1 PID: 1225 Comm: mount Not tainted 4.17.0+ #1
[ 3117.584017] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Ubuntu-1.8.2-1ubuntu1 04/01/2014
[ 3117.584022] RIP: 0010:__get_meta_page+0x448/0x4b0
[ 3117.584023] Code: 00 49 8d bc 24 84 00 00 00 e8 74 54 da ff 41 83 8c 24 84 00 00 00 08 4c 89 f6 4c 89 ef e8 c0 d9 95 00 48 89 ef e8 18 e3 00 00 <0f> 0b f0 80 4d 48 04 e9 0f fe ff ff 0f 0b 48 89 c7 48 89 04 24 e8
[ 3117.584072] RSP: 0018:ffff88018eb678c0 EFLAGS: 00010286
[ 3117.584082] RAX: ffff88018f0a6a78 RBX: ffffea0007a46600 RCX: ffffffff9314d1b2
[ 3117.584085] RDX: ffffffff00000001 RSI: 0000000000000000 RDI: ffff88018f0a6a98
[ 3117.584087] RBP: ffff88018ebe9980 R08: 0000000000000002 R09: 0000000000000001
[ 3117.584090] R10: 0000000000000001 R11: ffffed00326e4450 R12: ffff880193722200
[ 3117.584092] R13: ffff88018ebe9afc R14: 0000000000000206 R15: ffff88018eb67900
[ 3117.584096] FS: 00007f5694636840(0000) GS:ffff8801f3b00000(0000) knlGS:0000000000000000
[ 3117.584098] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 3117.584101] CR2: 00000000016f21b8 CR3: 0000000191c22000 CR4: 00000000000006e0
[ 3117.584112] Call Trace:
[ 3117.584121] ? f2fs_set_meta_page_dirty+0x150/0x150
[ 3117.584127] ? f2fs_build_segment_manager+0xbf9/0x3190
[ 3117.584133] ? f2fs_npages_for_summary_flush+0x75/0x120
[ 3117.584145] f2fs_build_segment_manager+0xda8/0x3190
[ 3117.584151] ? f2fs_get_valid_checkpoint+0x298/0xa00
[ 3117.584156] ? f2fs_flush_sit_entries+0x10e0/0x10e0
[ 3117.584184] ? map_id_range_down+0x17c/0x1b0
[ 3117.584188] ? __put_user_ns+0x30/0x30
[ 3117.584206] ? find_next_bit+0x53/0x90
[ 3117.584237] ? cpumask_next+0x16/0x20
[ 3117.584249] f2fs_fill_super+0x1948/0x2b40
[ 3117.584258] ? f2fs_commit_super+0x1a0/0x1a0
[ 3117.584279] ? sget_userns+0x65e/0x690
[ 3117.584296] ? set_blocksize+0x88/0x130
[ 3117.584302] ? f2fs_commit_super+0x1a0/0x1a0
[ 3117.584305] mount_bdev+0x1c0/0x200
[ 3117.584310] mount_fs+0x5c/0x190
[ 3117.584320] vfs_kern_mount+0x64/0x190
[ 3117.584330] do_mount+0x2e4/0x1450
[ 3117.584343] ? lockref_put_return+0x130/0x130
[ 3117.584347] ? copy_mount_string+0x20/0x20
[ 3117.584357] ? kasan_unpoison_shadow+0x31/0x40
[ 3117.584362] ? kasan_kmalloc+0xa6/0xd0
[ 3117.584373] ? memcg_kmem_put_cache+0x16/0x90
[ 3117.584377] ? __kmalloc_track_caller+0x196/0x210
[ 3117.584383] ? _copy_from_user+0x61/0x90
[ 3117.584396] ? memdup_user+0x3e/0x60
[ 3117.584401] ksys_mount+0x7e/0xd0
[ 3117.584405] __x64_sys_mount+0x62/0x70
[ 3117.584427] do_syscall_64+0x73/0x160
[ 3117.584440] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[ 3117.584455] RIP: 0033:0x7f5693f14b9a
[ 3117.584456] Code: 48 8b 0d 01 c3 2b 00 f7 d8 64 89 01 48 83 c8 ff c3 66 2e 0f 1f 84 00 00 00 00 00 0f 1f 44 00 00 49 89 ca b8 a5 00 00 00 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d ce c2 2b 00 f7 d8 64 89 01 48
[ 3117.584505] RSP: 002b:00007fff27346488 EFLAGS: 00000206 ORIG_RAX: 00000000000000a5
[ 3117.584510] RAX: ffffffffffffffda RBX: 00000000016e2030 RCX: 00007f5693f14b9a
[ 3117.584512] RDX: 00000000016e2210 RSI: 00000000016e3f30 RDI: 00000000016ee040
[ 3117.584514] RBP: 0000000000000000 R08: 0000000000000000 R09: 0000000000000013
[ 3117.584516] R10: 00000000c0ed0000 R11: 0000000000000206 R12: 00000000016ee040
[ 3117.584519] R13: 00000000016e2210 R14: 0000000000000000 R15: 0000000000000003
[ 3117.584523] ---[ end trace a8e0d899985faf31 ]---
[ 3117.685663] F2FS-fs (loop0): f2fs_check_nid_range: out-of-range nid=2, run fsck to fix.
[ 3117.685673] F2FS-fs (loop0): recover_data: ino = 2 (i_size: recover) recovered = 1, err = 0
[ 3117.685707] ==================================================================
[ 3117.685955] BUG: KASAN: slab-out-of-bounds in __remove_dirty_segment+0xdd/0x1e0
[ 3117.686175] Read of size 8 at addr ffff88018f0a63d0 by task mount/1225
[ 3117.686477] CPU: 0 PID: 1225 Comm: mount Tainted: G W 4.17.0+ #1
[ 3117.686481] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Ubuntu-1.8.2-1ubuntu1 04/01/2014
[ 3117.686483] Call Trace:
[ 3117.686494] dump_stack+0x71/0xab
[ 3117.686512] print_address_description+0x6b/0x290
[ 3117.686517] kasan_report+0x28e/0x390
[ 3117.686522] ? __remove_dirty_segment+0xdd/0x1e0
[ 3117.686527] __remove_dirty_segment+0xdd/0x1e0
[ 3117.686532] locate_dirty_segment+0x189/0x190
[ 3117.686538] f2fs_allocate_new_segments+0xa9/0xe0
[ 3117.686543] recover_data+0x703/0x2c20
[ 3117.686547] ? f2fs_recover_fsync_data+0x48f/0xd50
[ 3117.686553] ? ksys_mount+0x7e/0xd0
[ 3117.686564] ? policy_nodemask+0x1a/0x90
[ 3117.686567] ? policy_node+0x56/0x70
[ 3117.686571] ? add_fsync_inode+0xf0/0xf0
[ 3117.686592] ? blk_finish_plug+0x44/0x60
[ 3117.686597] ? f2fs_ra_meta_pages+0x38b/0x5e0
[ 3117.686602] ? find_inode_fast+0xac/0xc0
[ 3117.686606] ? f2fs_is_valid_blkaddr+0x320/0x320
[ 3117.686618] ? __radix_tree_lookup+0x150/0x150
[ 3117.686633] ? dqget+0x670/0x670
[ 3117.686648] ? pagecache_get_page+0x29/0x410
[ 3117.686656] ? kmem_cache_alloc+0x176/0x1e0
[ 3117.686660] ? f2fs_is_valid_blkaddr+0x11d/0x320
[ 3117.686664] f2fs_recover_fsync_data+0xc23/0xd50
[ 3117.686670] ? f2fs_space_for_roll_forward+0x60/0x60
[ 3117.686674] ? rb_insert_color+0x323/0x3d0
[ 3117.686678] ? f2fs_recover_orphan_inodes+0xa5/0x700
[ 3117.686683] ? proc_register+0x153/0x1d0
[ 3117.686686] ? f2fs_remove_orphan_inode+0x10/0x10
[ 3117.686695] ? f2fs_attr_store+0x50/0x50
[ 3117.686700] ? proc_create_single_data+0x52/0x60
[ 3117.686707] f2fs_fill_super+0x1d06/0x2b40
[ 3117.686728] ? f2fs_commit_super+0x1a0/0x1a0
[ 3117.686735] ? sget_userns+0x65e/0x690
[ 3117.686740] ? set_blocksize+0x88/0x130
[ 3117.686745] ? f2fs_commit_super+0x1a0/0x1a0
[ 3117.686748] mount_bdev+0x1c0/0x200
[ 3117.686753] mount_fs+0x5c/0x190
[ 3117.686758] vfs_kern_mount+0x64/0x190
[ 3117.686762] do_mount+0x2e4/0x1450
[ 3117.686769] ? lockref_put_return+0x130/0x130
[ 3117.686773] ? copy_mount_string+0x20/0x20
[ 3117.686777] ? kasan_unpoison_shadow+0x31/0x40
[ 3117.686780] ? kasan_kmalloc+0xa6/0xd0
[ 3117.686786] ? memcg_kmem_put_cache+0x16/0x90
[ 3117.686790] ? __kmalloc_track_caller+0x196/0x210
[ 3117.686795] ? _copy_from_user+0x61/0x90
[ 3117.686801] ? memdup_user+0x3e/0x60
[ 3117.686804] ksys_mount+0x7e/0xd0
[ 3117.686809] __x64_sys_mount+0x62/0x70
[ 3117.686816] do_syscall_64+0x73/0x160
[ 3117.686824] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[ 3117.686829] RIP: 0033:0x7f5693f14b9a
[ 3117.686830] Code: 48 8b 0d 01 c3 2b 00 f7 d8 64 89 01 48 83 c8 ff c3 66 2e 0f 1f 84 00 00 00 00 00 0f 1f 44 00 00 49 89 ca b8 a5 00 00 00 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d ce c2 2b 00 f7 d8 64 89 01 48
[ 3117.686887] RSP: 002b:00007fff27346488 EFLAGS: 00000206 ORIG_RAX: 00000000000000a5
[ 3117.686892] RAX: ffffffffffffffda RBX: 00000000016e2030 RCX: 00007f5693f14b9a
[ 3117.686894] RDX: 00000000016e2210 RSI: 00000000016e3f30 RDI: 00000000016ee040
[ 3117.686896] RBP: 0000000000000000 R08: 0000000000000000 R09: 0000000000000013
[ 3117.686899] R10: 00000000c0ed0000 R11: 0000000000000206 R12: 00000000016ee040
[ 3117.686901] R13: 00000000016e2210 R14: 0000000000000000 R15: 0000000000000003
[ 3117.687005] Allocated by task 1225:
[ 3117.687152] kasan_kmalloc+0xa6/0xd0
[ 3117.687157] kmem_cache_alloc_trace+0xfd/0x200
[ 3117.687161] f2fs_build_segment_manager+0x2d09/0x3190
[ 3117.687165] f2fs_fill_super+0x1948/0x2b40
[ 3117.687168] mount_bdev+0x1c0/0x200
[ 3117.687171] mount_fs+0x5c/0x190
[ 3117.687174] vfs_kern_mount+0x64/0x190
[ 3117.687177] do_mount+0x2e4/0x1450
[ 3117.687180] ksys_mount+0x7e/0xd0
[ 3117.687182] __x64_sys_mount+0x62/0x70
[ 3117.687186] do_syscall_64+0x73/0x160
[ 3117.687190] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[ 3117.687285] Freed by task 19:
[ 3117.687412] __kasan_slab_free+0x137/0x190
[ 3117.687416] kfree+0x8b/0x1b0
[ 3117.687460] ttm_bo_man_put_node+0x61/0x80 [ttm]
[ 3117.687476] ttm_bo_cleanup_refs+0x15f/0x250 [ttm]
[ 3117.687492] ttm_bo_delayed_delete+0x2f0/0x300 [ttm]
[ 3117.687507] ttm_bo_delayed_workqueue+0x17/0x50 [ttm]
[ 3117.687528] process_one_work+0x2f9/0x740
[ 3117.687531] worker_thread+0x78/0x6b0
[ 3117.687541] kthread+0x177/0x1c0
[ 3117.687545] ret_from_fork+0x35/0x40
[ 3117.687638] The buggy address belongs to the object at ffff88018f0a6300
which belongs to the cache kmalloc-192 of size 192
[ 3117.688014] The buggy address is located 16 bytes to the right of
192-byte region [ffff88018f0a6300, ffff88018f0a63c0)
[ 3117.688382] The buggy address belongs to the page:
[ 3117.688554] page:ffffea00063c2980 count:1 mapcount:0 mapping:ffff8801f3403180 index:0x0
[ 3117.688788] flags: 0x17fff8000000100(slab)
[ 3117.688944] raw: 017fff8000000100 ffffea00063c2840 0000000e0000000e ffff8801f3403180
[ 3117.689166] raw: 0000000000000000 0000000080100010 00000001ffffffff 0000000000000000
[ 3117.689386] page dumped because: kasan: bad access detected
[ 3117.689653] Memory state around the buggy address:
[ 3117.689816] ffff88018f0a6280: fb fb fb fb fb fb fb fb fc fc fc fc fc fc fc fc
[ 3117.690027] ffff88018f0a6300: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 3117.690239] >ffff88018f0a6380: 00 00 fc fc fc fc fc fc fc fc fc fc fc fc fc fc
[ 3117.690448] ^
[ 3117.690644] ffff88018f0a6400: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 3117.690868] ffff88018f0a6480: 00 00 fc fc fc fc fc fc fc fc fc fc fc fc fc fc
[ 3117.691077] ==================================================================
[ 3117.691290] Disabling lock debugging due to kernel taint
[ 3117.693893] BUG: unable to handle kernel NULL pointer dereference at 0000000000000000
[ 3117.694120] PGD 80000001f01bc067 P4D 80000001f01bc067 PUD 1d9638067 PMD 0
[ 3117.694338] Oops: 0002 [#1] SMP KASAN PTI
[ 3117.694490] CPU: 1 PID: 1225 Comm: mount Tainted: G B W 4.17.0+ #1
[ 3117.694703] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Ubuntu-1.8.2-1ubuntu1 04/01/2014
[ 3117.695073] RIP: 0010:__remove_dirty_segment+0xe2/0x1e0
[ 3117.695246] Code: c4 48 89 c7 e8 cf bb d7 ff 45 0f b6 24 24 41 83 e4 3f 44 88 64 24 07 41 83 e4 3f 4a 8d 7c e3 08 e8 b3 bc d7 ff 4a 8b 4c e3 08 <f0> 4c 0f b3 29 0f 82 94 00 00 00 48 8d bd 20 04 00 00 e8 97 bb d7
[ 3117.695793] RSP: 0018:ffff88018eb67638 EFLAGS: 00010292
[ 3117.695969] RAX: 0000000000000000 RBX: ffff88018f0a6300 RCX: 0000000000000000
[ 3117.696182] RDX: 0000000000000000 RSI: 0000000000000297 RDI: 0000000000000297
[ 3117.696391] RBP: ffff88018ebe9980 R08: ffffed003e743ebb R09: ffffed003e743ebb
[ 3117.696604] R10: 0000000000000001 R11: ffffed003e743eba R12: 0000000000000019
[ 3117.696813] R13: 0000000000000014 R14: 0000000000000320 R15: ffff88018ebe99e0
[ 3117.697032] FS: 00007f5694636840(0000) GS:ffff8801f3b00000(0000) knlGS:0000000000000000
[ 3117.697280] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 3117.702357] CR2: 00007fe89bb1a000 CR3: 0000000191c22000 CR4: 00000000000006e0
[ 3117.707235] Call Trace:
[ 3117.712077] locate_dirty_segment+0x189/0x190
