path: root/fs/fuse/file.c
2013-05-07Merge branch 'akpm' (incoming from Andrew)Linus Torvalds
Merge more incoming from Andrew Morton: - Various fixes which were stalled or which I picked up recently - A large rotorooting of the AIO code. Allegedly to improve performance but I don't really have good performance numbers (I might have lost the email) and I can't raise Kent today. I held this out of 3.9 and we could give it another cycle if it's all too late/scary. I ended up taking only the first two thirds of the AIO rotorooting. I left the percpu parts and the batch completion for later. - Linus * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (33 commits) aio: don't include aio.h in sched.h aio: kill ki_retry aio: kill ki_key aio: give shared kioctx fields their own cachelines aio: kill struct aio_ring_info aio: kill batch allocation aio: change reqs_active to include unreaped completions aio: use cancellation list lazily aio: use flush_dcache_page() aio: make aio_read_evt() more efficient, convert to hrtimers wait: add wait_event_hrtimeout() aio: refcounting cleanup aio: make aio_put_req() lockless aio: do fget() after aio_get_req() aio: dprintk() -> pr_debug() aio: move private stuff out of aio.h aio: add kiocb_cancel() aio: kill return value of aio_complete() char: add aio_{read,write} to /dev/{null,zero} aio: remove retry-based AIO ...
2013-05-07aio: don't include aio.h in sched.hKent Overstreet
Faster kernel compiles by way of fewer unnecessary includes. [akpm@linux-foundation.org: fix fallout] [akpm@linux-foundation.org: fix build] Signed-off-by: Kent Overstreet <koverstreet@google.com> Cc: Zach Brown <zab@redhat.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Jens Axboe <axboe@kernel.dk> Cc: Asai Thambi S P <asamymuthupa@micron.com> Cc: Selvan Mani <smani@micron.com> Cc: Sam Bradshaw <sbradshaw@micron.com> Cc: Jeff Moyer <jmoyer@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Benjamin LaHaise <bcrl@kvack.org> Reviewed-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-07Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse Pull fuse updates from Miklos Szeredi: "This contains two patchsets from Maxim Patlasov. The first reworks the request throttling so that only async requests are throttled. Wakeup of waiting async requests is also optimized. The second series adds support for async processing of direct IO which optimizes direct IO and enables the use of the AIO userspace interface." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse: fuse: add flag to turn on async direct IO fuse: truncate file if async dio failed fuse: optimize short direct reads fuse: enable asynchronous processing direct IO fuse: make fuse_direct_io() aware about AIO fuse: add support of async IO fuse: move fuse_release_user_pages() up fuse: optimize wake_up fuse: implement exclusive wakeup for blocked_waitq fuse: skip blocking on allocations of synchronous requests fuse: add flag fc->initialized fuse: make request allocations for background processing explicit
2013-05-01fuse: add flag to turn on async direct IOMiklos Szeredi
Without async DIO write requests to a single file were always serialized. With async DIO that's no longer the case. So don't turn on async DIO by default for fear of breaking backward compatibility. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2013-04-18fuse: truncate file if async dio failedMaxim Patlasov
The patch improves error handling in fuse_direct_IO(): if we successfully submitted several fuse requests on behalf of synchronous direct write extending file and some of them failed, let's try to do our best to clean-up. Changed in v2: reuse fuse_do_setattr(). Thanks to Brian for suggestion. Signed-off-by: Maxim Patlasov <mpatlasov@parallels.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2013-04-17fuse: optimize short direct readsMaxim Patlasov
If user requested direct read beyond EOF, we can skip sending fuse requests for positions beyond EOF because userspace would ACK them with zero bytes read anyway. We can trust to i_size in fuse_direct_IO for such cases because it's called from fuse_file_aio_read() and the latter updates fuse attributes including i_size. Signed-off-by: Maxim Patlasov <mpatlasov@parallels.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2013-04-17fuse: enable asynchronous processing direct IOMaxim Patlasov
