path: root/fs/fs-writeback.c
2012-02-02Merge branch 'android-3.0' into imx_3.0.15_androidXinyu Chen
Conflicts: drivers/misc/Kconfig drivers/misc/Makefile drivers/net/wireless/Makefile kernel/power/main.c sound/soc/soc-core.c
2012-01-09fix build errorJason Liu
Signed-off-by: Jason Liu <jason.hui@linaro.org>
2012-01-09ENGR00162198 [MX6q_ARM2]filesystem: Kernel dump if unplug SD card during bonnieTony Lin
add pointer check before accesssing to fix following problem staErXtT 3'-efms. .(.mmcblk1p2): error: remounting filesystem read-only Unable to handle kernel NULL pointer dereference at virtual address 00000010 pgd = df334000 [00000010] *pgd=71e85831, *pte=00000000, *ppte=00000000 Internal error: Oops: 17 [#1] PREEMPT SMP last sysfs file: /sys/devices/platform/sdhci-esdhc-imx.2/mmc_host/mmc1/ mmc1:b368/serial Modules linked in: ahci_platform ov3640_camera libahci libata CPU: 1 Not tainted (2.6.38-daily-00808-g43b3e87 #1) PC is at __mark_inode_dirty+0xc8/0x1b4 LR is at __mark_inode_dirty+0xb8/0x1b4 pc : [<800f7418>] lr : [<800f7408>] psr: 20000013 sp : df14dde0 ip : 00000062 fp : 00000000 r10: 003d2000 r9 : df14df38 r8 : 00000000 r7 : 4ec22acb r6 : 00000003 r5 : 00000000 r4 : e028c720 r3 : 00000001 r2 : 00000065 r1 : 804fe50c r0 : 00000001 Signed-off-by Tony Lin <tony.lin@freescale.com>
2011-10-27Merge commit 'v3.0.8' into android-3.0Colin Cross
2011-10-03writeback: update dirtied_when for synced inode to prevent livelockWu Fengguang
commit 94c3dcbb0b0cdfd82cedd21705424d8044edc42c upstream. Explicitly update .dirtied_when on synced inodes, so that they are no longer considered for writeback in the next round. It can prevent both of the following livelock schemes: - while true; do echo data >> f; done - while true; do touch f; done (in theory) The exact livelock condition is, during sync(1): (1) no new inodes are dirtied (2) an inode being actively dirtied On (2), the inode will be tagged and synced with .nr_to_write=LONG_MAX. When finished, it will be redirty_tail()ed because it's still dirty and (.nr_to_write > 0). redirty_tail() won't update its ->dirtied_when on condition (1). The sync work will then revisit it on the next queue_io() and find it eligible again because its old ->dirtied_when predates the sync work start time. We'll do more aggressive "keep writeback as long as we wrote something" logic in wb_writeback(). The "use LONG_MAX .nr_to_write" trick in commit b9543dac5bbc ("writeback: avoid livelocking WB_SYNC_ALL writeback") will no longer be enough to stop sync livelock. Reviewed-by: Jan Kara <jack@suse.cz> Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-03writeback: introduce .tagged_writepages for the WB_SYNC_NONE sync stageWu Fengguang
commit 6e6938b6d3130305a5960c86b1a9b21e58cf6144 upstream. sync(2) is performed in two stages: the WB_SYNC_NONE sync and the WB_SYNC_ALL sync. Identify the first stage with .tagged_writepages and do livelock prevention for it, too. Jan's commit f446daaea9 ("mm: implement writeback livelock avoidance using page tagging") is a partial fix in that it only fixed the WB_SYNC_ALL phase livelock. Although ext4 is tested to no longer livelock with commit f446daaea9, it may due to some "redirty_tail() after pages_skipped" effect which is by no means a guarantee for _all_ the file systems. Note that writeback_inodes_sb() is called by not only sync(), they are treated the same because the other callers also need livelock prevention. Impact: It changes the order in which pages/inodes are synced to disk. Now in the WB_SYNC_NONE stage, it won't proceed to write the next inode until finished with the current inode. Acked-by: Jan Kara <jack@suse.cz> CC: Dave Chinner <david@fromorbit.com> Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-06-14fs: block_dump: Don't display inode changes if block_dump < 2San Mehat
Signed-off-by: San Mehat <san@android.com>
2011-05-27fs: pass exact type of data dirties to ->dirty_inodeChristoph Hellwig
Tell the filesystem if we just updated timestamp (I_DIRTY_SYNC) or anything else, so that the filesystem can track internally if it needs to push out a transaction for fdatasync or not. This is just the prototype change with no user for it yet. I plan to push large XFS changes for the next merge window, and getting this trivial infrastructure in this window would help a lot to avoid tree interdependencies. Also remove incorrect comments that ->dirty_inode can't block. That has been changed a long time ago, and many implementations rely on it. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-24fs: pull inode->i_lock up out of writeback_single_inodeDave Chinner
First thing we do in writeback_single_inode() is take the i_lock and the last thing we do is drop it. A caller already holds the i_lock, so pull the i_lock out of writeback_single_inode() to reduce the round trips on this lock during inode writeback. Signed-off-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-24fs: move i_wb_list out from under inode_lockDave Chinner
