__fscache_check_consistency() does not decrement the count of operations
active after it finishes in the success case. This leads to a hung tasks on
cookie de-registration (commonly in inode eviction).
INFO: task kworker/1:2:4214 blocked for more than 120 seconds.
kworker/1:2 D ffff880443513fc0 0 4214 2 0x00000000
Workqueue: ceph-msgr con_work [libceph]
Call Trace:
[<ffffffff81569fc6>] ? _raw_spin_unlock_irqrestore+0x16/0x20
[<ffffffffa0016570>] ? fscache_wait_bit_interruptible+0x30/0x30 [fscache]
[<ffffffff81568d09>] schedule+0x29/0x70
[<ffffffffa001657e>] fscache_wait_atomic_t+0xe/0x20 [fscache]
[<ffffffff815665cf>] out_of_line_wait_on_atomic_t+0x9f/0xe0
[<ffffffff81083560>] ? autoremove_wake_function+0x40/0x40
[<ffffffffa0015a9c>] __fscache_relinquish_cookie+0x15c/0x310 [fscache]
[<ffffffffa00a4fae>] ceph_fscache_unregister_inode_cookie+0x3e/0x50 [ceph]
[<ffffffffa007e373>] ceph_destroy_inode+0x33/0x200 [ceph]
[<ffffffff811c13ae>] ? __fsnotify_inode_delete+0xe/0x10
[<ffffffff8119ba1c>] destroy_inode+0x3c/0x70
[<ffffffff8119bb69>] evict+0x119/0x1b0
Signed-off-by: Milosz Tanski <milosz@adfin.com>
Signed-off-by: Sage Weil <sage@inktank.com>
Currently the fscache code expect the netfs to call fscache_readpages_or_alloc
inside the aops readpages callback. It marks all the pages in the list
provided by readahead with PG_private_2. In the cases that the netfs fails to
read all the pages (which is legal) it ends up returning to the readahead and
triggering a BUG. This happens because the page list still contains marked
pages.
This patch implements a simple fscache_readpages_cancel function that the netfs
should call before returning from readpages. It will revoke the pages from the
underlying cache backend and unmark them.
The problem was originally worked out in the Ceph devel tree, but it also
occurs in CIFS. It appears that NFS, AFS and 9P are okay as read_cache_pages()
will clean up the unprocessed pages in the case of an error.
This can be used to address the following oops:
[12410647.597278] BUG: Bad page state in process petabucket pfn:3d504e
[12410647.597292] page:ffffea000f541380 count:0 mapcount:0 mapping:
(null) index:0x0
[12410647.597298] page flags: 0x200000000001000(private_2)
[12410647.597334] Call Trace:
[12410647.597345] [<ffffffff815523f2>] dump_stack+0x19/0x1b
[12410647.597356] [<ffffffff8111def7>] bad_page+0xc7/0x120
[12410647.597359] [<ffffffff8111e49e>] free_pages_prepare+0x10e/0x120
[12410647.597361] [<ffffffff8111fc80>] free_hot_cold_page+0x40/0x170
[12410647.597363] [<ffffffff81123507>] __put_single_page+0x27/0x30
[12410647.597365] [<ffffffff81123df5>] put_page+0x25/0x40
[12410647.597376] [<ffffffffa02bdcf9>] ceph_readpages+0x2e9/0x6e0 [ceph]
[12410647.597379] [<ffffffff81122a8f>] __do_page_cache_readahead+0x1af/0x260
[12410647.597382] [<ffffffff81122ea1>] ra_submit+0x21/0x30
[12410647.597384] [<ffffffff81118f64>] filemap_fault+0x254/0x490
[12410647.597387] [<ffffffff8113a74f>] __do_fault+0x6f/0x4e0
[12410647.597391] [<ffffffff810125bd>] ? __switch_to+0x16d/0x4a0
[12410647.597395] [<ffffffff810865ba>] ? finish_task_switch+0x5a/0xc0
[12410647.597398] [<ffffffff8113d856>] handle_pte_fault+0xf6/0x930
[12410647.597401] [<ffffffff81008c33>] ? pte_mfn_to_pfn+0x93/0x110
[12410647.597403] [<ffffffff81008cce>] ? xen_pmd_val+0xe/0x10
[12410647.597405] [<ffffffff81005469>] ? __raw_callee_save_xen_pmd_val+0x11/0x1e
[12410647.597407] [<ffffffff8113f361>] handle_mm_fault+0x251/0x370
[12410647.597411] [<ffffffff812b0ac4>] ? call_rwsem_down_read_failed+0x14/0x30
[12410647.597414] [<ffffffff8155bffa>] __do_page_fault+0x1aa/0x550
[12410647.597418] [<ffffffff8108011d>] ? up_write+0x1d/0x20
[12410647.597422] [<ffffffff8113141c>] ? vm_mmap_pgoff+0xbc/0xe0
[12410647.597425] [<ffffffff81143bb8>] ? SyS_mmap_pgoff+0xd8/0x240
[12410647.597427] [<ffffffff8155c3ae>] do_page_fault+0xe/0x10
[12410647.597431] [<ffffffff81558818>] page_fault+0x28/0x30
Extend the fscache netfs API so that the netfs can ask as to whether a cache
object is up to date with respect to its corresponding netfs object:
int fscache_check_consistency(struct fscache_cookie *cookie)
This will call back to the netfs to check whether the auxiliary data associated
with a cookie is correct. It returns 0 if it is and -ESTALE if it isn't; it
may also return -ENOMEM and -ERESTARTSYS.
The backends now have to implement a mandatory operation pointer:
int (*check_consistency)(struct fscache_object *object)
that corresponds to the above API call. FS-Cache takes care of pinning the
object and the cookie in memory and managing this call with respect to the
object state.
Original-author: Hongyi Jia <jiayisuse@gmail.com>
cc: Hongyi Jia <jiayisuse@gmail.com>
cc: Milosz Tanski <milosz@adfin.com>
Under certain circumstances, spin_is_locked() is hardwired to 0 - even when the
code would normally be in a locked section where it should return 1. This
means it cannot be used for an assertion that checks that a spinlock is locked.
Remove such usages from FS-Cache.
The following oops might otherwise be observed:
FS-Cache: Assertion failed
BUG: failure at fs/fscache/operation.c:270/fscache_start_operations()!
Kernel panic - not syncing: BUG!
CPU: 0 PID: 10 Comm: kworker/u2:1 Not tainted 3.10.0-rc1-00133-ge7ebb75 #2
Workqueue: fscache_operation fscache_op_work_func [fscache]
7f091c48 603c8947 7f090000 7f9b1361 7f25f080 00000001 7f26d440 7f091c90
60299eb8 7f091d90 602951c5 7f26d440 3000000008 7f091da0 7f091cc0 7f091cd0
00000007 00000007 00000006 7f091ae0 00000010 0000010e 7f9af330 7f091ae0
Call Trace:
7f091c88: [<60299eb8>] dump_stack+0x17/0x19
7f091c98: [<602951c5>] panic+0xf4/0x1e9
7f091d38: [<6002b10e>] set_signals+0x1e/0x40
7f091d58: [<6005b89e>] __wake_up+0x4e/0x70
7f091d98: [<7f9aa003>] fscache_start_operations+0x43/0x50 [fscache]
7f091da8: [<7f9aa1e3>] fscache_op_complete+0x1d3/0x220 [fscache]
7f091db8: [<60082985>] unlock_page+0x55/0x60
7f091de8: [<7fb25bb0>] cachefiles_read_copier+0x250/0x330 [cachefiles]
7f091e58: [<7f9ab03c>] fscache_op_work_func+0xac/0x120 [fscache]
7f091e88: [<6004d5b0>] process_one_work+0x250/0x3a0
7f091ef8: [<6004edc7>] worker_thread+0x177/0x2a0
7f091f38: [<6004ec50>] worker_thread+0x0/0x2a0
7f091f58: [<60054418>] kthread+0xd8/0xe0
7f091f68: [<6005bb27>] finish_task_switch.isra.64+0x37/0xa0
7f091fd8: [<600185cf>] new_thread_handler+0x8f/0xb0
Reported-by: Milosz Tanski <milosz@adfin.com>
Reviewed-and-tested-By: Milosz Tanski <milosz@adfin.com>
struct fscache_retrieval contains a count of the number of pages that still
need some processing (n_pages). This is decremented as the pages are
processed.
However, this needs to be atomic as fscache_retrieval_complete() (I think) just
occasionally may be called from cachefiles_read_backing_file() and
cachefiles_read_copier() simultaneously.
This happens when an fscache_read_or_alloc_pages() request containing a lot of
pages (say a couple of hundred) is being processed. The read on each backing
page is dispatched individually because we need to insert a monitor into the
waitqueue to catch when the read completes. However, under low-memory
conditions, we might be forced to wait in the allocator - and this gives the
I/O on the backing page a chance to complete first.