In case of synchronous DIO request (i.e. read(2) or write(2) for a file opened with O_DIRECT), the patch submits fuse requests asynchronously, but waits for their completions before return from fuse_direct_IO(). In case of asynchronous DIO request (i.e. libaio io_submit() or a file opened with O_DIRECT), the patch submits fuse requests asynchronously and return -EIOCBQUEUED immediately. The only special case is async DIO extending file. Here the patch falls back to old behaviour because we can't return -EIOCBQUEUED and update i_size later, without i_mutex hold. And we have no method to wait on real async I/O requests. The patch also clean __fuse_direct_write() up: it's better to update i_size in its callers. Thanks Brian for suggestion. Signed-off-by: Maxim Patlasov <mpatlasov@parallels.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2013-04-17fuse: make fuse_direct_io() aware about AIOMaxim Patlasov
The patch implements passing "struct fuse_io_priv *io" down the stack up to fuse_send_read/write where it is used to submit request asynchronously. io->async==0 designates synchronous processing. Non-trivial part of the patch is changes in fuse_direct_io(): resources like fuse requests and user pages cannot be released immediately in async case. Signed-off-by: Maxim Patlasov <mpatlasov@parallels.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2013-04-17fuse: add support of async IOMaxim Patlasov
The patch implements a framework to process an IO request asynchronously. The idea is to associate several fuse requests with a single kiocb by means of fuse_io_priv structure. The structure plays the same role for FUSE as 'struct dio' for direct-io.c. The framework is supposed to be used like this: - someone (who wants to process an IO asynchronously) allocates fuse_io_priv and initializes it setting 'async' field to non-zero value. - as soon as fuse request is filled, it can be submitted (in non-blocking way) by fuse_async_req_send() - when all submitted requests are ACKed by userspace, io->reqs drops to zero triggering aio_complete() In case of IO initiated by libaio, aio_complete() will finish processing the same way as in case of dio_complete() calling aio_complete(). But the framework may be also used for internal FUSE use when initial IO request was synchronous (from user perspective), but it's beneficial to process it asynchronously. Then the caller should wait on kiocb explicitly and aio_complete() will wake the caller up. Signed-off-by: Maxim Patlasov <mpatlasov@parallels.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2013-04-17fuse: move fuse_release_user_pages() upMaxim Patlasov
fuse_release_user_pages() will be indirectly used by fuse_send_read/write in future patches. Signed-off-by: Maxim Patlasov <mpatlasov@parallels.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2013-04-17fuse: make request allocations for background processing explicitMaxim Patlasov
There are two types of processing requests in FUSE: synchronous (via fuse_request_send()) and asynchronous (via adding to fc->bg_queue). Fortunately, the type of processing is always known in advance, at the time of request allocation. This preparatory patch utilizes this fact making fuse_get_req() aware about the type. Next patches will use it. Signed-off-by: Maxim Patlasov <mpatlasov@parallels.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2013-04-09lift sb_start_write/sb_end_write out of ->aio_write()Al Viro
2013-02-27more file_inode() open-coded instancesAl Viro
2013-02-04fuse: send poll eventsEnke Chen
commit 626cf23660 "poll: add poll_requested_events()..." enabled us to send the requested events to the filesystem. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2013-01-31Do not use RCU for current process credentialsAnatol Pomozov
Commit c69e8d9c0 added rcu lock to fuse/dir.c It was assuming that 'task' is some other process but in fact this parameter always equals to 'current'. Inline this parameter to make it more readable and remove RCU lock as it is not needed when access current process credentials. Signed-off-by: Anatol Pomozov <anatol.pomozov@gmail.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2013-01-24fuse: cleanup fuse_direct_io()Miklos Szeredi
