We currently use struct backing_dev_info for various different purposes.
Originally it was introduced to describe a backing device which includes
an unplug and congestion function and various bits of readahead information
and VM-relevant flags. We're also using for tracking dirty inodes for
writeback.
To make writeback properly find all inodes we need to only access the
per-filesystem backing_device pointed to by the superblock in ->s_bdi
inside the writeback code, and not the instances pointeded to by
inode->i_mapping->backing_dev which can be overriden by special devices
or might not be set at all by some filesystems.
Long term we should split out the writeback-relevant bits of struct
backing_device_info (which includes more than the current bdi_writeback)
and only point to it from the superblock while leaving the traditional
backing device as a separate structure that can be overriden by devices.
The one exception for now is the block device filesystem which really
wants different writeback contexts for it's different (internal) inodes
to handle the writeout more efficiently. For now we do this with
a hack in fs-writeback.c because we're so late in the cycle, but in
the future I plan to replace this with a superblock method that allows
for multiple writeback contexts per filesystem.
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
Signed-off-by: San Mehat <san@android.com>
Inodes of devices such as /dev/zero can get dirty for example via
utime(2) syscall or due to atime update. Backing device of such inodes
(zero_bdi, etc.) is however unable to handle dirty inodes and thus
__mark_inode_dirty complains. In fact, inode should be rather dirtied
against backing device of the filesystem holding it. This is generally a
good rule except for filesystems such as 'bdev' or 'mtd_inodefs'. Inodes
in these pseudofilesystems are referenced from ordinary filesystem
inodes and carry mapping with real data of the device. Thus for these
inodes we have to use inode->i_mapping->backing_dev_info as we did so
far. We distinguish these filesystems by checking whether sb->s_bdi
points to a non-trivial backing device or not.
Example: Assume we have an ext3 filesystem on /dev/sda1 mounted on /.
There's a device inode A described by a path "/dev/sdb" on this
filesystem. This inode will be dirtied against backing device "8:0"
after this patch. bdev filesystem contains block device inode B coupled
with our inode A. When someone modifies a page of /dev/sdb, it's B that
gets dirtied and the dirtying happens against the backing device "8:16".
Thus both inodes get filed to a correct bdi list.
Cc: stable@kernel.org
Setting the task state here may cause us to miss the wake up from
kthread_stop(), so we need to recheck kthread_should_stop() or risk
sleeping forever in the following schedule().
Symptom was an indefinite hang on an NFSv4 mount. (NFSv4 may create
multiple mounts in a temporary namespace while traversing the mount
path, and since the temporary namespace is immediately destroyed, it may
end up destroying a mount very soon after it was created, possibly
making this race more likely.)
INFO: task mount.nfs4:4314 blocked for more than 120 seconds.
"echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
mount.nfs4 D 0000000000000000 2880 4314 4313 0x00000000
ffff88001ed6da28 0000000000000046 ffff88001ed6dfd8 ffff88001ed6dfd8
ffff88001ed6c000 ffff88001ed6c000 ffff88001ed6c000 ffff88001e5003a0
ffff88001ed6dfd8 ffff88001e5003a8 ffff88001ed6c000 ffff88001ed6dfd8
Call Trace:
[<ffffffff8196090d>] schedule_timeout+0x1cd/0x2e0
[<ffffffff8106a31c>] ? mark_held_locks+0x6c/0xa0
[<ffffffff819639a0>] ? _raw_spin_unlock_irq+0x30/0x60
[<ffffffff8106a5fd>] ? trace_hardirqs_on_caller+0x14d/0x190
[<ffffffff819671fe>] ? sub_preempt_count+0xe/0xd0
[<ffffffff8195fc80>] wait_for_common+0x120/0x190
[<ffffffff81033c70>] ? default_wake_function+0x0/0x20
