path: root/fs/freevxfs
2012-03-20switch open-coded instances of d_make_root() to new helperAl Viro
2012-01-03fs: propagate umode_t, misc bitsAl Viro
2012-01-03vfs: fix the stupidity with i_dentry in inode destructorsAl Viro
Seeing that just about every destructor got that INIT_LIST_HEAD() copied into it, there is no point whatsoever keeping this INIT_LIST_HEAD in inode_init_once(); the cost of taking it into inode_init_always() will be negligible for pipes and sockets and negative for everything else. Not to mention the removal of boilerplate code from ->destroy_inode() instances... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-11-02filesystems: add set_nlink()Miklos Szeredi
Replace remaining direct i_nlink updates with a new set_nlink() updater function. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Tested-by: Toshiyuki Okajima <toshi.okajima@jp.fujitsu.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2011-05-10treewide: fix a few typos in commentsJustin P. Mattock
- kenrel -> kernel - whetehr -> whether - ttt -> tt - sss -> ss Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-03-10block: remove per-queue pluggingJens Axboe
Code has been converted over to the new explicit on-stack plugging, and delay users have been converted to use the new API for that. So lets kill off the old plugging along with aops->sync_page(). Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-01-07fs: icache RCU free inodesNick Piggin
RCU free the struct inode. This will allow: - Subsequent store-free path walking patch. The inode must be consulted for permissions when walking, so an RCU inode reference is a must. - sb_inode_list_lock to be moved inside i_lock because sb list walkers who want to take i_lock no longer need to take sb_inode_list_lock to walk the list in the first place. This will simplify and optimize locking. - Could remove some nested trylock loops in dcache code - Could potentially simplify things a bit in VM land. Do not need to take the page lock to follow page->mapping. The downsides of this is the performance cost of using RCU. In a simple creat/unlink microbenchmark, performance drops by about 10% due to inability to reuse cache-hot slab objects. As iterations increase and RCU freeing starts kicking over, this increases to about 20%. In cases where inode lifetimes are longer (ie. many inodes may be allocated during the average life span of a single inode), a lot of this cache reuse is not applicable, so the regression caused by this patch is smaller. The cache-hot regression could largely be avoided by using SLAB_DESTROY_BY_RCU, however this adds some complexity to list walking and store-free path walking, so I prefer to implement this at a later date, if it is shown to be a win in real situations. I haven't found a regression in any non-micro benchmark so I doubt it will be a problem. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2010-10-29new helper: mount_bdev()Al Viro
... and switch of the obvious get_sb_bdev() users to ->mount() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-25fs: do not assign default i_ino in new_inodeChristoph Hellwig
Instead of always assigning an increasing inode number in new_inode move the call to assign it into those callers that actually need it. For now callers that need it is estimated conservatively, that is the call is added to all filesystems that do not assign an i_ino by themselves. For a few more filesystems we can avoid assigning any inode number given that they aren't user visible, and for others it could be done lazily when an inode number is actually needed, but that's left for later patches. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-21BKL: remove BKL from freevxfsArnd Bergmann
All uses of the BKL in freevxfs were the result of a pushdown into code that doesn't really need it. As Christoph points out, this is a read-only file system, which eliminates most of the races in readdir/lookup. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Christoph Hellwig <hch@infradead.org>
2010-10-04BKL: Explicitly add BKL around get_sb/fill_superJan Blunck