When the I/O completes, fscache_enqueue_retrieval() chucks the retrieval onto
the workqueue without waiting for the operation to finish the initial I/O
dispatch (we want to release any pages we can as soon as we can), thus both can
end up running simultaneously and potentially attempting to partially complete
the retrieval simultaneously (ENOMEM may occur, backing pages may already be in
the page cache).
This was demonstrated by parallelling the non-atomic counter with an atomic
counter and printing both of them when the assertion fails. At this point, the
atomic counter has reached zero, but the non-atomic counter has not.
To fix this, make the counter an atomic_t.
This results in the following bug appearing
3 == 5 is false
kernel BUG at fs/fscache/operation.c:421!
or
3 == 5 is false
kernel BUG at fs/fscache/operation.c:414!
With a backtrace like the following:
RIP: 0010:[<ffffffffa0211b1d>] fscache_put_operation+0x1ad/0x240 [fscache]
Call Trace:
[<ffffffffa0213185>] fscache_retrieval_work+0x55/0x270 [fscache]
[<ffffffffa0213130>] ? fscache_retrieval_work+0x0/0x270 [fscache]
[<ffffffff81090b10>] worker_thread+0x170/0x2a0
[<ffffffff81096d10>] ? autoremove_wake_function+0x0/0x40
[<ffffffff810909a0>] ? worker_thread+0x0/0x2a0
[<ffffffff81096966>] kthread+0x96/0xa0
[<ffffffff8100c0ca>] child_rip+0xa/0x20
[<ffffffff810968d0>] ? kthread+0x0/0xa0
[<ffffffff8100c0c0>] ? child_rip+0x0/0x20
Acked-by: Jeff Layton <jlayton@redhat.com>
Simplify the way fscache cache objects retain their cookie. The way I
implemented the cookie storage handling made synchronisation a pain (ie. the
object state machine can't rely on the cookie actually still being there).
Instead of the the object being detached from the cookie and the cookie being
freed in __fscache_relinquish_cookie(), we defer both operations:
(*) The detachment of the object from the list in the cookie now takes place
in fscache_drop_object() and is thus governed by the object state machine
(fscache_detach_from_cookie() has been removed).
(*) The release of the cookie is now in fscache_object_destroy() - which is
called by the cache backend just before it frees the object.
This means that the fscache_cookie struct is now available to the cache all the
way through from ->alloc_object() to ->drop_object() and ->put_object() -
meaning that it's no longer necessary to take object->lock to guarantee access.
However, __fscache_relinquish_cookie() doesn't wait for the object to go all
the way through to destruction before letting the netfs proceed. That would
massively slow down the netfs. Since __fscache_relinquish_cookie() leaves the
cookie around, in must therefore break all attachments to the netfs - which
includes ->def, ->netfs_data and any outstanding page read/writes.
To handle this, struct fscache_cookie now has an n_active counter:
(1) This starts off initialised to 1.
(2) Any time the cache needs to get at the netfs data, it calls
fscache_use_cookie() to increment it - if it is not zero. If it was zero,
then access is not permitted.
(3) When the cache has finished with the data, it calls fscache_unuse_cookie()
to decrement it. This does a wake-up on it if it reaches 0.
(4) __fscache_relinquish_cookie() decrements n_active and then waits for it to
reach 0. The initialisation to 1 in step (1) ensures that we only get
wake ups when we're trying to get rid of the cookie.
This leaves __fscache_relinquish_cookie() a lot simpler.
This fixes a problem in the current code whereby if fscache_invalidate() is
followed sufficiently quickly by fscache_relinquish_cookie() then it is
possible for __fscache_relinquish_cookie() to have detached the cookie from the
object and cleared the pointer before a thread is dispatched to process the
invalidation state in the object state machine.
Since the pending write clearance was deferred to the invalidation state to
make it asynchronous, we need to either wait in relinquishment for the stores
tree to be cleared in the invalidation state or we need to handle the clearance
in relinquishment.
Further, if the relinquishment code does clear the tree, then the invalidation
state need to make the clearance contingent on still having the cookie to hand
(since that's where the tree is rooted) and we have to prevent the cookie from
disappearing for the duration.
This can lead to an oops like the following:
BUG: unable to handle kernel NULL pointer dereference at 000000000000000c
RIP: 0010:[<ffffffff8151023e>] _spin_lock+0xe/0x30
CR2: 000000000000000c ...
Process kslowd002 (...)
Call Trace:
[<ffffffffa01c3278>] fscache_invalidate_writes+0x38/0xd0 [fscache]
[<ffffffff810096f0>] ? __switch_to+0xd0/0x320
[<ffffffff8105e759>] ? find_busiest_queue+0x69/0x150
[<ffffffff8110ddd4>] ? slow_work_enqueue+0x104/0x180
[<ffffffffa01c1303>] fscache_object_slow_work_execute+0x5e3/0x9d0 [fscache]
[<ffffffff81096b67>] ? bit_waitqueue+0x17/0xd0
[<ffffffff8110e233>] slow_work_execute+0x233/0x310
[<ffffffff8110e515>] slow_work_thread+0x205/0x360
[<ffffffff81096ca0>] ? autoremove_wake_function+0x0/0x40
[<ffffffff8110e310>] ? slow_work_thread+0x0/0x360
[<ffffffff81096936>] kthread+0x96/0xa0
[<ffffffff810968a0>] ? kthread+0x0/0xa0
The parameter to fscache_invalidate_writes() was object->cookie which is NULL.
Tested-By: Milosz Tanski <milosz@adfin.com>
Fix object state machine to have separate work and wait states as that makes
it easier to envision.
There are now three kinds of state:
(1) Work state. This is an execution state. No event processing is performed
by a work state. The function attached to a work state returns a pointer
indicating the next state to which the OSM should transition. Returning
NO_TRANSIT repeats the current state, but goes back to the scheduler
first.
(2) Wait state. This is an event processing state. No execution is
performed by a wait state. Wait states are just tables of "if event X
occurs, clear it and transition to state Y". The dispatcher returns to
the scheduler if none of the events in which the wait state has an
interest are currently pending.
(3) Out-of-band state. This is a special work state. Transitions to normal
states can be overridden when an unexpected event occurs (eg. I/O error).
Instead the dispatcher disables and clears the OOB event and transits to
the specified work state. This then acts as an ordinary work state,
though object->state points to the overridden destination. Returning
NO_TRANSIT resumes the overridden transition.
In addition, the states have names in their definitions, so there's no need for
tables of state names. Further, the EV_REQUEUE event is no longer necessary as
that is automatic for work states.
Since the states are now separate structs rather than values in an enum, it's
not possible to use comparisons other than (non-)equality between them, so use
some object->flags to indicate what phase an object is in.
The EV_RELEASE, EV_RETIRE and EV_WITHDRAW events have been squished into one
(EV_KILL). An object flag now carries the information about retirement.
Similarly, the RELEASING, RECYCLING and WITHDRAWING states have been merged
into an KILL_OBJECT state and additional states have been added for handling
waiting dependent objects (JUMPSTART_DEPS and KILL_DEPENDENTS).
A state has also been added for synchronising with parent object initialisation
(WAIT_FOR_PARENT) and another for initiating look up (PARENT_READY).
Wrap checks on object state (mostly outside of fs/fscache/object.c) with
inline functions so that the mechanism can be replaced.
Some of the state checks within object.c are left as-is as they will be
replaced.
Uninline fscache_object_init() so as not to expose some of the FS-Cache
internals to the cache backend.
Don't sleep in __fscache_maybe_release_page() if __GFP_FS is not set. This
goes some way towards mitigating fscache deadlocking against ext4 by way of
the allocator, eg:
INFO: task flush-8:0:24427 blocked for more than 120 seconds.
"echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
flush-8:0 D ffff88003e2b9fd8 0 24427 2 0x00000000
ffff88003e2b9138 0000000000000046 ffff880012e3a040 ffff88003e2b9fd8
0000000000011c80 ffff88003e2b9fd8 ffffffff81a10400 ffff880012e3a040
0000000000000002 ffff880012e3a040 ffff88003e2b9098 ffffffff8106dcf5
Call Trace:
[<ffffffff8106dcf5>] ? __lock_is_held+0x31/0x53
[<ffffffff81219b61>] ? radix_tree_lookup_element+0xf4/0x12a
[<ffffffff81454bed>] schedule+0x60/0x62
[<ffffffffa01d349c>] __fscache_wait_on_page_write+0x8b/0xa5 [fscache]
[<ffffffff810498a8>] ? __init_waitqueue_head+0x4d/0x4d
[<ffffffffa01d393a>] __fscache_maybe_release_page+0x30c/0x324 [fscache]
[<ffffffffa01d369a>] ? __fscache_maybe_release_page+0x6c/0x324 [fscache]
[<ffffffff81071b53>] ? trace_hardirqs_on_caller+0x114/0x170
[<ffffffffa01fd7b2>] nfs_fscache_release_page+0x68/0x94 [nfs]
[<ffffffffa01ef73e>] nfs_release_page+0x7e/0x86 [nfs]
[<ffffffff810aa553>] try_to_release_page+0x32/0x3b
[<ffffffff810b6c70>] shrink_page_list+0x535/0x71a
[<ffffffff810b7352>] shrink_inactive_list+0x20a/0x2dd
[<ffffffff81071a13>] ? mark_held_locks+0xbe/0xea
[<ffffffff810b7a65>] shrink_lruvec+0x34c/0x3eb
[<ffffffff810b7bd3>] do_try_to_free_pages+0xcf/0x355
[<ffffffff810b7fc8>] try_to_free_pages+0x9a/0xa1
[<ffffffff810b08d2>] __alloc_pages_nodemask+0x494/0x6f7
[<ffffffff810d9a07>] kmem_getpages+0x58/0x155
[<ffffffff810dc002>] fallback_alloc+0x120/0x1f3
[<ffffffff8106db23>] ? trace_hardirqs_off+0xd/0xf
[<ffffffff810dbed3>] ____cache_alloc_node+0x177/0x186
[<ffffffff81162a6c>] ? ext4_init_io_end+0x1c/0x37
[<ffffffff810dc403>] kmem_cache_alloc+0xf1/0x176
[<ffffffff810b17ac>] ? test_set_page_writeback+0x101/0x113
[<ffffffff81162a6c>] ext4_init_io_end+0x1c/0x37
[<ffffffff81162ce4>] ext4_bio_write_page+0x20f/0x3af
[<ffffffff8115cc02>] mpage_da_submit_io+0x26e/0x2f6
[<ffffffff811088e5>] ? __find_get_block_slow+0x38/0x133
[<ffffffff81161348>] mpage_da_map_and_submit+0x3a7/0x3bd
[<ffffffff81161a60>] ext4_da_writepages+0x30d/0x426
[<ffffffff810b3359>] do_writepages+0x1c/0x2a
[<ffffffff81102f4d>] __writeback_single_inode+0x3e/0xe5
[<ffffffff81103995>] writeback_sb_inodes+0x1bd/0x2f4
[<ffffffff81103b3b>] __writeback_inodes_wb+0x6f/0xb4
[<ffffffff81103c81>] wb_writeback+0x101/0x195
[<ffffffff811043aa>] ? wb_do_writeback+0xaa/0x173
[<ffffffff8110434a>] wb_do_writeback+0x4a/0x173
[<ffffffff81071bbc>] ? trace_hardirqs_on+0xd/0xf
[<ffffffff81038554>] ? del_timer+0x4b/0x5b
[<ffffffff811044e0>] bdi_writeback_thread+0x6d/0x147
[<ffffffff81104473>] ? wb_do_writeback+0x173/0x173
[<ffffffff81048fbc>] kthread+0xd0/0xd8
[<ffffffff81455eb2>] ? _raw_spin_unlock_irq+0x29/0x3e
[<ffffffff81048eec>] ? __init_kthread_worker+0x55/0x55
[<ffffffff81456aac>] ret_from_fork+0x7c/0xb0
2 locks held by flush-8:0/24427:
#0: (&type->s_umount_key#41){.+.+..}, at: [<ffffffff810e3b73>] grab_super_passive+0x4c/0x76
#1: (jbd2_handle){+.+...}, at: [<ffffffff81190d81>] start_this_handle+0x475/0x4ea
The problem here is that another thread, which is attempting to write the
to-be-stored NFS page to the on-ext4 cache file is waiting for the journal
lock, eg:
INFO: task kworker/u:2:24437 blocked for more than 120 seconds.
kworker/u:2 D ffff880039589768 0 24437 2 0x00000000
ffff8800395896d8 0000000000000046 ffff8800283bf040 ffff880039589fd8
0000000000011c80 ffff880039589fd8 ffff880039f0b040 ffff8800283bf040
0000000000000006 ffff8800283bf6b8 ffff880039589658 ffffffff81071a13
Call Trace:
[<ffffffff81455e73>] ? _raw_spin_unlock_irqrestore+0x3a/0x50
[<ffffffff81190c23>] start_this_handle+0x317/0x4ea
[<ffffffff81190fcc>] jbd2__journal_start+0xb3/0x12e
[<ffffffff81176606>] __ext4_journal_start_sb+0xb2/0xc6
[<ffffffff8115f137>] ext4_da_write_begin+0x109/0x233
[<ffffffff810a964d>] generic_file_buffered_write+0x11a/0x264
[<ffffffff811032cf>] ? __mark_inode_dirty+0x2d/0x1ee
[<ffffffff810ab1ab>] __generic_file_aio_write+0x2a5/0x2d5
[<ffffffff810ab24a>] generic_file_aio_write+0x6f/0xd0
[<ffffffff81159a2c>] ext4_file_write+0x38c/0x3c4
[<ffffffff810e0915>] do_sync_write+0x91/0xd1
[<ffffffffa00a17f0>] cachefiles_write_page+0x26f/0x310 [cachefiles]
[<ffffffffa01d470b>] fscache_write_op+0x21e/0x37a [fscache]
[<ffffffffa01d2479>] fscache_op_work_func+0x78/0xd7 [fscache]
[<ffffffff8104455a>] process_one_work+0x232/0x3a8
[<ffffffff810444ff>] ? process_one_work+0x1d7/0x3a8
[<ffffffff81044ee0>] worker_thread+0x214/0x303
[<ffffffff81044ccc>] ? manage_workers+0x245/0x245
4 locks held by kworker/u:2/24437:
#0: (fscache_operation){.+.+.+}, at: [<ffffffff810444ff>] process_one_work+0x1d7/0x3a8
#1: ((&op->work)){+.+.+.}, at: [<ffffffff810444ff>] process_one_work+0x1d7/0x3a8
#2: (sb_writers#14){.+.+.+}, at: [<ffffffff810ab22c>] generic_file_aio_write+0x51/0xd0
#3: (&sb->s_type->i_mutex_key#19){+.+.+.}, at: [<ffffffff810ab236>] generic_file_aio_write+0x5b/0x
fscache already tries to cancel pending stores, but it can't cancel a write
for which I/O is already in progress.
An alternative would be to accept writing garbage to the cache under extreme
circumstances and to kill the afflicted cache object if we have to do this.
However, we really need to know how strapped the allocator is before deciding
to do that.
The spinlock() within the condition in while() will cause a compile error
if it is not a function. This is not a problem on mainline but it does not
look pretty and there is no reason to do it that way.
That patch writes it a little differently and avoids the double condition.
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
There is a kernel memory leak observed when the proc file
/proc/fs/fscache/stats is read.
The reason is that in fscache_stats_open, single_open is called and the
respective release function is not called during release. Hence fix
with correct release function - single_release().
Addresses https://bugzilla.kernel.org/show_bug.cgi?id=57101
Signed-off-by: Anurup m <anurup.m@huawei.com>
Cc: shyju pv <shyju.pv@huawei.com>
Cc: Sanil kumar <sanil.kumar@huawei.com>
Cc: Nataraj m <nataraj.m@huawei.com>
Cc: Li Zefan <lizefan@huawei.com>
Cc: <stable@vger.kernel.org>
I'm not sure why, but the hlist for each entry iterators were conceived
list_for_each_entry(pos, head, member)
The hlist ones were greedy and wanted an extra parameter:
hlist_for_each_entry(tpos, pos, head, member)
Why did they need an extra pos parameter? I'm not quite sure. Not only
they don't really need it, it also prevents the iterator from looking
exactly like the list iterator, which is unfortunate.
Besides the semantic patch, there was some manual work required:
- Fix up the actual hlist iterators in linux/list.h
- Fix up the declaration of other iterators based on the hlist ones.
- A very small amount of places were using the 'node' parameter, this
was modified to use 'obj->member' instead.
- Coccinelle didn't handle the hlist_for_each_entry_safe iterator
properly, so those had to be fixed up manually.