[ 3117.716891] f2fs_allocate_new_segments+0xa9/0xe0
[ 3117.721617] recover_data+0x703/0x2c20
[ 3117.726316] ? f2fs_recover_fsync_data+0x48f/0xd50
[ 3117.730957] ? ksys_mount+0x7e/0xd0
[ 3117.735573] ? policy_nodemask+0x1a/0x90
[ 3117.740198] ? policy_node+0x56/0x70
[ 3117.744829] ? add_fsync_inode+0xf0/0xf0
[ 3117.749487] ? blk_finish_plug+0x44/0x60
[ 3117.754152] ? f2fs_ra_meta_pages+0x38b/0x5e0
[ 3117.758831] ? find_inode_fast+0xac/0xc0
[ 3117.763448] ? f2fs_is_valid_blkaddr+0x320/0x320
[ 3117.768046] ? __radix_tree_lookup+0x150/0x150
[ 3117.772603] ? dqget+0x670/0x670
[ 3117.777159] ? pagecache_get_page+0x29/0x410
[ 3117.781648] ? kmem_cache_alloc+0x176/0x1e0
[ 3117.786067] ? f2fs_is_valid_blkaddr+0x11d/0x320
[ 3117.790476] f2fs_recover_fsync_data+0xc23/0xd50
[ 3117.794790] ? f2fs_space_for_roll_forward+0x60/0x60
[ 3117.799086] ? rb_insert_color+0x323/0x3d0
[ 3117.803304] ? f2fs_recover_orphan_inodes+0xa5/0x700
[ 3117.807563] ? proc_register+0x153/0x1d0
[ 3117.811766] ? f2fs_remove_orphan_inode+0x10/0x10
[ 3117.815947] ? f2fs_attr_store+0x50/0x50
[ 3117.820087] ? proc_create_single_data+0x52/0x60
[ 3117.824262] f2fs_fill_super+0x1d06/0x2b40
[ 3117.828367] ? f2fs_commit_super+0x1a0/0x1a0
[ 3117.832432] ? sget_userns+0x65e/0x690
[ 3117.836500] ? set_blocksize+0x88/0x130
[ 3117.840501] ? f2fs_commit_super+0x1a0/0x1a0
[ 3117.844420] mount_bdev+0x1c0/0x200
[ 3117.848275] mount_fs+0x5c/0x190
[ 3117.852053] vfs_kern_mount+0x64/0x190
[ 3117.855810] do_mount+0x2e4/0x1450
[ 3117.859441] ? lockref_put_return+0x130/0x130
[ 3117.862996] ? copy_mount_string+0x20/0x20
[ 3117.866417] ? kasan_unpoison_shadow+0x31/0x40
[ 3117.869719] ? kasan_kmalloc+0xa6/0xd0
[ 3117.872948] ? memcg_kmem_put_cache+0x16/0x90
[ 3117.876121] ? __kmalloc_track_caller+0x196/0x210
[ 3117.879333] ? _copy_from_user+0x61/0x90
[ 3117.882467] ? memdup_user+0x3e/0x60
[ 3117.885604] ksys_mount+0x7e/0xd0
[ 3117.888700] __x64_sys_mount+0x62/0x70
[ 3117.891742] do_syscall_64+0x73/0x160
[ 3117.894692] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[ 3117.897669] RIP: 0033:0x7f5693f14b9a
[ 3117.900563] Code: 48 8b 0d 01 c3 2b 00 f7 d8 64 89 01 48 83 c8 ff c3 66 2e 0f 1f 84 00 00 00 00 00 0f 1f 44 00 00 49 89 ca b8 a5 00 00 00 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d ce c2 2b 00 f7 d8 64 89 01 48
[ 3117.906922] RSP: 002b:00007fff27346488 EFLAGS: 00000206 ORIG_RAX: 00000000000000a5
[ 3117.910159] RAX: ffffffffffffffda RBX: 00000000016e2030 RCX: 00007f5693f14b9a
[ 3117.913469] RDX: 00000000016e2210 RSI: 00000000016e3f30 RDI: 00000000016ee040
[ 3117.916764] RBP: 0000000000000000 R08: 0000000000000000 R09: 0000000000000013
[ 3117.920071] R10: 00000000c0ed0000 R11: 0000000000000206 R12: 00000000016ee040
[ 3117.923393] R13: 00000000016e2210 R14: 0000000000000000 R15: 0000000000000003
[ 3117.926680] Modules linked in: snd_hda_codec_generic snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep snd_pcm snd_timer joydev input_leds serio_raw snd soundcore mac_hid i2c_piix4 ib_iser rdma_cm iw_cm ib_cm ib_core configfs iscsi_tcp libiscsi_tcp libiscsi scsi_transport_iscsi btrfs zstd_decompress zstd_compress xxhash raid10 raid456 async_raid6_recov async_memcpy async_pq async_xor async_tx xor raid6_pq libcrc32c raid1 raid0 multipath linear 8139too qxl ttm drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops drm crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcbc aesni_intel psmouse aes_x86_64 8139cp crypto_simd cryptd mii glue_helper pata_acpi floppy
[ 3117.949979] CR2: 0000000000000000
[ 3117.954283] ---[ end trace a8e0d899985faf32 ]---
[ 3117.958575] RIP: 0010:__remove_dirty_segment+0xe2/0x1e0
[ 3117.962810] Code: c4 48 89 c7 e8 cf bb d7 ff 45 0f b6 24 24 41 83 e4 3f 44 88 64 24 07 41 83 e4 3f 4a 8d 7c e3 08 e8 b3 bc d7 ff 4a 8b 4c e3 08 <f0> 4c 0f b3 29 0f 82 94 00 00 00 48 8d bd 20 04 00 00 e8 97 bb d7
[ 3117.971789] RSP: 0018:ffff88018eb67638 EFLAGS: 00010292
[ 3117.976333] RAX: 0000000000000000 RBX: ffff88018f0a6300 RCX: 0000000000000000
[ 3117.980926] RDX: 0000000000000000 RSI: 0000000000000297 RDI: 0000000000000297
[ 3117.985497] RBP: ffff88018ebe9980 R08: ffffed003e743ebb R09: ffffed003e743ebb
[ 3117.990098] R10: 0000000000000001 R11: ffffed003e743eba R12: 0000000000000019
[ 3117.994761] R13: 0000000000000014 R14: 0000000000000320 R15: ffff88018ebe99e0
[ 3117.999392] FS: 00007f5694636840(0000) GS:ffff8801f3b00000(0000) knlGS:0000000000000000
[ 3118.004096] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 3118.008816] CR2: 00007fe89bb1a000 CR3: 0000000191c22000 CR4: 00000000000006e0
- Location
https://elixir.bootlin.com/linux/v4.18-rc3/source/fs/f2fs/segment.c#L775
if (test_and_clear_bit(segno, dirty_i->dirty_segmap[t]))
dirty_i->nr_dirty[t]--;
Here dirty_i->dirty_segmap[t] can be NULL which leads to crash in test_and_clear_bit()
Signed-off-by: Chao Yu <yuchao0@huawei.com>
Signed-off-by: Jaegeuk Kim <jaegeuk@kernel.org>
[bwh: Backported to 4.14: The function is called sanity_check_ckpt()]
commit 18dd6470c2d14d10f5a2dd926925dc80dbd3abfd upstream.
If inode.i_extra_isize was fuzzed to an abnormal value, when
calculating inline data size, the result will overflow, result
in accessing invalid memory area when operating inline data.
Let's do sanity check with i_extra_isize during inode loading
for fixing.
https://bugzilla.kernel.org/show_bug.cgi?id=200421
- Reproduce
- POC (poc.c)
#define _GNU_SOURCE
#include <dirent.h>
#include <errno.h>
#include <error.h>
#include <fcntl.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <unistd.h>
char *foo_bar_baz;
char *foo_baz;
char *xattr;
int err;
err = asprintf(&foo_bar_baz, "%s/foo/bar/baz", mpoint);
err = asprintf(&foo_baz, "%s/foo/baz", mpoint);
rename(foo_bar_baz, foo_baz);
char buf2[113];
removexattr(xattr, "user.mime_type");
activity(argv[1]);
return 0;
- Kernel message
Umount the image will leave the following message
[ 2910.995489] F2FS-fs (loop0): Mounted with checkpoint version = 2
[ 2918.416465] ==================================================================
[ 2918.416807] BUG: KASAN: slab-out-of-bounds in f2fs_iget+0xcb9/0x1a80
[ 2918.417009] Read of size 4 at addr ffff88018efc2068 by task a.out/1229
[ 2918.417311] CPU: 1 PID: 1229 Comm: a.out Not tainted 4.17.0+ #1
[ 2918.417314] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Ubuntu-1.8.2-1ubuntu1 04/01/2014
[ 2918.417323] Call Trace:
[ 2918.417366] dump_stack+0x71/0xab
[ 2918.417401] print_address_description+0x6b/0x290
[ 2918.417407] kasan_report+0x28e/0x390
[ 2918.417411] ? f2fs_iget+0xcb9/0x1a80
[ 2918.417415] f2fs_iget+0xcb9/0x1a80
[ 2918.417422] ? f2fs_lookup+0x2e7/0x580
[ 2918.417425] f2fs_lookup+0x2e7/0x580
[ 2918.417433] ? __recover_dot_dentries+0x400/0x400
[ 2918.417447] ? legitimize_path.isra.29+0x5a/0xa0
[ 2918.417453] __lookup_slow+0x11c/0x220
[ 2918.417457] ? may_delete+0x2a0/0x2a0
[ 2918.417475] ? deref_stack_reg+0xe0/0xe0
[ 2918.417479] ? __lookup_hash+0xb0/0xb0
[ 2918.417483] lookup_slow+0x3e/0x60
[ 2918.417488] walk_component+0x3ac/0x990
[ 2918.417492] ? generic_permission+0x51/0x1e0
[ 2918.417495] ? inode_permission+0x51/0x1d0
[ 2918.417499] ? pick_link+0x3e0/0x3e0
[ 2918.417502] ? link_path_walk+0x4b1/0x770
[ 2918.417513] ? _raw_spin_lock_irqsave+0x25/0x50
[ 2918.417518] ? walk_component+0x990/0x990
[ 2918.417522] ? path_init+0x2e6/0x580
[ 2918.417526] path_lookupat+0x13f/0x430
[ 2918.417531] ? trailing_symlink+0x3a0/0x3a0
[ 2918.417534] ? do_renameat2+0x270/0x7b0
[ 2918.417538] ? __kasan_slab_free+0x14c/0x190
[ 2918.417541] ? do_renameat2+0x270/0x7b0
[ 2918.417553] ? kmem_cache_free+0x85/0x1e0
[ 2918.417558] ? do_renameat2+0x270/0x7b0
[ 2918.417563] filename_lookup+0x13c/0x280
[ 2918.417567] ? filename_parentat+0x2b0/0x2b0
[ 2918.417572] ? kasan_unpoison_shadow+0x31/0x40
[ 2918.417575] ? kasan_kmalloc+0xa6/0xd0
[ 2918.417593] ? strncpy_from_user+0xaa/0x1c0
[ 2918.417598] ? getname_flags+0x101/0x2b0
[ 2918.417614] ? path_listxattr+0x87/0x110
[ 2918.417619] path_listxattr+0x87/0x110
[ 2918.417623] ? listxattr+0xc0/0xc0
[ 2918.417637] ? mm_fault_error+0x1b0/0x1b0
[ 2918.417654] do_syscall_64+0x73/0x160
[ 2918.417660] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[ 2918.417676] RIP: 0033:0x7f2f3a3480d7
[ 2918.417677] Code: f0 ff ff 73 01 c3 48 8b 0d be dd 2b 00 f7 d8 64 89 01 48 83 c8 ff c3 66 2e 0f 1f 84 00 00 00 00 00 66 90 b8 c2 00 00 00 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d 91 dd 2b 00 f7 d8 64 89 01 48
[ 2918.417732] RSP: 002b:00007fff4095b7d8 EFLAGS: 00000206 ORIG_RAX: 00000000000000c2
[ 2918.417744] RAX: ffffffffffffffda RBX: 0000000000000000 RCX: 00007f2f3a3480d7
[ 2918.417746] RDX: 0000000000000071 RSI: 00007fff4095b810 RDI: 000000000126a0c0
[ 2918.417749] RBP: 00007fff4095b890 R08: 000000000126a010 R09: 0000000000000000
[ 2918.417751] R10: 00000000000001ab R11: 0000000000000206 R12: 00000000004005e0
[ 2918.417753] R13: 00007fff4095b990 R14: 0000000000000000 R15: 0000000000000000
[ 2918.417853] Allocated by task 329:
[ 2918.418002] kasan_kmalloc+0xa6/0xd0
[ 2918.418007] kmem_cache_alloc+0xc8/0x1e0
[ 2918.418023] mempool_init_node+0x194/0x230
[ 2918.418027] mempool_init+0x12/0x20
[ 2918.418042] bioset_init+0x2bd/0x380
[ 2918.418052] blk_alloc_queue_node+0xe9/0x540
[ 2918.418075] dm_create+0x2c0/0x800
[ 2918.418080] dev_create+0xd2/0x530
[ 2918.418083] ctl_ioctl+0x2a3/0x5b0
[ 2918.418087] dm_ctl_ioctl+0xa/0x10
[ 2918.418092] do_vfs_ioctl+0x13e/0x8c0
[ 2918.418095] ksys_ioctl+0x66/0x70
[ 2918.418098] __x64_sys_ioctl+0x3d/0x50
[ 2918.418102] do_syscall_64+0x73/0x160
[ 2918.418106] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[ 2918.418204] Freed by task 0:
[ 2918.418301] (stack is not available)
[ 2918.418521] The buggy address belongs to the object at ffff88018efc0000
which belongs to the cache biovec-max of size 8192
[ 2918.418894] The buggy address is located 104 bytes to the right of
8192-byte region [ffff88018efc0000, ffff88018efc2000)
[ 2918.419257] The buggy address belongs to the page:
[ 2918.419431] page:ffffea00063bf000 count:1 mapcount:0 mapping:ffff8801f2242540 index:0x0 compound_mapcount: 0
[ 2918.419702] flags: 0x17fff8000008100(slab|head)
[ 2918.419879] raw: 017fff8000008100 dead000000000100 dead000000000200 ffff8801f2242540
[ 2918.420101] raw: 0000000000000000 0000000000030003 00000001ffffffff 0000000000000000
[ 2918.420322] page dumped because: kasan: bad access detected
[ 2918.420599] Memory state around the buggy address:
[ 2918.420764] ffff88018efc1f00: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
[ 2918.420975] ffff88018efc1f80: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
[ 2918.421194] >ffff88018efc2000: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
[ 2918.421406] ^
[ 2918.421627] ffff88018efc2080: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
[ 2918.421838] ffff88018efc2100: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
