commit 4d2dc2cc766c3b51929658cacbc6e34fc8e242fb upstream.
Currently, we're capping the values too low in the F_GETLK64 case. The
fields in that structure are 64-bit values, so we shouldn't need to do
any sort of fixup there.
Make sure we check that assumption at build time in the future however
by ensuring that the sizes we're copying will fit.
With this, we no longer need COMPAT_LOFF_T_MAX either, so remove it.
Fixes: 94073ad77fff2 (fs/locks: don't mess with the address limit in compat_fcntl64)
Reported-by: Vitaly Lipatov <lav@etersoft.ru>
Signed-off-by: Jeff Layton <jlayton@redhat.com>
Reviewed-by: David Howells <dhowells@redhat.com>
[ Upstream commit 9280a601e6080c9ff658468c1c775ff6514099a6 ]
Currently we just return err here, but we need to put the fd reference
first.
Fixes: 94073ad77fff (fs/locks: don't mess with the address limit in compat_fcntl64)
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
When fixing things to avoid ambiguous cases I had a thinko
and included SIGPOLL/SIGIO in with all of the other signals
that have signal specific si_codes. Which is completely wrong.
Fix that.
Reported-by: Vince Weaver <vincent.weaver@maine.edu>
We have a weird and problematic intersection of features that when
they all come together result in ambiguous siginfo values, that
we can not support properly.
- Supporting fcntl(F_SETSIG,...) with arbitrary valid signals.
- Using positive values for POLL_IN, POLL_OUT, POLL_MSG, ..., etc
that imply they are signal specific si_codes and using the
aforementioned arbitrary signal to deliver them.
- Supporting injection of arbitrary siginfo values for debugging and
checkpoint/restore.
The result is that just looking at siginfo si_codes of 1 to 6 are
ambigious. It could either be a signal specific si_code or it could
be a generic si_code.
For most of the kernel this is a non-issue but for sending signals
with siginfo it is impossible to play back the kernel signals and
get the same result.
Strictly speaking when the si_code was changed from SI_SIGIO to
POLL_IN and friends between 2.2 and 2.4 this functionality was not
ambiguous, as only real time signals were supported. Before 2.4 was
released the kernel began supporting siginfo with non realtime signals
so they could give details of why the signal was sent.
The result is that if F_SETSIG is set to one of the signals with signal
specific si_codes then user space can not know why the signal was sent.
I grepped through a bunch of userspace programs using debian code
search to get a feel for how often people choose a signal that results
in an ambiguous si_code. I only found one program doing so and it was
using SIGCHLD to test the F_SETSIG functionality, and did not appear
to be a real world usage.
Therefore the ambiguity does not appears to be a real world problem in
practice. Remove the ambiguity while introducing the smallest chance
of breakage by changing the si_code to SI_SIGIO when signals with
signal specific si_codes are targeted.
Fixes: v2.3.40 -- Added support for queueing non-rt signals
Fixes: v2.3.21 -- Changed the si_code from SI_SIGIO
Michael Ellerman reported that commit 8c6657cb50cb ("Switch flock
copyin/copyout primitives to copy_{from,to}_user()") broke his
networking on a bunch of PPC machines (64-bit kernel, 32-bit userspace).
The reason is a brown-paper bug by that commit, which had the arguments
to "copy_flock_fields()" in the wrong order, breaking the compat
handling for file locking. Apparently very few people run 32-bit user
space on x86 any more, so the PPC people got the honor of noticing this
"feature".
Michael also sent a minimal diff that just changed the order of the
arguments in that macro.
This is not that minimal diff.
This not only changes the order of the arguments in the macro, it also
changes them to be pointers (to be consistent with all the other uses of
those pointers), and makes the functions that do all of this also have
the proper "const" attribution on the source pointers in order to make
issues like that (using the source as a destination) be really obvious.
Reported-by: Michael Ellerman <mpe@ellerman.id.au>
Acked-by: Al Viro <viro@zeniv.linux.org.uk>
Pull misc user access cleanups from Al Viro:
"The first pile is assorted getting rid of cargo-culted access_ok(),
cargo-culted set_fs() and field-by-field copyouts.