The semantic patch which is mostly the work of Peter Senna Tschudin is here:
iterator name hlist_for_each_entry, hlist_for_each_entry_continue, hlist_for_each_entry_from, hlist_for_each_entry_rcu, hlist_for_each_entry_rcu_bh, hlist_for_each_entry_continue_rcu_bh, for_each_busy_worker, ax25_uid_for_each, ax25_for_each, inet_bind_bucket_for_each, sctp_for_each_hentry, sk_for_each, sk_for_each_rcu, sk_for_each_from, sk_for_each_safe, sk_for_each_bound, hlist_for_each_entry_safe, hlist_for_each_entry_continue_rcu, nr_neigh_for_each, nr_neigh_for_each_safe, nr_node_for_each, nr_node_for_each_safe, for_each_gfn_indirect_valid_sp, for_each_gfn_sp, for_each_host;
type T;
expression a,c,d,e;
identifier b;
statement S;
-T b;
<+... when != b
hlist_for_each_entry(a,
- b,
c, d) S
hlist_for_each_entry_continue(a,
- b,
c) S
hlist_for_each_entry_from(a,
- b,
c) S
hlist_for_each_entry_rcu(a,
- b,
c, d) S
hlist_for_each_entry_rcu_bh(a,
- b,
c, d) S
hlist_for_each_entry_continue_rcu_bh(a,
- b,
c) S
for_each_busy_worker(a, c,
- b,
d) S
ax25_uid_for_each(a,
- b,
c) S
ax25_for_each(a,
- b,
c) S
inet_bind_bucket_for_each(a,
- b,
c) S
sctp_for_each_hentry(a,
- b,
c) S
sk_for_each(a,
- b,
c) S
sk_for_each_rcu(a,
- b,
c) S
sk_for_each_from
-(a, b)
+(a)
S
+ sk_for_each_from(a) S
sk_for_each_safe(a,
- b,
c, d) S
sk_for_each_bound(a,
- b,
c) S
hlist_for_each_entry_safe(a,
- b,
c, d, e) S
hlist_for_each_entry_continue_rcu(a,
- b,
c) S
nr_neigh_for_each(a,
- b,
c) S
nr_neigh_for_each_safe(a,
- b,
c, d) S
nr_node_for_each(a,
- b,
c) S
nr_node_for_each_safe(a,
- b,
c, d) S
- for_each_gfn_sp(a, c, d, b) S
+ for_each_gfn_sp(a, c, d) S
- for_each_gfn_indirect_valid_sp(a, c, d, b) S
+ for_each_gfn_indirect_valid_sp(a, c, d) S
for_each_host(a,
- b,
c) S
for_each_host_safe(a,
- b,
c, d) S
for_each_mesh_entry(a,
- b,
c, d) S
[akpm@linux-foundation.org: drop bogus change from net/ipv4/raw.c]
[akpm@linux-foundation.org: drop bogus hunk from net/ipv6/raw.c]
[akpm@linux-foundation.org: checkpatch fixes]
[akpm@linux-foundation.org: fix warnings]
[akpm@linux-foudnation.org: redo intrusive kvm changes]
Tested-by: Peter Senna Tschudin <peter.senna@gmail.com>
Cc: Wu Fengguang <fengguang.wu@intel.com>
Cc: Marcelo Tosatti <mtosatti@redhat.com>
Cc: Gleb Natapov <gleb@redhat.com>
Provide fscache_cancel_op() with a pointer to a function it should invoke under
lock if it cancels an operation.
Use this to clear the remaining page count upon cancellation of a pending
retrieval operation so that fscache_release_retrieval_op() doesn't get an
assertion failure (see below). This can happen when a signal occurs, say from
CTRL-C being pressed during data retrieval.
3 == 0 is false
kernel BUG at fs/fscache/page.c:237!
invalid opcode: 0000 [#641] SMP
Modules linked in: cachefiles(F) nfsv4(F) nfsv3(F) nfsv2(F) nfs(F) fscache(F) auth_rpcgss(F) nfs_acl(F) lockd(F) sunrpc(F)
CPU 0
Pid: 6075, comm: slurp-q Tainted: GF D 3.7.0-rc8-fsdevel+ #411 /DG965RY
RIP: 0010:[<ffffffffa007f328>] [<ffffffffa007f328>] fscache_release_retrieval_op+0x75/0xff [fscache]
RSP: 0000:ffff88001c6d7988 EFLAGS: 00010296
RAX: 000000000000000f RBX: ffff880014cdfe00 RCX: ffffffff6c102000
RDX: ffffffff8102d1ad RSI: ffffffff6c102000 RDI: ffffffff8102d1d6
RBP: ffff88001c6d7998 R08: 0000000000000002 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000000 R12: 00000000fffffe00
R13: ffff88001c6d7ab4 R14: ffff88001a8638a0 R15: ffff88001552b190
FS: 00007f877aaf0700(0000) GS:ffff88003bc00000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 00007fff11378fd2 CR3: 000000001c6c6000 CR4: 00000000000007f0
Process slurp-q (pid: 6075, threadinfo ffff88001c6d6000, task ffff88001c6c4080)
Stack:
ffffffffa007ec07 ffff880014cdfe00 ffff88001c6d79c8 ffffffffa007db4d
ffffffffa007ec07 ffff880014cdfe00 00000000fffffe00 ffff88001c6d7ab4
ffff88001c6d7a38 ffffffffa008116d 0000000000000000 ffff88001c6c4080
Call Trace:
[<ffffffffa007ec07>] ? fscache_cancel_op+0x194/0x1cf [fscache]
[<ffffffffa007db4d>] fscache_put_operation+0x135/0x2ed [fscache]
[<ffffffffa008116d>] __fscache_read_or_alloc_pages+0x413/0x4bc [fscache]
[<ffffffff810ac8ae>] ? __alloc_pages_nodemask+0x195/0x75c
[<ffffffffa00aab0f>] __nfs_readpages_from_fscache+0x86/0x13d [nfs]
[<ffffffffa00a5fe0>] nfs_readpages+0x186/0x1bd [nfs]
[<ffffffff810d23c8>] ? alloc_pages_current+0xc7/0xe4
[<ffffffff810a68b5>] ? __page_cache_alloc+0x84/0x91
[<ffffffff810af912>] ? __do_page_cache_readahead+0xa6/0x2e0
[<ffffffff810afaa3>] __do_page_cache_readahead+0x237/0x2e0
[<ffffffff810afe3e>] ra_submit+0x1c/0x20
[<ffffffff810b019b>] ondemand_readahead+0x359/0x382
[<ffffffff810b0279>] page_cache_sync_readahead+0x38/0x3a
[<ffffffff810a77b5>] generic_file_aio_read+0x26b/0x637
[<ffffffffa00f1852>] ? nfs_mark_delegation_referenced+0xb/0xb [nfsv4]
[<ffffffffa009cc85>] nfs_file_read+0xaa/0xcf [nfs]
[<ffffffff810db5b3>] do_sync_read+0x91/0xd1
[<ffffffff810dbb8b>] vfs_read+0x9b/0x144
[<ffffffff810dbc78>] sys_read+0x44/0x75
[<ffffffff81422892>] system_call_fastpath+0x16/0x1b
Mark as cancelled an operation that is in progress rather than pending at the
time it is cancelled, and call fscache_complete_op() to cancel an operation so
that blocked ops can be started.
In fscache_write_op(), if the object is determined to have become inactive or
to have lost its cookie, we don't move the operation state from in-progress,
and so an assertion in fscache_put_operation() fails with an assertion (see
below).
Instrumenting fscache_op_work_func() indicates that it called
fscache_write_op() before calling fscache_put_operation() - where the assertion
failed. The assertion at line 433 indicates that the operation state is
IN_PROGRESS rather than being COMPLETE or CANCELLED.
Instrumenting fscache_write_op() showed that it was being called on an object
that had had its cookie removed and that this was due to relinquishment of the
cookie by the netfs. At this point fscache no longer has access to the pages
of netfs data that were requested to be written, and so simply cancelling the
operation is the thing to do.
3 == 5 is false
kernel BUG at fs/fscache/operation.c:433!
invalid opcode: 0000 [#1] SMP
CPU 0
Pid: 1035, comm: kworker/u:3 Tainted: GF 3.7.0-rc8-fsdevel+ #411 /DG965RY
RIP: 0010:[<ffffffffa007db22>] [<ffffffffa007db22>] fscache_put_operation+0x11a/0x2ed [fscache]
RSP: 0018:ffff88003e32bcf8 EFLAGS: 00010296
RAX: 000000000000000f RBX: ffff88001818eb78 RCX: ffffffff6c102000
RBP: ffff88003e32bd18 R08: 0000000000000002 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000000 R12: ffffffffa00811da
R13: 0000000000000001 R14: 0000000100625d26 R15: 0000000000000000
FS: 0000000000000000(0000) GS:ffff88003bc00000(0000) knlGS:0000000000000000
CR2: 00007fff7dd31c68 CR3: 000000003d730000 CR4: 00000000000007f0
Process kworker/u:3 (pid: 1035, threadinfo ffff88003e32a000, task ffff88003bb38080)
Stack:
ffffffff8102d1ad ffff88001818eb78 ffffffffa00811da 0000000000000001
ffff88003e32bd48 ffffffffa007f0ad ffff88001818eb78 ffffffff819583c0
ffff88003df24e00 ffff88003882c3e0 ffff88003e32bde8 ffffffff81042de0
Call Trace:
[<ffffffff8102d1ad>] ? vprintk_emit+0x3c6/0x41a
[<ffffffffa00811da>] ? __fscache_read_or_alloc_pages+0x4bc/0x4bc [fscache]
[<ffffffffa007f0ad>] fscache_op_work_func+0xec/0x123 [fscache]
[<ffffffff81042de0>] process_one_work+0x21c/0x3b0
[<ffffffff81042d82>] ? process_one_work+0x1be/0x3b0
[<ffffffffa007efc1>] ? fscache_operation_gc+0x23e/0x23e [fscache]
[<ffffffff8104332e>] worker_thread+0x202/0x2df
[<ffffffff8104312c>] ? rescuer_thread+0x18e/0x18e
[<ffffffff81047c1c>] kthread+0xd0/0xd8
[<ffffffff81421bfa>] ? _raw_spin_unlock_irq+0x29/0x3e
[<ffffffff81047b4c>] ? __init_kthread_worker+0x55/0x55
[<ffffffff814227ec>] ret_from_fork+0x7c/0xb0
wait_on_bit() with TASK_INTERRUPTIBLE returns 1 rather than a negative error
code, so change what we check for. This means that the signal handling in
fscache_wait_for_retrieval_activation() should now work properly.