[ 2918.422046] ==================================================================
[ 2918.422264] Disabling lock debugging due to kernel taint
[ 2923.901641] BUG: unable to handle kernel paging request at ffff88018f0db000
[ 2923.901884] PGD 22226a067 P4D 22226a067 PUD 222273067 PMD 18e642063 PTE 800000018f0db061
[ 2923.902120] Oops: 0003 [#1] SMP KASAN PTI
[ 2923.902274] CPU: 1 PID: 1231 Comm: umount Tainted: G B 4.17.0+ #1
[ 2923.902490] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Ubuntu-1.8.2-1ubuntu1 04/01/2014
[ 2923.902761] RIP: 0010:__memset+0x24/0x30
[ 2923.902906] Code: 90 90 90 90 90 90 66 66 90 66 90 49 89 f9 48 89 d1 83 e2 07 48 c1 e9 03 40 0f b6 f6 48 b8 01 01 01 01 01 01 01 01 48 0f af c6 <f3> 48 ab 89 d1 f3 aa 4c 89 c8 c3 90 49 89 f9 40 88 f0 48 89 d1 f3
[ 2923.903446] RSP: 0018:ffff88018ddf7ae0 EFLAGS: 00010206
[ 2923.903622] RAX: 0000000000000000 RBX: ffff8801d549d888 RCX: 1ffffffffffdaffb
[ 2923.903833] RDX: 0000000000000000 RSI: 0000000000000000 RDI: ffff88018f0daffc
[ 2923.904062] RBP: ffff88018efc206c R08: 1ffff10031df840d R09: ffff88018efc206c
[ 2923.904273] R10: ffffffffffffe1ee R11: ffffed0031df65fa R12: 0000000000000000
[ 2923.904485] R13: ffff8801d549dc98 R14: 00000000ffffc3db R15: ffffea00063bec80
[ 2923.904693] FS: 00007fa8b2f8a840(0000) GS:ffff8801f3b00000(0000) knlGS:0000000000000000
[ 2923.904937] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 2923.910080] CR2: ffff88018f0db000 CR3: 000000018f892000 CR4: 00000000000006e0
[ 2923.914930] Call Trace:
[ 2923.919724] f2fs_truncate_inline_inode+0x114/0x170
[ 2923.924487] f2fs_truncate_blocks+0x11b/0x7c0
[ 2923.929178] ? f2fs_truncate_data_blocks+0x10/0x10
[ 2923.933834] ? dqget+0x670/0x670
[ 2923.938437] ? f2fs_destroy_extent_tree+0xd6/0x270
[ 2923.943107] ? __radix_tree_lookup+0x2f/0x150
[ 2923.947772] f2fs_truncate+0xd4/0x1a0
[ 2923.952491] f2fs_evict_inode+0x5ab/0x610
[ 2923.957204] evict+0x15f/0x280
[ 2923.961898] __dentry_kill+0x161/0x250
[ 2923.966634] shrink_dentry_list+0xf3/0x250
[ 2923.971897] shrink_dcache_parent+0xa9/0x100
[ 2923.976561] ? shrink_dcache_sb+0x1f0/0x1f0
[ 2923.981177] ? wait_for_completion+0x8a/0x210
[ 2923.985781] ? migrate_swap_stop+0x2d0/0x2d0
[ 2923.990332] do_one_tree+0xe/0x40
[ 2923.994735] shrink_dcache_for_umount+0x3a/0xa0
[ 2923.999077] generic_shutdown_super+0x3e/0x1c0
[ 2924.003350] kill_block_super+0x4b/0x70
[ 2924.007619] deactivate_locked_super+0x65/0x90
[ 2924.011812] cleanup_mnt+0x5c/0xa0
[ 2924.015995] task_work_run+0xce/0xf0
[ 2924.020174] exit_to_usermode_loop+0x115/0x120
[ 2924.024293] do_syscall_64+0x12f/0x160
[ 2924.028479] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[ 2924.032709] RIP: 0033:0x7fa8b2868487
[ 2924.036888] Code: 83 c8 ff c3 66 2e 0f 1f 84 00 00 00 00 00 0f 1f 44 00 00 31 f6 e9 09 00 00 00 66 0f 1f 84 00 00 00 00 00 b8 a6 00 00 00 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d e1 c9 2b 00 f7 d8 64 89 01 48
[ 2924.045750] RSP: 002b:00007ffc39824d58 EFLAGS: 00000246 ORIG_RAX: 00000000000000a6
[ 2924.050190] RAX: 0000000000000000 RBX: 00000000008ea030 RCX: 00007fa8b2868487
[ 2924.054604] RDX: 0000000000000001 RSI: 0000000000000000 RDI: 00000000008f4360
[ 2924.058940] RBP: 00000000008f4360 R08: 0000000000000000 R09: 0000000000000014
[ 2924.063186] R10: 00000000000006b2 R11: 0000000000000246 R12: 00007fa8b2d7183c
[ 2924.067418] R13: 0000000000000000 R14: 00000000008ea210 R15: 00007ffc39824fe0
[ 2924.071534] Modules linked in: snd_hda_codec_generic snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep snd_pcm snd_timer joydev input_leds serio_raw snd soundcore mac_hid i2c_piix4 ib_iser rdma_cm iw_cm ib_cm ib_core configfs iscsi_tcp libiscsi_tcp libiscsi scsi_transport_iscsi btrfs zstd_decompress zstd_compress xxhash raid10 raid456 async_raid6_recov async_memcpy async_pq async_xor async_tx xor raid6_pq libcrc32c raid1 raid0 multipath linear 8139too qxl ttm drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops drm crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcbc aesni_intel psmouse aes_x86_64 8139cp crypto_simd cryptd mii glue_helper pata_acpi floppy
[ 2924.098044] CR2: ffff88018f0db000
[ 2924.102520] ---[ end trace a8e0d899985faf31 ]---
[ 2924.107012] RIP: 0010:__memset+0x24/0x30
[ 2924.111448] Code: 90 90 90 90 90 90 66 66 90 66 90 49 89 f9 48 89 d1 83 e2 07 48 c1 e9 03 40 0f b6 f6 48 b8 01 01 01 01 01 01 01 01 48 0f af c6 <f3> 48 ab 89 d1 f3 aa 4c 89 c8 c3 90 49 89 f9 40 88 f0 48 89 d1 f3
[ 2924.120724] RSP: 0018:ffff88018ddf7ae0 EFLAGS: 00010206
[ 2924.125312] RAX: 0000000000000000 RBX: ffff8801d549d888 RCX: 1ffffffffffdaffb
[ 2924.129931] RDX: 0000000000000000 RSI: 0000000000000000 RDI: ffff88018f0daffc
[ 2924.134537] RBP: ffff88018efc206c R08: 1ffff10031df840d R09: ffff88018efc206c
[ 2924.139175] R10: ffffffffffffe1ee R11: ffffed0031df65fa R12: 0000000000000000
[ 2924.143825] R13: ffff8801d549dc98 R14: 00000000ffffc3db R15: ffffea00063bec80
[ 2924.148500] FS: 00007fa8b2f8a840(0000) GS:ffff8801f3b00000(0000) knlGS:0000000000000000
[ 2924.153247] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 2924.158003] CR2: ffff88018f0db000 CR3: 000000018f892000 CR4: 00000000000006e0
[ 2924.164641] BUG: Bad rss-counter state mm:00000000fa04621e idx:0 val:4
[ 2924.170007] BUG: Bad rss-counter
tate mm:00000000fa04621e idx:1 val:2
- Location
https://elixir.bootlin.com/linux/v4.18-rc3/source/fs/f2fs/inline.c#L78
memset(addr + from, 0, MAX_INLINE_DATA(inode) - from);
Here the length can be negative.
commit c9b60788fc760d136211853f10ce73dc152d1f4a upstream.
This patch add to do sanity check with below field:
- cp_pack_total_block_count
- blkaddr of data/node
- extent info
- Overview
BUG() in verify_block_addr() when writing to a corrupted f2fs image
- Reproduce (4.18 upstream kernel)
- POC (poc.c)
char *foo_bar_baz;
int err;
static int buf[8192];
memset(buf, 0, sizeof(buf));
int fd = open(foo_bar_baz, O_RDWR | O_TRUNC, 0777);
if (fd >= 0) {
write(fd, (char *)buf, sizeof(buf));
fdatasync(fd);
close(fd);
activity(argv[1]);
return 0;
- Kernel message
[ 689.349473] F2FS-fs (loop0): Mounted with checkpoint version = 3
[ 699.728662] WARNING: CPU: 0 PID: 1309 at fs/f2fs/segment.c:2860 f2fs_inplace_write_data+0x232/0x240
[ 699.728670] Modules linked in: snd_hda_codec_generic snd_hda_intel snd_hda_codec snd_hwdep snd_hda_core snd_pcm snd_timer snd mac_hid i2c_piix4 soundcore ib_iser rdma_cm iw_cm ib_cm ib_core iscsi_tcp libiscsi_tcp libiscsi scsi_transport_iscsi raid10 raid456 async_raid6_recov async_memcpy async_pq async_xor async_tx raid1 raid0 multipath linear 8139too crct10dif_pclmul crc32_pclmul qxl drm_kms_helper syscopyarea aesni_intel sysfillrect sysimgblt fb_sys_fops ttm drm aes_x86_64 crypto_simd cryptd 8139cp glue_helper mii pata_acpi floppy
[ 699.729056] CPU: 0 PID: 1309 Comm: a.out Not tainted 4.18.0-rc1+ #4
[ 699.729064] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Ubuntu-1.8.2-1ubuntu1 04/01/2014
[ 699.729074] RIP: 0010:f2fs_inplace_write_data+0x232/0x240
[ 699.729076] Code: ff e9 cf fe ff ff 49 8d 7d 10 e8 39 45 ad ff 4d 8b 7d 10 be 04 00 00 00 49 8d 7f 48 e8 07 49 ad ff 45 8b 7f 48 e9 fb fe ff ff <0f> 0b f0 41 80 4d 48 04 e9 65 fe ff ff 90 66 66 66 66 90 55 48 8d
[ 699.729130] RSP: 0018:ffff8801f43af568 EFLAGS: 00010202
[ 699.729139] RAX: 000000000000003f RBX: ffff8801f43af7b8 RCX: ffffffffb88c9113
[ 699.729142] RDX: 0000000000000003 RSI: dffffc0000000000 RDI: ffff8802024e5540
[ 699.729144] RBP: ffff8801f43af590 R08: 0000000000000009 R09: ffffffffffffffe8
[ 699.729147] R10: 0000000000000001 R11: ffffed0039b0596a R12: ffff8802024e5540
[ 699.729149] R13: ffff8801f0335500 R14: ffff8801e3e7a700 R15: ffff8801e1ee4450
[ 699.729154] FS: 00007f9bf97f5700(0000) GS:ffff8801f6e00000(0000) knlGS:0000000000000000
[ 699.729156] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 699.729159] CR2: 00007f9bf925d170 CR3: 00000001f0c34000 CR4: 00000000000006f0
[ 699.729171] Call Trace:
[ 699.729192] f2fs_do_write_data_page+0x2e2/0xe00
[ 699.729203] ? f2fs_should_update_outplace+0xd0/0xd0
[ 699.729238] ? memcg_drain_all_list_lrus+0x280/0x280
[ 699.729269] ? __radix_tree_replace+0xa3/0x120
[ 699.729276] __write_data_page+0x5c7/0xe30
[ 699.729291] ? kasan_check_read+0x11/0x20
[ 699.729310] ? page_mapped+0x8a/0x110
[ 699.729321] ? page_mkclean+0xe9/0x160
[ 699.729327] ? f2fs_do_write_data_page+0xe00/0xe00
[ 699.729331] ? invalid_page_referenced_vma+0x130/0x130
[ 699.729345] ? clear_page_dirty_for_io+0x332/0x450
[ 699.729351] f2fs_write_cache_pages+0x4ca/0x860
[ 699.729358] ? __write_data_page+0xe30/0xe30
[ 699.729374] ? percpu_counter_add_batch+0x22/0xa0
[ 699.729380] ? kasan_check_write+0x14/0x20
[ 699.729391] ? _raw_spin_lock+0x17/0x40
[ 699.729403] ? f2fs_mark_inode_dirty_sync.part.18+0x16/0x30
[ 699.729413] ? iov_iter_advance+0x113/0x640
[ 699.729418] ? f2fs_write_end+0x133/0x2e0
[ 699.729423] ? balance_dirty_pages_ratelimited+0x239/0x640
[ 699.729428] f2fs_write_data_pages+0x329/0x520
[ 699.729433] ? generic_perform_write+0x250/0x320
[ 699.729438] ? f2fs_write_cache_pages+0x860/0x860
[ 699.729454] ? current_time+0x110/0x110
[ 699.729459] ? f2fs_preallocate_blocks+0x1ef/0x370
[ 699.729464] do_writepages+0x37/0xb0
[ 699.729468] ? f2fs_write_cache_pages+0x860/0x860
[ 699.729472] ? do_writepages+0x37/0xb0
[ 699.729478] __filemap_fdatawrite_range+0x19a/0x1f0
[ 699.729483] ? delete_from_page_cache_batch+0x4e0/0x4e0
[ 699.729496] ? __vfs_write+0x2b2/0x410
[ 699.729501] file_write_and_wait_range+0x66/0xb0
[ 699.729506] f2fs_do_sync_file+0x1f9/0xd90
[ 699.729511] ? truncate_partial_data_page+0x290/0x290
[ 699.729521] ? __sb_end_write+0x30/0x50
[ 699.729526] ? vfs_write+0x20f/0x260
[ 699.729530] f2fs_sync_file+0x9a/0xb0
[ 699.729534] ? f2fs_do_sync_file+0xd90/0xd90
[ 699.729548] vfs_fsync_range+0x68/0x100
[ 699.729554] ? __fget_light+0xc9/0xe0
[ 699.729558] do_fsync+0x3d/0x70
[ 699.729562] __x64_sys_fdatasync+0x24/0x30
[ 699.729585] do_syscall_64+0x78/0x170
[ 699.729595] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[ 699.729613] RIP: 0033:0x7f9bf930d800
[ 699.729615] Code: 00 f7 d8 64 89 01 48 83 c8 ff c3 66 2e 0f 1f 84 00 00 00 00 00 0f 1f 44 00 00 83 3d 49 bf 2c 00 00 75 10 b8 4b 00 00 00 0f 05 <48> 3d 01 f0 ff ff 73 31 c3 48 83 ec 08 e8 be 78 01 00 48 89 04 24
[ 699.729668] RSP: 002b:00007ffee3606c68 EFLAGS: 00000246 ORIG_RAX: 000000000000004b
[ 699.729673] RAX: ffffffffffffffda RBX: 0000000000000000 RCX: 00007f9bf930d800
[ 699.729675] RDX: 0000000000008000 RSI: 00000000006010a0 RDI: 0000000000000003
[ 699.729678] RBP: 00007ffee3606ca0 R08: 0000000001503010 R09: 0000000000000000
[ 699.729680] R10: 00000000000002e8 R11: 0000000000000246 R12: 0000000000400610
[ 699.729683] R13: 00007ffee3606da0 R14: 0000000000000000 R15: 0000000000000000
[ 699.729687] ---[ end trace 4ce02f25ff7d3df5 ]---
[ 699.729782] ------------[ cut here ]------------
[ 699.729785] kernel BUG at fs/f2fs/segment.h:654!
