[ Upstream commit 2a23f2b8adbe4bd584f936f7ac17a99750eed9d7 ]
Since they are of unsigned int type, it's allowed to read them
unlocked during reporting to userspace. Let's underline this fact
with READ_ONCE() macroses.
Signed-off-by: Kirill Tkhai <ktkhai@virtuozzo.com>
Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
commit 6becdb601bae2a043d7fb9762c4d48699528ea6e upstream.
syzbot is reporting NULL pointer dereference at fuse_ctl_remove_conn() [1].
Since fc->ctl_ndents is incremented by fuse_ctl_add_conn() when new_inode()
failed, fuse_ctl_remove_conn() reaches an inode-less dentry and tries to
clear d_inode(dentry)->i_private field.
Fix by only adding the dentry to the array after being fully set up.
When tearing down the control directory, do d_invalidate() on it to get rid
of any mounts that might have been added.
[1] https://syzkaller.appspot.com/bug?id=f396d863067238959c91c0b7cfc10b163638cac6
Reported-by: syzbot <syzbot+32c236387d66c4516827@syzkaller.appspotmail.com>
Fixes: bafa96541b25 ("[PATCH] fuse: add control filesystem")
Cc: <stable@vger.kernel.org> # v2.6.18
simple_fill_super() is passed an array of tree_descr structures which
describe the files to create in the filesystem's root directory. Since
these arrays are never modified intentionally, they should be 'const' so
that they are placed in .rodata and benefit from memory protection.
This patch updates the function signature and all users, and also
constifies tree_descr.name.
CURRENT_TIME macro is not appropriate for filesystems as it
doesn't use the right granularity for filesystem timestamps.
Use current_time() instead.
CURRENT_TIME is also not y2038 safe.
This is also in preparation for the patch that transitions
vfs timestamps to use 64 bit time and hence make them
y2038 safe. As part of the effort current_time() will be
extended to do range checks. Hence, it is necessary for all
file system timestamps to use current_time(). Also,
current_time() will be transitioned along with vfs to be
y2038 safe.
Note that whenever a single call to current_time() is used
to change timestamps in different inodes, it is because they
share the same time granularity.
Signed-off-by: Deepa Dinamani <deepa.kernel@gmail.com>
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
Acked-by: Felipe Balbi <balbi@kernel.org>
Acked-by: Steven Whitehouse <swhiteho@redhat.com>
Acked-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
Acked-by: David Sterba <dsterba@suse.com>
that's the bulk of filesystem drivers dealing with inodes of their own
fuse_ctl_cleanup is only called by __exit fuse_exit
Signed-off-by: Fabian Frederick <fabf@skynet.be>
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
Modify the request_module to prefix the file system type with "fs-"
and add aliases to all of the filesystems that can be built as modules
to match.
A common practice is to build all of the kernel code and leave code
that is not commonly needed as modules, with the result that many
users are exposed to any bug anywhere in the kernel.
Looking for filesystems with a fs- prefix limits the pool of possible
modules that can be loaded by mount to just filesystems trivially
making things safer with no real cost.
Using aliases means user space can control the policy of which
filesystem modules are auto-loaded by editing /etc/modprobe.d/*.conf
with blacklist and alias directives. Allowing simple, safe,
well understood work-arounds to known problematic software.
This also addresses a rare but unfortunate problem where the filesystem
name is not the same as it's module name and module auto-loading
would not work. While writing this patch I saw a handful of such
cases. The most significant being autofs that lives in the module
autofs4.
This is relevant to user namespaces because we can reach the request
module in get_fs_type() without having any special permissions, and
people get uncomfortable when a user specified string (in this case
the filesystem type) goes all of the way to request_module.
After having looked at this issue I don't think there is any
particular reason to perform any filtering or permission checks beyond
making it clear in the module request that we want a filesystem
module. The common pattern in the kernel is to call request_module()
without regards to the users permissions. In general all a filesystem
module does once loaded is call register_filesystem() and go to sleep.
Which means there is not much attack surface exposed by loading a
filesytem module unless the filesystem is mounted. In a user
namespace filesystems are not mounted unless .fs_flags = FS_USERNS_MOUNT,
which most filesystems do not set today.