Without this, the following bug can be seen if CTRL-C is pressed during
fscache read operation:
2 == 3 is false
kernel BUG at fs/fscache/page.c:347!
CPU 1
Pid: 15006, comm: slurp-q Tainted: GF 3.7.0-rc8-fsdevel+ #411 /DG965RY
RIP: 0010:[<ffffffffa007fcb4>] [<ffffffffa007fcb4>] fscache_wait_for_retrieval_activation+0x167/0x177 [fscache]
RSP: 0018:ffff88002a4c39a8 EFLAGS: 00010292
RAX: 000000000000001a RBX: ffff88002d3dc158 RCX: 0000000000008685
RDX: ffffffff8102ccd6 RSI: 0000000000000001 RDI: ffffffff8102d1d6
RBP: ffff88002a4c39c8 R08: 0000000000000002 R09: 0000000000000000
R10: ffffffff8163afa0 R11: ffff88003bd11900 R12: ffffffffa00868c8
R13: ffff880028306458 R14: ffff88002d3dc1b0 R15: ffff88001372e538
FS: 00007f17426a0700(0000) GS:ffff88003bd00000(0000) knlGS:0000000000000000
CR2: 00007f1742494a44 CR3: 0000000031bd7000 CR4: 00000000000007e0
Process slurp-q (pid: 15006, threadinfo ffff88002a4c2000, task ffff880023de3040)
Stack:
ffff88002d3dc158 ffff88001372e538 ffff88002a4c3ab4 ffff8800283064e0
ffff88002a4c3a38 ffffffffa0080f6d 0000000000000000 ffff880023de3040
ffff88002a4c3ac8 ffffffff810ac8ae ffff880028306458 ffff88002a4c3bc8
Call Trace:
[<ffffffffa0080f6d>] __fscache_read_or_alloc_pages+0x24f/0x4bc [fscache]
Add a missing transition to the FS-Cache object state machine to handle an
invalidation event occuring between the back end completing the object lookup
by calling fscache_obtained_object() (which moves to state OBJECT_AVAILABLE)
and the backend returning to fscache_lookup_object() and thence to
fscache_object_state_machine() which then does a goto lookup_transit to handle
the transition - but lookup_transit doesn't handle EV_INVALIDATE.
Without this, the following BUG can be logged:
FS-Cache: Unsupported event 2 [5/f7] in state OBJECT_AVAILABLE
kernel BUG at fs/fscache/object.c:357!
Where event 2 is EV_INVALIDATE.
nfs_migrate_page() does not wait for FS-Cache to finish with a page, probably
leading to the following bad-page-state:
BUG: Bad page state in process python-bin pfn:17d39b
page:ffffea00053649e8 flags:004000000000100c count:0 mapcount:0 mapping:(null)
index:38686 (Tainted: G B ---------------- )
Pid: 31053, comm: python-bin Tainted: G B ----------------
2.6.32-71.24.1.el6.x86_64 #1
Call Trace:
[<ffffffff8111bfe7>] bad_page+0x107/0x160
[<ffffffff8111ee69>] free_hot_cold_page+0x1c9/0x220
[<ffffffff8111ef19>] __pagevec_free+0x59/0xb0
[<ffffffff8104b988>] ? flush_tlb_others_ipi+0x128/0x130
[<ffffffff8112230c>] release_pages+0x21c/0x250
[<ffffffff8115b92a>] ? remove_migration_pte+0x28a/0x2b0
[<ffffffff8115f3f8>] ? mem_cgroup_get_reclaim_stat_from_page+0x18/0x70
[<ffffffff81122687>] ____pagevec_lru_add+0x167/0x180
[<ffffffff811226f8>] __lru_cache_add+0x58/0x70
[<ffffffff81122731>] lru_cache_add_lru+0x21/0x40
[<ffffffff81123f49>] putback_lru_page+0x69/0x100
[<ffffffff8115c0bd>] migrate_pages+0x13d/0x5d0
[<ffffffff81122687>] ? ____pagevec_lru_add+0x167/0x180
[<ffffffff81152ab0>] ? compaction_alloc+0x0/0x370
[<ffffffff8115255c>] compact_zone+0x4cc/0x600
[<ffffffff8111cfac>] ? get_page_from_freelist+0x15c/0x820
[<ffffffff810672f4>] ? check_preempt_wakeup+0x1c4/0x3c0
[<ffffffff8115290e>] compact_zone_order+0x7e/0xb0
[<ffffffff81152a49>] try_to_compact_pages+0x109/0x170
[<ffffffff8111e94d>] __alloc_pages_nodemask+0x5ed/0x850
[<ffffffff814c9136>] ? thread_return+0x4e/0x778
[<ffffffff81150d43>] alloc_pages_vma+0x93/0x150
[<ffffffff81167ea5>] do_huge_pmd_anonymous_page+0x135/0x340
[<ffffffff814cb6f6>] ? rwsem_down_read_failed+0x26/0x30
[<ffffffff81136755>] handle_mm_fault+0x245/0x2b0
[<ffffffff814ce383>] do_page_fault+0x123/0x3a0
[<ffffffff814cbdf5>] page_fault+0x25/0x30
nfs_migrate_page() calls nfs_fscache_release_page() which doesn't actually wait
- even if __GFP_WAIT is set. The reason that doesn't wait is that
fscache_maybe_release_page() might deadlock the allocator as the work threads
writing to the cache may all end up sleeping on memory allocation.
However, I wonder if that is actually a problem. There are a number of things
I can do to deal with this:
(1) Make nfs_migrate_page() wait.
(2) Make fscache_maybe_release_page() honour the __GFP_WAIT flag.
(3) Set a timeout around the wait.
(4) Make nfs_migrate_page() return an error if the page is still busy.
For the moment, I'll select (2) and (4).
The function to submit an exclusive op (fscache_submit_exclusive_op()) can BUG
if there's been an I/O error because it may see the parent cache object in an
unexpected state. It should only BUG if there hasn't been an I/O error.
In this case the problem was produced by remounting the cache partition to be
R/O. The EROFS state was detected and the cache was aborted, but not
everything handled the aborting correctly.
SysRq : Emergency Remount R/O
EXT4-fs (sda6): re-mounted. Opts: (null)
Emergency Remount complete
CacheFiles: I/O Error: Failed to update xattr with error -30
FS-Cache: Cache cachefiles stopped due to I/O error
kernel BUG at fs/fscache/operation.c:128!