Protect the inode writeback list with a new global lock inode_wb_list_lock and use it to protect the list manipulations and traversals. This lock replaces the inode_lock as the inodes on the list can be validity checked while holding the inode->i_lock and hence the inode_lock is no longer needed to protect the list. Signed-off-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-24fs: move i_sb_list out from under inode_lockDave Chinner
Protect the per-sb inode list with a new global lock inode_sb_list_lock and use it to protect the list manipulations and traversals. This lock replaces the inode_lock as the inodes on the list can be validity checked while holding the inode->i_lock and hence the inode_lock is no longer needed to protect the list. Signed-off-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-24fs: protect inode->i_state with inode->i_lockDave Chinner
Protect inode state transitions and validity checks with the inode->i_lock. This enables us to make inode state transitions independently of the inode_lock and is the first step to peeling away the inode_lock from the code. This requires that __iget() is done atomically with i_state checks during list traversals so that we don't race with another thread marking the inode I_FREEING between the state check and grabbing the reference. Also remove the unlock_new_inode() memory barrier optimisation required to avoid taking the inode_lock when clearing I_NEW. Simplify the code by simply taking the inode->i_lock around the state change and wakeup. Because the wakeup is no longer tricky, remove the wake_up_inode() function and open code the wakeup where necessary. Signed-off-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-01-13fs/fs-writeback.c: fix sync_inodes_sb() return value kernel-docStefan Hajnoczi
The sync_inodes_sb() function does not have a return value. Remove the outdated documentation comment. Signed-off-by: Stefan Hajnoczi <stefanha@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13sync_inode_metadata: fix commentAndrew Morton
Use correct function name, remove incorrect apostrophe Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13writeback: avoid livelocking WB_SYNC_ALL writebackJan Kara
When wb_writeback() is called in WB_SYNC_ALL mode, work->nr_to_write is usually set to LONG_MAX. The logic in wb_writeback() then calls __writeback_inodes_sb() with nr_to_write == MAX_WRITEBACK_PAGES and we easily end up with non-positive nr_to_write after the function returns, if the inode has more than MAX_WRITEBACK_PAGES dirty pages at the moment. When nr_to_write is <= 0 wb_writeback() decides we need another round of writeback but this is wrong in some cases! For example when a single large file is continuously dirtied, we would never finish syncing it because each pass would be able to write MAX_WRITEBACK_PAGES and inode dirty timestamp never gets updated (as inode is never completely clean). Thus __writeback_inodes_sb() would write the redirtied inode again and again. Fix the issue by setting nr_to_write to LONG_MAX in WB_SYNC_ALL mode. We do not need nr_to_write in WB_SYNC_ALL mode anyway since write_cache_pages() does livelock avoidance using page tagging in WB_SYNC_ALL mode. This makes wb_writeback() call __writeback_inodes_sb() only once on WB_SYNC_ALL. The latter function won't livelock because it works on - a finite set of files by doing queue_io() once at the beginning - a finite set of pages by PAGECACHE_TAG_TOWRITE page tagging After this patch, program from http://lkml.org/lkml/2010/10/24/154 is no longer able to stall sync forever. [fengguang.wu@intel.com: fix locking comment] Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Dave Chinner <david@fromorbit.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Jan Engelhardt <jengelh@medozas.de> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13writeback: stop background/kupdate works from livelocking other worksJan Kara
Background writeback is easily livelockable in a loop in wb_writeback() by a process continuously re-dirtying pages (or continuously appending to a file). This is in fact intended as the target of background writeback is to write dirty pages it can find as long as we are over dirty_background_threshold. But the above behavior gets inconvenient at times because no other work queued in the flusher thread's queue gets processed. In particular, since e.g. sync(1) relies on flusher thread to do all the IO for it, sync(1) can hang forever waiting for flusher thread to do the work. Generally, when a flusher thread has some work queued, someone submitted the work to achieve a goal more specific than what background writeback does. Moreover by working on the specific work, we also reduce amount of dirty pages which is exactly the target of background writeout. So it makes sense to give specific work a priority over a generic page cleaning. Thus we interrupt background writeback if there is some other work to do. We return to the background writeback after completing all the queued work. This may delay the writeback of expired inodes for a while, however the expired inodes will eventually be flushed to disk as long as the other works won't livelock. [fengguang.wu@intel.com: update comment] Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Dave Chinner <david@fromorbit.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Jan Engelhardt <jengelh@medozas.de> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13writeback: trace wakeup event for background writebackWu Fengguang
