path: root/fs/filesystems.c
2011-04-17fs: synchronize_rcu when unregister_filesystem success not failureMilton Miller
While checking unregister_filesystem for saftey vs extra calls for "ext4: register ext2 and ext3 alias after ext4" I realized that the synchronize_rcu() was called on the error path but not on the success path. Cc: stable (2.6.38) Signed-off-by: Milton Miller <miltonm@bga.com> [ This probably won't really make a difference since commit d863b50ab013 ("vfs: call rcu_barrier after ->kill_sb()"), but it's the right thing to do. - Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-07fs: rcu-walk for path lookupNick Piggin
Perform common cases of path lookups without any stores or locking in the ancestor dentry elements. This is called rcu-walk, as opposed to the current algorithm which is a refcount based walk, or ref-walk. This results in far fewer atomic operations on every path element, significantly improving path lookup performance. It also avoids cacheline bouncing on common dentries, significantly improving scalability. The overall design is like this: * LOOKUP_RCU is set in nd->flags, which distinguishes rcu-walk from ref-walk. * Take the RCU lock for the entire path walk, starting with the acquiring of the starting path (eg. root/cwd/fd-path). So now dentry refcounts are not required for dentry persistence. * synchronize_rcu is called when unregistering a filesystem, so we can access d_ops and i_ops during rcu-walk. * Similarly take the vfsmount lock for the entire path walk. So now mnt refcounts are not required for persistence. Also we are free to perform mount lookups, and to assume dentry mount points and mount roots are stable up and down the path. * Have a per-dentry seqlock to protect the dentry name, parent, and inode, so we can load this tuple atomically, and also check whether any of its members have changed. * Dentry lookups (based on parent, candidate string tuple) recheck the parent sequence after the child is found in case anything changed in the parent during the path walk. * inode is also RCU protected so we can load d_inode and use the inode for limited things. * i_mode, i_uid, i_gid can be tested for exec permissions during path walk. * i_op can be loaded. When we reach the destination dentry, we lock it, recheck lookup sequence, and increment its refcount and mountpoint refcount. RCU and vfsmount locks are dropped. This is termed "dropping rcu-walk". If the dentry refcount does not match, we can not drop rcu-walk gracefully at the current point in the lokup, so instead return -ECHILD (for want of a better errno). This signals the path walking code to re-do the entire lookup with a ref-walk. Aside from the final dentry, there are other situations that may be encounted where we cannot continue rcu-walk. In that case, we drop rcu-walk (ie. take a reference on the last good dentry) and continue with a ref-walk. Again, if we can drop rcu-walk gracefully, we return -ECHILD and do the whole lookup using ref-walk. But it is very important that we can continue with ref-walk for most cases, particularly to avoid the overhead of double lookups, and to gain the scalability advantages on common path elements (like cwd and root). The cases where rcu-walk cannot continue are: * NULL dentry (ie. any uncached path element) * parent with d_inode->i_op->permission or ACLs * dentries with d_revalidate * Following links In future patches, permission checks and d_revalidate become rcu-walk aware. It may be possible eventually to make following links rcu-walk aware. Uncached path elements will always require dropping to ref-walk mode, at the very least because i_mutex needs to be grabbed, and objects allocated. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-04-20fs: Mark get_filesystem_list() as __init function.Tetsuo Handa
"int get_filesystem_list(char * buf)" is called by only "static void __init get_fs_names(char *page)". We can mark get_filesystem_list() as "__init". Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-01-14[CVE-2009-0029] System call wrappers part 27Heiko Carstens
2009-01-05vfs: remove duplicate code in get_fs_type()Li Zefan
save 14 bytes: text data bss dec hex filename 1354 32 4 1390 56e fs/filesystems.o.before text data bss dec hex filename 1340 32 4 1376 560 fs/filesystems.o Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-10-23proc: move /proc/filesystems to fs/filesystems.cAlexey Dobriyan
2007-05-08add filesystem subtype supportMiklos Szeredi
There's a slight problem with filesystem type representation in fuse based filesystems. From the kernel's view, there are just two filesystem types: fuse and fuseblk. From the user's view there are lots of different filesystem types. The user is not even much concerned if the filesystem is fuse based or not. So there's a conflict of interest in how this should be represented in fstab, mtab and /proc/mounts. The current scheme is to encode the real filesystem type in the mount source. So an sshfs mount looks like this: sshfs#user@server:/ /mnt/server fuse rw,nosuid,nodev,... This url-ish syntax works OK for sshfs and similar filesystems. However for block device based filesystems (ntfs-3g, zfs) it doesn't work, since the kernel expects the mount source to be a real device name. A possibly better scheme would be to encode the real type in the type field as "type.subtype". So fuse mounts would look like this: /dev/hda1 /mnt/windows fuseblk.ntfs-3g rw,... user@server:/ /mnt/server fuse.sshfs rw,nosuid,nodev,... This patch adds the necessary code to the kernel so that this can be correctly displayed in /proc/mounts. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-09-29[PATCH] Ban register_filesystem(NULL);Alexey Dobriyan
Everyone passes valid pointer there. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] fix missing includesTim Schmielau
I recently picked up my older work to remove unnecessary #includes of sched.h, starting from a patch by Dave Jones to not include sched.h from module.h. This reduces the number of indirect includes of sched.h by ~300. Another ~400 pointless direct includes can be removed after this disentangling (patch to follow later). However, quite a few indirect includes need to be fixed up for this. In order to feed the patches through -mm with as little disturbance as possible, I've split out the fixes I accumulated up to now (complete for i386 and x86_64, more archs to follow later) and post them before the real patch. This way this large part of the patch is kept simple with only adding #includes, and all hunks are independent of each other. So if any hunk rejects or gets in the way of other patches, just drop it. My scripts will pick it up again in the next round. Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
