Signed-off-by: Brian Swetland <swetland@google.com>
We are clearly missing '~' in fat_ioctl_set_attributes().
Cc: <stable@kernel.org>
Reported-by: Dmitry Dmitriev <dimondmm@yandex.ru>
Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
fat does not have problems with references to unlinked directories.
CC: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
Signed-off-by: Sage Weil <sage@newdream.net>
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (25 commits)
cifs: remove unnecessary dentry_unhash on rmdir/rename_dir
ocfs2: remove unnecessary dentry_unhash on rmdir/rename_dir
exofs: remove unnecessary dentry_unhash on rmdir/rename_dir
nfs: remove unnecessary dentry_unhash on rmdir/rename_dir
ext2: remove unnecessary dentry_unhash on rmdir/rename_dir
ext3: remove unnecessary dentry_unhash on rmdir/rename_dir
ext4: remove unnecessary dentry_unhash on rmdir/rename_dir
btrfs: remove unnecessary dentry_unhash in rmdir/rename_dir
ceph: remove unnecessary dentry_unhash calls
vfs: clean up vfs_rename_other
vfs: clean up vfs_rename_dir
vfs: clean up vfs_rmdir
vfs: fix vfs_rename_dir for FS_RENAME_DOES_D_MOVE filesystems
libfs: drop unneeded dentry_unhash
vfs: update dentry_unhash() comment
vfs: push dentry_unhash on rename_dir into file systems
vfs: push dentry_unhash on rmdir into file systems
vfs: remove dget() from dentry_unhash()
vfs: dentry_unhash immediately prior to rmdir
vfs: Block mmapped writes while the fs is frozen
Only a few file systems need this. Start by pushing it down into each
rename method (except gfs2 and xfs) so that it can be dealt with on a
per-fs basis.
Acked-by: Christoph Hellwig <hch@lst.de>
fs rmdir method (except gfs2 and xfs) so it can be dealt with on a per-fs
basis.
This does not change behavior for any in-tree file systems.
pathconf(, _PC_NAME_MAX) is too small for long Unicode filename on fat.
255 as max filename size on fat is Unicode UTF-16 characters.
it's not byte size.
https://bugzilla.kernel.org/show_bug.cgi?id=16469
To fix it, this returns "len * NLS_MAX_CHARSET_SIZE" instead.
Reported-by: Takumi Asaki <takumi.asaki@nokia.com>
Replace all printk with fat_msg()
Signed-off-by: Alexey Fisher <bug-track@fisher-privat.net>
Add fat_msg() to replace not cosequent used printk() in fs/fat/*
New message format should be as fallow:
FAT-fs (sda1): some thing happened.
- convert fat_fs_error to use %pV
- be consequent and use "supor_block *sb" instead of "supor_block *s"
- use devise name in each message.
Reported-by: <dame_eugene@mail.ru>
* 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-block: (65 commits)
Documentation/iostats.txt: bit-size reference etc.
cfq-iosched: removing unnecessary think time checking
cfq-iosched: Don't clear queue stats when preempt.
blk-throttle: Reset group slice when limits are changed
blk-cgroup: Only give unaccounted_time under debug
cfq-iosched: Don't set active queue in preempt
block: fix non-atomic access to genhd inflight structures
block: attempt to merge with existing requests on plug flush
block: NULL dereference on error path in __blkdev_get()
cfq-iosched: Don't update group weights when on service tree
fs: assign sb->s_bdi to default_backing_dev_info if the bdi is going away
block: Require subsystems to explicitly allocate bio_set integrity mempool
jbd2: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging
jbd: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging
fs: make fsync_buffers_list() plug
mm: make generic_writepages() use plugging
blk-cgroup: Add unaccounted time to timeslice_used.
block: fixup plugging stubs for !CONFIG_BLOCK
block: remove obsolete comments for blkdev_issue_zeroout.
blktrace: Use rq->cmd_flags directly in blk_add_trace_rq.
Fix up conflicts in fs/{aio.c,super.c}
The exportfs encode handle function should return the minimum required
handle size. This helps user to find out the handle size by passing 0
handle size in the first step and then redoing to the call again with
the returned handle size value.
Acked-by: Serge Hallyn <serue@us.ibm.com>
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
can't blindly check nd->flags in ->d_revalidate()
Code has been converted over to the new explicit on-stack plugging,
and delay users have been converted to use the new API for that.
So lets kill off the old plugging along with aops->sync_page().
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
don't bother with lock_super() in fat_fill_super() callers, while
we are at it - there won't be any concurrency anyway.
Require filesystems be aware of .d_revalidate being called in rcu-walk
mode (nd->flags & LOOKUP_RCU). For now do a simple push down, returning
-ECHILD from all implementations.
Signed-off-by: Nick Piggin <npiggin@kernel.dk>
Reduce some branches and memory accesses in dcache lookup by adding dentry
flags to indicate common d_ops are set, rather than having to check them.
