commit b48c6af2086ab2ba8a9c9b6ce9ecb34592ce500c upstream.
The test in fuse_file_llseek() "not SEEK_CUR or not SEEK_SET" always evaluates
to true.
This was introduced in 3.1 by commit 06222e49 (fs: handle SEEK_HOLE/SEEK_DATA
properly in all fs's that define their own llseek) and changed the behavior of
SEEK_CUR and SEEK_SET to always retrieve the file attributes. This is a
performance regression.
Fix the test so that it makes sense.
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
CC: Josef Bacik <josef@redhat.com>
CC: Al Viro <viro@zeniv.linux.org.uk>
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse:
fuse: check size of FUSE_NOTIFY_INVAL_ENTRY message
fuse: mark pages accessed when written to
fuse: delete dead .write_begin and .write_end aops
fuse: fix flock
fuse: fix non-ANSI void function notation
As fuse does not use the page cache library functions when userspace
writes to a file, it did not benefit from 'c8236db mm: mark page
accessed before we write_end()' that made sure pages are properly
marked accessed when written to.
Signed-off-by: Johannes Weiner <jweiner@redhat.com>
Ever since 'ea9b990 fuse: implement perform_write', the .write_begin
and .write_end aops have been dead code.
Their task - acquiring a page from the page cache, sending out a write
request and releasing the page again - is now done batch-wise to
maximize the number of pages send per userspace request.
Commit a9ff4f87 "fuse: support BSD locking semantics" overlooked a
number of issues with supporing flock locks over existing POSIX
locking infrastructure:
- it's not backward compatible, passing flock(2) calls to userspace
unconditionally (if userspace sets FUSE_POSIX_LOCKS)
- it doesn't cater for the fact that flock locks are automatically
unlocked on file release
- it doesn't take into account the fact that flock exclusive locks
(write locks) don't need an fd opened for write.
The last one invalidates the original premise of the patch that flock
locks can be emulated with POSIX locks.
This patch fixes the first two issues. The last one needs to be fixed
in userspace if the filesystem assumed that a write lock will happen
only on a file operned for write (as in the case of the current fuse
library).
Reported-by: Sebastian Pipping <webmaster@hartwork.org>
* 'for-3.1' of git://linux-nfs.org/~bfields/linux:
nfsd: don't break lease on CLAIM_DELEGATE_CUR
locks: rename lock-manager ops
nfsd4: update nfsv4.1 implementation notes
nfsd: turn on reply cache for NFSv4
nfsd4: call nfsd4_release_compoundargs from pc_release
nfsd41: Deny new lock before RECLAIM_COMPLETE done
fs: locks: remove init_once
nfsd41: check the size of request
nfsd41: error out when client sets maxreq_sz or maxresp_sz too small
nfsd4: fix file leak on open_downgrade
nfsd4: remember to put RW access on stateid destruction
NFSD: Added TEST_STATEID operation
NFSD: added FREE_STATEID operation
svcrpc: fix list-corrupting race on nfsd shutdown
rpc: allow autoloading of gss mechanisms
svcauth_unix.c: quiet sparse noise
svcsock.c: include sunrpc.h to quiet sparse noise
nfsd: Remove deprecated nfsctl system call and related code.
NFSD: allow OP_DESTROY_CLIENTID to be only op in COMPOUND
Fix up trivial conflicts in Documentation/feature-removal-schedule.txt
Btrfs needs to be able to control how filemap_write_and_wait_range() is called
in fsync to make it less of a painful operation, so push down taking i_mutex and
the calling of filemap_write_and_wait() down into the ->fsync() handlers. Some
file systems can drop taking the i_mutex altogether it seems, like ext3 and
ocfs2. For correctness sake I just pushed everything down in all cases to make
sure that we keep the current behavior the same for everybody, and then each
individual fs maintainer can make up their mind about what to do from there.
