path: root/fs/fat
2013-06-07fat: fix possible overflow for fat_clustersOGAWA Hirofumi
commit 7b92d03c3239f43e5b86c9cc9630f026d36ee995 upstream. Intermediate value of fat_clusters can be overflowed on 32bits arch. Reported-by: Krzysztof Strasburger <strasbur@chkw386.ch.pwr.wroc.pl> Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-23fat: fix bug in enforcing Long File Name lengthNamjae Jeon
Since '*outlen' is initialized to zero, it is currently possible to create a filename of length (FAT_LFN_LEN + 1) when utf8 is not enabled. To enforce the FAT_LFN_LEN limit, we must perform one less iteration. Signed-off-by: Namjae Jeon <linkinjeon@gmail.com> Signed-off-by: Ravishankar N <cyberax82@gmail.com> Acked-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-23fat: clean up xlate_to_uni()Namjae Jeon
xlate_to_uni() is called by vfat_build_slots() with sbi->nls_io as the final argument. nls_io can never be null at this point because the check is already being done in fat_fill_super() wherein the mount fails if it is null. Signed-off-by: Namjae Jeon <linkinjeon@gmail.com> Signed-off-by: Ravishankar N <cyberax82@gmail.com> Acked-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-20fat: switch to d_make_root()Al Viro
2012-01-09Merge branch 'usb-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb * 'usb-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (232 commits) USB: Add USB-ID for Multiplex RC serial adapter to cp210x.c xhci: Clean up 32-bit build warnings. USB: update documentation for usbmon usb: usb-storage doesn't support dynamic id currently, the patch disables the feature to fix an oops drivers/usb/class/cdc-acm.c: clear dangling pointer drivers/usb/dwc3/dwc3-pci.c: introduce missing kfree drivers/usb/host/isp1760-if.c: introduce missing kfree usb: option: add ZD Incorporated HSPA modem usb: ch9: fix up MaxStreams helper USB: usb-skeleton.c: cleanup open_count USB: usb-skeleton.c: fix open/disconnect race xhci: Properly handle COMP_2ND_BW_ERR USB: remove dead code from suspend/resume path USB: add quirk for another camera drivers: usb: wusbcore: Fix dependency for USB_WUSB xhci: Better debugging for critical host errors. xhci: Be less verbose during URB cancellation. xhci: Remove debugging about ring structure allocation. xhci: Remove debugging about toggling cycle bits. xhci: Remove debugging for individual transfers. ...
2012-01-08Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (53 commits) Kconfig: acpi: Fix typo in comment. misc latin1 to utf8 conversions devres: Fix a typo in devm_kfree comment btrfs: free-space-cache.c: remove extra semicolon. fat: Spelling s/obsolate/obsolete/g SCSI, pmcraid: Fix spelling error in a pmcraid_err() call tools/power turbostat: update fields in manpage mac80211: drop spelling fix types.h: fix comment spelling for 'architectures' typo fixes: aera -> area, exntension -> extension devices.txt: Fix typo of 'VMware'. sis900: Fix enum typo 'sis900_rx_bufer_status' decompress_bunzip2: remove invalid vi modeline treewide: Fix comment and string typo 'bufer' hyper-v: Update MAINTAINERS treewide: Fix typos in various parts of the kernel, and fix some comments. clockevents: drop unknown Kconfig symbol GENERIC_CLOCKEVENTS_MIGR gpio: Kconfig: drop unknown symbol 'CS5535_GPIO' leds: Kconfig: Fix typo 'D2NET_V2' sound: Kconfig: drop unknown symbol ARCH_CLPS7500 ... Fix up trivial conflicts in arch/powerpc/platforms/40x/Kconfig (some new kconfig additions, close to removed commented-out old ones)
2012-01-06vfs: switch ->show_options() to struct dentry *Al Viro
2012-01-03fat: propagate umode_tAl Viro
2012-01-03switch ->create() to umode_tAl Viro
vfs_create() ignores everything outside of 16bit subset of its mode argument; switching it to umode_t is obviously equivalent and it's the only caller of the method Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-01-03switch vfs_mkdir() and ->mkdir() to umode_tAl Viro
vfs_mkdir() gets int, but immediately drops everything that might not fit into umode_t and that's the only caller of ->mkdir()... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-01-03vfs: fix the stupidity with i_dentry in inode destructorsAl Viro
Seeing that just about every destructor got that INIT_LIST_HEAD() copied into it, there is no point whatsoever keeping this INIT_LIST_HEAD in inode_init_once(); the cost of taking it into inode_init_always() will be negligible for pipes and sockets and negative for everything else. Not to mention the removal of boilerplate code from ->destroy_inode() instances... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-01-03vfs: mnt_drop_write_file()Al Viro
new helper (wrapper around mnt_drop_write()) to be used in pair with mnt_want_write_file(). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-01-03switch a bunch of places to mnt_want_write_file()Al Viro
it's both faster (in case when file has been opened for write) and cleaner. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-12-15fat: Spelling s/obsolate/obsolete/gGeert Uytterhoeven
Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-11-18NLS: improve UTF8 -> UTF16 string conversion routineAlan Stern
The utf8s_to_utf16s conversion routine needs to be improved. Unlike its utf16s_to_utf8s sibling, it doesn't accept arguments specifying the maximum length of the output buffer or the endianness of its 16-bit output. This patch (as1501) adds the two missing arguments, and adjusts the only two places in the kernel where the function is called. A follow-on patch will add a third caller that does utilize the new capabilities. The two conversion routines are still annoyingly inconsistent in the way they handle invalid byte combinations. But that's a subject for a different patch. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> CC: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-02filesystems: add set_nlink()Miklos Szeredi
Replace remaining direct i_nlink updates with a new set_nlink() updater function. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Tested-by: Toshiyuki Okajima <toshi.okajima@jp.fujitsu.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2011-10-31fat: follow rename pack_hex_byte() to hex_byte_pack()Andy Shevchenko
There is no functional change. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Acked-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-31treewide: use __printf not __attribute__((format(printf,...)))Joe Perches
Standardize the style for compiler based printf format verification. Standardized the location of __printf too. Done via script and a little typing. $ grep -rPl --include=*.[ch] -w "__attribute__" * | \ grep -vP "^(tools|scripts|include/linux/compiler-gcc.h)" | \ xargs perl -n -i -e 'local $/; while (<>) { s/\b__attribute__\s*\(\s*\(\s*format\s*\(\s*printf\s*,\s*(.+)\s*,\s*(.+)\s*\)\s*\)\s*\)/__printf($1, $2)/g ; print; }' [akpm@linux-foundation.org: revert arch bits] Signed-off-by: Joe Perches <joe@perches.com> Cc: "Kirill A. Shutemov" <kirill@shutemov.name> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/hirofumi/fatfs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/hirofumi/fatfs-2.6: fat: fat16 support maximum 4GB file/vol size as WinXP or 7. fat: fix utf8 iocharset warning message fat: fix build warning
2011-08-17fat: fat16 support maximum 4GB file/vol size as WinXP or 7.Namjae Jeon
FAT16 support maximum 4GB vol/file size with 64KB cluster size. Win NT/XP/7 increased the maximum cluster size to 64KB, and file/vol size increased 4GB also. Although increasing, the file size of linux FAT is still limited at 2GB. I found that it is limited by sb->maxbytes(0x7fffffff) when partition is formatted by FAT16. sb->s_maxbytes in fill_super should be set to 0xffffffff like fat32. Signed-off-by: Namjae Jeon <linkinjeon@gmail.com> Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
2011-08-17fat: fix utf8 iocharset warning messageMihai Moldovan
The fat_msg function already formats the given message and appends a newline to it - we don't need to do this in the passed message string as well, or will end up with a blank line printed in the kernel log ring buffer. Also change the loglevel from error to warning. Signed-off-by: Mihai Moldovan <ionic@ionic.de> Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
2011-08-17fat: fix build warningJonas Aberg
This fixes a compile warning (unititialized variable) in the fat filesystem code. Signed-off-by: Jonas Aberg <jonas.aberg@stericsson.com> Signed-off-by: Lee Jones <lee.jones@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
2011-07-20fs: push i_mutex and filemap_write_and_wait down into ->fsync() handlersJosef Bacik
Btrfs needs to be able to control how filemap_write_and_wait_range() is called in fsync to make it less of a painful operation, so push down taking i_mutex and the calling of filemap_write_and_wait() down into the ->fsync() handlers. Some file systems can drop taking the i_mutex altogether it seems, like ext3 and ocfs2. For correctness sake I just pushed everything down in all cases to make sure that we keep the current behavior the same for everybody, and then each individual fs maintainer can make up their mind about what to do from there. Thanks, Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20fs: simplify the blockdev_direct_IO prototypeChristoph Hellwig
Simple filesystems always pass inode->i_sb_bdev as the block device argument, and never need a end_io handler. Let's simply things for them and for my grepping activity by dropping these arguments. The only thing not falling into that scheme is ext4, which passes and end_io handler without needing special flags (yet), but given how messy the direct I/O code there is use of __blockdev_direct_IO in one instead of two out of three cases isn't going to make a large difference anyway. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20fs: move inode_dio_wait calls into ->setattrChristoph Hellwig
Let filesystems handle waiting for direct I/O requests themselves instead of doing it beforehand. This means filesystem-specific locks to prevent new dio referenes from appearing can be held. This is important to allow generalizing i_dio_count to non-DIO_LOCKING filesystems. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20fat: remove i_alloc_sem abuseChristoph Hellwig