This patch is a preparation necessary to remove the BKL from do_new_mount(). It explicitly adds calls to lock_kernel()/unlock_kernel() around get_sb/fill_super operations for filesystems that still uses the BKL. I've read through all the code formerly covered by the BKL inside do_kern_mount() and have satisfied myself that it doesn't need the BKL any more. do_kern_mount() is already called without the BKL when mounting the rootfs and in nfsctl. do_kern_mount() calls vfs_kern_mount(), which is called from various places without BKL: simple_pin_fs(), nfs_do_clone_mount() through nfs_follow_mountpoint(), afs_mntpt_do_automount() through afs_mntpt_follow_link(). Both later functions are actually the filesystems follow_link inode operation. vfs_kern_mount() is calling the specified get_sb function and lets the filesystem do its job by calling the given fill_super function. Therefore I think it is safe to push down the BKL from the VFS to the low-level filesystems get_sb/fill_super operation. [arnd: do not add the BKL to those file systems that already don't use it elsewhere] Signed-off-by: Jan Blunck <jblunck@infradead.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Christoph Hellwig <hch@infradead.org>
2010-08-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (96 commits) no need for list_for_each_entry_safe()/resetting with superblock list Fix sget() race with failing mount vfs: don't hold s_umount over close_bdev_exclusive() call sysv: do not mark superblock dirty on remount sysv: do not mark superblock dirty on mount btrfs: remove junk sb_dirt change BFS: clean up the superblock usage AFFS: wait for sb synchronization when needed AFFS: clean up dirty flag usage cifs: truncate fallout mbcache: fix shrinker function return value mbcache: Remove unused features add f_flags to struct statfs(64) pass a struct path to vfs_statfs update VFS documentation for method changes. All filesystems that need invalidate_inode_buffers() are doing that explicitly convert remaining ->clear_inode() to ->evict_inode() Make ->drop_inode() just return whether inode needs to be dropped fs/inode.c:clear_inode() is gone fs/inode.c:evict() doesn't care about delete vs. non-delete paths now ... Fix up trivial conflicts in fs/nilfs2/super.c
2010-08-09convert remaining ->clear_inode() to ->evict_inode()Al Viro
2010-06-16Merge branch 'master' into for-nextJiri Kosina
2010-06-16fix typos concerning "initiali[zs]e"Uwe Kleine-König
Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-05-27fs/: do not fallback to default_llseek() when readdir() uses BKLjan Blunck
Do not use the fallback default_llseek() if the readdir operation of the filesystem still uses the big kernel lock. Since llseek() modifies file->f_pos of the directory directly it may need locking to not confuse readdir which usually uses file->f_pos directly as well Since the special characteristics of the BKL (unlocked on schedule) are not necessary in this case, the inode mutex can be used for locking as provided by generic_file_llseek(). This is only possible since all filesystems, except reiserfs, either use a directory as a flat file or with disk address offsets. Reiserfs on the other hand uses a 32bit hash off the filename as the offset so generic_file_llseek() can get used as well since the hash is always smaller than sb->s_maxbytes (= (512 << 32) - blocksize). Signed-off-by: Jan Blunck <jblunck@suse.de> Acked-by: Jan Kara <jack@suse.cz> Acked-by: Anders Larsen <al@alarsen.net> Cc: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-07-12headers: smp_lock.h reduxAlexey Dobriyan
* Remove smp_lock.h from files which don't need it (including some headers!) * Add smp_lock.h to files which do need it * Make smp_lock.h include conditional in hardirq.h It's needed only for one kernel_locked() usage which is under CONFIG_PREEMPT This will make hardirq.h inclusion cheaper for every PREEMPT=n config (which includes allmodconfig/allyesconfig, BTW) Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-11push BKL down into ->put_superChristoph Hellwig
Move BKL into ->put_super from the only caller. A couple of filesystems had trivial enough ->put_super (only kfree and NULLing of s_fs_info + stuff in there) to not get any locking: coda, cramfs, efs, hugetlbfs, omfs, qnx4, shmem, all others got the full treatment. Most of them probably don't need it, but I'd rather sort that out individually. Preferably after all the other BKL pushdowns in that area. [AV: original used to move lock_super() down as well; these changes are removed since we don't do lock_super() at all in generic_shutdown_super() now] [AV: fuse, btrfs and xfs are known to need no damn BKL, exempt] Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-01-22fs/Kconfig: move vxfs outAlexey Dobriyan