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
Reported-by: Kees Cook <keescook@google.com>
gcc 4.6.3 complains about uninitialized variables in fs/fuse/control.c:
CC fs/fuse/control.o
fs/fuse/control.c: In function 'fuse_conn_congestion_threshold_write':
fs/fuse/control.c:165:29: warning: 'val' may be used uninitialized in this function [-Wuninitialized]
fs/fuse/control.c: In function 'fuse_conn_max_background_write':
fs/fuse/control.c:128:23: warning: 'val' may be used uninitialized in this function [-Wuninitialized]
fuse_conn_limit_write() will always return non-zero unless the &val
is modified, so the warning is misleading. Let the compiler know
about it by marking 'val' with 'uninitialized_var'.
Signed-off-by: Daniel Mack <zonque@gmail.com>
Cc: Brian Foster <bfoster@redhat.com>
This patch replaces the code for getting an number from a
userspace buffer by a simple call to kstroul_from_user.
This makes it easier to read and less error prone.
Signed-off-by: Peter Huewe <peterhuewe@gmx.de>
Replace remaining direct i_nlink updates with a new set_nlink()
updater function.
Tested-by: Toshiyuki Okajima <toshi.okajima@jp.fujitsu.com>
Instead of always assigning an increasing inode number in new_inode
move the call to assign it into those callers that actually need it.
For now callers that need it is estimated conservatively, that is
the call is added to all filesystems that do not assign an i_ino
by themselves. For a few more filesystems we can avoid assigning
any inode number given that they aren't user visible, and for others
it could be done lazily when an inode number is actually needed,
but that's left for later patches.
Signed-off-by: Dave Chinner <dchinner@redhat.com>
All file_operations should get a .llseek operation so we can make
nonseekable_open the default for future file operations without a
.llseek pointer.
The three cases that we can automatically detect are no_llseek, seq_lseek
and default_llseek. For cases where we can we can automatically prove that
the file offset is always ignored, we use noop_llseek, which maintains
the current behavior of not returning an error from a seek.
New drivers should normally not use noop_llseek but instead use no_llseek
and call nonseekable_open at open time. Existing drivers can be converted
to do the same when the maintainer knows for certain that no user code
relies on calling seek on the device file.
The generated code is often incorrectly indented and right now contains
comments that clarify for each added line why a specific variant was
chosen. In the version that gets submitted upstream, the comments will
be gone and I will manually fix the indentation, because there does not
seem to be a way to do that using coccinelle.
Some amount of new code is currently sitting in linux-next that should get
the same modifications, which I will do at the end of the merge window.
Many thanks to Julia Lawall for helping me learn to write a semantic
patch that does all this.
===== begin semantic patch =====
// This adds an llseek= method to all file operations,
// as a preparation for making no_llseek the default.
// The rules are
// - use no_llseek explicitly if we do nonseekable_open
// - use seq_lseek for sequential files
// - use default_llseek if we know we access f_pos
// - use noop_llseek if we know we don't access f_pos,
// but we still want to allow users to call lseek
@ open1 exists @
identifier nested_open;
nested_open(...)
nonseekable_open(...)
@ open exists@
identifier open_f;
identifier i, f;
identifier open1.nested_open;
int open_f(struct inode *i, struct file *f)
nested_open(...)
@ read disable optional_qualifier exists @
identifier read_f;
identifier f, p, s, off;
type ssize_t, size_t, loff_t;
expression E;
identifier func;
ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ read_no_fpos disable optional_qualifier exists @
identifier read_f;
... when != off
@ write @
identifier write_f;
expression E;
identifier func;
ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ write_no_fpos @
identifier write_f;
... when != off
@ fops0 @
identifier fops;
struct file_operations fops = {
@ has_llseek depends on fops0 @
identifier fops0.fops;
identifier llseek_f;
.llseek = llseek_f,
@ has_read depends on fops0 @
identifier read_f;
.read = read_f,
@ has_write depends on fops0 @
identifier write_f;
.write = write_f,
@ has_open depends on fops0 @
identifier open_f;
.open = open_f,
// use no_llseek if we call nonseekable_open
@ nonseekable1 depends on !has_llseek && has_open @
identifier nso ~= "nonseekable_open";
... .open = nso, ...
+.llseek = no_llseek, /* nonseekable */
@ nonseekable2 depends on !has_llseek @
identifier open.open_f;
... .open = open_f, ...