This tracks when balance_dirty_pages() tries to wakeup the flusher thread for background writeback (if it was not started already). Suggested-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Jan Kara <jack@suse.cz> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Dave Chinner <david@fromorbit.com> Cc: Jan Engelhardt <jengelh@medozas.de> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13writeback: integrated background writeback workJan Kara
Check whether background writeback is needed after finishing each work. When bdi flusher thread finishes doing some work check whether any kind of background writeback needs to be done (either because dirty_background_ratio is exceeded or because we need to start flushing old inodes). If so, just do background write back. This way, bdi_start_background_writeback() just needs to wake up the flusher thread. It will do background writeback as soon as there is no other work. This is a preparatory patch for the next patch which stops background writeback as soon as there is other work to do. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Dave Chinner <david@fromorbit.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Jan Engelhardt <jengelh@medozas.de> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-30Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable: (39 commits) Btrfs: deal with errors from updating the tree log Btrfs: allow subvol deletion by unprivileged user with -o user_subvol_rm_allowed Btrfs: make SNAP_DESTROY async Btrfs: add SNAP_CREATE_ASYNC ioctl Btrfs: add START_SYNC, WAIT_SYNC ioctls Btrfs: async transaction commit Btrfs: fix deadlock in btrfs_commit_transaction Btrfs: fix lockdep warning on clone ioctl Btrfs: fix clone ioctl where range is adjacent to extent Btrfs: fix delalloc checks in clone ioctl Btrfs: drop unused variable in block_alloc_rsv Btrfs: cleanup warnings from gcc 4.6 (nonbugs) Btrfs: Fix variables set but not read (bugs found by gcc 4.6) Btrfs: Use ERR_CAST helpers Btrfs: use memdup_user helpers Btrfs: fix raid code for removing missing drives Btrfs: Switch the extent buffer rbtree into a radix tree Btrfs: restructure try_release_extent_buffer() Btrfs: use the flusher threads for delalloc throttling Btrfs: tune the chunk allocation to 5% of the FS as metadata ... Fix up trivial conflicts in fs/btrfs/super.c and fs/fs-writeback.c, and remove use of INIT_RCU_HEAD in fs/btrfs/extent_io.c (that init macro was useless and removed in commit 5e8067adfdba: "rcu head remove init")
2010-10-30fs-writeback.c: unify some common codeLinus Torvalds
The btrfs merge looks like hell, because it changes fs-writeback.c, and the crazy code has this repeated "estimate number of dirty pages" counting that involves three different helper functions. And it's done in two different places. Just unify that whole calculation as a "get_nr_dirty_pages()" helper function, and the merge result will look half-way decent. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-29Add new functions for triggering inode writebackChris Mason
When btrfs is running low on metadata space, it needs to force delayed allocation pages to disk. It currently does this with a suboptimal walk of a private list of inodes with delayed allocation, and it would be much better if we used the generic flusher threads. writeback_inodes_sb_if_idle would be ideal, but it waits for the flusher thread to start IO on all the dirty pages in the FS before it returns. This adds variants of writeback_inodes_sb* that allow the caller to control how many pages get sent down. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-10-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (52 commits) split invalidate_inodes() fs: skip I_FREEING inodes in writeback_sb_inodes fs: fold invalidate_list into invalidate_inodes fs: do not drop inode_lock in dispose_list fs: inode split IO and LRU lists fs: switch bdev inode bdi's correctly fs: fix buffer invalidation in invalidate_list fsnotify: use dget_parent smbfs: use dget_parent exportfs: use dget_parent fs: use RCU read side protection in d_validate fs: clean up dentry lru modification fs: split __shrink_dcache_sb fs: improve DCACHE_REFERENCED usage fs: use percpu counter for nr_dentry and nr_dentry_unused fs: simplify __d_free fs: take dcache_lock inside __d_path fs: do not assign default i_ino in new_inode fs: introduce a per-cpu last_ino allocator new helper: ihold() ...