2008-12-31freevxfs: ensure fast symlinks are NUL-terminatedDuane Griffin
Ensure fast symlink targets are NUL-terminated, even if corrupted on-disk. Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Duane Griffin <duaneg@dghda.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-04-29fs/freevxfs/: proper externsAdrian Bunk
Move the extern declarations of several structs to vxfs_extern.h Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07iget: stop FreeVXFS from using iget() and read_inode()David Howells
Stop the FreeVXFS filesystem from using iget() and read_inode(). Replace vxfs_read_inode() with vxfs_iget(), and call that instead of iget(). vxfs_iget() then uses iget_locked() directly and returns a proper error code instead of an inode in the event of an error. vxfs_fill_super() returns any error incurred when getting the root inode instead of EINVAL. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-03fs/: Spelling fixesJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-07-16vxfs warning fixesAndrew Morton
gcc-4.3: fs/freevxfs/vxfs_lookup.c: In function 'vxfs_find_entry': fs/freevxfs/vxfs_lookup.c:139: warning: cast from pointer to integer of different size fs/freevxfs/vxfs_lookup.c: In function 'vxfs_readdir': fs/freevxfs/vxfs_lookup.c:294: warning: cast from pointer to integer of different size Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08freevxfs: possible null pointer dereference fixDmitriy Monakhov
sb_read may return NULL, so let's explicitly check it. Signed-off-by: Dmitriy Monakhov <dmonakhov@openvz.org> Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07mm: make read_cache_page synchronousNick Piggin
Ensure pages are uptodate after returning from read_cache_page, which allows us to cut out most of the filesystem-internal PageUptodate calls. I didn't have a great look down the call chains, but this appears to fixes 7 possible use-before uptodate in hfs, 2 in hfsplus, 1 in jfs, a few in ecryptfs, 1 in jffs2, and a possible cleared data overwritten with readpage in block2mtd. All depending on whether the filler is async and/or can return with a !uptodate page. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-08[PATCH] struct path: convert freevxfsJosef Sipek
2006-09-29[PATCH] freevxfs: fix leak on error pathAlexey Dobriyan
If register_filesystem() fails, vxfs_inode cache must be destroyed. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] inode_diet: Replace inode.u.generic_ip with inode.i_privateTheodore Ts'o
The following patches reduce the size of the VFS inode structure by 28 bytes on a UP x86. (It would be more on an x86_64 system). This is a 10% reduction in the inode size on a UP kernel that is configured in a production mode (i.e., with no spinlock or other debugging functions enabled; if you want to save memory taken up by in-core inodes, the first thing you should do is disable the debugging options; they are responsible for a huge amount of bloat in the VFS inode structure). This patch: The filesystem or device-specific pointer in the inode is inside a union, which is pretty pointless given that all 30+ users of this field have been using the void pointer. Get rid of the union and rename it to i_private, with a comment to explain who is allowed to use the void pointer. This is just a cleanup, but it allows us to reuse the union 'u' for something something where the union will actually be used. [judith@osdl.org: powerpc build fix] Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Judith Lebzelter <judith@osdl.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-31[PATCH] freevxfs: Add missing lock_kernel() to vxfs_readdirJosh Triplett
Commit 7b2fd697427e73c81d5fa659efd91bd07d303b0e in the historical GIT tree stopped calling the readdir member of a file_operations struct with the big kernel lock held, and fixed up all the readdir functions to do their own locking. However, that change added calls to unlock_kernel() in vxfs_readdir, but no call to lock_kernel(). Fix this by adding a call to lock_kernel(). Signed-off-by: Josh Triplett <josh@freedesktop.org> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-28[PATCH] mark address_space_operations constChristoph Hellwig
Same as with already do with the file operations: keep them in .rodata and prevents people from doing runtime patching. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Steven French <sfrench@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] fs/freevxfs: cleanup of spelling errorsCliff Wickman