[ 699.731055] invalid opcode: 0000 [#1] SMP KASAN PTI
[ 699.732104] CPU: 0 PID: 1309 Comm: a.out Tainted: G W 4.18.0-rc1+ #4
[ 699.733684] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Ubuntu-1.8.2-1ubuntu1 04/01/2014
[ 699.735611] RIP: 0010:f2fs_submit_page_bio+0x29b/0x730
[ 699.736649] Code: 54 49 8d bd 18 04 00 00 e8 b2 59 af ff 41 8b 8d 18 04 00 00 8b 45 b8 41 d3 e6 44 01 f0 4c 8d 73 14 41 39 c7 0f 82 37 fe ff ff <0f> 0b 65 8b 05 2c 04 77 47 89 c0 48 0f a3 05 52 c1 d5 01 0f 92 c0
[ 699.740524] RSP: 0018:ffff8801f43af508 EFLAGS: 00010283
[ 699.741573] RAX: 0000000000000000 RBX: ffff8801f43af7b8 RCX: ffffffffb88a7cef
[ 699.743006] RDX: 0000000000000007 RSI: dffffc0000000000 RDI: ffff8801e3e7a64c
[ 699.744426] RBP: ffff8801f43af558 R08: ffffed003e066b55 R09: ffffed003e066b55
[ 699.745833] R10: 0000000000000001 R11: ffffed003e066b54 R12: ffffea0007876940
[ 699.747256] R13: ffff8801f0335500 R14: ffff8801e3e7a600 R15: 0000000000000001
[ 699.748683] FS: 00007f9bf97f5700(0000) GS:ffff8801f6e00000(0000) knlGS:0000000000000000
[ 699.750293] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 699.751462] CR2: 00007f9bf925d170 CR3: 00000001f0c34000 CR4: 00000000000006f0
[ 699.752874] Call Trace:
[ 699.753386] ? f2fs_inplace_write_data+0x93/0x240
[ 699.754341] f2fs_inplace_write_data+0xd2/0x240
[ 699.755271] f2fs_do_write_data_page+0x2e2/0xe00
[ 699.756214] ? f2fs_should_update_outplace+0xd0/0xd0
[ 699.757215] ? memcg_drain_all_list_lrus+0x280/0x280
[ 699.758209] ? __radix_tree_replace+0xa3/0x120
[ 699.759164] __write_data_page+0x5c7/0xe30
[ 699.760002] ? kasan_check_read+0x11/0x20
[ 699.760823] ? page_mapped+0x8a/0x110
[ 699.761573] ? page_mkclean+0xe9/0x160
[ 699.762345] ? f2fs_do_write_data_page+0xe00/0xe00
[ 699.763332] ? invalid_page_referenced_vma+0x130/0x130
[ 699.764374] ? clear_page_dirty_for_io+0x332/0x450
[ 699.765347] f2fs_write_cache_pages+0x4ca/0x860
[ 699.766276] ? __write_data_page+0xe30/0xe30
[ 699.767161] ? percpu_counter_add_batch+0x22/0xa0
[ 699.768112] ? kasan_check_write+0x14/0x20
[ 699.768951] ? _raw_spin_lock+0x17/0x40
[ 699.769739] ? f2fs_mark_inode_dirty_sync.part.18+0x16/0x30
[ 699.770885] ? iov_iter_advance+0x113/0x640
[ 699.771743] ? f2fs_write_end+0x133/0x2e0
[ 699.772569] ? balance_dirty_pages_ratelimited+0x239/0x640
[ 699.773680] f2fs_write_data_pages+0x329/0x520
[ 699.774603] ? generic_perform_write+0x250/0x320
[ 699.775544] ? f2fs_write_cache_pages+0x860/0x860
[ 699.776510] ? current_time+0x110/0x110
[ 699.777299] ? f2fs_preallocate_blocks+0x1ef/0x370
[ 699.778279] do_writepages+0x37/0xb0
[ 699.779026] ? f2fs_write_cache_pages+0x860/0x860
[ 699.779978] ? do_writepages+0x37/0xb0
[ 699.780755] __filemap_fdatawrite_range+0x19a/0x1f0
[ 699.781746] ? delete_from_page_cache_batch+0x4e0/0x4e0
[ 699.782820] ? __vfs_write+0x2b2/0x410
[ 699.783597] file_write_and_wait_range+0x66/0xb0
[ 699.784540] f2fs_do_sync_file+0x1f9/0xd90
[ 699.785381] ? truncate_partial_data_page+0x290/0x290
[ 699.786415] ? __sb_end_write+0x30/0x50
[ 699.787204] ? vfs_write+0x20f/0x260
[ 699.787941] f2fs_sync_file+0x9a/0xb0
[ 699.788694] ? f2fs_do_sync_file+0xd90/0xd90
[ 699.789572] vfs_fsync_range+0x68/0x100
[ 699.790360] ? __fget_light+0xc9/0xe0
[ 699.791128] do_fsync+0x3d/0x70
[ 699.791779] __x64_sys_fdatasync+0x24/0x30
[ 699.792614] do_syscall_64+0x78/0x170
[ 699.793371] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[ 699.794406] RIP: 0033:0x7f9bf930d800
[ 699.795134] Code: 00 f7 d8 64 89 01 48 83 c8 ff c3 66 2e 0f 1f 84 00 00 00 00 00 0f 1f 44 00 00 83 3d 49 bf 2c 00 00 75 10 b8 4b 00 00 00 0f 05 <48> 3d 01 f0 ff ff 73 31 c3 48 83 ec 08 e8 be 78 01 00 48 89 04 24
[ 699.798960] RSP: 002b:00007ffee3606c68 EFLAGS: 00000246 ORIG_RAX: 000000000000004b
[ 699.800483] RAX: ffffffffffffffda RBX: 0000000000000000 RCX: 00007f9bf930d800
[ 699.801923] RDX: 0000000000008000 RSI: 00000000006010a0 RDI: 0000000000000003
[ 699.803373] RBP: 00007ffee3606ca0 R08: 0000000001503010 R09: 0000000000000000
[ 699.804798] R10: 00000000000002e8 R11: 0000000000000246 R12: 0000000000400610
[ 699.806233] R13: 00007ffee3606da0 R14: 0000000000000000 R15: 0000000000000000
[ 699.807667] Modules linked in: snd_hda_codec_generic snd_hda_intel snd_hda_codec snd_hwdep snd_hda_core snd_pcm snd_timer snd mac_hid i2c_piix4 soundcore ib_iser rdma_cm iw_cm ib_cm ib_core iscsi_tcp libiscsi_tcp libiscsi scsi_transport_iscsi raid10 raid456 async_raid6_recov async_memcpy async_pq async_xor async_tx raid1 raid0 multipath linear 8139too crct10dif_pclmul crc32_pclmul qxl drm_kms_helper syscopyarea aesni_intel sysfillrect sysimgblt fb_sys_fops ttm drm aes_x86_64 crypto_simd cryptd 8139cp glue_helper mii pata_acpi floppy
[ 699.817079] ---[ end trace 4ce02f25ff7d3df6 ]---
[ 699.818068] RIP: 0010:f2fs_submit_page_bio+0x29b/0x730
[ 699.819114] Code: 54 49 8d bd 18 04 00 00 e8 b2 59 af ff 41 8b 8d 18 04 00 00 8b 45 b8 41 d3 e6 44 01 f0 4c 8d 73 14 41 39 c7 0f 82 37 fe ff ff <0f> 0b 65 8b 05 2c 04 77 47 89 c0 48 0f a3 05 52 c1 d5 01 0f 92 c0
[ 699.822919] RSP: 0018:ffff8801f43af508 EFLAGS: 00010283
[ 699.823977] RAX: 0000000000000000 RBX: ffff8801f43af7b8 RCX: ffffffffb88a7cef
[ 699.825436] RDX: 0000000000000007 RSI: dffffc0000000000 RDI: ffff8801e3e7a64c
[ 699.826881] RBP: ffff8801f43af558 R08: ffffed003e066b55 R09: ffffed003e066b55
[ 699.828292] R10: 0000000000000001 R11: ffffed003e066b54 R12: ffffea0007876940
[ 699.829750] R13: ffff8801f0335500 R14: ffff8801e3e7a600 R15: 0000000000000001
[ 699.831192] FS: 00007f9bf97f5700(0000) GS:ffff8801f6e00000(0000) knlGS:0000000000000000
[ 699.832793] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 699.833981] CR2: 00007f9bf925d170 CR3: 00000001f0c34000 CR4: 00000000000006f0
[ 699.835556] ==================================================================
[ 699.837029] BUG: KASAN: stack-out-of-bounds in update_stack_state+0x38c/0x3e0
[ 699.838462] Read of size 8 at addr ffff8801f43af970 by task a.out/1309
[ 699.840086] CPU: 0 PID: 1309 Comm: a.out Tainted: G D W 4.18.0-rc1+ #4
[ 699.841603] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Ubuntu-1.8.2-1ubuntu1 04/01/2014
[ 699.843475] Call Trace:
[ 699.843982] dump_stack+0x7b/0xb5
[ 699.844661] print_address_description+0x70/0x290
[ 699.845607] kasan_report+0x291/0x390
[ 699.846351] ? update_stack_state+0x38c/0x3e0
[ 699.853831] __asan_load8+0x54/0x90
[ 699.854569] update_stack_state+0x38c/0x3e0
[ 699.855428] ? __read_once_size_nocheck.constprop.7+0x20/0x20
[ 699.856601] ? __save_stack_trace+0x5e/0x100
[ 699.857476] unwind_next_frame.part.5+0x18e/0x490
[ 699.858448] ? unwind_dump+0x290/0x290
[ 699.859217] ? clear_page_dirty_for_io+0x332/0x450
[ 699.860185] __unwind_start+0x106/0x190
[ 699.860974] __save_stack_trace+0x5e/0x100
[ 699.861808] ? __save_stack_trace+0x5e/0x100
[ 699.862691] ? unlink_anon_vmas+0xba/0x2c0
[ 699.863525] save_stack_trace+0x1f/0x30
[ 699.864312] save_stack+0x46/0xd0
[ 699.864993] ? __alloc_pages_slowpath+0x1420/0x1420
[ 699.865990] ? flush_tlb_mm_range+0x15e/0x220
[ 699.866889] ? kasan_check_write+0x14/0x20
[ 699.867724] ? __dec_node_state+0x92/0xb0
[ 699.868543] ? lock_page_memcg+0x85/0xf0
[ 699.869350] ? unlock_page_memcg+0x16/0x80
[ 699.870185] ? page_remove_rmap+0x198/0x520
[ 699.871048] ? mark_page_accessed+0x133/0x200
[ 699.871930] ? _cond_resched+0x1a/0x50
[ 699.872700] ? unmap_page_range+0xcd4/0xe50
[ 699.873551] ? rb_next+0x58/0x80
[ 699.874217] ? rb_next+0x58/0x80
[ 699.874895] __kasan_slab_free+0x13c/0x1a0
[ 699.875734] ? unlink_anon_vmas+0xba/0x2c0
[ 699.876563] kasan_slab_free+0xe/0x10
[ 699.877315] kmem_cache_free+0x89/0x1e0
[ 699.878095] unlink_anon_vmas+0xba/0x2c0
[ 699.878913] free_pgtables+0x101/0x1b0
[ 699.879677] exit_mmap+0x146/0x2a0
[ 699.880378] ? __ia32_sys_munmap+0x50/0x50
[ 699.881214] ? kasan_check_read+0x11/0x20
[ 699.882052] ? mm_update_next_owner+0x322/0x380
[ 699.882985] mmput+0x8b/0x1d0
[ 699.883602] do_exit+0x43a/0x1390
[ 699.884288] ? mm_update_next_owner+0x380/0x380
[ 699.885212] ? f2fs_sync_file+0x9a/0xb0
[ 699.885995] ? f2fs_do_sync_file+0xd90/0xd90
[ 699.886877] ? vfs_fsync_range+0x68/0x100
[ 699.887694] ? __fget_light+0xc9/0xe0
[ 699.888442] ? do_fsync+0x3d/0x70
[ 699.889118] ? __x64_sys_fdatasync+0x24/0x30
[ 699.889996] rewind_stack_do_exit+0x17/0x20
[ 699.890860] RIP: 0033:0x7f9bf930d800
[ 699.891585] Code: Bad RIP value.