Fix the following sparse warnings: fs/fuse/file.c:1216:43: warning: cast removes address space of expression fs/fuse/file.c:1216:43: warning: incorrect type in initializer (different address spaces) fs/fuse/file.c:1216:43: expected void [noderef] <asn:1>*iov_base fs/fuse/file.c:1216:43: got void *<noident> fs/fuse/file.c:1241:43: warning: cast removes address space of expression fs/fuse/file.c:1241:43: warning: incorrect type in initializer (different address spaces) fs/fuse/file.c:1241:43: expected void [noderef] <asn:1>*iov_base fs/fuse/file.c:1241:43: got void *<noident> fs/fuse/file.c:1267:43: warning: cast removes address space of expression fs/fuse/file.c:1267:43: warning: incorrect type in initializer (different address spaces) fs/fuse/file.c:1267:43: expected void [noderef] <asn:1>*iov_base fs/fuse/file.c:1267:43: got void *<noident> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2013-01-24fuse: optimize __fuse_direct_io()Maxim Patlasov
__fuse_direct_io() allocates fuse-requests by calling fuse_get_req(fc, n). The patch calculates 'n' based on iov[] array. This is useful because allocating FUSE_MAX_PAGES_PER_REQ page pointers and descriptors for each fuse request would be waste of memory in case of iov-s of smaller size. Signed-off-by: Maxim Patlasov <mpatlasov@parallels.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2013-01-24fuse: optimize fuse_get_user_pages()Maxim Patlasov
Let fuse_get_user_pages() pack as many iov-s to a single fuse_req as possible. This is very beneficial in case of iov[] consisting of many iov-s of relatively small sizes (e.g. PAGE_SIZE). Signed-off-by: Maxim Patlasov <mpatlasov@parallels.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2013-01-24fuse: pass iov[] to fuse_get_user_pages()Maxim Patlasov
The patch makes preliminary work for the next patch optimizing scatter-gather direct IO. The idea is to allow fuse_get_user_pages() to pack as many iov-s to each fuse request as possible. So, here we only rework all related call-paths to carry iov[] from fuse_direct_IO() to fuse_get_user_pages(). Signed-off-by: Maxim Patlasov <mpatlasov@parallels.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2013-01-24fuse: use req->page_descs[] for argpages casesMaxim Patlasov
Previously, anyone who set flag 'argpages' only filled req->pages[] and set per-request page_offset. This patch re-works all cases where argpages=1 to fill req->page_descs[] properly. Having req->page_descs[] filled properly allows to re-work fuse_copy_pages() to copy page fragments described by req->page_descs[]. This will be useful for next patches optimizing direct_IO. Signed-off-by: Maxim Patlasov <mpatlasov@parallels.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2013-01-24fuse: add per-page descriptor <offset, length> to fuse_reqMaxim Patlasov
The ability to save page pointers along with lengths and offsets in fuse_req will be useful to cover several iovec-s with a single fuse_req. Per-request page_offset is removed because anybody who need it can use req->page_descs[0].offset instead. Signed-off-by: Maxim Patlasov <mpatlasov@parallels.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2013-01-24fuse: rework fuse_do_ioctl()Maxim Patlasov
fuse_do_ioctl() already calculates the number of pages it's going to use. It is stored in 'num_pages' variable. So the patch simply uses it for allocating fuse_req. Signed-off-by: Maxim Patlasov <mpatlasov@parallels.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2013-01-24fuse: rework fuse_perform_write()Maxim Patlasov
The patch allocates as many page pointers in fuse_req as needed to cover interval [pos .. pos+len-1]. Inline helper fuse_wr_pages() is introduced to hide this cumbersome arithmetic. Signed-off-by: Maxim Patlasov <mpatlasov@parallels.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2013-01-24fuse: rework fuse_readpages()Maxim Patlasov
The patch uses 'nr_pages' argument of fuse_readpages() as heuristics for the number of page pointers to allocate. This can be improved further by taking in consideration fc->max_read and gaps between page indices, but it's not clear whether it's worthy or not. Signed-off-by: Maxim Patlasov <mpatlasov@parallels.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2013-01-24fuse: categorize fuse_get_req()Maxim Patlasov