2010-10-26kernel: remove PF_FLUSHERPeter Zijlstra
PF_FLUSHER is only ever set, not tested, remove it. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26fs/fs-writeback.c: restore lost commentAndrew Morton
I had to go back to a 2.6.20 tree to work out why we're adding a number-of-inodes into a number-of-pages count. Restore the lost comment. Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26writeback: remove the internal 5% low bound on dirty_ratioWu Fengguang
The dirty_ratio was silently limited in global_dirty_limits() to >= 5%. This is not a user expected behavior. And it's inconsistent with calc_period_shift(), which uses the plain vm_dirty_ratio value. Let's remove the internal bound. At the same time, fix balance_dirty_pages() to work with the dirty_thresh=0 case. This allows applications to proceed when dirty+writeback pages are all cleaned. And ">" fits with the name "exceeded" better than ">=" does. Neil thinks it is an aesthetic improvement as well as a functional one :) Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Jan Kara <jack@suse.cz> Proposed-by: Con Kolivas <kernel@kolivas.org> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Reviewed-by: Rik van Riel <riel@redhat.com> Reviewed-by: Neil Brown <neilb@suse.de> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Michael Rubin <mrubin@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-25fs: skip I_FREEING inodes in writeback_sb_inodesChristoph Hellwig
Skip I_FREEING inodes just like I_WILL_FREE and I_NEW when walking the writeback lists. Currenly this can't happen, but once we move from inode_lock to more fine grained locking we can have an inode that's still on the writeback lists but has I_FREEING set, and we absolutely need to skip it here, just like we do for all other inode list walks. Based on a patch from Dave Chinner. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-25fs: inode split IO and LRU listsNick Piggin
The use of the same inode list structure (inode->i_list) for two different list constructs with different lifecycles and purposes makes it impossible to separate the locking of the different operations. Therefore, to enable the separation of the locking of the writeback and reclaim lists, split the inode->i_list into two separate lists dedicated to their specific tracking functions. Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-25fs: Implement lazy LRU updates for inodesNick Piggin
Convert the inode LRU to use lazy updates to reduce lock and cacheline traffic. We avoid moving inodes around in the LRU list during iget/iput operations so these frequent operations don't need to access the LRUs. Instead, we defer the refcount checks to reclaim-time and use a per-inode state flag, I_REFERENCED, to tell reclaim that iget has touched the inode in the past. This means that only reclaim should be touching the LRU with any frequency, hence significantly reducing lock acquisitions and the amount contention on LRU updates. This also removes the inode_in_use list, which means we now only have one list for tracking the inode LRU status. This makes it much simpler to split out the LRU list operations under it's own lock. Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-25fs: Convert nr_inodes and nr_unused to per-cpu countersDave Chinner
The number of inodes allocated does not need to be tied to the addition or removal of an inode to/from a list. If we are not tied to a list lock, we could update the counters when inodes are initialised or destroyed, but to do that we need to convert the counters to be per-cpu (i.e. independent of a lock). This means that we have the freedom to change the list/locking implementation without needing to care about the counters. Based on a patch originally from Eric Dumazet. [AV: cleaned up a bit, fixed build breakage on weird configs Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-25new helper: inode_unhashed()Al Viro
note: for race-free uses you inode_lock held Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-25fs: add sync_inode_metadataChristoph Hellwig
Add a new helper to write out the inode using the writeback code, that is including the correct dirty bit and list manipulation. A few of filesystems already opencode this, and a lot of others should be using it instead of using write_inode_now which also writes out the data. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-04writeback: always use sb->s_bdi for writeback purposesChristoph Hellwig
We currently use struct backing_dev_info for various different purposes. Originally it was introduced to describe a backing device which includes an unplug and congestion function and various bits of readahead information and VM-relevant flags. We're also using for tracking dirty inodes for writeback. To make writeback properly find all inodes we need to only access the per-filesystem backing_device pointed to by the superblock in ->s_bdi inside the writeback code, and not the instances pointeded to by inode->i_mapping->backing_dev which can be overriden by special devices or might not be set at all by some filesystems. Long term we should split out the writeback-relevant bits of struct backing_device_info (which includes more than the current bdi_writeback) and only point to it from the superblock while leaving the traditional backing device as a separate structure that can be overriden by devices. The one exception for now is the block device filesystem which really wants different writeback contexts for it's different (internal) inodes to handle the writeout more efficiently. For now we do this with a hack in fs-writeback.c because we're so late in the cycle, but in the future I plan to replace this with a superblock method that allows for multiple writeback contexts per filesystem. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-22bdi: Fix warnings in __mark_inode_dirty for /dev/zero and friendsJan Kara