This saves a pointer memory access (dentry->d_op) in common path lookup
situations, and saves another pointer load and branch in cases where we
have d_op but not the particular operation.
Patched with:
git grep -E '[.>]([[:space:]])*d_op([[:space:]])*=' | xargs sed -e 's/\([^\t ]*\)->d_op = \(.*\);/d_set_d_op(\1, \2);/' -e 's/\([^\t ]*\)\.d_op = \(.*\);/d_set_d_op(\&\1, \2);/' -i
RCU free the struct inode. This will allow:
- Subsequent store-free path walking patch. The inode must be consulted for
permissions when walking, so an RCU inode reference is a must.
- sb_inode_list_lock to be moved inside i_lock because sb list walkers who want
to take i_lock no longer need to take sb_inode_list_lock to walk the list in
the first place. This will simplify and optimize locking.
- Could remove some nested trylock loops in dcache code
- Could potentially simplify things a bit in VM land. Do not need to take the
page lock to follow page->mapping.
The downsides of this is the performance cost of using RCU. In a simple
creat/unlink microbenchmark, performance drops by about 10% due to inability to
reuse cache-hot slab objects. As iterations increase and RCU freeing starts
kicking over, this increases to about 20%.
In cases where inode lifetimes are longer (ie. many inodes may be allocated
during the average life span of a single inode), a lot of this cache reuse is
not applicable, so the regression caused by this patch is smaller.
The cache-hot regression could largely be avoided by using SLAB_DESTROY_BY_RCU,
however this adds some complexity to list walking and store-free path walking,
so I prefer to implement this at a later date, if it is shown to be a win in
real situations. I haven't found a regression in any non-micro benchmark so I
doubt it will be a problem.
Change d_hash so it may be called from lock-free RCU lookups. See similar
patch for d_compare for details.
For in-tree filesystems, this is just a mechanical change.
Change d_compare so it may be called from lock-free RCU lookups. This
does put significant restrictions on what may be done from the callback,
however there don't seem to have been any problems with in-tree fses.
If some strange use case pops up that _really_ cannot cope with the
rcu-walk rules, we can just add new rcu-unaware callbacks, which would
cause name lookup to drop out of rcu-walk mode.
... and switch of the obvious get_sb_bdev() users to ->mount()
* 'for-2.6.37/barrier' of git://git.kernel.dk/linux-2.6-block: (46 commits)
xen-blkfront: disable barrier/flush write support
Added blk-lib.c and blk-barrier.c was renamed to blk-flush.c
block: remove BLKDEV_IFL_WAIT
aic7xxx_old: removed unused 'req' variable
block: remove the BH_Eopnotsupp flag
block: remove the BLKDEV_IFL_BARRIER flag
block: remove the WRITE_BARRIER flag
swap: do not send discards as barriers
fat: do not send discards as barriers
ext4: do not send discards as barriers
jbd2: replace barriers with explicit flush / FUA usage
jbd2: Modify ASYNC_COMMIT code to not rely on queue draining on barrier
jbd: replace barriers with explicit flush / FUA usage
nilfs2: replace barriers with explicit flush / FUA usage
reiserfs: replace barriers with explicit flush / FUA usage
gfs2: replace barriers with explicit flush / FUA usage
btrfs: replace barriers with explicit flush / FUA usage
xfs: replace barriers with explicit flush / FUA usage
block: pass gfp_mask and flags to sb_issue_discard
dm: convey that all flushes are processed as empty
The lock_kernel in fat_put_super is not needed because
it only protects the super block itself and we know that
no other thread can reach it because we are about to
kfree the object.
In the two fill_super functions, this converts the locking
to use lock_super like elsewhere in the fat code. This
is probably not needed either, but is consistent and puts
us on the safe side.
Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
Cc: Jan Blunck <jblunck@infradead.org>
This patch is a preparation necessary to remove the BKL from do_new_mount().
It explicitly adds calls to lock_kernel()/unlock_kernel() around
get_sb/fill_super operations for filesystems that still uses the BKL.
I've read through all the code formerly covered by the BKL inside
do_kern_mount() and have satisfied myself that it doesn't need the BKL
any more.
do_kern_mount() is already called without the BKL when mounting the rootfs
and in nfsctl. do_kern_mount() calls vfs_kern_mount(), which is called
from various places without BKL: simple_pin_fs(), nfs_do_clone_mount()
through nfs_follow_mountpoint(), afs_mntpt_do_automount() through
afs_mntpt_follow_link(). Both later functions are actually the filesystems
follow_link inode operation. vfs_kern_mount() is calling the specified
get_sb function and lets the filesystem do its job by calling the given
fill_super function.
Therefore I think it is safe to push down the BKL from the VFS to the
low-level filesystems get_sb/fill_super operation.
