path: root/fs/fscache/Kconfig
2010-03-08FS-Cache: Remove the EXPERIMENTAL flagChristian Kujau
Remove the EXPERIMENTAL flag from FS-Cache so that Ubuntu can make use of the facility. Signed-off-by: Christian Kujau <lists@nerdbynature.de> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-11-19FS-Cache: Allow the current state of all objects to be dumpedDavid Howells
Allow the current state of all fscache objects to be dumped by doing: cat /proc/fs/fscache/objects By default, all objects and all fields will be shown. This can be restricted by adding a suitable key to one of the caller's keyrings (such as the session keyring): keyctl add user fscache:objlist "<restrictions>" @s The <restrictions> are: K Show hexdump of object key (don't show if not given) A Show hexdump of object aux data (don't show if not given) And paired restrictions: C Show objects that have a cookie c Show objects that don't have a cookie B Show objects that are busy b Show objects that aren't busy W Show objects that have pending writes w Show objects that don't have pending writes R Show objects that have outstanding reads r Show objects that don't have outstanding reads S Show objects that have slow work queued s Show objects that don't have slow work queued If neither side of a restriction pair is given, then both are implied. For example: keyctl add user fscache:objlist KB @s shows objects that are busy, and lists their object keys, but does not dump their auxiliary data. It also implies "CcWwRrSs", but as 'B' is given, 'b' is not implied. Signed-off-by: David Howells <dhowells@redhat.com>
2009-04-03FS-Cache: Add use of /proc and presentation of statisticsDavid Howells
Make FS-Cache create its /proc interface and present various statistical information through it. Also provide the functions for updating this information. These features are enabled by: CONFIG_FSCACHE_PROC CONFIG_FSCACHE_STATS CONFIG_FSCACHE_HISTOGRAM The /proc directory for FS-Cache is also exported so that caching modules can add their own statistics there too. The FS-Cache module is loadable at this point, and the statistics files can be examined by userspace: cat /proc/fs/fscache/stats cat /proc/fs/fscache/histogram Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Steve Dickson <steved@redhat.com> Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Tested-by: Daire Byrne <Daire.Byrne@framestore.com>
2009-04-03FS-Cache: Add main configuration option, module entry points and debuggingDavid Howells
Add the main configuration option, allowing FS-Cache to be selected; the module entry and exit functions and the debugging stuff used by these patches. The two configuration options added are: CONFIG_FSCACHE CONFIG_FSCACHE_DEBUG The first enables the facility, and the second makes the debugging statements enableable through the "debug" module parameter. The value of this parameter is a bitmask as described in: Documentation/filesystems/caching/fscache.txt The module can be loaded at this point, but all it will do at this point in the patch series is to start up the slow work facility and shut it down again. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Steve Dickson <steved@redhat.com> Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Tested-by: Daire Byrne <Daire.Byrne@framestore.com>