Fix of some spelling errors in fs/freevxfs error messages and comments Signed-off-by: Cliff Wickman <cpw@sgi.com> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] read_mapping_page for address spacePekka Enberg
Add read_mapping_page() which is used for callers that pass mapping->a_ops->readpage as the filler for read_cache_page. This removes some duplication from filesystem code. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] VFS: Permit filesystem to perform statfs with a known root dentryDavid Howells
Give the statfs superblock operation a dentry pointer rather than a superblock pointer. This complements the get_sb() patch. That reduced the significance of sb->s_root, allowing NFS to place a fake root there. However, NFS does require a dentry to use as a target for the statfs operation. This permits the root in the vfsmount to be used instead. linux/mount.h has been added where necessary to make allyesconfig build successfully. Interest has also been expressed for use with the FUSE and XFS filesystems. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Nathan Scott <nathans@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] VFS: Permit filesystem to override root dentry on mountDavid Howells
Extend the get_sb() filesystem operation to take an extra argument that permits the VFS to pass in the target vfsmount that defines the mountpoint. The filesystem is then required to manually set the superblock and root dentry pointers. For most filesystems, this should be done with simple_set_mnt() which will set the superblock pointer and then set the root dentry to the superblock's s_root (as per the old default behaviour). The get_sb() op now returns an integer as there's now no need to return the superblock pointer. This patch permits a superblock to be implicitly shared amongst several mount points, such as can be done with NFS to avoid potential inode aliasing. In such a case, simple_set_mnt() would not be called, and instead the mnt_root and mnt_sb would be set directly. The patch also makes the following changes: (*) the get_sb_*() convenience functions in the core kernel now take a vfsmount pointer argument and return an integer, so most filesystems have to change very little. (*) If one of the convenience function is not used, then get_sb() should normally call simple_set_mnt() to instantiate the vfsmount. This will always return 0, and so can be tail-called from get_sb(). (*) generic_shutdown_super() now calls shrink_dcache_sb() to clean up the dcache upon superblock destruction rather than shrink_dcache_anon(). This is required because the superblock may now have multiple trees that aren't actually bound to s_root, but that still need to be cleaned up. The currently called functions assume that the whole tree is rooted at s_root, and that anonymous dentries are not the roots of trees which results in dentries being left unculled. However, with the way NFS superblock sharing are currently set to be implemented, these assumptions are violated: the root of the filesystem is simply a dummy dentry and inode (the real inode for '/' may well be inaccessible), and all the vfsmounts are rooted on anonymous[*] dentries with child trees. [*] Anonymous until discovered from another tree. (*) The documentation has been adjusted, including the additional bit of changing ext2_* into foo_* in the documentation. [akpm@osdl.org: convert ipath_fs, do other stuff] Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Nathan Scott <nathans@sgi.com> Cc: Roland Dreier <rolandd@cisco.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-02BUG_ON() Conversion in fs/freevxfs/Eric Sesterhenn
this changes if() BUG(); constructs to BUG_ON() which is cleaner, contains unlikely() and can better optimized away. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-03-28[PATCH] Make most file operations structs in fs/ constArjan van de Ven
This is a conversion to make the various file_operations structs in fs/ const. Basically a regexp job, with a few manual fixups The goal is both to increase correctness (harder to accidentally write to shared datastructures) and reducing the false sharing of cachelines with things that get dirty in .data (while .rodata is nicely read only and thus cache clean) Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] cpuset memory spread: slab cache filesystemsPaul Jackson