The same description applies to a lot of stuff in other branches -
this is just the stuff that didn't fit into a more specific topical
branch"
* 'work.misc-set_fs' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
Switch flock copyin/copyout primitives to copy_{from,to}_user()
fs/fcntl: return -ESRCH in f_setown when pid/pgid can't be found
fs/fcntl: f_setown, avoid undefined behaviour
fs/fcntl: f_setown, allow returning error
lpfc debugfs: get rid of pointless access_ok()
adb: get rid of pointless access_ok()
isdn: get rid of pointless access_ok()
compat statfs: switch to copy_to_user()
nfsd_readlink(): switch to vfs_get_link()
drbd: ->sendpage() never needed set_fs()
fs/locks: pass kernel struct flock to fcntl_getlk/setlk
fs: locks: Fix some troubles at kernel-doc comments
Some architectures (at least PPC) doesn't like get/put_user with
64-bit types on a 32-bit system. Use the variably sized copy
to/from user variants instead.
Fixes: c75b1d9421f8 ("fs: add fcntl() interface for setting/getting write life time hints")
Define a set of write life time hints:
RWH_WRITE_LIFE_NOT_SET No hint information set
RWH_WRITE_LIFE_NONE No hints about write life time
RWH_WRITE_LIFE_SHORT Data written has a short life time
RWH_WRITE_LIFE_MEDIUM Data written has a medium life time
RWH_WRITE_LIFE_LONG Data written has a long life time
RWH_WRITE_LIFE_EXTREME Data written has an extremely long life time
The intent is for these values to be relative to each other, no
absolute meaning should be attached to these flag names.
Add an fcntl interface for querying these flags, and also for
setting them as well:
F_GET_RW_HINT Returns the read/write hint set on the
underlying inode.
F_SET_RW_HINT Set one of the above write hints on the
underlying inode.
F_GET_FILE_RW_HINT Returns the read/write hint set on the
file descriptor.
F_SET_FILE_RW_HINT Set one of the above write hints on the
file descriptor.
The user passes in a 64-bit pointer to get/set these values, and
the interface returns 0/-1 on success/error.
Sample program testing/implementing basic setting/getting of write
hints is below.
Add support for storing the write life time hint in the inode flags
and in struct file as well, and pass them to the kiocb flags. If
both a file and its corresponding inode has a write hint, then we
use the one in the file, if available. The file hint can be used
for sync/direct IO, for buffered writeback only the inode hint
is available.
This is in preparation for utilizing these hints in the block layer,
to guide on-media data placement.
* writehint.c: get or set an inode write hint
#include <stdio.h>
#include <fcntl.h>
#include <stdlib.h>
#include <unistd.h>
#include <stdbool.h>
#include <inttypes.h>
#ifndef F_GET_RW_HINT
#define F_LINUX_SPECIFIC_BASE 1024
#define F_GET_RW_HINT (F_LINUX_SPECIFIC_BASE + 11)
#define F_SET_RW_HINT (F_LINUX_SPECIFIC_BASE + 12)
#endif
static char *str[] = { "RWF_WRITE_LIFE_NOT_SET", "RWH_WRITE_LIFE_NONE",
"RWH_WRITE_LIFE_SHORT", "RWH_WRITE_LIFE_MEDIUM",
"RWH_WRITE_LIFE_LONG", "RWH_WRITE_LIFE_EXTREME" };
int main(int argc, char *argv[])
uint64_t hint;
int fd, ret;
if (argc < 2) {
fprintf(stderr, "%s: file <hint>\n", argv[0]);
return 1;
fd = open(argv[1], O_RDONLY);
if (fd < 0) {
perror("open");
return 2;
if (argc > 2) {
hint = atoi(argv[2]);
ret = fcntl(fd, F_SET_RW_HINT, &hint);
if (ret < 0) {
perror("fcntl: F_SET_RW_HINT");
return 4;
ret = fcntl(fd, F_GET_RW_HINT, &hint);
if (ret < 0) {
perror("fcntl: F_GET_RW_HINT");
return 3;
printf("%s: hint %s\n", argv[1], str[hint]);
close(fd);
return 0;
Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com>
... and lose HAVE_ARCH_...; if copy_{to,from}_user() on an
architecture sucks badly enough to make it a problem, we have
a worse problem.