Inodes of devices such as /dev/zero can get dirty for example via utime(2) syscall or due to atime update. Backing device of such inodes (zero_bdi, etc.) is however unable to handle dirty inodes and thus __mark_inode_dirty complains. In fact, inode should be rather dirtied against backing device of the filesystem holding it. This is generally a good rule except for filesystems such as 'bdev' or 'mtd_inodefs'. Inodes in these pseudofilesystems are referenced from ordinary filesystem inodes and carry mapping with real data of the device. Thus for these inodes we have to use inode->i_mapping->backing_dev_info as we did so far. We distinguish these filesystems by checking whether sb->s_bdi points to a non-trivial backing device or not. Example: Assume we have an ext3 filesystem on /dev/sda1 mounted on /. There's a device inode A described by a path "/dev/sdb" on this filesystem. This inode will be dirtied against backing device "8:0" after this patch. bdev filesystem contains block device inode B coupled with our inode A. When someone modifies a page of /dev/sdb, it's B that gets dirtied and the dirtying happens against the backing device "8:16". Thus both inodes get filed to a correct bdi list. Cc: stable@kernel.org Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-28writeback: Fix lost wake-up shutting down writeback threadJ. Bruce Fields
Setting the task state here may cause us to miss the wake up from kthread_stop(), so we need to recheck kthread_should_stop() or risk sleeping forever in the following schedule(). Symptom was an indefinite hang on an NFSv4 mount. (NFSv4 may create multiple mounts in a temporary namespace while traversing the mount path, and since the temporary namespace is immediately destroyed, it may end up destroying a mount very soon after it was created, possibly making this race more likely.) INFO: task mount.nfs4:4314 blocked for more than 120 seconds. "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message. mount.nfs4 D 0000000000000000 2880 4314 4313 0x00000000 ffff88001ed6da28 0000000000000046 ffff88001ed6dfd8 ffff88001ed6dfd8 ffff88001ed6c000 ffff88001ed6c000 ffff88001ed6c000 ffff88001e5003a0 ffff88001ed6dfd8 ffff88001e5003a8 ffff88001ed6c000 ffff88001ed6dfd8 Call Trace: [<ffffffff8196090d>] schedule_timeout+0x1cd/0x2e0 [<ffffffff8106a31c>] ? mark_held_locks+0x6c/0xa0 [<ffffffff819639a0>] ? _raw_spin_unlock_irq+0x30/0x60 [<ffffffff8106a5fd>] ? trace_hardirqs_on_caller+0x14d/0x190 [<ffffffff819671fe>] ? sub_preempt_count+0xe/0xd0 [<ffffffff8195fc80>] wait_for_common+0x120/0x190 [<ffffffff81033c70>] ? default_wake_function+0x0/0x20 [<ffffffff8195fdcd>] wait_for_completion+0x1d/0x20 [<ffffffff810595fa>] kthread_stop+0x4a/0x150 [<ffffffff81061a60>] ? thaw_process+0x70/0x80 [<ffffffff810cc68a>] bdi_unregister+0x10a/0x1a0 [<ffffffff81229dc9>] nfs_put_super+0x19/0x20 [<ffffffff810ee8c4>] generic_shutdown_super+0x54/0xe0 [<ffffffff810ee9b6>] kill_anon_super+0x16/0x60 [<ffffffff8122d3b9>] nfs4_kill_super+0x39/0x90 [<ffffffff810eda45>] deactivate_locked_super+0x45/0x60 [<ffffffff810edfb9>] deactivate_super+0x49/0x70 [<ffffffff81108294>] mntput_no_expire+0x84/0xe0 [<ffffffff811084ef>] release_mounts+0x9f/0xc0 [<ffffffff81108575>] put_mnt_ns+0x65/0x80 [<ffffffff8122cc56>] nfs_follow_remote_path+0x1e6/0x420 [<ffffffff8122cfbf>] nfs4_try_mount+0x6f/0xd0 [<ffffffff8122d0c2>] nfs4_get_sb+0xa2/0x360 [<ffffffff810edcb8>] vfs_kern_mount+0x88/0x1f0 [<ffffffff810ede92>] do_kern_mount+0x52/0x130 [<ffffffff81963d9a>] ? _lock_kernel+0x6a/0x170 [<ffffffff81108e9e>] do_mount+0x26e/0x7f0 [<ffffffff81106b3a>] ? copy_mount_options+0xea/0x190 [<ffffffff811094b8>] sys_mount+0x98/0xf0 [<ffffffff810024d8>] system_call_fastpath+0x16/0x1b 1 lock held by mount.nfs4/4314: #0: (&type->s_umount_key#24){+.+...}, at: [<ffffffff810edfb1>] deactivate_super+0x41/0x70 Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com> Acked-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2010-08-12mm: fix writeback_in_progress()Jan Kara