CPU 0
Modules linked in: cachefiles nfs fscache auth_rpcgss nfs_acl lockd sunrpc
Pid: 6612, comm: kworker/u:2 Not tainted 3.1.0-rc8-fsdevel+ #1093 /DG965RY
RIP: 0010:[<ffffffffa00739c0>] [<ffffffffa00739c0>] fscache_submit_exclusive_op+0x2ad/0x2c2 [fscache]
RSP: 0018:ffff880000853d40 EFLAGS: 00010206
RAX: ffff880038ac72a8 RBX: ffff8800181f2260 RCX: ffffffff81f2b2b0
RDX: 0000000000000001 RSI: ffffffff8179a478 RDI: ffff8800181f2280
RBP: ffff880000853d60 R08: 0000000000000002 R09: 0000000000000000
R10: 0000000000000001 R11: 0000000000000001 R12: ffff880038ac7268
R13: ffff8800181f2280 R14: ffff88003a359190 R15: 000000010122b162
CR2: 00000034cc4a77f0 CR3: 0000000010e96000 CR4: 00000000000006f0
Process kworker/u:2 (pid: 6612, threadinfo ffff880000852000, task ffff880014c3c040)
Stack:
ffff8800181f2260 ffff8800181f2310 ffff880038ac7268 ffff8800181f2260
ffff880000853dc0 ffffffffa0072375 ffff880037ecfe00 ffff88003a359198
ffff880000853dc0 0000000000000246 0000000000000000 ffff88000a91d308
Call Trace:
[<ffffffffa0072375>] fscache_object_work_func+0x792/0xe65 [fscache]
[<ffffffff81047e44>] process_one_work+0x1eb/0x37f
[<ffffffff81047de6>] ? process_one_work+0x18d/0x37f
[<ffffffffa0071be3>] ? fscache_enqueue_dependents+0xd8/0xd8 [fscache]
[<ffffffff810482e4>] worker_thread+0x15a/0x21a
[<ffffffff8104818a>] ? rescuer_thread+0x188/0x188
[<ffffffff8104bf96>] kthread+0x7f/0x87
[<ffffffff813ad6f4>] kernel_thread_helper+0x4/0x10
[<ffffffff81026b98>] ? finish_task_switch+0x45/0xc0
[<ffffffff813abd1d>] ? retint_restore_args+0xe/0xe
[<ffffffff8104bf17>] ? __init_kthread_worker+0x53/0x53
[<ffffffff813ad6f0>] ? gs_change+0xb/0xb
Limit the number of I/O error reports for a cache to 1 to prevent massive
amounts of noise. After the first I/O error the cache is taken off line
automatically, so must be restarted to resume caching.
Don't mask off the object event mask when printing it. That way it can be seen
if threre are bits set that shouldn't be.
Initialise the object event mask with the calculated mask rather than unmasking
undefined events also.
CacheFiles is missing some calls to fscache_retrieval_complete() in the error
handling/collision paths of its reader functions.
This can be seen by the following assertion tripping in fscache_put_operation()
whereby the operation being destroyed is still in the in-progress state and has
not been cancelled or completed:
3 == 5 is false
kernel BUG at fs/fscache/operation.c:408!
CPU 2
Modules linked in: xfs ioatdma dca loop joydev evdev
psmouse dcdbas pcspkr serio_raw i5000_edac edac_core i5k_amb shpchp
pci_hotplug sg sr_mod]
Pid: 8062, comm: httpd Not tainted 3.1.0-rc8 #1 Dell Inc. PowerEdge 1950/0DT097
RIP: 0010:[<ffffffff81197b24>] [<ffffffff81197b24>] fscache_put_operation+0x304/0x330
RSP: 0018:ffff880062f739d8 EFLAGS: 00010296
RAX: 0000000000000025 RBX: ffff8800c5122e84 RCX: ffffffff81ddf040
RDX: 00000000ffffffff RSI: 0000000000000082 RDI: ffffffff81ddef30
RBP: ffff880062f739f8 R08: 0000000000000005 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000003 R12: ffff8800c5122e40
R13: ffff880037a2cd20 R14: ffff880087c7a058 R15: ffff880087c7a000
FS: 00007f63dcf636e0(0000) GS:ffff88022fc80000(0000) knlGS:0000000000000000
CR2: 00007f0c0a91f000 CR3: 0000000062ec2000 CR4: 00000000000006e0
Process httpd (pid: 8062, threadinfo ffff880062f72000, task ffff880087e58000)
Stack:
ffff880062f73bf8 0000000000000000 ffff880062f73bf8 ffff880037a2cd20
ffff880062f73a68 ffffffff8119aa7e ffff88006540e000 ffff880062f73ad4
ffff88008e9a4308 ffff880037a2cd20 ffff880062f73a48 ffff8800c5122e40
Call Trace:
[<ffffffff8119aa7e>] __fscache_read_or_alloc_pages+0x1fe/0x530
[<ffffffff81250780>] __nfs_readpages_from_fscache+0x70/0x1c0
[<ffffffff8123142a>] nfs_readpages+0xca/0x1e0
[<ffffffff815f3c06>] ? rpc_do_put_task+0x36/0x50
[<ffffffff8122755b>] ? alloc_nfs_open_context+0x4b/0x110
[<ffffffff815ecd1a>] ? rpc_call_sync+0x5a/0x70
[<ffffffff810e7e9a>] __do_page_cache_readahead+0x1ca/0x270
[<ffffffff810e7f61>] ra_submit+0x21/0x30
[<ffffffff810e818d>] ondemand_readahead+0x11d/0x250
[<ffffffff810e83b6>] page_cache_sync_readahead+0x36/0x60
[<ffffffff810dffa4>] generic_file_aio_read+0x454/0x770
[<ffffffff81224ce1>] nfs_file_read+0xe1/0x130
[<ffffffff81121bd9>] do_sync_read+0xd9/0x120
[<ffffffff8114088f>] ? mntput+0x1f/0x40
[<ffffffff811238cb>] ? fput+0x1cb/0x260
[<ffffffff81122938>] vfs_read+0xc8/0x180
[<ffffffff81122af5>] sys_read+0x55/0x90
Reported-by: Mark Moseley <moseleymark@gmail.com>
Provide a proper invalidation method rather than relying on the netfs retiring
the cookie it has and getting a new one. The problem with this is that isn't
easy for the netfs to make sure that it has completed/cancelled all its
outstanding storage and retrieval operations on the cookie it is retiring.
Instead, have the cache provide an invalidation method that will cancel or wait
for all currently outstanding operations before invalidating the cache, and
will cause new operations to queue up behind that. Whilst invalidation is in
progress, some requests will be rejected until the cache can stack a barrier on
the operation queue to cause new operations to be deferred behind it.
Fix the state management of internal fscache operations and the accounting of
what operations are in what states.
This is done by:
(1) Give struct fscache_operation a enum variable that directly represents the
state it's currently in, rather than spreading this knowledge over a bunch
of flags, who's processing the operation at the moment and whether it is
queued or not.
This makes it easier to write assertions to check the state at various
points and to prevent invalid state transitions.
(2) Add an 'operation complete' state and supply a function to indicate the
completion of an operation (fscache_op_complete()) and make things call
it. The final call to fscache_put_operation() can then check that an op
in the appropriate state (complete or cancelled).
(3) Adjust the use of object->n_ops, ->n_in_progress, ->n_exclusive to better
govern the state of an object:
(a) The ->n_ops is now the number of extant operations on the object
and is now decremented by fscache_put_operation() only.
(b) The ->n_in_progress is simply the number of objects that have been
taken off of the object's pending queue for the purposes of being
run. This is decremented by fscache_op_complete() only.
(c) The ->n_exclusive is the number of exclusive ops that have been
submitted and queued or are in progress. It is decremented by
fscache_op_complete() and by fscache_cancel_op().
fscache_put_operation() and fscache_operation_gc() now no longer try to
clean up ->n_exclusive and ->n_in_progress. That was leading to double
decrements against fscache_cancel_op().
fscache_cancel_op() now no longer decrements ->n_ops. That was leading to
double decrements against fscache_put_operation().
fscache_submit_exclusive_op() now decides whether it has to queue an op
based on ->n_in_progress being > 0 rather than ->n_ops > 0 as the latter
will persist in being true even after all preceding operations have been
cancelled or completed. Furthermore, if an object is active and there are
runnable ops against it, there must be at least one op running.
(4) Add a remaining-pages counter (n_pages) to struct fscache_retrieval and
provide a function to record completion of the pages as they complete.
When n_pages reaches 0, the operation is deemed to be complete and
fscache_op_complete() is called.
Add calls to fscache_retrieval_complete() anywhere we've finished with a
page we've been given to read or allocate for. This includes places where
we just return pages to the netfs for reading from the server and where
accessing the cache fails and we discard the proposed netfs page.
The bugs in the unfixed state management manifest themselves as oopses like the
following where the operation completion gets out of sync with return of the
cookie by the netfs. This is possible because the cache unlocks and returns
all the netfs pages before recording its completion - which means that there's
nothing to stop the netfs discarding them and returning the cookie.
FS-Cache: Cookie 'NFS.fh' still has outstanding reads
kernel BUG at fs/fscache/cookie.c:519!
