Signed-off-by: San Mehat <san@android.com>
This fixes a soft lockup on conditions
a) the flusher is working on a work by __bdi_start_writeback(), while
b) someone else calls writeback_inodes_sb*() or sync_inodes_sb(), which
grab sb->s_umount and enqueue a new work for the flusher to execute
The s_umount grabbed by (b) will fail the grab_super_passive() in (a).
Then if the inode is requeued, wb_writeback() will busy retry on it.
As a result, wb_writeback() loops for ever without releasing
wb->list_lock, which further blocks other tasks.
Fix the busy loop by redirtying the inode. This may undesirably delay
the writeback of the inode, however most likely it will be picked up
soon by the queued work by writeback_inodes_sb*(), sync_inodes_sb() or
even writeback_inodes_wb().
bug url: http://www.spinics.net/lists/linux-fsdevel/msg47292.html
Reported-by: Christoph Hellwig <hch@infradead.org>
Tested-by: Christoph Hellwig <hch@infradead.org>
Signed-off-by: Wu Fengguang <fengguang.wu@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/wfg/writeback
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/wfg/writeback: (27 commits)
mm: properly reflect task dirty limits in dirty_exceeded logic
writeback: don't busy retry writeback on new/freeing inodes
writeback: scale IO chunk size up to half device bandwidth
writeback: trace global_dirty_state
writeback: introduce max-pause and pass-good dirty limits
writeback: introduce smoothed global dirty limit
writeback: consolidate variable names in balance_dirty_pages()
writeback: show bdi write bandwidth in debugfs
writeback: bdi write bandwidth estimation
writeback: account per-bdi accumulated written pages
writeback: make writeback_control.nr_to_write straight
writeback: skip tmpfs early in balance_dirty_pages_ratelimited_nr()
writeback: trace event writeback_queue_io
writeback: trace event writeback_single_inode
writeback: remove .nonblocking and .encountered_congestion
writeback: remove writeback_control.more_io
writeback: skip balance_dirty_pages() for in-memory fs
writeback: add bdi_dirty_limit() kernel-doc
writeback: avoid extra sync work at enqueue time
writeback: elevate queue_io() into wb_writeback()
Fix up trivial conflicts in fs/fs-writeback.c and mm/filemap.c
Fix a system hang bug introduced by commit b7a2441f9966 ("writeback:
remove writeback_control.more_io") and e8dfc3058 ("writeback: elevate
queue_io() into wb_writeback()") easily reproducible with high memory
pressure and lots of file creation/deletions, for example, a kernel
build in limited memory.
It hangs when some inode is in the I_NEW, I_FREEING or I_WILL_FREE
state, the flusher will get stuck busy retrying that inode, never
releasing wb->list_lock. The lock in turn blocks all kinds of other
tasks when they are trying to grab it.
As put by Jan, it's a safe change regarding data integrity. I_FREEING or
I_WILL_FREE inodes are written back by iput_final() and it is reclaim
code that is responsible for eventually removing them. So writeback code
can safely ignore them. I_NEW inodes should move out of this state when
they are fully set up and in the writeback round following that, we will
consider them for writeback. So the change makes sense.
CC: Jan Kara <jack@suse.cz>
Reported-by: Hugh Dickins <hughd@google.com>
Tested-by: Hugh Dickins <hughd@google.com>
The per-sb shrinker has the same requirement as the writeback
threads of ensuring that the superblock is usable and pinned for the
time it takes to run the work. Both need to take a passive reference
to the sb, take a read lock on the s_umount lock and then only
continue if an unmount is not in progress.
pin_sb_for_writeback() does this exactly, so move it to fs/super.c
and rename it to grab_super_passive() and exporting it via
fs/internal.h for all the VFS code to be able to use.
Signed-off-by: Dave Chinner <dchinner@redhat.com>
Originally, MAX_WRITEBACK_PAGES was hard-coded to 1024 because of a
concern of not holding I_SYNC for too long. (At least, that was the
comment previously.) This doesn't make sense now because the only
time we wait for I_SYNC is if we are calling sync or fsync, and in
that case we need to write out all of the data anyway. Previously
there may have been other code paths that waited on I_SYNC, but not
any more. -- Theodore Ts'o
So remove the MAX_WRITEBACK_PAGES constraint. The writeback pages
will adapt to as large as the storage device can write within 500ms.
XFS is observed to do IO completions in a batch, and the batch size is
equal to the write chunk size. To avoid dirty pages to suddenly drop
out of balance_dirty_pages()'s dirty control scope and create large
fluctuations, the chunk size is also limited to half the control scope.
The balance_dirty_pages() control scrope is
[(background_thresh + dirty_thresh) / 2, dirty_thresh]
which is by default [15%, 20%] of global dirty pages, whose range size
is dirty_thresh / DIRTY_FULL_SCOPE.