Commit 83ba7b071f3 ("writeback: simplify the write back thread queue") broke writeback_in_progress() as in that commit we started to remove work items from the list at the moment we start working on them and not at the moment they are finished. Thus if the flusher thread was doing some work but there was no other work queued, writeback_in_progress() returned false. This could in particular cause unnecessary queueing of background writeback from balance_dirty_pages() or writeout work from writeback_sb_if_idle(). This patch fixes the problem by introducing a bit in the bdi state which indicates that the flusher thread is processing some work and uses this bit for writeback_in_progress() test. NOTE: Both callsites of writeback_in_progress() (namely, writeback_inodes_sb_if_idle() and balance_dirty_pages()) would actually need a different information than what writeback_in_progress() provides. They would need to know whether *the kind of writeback they are going to submit* is already queued. But this information isn't that simple to provide so let's fix writeback_in_progress() for the time being. Signed-off-by: Jan Kara <jack@suse.cz> Cc: Christoph Hellwig <hch@lst.de> Cc: Wu Fengguang <fengguang.wu@intel.com> Acked-by: Jens Axboe <jaxboe@fusionio.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-12writeback: merge for_kupdate and !for_kupdate casesWu Fengguang
Unify the logic for kupdate and non-kupdate cases. There won't be starvation because the inodes requeued into b_more_io will later be spliced _after_ the remaining inodes in b_io, hence won't stand in the way of other inodes in the next run. It avoids unnecessary redirty_tail() calls, hence the update of i_dirtied_when. The timestamp update is undesirable because it could later delay the inode's periodic writeback, or may exclude the inode from the data integrity sync operation (which checks timestamp to avoid extra work and livelock). === How the redirty_tail() comes about: It was a long story.. This redirty_tail() was introduced with wbc.more_io. The initial patch for more_io actually does not have the redirty_tail(), and when it's merged, several 100% iowait bug reports arised: reiserfs: http://lkml.org/lkml/2007/10/23/93 jfs: commit 29a424f28390752a4ca2349633aaacc6be494db5 JFS: clear PAGECACHE_TAG_DIRTY for no-write pages ext2: http://www.spinics.net/linux/lists/linux-ext4/msg04762.html They are all old bugs hidden in various filesystems that become "visible" with the more_io patch. At the time, the ext2 bug is thought to be "trivial", so not fixed. Instead the following updated more_io patch with redirty_tail() is merged: http://www.spinics.net/linux/lists/linux-ext4/msg04507.html This will in general prevent 100% on ext2 and possibly other unknown FS bugs. Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Dave Chinner <david@fromorbit.com> Cc: Martin Bligh <mbligh@google.com> Cc: Michael Rubin <mrubin@google.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Christoph Hellwig <hch@infradead.org> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-12writeback: fix queue_io() orderingWu Fengguang
This was not a bug, since b_io is empty for kupdate writeback. The next patch will do requeue_io() for non-kupdate writeback, so let's fix it. Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Dave Chinner <david@fromorbit.com> Cc: Martin Bligh <mbligh@google.com> Cc: Michael Rubin <mrubin@google.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Christoph Hellwig <hch@infradead.org> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-12writeback: don't redirty tail an inode with dirty pagesWu Fengguang
Avoid delaying writeback for an expire inode with lots of dirty pages, but no active dirtier at the moment. Previously we only do that for the kupdate case. Any filesystem that does delayed allocation or unwritten extent conversion after IO completion will cause this - for example, XFS. Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Acked-by: Jan Kara <jack@suse.cz> Cc: Dave Chinner <david@fromorbit.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Dave Chinner <david@fromorbit.com> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-12writeback: avoid unnecessary calculation of bdi dirty thresholdsWu Fengguang
Split get_dirty_limits() into global_dirty_limits()+bdi_dirty_limit(), so that the latter can be avoided when under global dirty background threshold (which is the normal state for most systems). Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Christoph Hellwig <hch@infradead.org> Cc: Dave Chinner <david@fromorbit.com> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-10Merge branch 'for-2.6.36' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.36' of git://git.kernel.dk/linux-2.6-block: (149 commits) block: make sure that REQ_* types are seen even with CONFIG_BLOCK=n xen-blkfront: fix missing out label blkdev: fix blkdev_issue_zeroout return value block: update request stacking methods to support discards block: fix missing export of blk_types.h writeback: fix bad _bh spinlock nesting drbd: revert "delay probes", feature is being re-implemented differently drbd: Initialize all members of sync_conf to their defaults [Bugz 315] drbd: Disable delay probes for the upcomming release writeback: cleanup bdi_register writeback: add new tracepoints writeback: remove unnecessary init_timer call writeback: optimize periodic bdi thread wakeups writeback: prevent unnecessary bdi threads wakeups writeback: move bdi threads exiting logic to the forker thread writeback: restructure bdi forker loop a little writeback: move last_active to bdi writeback: do not remove bdi from bdi_list writeback: simplify bdi code a little writeback: do not lose wake-ups in bdi threads ... Fixed up pretty trivial conflicts in drivers/block/virtio_blk.c and drivers/scsi/scsi_error.c as per Jens.