The current implementation of F_SETOWN doesn't properly vet the argument
passed in and only returns an error if INT_MIN is passed in. If the
argument doesn't specify a valid pid/pgid, then we just end up cleaning
out the file->f_owner structure.
What we really want is to only clean that out only in the case where
userland passed in an argument of 0. For anything else, we want to
return ESRCH if it doesn't refer to a valid pid.
The relevant POSIX spec page is here:
http://pubs.opengroup.org/onlinepubs/9699919799/functions/fcntl.html
Cc: Jiri Slaby <jslaby@suse.cz>
Cc: zhong jiang <zhongjiang@huawei.com>
fcntl(0, F_SETOWN, 0x80000000) triggers:
UBSAN: Undefined behaviour in fs/fcntl.c:118:7
negation of -2147483648 cannot be represented in type 'int':
CPU: 1 PID: 18261 Comm: syz-executor Not tainted 4.8.1-0-syzkaller #1
Call Trace:
[<ffffffffad8f0868>] ? f_setown+0x1d8/0x200
[<ffffffffad8f19a9>] ? SyS_fcntl+0x999/0xf30
[<ffffffffaed1fb00>] ? entry_SYSCALL_64_fastpath+0x23/0xc1
Fix that by checking the arg parameter properly (against INT_MAX) before
"who = -who". And return immediatelly with -EINVAL in case it is wrong.
Note that according to POSIX we can return EINVAL:
[EINVAL]
The cmd argument is F_SETOWN and the value of the argument
is not valid as a process or process group identifier.
[v2] returns an error, v1 used to fail silently
[v3] implement proper check for the bad value INT_MIN
Cc: Jeff Layton <jlayton@poochiereds.net>
Cc: "J. Bruce Fields" <bfields@fieldses.org>
Cc: linux-fsdevel@vger.kernel.org
Allow f_setown to return an error value. We will fail in the next patch
with EINVAL for bad input to f_setown, so tile the path for the later
patch.
Reviewed-by: Jeff Layton <jlayton@redhat.com>
Instead write a proper compat syscall that calls common helpers.
[ jlayton: fix pointer dereferencing in fixup_compat_flock ]
This will make it easier to implement a sane compat fcntl syscall.
[ jlayton: fix undeclared identifiers in 32-bit fcntl64 syscall handler ]
Pull misc vfs updates from Al Viro:
"Assorted bits and pieces from various people. No common topic in this
pile, sorry"
* 'work.misc' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
fs/affs: add rename exchange
fs/affs: add rename2 to prepare multiple methods
Make stat/lstat/fstatat pass AT_NO_AUTOMOUNT to vfs_statx()
fs: don't set *REFERENCED on single use objects
fs: compat: Remove warning from COMPATIBLE_IOCTL
remove pointless extern of atime_need_update_rcu()
fs: completely ignore unknown open flags
fs: add a VALID_OPEN_FLAGS
fs: remove _submit_bh()
fs: constify tree_descr arrays passed to simple_fill_super()
fs: drop duplicate header percpu-rwsem.h
fs/affs: bugfix: Write files greater than page size on OFS
fs/affs: bugfix: enable writes on OFS disks
fs/affs: remove node generation check
fs/affs: import amigaffs.h
fs/affs: bugfix: make symbolic links work again
Add a central define for all valid open flags, and use it in the uniqueness
check.
<linux/sched/task.h>
We are going to split <linux/sched/task.h> out of <linux/sched.h>, which
will have to be picked up from other headers and a couple of .c files.
Create a trivial placeholder <linux/sched/task.h> file that just
maps to <linux/sched.h> to make this patch obviously correct and
bisectable.
Include the new header in the files that are going to need it.