[<ffffffff8195fdcd>] wait_for_completion+0x1d/0x20
[<ffffffff810595fa>] kthread_stop+0x4a/0x150
[<ffffffff81061a60>] ? thaw_process+0x70/0x80
[<ffffffff810cc68a>] bdi_unregister+0x10a/0x1a0
[<ffffffff81229dc9>] nfs_put_super+0x19/0x20
[<ffffffff810ee8c4>] generic_shutdown_super+0x54/0xe0
[<ffffffff810ee9b6>] kill_anon_super+0x16/0x60
[<ffffffff8122d3b9>] nfs4_kill_super+0x39/0x90
[<ffffffff810eda45>] deactivate_locked_super+0x45/0x60
[<ffffffff810edfb9>] deactivate_super+0x49/0x70
[<ffffffff81108294>] mntput_no_expire+0x84/0xe0
[<ffffffff811084ef>] release_mounts+0x9f/0xc0
[<ffffffff81108575>] put_mnt_ns+0x65/0x80
[<ffffffff8122cc56>] nfs_follow_remote_path+0x1e6/0x420
[<ffffffff8122cfbf>] nfs4_try_mount+0x6f/0xd0
[<ffffffff8122d0c2>] nfs4_get_sb+0xa2/0x360
[<ffffffff810edcb8>] vfs_kern_mount+0x88/0x1f0
[<ffffffff810ede92>] do_kern_mount+0x52/0x130
[<ffffffff81963d9a>] ? _lock_kernel+0x6a/0x170
[<ffffffff81108e9e>] do_mount+0x26e/0x7f0
[<ffffffff81106b3a>] ? copy_mount_options+0xea/0x190
[<ffffffff811094b8>] sys_mount+0x98/0xf0
[<ffffffff810024d8>] system_call_fastpath+0x16/0x1b
1 lock held by mount.nfs4/4314:
#0: (&type->s_umount_key#24){+.+...}, at: [<ffffffff810edfb1>] deactivate_super+0x41/0x70
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
Acked-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
Commit 83ba7b071f3 ("writeback: simplify the write back thread queue")
broke writeback_in_progress() as in that commit we started to remove work
items from the list at the moment we start working on them and not at the
moment they are finished. Thus if the flusher thread was doing some work
but there was no other work queued, writeback_in_progress() returned
false. This could in particular cause unnecessary queueing of background
writeback from balance_dirty_pages() or writeout work from
writeback_sb_if_idle().
This patch fixes the problem by introducing a bit in the bdi state which
indicates that the flusher thread is processing some work and uses this
bit for writeback_in_progress() test.
NOTE: Both callsites of writeback_in_progress() (namely,
writeback_inodes_sb_if_idle() and balance_dirty_pages()) would actually
need a different information than what writeback_in_progress() provides.
They would need to know whether *the kind of writeback they are going to
submit* is already queued. But this information isn't that simple to
provide so let's fix writeback_in_progress() for the time being.
Cc: Wu Fengguang <fengguang.wu@intel.com>
Acked-by: Jens Axboe <jaxboe@fusionio.com>
Unify the logic for kupdate and non-kupdate cases. There won't be
starvation because the inodes requeued into b_more_io will later be
spliced _after_ the remaining inodes in b_io, hence won't stand in the way
of other inodes in the next run.
It avoids unnecessary redirty_tail() calls, hence the update of
i_dirtied_when. The timestamp update is undesirable because it could
later delay the inode's periodic writeback, or may exclude the inode from
the data integrity sync operation (which checks timestamp to avoid extra
work and livelock).
How the redirty_tail() comes about:
It was a long story.. This redirty_tail() was introduced with
wbc.more_io. The initial patch for more_io actually does not have the
redirty_tail(), and when it's merged, several 100% iowait bug reports
arised:
reiserfs:
http://lkml.org/lkml/2007/10/23/93
jfs:
commit 29a424f28390752a4ca2349633aaacc6be494db5
JFS: clear PAGECACHE_TAG_DIRTY for no-write pages
ext2:
http://www.spinics.net/linux/lists/linux-ext4/msg04762.html
They are all old bugs hidden in various filesystems that become "visible"
with the more_io patch. At the time, the ext2 bug is thought to be
"trivial", so not fixed. Instead the following updated more_io patch with
redirty_tail() is merged:
http://www.spinics.net/linux/lists/linux-ext4/msg04507.html
This will in general prevent 100% on ext2 and possibly other unknown FS bugs.