2010-08-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (96 commits) no need for list_for_each_entry_safe()/resetting with superblock list Fix sget() race with failing mount vfs: don't hold s_umount over close_bdev_exclusive() call sysv: do not mark superblock dirty on remount sysv: do not mark superblock dirty on mount btrfs: remove junk sb_dirt change BFS: clean up the superblock usage AFFS: wait for sb synchronization when needed AFFS: clean up dirty flag usage cifs: truncate fallout mbcache: fix shrinker function return value mbcache: Remove unused features add f_flags to struct statfs(64) pass a struct path to vfs_statfs update VFS documentation for method changes. All filesystems that need invalidate_inode_buffers() are doing that explicitly convert remaining ->clear_inode() to ->evict_inode() Make ->drop_inode() just return whether inode needs to be dropped fs/inode.c:clear_inode() is gone fs/inode.c:evict() doesn't care about delete vs. non-delete paths now ... Fix up trivial conflicts in fs/nilfs2/super.c
2010-08-09mm: avoid resetting wb_start after each writeback roundJan Kara
WB_SYNC_NONE writeback is done in rounds of 1024 pages so that we don't write out some huge inode for too long while starving writeout of other inodes. To avoid livelocks, we record time we started writeback in wbc->wb_start and do not write out inodes which were dirtied after this time. But currently, writeback_inodes_wb() resets wb_start each time it is called thus effectively invalidating this logic and making any WB_SYNC_NONE writeback prone to livelocks. This patch makes sure wb_start is set only once when we start writeback. Signed-off-by: Jan Kara <jack@suse.cz> Reviewed-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Christoph Hellwig <hch@lst.de> Acked-by: Jens Axboe <jaxboe@fusionio.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09simplify checks for I_CLEAR/I_FREEINGAl Viro
add I_CLEAR instead of replacing I_FREEING with it. I_CLEAR is equivalent to I_FREEING for almost all code looking at either; it's there to keep track of having called clear_inode() exactly once per inode lifetime, at some point after having set I_FREEING. I_CLEAR and I_FREEING never get set at the same time with the current code, so we can switch to setting i_flags to I_FREEING | I_CLEAR instead of I_CLEAR without loss of information. As the result of such change, checks become simpler and the amount of code that needs to know about I_CLEAR shrinks a lot. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-07writeback: optimize periodic bdi thread wakeupsArtem Bityutskiy
Whe the first inode for a bdi is marked dirty, we wake up the bdi thread which should take care of the periodic background write-out. However, the write-out will actually start only 'dirty_writeback_interval' centisecs later, so we can delay the wake-up. This change was requested by Nick Piggin who pointed out that if we delay the wake-up, we weed out 2 unnecessary contex switches, which matters because '__mark_inode_dirty()' is a hot-path function. This patch introduces a new function - 'bdi_wakeup_thread_delayed()', which sets up a timer to wake-up the bdi thread and returns. So the wake-up is delayed. We also delete the timer in bdi threads just before writing-back. And synchronously delete it when unregistering bdi. At the unregister point the bdi does not have any users, so no one can arm it again. Since now we take 'bdi->wb_lock' in the timer, which can execute in softirq context, we have to use 'spin_lock_bh()' for 'bdi->wb_lock'. This patch makes this change as well. This patch also moves the 'bdi_wb_init()' function down in the file to avoid forward-declaration of 'bdi_wakeup_thread_delayed()'. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07writeback: prevent unnecessary bdi threads wakeupsArtem Bityutskiy
Finally, we can get rid of unnecessary wake-ups in bdi threads, which are very bad for battery-driven devices. There are two types of activities bdi threads do: 1. process bdi works from the 'bdi->work_list' 2. periodic write-back So there are 2 sources of wake-up events for bdi threads: 1. 'bdi_queue_work()' - submits bdi works 2. '__mark_inode_dirty()' - adds dirty I/O to bdi's The former already has bdi wake-up code. The latter does not, and this patch adds it. '__mark_inode_dirty()' is hot-path function, but this patch adds another 'spin_lock(&bdi->wb_lock)' there. However, it is taken only in rare cases when the bdi has no dirty inodes. So adding this spinlock should be fine and should not affect performance. This patch makes sure bdi threads and the forker thread do not wake-up if there is nothing to do. The forker thread will nevertheless wake up at least every 5 min. to check whether it has to kill a bdi thread. This can also be optimized, but is not worth it. This patch also tidies up the warning about unregistered bid, and turns it from an ugly crocodile to a simple 'WARN()' statement. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07writeback: move bdi threads exiting logic to the forker threadArtem Bityutskiy