[arnd: do not add the BKL to those file systems that already
don't use it elsewhere]
Signed-off-by: Jan Blunck <jblunck@infradead.org>
Cc: Matthew Wilcox <matthew@wil.cx>
All the blkdev_issue_* helpers can only sanely be used for synchronous
caller. To issue cache flushes or barriers asynchronously the caller needs
to set up a bio by itself with a completion callback to move the asynchronous
state machine ahead. So drop the BLKDEV_IFL_WAIT flag that is always
specified when calling blkdev_issue_* and also remove the now unused flags
argument to blkdev_issue_flush and blkdev_issue_zeroout. For
blkdev_issue_discard we need to keep it for the secure discard flag, which
gains a more descriptive name and loses the bitops vs flag confusion.
This flag was only set for barrier buffers, which we don't submit
anymore.
fat already uses synchronous discards, no need to add I/O barriers.
We'll need to get rid of the BLKDEV_IFL_BARRIER flag, and to facilitate
that and to make the interface less confusing pass all flags explicitly.
Acked-by: Mike Snitzer <snitzer@redhat.com>
These flags aren't real I/O types, but tell ll_rw_block to always
lock the buffer instead of giving up on a failed trylock.
Instead add a new write_dirty_buffer helper that implements this semantic
and use it from the existing SWRITE* callers. Note that the ll_rw_block
code had a bug where it didn't promote WRITE_SYNC_PLUG properly, which
this patch fixes.
In the ufs code clean up the helper that used to call ll_rw_block
to mirror sync_dirty_buffer, which is the function it implements for
compound buffers.
Make sure we check the truncate constraints early on in ->setattr by adding
those checks to inode_change_ok. Also clean up and document inode_change_ok
to make this obvious.
As a fallout we don't have to call inode_newsize_ok from simple_setsize and
simplify it down to a truncate_setsize which doesn't return an error. This
simplifies a lot of setattr implementations and means we use truncate_setsize
almost everywhere. Get rid of fat_setsize now that it's trivial and mark
ext2_setsize static to make the calling convention obvious.
Keep the inode_newsize_ok in vmtruncate for now as all callers need an
audit for its removal anyway.
Note: setattr code in ecryptfs doesn't call inode_change_ok at all and
needs a deeper audit, but that is left for later.
Make sure we call inode_change_ok before doing any changes in ->setattr,
and make sure to call it even if our fs wants to ignore normal UNIX
permissions, but use the ATTR_FORCE to skip those.
Despite its name it's now a generic implementation of ->setattr, but
rather a helper to copy attributes from a struct iattr to the inode.
Rename it to setattr_copy to reflect this fact.
Move the call to vmtruncate to get rid of accessive blocks to the callers
in preparation of the new truncate sequence and rename the non-truncating
version to cont_write_begin.
in prepearation of the new truncate calling sequence. This was only done
for DIO_LOCKING filesystems, so the __blockdev_direct_IO_newtrunc variant
was not needed anyway. Get rid of blockdev_direct_IO_no_locking and
its _newtrunc variant while at it as just opencoding the two additional
paramters is shorted than the name suffix.
Signed-off-by: Nick Piggin <npiggin@suse.de>
We don't name our generic fsync implementations very well currently.
The no-op implementation for in-memory filesystems currently is called
simple_sync_file which doesn't make too much sense to start with,
the the generic one for simple filesystems is called simple_fsync
which can lead to some confusion.
This patch renames the generic file fsync method to generic_file_fsync
to match the other generic_file_* routines it is supposed to be used
with, and the no-op implementation to noop_fsync to make it obvious
what to expect. In addition add some documentation for both methods.
* git://git.kernel.org/pub/scm/linux/kernel/git/hirofumi/fatfs-2.6:
fat: convert to unlocked_ioctl
fat: Cleanup nls_unload() usage
fat: use pack_hex_byte() instead of custom one
FAT does not require the BKL in its ioctl function, which is already serialized
through a mutex. Since we're already touching the ioctl code, also fix the
missing handling of FAT_IOCTL_GET_ATTRIBUTES in the compat code.
When using the string representation of a random counter as part of the base
name, ensure that it is no longer than 4 bytes.
Since we are repeatedly decrementing the counter in a loop until we have found a
unique base name, the counter may wrap around zero; therefore, it is not enough
to mask its higher bits before entering the loop, this must be done inside the
loop.
[hirofumi@mail.parknet.co.jp: use snprintf()]
Signed-off-by: Nikolaus Schulz <microschulz@web.de>
Cc: stable@kernel.org
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Other users doesn't check NULL explicitly. So, these doesn't also
check to remove inconsistency.
Signed-off-by: Andy Shevchenko <ext-andriy.shevchenko@nokia.com>
fat: Fix stat->f_namelen
fat: Fix vfat_lookup()
This gives the filesystem more information about the writeback that
is happening. Trond requested this for the NFS unstable write handling,
and other filesystems might benefit from this too by beeing able to
distinguish between the different callers in more detail.