+.llseek = no_llseek, /* open uses nonseekable */
// use seq_lseek for sequential files
@ seq depends on !has_llseek @
identifier sr ~= "seq_read";
... .read = sr, ...
+.llseek = seq_lseek, /* we have seq_read */
// use default_llseek if there is a readdir
@ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier readdir_e;
// any other fop is used that changes pos
... .readdir = readdir_e, ...
+.llseek = default_llseek, /* readdir is present */
// use default_llseek if at least one of read/write touches f_pos
@ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read.read_f;
// read fops use offset
... .read = read_f, ...
+.llseek = default_llseek, /* read accesses f_pos */
@ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier write.write_f;
// write fops use offset
... .write = write_f, ...
+ .llseek = default_llseek, /* write accesses f_pos */
// Use noop_llseek if neither read nor write accesses f_pos
@ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read_no_fpos.read_f;
identifier write_no_fpos.write_f;
.write = write_f,
.read = read_f,
+.llseek = noop_llseek, /* read and write both use no f_pos */
@ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* write uses no f_pos */
@ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* read uses no f_pos */
@ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* no read or write fn */
===== End semantic patch =====
Cc: Julia Lawall <julia@diku.dk>
Make the max_background and congestion_threshold parameters of a FUSE
mount tunable at runtime by adding the respective knobs to its directory
within the fusectl filesystem.
Signed-off-by: Csaba Henk <csaba@gluster.com>
drop_nlink() is the API function to decrease the link count of an inode.
However, at a place the control filesystem used the decrement operator
on i_nlink directly. Fix this.
Cc: Anand Avati <avati@gluster.com>
Fix coding style errors reported by checkpatch and others. Uptdate
copyright date to 2008.
Register FUSE's backing_dev_info under sysfs with the name "fuse-MAJOR:MINOR"
Make the fuse control filesystem use s_dev instead of a fuse specific ID.
This makes it easier to match directories under /sys/fs/fuse/connections/ with
directories under /sys/class/bdi, and with actual mounts.
Many struct inode_operations in the kernel can be "const". Marking them const
moves these to the .rodata section, which avoids false sharing with potential
dirty data. In addition it'll catch accidental writes at compile time to
these shared resources.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
The BUG in fuse_ctl_add_dentry() could be triggered if the control
filesystem was unmounted and mounted again while one or more fuse
filesystems were present.
The fix is to reset the dentry counter in fuse_ctl_kill_sb().
Bug reported by Florent Mertens.
Signed-off-by: Miklos Szeredi <miklos@szeredi.hu>
Signed-off-by: Josef Sipek <jsipek@fsl.cs.sunysb.edu>
This is mostly included for parity with dec_nlink(), where we will have some
more hooks. This one should stay pretty darn straightforward for now.
Signed-off-by: Dave Hansen <haveblue@us.ibm.com>
Acked-by: Christoph Hellwig <hch@lst.de>
The following patches reduce the size of the VFS inode structure by 28 bytes
on a UP x86. (It would be more on an x86_64 system). This is a 10% reduction
in the inode size on a UP kernel that is configured in a production mode
(i.e., with no spinlock or other debugging functions enabled; if you want to
save memory taken up by in-core inodes, the first thing you should do is
disable the debugging options; they are responsible for a huge amount of bloat
in the VFS inode structure).
This patch:
The filesystem or device-specific pointer in the inode is inside a union,
which is pretty pointless given that all 30+ users of this field have been
using the void pointer. Get rid of the union and rename it to i_private, with
a comment to explain who is allowed to use the void pointer. This is just a
cleanup, but it allows us to reuse the union 'u' for something something where
the union will actually be used.
[judith@osdl.org: powerpc build fix]
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
Signed-off-by: Judith Lebzelter <judith@osdl.org>
Add a control filesystem to fuse, replacing the attributes currently exported
through sysfs. An empty directory '/sys/fs/fuse/connections' is still created
in sysfs, and mounting the control filesystem here provides backward
compatibility.
Advantages of the control filesystem over the previous solution:
- allows the object directory and the attributes to be owned by the
filesystem owner, hence letting unpriviled users abort the
filesystem connection
- does not suffer from module unload race
[akpm@osdl.org: fix this fs for recent dhowells depredations]
[akpm@osdl.org: fix 64-bit printk warnings]