The adpative write chunk size will be rounded to the nearest 4MB
boundary.
http://bugzilla.kernel.org/show_bug.cgi?id=13930
CC: Theodore Ts'o <tytso@mit.edu>
CC: Dave Chinner <david@fromorbit.com>
CC: Chris Mason <chris.mason@oracle.com>
CC: Peter Zijlstra <a.p.zijlstra@chello.nl>
The start of a heavy weight application (ie. KVM) may instantly knock
down determine_dirtyable_memory() if the swap is not enabled or full.
global_dirty_limits() and bdi_dirty_limit() will in turn get global/bdi
dirty thresholds that are _much_ lower than the global/bdi dirty pages.
balance_dirty_pages() will then heavily throttle all dirtiers including
the light ones, until the dirty pages drop below the new dirty thresholds.
During this _deep_ dirty-exceeded state, the system may appear rather
unresponsive to the users.
About "deep" dirty-exceeded: task_dirty_limit() assigns 1/8 lower dirty
threshold to heavy dirtiers than light ones, and the dirty pages will
be throttled around the heavy dirtiers' dirty threshold and reasonably
below the light dirtiers' dirty threshold. In this state, only the heavy
dirtiers will be throttled and the dirty pages are carefully controlled
to not exceed the light dirtiers' dirty threshold. However if the
threshold itself suddenly drops below the number of dirty pages, the
light dirtiers will get heavily throttled.
So introduce global_dirty_limit for tracking the global dirty threshold
with policies
- follow downwards slowly
- follow up in one shot
global_dirty_limit can effectively mask out the impact of sudden drop of
dirtyable memory. It will be used in the next patch for two new type of
dirty limits. Note that the new dirty limits are not going to avoid
throttling the light dirtiers, but could limit their sleep time to 200ms.
The estimation value will start from 100MB/s and adapt to the real
bandwidth in seconds.
It tries to update the bandwidth only when disk is fully utilized.
Any inactive period of more than one second will be skipped.
The estimated bandwidth will be reflecting how fast the device can
writeout when _fully utilized_, and won't drop to 0 when it goes idle.
The value will remain constant at disk idle time. At busy write time, if
not considering fluctuations, it will also remain high unless be knocked
down by possible concurrent reads that compete for the disk time and
bandwidth with async writes.
The estimation is not done purely in the flusher because there is no
guarantee for write_cache_pages() to return timely to update bandwidth.
The bdi->avg_write_bandwidth smoothing is very effective for filtering
out sudden spikes, however may be a little biased in long term.
The overheads are low because the bdi bandwidth update only occurs at
200ms intervals.
The 200ms update interval is suitable, because it's not possible to get
the real bandwidth for the instance at all, due to large fluctuations.
The NFS commits can be as large as seconds worth of data. One XFS
completion may be as large as half second worth of data if we are going
to increase the write chunk to half second worth of data. In ext4,
fluctuations with time period of around 5 seconds is observed. And there
is another pattern of irregular periods of up to 20 seconds on SSD tests.
That's why we are not only doing the estimation at 200ms intervals, but
also averaging them over a period of 3 seconds and then go further to do
another level of smoothing in avg_write_bandwidth.
CC: Li Shaohua <shaohua.li@intel.com>
Pass struct wb_writeback_work all the way down to writeback_sb_inodes(),
and initialize the struct writeback_control there.
struct writeback_control is basically designed to control writeback of a
single file, but we keep abuse it for writing multiple files in
writeback_sb_inodes() and its callers.
It immediately clean things up, e.g. suddenly wbc.nr_to_write vs
work->nr_pages starts to make sense, and instead of saving and restoring
pages_skipped in writeback_sb_inodes it can always start with a clean
zero value.
It also makes a neat IO pattern change: large dirty files are now
written in the full 4MB writeback chunk size, rather than whatever
remained quota in wbc->nr_to_write.
Acked-by: Jan Kara <jack@suse.cz>
Proposed-by: Christoph Hellwig <hch@infradead.org>
Note that it adds a little overheads to account the moved/enqueued
inodes from b_dirty to b_io. The "moved" accounting may be later used to
limit the number of inodes that can be moved in one shot, in order to
keep spinlock hold time under control.
It is valuable to know how the dirty inodes are iterated and their IO size.
"writeback_single_inode: bdi 8:0: ino=134246746 state=I_DIRTY_SYNC|I_SYNC age=414 index=0 to_write=1024 wrote=0"
- "state" reflects inode->i_state at the end of writeback_single_inode()
- "index" reflects mapping->writeback_index after the ->writepages() call
- "to_write" is the wbc->nr_to_write at entrance of writeback_single_inode()
- "wrote" is the number of pages actually written
v2: add trace event writeback_single_inode_requeue as proposed by Dave.
When wbc.more_io was first introduced, it indicates whether there are
at least one superblock whose s_more_io contains more IO work. Now with
the per-bdi writeback, it can be replaced with a simple b_more_io test.