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
This was entirely automated, using the script by Al:
PATT='^[[:blank:]]*#[[:blank:]]*include[[:blank:]]*<asm/uaccess.h>'
sed -i -e "s!$PATT!#include <linux/uaccess.h>!" \
$(git grep -l "$PATT"|grep -v ^include/linux/uaccess.h)
to do the replacement at the end of the merge window.
Requested-by: Al Viro <viro@zeniv.linux.org.uk>
With packetized mode for pipes, it's not possible to set O_DIRECT on pipe file
via sys_fcntl, because of unsupported sanity checks.
Ability to set this flag will be used by CRIU to migrate packetized pipes.
v2:
Fixed typos and mode variable to check.
Signed-off-by: Stanislav Kinsburskiy <skinsbursky@virtuozzo.com>
Fix clashing values for O_PATH and FMODE_NONOTIFY on sparc. The
clashing O_PATH value was added in commit 5229645bdc35 ("vfs: add
nonconflicting values for O_PATH") but this can't be changed as it is
user-visible.
FMODE_NONOTIFY is only used internally in the kernel, but it is in the
same numbering space as the other O_* flags, as indicated by the comment
at the top of include/uapi/asm-generic/fcntl.h (and its use in
fs/notify/fanotify/fanotify_user.c). So renumber it to avoid the clash.
All of this has happened before (commit 12ed2e36c98a: "fanotify:
FMODE_NONOTIFY and __O_SYNC in sparc conflict"), and all of this will
happen again -- so update the uniqueness check in fcntl_init() to
include __FMODE_NONOTIFY.
Signed-off-by: David Drysdale <drysdale@google.com>
Acked-by: Jan Kara <jack@suse.cz>
Cc: Heinrich Schuchardt <xypron.glpk@gmx.de>
Cc: Eric Paris <eparis@redhat.com>
security_file_set_fowner always returns 0, so make it f_setown and
__f_setown void return functions and fix up the error handling in the
callers.
Cc: linux-security-module@vger.kernel.org
Signed-off-by: Jeff Layton <jlayton@primarydata.com>
If two processes share a common memory region, they usually want some
guarantees to allow safe access. This often includes:
- one side cannot overwrite data while the other reads it
- one side cannot shrink the buffer while the other accesses it
- one side cannot grow the buffer beyond previously set boundaries
If there is a trust-relationship between both parties, there is no need
for policy enforcement. However, if there's no trust relationship (eg.,
for general-purpose IPC) sharing memory-regions is highly fragile and
often not possible without local copies. Look at the following two
use-cases:
1) A graphics client wants to share its rendering-buffer with a
graphics-server. The memory-region is allocated by the client for
read/write access and a second FD is passed to the server. While
scanning out from the memory region, the server has no guarantee that
the client doesn't shrink the buffer at any time, requiring rather
cumbersome SIGBUS handling.
2) A process wants to perform an RPC on another process. To avoid huge
bandwidth consumption, zero-copy is preferred. After a message is
assembled in-memory and a FD is passed to the remote side, both sides
want to be sure that neither modifies this shared copy, anymore. The
source may have put sensible data into the message without a separate
copy and the target may want to parse the message inline, to avoid a
local copy.
While SIGBUS handling, POSIX mandatory locking and MAP_DENYWRITE provide
ways to achieve most of this, the first one is unproportionally ugly to
use in libraries and the latter two are broken/racy or even disabled due
to denial of service attacks.
This patch introduces the concept of SEALING. If you seal a file, a
specific set of operations is blocked on that file forever. Unlike locks,
seals can only be set, never removed. Hence, once you verified a specific
set of seals is set, you're guaranteed that no-one can perform the blocked
operations on this file, anymore.
An initial set of SEALS is introduced by this patch:
- SHRINK: If SEAL_SHRINK is set, the file in question cannot be reduced
in size. This affects ftruncate() and open(O_TRUNC).
- GROW: If SEAL_GROW is set, the file in question cannot be increased
in size. This affects ftruncate(), fallocate() and write().
- WRITE: If SEAL_WRITE is set, no write operations (besides resizing)
are possible. This affects fallocate(PUNCH_HOLE), mmap() and
write().