Mark file system inode and similar slab caches subject to SLAB_MEM_SPREAD memory spreading. If a slab cache is marked SLAB_MEM_SPREAD, then anytime that a task that's in a cpuset with the 'memory_spread_slab' option enabled goes to allocate from such a slab cache, the allocations are spread evenly over all the memory nodes (task->mems_allowed) allowed to that task, instead of favoring allocation on the node local to the current cpu. The following inode and similar caches are marked SLAB_MEM_SPREAD: file cache ==== ===== fs/adfs/super.c adfs_inode_cache fs/affs/super.c affs_inode_cache fs/befs/linuxvfs.c befs_inode_cache fs/bfs/inode.c bfs_inode_cache fs/block_dev.c bdev_cache fs/cifs/cifsfs.c cifs_inode_cache fs/coda/inode.c coda_inode_cache fs/dquot.c dquot fs/efs/super.c efs_inode_cache fs/ext2/super.c ext2_inode_cache fs/ext2/xattr.c (fs/mbcache.c) ext2_xattr fs/ext3/super.c ext3_inode_cache fs/ext3/xattr.c (fs/mbcache.c) ext3_xattr fs/fat/cache.c fat_cache fs/fat/inode.c fat_inode_cache fs/freevxfs/vxfs_super.c vxfs_inode fs/hpfs/super.c hpfs_inode_cache fs/isofs/inode.c isofs_inode_cache fs/jffs/inode-v23.c jffs_fm fs/jffs2/super.c jffs2_i fs/jfs/super.c jfs_ip fs/minix/inode.c minix_inode_cache fs/ncpfs/inode.c ncp_inode_cache fs/nfs/direct.c nfs_direct_cache fs/nfs/inode.c nfs_inode_cache fs/ntfs/super.c ntfs_big_inode_cache_name fs/ntfs/super.c ntfs_inode_cache fs/ocfs2/dlm/dlmfs.c dlmfs_inode_cache fs/ocfs2/super.c ocfs2_inode_cache fs/proc/inode.c proc_inode_cache fs/qnx4/inode.c qnx4_inode_cache fs/reiserfs/super.c reiser_inode_cache fs/romfs/inode.c romfs_inode_cache fs/smbfs/inode.c smb_inode_cache fs/sysv/inode.c sysv_inode_cache fs/udf/super.c udf_inode_cache fs/ufs/super.c ufs_inode_cache net/socket.c sock_inode_cache net/sunrpc/rpc_pipe.c rpc_inode_cache The choice of which slab caches to so mark was quite simple. I marked those already marked SLAB_RECLAIM_ACCOUNT, except for fs/xfs, dentry_cache, inode_cache, and buffer_head, which were marked in a previous patch. Even though SLAB_RECLAIM_ACCOUNT is for a different purpose, it marks the same potentially large file system i/o related slab caches as we need for memory spreading. Given that the rule now becomes "wherever you would have used a SLAB_RECLAIM_ACCOUNT slab cache flag before (usually the inode cache), use the SLAB_MEM_SPREAD flag too", this should be easy enough to maintain. Future file system writers will just copy one of the existing file system slab cache setups and tend to get it right without thinking. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] fix possible PAGE_CACHE_SHIFT overflowsAndrew Morton
We've had two instances recently of overflows when doing 64_bit_value = (32_bit_value << PAGE_CACHE_SHIFT) I did a tree-wide grep of `<<.*PAGE_CACHE_SHIFT' and this is the result. - afs_rxfs_fetch_descriptor.offset is of type off_t, which seems broken. - jfs and jffs are limited to 4GB anyway. - reiserfs map_block_for_writepage() takes an unsigned long for the block - it should take sector_t. (It'll fail for huge filesystems with blocksize<PAGE_CACHE_SIZE) - cramfs_read() needs to use sector_t (I think cramsfs is busted on large filesystems anyway) - affs is limited in file size anyway. - I generally didn't fix 32-bit overflows in directory operations. - arm's __flush_dcache_page() is peculiar. What if the page lies beyond 4G? - gss_wrap_req_priv() needs checking (snd_buf->page_base) Cc: Oleg Drokin <green@linuxhacker.ru> Cc: David Howells <dhowells@redhat.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: <reiserfs-dev@namesys.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Anton Altaparmakov <aia21@cantab.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: <linux-fsdevel@vger.kernel.org> Cc: Miklos Szeredi <miklos@szeredi.hu> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-08fs/freevxfs/: add #include'sAdrian Bunk
Every file should #include the headers containing the prototypes for it's global functions. Signed-off-by: Adrian Bunk <bunk@stusta.de>
2005-11-07[PATCH] vxfs: use generic_ro_fopsChristoph Hellwig
No need to duplicate a generic readonly file ops table in befs. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] mm: rename kmem_cache_s to kmem_cachePekka J Enberg
This patch renames struct kmem_cache_s to kmem_cache so we can start using it instead of kmem_cache_t typedef. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