Acked-by: Mel Gorman <mel@csn.ul.ie>
Reviewed-by: Minchan Kim <minchan.kim@gmail.com>
This removes writeback_control.wb_start and does more straightforward
sync livelock prevention by setting .older_than_this to prevent extra
inodes from being enqueued in the first place.
Code refactor for more logical code layout.
No behavior change.
- remove the mis-named __writeback_inodes_sb()
- wb_writeback()/writeback_inodes_wb() will decide when to queue_io()
before calling __writeback_inodes_wb()
Split the global inode_wb_list_lock into a per-bdi_writeback list_lock,
as it's currently the most contended lock in the system for metadata
heavy workloads. It won't help for single-filesystem workloads for
which we'll need the I/O-less balance_dirty_pages, but at least we
can dedicate a cpu to spinning on each bdi now for larger systems.
Based on earlier patches from Nick Piggin and Dave Chinner.
It reduces lock contentions to 1/4 in this test case:
10 HDD JBOD, 100 dd on each disk, XFS, 6GB ram
lock_stat version 0.3
class name con-bounces contentions waittime-min waittime-max waittime-total acq-bounces acquisitions holdtime-min holdtime-max holdtime-total
vanilla 2.6.39-rc3:
inode_wb_list_lock: 42590 44433 0.12 147.74 144127.35 252274 886792 0.08 121.34 917211.23
inode_wb_list_lock 2 [<ffffffff81165da5>] bdev_inode_switch_bdi+0x29/0x85
inode_wb_list_lock 34 [<ffffffff8115bd0b>] inode_wb_list_del+0x22/0x49
inode_wb_list_lock 12893 [<ffffffff8115bb53>] __mark_inode_dirty+0x170/0x1d0
inode_wb_list_lock 10702 [<ffffffff8115afef>] writeback_single_inode+0x16d/0x20a
inode_wb_list_lock 19 [<ffffffff8115bd0b>] inode_wb_list_del+0x22/0x49
inode_wb_list_lock 5550 [<ffffffff8115bb53>] __mark_inode_dirty+0x170/0x1d0
inode_wb_list_lock 8511 [<ffffffff8115b4ad>] writeback_sb_inodes+0x10f/0x157
2.6.39-rc3 + patch:
&(&wb->list_lock)->rlock: 11383 11657 0.14 151.69 40429.51 90825 527918 0.11 145.90 556843.37
&(&wb->list_lock)->rlock 10 [<ffffffff8115b189>] inode_wb_list_del+0x5f/0x86
&(&wb->list_lock)->rlock 1493 [<ffffffff8115b1ed>] writeback_inodes_wb+0x3d/0x150
&(&wb->list_lock)->rlock 3652 [<ffffffff8115a8e9>] writeback_sb_inodes+0x123/0x16f
&(&wb->list_lock)->rlock 1412 [<ffffffff8115a38e>] writeback_single_inode+0x17f/0x223
&(&wb->list_lock)->rlock 3 [<ffffffff8110b5af>] bdi_lock_two+0x46/0x4b
&(&wb->list_lock)->rlock 6 [<ffffffff8115b189>] inode_wb_list_del+0x5f/0x86
&(&wb->list_lock)->rlock 2061 [<ffffffff8115af97>] __mark_inode_dirty+0x173/0x1cf
&(&wb->list_lock)->rlock 2629 [<ffffffff8115a8e9>] writeback_sb_inodes+0x123/0x16f
hughd@google.com: fix recursive lock when bdi_lock_two() is called with new the same as old
akpm@linux-foundation.org: cleanup bdev_inode_switch_bdi() comment
There is no point to carry different refill policies between for_kupdate
and other type of works. Use a consistent "refill b_io iff empty" policy
which can guarantee fairness in an easy to understand way.
A b_io refill will setup a _fixed_ work set with all currently eligible
inodes and start a new round of walk through b_io. The "fixed" work set
means no new inodes will be added to the work set during the walk.
Only when a complete walk over b_io is done, new inodes that are
eligible at the time will be enqueued and the walk be started over.
This procedure provides fairness among the inodes because it guarantees
each inode to be synced once and only once at each round. So all inodes
will be free from starvations.
This change relies on wb_writeback() to keep retrying as long as we made
some progress on cleaning some pages and/or inodes. Without that ability,
the old logic on background works relies on aggressively queuing all
eligible inodes into b_io at every time. But that's not a guarantee.
The below test script completes a slightly faster now:
2.6.39-rc3 2.6.39-rc3-dyn-expire+
all elapsed 256.043 252.367
stddev 24.381 12.530
tar elapsed 30.097 28.808
dd elapsed 13.214 11.782
#!/bin/zsh
cp /c/linux-2.6.38.3.tar.bz2 /dev/shm/
umount /dev/sda7
mkfs.xfs -f /dev/sda7
mount /dev/sda7 /fs
echo 3 > /proc/sys/vm/drop_caches
tic=$(cat /proc/uptime|cut -d' ' -f2)
cd /fs
time tar jxf /dev/shm/linux-2.6.38.3.tar.bz2 &
time dd if=/dev/zero of=/fs/zero bs=1M count=1000 &
wait
sync
tac=$(cat /proc/uptime|cut -d' ' -f2)
echo elapsed: $((tac - tic))
It maintains roughly the same small vs. large file writeout shares, and
offers large files better chances to be written in nice 4M chunks.