- SEAL: If SEAL_SEAL is set, no further seals can be added to a file.
This basically prevents the F_ADD_SEAL operation on a file and
can be set to prevent others from adding further seals that you
don't want.
The described use-cases can easily use these seals to provide safe use
without any trust-relationship:
1) The graphics server can verify that a passed file-descriptor has
SEAL_SHRINK set. This allows safe scanout, while the client is
allowed to increase buffer size for window-resizing on-the-fly.
Concurrent writes are explicitly allowed.
2) For general-purpose IPC, both processes can verify that SEAL_SHRINK,
SEAL_GROW and SEAL_WRITE are set. This guarantees that neither
process can modify the data while the other side parses it.
Furthermore, it guarantees that even with writable FDs passed to the
peer, it cannot increase the size to hit memory-limits of the source
process (in case the file-storage is accounted to the source).
The new API is an extension to fcntl(), adding two new commands:
F_GET_SEALS: Return a bitset describing the seals on the file. This
can be called on any FD if the underlying file supports
sealing.
F_ADD_SEALS: Change the seals of a given file. This requires WRITE
access to the file and F_SEAL_SEAL may not already be set.
Furthermore, the underlying file must support sealing and
there may not be any existing shared mapping of that file.
Otherwise, EBADF/EPERM is returned.
The given seals are _added_ to the existing set of seals
on the file. You cannot remove seals again.
The fcntl() handler is currently specific to shmem and disabled on all
files. A file needs to explicitly support sealing for this interface to
work. A separate syscall is added in a follow-up, which creates files that
support sealing. There is no intention to support this on other
file-systems. Semantics are unclear for non-volatile files and we lack any
use-case right now. Therefore, the implementation is specific to shmem.
Signed-off-by: David Herrmann <dh.herrmann@gmail.com>
Cc: Michael Kerrisk <mtk.manpages@gmail.com>
Cc: Ryan Lortie <desrt@desrt.ca>
Cc: Lennart Poettering <lennart@poettering.net>
Cc: Daniel Mack <zonque@gmail.com>
File-private locks have been merged into Linux for v3.15, and *now*
people are commenting that the name and macro definitions for the new
file-private locks suck.
...and I can't even disagree. The names and command macros do suck.
We're going to have to live with these for a long time, so it's
important that we be happy with the names before we're stuck with them.
The consensus on the lists so far is that they should be rechristened as
"open file description locks".
The name isn't a big deal for the kernel, but the command macros are not
visually distinct enough from the traditional POSIX lock macros. The
glibc and documentation folks are recommending that we change them to
look like F_OFD_{GETLK|SETLK|SETLKW}. That lessens the chance that a
programmer will typo one of the commands wrong, and also makes it easier
to spot this difference when reading code.
This patch makes the following changes that I think are necessary before
v3.15 ships:
1) rename the command macros to their new names. These end up in the uapi
headers and so are part of the external-facing API. It turns out that
glibc doesn't actually use the fcntl.h uapi header, but it's hard to
be sure that something else won't. Changing it now is safest.
2) make the the /proc/locks output display these as type "OFDLCK"
Cc: Carlos O'Donell <carlos@redhat.com>
Cc: Stefan Metzmacher <metze@samba.org>
Cc: Frank Filz <ffilzlnx@mindspring.com>
Cc: Theodore Ts'o <tytso@mit.edu>
Due to some unfortunate history, POSIX locks have very strange and
unhelpful semantics. The thing that usually catches people by surprise
is that they are dropped whenever the process closes any file descriptor
associated with the inode.
This is extremely problematic for people developing file servers that
need to implement byte-range locks. Developers often need a "lock
management" facility to ensure that file descriptors are not closed
until all of the locks associated with the inode are finished.
Additionally, "classic" POSIX locks are owned by the process. Locks
taken between threads within the same process won't conflict with one
another, which renders them useless for synchronization between threads.
This patchset adds a new type of lock that attempts to address these
issues. These locks conflict with classic POSIX read/write locks, but
have semantics that are more like BSD locks with respect to inheritance
and behavior on close.