CPU 1
Pid: 400, comm: kswapd0 Not tainted 3.1.0-rc7-fsdevel+ #1090 /DG965RY
RIP: 0010:[<ffffffffa007050a>] [<ffffffffa007050a>] __fscache_relinquish_cookie+0x170/0x343 [fscache]
RSP: 0018:ffff8800368cfb00 EFLAGS: 00010282
RAX: 000000000000003c RBX: ffff880023cc8790 RCX: 0000000000000000
RDX: 0000000000002f2e RSI: 0000000000000001 RDI: ffffffff813ab86c
RBP: ffff8800368cfb50 R08: 0000000000000002 R09: 0000000000000000
R10: ffff88003a1b7890 R11: ffff88001df6e488 R12: ffff880023d8ed98
R13: ffff880023cc8798 R14: 0000000000000004 R15: ffff88003b8bf370
FS: 0000000000000000(0000) GS:ffff88003bd00000(0000) knlGS:0000000000000000
CR2: 00000000008ba008 CR3: 0000000023d93000 CR4: 00000000000006e0
Process kswapd0 (pid: 400, threadinfo ffff8800368ce000, task ffff88003b8bf040)
Stack:
ffff88003b8bf040 ffff88001df6e528 ffff88001df6e528 ffffffffa00b46b0
ffff88003b8bf040 ffff88001df6e488 ffff88001df6e620 ffffffffa00b46b0
ffff88001ebd04c8 0000000000000004 ffff8800368cfb70 ffffffffa00b2c91
Call Trace:
[<ffffffffa00b2c91>] nfs_fscache_release_inode_cookie+0x3b/0x47 [nfs]
[<ffffffffa008f25f>] nfs_clear_inode+0x3c/0x41 [nfs]
[<ffffffffa0090df1>] nfs4_evict_inode+0x2f/0x33 [nfs]
[<ffffffff810d8d47>] evict+0xa1/0x15c
[<ffffffff810d8e2e>] dispose_list+0x2c/0x38
[<ffffffff810d9ebd>] prune_icache_sb+0x28c/0x29b
[<ffffffff810c56b7>] prune_super+0xd5/0x140
[<ffffffff8109b615>] shrink_slab+0x102/0x1ab
[<ffffffff8109d690>] balance_pgdat+0x2f2/0x595
[<ffffffff8103e009>] ? process_timeout+0xb/0xb
[<ffffffff8109dba3>] kswapd+0x270/0x289
[<ffffffff8104c5ea>] ? __init_waitqueue_head+0x46/0x46
[<ffffffff8109d933>] ? balance_pgdat+0x595/0x595
[<ffffffff8104bf7a>] kthread+0x7f/0x87
[<ffffffff813ad6b4>] kernel_thread_helper+0x4/0x10
[<ffffffff813abcdd>] ? retint_restore_args+0xe/0xe
[<ffffffff8104befb>] ? __init_kthread_worker+0x53/0x53
[<ffffffff813ad6b0>] ? gs_change+0xb/0xb
Make fscache_relinquish_cookie() log a warning and wait if there are any
outstanding reads left on the cookie it was given.
Check that the netfs isn't trying to relinquish a cookie that still has read
operations in progress upon it. If there are, then give log a warning and BUG.
Downgrade the requirements passed to the allocator in the gfp flags parameter.
FS-Cache/CacheFiles can handle OOM conditions simply by aborting the attempt to
store an object or a page in the cache.
Under some circumstances CacheFiles defers the marking of pages with PG_fscache
so that it can take advantage of pagevecs to reduce the number of calls to
fscache_mark_pages_cached() and the netfs's hook to keep track of this.
There are, however, two problems with this:
(1) It can lead to the PG_fscache mark being applied _after_ the page is set
PG_uptodate and unlocked (by the call to fscache_end_io()).
(2) CacheFiles's ref on the page is dropped immediately following
fscache_end_io() - and so may not still be held when the mark is applied.
This can lead to the page being passed back to the allocator before the
mark is applied.
Fix this by, where appropriate, marking the page before calling
fscache_end_io() and releasing the page. This means that we can't take
advantage of pagevecs and have to make a separate call for each page to the
marking routines.
The symptoms of this are Bad Page state errors cropping up under memory
pressure, for example:
BUG: Bad page state in process tar pfn:002da
page:ffffea0000009fb0 count:0 mapcount:0 mapping: (null) index:0x1447
page flags: 0x1000(private_2)
Pid: 4574, comm: tar Tainted: G W 3.1.0-rc4-fsdevel+ #1064
Call Trace:
[<ffffffff8109583c>] ? dump_page+0xb9/0xbe
[<ffffffff81095916>] bad_page+0xd5/0xea
[<ffffffff81095d82>] get_page_from_freelist+0x35b/0x46a
[<ffffffff810961f3>] __alloc_pages_nodemask+0x362/0x662
[<ffffffff810989da>] __do_page_cache_readahead+0x13a/0x267
[<ffffffff81098942>] ? __do_page_cache_readahead+0xa2/0x267
[<ffffffff81098d7b>] ra_submit+0x1c/0x20
[<ffffffff8109900a>] ondemand_readahead+0x28b/0x29a
[<ffffffff81098ee2>] ? ondemand_readahead+0x163/0x29a
[<ffffffff810990ce>] page_cache_sync_readahead+0x38/0x3a
[<ffffffff81091d8a>] generic_file_aio_read+0x2ab/0x67e
[<ffffffffa008cfbe>] nfs_file_read+0xa4/0xc9 [nfs]
[<ffffffff810c22c4>] do_sync_read+0xba/0xfa
[<ffffffff81177a47>] ? security_file_permission+0x7b/0x84
[<ffffffff810c25dd>] ? rw_verify_area+0xab/0xc8
[<ffffffff810c29a4>] vfs_read+0xaa/0x13a
[<ffffffff810c2a79>] sys_read+0x45/0x6c
[<ffffffff813ac37b>] system_call_fastpath+0x16/0x1b
As can be seen, PG_private_2 (== PG_fscache) is set in the page flags.
Instrumenting fscache_mark_pages_cached() to verify whether page->mapping was
set appropriately showed that sometimes it wasn't. This led to the discovery
that sometimes the page has apparently been reclaimed by the time the marker
got to see it.
Reported-by: M. Stevens <m@tippett.com>
Reviewed-by: Jeff Layton <jlayton@redhat.com>
The compiler, at least for ix86 and m68k, validly warns that the
comparison:
next <= (loff_t)-1
is always true (and it's always true also for x86-64 and probably all
other arches - as long as pgoff_t isn't wider than loff_t). The
intention appears to be to avoid wrapping of "next", so rather than
eliminating the pointless comparison, fix the loop to indeed get exited
when "next" would otherwise wrap.
On m68k the following warning is observed:
fs/fscache/page.c: In function '__fscache_uncache_all_inode_pages':
fs/fscache/page.c:979: warning: comparison is always false due to limited range of data type
Reported-by: Geert Uytterhoeven <geert@linux-m68k.org>
Reported-by: Jan Beulich <jbeulich@novell.com>
Signed-off-by: Jan Beulich <jbeulich@novell.com>
Cc: Suresh Jayaraman <sjayaraman@suse.de>
Cc: stable@kernel.org
Add an FS-Cache helper to bulk uncache pages on an inode. This will
only work for the circumstance where the pages in the cache correspond
1:1 with the pages attached to an inode's page cache.
This is required for CIFS and NFS: When disabling inode cookie, we were
returning the cookie and setting cifsi->fscache to NULL but failed to
invalidate any previously mapped pages. This resulted in "Bad page
state" errors and manifested in other kind of errors when running
fsstress. Fix it by uncaching mapped pages when we disable the inode
cookie.
This patch should fix the following oops and "Bad page state" errors
seen during fsstress testing.
kernel BUG at fs/cachefiles/namei.c:201!
Pid: 5, comm: kworker/u:0 Not tainted 2.6.38.7-30.fc15.x86_64 #1 Bochs Bochs
RIP: 0010: cachefiles_walk_to_object+0x436/0x745 [cachefiles]
RSP: 0018:ffff88002ce6dd00 EFLAGS: 00010282
RAX: ffff88002ef165f0 RBX: ffff88001811f500 RCX: 0000000000000000
RDX: 0000000000000000 RSI: 0000000000000100 RDI: 0000000000000282
RBP: ffff88002ce6dda0 R08: 0000000000000100 R09: ffffffff81b3a300
R10: 0000ffff00066c0a R11: 0000000000000003 R12: ffff88002ae54840
R13: ffff88002ae54840 R14: ffff880029c29c00 R15: ffff88001811f4b0
FS: 00007f394dd32720(0000) GS:ffff88002ef00000(0000) knlGS:0000000000000000
CR2: 00007fffcb62ddf8 CR3: 000000001825f000 CR4: 00000000000006e0
Process kworker/u:0 (pid: 5, threadinfo ffff88002ce6c000, task ffff88002ce55cc0)
Stack:
0000000000000246 ffff88002ce55cc0 ffff88002ce6dd58 ffff88001815dc00
ffff8800185246c0 ffff88001811f618 ffff880029c29d18 ffff88001811f380
ffff88002ce6dd50 ffffffff814757e4 ffff88002ce6dda0 ffffffff8106ac56
Call Trace:
cachefiles_lookup_object+0x78/0xd4 [cachefiles]
fscache_lookup_object+0x131/0x16d [fscache]
fscache_object_work_func+0x1bc/0x669 [fscache]
process_one_work+0x186/0x298
worker_thread+0xda/0x15d
kthread+0x84/0x8c
RIP cachefiles_walk_to_object+0x436/0x745 [cachefiles]
---[ end trace 1d481c9af1804caa ]---
I tested the uncaching by the following means:
(1) Create a big file on my NFS server (104857600 bytes).