Analyzes from Dave Chinner in great details:
Let's say we have lots of inodes with 100 dirty pages being created,
and one large writeback going on. We expire 8 new inodes for every
1024 pages we write back.
With the old code, we do:
b_more_io (large inode) -> b_io (1l)
8 newly expired inodes -> b_io (1l, 8s)
writeback large inode 1024 pages -> b_more_io
b_more_io (large inode) -> b_io (8s, 1l)
8 newly expired inodes -> b_io (8s, 1l, 8s)
writeback 8 small inodes 800 pages
1 large inode 224 pages -> b_more_io
Your new code:
(b_io == 8s)
b_io empty: (1800 pages written)
14 newly expired inodes -> b_io (1l, 14s)
(b_io == 14s)
writeback 10 small inodes 1000 pages
1 small inode 24 pages -> b_more_io (1l, 1s(24))
writeback 5 small inodes 500 pages
b_io empty: (2548 pages written)
b_more_io (large inode) -> b_io (1l, 1s(24))
20 newly expired inodes -> b_io (1l, 1s(24), 20s)
Rough progression of pages written at b_io refill:
Old code:
total large file % of writeback
1024 224 21.9% (fixed)
New code:
1800 1024 ~55%
2550 1024 ~40%
3050 1024 ~33%
3500 1024 ~29%
3950 1024 ~26%
4250 1024 ~24%
4500 1024 ~22.7%
4700 1024 ~21.7%
4800 1024 ~21.3%
4800 1024 ~21.3%
(pretty much steady state from here)
Ok, so the steady state is reached with a similar percentage of
writeback to the large file as the existing code. Ok, that's good,
but providing some evidence that is doesn't change the shared of
writeback to the large should be in the commit message ;)
The other advantage to this is that we always write 1024 page chunks
to the large file, rather than smaller "whatever remains" chunks.
Dynamically compute the dirty expire timestamp at queue_io() time.
writeback_control.older_than_this used to be determined at entrance to
the kupdate writeback work. This _static_ timestamp may go stale if the
kupdate work runs on and on. The flusher may then stuck with some old
busy inodes, never considering newly expired inodes thereafter.
This has two possible problems:
- It is unfair for a large dirty inode to delay (for a long time) the
writeback of small dirty inodes.
- As time goes by, the large and busy dirty inode may contain only
_freshly_ dirtied pages. Ignoring newly expired dirty inodes risks
delaying the expired dirty pages to the end of LRU lists, triggering
the evil pageout(). Nevertheless this patch merely addresses part
of the problem.
v2: keep policy changes inside wb_writeback() and keep the
wbc.older_than_this visibility as suggested by Dave.
Signed-off-by: Itaru Kitayama <kitayama@cl.bb4u.ne.jp>
writeback_inodes_wb()/__writeback_inodes_sb() are not aggressive in that
they only populate possibly a subset of eligible inodes into b_io at
entrance time. When the queued set of inodes are all synced, they just
return, possibly with all queued inode pages written but still
wbc.nr_to_write > 0.
For kupdate and background writeback, there may be more eligible inodes
sitting in b_dirty when the current set of b_io inodes are completed. So
it is necessary to try another round of writeback as long as we made some
progress in this round. When there are no more eligible inodes, no more
inodes will be enqueued in queue_io(), hence nothing could/will be
synced and we may safely bail.
For example, imagine 100 inodes
i0, i1, i2, ..., i90, i91, i99
At queue_io() time, i90-i99 happen to be expired and moved to s_io for
IO. When finished successfully, if their total size is less than
MAX_WRITEBACK_PAGES, nr_to_write will be > 0. Then wb_writeback() will
quit the background work (w/o this patch) while it's still over
background threshold. This will be a fairly normal/frequent case I guess.
Now that we do tagged sync and update inode->dirtied_when after the sync,
this change won't livelock sync(1). I actually tried to write 1 page
per 1ms with this command
write-and-fsync -n10000 -S 1000 -c 4096 /fs/test
and do sync(1) at the same time. The sync completes quickly on ext4,
xfs, btrfs.
The flusher works on dirty inodes in batches, and may quit prematurely
if the batch of inodes happen to be metadata-only dirtied: in this case
wbc->nr_to_write won't be decreased at all, which stands for "no pages
written" but also mis-interpreted as "no progress".
So introduce writeback_control.inodes_written to count the inodes get
cleaned from VFS POV. A non-zero value means there are some progress on
writeback, in which case more writeback can be tried.
Explicitly update .dirtied_when on synced inodes, so that they are no
longer considered for writeback in the next round.