[ 699.892268] RSP: 002b:00007ffee3606c68 EFLAGS: 00000246 ORIG_RAX: 000000000000004b
[ 699.893781] RAX: ffffffffffffffda RBX: 0000000000000000 RCX: 00007f9bf930d800
[ 699.895220] RDX: 0000000000008000 RSI: 00000000006010a0 RDI: 0000000000000003
[ 699.896643] RBP: 00007ffee3606ca0 R08: 0000000001503010 R09: 0000000000000000
[ 699.898069] R10: 00000000000002e8 R11: 0000000000000246 R12: 0000000000400610
[ 699.899505] R13: 00007ffee3606da0 R14: 0000000000000000 R15: 0000000000000000
[ 699.901241] The buggy address belongs to the page:
[ 699.902215] page:ffffea0007d0ebc0 count:0 mapcount:0 mapping:0000000000000000 index:0x0
[ 699.903811] flags: 0x2ffff0000000000()
[ 699.904585] raw: 02ffff0000000000 0000000000000000 ffffffff07d00101 0000000000000000
[ 699.906125] raw: 0000000000000000 0000000000240000 00000000ffffffff 0000000000000000
[ 699.907673] page dumped because: kasan: bad access detected
[ 699.909108] Memory state around the buggy address:
[ 699.910077] ffff8801f43af800: 00 f1 f1 f1 f1 00 f4 f4 f4 f3 f3 f3 f3 00 00 00
[ 699.911528] ffff8801f43af880: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 699.912953] >ffff8801f43af900: 00 00 00 00 00 00 00 00 f1 01 f4 f4 f4 f2 f2 f2
[ 699.914392] ^
[ 699.915758] ffff8801f43af980: f2 00 f4 f4 00 00 00 00 f2 00 00 00 00 00 00 00
[ 699.917193] ffff8801f43afa00: 00 00 00 00 00 00 00 00 00 f3 f3 f3 00 00 00 00
[ 699.918634] ==================================================================
- Location
https://elixir.bootlin.com/linux/v4.18-rc1/source/fs/f2fs/segment.h#L644
- Error label is different in validate_checkpoint() due to the earlier
backport of "f2fs: fix invalid memory access"
- Adjust context]
commit e34438c903b653daca2b2a7de95aed46226f8ed3 upstream.
This patch adds to do sanity check with below fields of inode to
avoid reported panic.
- node footer
- iblocks
https://bugzilla.kernel.org/show_bug.cgi?id=200223
- Overview
BUG() triggered in f2fs_truncate_inode_blocks() when un-mounting a mounted f2fs image after writing to it
- Reproduce
- POC (poc.c)
static void activity(char *mpoint) {
char *foo_bar_baz;
int err;
// open / write / read
if (fd >= 0) {
write(fd, (char *)buf, 517);
close(fd);
int main(int argc, char *argv[]) {
activity(argv[1]);
return 0;
- Kernel meesage
[ 552.479723] F2FS-fs (loop0): Mounted with checkpoint version = 2
[ 556.451891] ------------[ cut here ]------------
[ 556.451899] kernel BUG at fs/f2fs/node.c:987!
[ 556.452920] invalid opcode: 0000 [#1] SMP KASAN PTI
[ 556.453936] CPU: 1 PID: 1310 Comm: umount Not tainted 4.18.0-rc1+ #4
[ 556.455213] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Ubuntu-1.8.2-1ubuntu1 04/01/2014
[ 556.457140] RIP: 0010:f2fs_truncate_inode_blocks+0x4a7/0x6f0
[ 556.458280] Code: e8 ae ea ff ff 41 89 c7 c1 e8 1f 84 c0 74 0a 41 83 ff fe 0f 85 35 ff ff ff 81 85 b0 fe ff ff fb 03 00 00 e9 f7 fd ff ff 0f 0b <0f> 0b e8 62 b7 9a 00 48 8b bd a0 fe ff ff e8 56 54 ae ff 48 8b b5
[ 556.462015] RSP: 0018:ffff8801f292f808 EFLAGS: 00010286
[ 556.463068] RAX: ffffed003e73242d RBX: ffff8801f292f958 RCX: ffffffffb88b81bc
[ 556.464479] RDX: 0000000000000000 RSI: 0000000000000004 RDI: ffff8801f3992164
[ 556.465901] RBP: ffff8801f292f980 R08: ffffed003e73242d R09: ffffed003e73242d
[ 556.467311] R10: 0000000000000001 R11: ffffed003e73242c R12: 00000000fffffc64
[ 556.468706] R13: ffff8801f3992000 R14: 0000000000000058 R15: 00000000ffff8801
[ 556.470117] FS: 00007f8029297840(0000) GS:ffff8801f6f00000(0000) knlGS:0000000000000000
[ 556.471702] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 556.472838] CR2: 000055f5f57305d8 CR3: 00000001f18b0000 CR4: 00000000000006e0
[ 556.474265] Call Trace:
[ 556.474782] ? f2fs_alloc_nid_failed+0xf0/0xf0
[ 556.475686] ? truncate_nodes+0x980/0x980
[ 556.476516] ? pagecache_get_page+0x21f/0x2f0
[ 556.477412] ? __asan_loadN+0xf/0x20
[ 556.478153] ? __get_node_page+0x331/0x5b0
[ 556.478992] ? reweight_entity+0x1e6/0x3b0
[ 556.479826] f2fs_truncate_blocks+0x55e/0x740
[ 556.480709] ? f2fs_truncate_data_blocks+0x20/0x20
[ 556.481689] ? __radix_tree_lookup+0x34/0x160
[ 556.482630] ? radix_tree_lookup+0xd/0x10
[ 556.483445] f2fs_truncate+0xd4/0x1a0
[ 556.484206] f2fs_evict_inode+0x5ce/0x630
[ 556.485032] evict+0x16f/0x290
[ 556.485664] iput+0x280/0x300
[ 556.486300] dentry_unlink_inode+0x165/0x1e0
[ 556.487169] __dentry_kill+0x16a/0x260
[ 556.487936] dentry_kill+0x70/0x250
[ 556.488651] shrink_dentry_list+0x125/0x260
[ 556.489504] shrink_dcache_parent+0xc1/0x110
[ 556.490379] ? shrink_dcache_sb+0x200/0x200
[ 556.491231] ? bit_wait_timeout+0xc0/0xc0
[ 556.492047] do_one_tree+0x12/0x40
[ 556.492743] shrink_dcache_for_umount+0x3f/0xa0
[ 556.493656] generic_shutdown_super+0x43/0x1c0
[ 556.494561] kill_block_super+0x52/0x80
[ 556.495341] kill_f2fs_super+0x62/0x70
[ 556.496105] deactivate_locked_super+0x6f/0xa0
[ 556.497004] deactivate_super+0x5e/0x80
[ 556.497785] cleanup_mnt+0x61/0xa0
[ 556.498492] __cleanup_mnt+0x12/0x20
[ 556.499218] task_work_run+0xc8/0xf0
[ 556.499949] exit_to_usermode_loop+0x125/0x130
[ 556.500846] do_syscall_64+0x138/0x170
[ 556.501609] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[ 556.502659] RIP: 0033:0x7f8028b77487
[ 556.503384] Code: 83 c8 ff c3 66 2e 0f 1f 84 00 00 00 00 00 0f 1f 44 00 00 31 f6 e9 09 00 00 00 66 0f 1f 84 00 00 00 00 00 b8 a6 00 00 00 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d e1 c9 2b 00 f7 d8 64 89 01 48
[ 556.507137] RSP: 002b:00007fff9f2e3598 EFLAGS: 00000246 ORIG_RAX: 00000000000000a6
[ 556.508637] RAX: 0000000000000000 RBX: 0000000000ebd030 RCX: 00007f8028b77487
[ 556.510069] RDX: 0000000000000001 RSI: 0000000000000000 RDI: 0000000000ec41e0
[ 556.511481] RBP: 0000000000ec41e0 R08: 0000000000000000 R09: 0000000000000014
[ 556.512892] R10: 00000000000006b2 R11: 0000000000000246 R12: 00007f802908083c
[ 556.514320] R13: 0000000000000000 R14: 0000000000ebd210 R15: 00007fff9f2e3820
[ 556.515745] Modules linked in: snd_hda_codec_generic snd_hda_intel snd_hda_codec snd_hwdep snd_hda_core snd_pcm snd_timer snd mac_hid i2c_piix4 soundcore ib_iser rdma_cm iw_cm ib_cm ib_core iscsi_tcp libiscsi_tcp libiscsi scsi_transport_iscsi raid10 raid456 async_raid6_recov async_memcpy async_pq async_xor async_tx raid1 raid0 multipath linear 8139too crct10dif_pclmul crc32_pclmul qxl drm_kms_helper syscopyarea aesni_intel sysfillrect sysimgblt fb_sys_fops ttm drm aes_x86_64 crypto_simd cryptd 8139cp glue_helper mii pata_acpi floppy
[ 556.529276] ---[ end trace 4ce02f25ff7d3df5 ]---
[ 556.530340] RIP: 0010:f2fs_truncate_inode_blocks+0x4a7/0x6f0
[ 556.531513] Code: e8 ae ea ff ff 41 89 c7 c1 e8 1f 84 c0 74 0a 41 83 ff fe 0f 85 35 ff ff ff 81 85 b0 fe ff ff fb 03 00 00 e9 f7 fd ff ff 0f 0b <0f> 0b e8 62 b7 9a 00 48 8b bd a0 fe ff ff e8 56 54 ae ff 48 8b b5
[ 556.535330] RSP: 0018:ffff8801f292f808 EFLAGS: 00010286
[ 556.536395] RAX: ffffed003e73242d RBX: ffff8801f292f958 RCX: ffffffffb88b81bc
[ 556.537824] RDX: 0000000000000000 RSI: 0000000000000004 RDI: ffff8801f3992164
[ 556.539290] RBP: ffff8801f292f980 R08: ffffed003e73242d R09: ffffed003e73242d
[ 556.540709] R10: 0000000000000001 R11: ffffed003e73242c R12: 00000000fffffc64
[ 556.542131] R13: ffff8801f3992000 R14: 0000000000000058 R15: 00000000ffff8801
[ 556.543579] FS: 00007f8029297840(0000) GS:ffff8801f6f00000(0000) knlGS:0000000000000000
[ 556.545180] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 556.546338] CR2: 000055f5f57305d8 CR3: 00000001f18b0000 CR4: 00000000000006e0
[ 556.547809] ==================================================================
[ 556.549248] BUG: KASAN: stack-out-of-bounds in arch_tlb_gather_mmu+0x52/0x170
[ 556.550672] Write of size 8 at addr ffff8801f292fd10 by task umount/1310
[ 556.552338] CPU: 1 PID: 1310 Comm: umount Tainted: G D 4.18.0-rc1+ #4
[ 556.553886] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Ubuntu-1.8.2-1ubuntu1 04/01/2014
[ 556.555756] Call Trace:
[ 556.556264] dump_stack+0x7b/0xb5
[ 556.556944] print_address_description+0x70/0x290
[ 556.557903] kasan_report+0x291/0x390
[ 556.558649] ? arch_tlb_gather_mmu+0x52/0x170
[ 556.559537] __asan_store8+0x57/0x90
[ 556.560268] arch_tlb_gather_mmu+0x52/0x170
[ 556.561110] tlb_gather_mmu+0x12/0x40
[ 556.561862] exit_mmap+0x123/0x2a0
[ 556.562555] ? __ia32_sys_munmap+0x50/0x50
[ 556.563384] ? exit_aio+0x98/0x230
[ 556.564079] ? __x32_compat_sys_io_submit+0x260/0x260
[ 556.565099] ? taskstats_exit+0x1f4/0x640
[ 556.565925] ? kasan_check_read+0x11/0x20
[ 556.566739] ? mm_update_next_owner+0x322/0x380
[ 556.567652] mmput+0x8b/0x1d0
[ 556.568260] do_exit+0x43a/0x1390
[ 556.568937] ? mm_update_next_owner+0x380/0x380
[ 556.569855] ? deactivate_super+0x5e/0x80
[ 556.570668] ? cleanup_mnt+0x61/0xa0
[ 556.571395] ? __cleanup_mnt+0x12/0x20
[ 556.572156] ? task_work_run+0xc8/0xf0
[ 556.572917] ? exit_to_usermode_loop+0x125/0x130
[ 556.573861] rewind_stack_do_exit+0x17/0x20
[ 556.574707] RIP: 0033:0x7f8028b77487
[ 556.575428] Code: Bad RIP value.