Thanks,
Acked-by: Jan Kara <jack@suse.cz>
Signed-off-by: Josef Bacik <josef@redhat.com>
This converts everybody to handle SEEK_HOLE/SEEK_DATA properly. In some cases
we just return -EINVAL, in others we do the normal generic thing, and in others
we're simply making sure that the properly due-dilligence is done. For example
in NFS/CIFS we need to make sure the file size is update properly for the
SEEK_HOLE and SEEK_DATA case, but since it calls the generic llseek stuff itself
that is all we have to do. Thanks,
Both the filesystem and the lock manager can associate operations with a
lock. Confusingly, one of them (fl_release_private) actually has the
same name in both operation structures.
It would save some confusion to give the lock-manager ops different
names.
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
If a fuse dev connection is broken, wake up any
processes that are blocking, in a poll system call,
on one of the files in the now defunct filesystem.
Single threaded NTFS-3G could get stuck if a delayed RELEASE reply
triggered a DESTROY request via path_put().
Fix this by
a) making RELEASE requests synchronous, whenever possible, on fuseblk
filesystems
b) if not possible (triggered by an asynchronous read/write) then do
the path_put() in a separate thread with schedule_work().
Reported-by: Oliver Neukum <oneukum@suse.de>
Cc: stable@kernel.org
In kernel ABI version 7.16 and later FUSE_IOCTL_RETRY reply from a
unrestricted IOCTL request shall return with an array of 'struct
fuse_ioctl_iovec' instead of 'struct iovec'. This fixes the ABI
ambiguity of 32bit vs. 64bit.
Reported-by: "ccmail111" <ccmail111@yahoo.com>
CC: Tejun Heo <tj@kernel.org>
Get rid of unnecessary page_address()-es.
Verify that the total length of the iovec returned in FUSE_IOCTL_RETRY
doesn't overflow iov_length().
CC: <stable@kernel.org> [2.6.31+]
If a 32bit CUSE server is run on 64bit this results in EIO being
returned to the caller.
The reason is that FUSE_IOCTL_RETRY reply was defined to use 'struct
iovec', which is different on 32bit and 64bit archs.
Work around this by looking at the size of the reply to determine
which struct was used. This is only needed if CONFIG_COMPAT is
defined.
A more permanent fix for the interface will be to use the same struct
on both 32bit and 64bit.
The attribute cache for a file was not being cleared when a file is opened
with O_TRUNC.
If the filesystem's open operation truncates the file ("atomic_o_trunc"
feature flag is set) then the kernel should invalidate the cached st_mtime
and st_ctime attributes.
Also i_size should be explicitly be set to zero as it is used sometimes
without refreshing the cache.
Signed-off-by: Ken Sumrall <ksumrall@android.com>
Cc: Anfei <anfei.zhou@gmail.com>
Cc: "Anand V. Avati" <avati@gluster.com>
Signed-off-by: Miklos Szeredi <miklos@szeredi.hu>
Cc: <stable@kernel.org>
Sparse doesn't understand lock annotations of the form
__releases(&foo->lock). Change them to __releases(foo->lock). Same
for __acquires().
Userspace filesystem can request data to be stored in the inode's
mapping. This request is synchronous and has no reply. If the write
to the fuse device returns an error then the store request was not
fully completed (but may have updated some pages).
If the stored data overflows the current file size, then the size is
extended, similarly to a write(2) on the filesystem.
Pages which have been completely stored are marked uptodate.
mm: export generic_pipe_buf_*() to modules
fuse: support splice() reading from fuse device
fuse: allow splice to move pages
mm: export remove_from_page_cache() to modules
mm: export lru_cache_add_*() to modules
fuse: support splice() writing to fuse device
fuse: get page reference for readpages
fuse: use get_user_pages_fast()
fuse: remove unneeded variable
When splicing buffers to the fuse device with SPLICE_F_MOVE, try to
move pages from the pipe buffer into the page cache. This allows
populating the fuse filesystem's cache without ever touching the page
contents, i.e. zero copy read capability.