It can prevent both of the following livelock schemes:
- while true; do echo data >> f; done
- while true; do touch f; done (in theory)
The exact livelock condition is, during sync(1):
(1) no new inodes are dirtied
(2) an inode being actively dirtied
On (2), the inode will be tagged and synced with .nr_to_write=LONG_MAX.
When finished, it will be redirty_tail()ed because it's still dirty
and (.nr_to_write > 0). redirty_tail() won't update its ->dirtied_when
on condition (1). The sync work will then revisit it on the next
queue_io() and find it eligible again because its old ->dirtied_when
predates the sync work start time.
We'll do more aggressive "keep writeback as long as we wrote something"
logic in wb_writeback(). The "use LONG_MAX .nr_to_write" trick in commit
b9543dac5bbc ("writeback: avoid livelocking WB_SYNC_ALL writeback") will
no longer be enough to stop sync livelock.
sync(2) is performed in two stages: the WB_SYNC_NONE sync and the
WB_SYNC_ALL sync. Identify the first stage with .tagged_writepages and
do livelock prevention for it, too.
Jan's commit f446daaea9 ("mm: implement writeback livelock avoidance
using page tagging") is a partial fix in that it only fixed the
WB_SYNC_ALL phase livelock.
Although ext4 is tested to no longer livelock with commit f446daaea9,
it may due to some "redirty_tail() after pages_skipped" effect which
is by no means a guarantee for _all_ the file systems.
Note that writeback_inodes_sb() is called by not only sync(), they are
treated the same because the other callers also need livelock prevention.
Impact: It changes the order in which pages/inodes are synced to disk.
Now in the WB_SYNC_NONE stage, it won't proceed to write the next inode
until finished with the current inode.
Tell the filesystem if we just updated timestamp (I_DIRTY_SYNC) or
anything else, so that the filesystem can track internally if it
needs to push out a transaction for fdatasync or not.
This is just the prototype change with no user for it yet. I plan
to push large XFS changes for the next merge window, and getting
this trivial infrastructure in this window would help a lot to avoid
tree interdependencies.
Also remove incorrect comments that ->dirty_inode can't block. That
has been changed a long time ago, and many implementations rely on it.
First thing we do in writeback_single_inode() is take the i_lock and
the last thing we do is drop it. A caller already holds the i_lock,
so pull the i_lock out of writeback_single_inode() to reduce the
round trips on this lock during inode writeback.
Protect the inode writeback list with a new global lock
inode_wb_list_lock and use it to protect the list manipulations and
traversals. This lock replaces the inode_lock as the inodes on the
list can be validity checked while holding the inode->i_lock and
hence the inode_lock is no longer needed to protect the list.
Protect the per-sb inode list with a new global lock
inode_sb_list_lock and use it to protect the list manipulations and
Protect inode state transitions and validity checks with the
inode->i_lock. This enables us to make inode state transitions
independently of the inode_lock and is the first step to peeling
away the inode_lock from the code.
This requires that __iget() is done atomically with i_state checks
during list traversals so that we don't race with another thread
marking the inode I_FREEING between the state check and grabbing the
reference.
Also remove the unlock_new_inode() memory barrier optimisation
required to avoid taking the inode_lock when clearing I_NEW.
Simplify the code by simply taking the inode->i_lock around the
state change and wakeup. Because the wakeup is no longer tricky,
remove the wake_up_inode() function and open code the wakeup where
necessary.
The sync_inodes_sb() function does not have a return value. Remove the
outdated documentation comment.
Signed-off-by: Stefan Hajnoczi <stefanha@linux.vnet.ibm.com>
Use correct function name, remove incorrect apostrophe
When wb_writeback() is called in WB_SYNC_ALL mode, work->nr_to_write is
usually set to LONG_MAX. The logic in wb_writeback() then calls
__writeback_inodes_sb() with nr_to_write == MAX_WRITEBACK_PAGES and we
easily end up with non-positive nr_to_write after the function returns, if
the inode has more than MAX_WRITEBACK_PAGES dirty pages at the moment.
When nr_to_write is <= 0 wb_writeback() decides we need another round of
writeback but this is wrong in some cases! For example when a single
large file is continuously dirtied, we would never finish syncing it
because each pass would be able to write MAX_WRITEBACK_PAGES and inode
dirty timestamp never gets updated (as inode is never completely clean).
Thus __writeback_inodes_sb() would write the redirtied inode again and
again.
Fix the issue by setting nr_to_write to LONG_MAX in WB_SYNC_ALL mode. We
do not need nr_to_write in WB_SYNC_ALL mode anyway since
write_cache_pages() does livelock avoidance using page tagging in
WB_SYNC_ALL mode.
This makes wb_writeback() call __writeback_inodes_sb() only once on
WB_SYNC_ALL. The latter function won't livelock because it works on
- a finite set of files by doing queue_io() once at the beginning
- a finite set of pages by PAGECACHE_TAG_TOWRITE page tagging
After this patch, program from http://lkml.org/lkml/2010/10/24/154 is no
longer able to stall sync forever.