This is implemented primarily by changing how fl_owner field is set for
these locks. Instead of having them owned by the files_struct of the
process, they are instead owned by the filp on which they were acquired.
Thus, they are inherited across fork() and are only released when the
last reference to a filp is put.
These new semantics prevent them from being merged with classic POSIX
locks, even if they are acquired by the same process. These locks will
also conflict with classic POSIX locks even if they are acquired by
the same process or on the same file descriptor.
The new locks are managed using a new set of cmd values to the fcntl()
syscall. The initial implementation of this converts these values to
"classic" cmd values at a fairly high level, and the details are not
exposed to the underlying filesystem. We may eventually want to push
this handing out to the lower filesystem code but for now I don't
see any need for it.
Also, note that with this implementation the new cmd values are only
available via fcntl64() on 32-bit arches. There's little need to
add support for legacy apps on a new interface like this.
Once we introduce file private locks, we'll need to know what cmd value
was used, as that affects the ownership and whether a conflict would
arise.
As comment in include/uapi/asm-generic/fcntl.h described, when
introducing new O_* bits, we need to check its uniqueness in
fcntl_init(). But __O_TMPFILE bit is missing. So fix it.
Signed-off-by: Zheng Liu <wenqing.lz@taobao.com>
Fix a braino in F_DUPFD_CLOEXEC; f_dupfd() expects flags for alloc_fd(),
get_unused_fd() etc and there clone-on-exec if O_CLOEXEC, not
FD_CLOEXEC.
Reported-by: Richard W.M. Jones <rjones@redhat.com>
__user * != * __user...
... except for one in android, where the check is different
and already done in caller. No need to recalculate rlimit
many times in alloc_fd() either.
When we restore file descriptors we would like them to look exactly as
they were at dumping time.
With help of fcntl it's almost possible, the missing snippet is file
owners UIDs.
To be able to read their values the F_GETOWNER_UIDS is introduced.
This option is valid iif CONFIG_CHECKPOINT_RESTORE is turned on, otherwise
returning -EINVAL.
Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org>
Acked-by: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: "Serge E. Hallyn" <serge@hallyn.com>
Cc: Pavel Emelyanov <xemul@parallels.com>
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
Wrap accesses to the fd_sets in struct fdtable (for recording open files and
close-on-exec flags) so that we can move away from using fd_sets since we
abuse the fd_set structs by not allocating the full-sized structure under
normal circumstances and by non-core code looking at the internals of the
fd_sets.
The first abuse means that use of FD_ZERO() on these fd_sets is not permitted,
since that cannot be told about their abnormal lengths.
This introduces six wrapper functions for setting, clearing and testing
close-on-exec flags and fd-is-open flags:
void __set_close_on_exec(int fd, struct fdtable *fdt);
void __clear_close_on_exec(int fd, struct fdtable *fdt);
bool close_on_exec(int fd, const struct fdtable *fdt);
void __set_open_fd(int fd, struct fdtable *fdt);
void __clear_open_fd(int fd, struct fdtable *fdt);
bool fd_is_open(int fd, const struct fdtable *fdt);
Note that I've prepended '__' to the names of the set/clear functions because
they require the caller to hold a lock to use them.
Note also that I haven't added wrappers for looking behind the scenes at the
the array. Possibly that should exist too.
Link: http://lkml.kernel.org/r/20120216174942.23314.1364.stgit@warthog.procyon.org.uk
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
And give it a kernel-doc comment.
[akpm@linux-foundation.org: btrfs changed in linux-next]
Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Daniel Lezcano <daniel.lezcano@free.fr>
New flag for open(2) - O_PATH. Semantics:
* pathname is resolved, but the file itself is _NOT_ opened
as far as filesystem is concerned.
* almost all operations on the resulting descriptors shall
fail with -EBADF. Exceptions are:
1) operations on descriptors themselves (i.e.
close(), dup(), dup2(), dup3(), fcntl(fd, F_DUPFD),
fcntl(fd, F_DUPFD_CLOEXEC, ...), fcntl(fd, F_GETFD),
fcntl(fd, F_SETFD, ...))