The patch categorizes all fuse_get_req() invocations into two categories: - fuse_get_req_nopages(fc) - when caller doesn't care about req->pages - fuse_get_req(fc, n) - when caller need n page pointers (n > 0) Adding fuse_get_req_nopages() helps to avoid numerous fuse_get_req(fc, 0) scattered over code. Now it's clear from the first glance when a caller need fuse_req with page pointers. The patch doesn't make any logic changes. In multi-page case, it silly allocates array of FUSE_MAX_PAGES_PER_REQ page pointers. This will be amended by future patches. Signed-off-by: Maxim Patlasov <mpatlasov@parallels.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2013-01-24fuse: general infrastructure for pages[] of variable sizeMaxim Patlasov
The patch removes inline array of FUSE_MAX_PAGES_PER_REQ page pointers from fuse_req. Instead of that, req->pages may now point either to small inline array or to an array allocated dynamically. This essentially means that all callers of fuse_request_alloc[_nofs] should pass the number of pages needed explicitly. The patch doesn't make any logic changes. Signed-off-by: Maxim Patlasov <mpatlasov@parallels.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2013-01-17fuse: make fuse_file_fallocate() staticMiklos Szeredi
Fix the following sparse warning: fs/fuse/file.c:2249:6: warning: symbol 'fuse_file_fallocate' was not declared. Should it be static? Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2012-12-17lseek: the "whence" argument is called "whence"Andrew Morton
But the kernel decided to call it "origin" instead. Fix most of the sites. Acked-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09mm: kill vma flag VM_CAN_NONLINEARKonstantin Khlebnikov
Move actual pte filling for non-linear file mappings into the new special vma operation: ->remap_pages(). Filesystems must implement this method to get non-linear mapping support, if it uses filemap_fault() then generic_file_remap_pages() can be used. Now device drivers can implement this method and obtain nonlinear vma support. Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Carsten Otte <cotte@de.ibm.com> Cc: Chris Metcalf <cmetcalf@tilera.com> #arch/tile Cc: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Eric Paris <eparis@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Hugh Dickins <hughd@google.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: James Morris <james.l.morris@oracle.com> Cc: Jason Baron <jbaron@redhat.com> Cc: Kentaro Takeda <takedakn@nttdata.co.jp> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Robert Richter <robert.richter@amd.com> Cc: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Cc: Venkatesh Pallipadi <venki@google.com> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-08-16Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse Pull fuse updates from Miklos Szeredi. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse: fuse: verify all ioctl retry iov elements fuse: add missing INIT flag descriptions fuse: add missing INIT flags fuse: update attributes on aio_read fuse: invalidate inode mapping if mtime changes fuse: add FUSE_AUTO_INVAL_DATA init flag
2012-08-06fuse: verify all ioctl retry iov elementsZach Brown
Commit 7572777eef78ebdee1ecb7c258c0ef94d35bad16 attempted to verify that the total iovec from the client doesn't overflow iov_length() but it only checked the first element. The iovec could still overflow by starting with a small element. The obvious fix is to check all the elements. The overflow case doesn't look dangerous to the kernel as the copy is limited by the length after the overflow. This fix restores the intention of returning an error instead of successfully copying less than the iovec represented. I found this by code inspection. I built it but don't have a test case. I'm cc:ing stable because the initial commit did as well. Signed-off-by: Zach Brown <zab@redhat.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> CC: <stable@vger.kernel.org> [2.6.37+]
2012-07-31fuse: Convert to new freezing mechanismJan Kara
Convert check in fuse_file_aio_write() to using new freeze protection. CC: fuse-devel@lists.sourceforge.net CC: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-18fuse: update attributes on aio_readBrian Foster