(2) Read the file into the cache with md5sum on the NFS client. Look in
/proc/fs/fscache/stats:
Pages : mrk=25601 unc=0
(3) Open the file for read/write ("bash 5<>/warthog/bigfile"). Look in proc
again:
Pages : mrk=25601 unc=25601
Reported-by: Jeff Layton <jlayton@redhat.com>
Reviewed-and-Tested-by: Suresh Jayaraman <sjayaraman@suse.de>
cc: stable@kernel.org
There is no CONFIG_WORKQUEUE_DEBUGFS any more, so this code is dead.
Signed-off-by: WANG Cong <amwang@redhat.com>
fscache_submit_exclusive_op() adds an operation to the pending list if
other operations are pending. Fix the check for pending ops as n_ops
must be greater than 0 at the point it is checked as it is incremented
immediately before under lock.
Signed-off-by: Akshat Aranya <aranya@nec-labs.com>
Add a dummy printk function for the maintenance of unused printks through gcc
format checking, and also so that side-effect checking is maintained too.
Commit 8b8edefa (fscache: convert object to use workqueue instead of
slow-work) made fscache_exit() call unregister_sysctl_table()
unconditionally breaking build when sysctl is disabled. Fix it by
putting it inside CONFIG_SYSCTL.
Reported-by: Randy Dunlap <randy.dunlap@oracle.com>
fscache no longer uses slow-work. Drop references to it.
Make fscache operation to use only workqueue instead of combination of
workqueue and slow-work. FSCACHE_OP_SLOW is dropped and
FSCACHE_OP_FAST is renamed to FSCACHE_OP_ASYNC and uses newly added
fscache_op_wq workqueue to execute op->processor().
fscache_operation_init_slow() is dropped and fscache_operation_init()
now takes @processor argument directly.
* Unbound workqueue is used.
* fscache_retrieval_work() is no longer necessary as OP_ASYNC now does
the equivalent thing.
* sysctl fscache.operation_max_active added to control concurrency.
The default value is nr_cpus clamped between 2 and
WQ_UNBOUND_MAX_ACTIVE.
* debugfs support is dropped for now. Tracing API based debug
facility is planned to be added.
Make fscache object state transition callbacks use workqueue instead
of slow-work. New dedicated unbound CPU workqueue fscache_object_wq
is created. get/put callbacks are renamed and modified to take
@object and called directly from the enqueue wrapper and the work
function. While at it, make all open coded instances of get/put to
use fscache_get/put_object().
* work_busy() output is printed instead of slow-work flags in object
debugging outputs. They mean basically the same thing bit-for-bit.
* sysctl fscache.object_max_active added to control concurrency. The
default value is nr_cpus clamped between 4 and
* slow_work_sleep_till_thread_needed() is replaced with fscache
private implementation fscache_object_sleep_till_congested() which
waits on fscache_object_wq congestion.
fscache_write_op() makes unnecessary checks of the page variable to see if it
is NULL. It can't be NULL at those points as the kernel would already have
crashed a little higher up where we examined page->index.
Furthermore, unless radix_tree_gang_lookup_tag() can return 1 but no page, a
NULL pointer crash should not be encountered there as we can only get there if
r_t_g_l_t() returned 1.
fs/fscache/object-list.c: In function 'fscache_objlist_lookup':
fs/fscache/object-list.c:105: warning: cast to pointer from integer of different size
Order the debugfs statistics correctly. The values displayed through a
seq_printf() statement should be in the same order as the names in the
format string.
In the 'Lookups' line, objects created ('crt=') and lookups timed out
('tmo=') have their values transposed.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
CONFIG_SLOW_WORK_PROC was changed to CONFIG_SLOW_WORK_DEBUG, but not in all
instances. Change the remaining instances. This makes the debugfs file
display the time mark and the owner's description again.
Sparse complained about this missing spin_unlock()
Remove the EXPERIMENTAL flag from FS-Cache so that Ubuntu can make use of the
facility.
Signed-off-by: Christian Kujau <lists@nerdbynature.de>
Andrew Morton's compiler sees the following warning in FS-Cache:
fs/fscache/object-list.c:94: warning: 'obj' may be used uninitialized in this function
which my compiler doesn't. This is a false positive as obj can only be
used in the comparison against minobj if minobj has been set to something
other than NULL, but for that to happen, obj has to be first set to
something.
Deal with this by preclearing obj too.
Reported-by: Andrew Morton <akpm@linux-foundation.org>
Provide nop fscache_stat_d() macro if CONFIG_FSCACHE_STATS=n lest errors like
the following occur:
fs/fscache/cache.c: In function 'fscache_withdraw_cache':
fs/fscache/cache.c:386: error: implicit declaration of function 'fscache_stat_d'
fs/fscache/cache.c:386: error: 'fscache_n_cop_sync_cache' undeclared (first use in this function)
fs/fscache/cache.c:386: error: (Each undeclared identifier is reported only once
fs/fscache/cache.c:386: error: for each function it appears in.)
fs/fscache/cache.c:392: error: 'fscache_n_cop_dissociate_pages' undeclared (first use in this function)
Catch an overly long wait for an old, dying active object when we want to
replace it with a new one. The probability is that all the slow-work threads
are hogged, and the delete can't get a look in.
What we do instead is:
(1) if there's nothing in the slow work queue, we sleep until either the dying
object has finished dying or there is something in the slow work queue
behind which we can queue our object.
(2) if there is something in the slow work queue, we return ETIMEDOUT to
fscache_lookup_object(), which then puts us back on the slow work queue,
presumably behind the deletion that we're blocked by. We are then
deferred for a while until we work our way back through the queue -
without blocking a slow-work thread unnecessarily.
A backtrace similar to the following may appear in the log without this patch:
INFO: task kslowd004:5711 blocked for more than 120 seconds.
kslowd004 D 0000000000000000 0 5711 2 0x00000080
ffff88000340bb80 0000000000000046 ffff88002550d000 0000000000000000
ffff88002550d000 0000000000000007 ffff88000340bfd8 ffff88002550d2a8
000000000000ddf0 00000000000118c0 00000000000118c0 ffff88002550d2a8
Call Trace:
[<ffffffff81058e21>] ? trace_hardirqs_on+0xd/0xf
[<ffffffffa011c4d8>] ? cachefiles_wait_bit+0x0/0xd [cachefiles]
[<ffffffffa011c4e1>] cachefiles_wait_bit+0x9/0xd [cachefiles]
[<ffffffff81353153>] __wait_on_bit+0x43/0x76
[<ffffffff8111ae39>] ? ext3_xattr_get+0x1ec/0x270
[<ffffffff813531ef>] out_of_line_wait_on_bit+0x69/0x74
[<ffffffff8104c125>] ? wake_bit_function+0x0/0x2e
[<ffffffffa011bc79>] cachefiles_mark_object_active+0x203/0x23b [cachefiles]
[<ffffffffa011c209>] cachefiles_walk_to_object+0x558/0x827 [cachefiles]
[<ffffffffa011a429>] cachefiles_lookup_object+0xac/0x12a [cachefiles]
[<ffffffffa00aa1e9>] fscache_lookup_object+0x1c7/0x214 [fscache]
[<ffffffffa00aafc5>] fscache_object_state_machine+0xa5/0x52d [fscache]
[<ffffffffa00ab4ac>] fscache_object_slow_work_execute+0x5f/0xa0 [fscache]
[<ffffffff81082093>] slow_work_execute+0x18f/0x2d1
[<ffffffff8108239a>] slow_work_thread+0x1c5/0x308
[<ffffffff8104c0f1>] ? autoremove_wake_function+0x0/0x34
[<ffffffff810821d5>] ? slow_work_thread+0x0/0x308
[<ffffffff8104be91>] kthread+0x7a/0x82
[<ffffffff8100beda>] child_rip+0xa/0x20
[<ffffffff8100b87c>] ? restore_args+0x0/0x30
[<ffffffff8104be17>] ? kthread+0x0/0x82
[<ffffffff8100bed0>] ? child_rip+0x0/0x20
1 lock held by kslowd004/5711:
#0: (&sb->s_type->i_mutex_key#7/1){+.+.+.}, at: [<ffffffffa011be64>] cachefiles_walk_to_object+0x1b3/0x827 [cachefiles]
FS-Cache objects have an FSCACHE_OBJECT_EV_REQUEUE event that can theoretically
be raised to ask the state machine to requeue the object for further processing
before the work function returns to the slow-work facility.
However, fscache_object_work_execute() was clearing that bit before checking
the event mask to see whether the object has any pending events that require it
to be requeued immediately.
Instead, the bit should be cleared after the check and enqueue.