2) fcntl(fd, F_GETFL), for a common non-destructive way to
check if descriptor is open
3) "dfd" arguments of ...at(2) syscalls, i.e. the starting
points of pathname resolution
* closing such descriptor does *NOT* affect dnotify or
posix locks.
* permissions are checked as usual along the way to file;
no permission checks are applied to the file itself. Of course,
giving such thing to syscall will result in permission checks (at
the moment it means checking that starting point of ....at() is
a directory and caller has exec permissions on it).
fget() and fget_light() return NULL on such descriptors; use of
fget_raw() and fget_raw_light() is needed to get them. That protects
existing code from dealing with those things.
There are two things still missing (they come in the next commits):
one is handling of symlinks (right now we refuse to open them that
way; see the next commit for semantics related to those) and another
is descriptor passing via SCM_RIGHTS datagrams.
FMODE_EXEC is a constant type of fmode_t but was used with normal integer
constants. This results in following warnings from sparse. Fix it using
new macro __FMODE_EXEC.
fs/exec.c:116:58: warning: restricted fmode_t degrades to integer
fs/exec.c:689:58: warning: restricted fmode_t degrades to integer
fs/fcntl.c:777:9: warning: restricted fmode_t degrades to integer
Signed-off-by: Namhyung Kim <namhyung@gmail.com>
In commit f7347ce4ee7c ("fasync: re-organize fasync entry insertion to
allow it under a spinlock") Arnd took an earlier patch of mine that had
the comment about the FASYNC flag above the wrong function.
When the fasync_add_entry() function was split to introduce the new
fasync_insert_entry() helper function, the code that actually cares
about the FASYNC bit moved to that new helper.
So just move the comment to the right point.
You currently cannot use "fasync_helper()" in an atomic environment to
insert a new fasync entry, because it will need to allocate the new
"struct fasync_struct".
Yet fcntl_setlease() wants to call this under lock_flocks(), which is in
the process of being converted from the BKL to a spinlock.
In order to fix this, this abstracts out the actual fasync list
insertion and the fasync allocations into functions of their own, and
teaches fs/locks.c to pre-allocate the fasync_struct entry. That way
the actual list insertion can happen while holding the required
spinlock.
[bfields@redhat.com: rebase on top of my changes to Arnd's patch]
Tested-by: J. Bruce Fields <bfields@redhat.com>
O_NONBLOCK on parisc has a dual value:
#define O_NONBLOCK 000200004 /* HPUX has separate NDELAY & NONBLOCK */
It is caught by the O_* bits uniqueness check and leads to a parisc
compile error. The fix would be to take O_NONBLOCK out.
Signed-off-by: Wu Fengguang <fengguang.wu@intel.com>
Signed-off-by: James Bottomley <James.Bottomley@suse.de>
Cc: Jamie Lokier <jamie@shareable.org>
The O_* bit numbers are defined in 20+ arch/*, and can silently overlap.
Add a compile time check to ensure the uniqueness as suggested by David
Miller.
Cc: Roland Dreier <rdreier@cisco.com>
Cc: Andreas Schwab <schwab@linux-m68k.org>
Fix a lockdep-splat-causing regression introduced by commit 989a2979205d
("fasync: RCU and fine grained locking").
kill_fasync() can be called from both process and hard-irq context, so
fa_lock must be taken with IRQs disabled.
Addresses https://bugzilla.kernel.org/show_bug.cgi?id=16230
Reported-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Reported-by: Dominik Brodowski <linux@dominikbrodowski.net>
Tested-by: Dominik Brodowski <linux@dominikbrodowski.net>
Cc: Maciej Rutecki <maciej.rutecki@gmail.com>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Cc: Lai Jiangshan <laijs@cn.fujitsu.com>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
copy_to_user() returns the number of bytes remaining, but we want to
return -EFAULT.
ret = fcntl(fd, F_SETOWN_EX, NULL);
With the original code ret would be 8 here.
V2: Takuya Yoshikawa pointed out a similar issue in f_getown_ex()
fs/ext3/fsync.c