A fuse-based network filesystem might allow for the inode and/or file data to change unexpectedly. A local client that opens and repeatedly reads a file might never pick up on such changes and indefinitely return stale data. Always invoke fuse_update_attributes() in the read path to cause an attr revalidation when the attributes expire. This leads to a page cache invalidation if necessary and ensures fuse issues new read requests to the fuse client. The original logic (reval only on reads beyond EOF) is preserved unless the client specifies FUSE_AUTO_INVAL_DATA on init. Signed-off-by: Brian Foster <bfoster@redhat.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2012-06-05Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse Pull fuse updates from Miklos Szeredi. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse: fuse: fix blksize calculation fuse: fix stat call on 32 bit platforms fuse: optimize fallocate on permanent failure fuse: add FALLOCATE operation fuse: Convert to kstrtoul_from_user
2012-06-01fs: introduce inode operation ->update_timeJosef Bacik
Btrfs has to make sure we have space to allocate new blocks in order to modify the inode, so updating time can fail. We've gotten around this by having our own file_update_time but this is kind of a pain, and Christoph has indicated he would like to make xfs do something different with atime updates. So introduce ->update_time, where we will deal with i_version an a/m/c time updates and indicate which changes need to be made. The normal version just does what it has always done, updates the time and marks the inode dirty, and then filesystems can choose to do something different. I've gone through all of the users of file_update_time and made them check for errors with the exception of the fault code since it's complicated and I wasn't quite sure what to do there, also Jan is going to be pushing the file time updates into page_mkwrite for those who have it so that should satisfy btrfs and make it not a big deal to check the file_update_time() return code in the generic fault path. Thanks, Signed-off-by: Josef Bacik <josef@redhat.com>
2012-04-26fuse: optimize fallocate on permanent failureMiklos Szeredi
If userspace filesystem doesn't support fallocate, remember this and don't send request next time. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2012-04-25fuse: add FALLOCATE operationAnatol Pomozov
fallocate filesystem operation preallocates media space for the given file. If fallocate returns success then any subsequent write to the given range never fails with 'not enough space' error. Signed-off-by: Anatol Pomozov <anatol.pomozov@gmail.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2012-04-18Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse Pull fuse updates from Miklos Szeredi. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse: fuse: use flexible array in fuse.h fuse: allow nanosecond granularity fuse: O_DIRECT support for files fuse: fix nlink after unlink
2012-03-20fuse: remove the second argument of k[un]map_atomic()Cong Wang
Signed-off-by: Cong Wang <amwang@redhat.com>
2012-03-05fuse: O_DIRECT support for filesAnand Avati
Implement ->direct_IO() method in aops. The ->direct_IO() method combines the existing fuse_direct_read/fuse_direct_write methods to implement O_DIRECT functionality. Reaching ->direct_IO() in the read path via generic_file_aio_read ensures proper synchronization with page cache with its existing framework. Reaching ->direct_IO() in the write path via fuse_file_aio_write is made to come via generic_file_direct_write() which makes it play nice with the page cache w.r.t other mmap pages etc. On files marked 'direct_io' by the filesystem server, IO always follows the fuse_direct_read/write path. There is no effect of fcntl(O_DIRECT) and it always succeeds. On files not marked with 'direct_io' by the filesystem server, the IO path depends on O_DIRECT flag by the application. This can be passed at the time of open() as well as via fcntl(). Note that asynchronous O_DIRECT iocb jobs are completed synchronously always (this has been the case with FUSE even before this patch) Signed-off-by: Anand Avati <avati@redhat.com> Reviewed-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2011-12-13fuse: support ioctl on directoriesMiklos Szeredi
Multiplexing filesystems may want to support ioctls on the underlying files and directores (e.g. FS_IOC_{GET,SET}FLAGS). Ioctl support on directories was missing so add it now. Reported-by: Antonio SJ Musumeci <bile@landofbile.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2011-12-13fuse: Use kcalloc instead of kzalloc to allocate arrayThomas Meyer