The following steps are performed when trying to move a page into the
page cache:
- buf->ops->confirm() to make sure the new page is uptodate
- buf->ops->steal() to try to remove the new page from it's previous place
- remove_from_page_cache() on the old page
- add_to_page_cache_locked() on the new page
If any of the above steps fail (non fatally) then the code falls back
to copying the page. In particular ->steal() will fail if there are
external references (other than the page cache and the pipe buffer) to
the page.
Also since the remove_from_page_cache() + add_to_page_cache_locked()
are non-atomic it is possible that the page cache is repopulated in
between the two and add_to_page_cache_locked() will fail. This could
be fixed by creating a new atomic replace_page_cache_page() function.
fuse_readpages_end() needed to be reworked so it works even if
page->mapping is NULL for some or all pages which can happen if the
add_to_page_cache_locked() failed.
A number of sanity checks were added to make sure the stolen pages
don't have weird flags set, etc... These could be moved into generic
splice/steal code.
Acquire a page ref on pages in ->readpages() and release them when the
read has finished. Not acquiring a reference didn't seem to cause any
trouble since the page is locked and will not be kicked out of the
page cache during the read.
However the following patches will want to remove the page from the
cache so a separate ref is needed. Making the reference in req->pages
explicit also makes the code easier to understand.
Replace uses of get_user_pages() with get_user_pages_fast(). It looks
nicer and should be faster in most cases.
"map" isn't needed any more after: 0bd87182d3ab18 "fuse: fix kunmap in
fuse_ioctl_copy_user"
The cache alias problem will happen if the changes of user shared mapping
is not flushed before copying, then user and kernel mapping may be mapped
into two different cache line, it is impossible to guarantee the coherence
after iov_iter_copy_from_user_atomic. So the right steps should be:
flush_dcache_page(page);
kmap_atomic(page);
write to page;
kunmap_atomic(page);
More precisely, we might create two new APIs flush_dcache_user_page and
flush_dcache_kern_page to replace the two flush_dcache_page accordingly.
Here is a snippet tested on omap2430 with VIPT cache, and I think it is
not ARM-specific:
int val = 0x11111111;
fd = open("abc", O_RDWR);
addr = mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_SHARED, fd, 0);
*(addr+0) = 0x44444444;
tmp = *(addr+0);
*(addr+1) = 0x77777777;
write(fd, &val, sizeof(int));
close(fd);
The results are not always 0x11111111 0x77777777 at the beginning as expected. Sometimes we see 0x44444444 0x77777777.
Signed-off-by: Anfei <anfei.zhou@gmail.com>
Cc: Miklos Szeredi <miklos@szeredi.hu>
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
Cc: <linux-arch@vger.kernel.org>
Looks like another victim of the confusing kmap() vs kmap_atomic() API
differences.
Reported-by: Todor Gyumyushev <yodor1@gmail.com>
Cc: Tejun Heo <tj@kernel.org>
fuse_direct_io() has a loop where requests are allocated in each
iteration. if allocation fails, the loop is broken out and follows
into an unconditional fuse_put_request() on that invalid pointer.
Signed-off-by: Anand V. Avati <avati@gluster.com>
* mark struct vm_area_struct::vm_ops as const
* mark vm_ops in AGP code
But leave TTM code alone, something is fishy there with global vm_ops
being used.
Fix fuse_file_poll() which returned a -errno value instead of a poll
mask.
CC: stable@kernel.org
Export the following symbols for CUSE.
fuse_conn_put()
fuse_conn_get()
fuse_conn_kill()
fuse_send_init()
fuse_do_open()
fuse_sync_release()
fuse_direct_io()
fuse_do_ioctl()
fuse_file_poll()
fuse_request_alloc()
fuse_get_req()
fuse_put_request()
fuse_request_send()
fuse_abort_conn()
fuse_dev_release()
fuse_dev_operations
Use ff->fc and ff->nodeid instead of file->f_dentry->d_inode in the
fuse_file_poll() implementation.