Signed-off-by: Wu Fengguang <fengguang.wu@intel.com>
Cc: Martin Bligh <mbligh@google.com>
Cc: Michael Rubin <mrubin@google.com>
This was not a bug, since b_io is empty for kupdate writeback. The next
patch will do requeue_io() for non-kupdate writeback, so let's fix it.
Avoid delaying writeback for an expire inode with lots of dirty pages, but
no active dirtier at the moment. Previously we only do that for the
kupdate case.
Any filesystem that does delayed allocation or unwritten extent conversion
after IO completion will cause this - for example, XFS.
Acked-by: Jan Kara <jack@suse.cz>
Split get_dirty_limits() into global_dirty_limits()+bdi_dirty_limit(), so
that the latter can be avoided when under global dirty background
threshold (which is the normal state for most systems).
* 'for-2.6.36' of git://git.kernel.dk/linux-2.6-block: (149 commits)
block: make sure that REQ_* types are seen even with CONFIG_BLOCK=n
xen-blkfront: fix missing out label
blkdev: fix blkdev_issue_zeroout return value
block: update request stacking methods to support discards
block: fix missing export of blk_types.h
writeback: fix bad _bh spinlock nesting
drbd: revert "delay probes", feature is being re-implemented differently
drbd: Initialize all members of sync_conf to their defaults [Bugz 315]
drbd: Disable delay probes for the upcomming release
writeback: cleanup bdi_register
writeback: add new tracepoints
writeback: remove unnecessary init_timer call
writeback: optimize periodic bdi thread wakeups
writeback: prevent unnecessary bdi threads wakeups
writeback: move bdi threads exiting logic to the forker thread
writeback: restructure bdi forker loop a little
writeback: move last_active to bdi
writeback: do not remove bdi from bdi_list
writeback: simplify bdi code a little
writeback: do not lose wake-ups in bdi threads
Fixed up pretty trivial conflicts in drivers/block/virtio_blk.c and
drivers/scsi/scsi_error.c as per Jens.
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (96 commits)
no need for list_for_each_entry_safe()/resetting with superblock list
Fix sget() race with failing mount
vfs: don't hold s_umount over close_bdev_exclusive() call
sysv: do not mark superblock dirty on remount
sysv: do not mark superblock dirty on mount
btrfs: remove junk sb_dirt change
BFS: clean up the superblock usage
AFFS: wait for sb synchronization when needed
AFFS: clean up dirty flag usage
cifs: truncate fallout
mbcache: fix shrinker function return value
mbcache: Remove unused features
add f_flags to struct statfs(64)
pass a struct path to vfs_statfs
update VFS documentation for method changes.
All filesystems that need invalidate_inode_buffers() are doing that explicitly
convert remaining ->clear_inode() to ->evict_inode()
Make ->drop_inode() just return whether inode needs to be dropped
fs/inode.c:clear_inode() is gone
fs/inode.c:evict() doesn't care about delete vs. non-delete paths now
Fix up trivial conflicts in fs/nilfs2/super.c
WB_SYNC_NONE writeback is done in rounds of 1024 pages so that we don't
write out some huge inode for too long while starving writeout of other
inodes. To avoid livelocks, we record time we started writeback in
wbc->wb_start and do not write out inodes which were dirtied after this
time. But currently, writeback_inodes_wb() resets wb_start each time it
is called thus effectively invalidating this logic and making any
WB_SYNC_NONE writeback prone to livelocks.
This patch makes sure wb_start is set only once when we start writeback.
Reviewed-by: Wu Fengguang <fengguang.wu@intel.com>
add I_CLEAR instead of replacing I_FREEING with it. I_CLEAR is
equivalent to I_FREEING for almost all code looking at either;
it's there to keep track of having called clear_inode() exactly
once per inode lifetime, at some point after having set I_FREEING.
I_CLEAR and I_FREEING never get set at the same time with the
current code, so we can switch to setting i_flags to I_FREEING | I_CLEAR
instead of I_CLEAR without loss of information. As the result of
such change, checks become simpler and the amount of code that needs
to know about I_CLEAR shrinks a lot.