[ 556.576106] RSP: 002b:00007fff9f2e3598 EFLAGS: 00000246 ORIG_RAX: 00000000000000a6
[ 556.577599] RAX: 0000000000000000 RBX: 0000000000ebd030 RCX: 00007f8028b77487
[ 556.579020] RDX: 0000000000000001 RSI: 0000000000000000 RDI: 0000000000ec41e0
[ 556.580422] RBP: 0000000000ec41e0 R08: 0000000000000000 R09: 0000000000000014
[ 556.581833] R10: 00000000000006b2 R11: 0000000000000246 R12: 00007f802908083c
[ 556.583252] R13: 0000000000000000 R14: 0000000000ebd210 R15: 00007fff9f2e3820
[ 556.584983] The buggy address belongs to the page:
[ 556.585961] page:ffffea0007ca4bc0 count:0 mapcount:0 mapping:0000000000000000 index:0x0
[ 556.587540] flags: 0x2ffff0000000000()
[ 556.588296] raw: 02ffff0000000000 0000000000000000 dead000000000200 0000000000000000
[ 556.589822] raw: 0000000000000000 0000000000000000 00000000ffffffff 0000000000000000
[ 556.591359] page dumped because: kasan: bad access detected
[ 556.592786] Memory state around the buggy address:
[ 556.593753] ffff8801f292fc00: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 556.595191] ffff8801f292fc80: 00 00 00 00 00 00 00 00 f1 f1 f1 f1 00 00 00 00
[ 556.596613] >ffff8801f292fd00: 00 00 f3 00 00 00 00 f3 f3 00 00 00 00 f4 f4 f4
[ 556.598044] ^
[ 556.598797] ffff8801f292fd80: f3 f3 f3 f3 00 00 00 00 00 00 00 00 00 00 00 00
[ 556.600225] ffff8801f292fe00: 00 00 00 00 00 00 00 00 f1 f1 f1 f1 00 f4 f4 f4
[ 556.601647] ==================================================================
- Location
https://elixir.bootlin.com/linux/v4.18-rc1/source/fs/f2fs/node.c#L987
case NODE_DIND_BLOCK:
err = truncate_nodes(&dn, nofs, offset[1], 3);
cont = 0;
break;
default:
BUG(); <---
commit 9dc956b2c8523aed39d1e6508438be9fea28c8fc upstream.
This patch fixs to do sanity check with user_block_count.
- Overview
Divide zero in utilization when mount() a corrupted f2fs image
- Kernel message
[ 564.099503] F2FS-fs (loop0): invalid crc value
[ 564.101991] divide error: 0000 [#1] SMP KASAN PTI
[ 564.103103] CPU: 1 PID: 1298 Comm: f2fs_discard-7: Not tainted 4.18.0-rc1+ #4
[ 564.104584] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Ubuntu-1.8.2-1ubuntu1 04/01/2014
[ 564.106624] RIP: 0010:issue_discard_thread+0x248/0x5c0
[ 564.107692] Code: ff ff 48 8b bd e8 fe ff ff 41 8b 9d 4c 04 00 00 e8 cd b8 ad ff 41 8b 85 50 04 00 00 31 d2 48 8d 04 80 48 8d 04 80 48 c1 e0 02 <48> f7 f3 83 f8 50 7e 16 41 c7 86 7c ff ff ff 01 00 00 00 41 c7 86
[ 564.111686] RSP: 0018:ffff8801f3117dc0 EFLAGS: 00010206
[ 564.112775] RAX: 0000000000000384 RBX: 0000000000000000 RCX: ffffffffb88c1e03
[ 564.114250] RDX: 0000000000000000 RSI: dffffc0000000000 RDI: ffff8801e3aa4850
[ 564.115706] RBP: ffff8801f3117f00 R08: 1ffffffff751a1d0 R09: fffffbfff751a1d0
[ 564.117177] R10: 0000000000000001 R11: fffffbfff751a1d0 R12: 00000000fffffffc
[ 564.118634] R13: ffff8801e3aa4400 R14: ffff8801f3117ed8 R15: ffff8801e2050000
[ 564.120094] FS: 0000000000000000(0000) GS:ffff8801f6f00000(0000) knlGS:0000000000000000
[ 564.121748] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 564.122923] CR2: 000000000202b078 CR3: 00000001f11ac000 CR4: 00000000000006e0
[ 564.124383] Call Trace:
[ 564.124924] ? __issue_discard_cmd+0x480/0x480
[ 564.125882] ? __sched_text_start+0x8/0x8
[ 564.126756] ? __kthread_parkme+0xcb/0x100
[ 564.127620] ? kthread_blkcg+0x70/0x70
[ 564.128412] kthread+0x180/0x1d0
[ 564.129105] ? __issue_discard_cmd+0x480/0x480
[ 564.130029] ? kthread_associate_blkcg+0x150/0x150
[ 564.131033] ret_from_fork+0x35/0x40
[ 564.131794] Modules linked in: snd_hda_codec_generic snd_hda_intel snd_hda_codec snd_hwdep snd_hda_core snd_pcm snd_timer snd mac_hid i2c_piix4 soundcore ib_iser rdma_cm iw_cm ib_cm ib_core iscsi_tcp libiscsi_tcp libiscsi scsi_transport_iscsi raid10 raid456 async_raid6_recov async_memcpy async_pq async_xor async_tx raid1 raid0 multipath linear 8139too crct10dif_pclmul crc32_pclmul qxl drm_kms_helper syscopyarea aesni_intel sysfillrect sysimgblt fb_sys_fops ttm drm aes_x86_64 crypto_simd cryptd 8139cp glue_helper mii pata_acpi floppy
[ 564.141798] ---[ end trace 4ce02f25ff7d3df5 ]---
[ 564.142773] RIP: 0010:issue_discard_thread+0x248/0x5c0
[ 564.143885] Code: ff ff 48 8b bd e8 fe ff ff 41 8b 9d 4c 04 00 00 e8 cd b8 ad ff 41 8b 85 50 04 00 00 31 d2 48 8d 04 80 48 8d 04 80 48 c1 e0 02 <48> f7 f3 83 f8 50 7e 16 41 c7 86 7c ff ff ff 01 00 00 00 41 c7 86
[ 564.147776] RSP: 0018:ffff8801f3117dc0 EFLAGS: 00010206
[ 564.148856] RAX: 0000000000000384 RBX: 0000000000000000 RCX: ffffffffb88c1e03
[ 564.150424] RDX: 0000000000000000 RSI: dffffc0000000000 RDI: ffff8801e3aa4850
[ 564.151906] RBP: ffff8801f3117f00 R08: 1ffffffff751a1d0 R09: fffffbfff751a1d0
[ 564.153463] R10: 0000000000000001 R11: fffffbfff751a1d0 R12: 00000000fffffffc
[ 564.154915] R13: ffff8801e3aa4400 R14: ffff8801f3117ed8 R15: ffff8801e2050000
[ 564.156405] FS: 0000000000000000(0000) GS:ffff8801f6f00000(0000) knlGS:0000000000000000
[ 564.158070] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 564.159279] CR2: 000000000202b078 CR3: 00000001f11ac000 CR4: 00000000000006e0
[ 564.161043] ==================================================================
[ 564.162587] BUG: KASAN: stack-out-of-bounds in from_kuid_munged+0x1d/0x50
[ 564.163994] Read of size 4 at addr ffff8801f3117c84 by task f2fs_discard-7:/1298
[ 564.165852] CPU: 1 PID: 1298 Comm: f2fs_discard-7: Tainted: G D 4.18.0-rc1+ #4
[ 564.167593] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Ubuntu-1.8.2-1ubuntu1 04/01/2014
[ 564.169522] Call Trace:
[ 564.170057] dump_stack+0x7b/0xb5
[ 564.170778] print_address_description+0x70/0x290
[ 564.171765] kasan_report+0x291/0x390
[ 564.172540] ? from_kuid_munged+0x1d/0x50
[ 564.173408] __asan_load4+0x78/0x80
[ 564.174148] from_kuid_munged+0x1d/0x50
[ 564.174962] do_notify_parent+0x1f5/0x4f0
[ 564.175808] ? send_sigqueue+0x390/0x390
[ 564.176639] ? css_set_move_task+0x152/0x340
[ 564.184197] do_exit+0x1290/0x1390
[ 564.184950] ? __issue_discard_cmd+0x480/0x480
[ 564.185884] ? mm_update_next_owner+0x380/0x380
[ 564.186829] ? __sched_text_start+0x8/0x8
[ 564.187672] ? __kthread_parkme+0xcb/0x100
[ 564.188528] ? kthread_blkcg+0x70/0x70
[ 564.189333] ? kthread+0x180/0x1d0
[ 564.190052] ? __issue_discard_cmd+0x480/0x480
[ 564.190983] rewind_stack_do_exit+0x17/0x20
[ 564.192190] The buggy address belongs to the page:
[ 564.193213] page:ffffea0007cc45c0 count:0 mapcount:0 mapping:0000000000000000 index:0x0
[ 564.194856] flags: 0x2ffff0000000000()
[ 564.195644] raw: 02ffff0000000000 0000000000000000 dead000000000200 0000000000000000
[ 564.197247] raw: 0000000000000000 0000000000000000 00000000ffffffff 0000000000000000
[ 564.198826] page dumped because: kasan: bad access detected
[ 564.200299] Memory state around the buggy address:
[ 564.201306] ffff8801f3117b80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 564.202779] ffff8801f3117c00: 00 00 00 00 00 00 00 00 00 00 00 f3 f3 f3 f3 f3
[ 564.204252] >ffff8801f3117c80: f3 f3 f3 00 00 00 00 00 00 00 00 00 f1 f1 f1 f1
[ 564.205742] ^
[ 564.206424] ffff8801f3117d00: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 564.207908] ffff8801f3117d80: f3 f3 f3 f3 f3 f3 f3 f3 00 00 00 00 00 00 00 00
[ 564.209389] ==================================================================
[ 564.231795] F2FS-fs (loop0): Mounted with checkpoint version = 2
- Location
https://elixir.bootlin.com/linux/v4.18-rc1/source/fs/f2fs/segment.h#L586
return div_u64((u64)valid_user_blocks(sbi) * 100,
sbi->user_block_count);
Missing checks on sbi->user_block_count.
Reported-by: Wen Xu <wen.xu@gatech.edu>
commit 76d56d4ab4f2a9e4f085c7d77172194ddaccf7d2 upstream.
If FI_EXTRA_ATTR is set in inode by fuzzing, inode.i_addr[0] will be
parsed as inode.i_extra_isize, then in __recover_inline_status, inline
data address will beyond boundary of page, result in accessing invalid
memory.
So in this condition, during reading inode page, let's do sanity check
with EXTRA_ATTR feature of fs and extra_attr bit of inode, if they're
inconsistent, deny to load this inode.
- Overview
Out-of-bound access in f2fs_iget() when mounting a corrupted f2fs image
- Reproduce
The following message will be got in KASAN build of 4.18 upstream kernel.