Currently, bdi threads can decide to exit if there were no useful activities for 5 minutes. However, this causes nasty races: we can easily oops in the 'bdi_queue_work()' if the bdi thread decides to exit while we are waking it up. And even if we do not oops, but the bdi tread exits immediately after we wake it up, we'd lose the wake-up event and have an unnecessary delay (up to 5 secs) in the bdi work processing. This patch makes the forker thread to be the central place which not only creates bdi threads, but also kills them if they were inactive long enough. This better design-wise. Another reason why this change was done is to prepare for the further changes which will prevent the bdi threads from waking up every 5 sec and wasting power. Indeed, when the task does not wake up periodically anymore, it won't be able to exit either. This patch also moves the the 'wake_up_bit()' call from the bdi thread to the forker thread as well. So now the forker thread sets the BDI_pending bit, then forks the task or kills it, then clears the bit and wakes up the waiting process. The only process which may wain on the bit is 'bdi_wb_shutdown()'. This function was changed as well - now it first removes the bdi from the 'bdi_list', then waits on the 'BDI_pending' bit. Once it wakes up, it is guaranteed that the forker thread won't race with it, because the bdi is not visible. Note, the forker thread sets the 'BDI_pending' bit under the 'bdi->wb_lock' which is essential for proper serialization. And additionally, when we change 'bdi->wb.task', we now take the 'bdi->work_lock', to make sure that we do not lose wake-ups which we otherwise would when raced with, say, 'bdi_queue_work()'. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07writeback: move last_active to bdiArtem Bityutskiy
Currently bdi threads use local variable 'last_active' which stores last time when the bdi thread did some useful work. Move this local variable to 'struct bdi_writeback'. This is just a preparation for the further patches which will make the forker thread decide when bdi threads should be killed. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07writeback: do not remove bdi from bdi_listArtem Bityutskiy
The forker thread removes bdis from 'bdi_list' before forking the bdi thread. But this is wrong for at least 2 reasons. Reason #1: if we temporary remove a bdi from the list, we may miss works which would otherwise be given to us. Reason #2: this is racy; indeed, 'bdi_wb_shutdown()' expects that bdis are always in the 'bdi_list' (see 'bdi_remove_from_list()'), and when it races with the forker thread, it can shut down the bdi thread at the same time as the forker creates it. This patch makes sure the forker thread never removes bdis from 'bdi_list' (which was suggested by Christoph Hellwig). In order to make sure that we do not race with 'bdi_wb_shutdown()', we have to hold the 'bdi_lock' while walking the 'bdi_list' and setting the 'BDI_pending' flag. NOTE! The error path is interesting. Currently, when we fail to create a bdi thread, we move the bdi to the tail of 'bdi_list'. But if we never remove the bdi from the list, we cannot move it to the tail either, because then we can mess up the RCU readers which walk the list. And also, we'll have the race described above in "Reason #2". But I not think that adding to the tail is any important so I just do not do that. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07writeback: do not lose wake-ups in bdi threadsArtem Bityutskiy
Currently, bdi threads ('bdi_writeback_thread()') can lose wake-ups. For example, if 'bdi_queue_work()' is executed after the bdi thread have had finished 'wb_do_writeback()' but before it called 'schedule_timeout_interruptible()'. To fix this issue, we have to check whether we have works to process after we have changed the task state to 'TASK_INTERRUPTIBLE'. This patch also clean-ups handling of the cases when 'dirty_writeback_interval' is zero or non-zero. Additionally, this patch also removes unneeded 'list_empty_careful()' call. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