Whe the first inode for a bdi is marked dirty, we wake up the bdi thread which
should take care of the periodic background write-out. However, the write-out
will actually start only 'dirty_writeback_interval' centisecs later, so we can
delay the wake-up.
This change was requested by Nick Piggin who pointed out that if we delay the
wake-up, we weed out 2 unnecessary contex switches, which matters because
'__mark_inode_dirty()' is a hot-path function.
This patch introduces a new function - 'bdi_wakeup_thread_delayed()', which
sets up a timer to wake-up the bdi thread and returns. So the wake-up is
delayed.
We also delete the timer in bdi threads just before writing-back. And
synchronously delete it when unregistering bdi. At the unregister point the bdi
does not have any users, so no one can arm it again.
Since now we take 'bdi->wb_lock' in the timer, which can execute in softirq
context, we have to use 'spin_lock_bh()' for 'bdi->wb_lock'. This patch makes
this change as well.
This patch also moves the 'bdi_wb_init()' function down in the file to avoid
forward-declaration of 'bdi_wakeup_thread_delayed()'.
Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
Finally, we can get rid of unnecessary wake-ups in bdi threads, which are very
bad for battery-driven devices.
There are two types of activities bdi threads do:
1. process bdi works from the 'bdi->work_list'
2. periodic write-back
So there are 2 sources of wake-up events for bdi threads:
1. 'bdi_queue_work()' - submits bdi works
2. '__mark_inode_dirty()' - adds dirty I/O to bdi's
The former already has bdi wake-up code. The latter does not, and this patch
adds it.
'__mark_inode_dirty()' is hot-path function, but this patch adds another
'spin_lock(&bdi->wb_lock)' there. However, it is taken only in rare cases when
the bdi has no dirty inodes. So adding this spinlock should be fine and should
not affect performance.
This patch makes sure bdi threads and the forker thread do not wake-up if there
is nothing to do. The forker thread will nevertheless wake up at least every
5 min. to check whether it has to kill a bdi thread. This can also be optimized,
but is not worth it.
This patch also tidies up the warning about unregistered bid, and turns it from
an ugly crocodile to a simple 'WARN()' statement.
Currently, bdi threads can decide to exit if there were no useful activities
for 5 minutes. However, this causes nasty races: we can easily oops in the
'bdi_queue_work()' if the bdi thread decides to exit while we are waking it up.
And even if we do not oops, but the bdi tread exits immediately after we wake
it up, we'd lose the wake-up event and have an unnecessary delay (up to 5 secs)
in the bdi work processing.
This patch makes the forker thread to be the central place which not only
creates bdi threads, but also kills them if they were inactive long enough.
This better design-wise.
Another reason why this change was done is to prepare for the further changes
which will prevent the bdi threads from waking up every 5 sec and wasting
power. Indeed, when the task does not wake up periodically anymore, it won't be
able to exit either.
This patch also moves the the 'wake_up_bit()' call from the bdi thread to the
forker thread as well. So now the forker thread sets the BDI_pending bit, then
forks the task or kills it, then clears the bit and wakes up the waiting
process.
The only process which may wain on the bit is 'bdi_wb_shutdown()'. This
function was changed as well - now it first removes the bdi from the
'bdi_list', then waits on the 'BDI_pending' bit. Once it wakes up, it is
guaranteed that the forker thread won't race with it, because the bdi is not
visible. Note, the forker thread sets the 'BDI_pending' bit under the
'bdi->wb_lock' which is essential for proper serialization.
And additionally, when we change 'bdi->wb.task', we now take the
'bdi->work_lock', to make sure that we do not lose wake-ups which we otherwise
would when raced with, say, 'bdi_queue_work()'.
Currently bdi threads use local variable 'last_active' which stores last time
when the bdi thread did some useful work. Move this local variable to 'struct
bdi_writeback'. This is just a preparation for the further patches which will
make the forker thread decide when bdi threads should be killed.