This prepares this function for use by CUSE, where the inode is not
owned by a fuse filesystem.
Create a helper for sending an IOCTL request that doesn't use a struct
inode.
Make fuse_sync_release() a generic helper function that doesn't need a
struct inode pointer. This makes it suitable for use by CUSE.
Change return value of fuse_release_common() from int to void.
Create a helper for sending an OPEN request that doesn't need a struct
inode pointer.
Move setting ff->fh, ff->nodeid and file->private_data outside
fuse_finish_open(). Add ->open_flags member to struct fuse_file.
This simplifies the argument passing to fuse_finish_open() and
fuse_release_fill(), and paves the way for creating an open helper
that doesn't need an inode pointer.
Use ff->fc and ff->nodeid instead of passing down the inode.
Add new members ->fc and ->nodeid to struct fuse_file. This will aid
in converting functions for use by CUSE, where the inode is not owned
Move code operating on the inode out from fuse_direct_io().
Move out code from fuse_write_fill() which is not common to all
callers. Remove two function arguments which become unnecessary.
Also remove unnecessary memset(), the request is already initialized
to zero.
Use struct path instead of separate dentry and vfsmount in
req->misc.release.
* fuse_file_alloc() was structured in weird way. The success path was
split between else block and code following the block. Restructure
the code such that it's easier to read and modify.
* Unindent success path of fuse_release_common() to ease future
changes.
MAP_PRIVATE mmap could return stale data from the cache for
"direct_io" files. Fix this by flushing the cache on mmap.
Found with a slightly modified fsx-linux.
Fix the following warning:
fs/fuse/file.c: In function 'fuse_direct_io':
fs/fuse/file.c:1002: warning: passing argument 3 of 'fuse_get_user_pages' from incompatible pointer type
This was introduced by commit f4975c67 "fuse: allow kernel to access
"direct_io" files".
Allow MAP_PRIVATE mmaps of "direct_io" files. This is necessary for
execute support.
MAP_SHARED mappings require some sort of coherency between the
underlying file and the mapping. With "direct_io" it is difficult to
provide this, so for the moment just disallow shared (read-write and
read-only) mappings altogether.
Allow the kernel read and write on "direct_io" files. This is
necessary for nfs export and execute support.
The implementation is simple: if an access from the kernel is
detected, don't perform get_user_pages(), just use the kernel address
provided by the requester to copy from/to the userspace filesystem.
Change the page_mkwrite prototype to take a struct vm_fault, and return
VM_FAULT_xxx flags. There should be no functional change.
This makes it possible to return much more detailed error information to
the VM (and also can provide more information eg. virtual_address to the
driver, which might be important in some special cases).
This is required for a subsequent fix. And will also make it easier to
merge page_mkwrite() with fault() in future.
Signed-off-by: Nick Piggin <npiggin@suse.de>
Cc: Chris Mason <chris.mason@oracle.com>
Cc: Trond Myklebust <trond.myklebust@fys.uio.no>
Cc: Steven Whitehouse <swhiteho@redhat.com>
Cc: Mark Fasheh <mfasheh@suse.com>
Cc: Joel Becker <joel.becker@oracle.com>
Cc: Artem Bityutskiy <dedekind@infradead.org>
Cc: Felix Blyakher <felixb@sgi.com>
This bug was found with smatch (http://repo.or.cz/w/smatch.git/). If
we return directly the inode->i_mutex lock doesn't get released.
ff is set to NULL and then dereferenced on line 65. Compile tested only.
fuse: clean up annotations of fc->lock
fuse: fix sparse warning in ioctl
fuse: update interface version
fuse: add fuse_conn->release()
fuse: separate out fuse_conn_init() from new_conn()
fuse: add fuse_ prefix to several functions
fuse: implement poll support
fuse: implement unsolicited notification
fuse: add file kernel handle
fuse: implement ioctl support
fuse: don't let fuse_req->end() put the base reference
fuse: move FUSE_MINOR to miscdevice.h
fuse: style fixes
