path: root/fs/fcntl.c
2005-05-01[PATCH] convert that currently tests _NSIG directly to use valid_signal()Jesper Juhl
Convert most of the current code that uses _NSIG directly to instead use valid_signal(). This avoids gcc -W warnings and off-by-one errors. Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-16[PATCH] AYSNC IO using singals other than SIGIOBharath Ramesh
A question on sigwaitinfo based IO mechanism in multithreaded applications. I am trying to use RT signals to notify me of IO events using RT signals instead of SIGIO in a multithreaded applications. I noticed that there was some discussion on lkml during november 1999 with the subject of the discussion as "Signal driven IO". In the thread I noticed that RT signals were being delivered to the worker thread. I am running 2.6.10 kernel and I am trying to use the very same mechanism and I find that only SIGIO being propogated to the worker threads and RT signals only being propogated to the main thread and not the worker threads where I actually want them to be propogated too. On further inspection I found that the following patch which I have attached solves the problem. I am not sure if this is a bug or feature in the kernel. Roland McGrath <roland@redhat.com> said: This relates only to fcntl F_SETSIG, which is a Linux extension. So there is no POSIX issue. When changing various things like the normal SIGIO signalling to do group signals, I was concerned strictly with the POSIX semantics and generally avoided touching things in the domain of Linux inventions. That's why I didn't change this when I changed the call right next to it. There is no reason I can see that F_SETSIG-requested signals shouldn't use a group signal like normal SIGIO does. I'm happy to ACK this patch, there is nothing wrong with its change to the semantics in my book. But neither POSIX nor I care a whit what F_SETSIG does. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