The forker thread removes bdis from 'bdi_list' before forking the bdi thread.
But this is wrong for at least 2 reasons.
Reason #1: if we temporary remove a bdi from the list, we may miss works which
would otherwise be given to us.
Reason #2: this is racy; indeed, 'bdi_wb_shutdown()' expects that bdis are
always in the 'bdi_list' (see 'bdi_remove_from_list()'), and when
it races with the forker thread, it can shut down the bdi thread
at the same time as the forker creates it.
This patch makes sure the forker thread never removes bdis from 'bdi_list'
(which was suggested by Christoph Hellwig).
In order to make sure that we do not race with 'bdi_wb_shutdown()', we have to
hold the 'bdi_lock' while walking the 'bdi_list' and setting the 'BDI_pending'
flag.
NOTE! The error path is interesting. Currently, when we fail to create a bdi
thread, we move the bdi to the tail of 'bdi_list'. But if we never remove the
bdi from the list, we cannot move it to the tail either, because then we can
mess up the RCU readers which walk the list. And also, we'll have the race
described above in "Reason #2".
But I not think that adding to the tail is any important so I just do not do
that.
Currently, bdi threads ('bdi_writeback_thread()') can lose wake-ups. For
example, if 'bdi_queue_work()' is executed after the bdi thread have had
finished 'wb_do_writeback()' but before it called
'schedule_timeout_interruptible()'.
To fix this issue, we have to check whether we have works to process after we
have changed the task state to 'TASK_INTERRUPTIBLE'.
This patch also clean-ups handling of the cases when 'dirty_writeback_interval'
is zero or non-zero.
Additionally, this patch also removes unneeded 'list_empty_careful()' call.
The write-back code mixes words "thread" and "task" for the same things. This
is not a big deal, but still an inconsistency.
hch: a convention I tend to use and I've seen in various places
is to always use _task for the storage of the task_struct pointer,
and thread everywhere else. This especially helps with having
foo_thread for the actual thread and foo_task for a global
variable keeping the task_struct pointer
This patch renames:
* 'bdi_add_default_flusher_task()' -> 'bdi_add_default_flusher_thread()'
* 'bdi_forker_task()' -> 'bdi_forker_thread()'
because bdi threads are 'bdi_writeback_thread()', so these names are more
consistent.
This patch also amends commentaries and makes them refer the forker and bdi
threads as "thread", not "task".
Also, while on it, make 'bdi_add_default_flusher_thread()' declaration use
'static void' instead of 'void static' and make checkpatch.pl happy.
83ba7b07 cleans up the writeback.
So we don't use wb any more in get_next_work_item.
Let's remove unnecessary argument.
CC: Christoph Hellwig <hch@lst.de>
Signed-off-by: Minchan Kim <minchan.kim@gmail.com>
Tracing high level background writeback events is good, but it doesn't
give the entire picture. Add visibility into write throttling to catch IO
dispatched by foreground throttling of processing dirtying lots of pages.
Signed-off-by: Dave Chinner <dchinner@redhat.com>
Trace queue/sched/exec parts of the writeback loop. This provides
insight into when and why flusher threads are scheduled to run. e.g
a sync invocation leaves traces like:
sync-[...]: writeback_queue: bdi 8:0: sb_dev 8:1 nr_pages=7712 sync_mode=0 kupdate=0 range_cyclic=0 background=0
flush-8:0-[...]: writeback_exec: bdi 8:0: sb_dev 8:1 nr_pages=7712 sync_mode=0 kupdate=0 range_cyclic=0 background=0
This also lays the foundation for adding more writeback tracing to
provide deeper insight into the whole writeback path.
The original tracing code is from Jens Axboe, though this version is
a rewrite as a result of the code being traced changing
significantly.
Move all code for the writeback thread into fs/fs-writeback.c instead of
splitting it over two functions in two files.
The wb_list member of struct backing_device_info always has exactly one
element. Just use the direct bdi->wb pointer instead and simplify some
code.
Also remove bdi_task_init which is now trivial to prepare for the next
patch.