[fengguang.wu@intel.com: fix locking comment]
Cc: Jan Engelhardt <jengelh@medozas.de>
Background writeback is easily livelockable in a loop in wb_writeback() by
a process continuously re-dirtying pages (or continuously appending to a
file). This is in fact intended as the target of background writeback is
to write dirty pages it can find as long as we are over
dirty_background_threshold.
But the above behavior gets inconvenient at times because no other work
queued in the flusher thread's queue gets processed. In particular, since
e.g. sync(1) relies on flusher thread to do all the IO for it, sync(1)
can hang forever waiting for flusher thread to do the work.
Generally, when a flusher thread has some work queued, someone submitted
the work to achieve a goal more specific than what background writeback
does. Moreover by working on the specific work, we also reduce amount of
dirty pages which is exactly the target of background writeout. So it
makes sense to give specific work a priority over a generic page cleaning.
Thus we interrupt background writeback if there is some other work to do.
We return to the background writeback after completing all the queued
work.
This may delay the writeback of expired inodes for a while, however the
expired inodes will eventually be flushed to disk as long as the other
works won't livelock.
[fengguang.wu@intel.com: update comment]
This tracks when balance_dirty_pages() tries to wakeup the flusher thread
for background writeback (if it was not started already).
Suggested-by: Christoph Hellwig <hch@infradead.org>
Cc: Jan Kara <jack@suse.cz>
Check whether background writeback is needed after finishing each work.
When bdi flusher thread finishes doing some work check whether any kind of
background writeback needs to be done (either because
dirty_background_ratio is exceeded or because we need to start flushing
old inodes). If so, just do background write back.
This way, bdi_start_background_writeback() just needs to wake up the
flusher thread. It will do background writeback as soon as there is no
other work.
This is a preparatory patch for the next patch which stops background
writeback as soon as there is other work to do.
git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable: (39 commits)
Btrfs: deal with errors from updating the tree log
Btrfs: allow subvol deletion by unprivileged user with -o user_subvol_rm_allowed
Btrfs: make SNAP_DESTROY async
Btrfs: add SNAP_CREATE_ASYNC ioctl
Btrfs: add START_SYNC, WAIT_SYNC ioctls
Btrfs: async transaction commit
Btrfs: fix deadlock in btrfs_commit_transaction
Btrfs: fix lockdep warning on clone ioctl
Btrfs: fix clone ioctl where range is adjacent to extent
Btrfs: fix delalloc checks in clone ioctl
Btrfs: drop unused variable in block_alloc_rsv
Btrfs: cleanup warnings from gcc 4.6 (nonbugs)
Btrfs: Fix variables set but not read (bugs found by gcc 4.6)
Btrfs: Use ERR_CAST helpers
Btrfs: use memdup_user helpers
Btrfs: fix raid code for removing missing drives
Btrfs: Switch the extent buffer rbtree into a radix tree
Btrfs: restructure try_release_extent_buffer()
Btrfs: use the flusher threads for delalloc throttling
Btrfs: tune the chunk allocation to 5% of the FS as metadata
Fix up trivial conflicts in fs/btrfs/super.c and fs/fs-writeback.c, and
remove use of INIT_RCU_HEAD in fs/btrfs/extent_io.c (that init macro was
useless and removed in commit 5e8067adfdba: "rcu head remove init")
The btrfs merge looks like hell, because it changes fs-writeback.c, and
the crazy code has this repeated "estimate number of dirty pages"
counting that involves three different helper functions. And it's done
in two different places.
Just unify that whole calculation as a "get_nr_dirty_pages()" helper
function, and the merge result will look half-way decent.
When btrfs is running low on metadata space, it needs to force delayed
allocation pages to disk. It currently does this with a suboptimal walk
of a private list of inodes with delayed allocation, and it would be
much better if we used the generic flusher threads.
writeback_inodes_sb_if_idle would be ideal, but it waits for the flusher
thread to start IO on all the dirty pages in the FS before it returns.
This adds variants of writeback_inodes_sb* that allow the caller to
control how many pages get sent down.
Signed-off-by: Chris Mason <chris.mason@oracle.com>
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (52 commits)
split invalidate_inodes()
fs: skip I_FREEING inodes in writeback_sb_inodes
fs: fold invalidate_list into invalidate_inodes
fs: do not drop inode_lock in dispose_list
fs: inode split IO and LRU lists
fs: switch bdev inode bdi's correctly
fs: fix buffer invalidation in invalidate_list
fsnotify: use dget_parent
smbfs: use dget_parent
exportfs: use dget_parent
fs: use RCU read side protection in d_validate
fs: clean up dentry lru modification
fs: split __shrink_dcache_sb
fs: improve DCACHE_REFERENCED usage
fs: use percpu counter for nr_dentry and nr_dentry_unused
fs: simplify __d_free
fs: take dcache_lock inside __d_path
fs: do not assign default i_ino in new_inode
fs: introduce a per-cpu last_ino allocator
new helper: ihold()
PF_FLUSHER is only ever set, not tested, remove it.