Add a new rw_semaphore to protect bmap against truncate. Previous i_alloc_sem was abused for this, but it's going away in this series. Note that we can't simply use i_mutex, given that the swapon code calls ->bmap under it. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20make d_splice_alias(ERR_PTR(err), dentry) = ERR_PTR(err)Al Viro
... and simplify the living hell out of callers Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20LOOKUP_CREATE and LOOKUP_RENAME_TARGET can be set only on the last stepAl Viro
2011-05-31fat: Fix corrupt inode flags when remove ATTR_SYS flagOGAWA Hirofumi
We are clearly missing '~' in fat_ioctl_set_attributes(). Cc: <stable@kernel.org> Reported-by: Dmitry Dmitriev <dimondmm@yandex.ru> Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
2011-05-28fat: remove unnecessary dentry_unhash on rmdir, dir renameSage Weil
fat does not have problems with references to unlinked directories. CC: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Sage Weil <sage@newdream.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (25 commits) cifs: remove unnecessary dentry_unhash on rmdir/rename_dir ocfs2: remove unnecessary dentry_unhash on rmdir/rename_dir exofs: remove unnecessary dentry_unhash on rmdir/rename_dir nfs: remove unnecessary dentry_unhash on rmdir/rename_dir ext2: remove unnecessary dentry_unhash on rmdir/rename_dir ext3: remove unnecessary dentry_unhash on rmdir/rename_dir ext4: remove unnecessary dentry_unhash on rmdir/rename_dir btrfs: remove unnecessary dentry_unhash in rmdir/rename_dir ceph: remove unnecessary dentry_unhash calls vfs: clean up vfs_rename_other vfs: clean up vfs_rename_dir vfs: clean up vfs_rmdir vfs: fix vfs_rename_dir for FS_RENAME_DOES_D_MOVE filesystems libfs: drop unneeded dentry_unhash vfs: update dentry_unhash() comment vfs: push dentry_unhash on rename_dir into file systems vfs: push dentry_unhash on rmdir into file systems vfs: remove dget() from dentry_unhash() vfs: dentry_unhash immediately prior to rmdir vfs: Block mmapped writes while the fs is frozen ...
2011-05-26vfs: push dentry_unhash on rename_dir into file systemsSage Weil
Only a few file systems need this. Start by pushing it down into each rename method (except gfs2 and xfs) so that it can be dealt with on a per-fs basis. Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Sage Weil <sage@newdream.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-26vfs: push dentry_unhash on rmdir into file systemsSage Weil
Only a few file systems need this. Start by pushing it down into each fs rmdir method (except gfs2 and xfs) so it can be dealt with on a per-fs basis. This does not change behavior for any in-tree file systems. Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Sage Weil <sage@newdream.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-04-12fat: Fix statfs->f_namelenOGAWA Hirofumi
pathconf(, _PC_NAME_MAX) is too small for long Unicode filename on fat. 255 as max filename size on fat is Unicode UTF-16 characters. it's not byte size. https://bugzilla.kernel.org/show_bug.cgi?id=16469 To fix it, this returns "len * NLS_MAX_CHARSET_SIZE" instead. Reported-by: Takumi Asaki <takumi.asaki@nokia.com> Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
2011-04-12fat: Replace all printk with fat_msg()Alexey Fisher
Replace all printk with fat_msg() Signed-off-by: Alexey Fisher <bug-track@fisher-privat.net> Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
2011-04-12fat: Add fat_msg() function for preformated FAT messagesAlexey Fisher
Add fat_msg() to replace not cosequent used printk() in fs/fat/* New message format should be as fallow: FAT-fs (sda1): some thing happened. Signed-off-by: Alexey Fisher <bug-track@fisher-privat.net> Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
2011-04-12fat: Convert fat_fs_error to use %pVAlexey Fisher
- convert fat_fs_error to use %pV - be consequent and use "supor_block *sb" instead of "supor_block *s" - use devise name in each message. Signed-off-by: Alexey Fisher <bug-track@fisher-privat.net> Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
2011-04-12fat: Fix possible null deref in fat_cache_add()OGAWA Hirofumi
Reported-by: <dame_eugene@mail.ru> Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
2011-04-12fat: use new setup() for ->dir_ops tooOGAWA Hirofumi