First remove items from work_list as soon as we start working on them. This
means we don't have to track any pending or visited state and can get
rid of all the RCU magic freeing the work items - we can simply free
them once the operation has finished. Second use a real completion for
tracking synchronous requests - if the caller sets the completion pointer
we complete it, otherwise use it as a boolean indicator that we can free
the work item directly. Third unify struct wb_writeback_args and struct
bdi_work into a single data structure, wb_writeback_work. Previous we
set all parameters into a struct wb_writeback_args, copied it into
struct bdi_work, copied it again on the stack to use it there. Instead
of just allocate one structure dynamically or on the stack and use it
all the way through the stack.
The case where we have a superblock doesn't require a loop here as we scan
over all inodes in writeback_sb_inodes. Split it out into a separate helper
to make the code simpler. This also allows to get rid of the sb member in
struct writeback_control, which was rather out of place there.
Also update the comments in writeback_sb_inodes that explain the handling
of inodes from wrong superblocks.
This was just an odd wrapper around writeback_inodes_wb. Removing this
also allows to get rid of the bdi member of struct writeback_control
Fix kernel-doc to match the function's changed args.
Warning(fs/fs-writeback.c:190): No description found for parameter 'args'
Warning(fs/fs-writeback.c:190): Excess function parameter 'sb' description in 'bdi_queue_work_onstack'
We need to check for s_instances to make sure we don't bother working
against a filesystem that is beeing unmounted, and we need to call
put_super to make sure a superblock is freed when we race against
umount. Also no need to keep sb_lock after we got a reference on it.
In "writeback: fix writeback_inodes_wb from writeback_inodes_sb" I
accidentally removed the requeue_io if we need to skip a superblock
because we can't pin it. Add it back, otherwise we're getting spurious
lockups after multiple xfstests runs.
bdi_start_writeback now never gets a superblock passed, so we can just remove
that case. And to further untangle the code and flatten the call stack
split it into two trivial helpers for it's two callers.
bdi_writeback_all only has one caller, so fold it to simplify the code and
flatten the call stack.
When we call writeback_inodes_wb from writeback_inodes_sb we always have
s_umount held, which currently makes the whole operation a no-op.
But if we are called to write out inodes for a specific superblock we always
have s_umount held, so replace the incorrect logic checking for WB_SYNC_ALL
which only worked by coincidence with the proper check for an explicit
superblock argument.
Make sure that not only sync_filesystem but all callers of writeback_inodes_sb
have the superblock protected against remount. As-is this disables all
functionality for these callers, but the next patch relies on this locking to
fix writeback_inodes_sb for sync_filesystem.
If we want to rely on s_umount in the caller we need to wait for completion
of the I/O submission before returning to the caller. Refactor
bdi_sync_writeback into a bdi_queue_work_onstack helper and use it for this
case.
The code dealing with bdi_work->state and completion of a bdi_work is a
major mess currently. This patch makes sure we directly use one set of
flags to deal with it, and use it consistently, which means:
- always notify about completion from the rcu callback. We only ever
wait for it from on-stack callers, so this simplification does not
even cause a theoretical slowdown currently. It also makes sure we
don't miss out on the notification if we ever add other callers to
wait for it.
- make earlier completion notification depending on the on-stack
allocation, not the sync mode. If we introduce new callers that
want to do WB_SYNC_NONE writeback from on-stack callers this will
be nessecary.
Also rename bdi_wait_on_work_clear to bdi_wait_on_work_done and inline
a few small functions into their only caller to make the code
understandable.
fs/pipe.c
This reverts commit e913fc825dc685a444cb4c1d0f9d32f372f59861.
We are investigating a hang associated with the WB_SYNC_NONE changes,
so revert them for now.
fs/fs-writeback.c
mm/page-writeback.c
This reverts commit 7c8a3554c683f512dbcee26faedb42e4c05f12fa.
When wb_writeback() hasn't written anything it will re-acquire the inode
lock before calling inode_wait_for_writeback.
This change tests the sync bit first so that is doesn't need to drop &
re-acquire the lock if the inode became available while wb_writeback() was
waiting to get the lock.