[ 819.392227] ==================================================================
[ 819.393901] BUG: KASAN: slab-out-of-bounds in f2fs_iget+0x736/0x1530
[ 819.395329] Read of size 4 at addr ffff8801f099c968 by task mount/1292
[ 819.397079] CPU: 1 PID: 1292 Comm: mount Not tainted 4.18.0-rc1+ #4
[ 819.397082] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Ubuntu-1.8.2-1ubuntu1 04/01/2014
[ 819.397088] Call Trace:
[ 819.397124] dump_stack+0x7b/0xb5
[ 819.397154] print_address_description+0x70/0x290
[ 819.397159] kasan_report+0x291/0x390
[ 819.397163] ? f2fs_iget+0x736/0x1530
[ 819.397176] check_memory_region+0x139/0x190
[ 819.397182] __asan_loadN+0xf/0x20
[ 819.397185] f2fs_iget+0x736/0x1530
[ 819.397197] f2fs_fill_super+0x1b4f/0x2b40
[ 819.397202] ? f2fs_fill_super+0x1b4f/0x2b40
[ 819.397208] ? f2fs_commit_super+0x1b0/0x1b0
[ 819.397227] ? set_blocksize+0x90/0x140
[ 819.397241] mount_bdev+0x1c5/0x210
[ 819.397245] ? f2fs_commit_super+0x1b0/0x1b0
[ 819.397252] f2fs_mount+0x15/0x20
[ 819.397256] mount_fs+0x60/0x1a0
[ 819.397267] ? alloc_vfsmnt+0x309/0x360
[ 819.397272] vfs_kern_mount+0x6b/0x1a0
[ 819.397282] do_mount+0x34a/0x18c0
[ 819.397300] ? lockref_put_or_lock+0xcf/0x160
[ 819.397306] ? copy_mount_string+0x20/0x20
[ 819.397318] ? memcg_kmem_put_cache+0x1b/0xa0
[ 819.397324] ? kasan_check_write+0x14/0x20
[ 819.397334] ? _copy_from_user+0x6a/0x90
[ 819.397353] ? memdup_user+0x42/0x60
[ 819.397359] ksys_mount+0x83/0xd0
[ 819.397365] __x64_sys_mount+0x67/0x80
[ 819.397388] do_syscall_64+0x78/0x170
[ 819.397403] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[ 819.397422] RIP: 0033:0x7f54c667cb9a
[ 819.397424] Code: 48 8b 0d 01 c3 2b 00 f7 d8 64 89 01 48 83 c8 ff c3 66 2e 0f 1f 84 00 00 00 00 00 0f 1f 44 00 00 49 89 ca b8 a5 00 00 00 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d ce c2 2b 00 f7 d8 64 89 01 48
[ 819.397483] RSP: 002b:00007ffd8f46cd08 EFLAGS: 00000202 ORIG_RAX: 00000000000000a5
[ 819.397496] RAX: ffffffffffffffda RBX: 0000000000dfa030 RCX: 00007f54c667cb9a
[ 819.397498] RDX: 0000000000dfa210 RSI: 0000000000dfbf30 RDI: 0000000000e02ec0
[ 819.397501] RBP: 0000000000000000 R08: 0000000000000000 R09: 0000000000000013
[ 819.397503] R10: 00000000c0ed0000 R11: 0000000000000202 R12: 0000000000e02ec0
[ 819.397505] R13: 0000000000dfa210 R14: 0000000000000000 R15: 0000000000000003
[ 819.397866] Allocated by task 139:
[ 819.398702] save_stack+0x46/0xd0
[ 819.398705] kasan_kmalloc+0xad/0xe0
[ 819.398709] kasan_slab_alloc+0x11/0x20
[ 819.398713] kmem_cache_alloc+0xd1/0x1e0
[ 819.398717] dup_fd+0x50/0x4c0
[ 819.398740] copy_process.part.37+0xbed/0x32e0
[ 819.398744] _do_fork+0x16e/0x590
[ 819.398748] __x64_sys_clone+0x69/0x80
[ 819.398752] do_syscall_64+0x78/0x170
[ 819.398756] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[ 819.399097] Freed by task 159:
[ 819.399743] save_stack+0x46/0xd0
[ 819.399747] __kasan_slab_free+0x13c/0x1a0
[ 819.399750] kasan_slab_free+0xe/0x10
[ 819.399754] kmem_cache_free+0x89/0x1e0
[ 819.399757] put_files_struct+0x132/0x150
[ 819.399761] exit_files+0x62/0x70
[ 819.399766] do_exit+0x47b/0x1390
[ 819.399770] do_group_exit+0x86/0x130
[ 819.399774] __x64_sys_exit_group+0x2c/0x30
[ 819.399778] do_syscall_64+0x78/0x170
[ 819.399782] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[ 819.400115] The buggy address belongs to the object at ffff8801f099c680
which belongs to the cache files_cache of size 704
[ 819.403234] The buggy address is located 40 bytes to the right of
704-byte region [ffff8801f099c680, ffff8801f099c940)
[ 819.405689] The buggy address belongs to the page:
[ 819.406709] page:ffffea0007c26700 count:1 mapcount:0 mapping:ffff8801f69a3340 index:0xffff8801f099d380 compound_mapcount: 0
[ 819.408984] flags: 0x2ffff0000008100(slab|head)
[ 819.409932] raw: 02ffff0000008100 ffffea00077fb600 0000000200000002 ffff8801f69a3340
[ 819.411514] raw: ffff8801f099d380 0000000080130000 00000001ffffffff 0000000000000000
[ 819.413073] page dumped because: kasan: bad access detected
[ 819.414539] Memory state around the buggy address:
[ 819.415521] ffff8801f099c800: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
[ 819.416981] ffff8801f099c880: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
[ 819.418454] >ffff8801f099c900: fb fb fb fb fb fb fb fb fc fc fc fc fc fc fc fc
[ 819.419921] ^
[ 819.421265] ffff8801f099c980: fc fc fc fc fc fc fc fc fb fb fb fb fb fb fb fb
[ 819.422745] ffff8801f099ca00: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
[ 819.424206] ==================================================================
[ 819.425668] Disabling lock debugging due to kernel taint
[ 819.457463] F2FS-fs (loop0): Mounted with checkpoint version = 3
The kernel still mounts the image. If you run the following program on the mounted folder mnt,
(poc.c)
char *foo_bar_baz;
int err;
int fd = open(foo_bar_baz, O_RDONLY, 0);
if (fd >= 0) {
read(fd, (char *)buf, 11);
close(fd);
activity(argv[1]);
return 0;
You can get kernel crash:
[ 918.028501] BUG: unable to handle kernel paging request at ffffed0048000d82
[ 918.044020] PGD 23ffee067 P4D 23ffee067 PUD 23fbef067 PMD 0
[ 918.045207] Oops: 0000 [#1] SMP KASAN PTI
[ 918.046048] CPU: 0 PID: 1309 Comm: poc Tainted: G B 4.18.0-rc1+ #4
[ 918.047573] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Ubuntu-1.8.2-1ubuntu1 04/01/2014
[ 918.049552] RIP: 0010:check_memory_region+0x5e/0x190
[ 918.050565] Code: f8 49 c1 e8 03 49 89 db 49 c1 eb 03 4d 01 cb 4d 01 c1 4d 8d 63 01 4c 89 c8 4d 89 e2 4d 29 ca 49 83 fa 10 7f 3d 4d 85 d2 74 32 <41> 80 39 00 75 23 48 b8 01 00 00 00 00 fc ff df 4d 01 d1 49 01 c0
[ 918.054322] RSP: 0018:ffff8801e3a1f258 EFLAGS: 00010202
[ 918.055400] RAX: ffffed0048000d82 RBX: ffff880240006c11 RCX: ffffffffb8867d14
[ 918.056832] RDX: 0000000000000000 RSI: 0000000000000002 RDI: ffff880240006c10
[ 918.058253] RBP: ffff8801e3a1f268 R08: 1ffff10048000d82 R09: ffffed0048000d82
[ 918.059717] R10: 0000000000000001 R11: ffffed0048000d82 R12: ffffed0048000d83
[ 918.061159] R13: ffff8801e3a1f390 R14: 0000000000000000 R15: ffff880240006c08
[ 918.062614] FS: 00007fac9732c700(0000) GS:ffff8801f6e00000(0000) knlGS:0000000000000000
[ 918.064246] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 918.065412] CR2: ffffed0048000d82 CR3: 00000001df77a000 CR4: 00000000000006f0
[ 918.066882] Call Trace:
[ 918.067410] __asan_loadN+0xf/0x20
[ 918.068149] f2fs_find_target_dentry+0xf4/0x270
[ 918.069083] ? __get_node_page+0x331/0x5b0
[ 918.069925] f2fs_find_in_inline_dir+0x24b/0x310
[ 918.070881] ? f2fs_recover_inline_data+0x4c0/0x4c0
[ 918.071905] ? unwind_next_frame.part.5+0x34f/0x490
[ 918.072901] ? unwind_dump+0x290/0x290
[ 918.073695] ? is_bpf_text_address+0xe/0x20
[ 918.074566] __f2fs_find_entry+0x599/0x670
[ 918.075408] ? kasan_unpoison_shadow+0x36/0x50
[ 918.076315] ? kasan_kmalloc+0xad/0xe0
[ 918.077100] ? memcg_kmem_put_cache+0x55/0xa0
[ 918.077998] ? f2fs_find_target_dentry+0x270/0x270
[ 918.079006] ? d_set_d_op+0x30/0x100
[ 918.079749] ? __d_lookup_rcu+0x69/0x2e0
[ 918.080556] ? __d_alloc+0x275/0x450
[ 918.081297] ? kasan_check_write+0x14/0x20
[ 918.082135] ? memset+0x31/0x40
[ 918.082820] ? fscrypt_setup_filename+0x1ec/0x4c0
[ 918.083782] ? d_alloc_parallel+0x5bb/0x8c0
[ 918.084640] f2fs_find_entry+0xe9/0x110
[ 918.085432] ? __f2fs_find_entry+0x670/0x670
[ 918.086308] ? kasan_check_write+0x14/0x20
[ 918.087163] f2fs_lookup+0x297/0x590
[ 918.087902] ? f2fs_link+0x2b0/0x2b0
[ 918.088646] ? legitimize_path.isra.29+0x61/0xa0
[ 918.089589] __lookup_slow+0x12e/0x240
[ 918.090371] ? may_delete+0x2b0/0x2b0
[ 918.091123] ? __nd_alloc_stack+0xa0/0xa0
[ 918.091944] lookup_slow+0x44/0x60
[ 918.092642] walk_component+0x3ee/0xa40
[ 918.093428] ? is_bpf_text_address+0xe/0x20
[ 918.094283] ? pick_link+0x3e0/0x3e0
[ 918.095047] ? in_group_p+0xa5/0xe0
[ 918.095771] ? generic_permission+0x53/0x1e0
[ 918.096666] ? security_inode_permission+0x1d/0x70
[ 918.097646] ? inode_permission+0x7a/0x1f0
[ 918.098497] link_path_walk+0x2a2/0x7b0
[ 918.099298] ? apparmor_capget+0x3d0/0x3d0
[ 918.100140] ? walk_component+0xa40/0xa40
[ 918.100958] ? path_init+0x2e6/0x580
[ 918.101695] path_openat+0x1bb/0x2160
[ 918.102471] ? __save_stack_trace+0x92/0x100
[ 918.103352] ? save_stack+0xb5/0xd0
[ 918.104070] ? vfs_unlink+0x250/0x250
[ 918.104822] ? save_stack+0x46/0xd0
[ 918.105538] ? kasan_slab_alloc+0x11/0x20
[ 918.106370] ? kmem_cache_alloc+0xd1/0x1e0
[ 918.107213] ? getname_flags+0x76/0x2c0
[ 918.107997] ? getname+0x12/0x20
[ 918.108677] ? do_sys_open+0x14b/0x2c0
[ 918.109450] ? __x64_sys_open+0x4c/0x60
[ 918.110255] ? do_syscall_64+0x78/0x170
[ 918.111083] ? entry_SYSCALL_64_after_hwframe+0x44/0xa9
[ 918.112148] ? entry_SYSCALL_64_after_hwframe+0x44/0xa9
[ 918.113204] ? f2fs_empty_inline_dir+0x1e0/0x1e0
[ 918.114150] ? timespec64_trunc+0x5c/0x90
[ 918.114993] ? wb_io_lists_depopulated+0x1a/0xc0
[ 918.115937] ? inode_io_list_move_locked+0x102/0x110
[ 918.116949] do_filp_open+0x12b/0x1d0
[ 918.117709] ? may_open_dev+0x50/0x50
[ 918.118475] ? kasan_kmalloc+0xad/0xe0
[ 918.119246] do_sys_open+0x17c/0x2c0
[ 918.119983] ? do_sys_open+0x17c/0x2c0
[ 918.120751] ? filp_open+0x60/0x60
[ 918.121463] ? task_work_run+0x4d/0xf0
[ 918.122237] __x64_sys_open+0x4c/0x60
[ 918.123001] do_syscall_64+0x78/0x170
[ 918.123759] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[ 918.124802] RIP: 0033:0x7fac96e3e040
[ 918.125537] Code: 00 f7 d8 64 89 01 48 83 c8 ff c3 66 2e 0f 1f 84 00 00 00 00 00 0f 1f 44 00 00 83 3d 09 27 2d 00 00 75 10 b8 02 00 00 00 0f 05 <48> 3d 01 f0 ff ff 73 31 c3 48 83 ec 08 e8 7e e0 01 00 48 89 04 24
[ 918.129341] RSP: 002b:00007fff1b37f848 EFLAGS: 00000246 ORIG_RAX: 0000000000000002
[ 918.130870] RAX: ffffffffffffffda RBX: 0000000000000000 RCX: 00007fac96e3e040
[ 918.132295] RDX: 0000000000000000 RSI: 0000000000000000 RDI: 000000000122d080
[ 918.133748] RBP: 00007fff1b37f9b0 R08: 00007fac9710bbd8 R09: 0000000000000001
[ 918.135209] R10: 000000000000069d R11: 0000000000000246 R12: 0000000000400c20
[ 918.136650] R13: 00007fff1b37fab0 R14: 0000000000000000 R15: 0000000000000000
[ 918.138093] Modules linked in: snd_hda_codec_generic snd_hda_intel snd_hda_codec snd_hwdep snd_hda_core snd_pcm snd_timer snd mac_hid i2c_piix4 soundcore ib_iser rdma_cm iw_cm ib_cm ib_core iscsi_tcp libiscsi_tcp libiscsi scsi_transport_iscsi raid10 raid456 async_raid6_recov async_memcpy async_pq async_xor async_tx raid1 raid0 multipath linear 8139too crct10dif_pclmul crc32_pclmul qxl drm_kms_helper syscopyarea aesni_intel sysfillrect sysimgblt fb_sys_fops ttm drm aes_x86_64 crypto_simd cryptd 8139cp glue_helper mii pata_acpi floppy
[ 918.147924] CR2: ffffed0048000d82
[ 918.148619] ---[ end trace 4ce02f25ff7d3df5 ]---
[ 918.149563] RIP: 0010:check_memory_region+0x5e/0x190
[ 918.150576] Code: f8 49 c1 e8 03 49 89 db 49 c1 eb 03 4d 01 cb 4d 01 c1 4d 8d 63 01 4c 89 c8 4d 89 e2 4d 29 ca 49 83 fa 10 7f 3d 4d 85 d2 74 32 <41> 80 39 00 75 23 48 b8 01 00 00 00 00 fc ff df 4d 01 d1 49 01 c0
[ 918.154360] RSP: 0018:ffff8801e3a1f258 EFLAGS: 00010202
[ 918.155411] RAX: ffffed0048000d82 RBX: ffff880240006c11 RCX: ffffffffb8867d14
[ 918.156833] RDX: 0000000000000000 RSI: 0000000000000002 RDI: ffff880240006c10
[ 918.158257] RBP: ffff8801e3a1f268 R08: 1ffff10048000d82 R09: ffffed0048000d82
[ 918.159722] R10: 0000000000000001 R11: ffffed0048000d82 R12: ffffed0048000d83
[ 918.161149] R13: ffff8801e3a1f390 R14: 0000000000000000 R15: ffff880240006c08
[ 918.162587] FS: 00007fac9732c700(0000) GS:ffff8801f6e00000(0000) knlGS:0000000000000000
[ 918.164203] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 918.165356] CR2: ffffed0048000d82 CR3: 00000001df77a000 CR4: 00000000000006f0
[bwh: Backported to 4.14: adjust context]
Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
This was done as part of commit 5d64600d4f33 "f2fs: avoid bug_on on
corrupted inode" upstream, but the specific check that commit added is
not applicable to 4.14.