2011-03-24Merge branch 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-block: (65 commits) Documentation/iostats.txt: bit-size reference etc. cfq-iosched: removing unnecessary think time checking cfq-iosched: Don't clear queue stats when preempt. blk-throttle: Reset group slice when limits are changed blk-cgroup: Only give unaccounted_time under debug cfq-iosched: Don't set active queue in preempt block: fix non-atomic access to genhd inflight structures block: attempt to merge with existing requests on plug flush block: NULL dereference on error path in __blkdev_get() cfq-iosched: Don't update group weights when on service tree fs: assign sb->s_bdi to default_backing_dev_info if the bdi is going away block: Require subsystems to explicitly allocate bio_set integrity mempool jbd2: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging jbd: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging fs: make fsync_buffers_list() plug mm: make generic_writepages() use plugging blk-cgroup: Add unaccounted time to timeslice_used. block: fixup plugging stubs for !CONFIG_BLOCK block: remove obsolete comments for blkdev_issue_zeroout. blktrace: Use rq->cmd_flags directly in blk_add_trace_rq. ... Fix up conflicts in fs/{aio.c,super.c}
2011-03-14exportfs: Return the minimum required handle sizeAneesh Kumar K.V
The exportfs encode handle function should return the minimum required handle size. This helps user to find out the handle size by passing 0 handle size in the first step and then redoing to the call again with the returned handle size value. Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-10fat: fix d_revalidate oopsen on NFS exportsAl Viro
can't blindly check nd->flags in ->d_revalidate() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-10block: remove per-queue pluggingJens Axboe
Code has been converted over to the new explicit on-stack plugging, and delay users have been converted to use the new API for that. So lets kill off the old plugging along with aops->sync_page(). Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-01-12switch fat to ->s_d_op, close exportfs races thereAl Viro
don't bother with lock_super() in fat_fill_super() callers, while we are at it - there won't be any concurrency anyway. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-01-07fs: rcu-walk aware d_revalidate methodNick Piggin
Require filesystems be aware of .d_revalidate being called in rcu-walk mode (nd->flags & LOOKUP_RCU). For now do a simple push down, returning -ECHILD from all implementations. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: dcache reduce branches in lookup pathNick Piggin
Reduce some branches and memory accesses in dcache lookup by adding dentry flags to indicate common d_ops are set, rather than having to check them. This saves a pointer memory access (dentry->d_op) in common path lookup situations, and saves another pointer load and branch in cases where we have d_op but not the particular operation. Patched with: git grep -E '[.>]([[:space:]])*d_op([[:space:]])*=' | xargs sed -e 's/\([^\t ]*\)->d_op = \(.*\);/d_set_d_op(\1, \2);/' -e 's/\([^\t ]*\)\.d_op = \(.*\);/d_set_d_op(\&\1, \2);/' -i Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: icache RCU free inodesNick Piggin
RCU free the struct inode. This will allow: - Subsequent store-free path walking patch. The inode must be consulted for permissions when walking, so an RCU inode reference is a must. - sb_inode_list_lock to be moved inside i_lock because sb list walkers who want to take i_lock no longer need to take sb_inode_list_lock to walk the list in the first place. This will simplify and optimize locking. - Could remove some nested trylock loops in dcache code - Could potentially simplify things a bit in VM land. Do not need to take the page lock to follow page->mapping. The downsides of this is the performance cost of using RCU. In a simple creat/unlink microbenchmark, performance drops by about 10% due to inability to reuse cache-hot slab objects. As iterations increase and RCU freeing starts kicking over, this increases to about 20%. In cases where inode lifetimes are longer (ie. many inodes may be allocated during the average life span of a single inode), a lot of this cache reuse is not applicable, so the regression caused by this patch is smaller. The cache-hot regression could largely be avoided by using SLAB_DESTROY_BY_RCU, however this adds some complexity to list walking and store-free path walking, so I prefer to implement this at a later date, if it is shown to be a win in real situations. I haven't found a regression in any non-micro benchmark so I doubt it will be a problem. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: change d_hash for rcu-walkNick Piggin
Change d_hash so it may be called from lock-free RCU lookups. See similar patch for d_compare for details. For in-tree filesystems, this is just a mechanical change. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: change d_compare for rcu-walkNick Piggin
Change d_compare so it may be called from lock-free RCU lookups. This does put significant restrictions on what may be done from the callback, however there don't seem to have been any problems with in-tree fses. If some strange use case pops up that _really_ cannot cope with the rcu-walk rules, we can just add new rcu-unaware callbacks, which would cause name lookup to drop out of rcu-walk mode. For in-tree filesystems, this is just a mechanical change. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2010-10-29new helper: mount_bdev()Al Viro
... and switch of the obvious get_sb_bdev() users to ->mount() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