Signed-off-by: Richard Kennedy <richard@rsk.demon.co.uk>
Cc: Jens Axboe <jens.axboe@oracle.com>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (69 commits)
fix handling of offsets in cris eeprom.c, get rid of fake on-stack files
get rid of home-grown mutex in cris eeprom.c
switch ecryptfs_write() to struct inode *, kill on-stack fake files
switch ecryptfs_get_locked_page() to struct inode *
simplify access to ecryptfs inodes in ->readpage() and friends
AFS: Don't put struct file on the stack
Ban ecryptfs over ecryptfs
logfs: replace inode uid,gid,mode initialization with helper function
ufs: replace inode uid,gid,mode initialization with helper function
udf: replace inode uid,gid,mode init with helper
ubifs: replace inode uid,gid,mode initialization with helper function
sysv: replace inode uid,gid,mode initialization with helper function
reiserfs: replace inode uid,gid,mode initialization with helper function
ramfs: replace inode uid,gid,mode initialization with helper function
omfs: replace inode uid,gid,mode initialization with helper function
bfs: replace inode uid,gid,mode initialization with helper function
ocfs2: replace inode uid,gid,mode initialization with helper function
nilfs2: replace inode uid,gid,mode initialization with helper function
minix: replace inode uid,gid,mode init with helper
ext4: replace inode uid,gid,mode init with helper
Trivial conflict in fs/fs-writeback.c (mark bitfields unsigned)
This fixes sparse noise:
error: dubious one-bit signed bitfield
Calling schedule without setting the task state to non-running will
return immediately, so ensure that we set it properly and check our
sleep conditions after doing so.
This is a fixup for commit 69b62d01.
Even if the writeout itself isn't a data integrity operation, we need
to ensure that the caller doesn't drop the sb umount sem before we
have actually done the writeback.
This is a fixup for commit e913fc82.
Filesystems with delalloc support may dirty inode during writepages.
As result inode will have dirty metadata flags even after write_inode.
In fact we have two dedicated functions for proper data and metadata
writeback. It is reasonable to separate flags updates in two stages.
https://bugzilla.kernel.org/show_bug.cgi?id=15906
Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org>
When umount calls sync_filesystem(), we first do a WB_SYNC_NONE
writeback to kick off writeback of pending dirty inodes, then follow
that up with a WB_SYNC_ALL to wait for it. Since umount already holds
the sb s_umount mutex, WB_SYNC_NONE ends up doing nothing and all
writeback happens as WB_SYNC_ALL. This can greatly slow down umount,
since WB_SYNC_ALL writeback is a data integrity operation and thus
a bigger hammer than simple WB_SYNC_NONE. For barrier aware file systems
it's a lot slower.
Prior to 2.6.32, setting /proc/sys/vm/dirty_writeback_centisecs disabled
periodic dirty writeback from kupdate. This got broken and now causes
excessive sys CPU usage if set to zero, as we'll keep beating on
schedule().
Reported-by: Justin Maggard <jmaggard10@gmail.com>
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: (34 commits)
cfq-iosched: Fix the incorrect timeslice accounting with forced_dispatch
loop: Update mtime when writing using aops
block: expose the statistics in blkio.time and blkio.sectors for the root cgroup
backing-dev: Handle class_create() failure
Block: Fix block/elevator.c elevator_get() off-by-one error
drbd: lc_element_by_index() never returns NULL
cciss: unlock on error path
cfq-iosched: Do not merge queues of BE and IDLE classes
cfq-iosched: Add additional blktrace log messages in CFQ for easier debugging
i2o: Remove the dangerous kobj_to_i2o_device macro
block: remove 16 bytes of padding from struct request on 64bits
cfq-iosched: fix a kbuild regression
block: make CONFIG_BLK_CGROUP visible
Remove GENHD_FL_DRIVERFS
block: Export max number of segments and max segment size in sysfs
block: Finalize conversion of block limits functions
block: Fix overrun in lcm() and move it to lib
vfs: improve writeback_inodes_wb()
paride: fix off-by-one test
drbd: fix al-to-on-disk-bitmap for 4k logical_block_size