I had to go back to a 2.6.20 tree to work out why we're adding a
number-of-inodes into a number-of-pages count. Restore the lost comment.
The dirty_ratio was silently limited in global_dirty_limits() to >= 5%.
This is not a user expected behavior. And it's inconsistent with
calc_period_shift(), which uses the plain vm_dirty_ratio value.
Let's remove the internal bound.
At the same time, fix balance_dirty_pages() to work with the
dirty_thresh=0 case. This allows applications to proceed when
dirty+writeback pages are all cleaned.
And ">" fits with the name "exceeded" better than ">=" does. Neil thinks
it is an aesthetic improvement as well as a functional one :)
Proposed-by: Con Kolivas <kernel@kolivas.org>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Reviewed-by: Neil Brown <neilb@suse.de>
Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Cc: Michael Rubin <mrubin@google.com>
Skip I_FREEING inodes just like I_WILL_FREE and I_NEW when walking the
writeback lists. Currenly this can't happen, but once we move from
inode_lock to more fine grained locking we can have an inode that's
still on the writeback lists but has I_FREEING set, and we absolutely
need to skip it here, just like we do for all other inode list walks.
Based on a patch from Dave Chinner.
The use of the same inode list structure (inode->i_list) for two
different list constructs with different lifecycles and purposes
makes it impossible to separate the locking of the different
operations. Therefore, to enable the separation of the locking of
the writeback and reclaim lists, split the inode->i_list into two
separate lists dedicated to their specific tracking functions.
Signed-off-by: Nick Piggin <npiggin@suse.de>
Convert the inode LRU to use lazy updates to reduce lock and
cacheline traffic. We avoid moving inodes around in the LRU list
during iget/iput operations so these frequent operations don't need
to access the LRUs. Instead, we defer the refcount checks to
reclaim-time and use a per-inode state flag, I_REFERENCED, to tell
reclaim that iget has touched the inode in the past. This means that
only reclaim should be touching the LRU with any frequency, hence
significantly reducing lock acquisitions and the amount contention
on LRU updates.
This also removes the inode_in_use list, which means we now only
have one list for tracking the inode LRU status. This makes it much
simpler to split out the LRU list operations under it's own lock.
The number of inodes allocated does not need to be tied to the
addition or removal of an inode to/from a list. If we are not tied
to a list lock, we could update the counters when inodes are
initialised or destroyed, but to do that we need to convert the
counters to be per-cpu (i.e. independent of a lock). This means that
we have the freedom to change the list/locking implementation
without needing to care about the counters.
Based on a patch originally from Eric Dumazet.
[AV: cleaned up a bit, fixed build breakage on weird configs
note: for race-free uses you inode_lock held
Add a new helper to write out the inode using the writeback code,
that is including the correct dirty bit and list manipulation. A few
of filesystems already opencode this, and a lot of others should be
using it instead of using write_inode_now which also writes out the
data.
We currently use struct backing_dev_info for various different purposes.
Originally it was introduced to describe a backing device which includes
an unplug and congestion function and various bits of readahead information
and VM-relevant flags. We're also using for tracking dirty inodes for
writeback.
To make writeback properly find all inodes we need to only access the
per-filesystem backing_device pointed to by the superblock in ->s_bdi
inside the writeback code, and not the instances pointeded to by
inode->i_mapping->backing_dev which can be overriden by special devices
or might not be set at all by some filesystems.
Long term we should split out the writeback-relevant bits of struct
backing_device_info (which includes more than the current bdi_writeback)
and only point to it from the superblock while leaving the traditional
backing device as a separate structure that can be overriden by devices.
The one exception for now is the block device filesystem which really
wants different writeback contexts for it's different (internal) inodes
to handle the writeout more efficiently. For now we do this with
a hack in fs-writeback.c because we're so late in the cycle, but in
the future I plan to replace this with a superblock method that allows
for multiple writeback contexts per filesystem.
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
Inodes of devices such as /dev/zero can get dirty for example via
utime(2) syscall or due to atime update. Backing device of such inodes
(zero_bdi, etc.) is however unable to handle dirty inodes and thus
__mark_inode_dirty complains. In fact, inode should be rather dirtied
against backing device of the filesystem holding it. This is generally a
good rule except for filesystems such as 'bdev' or 'mtd_inodefs'. Inodes
in these pseudofilesystems are referenced from ordinary filesystem
inodes and carry mapping with real data of the device. Thus for these
inodes we have to use inode->i_mapping->backing_dev_info as we did so
far. We distinguish these filesystems by checking whether sb->s_bdi
points to a non-trivial backing device or not.
Example: Assume we have an ext3 filesystem on /dev/sda1 mounted on /.