Cc: Jaegeuk Kim <jaegeuk@kernel.org>
Cc: Chao Yu <yuchao0@huawei.com>
commit 42bf546c1fe3f3654bdf914e977acbc2b80a5be5 upstream.
As Wen Xu reported in below link:
https://bugzilla.kernel.org/show_bug.cgi?id=200183
- Overview
Divide zero in reset_curseg() when mounting a crafted f2fs image
- Reproduce
- Kernel message
[ 588.281510] divide error: 0000 [#1] SMP KASAN PTI
[ 588.282701] CPU: 0 PID: 1293 Comm: mount Not tainted 4.18.0-rc1+ #4
[ 588.284000] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Ubuntu-1.8.2-1ubuntu1 04/01/2014
[ 588.286178] RIP: 0010:reset_curseg+0x94/0x1a0
[ 588.298166] RSP: 0018:ffff8801e88d7940 EFLAGS: 00010246
[ 588.299360] RAX: 0000000000000014 RBX: ffff8801e1d46d00 RCX: ffffffffb88bf60b
[ 588.300809] RDX: 0000000000000000 RSI: dffffc0000000000 RDI: ffff8801e1d46d64
[ 588.305272] R13: 0000000000000000 R14: 0000000000000014 R15: 0000000000000000
[ 588.306822] FS: 00007fad85008840(0000) GS:ffff8801f6e00000(0000) knlGS:0000000000000000
[ 588.308456] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 588.309623] CR2: 0000000001705078 CR3: 00000001f30f8000 CR4: 00000000000006f0
[ 588.311085] Call Trace:
[ 588.311637] f2fs_build_segment_manager+0x103f/0x3410
[ 588.316136] ? f2fs_commit_super+0x1b0/0x1b0
[ 588.317031] ? set_blocksize+0x90/0x140
[ 588.319473] f2fs_mount+0x15/0x20
[ 588.320166] mount_fs+0x60/0x1a0
[ 588.320847] ? alloc_vfsmnt+0x309/0x360
[ 588.321647] vfs_kern_mount+0x6b/0x1a0
[ 588.322432] do_mount+0x34a/0x18c0
[ 588.323175] ? strndup_user+0x46/0x70
[ 588.323937] ? copy_mount_string+0x20/0x20
[ 588.324793] ? memcg_kmem_put_cache+0x1b/0xa0
[ 588.325702] ? kasan_check_write+0x14/0x20
[ 588.326562] ? _copy_from_user+0x6a/0x90
[ 588.327375] ? memdup_user+0x42/0x60
[ 588.328118] ksys_mount+0x83/0xd0
[ 588.328808] __x64_sys_mount+0x67/0x80
[ 588.329607] do_syscall_64+0x78/0x170
[ 588.330400] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[ 588.331461] RIP: 0033:0x7fad848e8b9a
[ 588.336022] RSP: 002b:00007ffd7c5b6be8 EFLAGS: 00000206 ORIG_RAX: 00000000000000a5
[ 588.337547] RAX: ffffffffffffffda RBX: 00000000016f8030 RCX: 00007fad848e8b9a
[ 588.338999] RDX: 00000000016f8210 RSI: 00000000016f9f30 RDI: 0000000001700ec0
[ 588.340442] RBP: 0000000000000000 R08: 0000000000000000 R09: 0000000000000013
[ 588.341887] R10: 00000000c0ed0000 R11: 0000000000000206 R12: 0000000001700ec0
[ 588.343341] R13: 00000000016f8210 R14: 0000000000000000 R15: 0000000000000003
[ 588.354891] ---[ end trace 4ce02f25ff7d3df5 ]---
[ 588.355862] RIP: 0010:reset_curseg+0x94/0x1a0
[ 588.360742] RSP: 0018:ffff8801e88d7940 EFLAGS: 00010246
[ 588.361812] RAX: 0000000000000014 RBX: ffff8801e1d46d00 RCX: ffffffffb88bf60b
[ 588.363485] RDX: 0000000000000000 RSI: dffffc0000000000 RDI: ffff8801e1d46d64
[ 588.365213] RBP: ffff8801e88d7968 R08: ffffed003c32266f R09: ffffed003c32266f
[ 588.366661] R10: 0000000000000001 R11: ffffed003c32266e R12: ffff8801f0337700
[ 588.368110] R13: 0000000000000000 R14: 0000000000000014 R15: 0000000000000000
[ 588.370057] FS: 00007fad85008840(0000) GS:ffff8801f6e00000(0000) knlGS:0000000000000000
[ 588.372099] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 588.373291] CR2: 0000000001705078 CR3: 00000001f30f8000 CR4: 00000000000006f0
- Location
https://elixir.bootlin.com/linux/latest/source/fs/f2fs/segment.c#L2147
curseg->zone = GET_ZONE_FROM_SEG(sbi, curseg->segno);
If secs_per_zone is corrupted due to fuzzing test, it will cause divide
zero operation when using GET_ZONE_FROM_SEG macro, so we should do more
sanity check with secs_per_zone during mount to avoid this issue.
commit e1da7872f6eda977bd812346bf588c35e4495a1e upstream.
This patch introduces verify_blkaddr to check meta/data block address
with valid range to detect bug earlier.
In addition, once we encounter an invalid blkaddr, notice user to run
fsck to fix, and let the kernel panic.
[bwh: Backported to 4.14: I skipped an earlier renaming of
is_valid_meta_blkaddr() to f2fs_is_valid_meta_blkaddr()]
commit 7b525dd01365c6764018e374d391c92466be1b7a upstream.
- rename is_valid_blkaddr() to is_valid_meta_blkaddr() for readability.
- introduce is_valid_blkaddr() for cleanup.
No logic change in this patch.
commit 0cfe75c5b011994651a4ca6d74f20aa997bfc69a upstream.
In order to avoid the below overflow issue, we should have checked the
boundaries in superblock before reaching out to allocation. As Linus suggested,
the right place should be sanity_check_raw_super().
Dr Silvio Cesare of InfoSect reported:
There are integer overflows with using the cp_payload superblock field in the
f2fs filesystem potentially leading to memory corruption.
include/linux/f2fs_fs.h
struct f2fs_super_block {
__le32 cp_payload;
fs/f2fs/f2fs.h
typedef u32 block_t; /*
* should not change u32, since it is the on-disk block
* address format, __le32.
static inline block_t __cp_payload(struct f2fs_sb_info *sbi)
return le32_to_cpu(F2FS_RAW_SUPER(sbi)->cp_payload);
fs/f2fs/checkpoint.c
block_t start_blk, orphan_blocks, i, j;
start_blk = __start_cp_addr(sbi) + 1 + __cp_payload(sbi);
orphan_blocks = __start_sum_addr(sbi) - 1 - __cp_payload(sbi);
+++ integer overflows
unsigned int cp_blks = 1 + __cp_payload(sbi);
sbi->ckpt = kzalloc(cp_blks * blk_size, GFP_KERNEL);
+++ integer overflow leading to incorrect heap allocation.
int cp_payload_blks = __cp_payload(sbi);
ckpt->cp_pack_start_sum = cpu_to_le32(1 + cp_payload_blks +
orphan_blocks);
+++ sign bug and integer overflow
for (i = 1; i < 1 + cp_payload_blks; i++)
sbi->max_orphans = (sbi->blocks_per_seg - F2FS_CP_PACKS -
NR_CURSEG_TYPE - __cp_payload(sbi)) *
F2FS_ORPHANS_PER_BLOCK;
Reported-by: Greg KH <greg@kroah.com>
Reported-by: Silvio Cesare <silvio.cesare@gmail.com>
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
Reviewed-by: Chao Yu <yuchao0@huawei.com>
[bwh: Backported to 4.14: No hot file extension support]
commit b2ca374f33bd33fd822eb871876e4888cf79dc97 upstream.
syzbot hit the following crash on upstream commit
87ef12027b9b1dd0e0b12cf311fbcb19f9d92539 (Wed Apr 18 19:48:17 2018 +0000)
Merge tag 'ceph-for-4.17-rc2' of git://github.com/ceph/ceph-client
syzbot dashboard link: https://syzkaller.appspot.com/bug?extid=83699adeb2d13579c31e
C reproducer: https://syzkaller.appspot.com/x/repro.c?id=5805208181407744
syzkaller reproducer: https://syzkaller.appspot.com/x/repro.syz?id=6005073343676416
Raw console output: https://syzkaller.appspot.com/x/log.txt?id=6555047731134464
Kernel config: https://syzkaller.appspot.com/x/.config?id=1808800213120130118
compiler: gcc (GCC) 8.0.1 20180413 (experimental)
IMPORTANT: if you fix the bug, please add the following tag to the commit:
Reported-by: syzbot+83699adeb2d13579c31e@syzkaller.appspotmail.com
It will help syzbot understand when the bug is fixed. See footer for details.
If you forward the report, please keep this part and the footer.
F2FS-fs (loop0): Magic Mismatch, valid(0xf2f52010) - read(0x0)
F2FS-fs (loop0): Can't find valid F2FS filesystem in 1th superblock
BUG: unable to handle kernel paging request at ffffed006b2a50c0
PGD 21ffee067 P4D 21ffee067 PUD 21fbeb067 PMD 0
Dumping ftrace buffer:
(ftrace buffer empty)
Modules linked in:
CPU: 0 PID: 4514 Comm: syzkaller989480 Not tainted 4.17.0-rc1+ #8
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011
RIP: 0010:build_sit_entries fs/f2fs/segment.c:3653 [inline]
RIP: 0010:build_segment_manager+0x7ef7/0xbf70 fs/f2fs/segment.c:3852
RSP: 0018:ffff8801b102e5b0 EFLAGS: 00010a06
RAX: 1ffff1006b2a50c0 RBX: 0000000000000004 RCX: 0000000000000001
RDX: 0000000000000000 RSI: 0000000000000001 RDI: ffff8801ac74243e
RBP: ffff8801b102f410 R08: ffff8801acbd46c0 R09: fffffbfff14d9af8
R10: fffffbfff14d9af8 R11: ffff8801acbd46c0 R12: ffff8801ac742a80
R13: ffff8801d9519100 R14: dffffc0000000000 R15: ffff880359528600
FS: 0000000001e04880(0000) GS:ffff8801dae00000(0000) knlGS:0000000000000000
CR2: ffffed006b2a50c0 CR3: 00000001ac6ac000 CR4: 00000000001406f0
DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
Call Trace:
f2fs_fill_super+0x4095/0x7bf0 fs/f2fs/super.c:2803
mount_bdev+0x30c/0x3e0 fs/super.c:1165
f2fs_mount+0x34/0x40 fs/f2fs/super.c:3020
mount_fs+0xae/0x328 fs/super.c:1268
vfs_kern_mount.part.34+0xd4/0x4d0 fs/namespace.c:1037
vfs_kern_mount fs/namespace.c:1027 [inline]
do_new_mount fs/namespace.c:2517 [inline]
do_mount+0x564/0x3070 fs/namespace.c:2847
ksys_mount+0x12d/0x140 fs/namespace.c:3063
__do_sys_mount fs/namespace.c:3077 [inline]
__se_sys_mount fs/namespace.c:3074 [inline]
__x64_sys_mount+0xbe/0x150 fs/namespace.c:3074
do_syscall_64+0x1b1/0x800 arch/x86/entry/common.c:287
entry_SYSCALL_64_after_hwframe+0x49/0xbe
RIP: 0033:0x443d6a
RSP: 002b:00007ffd312813c8 EFLAGS: 00000297 ORIG_RAX: 00000000000000a5
RAX: ffffffffffffffda RBX: 0000000020000c00 RCX: 0000000000443d6a
RDX: 0000000020000000 RSI: 0000000020000100 RDI: 00007ffd312813d0
RBP: 0000000000000003 R08: 0000000020016a00 R09: 000000000000000a
R10: 0000000000000000 R11: 0000000000000297 R12: 0000000000000004
R13: 0000000000402c60 R14: 0000000000000000 R15: 0000000000000000
RIP: build_sit_entries fs/f2fs/segment.c:3653 [inline] RSP: ffff8801b102e5b0
RIP: build_segment_manager+0x7ef7/0xbf70 fs/f2fs/segment.c:3852 RSP: ffff8801b102e5b0
---[ end trace a2034989e196ff17 ]---
Reported-and-tested-by: syzbot+83699adeb2d13579c31e@syzkaller.appspotmail.com
Signed-off-by: Jaegeuk Kim <jaegeuk@kernel.org>
commit 0833721ec3658a4e9d5e58b6fa82cf9edc431e59 upstream.
This patch check blkaddr more accuratly before issue a
write or read bio.
Signed-off-by: Yunlei He <heyunlei@huawei.com>
commit 4c58ed076875f36dae0f240da1e25e99e5d4afb8 upstream.
Below race can cause reversed reference on dirty count, fix it by
relocating __submit_bio() and inc_page_count().
Thread A Thread B
- f2fs_inplace_write_data
- f2fs_submit_page_bio
- __submit_bio
- f2fs_write_end_io
- dec_page_count
- inc_page_count
Cc: <stable@vger.kernel.org>
Fixes: d1b3e72d5490 ("f2fs: submit bio of in-place-update pages")
Signed-off-by: Chao Yu <yuchao0@huawei.com>
commit 164a63fa6b384e30ceb96ed80bc7dc3379bc0960 upstream.
This reverts commit 66110abc4c931f879d70e83e1281f891699364bf.
If we clear the cold data flag out of the writeback flow, we can miscount
-1 by end_io, which incurs a deadlock caused by all I/Os being blocked during
heavy GC.
Balancing F2FS Async:
- IO (CP: 1, Data: -1, Flush: ( 0 0 1), Discard: ( ...
GC thread: IRQ
- move_data_page()
- set_page_dirty()
- clear_cold_data()
- f2fs_write_end_io()
- type = WB_DATA_TYPE(page);
here, we get wrong type
- dec_page_count(sbi, type);
- f2fs_wait_on_page_writeback()
Reported-and-Tested-by: Park Ju Hyung <qkrwngud825@gmail.com>