There's a device inode A described by a path "/dev/sdb" on this
filesystem. This inode will be dirtied against backing device "8:0"
after this patch. bdev filesystem contains block device inode B coupled
with our inode A. When someone modifies a page of /dev/sdb, it's B that
gets dirtied and the dirtying happens against the backing device "8:16".
Thus both inodes get filed to a correct bdi list.
Cc: stable@kernel.org
Setting the task state here may cause us to miss the wake up from
kthread_stop(), so we need to recheck kthread_should_stop() or risk
sleeping forever in the following schedule().
Symptom was an indefinite hang on an NFSv4 mount. (NFSv4 may create
multiple mounts in a temporary namespace while traversing the mount
path, and since the temporary namespace is immediately destroyed, it may
end up destroying a mount very soon after it was created, possibly
making this race more likely.)
INFO: task mount.nfs4:4314 blocked for more than 120 seconds.
"echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
mount.nfs4 D 0000000000000000 2880 4314 4313 0x00000000
ffff88001ed6da28 0000000000000046 ffff88001ed6dfd8 ffff88001ed6dfd8
ffff88001ed6c000 ffff88001ed6c000 ffff88001ed6c000 ffff88001e5003a0
ffff88001ed6dfd8 ffff88001e5003a8 ffff88001ed6c000 ffff88001ed6dfd8
Call Trace:
[<ffffffff8196090d>] schedule_timeout+0x1cd/0x2e0
[<ffffffff8106a31c>] ? mark_held_locks+0x6c/0xa0
[<ffffffff819639a0>] ? _raw_spin_unlock_irq+0x30/0x60
[<ffffffff8106a5fd>] ? trace_hardirqs_on_caller+0x14d/0x190
[<ffffffff819671fe>] ? sub_preempt_count+0xe/0xd0
[<ffffffff8195fc80>] wait_for_common+0x120/0x190
[<ffffffff81033c70>] ? default_wake_function+0x0/0x20
[<ffffffff8195fdcd>] wait_for_completion+0x1d/0x20
[<ffffffff810595fa>] kthread_stop+0x4a/0x150
[<ffffffff81061a60>] ? thaw_process+0x70/0x80
[<ffffffff810cc68a>] bdi_unregister+0x10a/0x1a0
[<ffffffff81229dc9>] nfs_put_super+0x19/0x20
[<ffffffff810ee8c4>] generic_shutdown_super+0x54/0xe0
[<ffffffff810ee9b6>] kill_anon_super+0x16/0x60
[<ffffffff8122d3b9>] nfs4_kill_super+0x39/0x90
[<ffffffff810eda45>] deactivate_locked_super+0x45/0x60
[<ffffffff810edfb9>] deactivate_super+0x49/0x70
[<ffffffff81108294>] mntput_no_expire+0x84/0xe0
[<ffffffff811084ef>] release_mounts+0x9f/0xc0
[<ffffffff81108575>] put_mnt_ns+0x65/0x80
[<ffffffff8122cc56>] nfs_follow_remote_path+0x1e6/0x420
[<ffffffff8122cfbf>] nfs4_try_mount+0x6f/0xd0
[<ffffffff8122d0c2>] nfs4_get_sb+0xa2/0x360
[<ffffffff810edcb8>] vfs_kern_mount+0x88/0x1f0
[<ffffffff810ede92>] do_kern_mount+0x52/0x130
[<ffffffff81963d9a>] ? _lock_kernel+0x6a/0x170
[<ffffffff81108e9e>] do_mount+0x26e/0x7f0
[<ffffffff81106b3a>] ? copy_mount_options+0xea/0x190
[<ffffffff811094b8>] sys_mount+0x98/0xf0
[<ffffffff810024d8>] system_call_fastpath+0x16/0x1b
1 lock held by mount.nfs4/4314:
#0: (&type->s_umount_key#24){+.+...}, at: [<ffffffff810edfb1>] deactivate_super+0x41/0x70
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
Acked-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
Commit 83ba7b071f3 ("writeback: simplify the write back thread queue")
broke writeback_in_progress() as in that commit we started to remove work
items from the list at the moment we start working on them and not at the
moment they are finished. Thus if the flusher thread was doing some work
but there was no other work queued, writeback_in_progress() returned
false. This could in particular cause unnecessary queueing of background
writeback from balance_dirty_pages() or writeout work from
writeback_sb_if_idle().
This patch fixes the problem by introducing a bit in the bdi state which
indicates that the flusher thread is processing some work and uses this
bit for writeback_in_progress() test.
NOTE: Both callsites of writeback_in_progress() (namely,
writeback_inodes_sb_if_idle() and balance_dirty_pages()) would actually
need a different information than what writeback_in_progress() provides.
They would need to know whether *the kind of writeback they are going to
submit* is already queued. But this information isn't that simple to
provide so let's fix writeback_in_progress() for the time being.
Cc: Wu Fengguang <fengguang.wu@intel.com>
Acked-by: Jens Axboe <jaxboe@fusionio.com>