The advantage of kcalloc is, that will prevent integer overflows which could result from the multiplication of number of elements and size and it is also a bit nicer to read. The semantic patch that makes this change is available in https://lkml.org/lkml/2011/11/25/107 Signed-off-by: Thomas Meyer <thomas@m3y3r.de> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2011-12-13fuse: llseek optimize SEEK_CUR and SEEK_SETMiklos Szeredi
Use generic_file_llseek() instead of open coding the seek function. i_mutex protection is only necessary for SEEK_END (and SEEK_HOLE, SEEK_DATA), so move SEEK_CUR and SEEK_SET out from under i_mutex. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2011-12-13fuse: llseek fix raceMiklos Szeredi
Fix race between lseek(fd, 0, SEEK_CUR) and read/write. This was fixed in generic code by commit 5b6f1eb97d (vfs: lseek(fd, 0, SEEK_CUR) race condition). Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2011-12-13fuse: fix llseek bugRoel Kluin
The test in fuse_file_llseek() "not SEEK_CUR or not SEEK_SET" always evaluates to true. This was introduced in 3.1 by commit 06222e49 (fs: handle SEEK_HOLE/SEEK_DATA properly in all fs's that define their own llseek) and changed the behavior of SEEK_CUR and SEEK_SET to always retrieve the file attributes. This is a performance regression. Fix the test so that it makes sense. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> CC: stable@vger.kernel.org CC: Josef Bacik <josef@redhat.com> CC: Al Viro <viro@zeniv.linux.org.uk>
2011-08-24Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse: fuse: check size of FUSE_NOTIFY_INVAL_ENTRY message fuse: mark pages accessed when written to fuse: delete dead .write_begin and .write_end aops fuse: fix flock fuse: fix non-ANSI void function notation
2011-08-08fuse: mark pages accessed when written toJohannes Weiner
As fuse does not use the page cache library functions when userspace writes to a file, it did not benefit from 'c8236db mm: mark page accessed before we write_end()' that made sure pages are properly marked accessed when written to. Signed-off-by: Johannes Weiner <jweiner@redhat.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2011-08-08fuse: delete dead .write_begin and .write_end aopsJohannes Weiner
Ever since 'ea9b990 fuse: implement perform_write', the .write_begin and .write_end aops have been dead code. Their task - acquiring a page from the page cache, sending out a write request and releasing the page again - is now done batch-wise to maximize the number of pages send per userspace request. Signed-off-by: Johannes Weiner <jweiner@redhat.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2011-08-08fuse: fix flockMiklos Szeredi
Commit a9ff4f87 "fuse: support BSD locking semantics" overlooked a number of issues with supporing flock locks over existing POSIX locking infrastructure: - it's not backward compatible, passing flock(2) calls to userspace unconditionally (if userspace sets FUSE_POSIX_LOCKS) - it doesn't cater for the fact that flock locks are automatically unlocked on file release - it doesn't take into account the fact that flock exclusive locks (write locks) don't need an fd opened for write. The last one invalidates the original premise of the patch that flock locks can be emulated with POSIX locks. This patch fixes the first two issues. The last one needs to be fixed in userspace if the filesystem assumed that a write lock will happen only on a file operned for write (as in the case of the current fuse library). Reported-by: Sebastian Pipping <webmaster@hartwork.org> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2011-07-25Merge branch 'for-3.1' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-3.1' of git://linux-nfs.org/~bfields/linux: nfsd: don't break lease on CLAIM_DELEGATE_CUR locks: rename lock-manager ops nfsd4: update nfsv4.1 implementation notes nfsd: turn on reply cache for NFSv4 nfsd4: call nfsd4_release_compoundargs from pc_release nfsd41: Deny new lock before RECLAIM_COMPLETE done fs: locks: remove init_once nfsd41: check the size of request nfsd41: error out when client sets maxreq_sz or maxresp_sz too small nfsd4: fix file leak on open_downgrade nfsd4: remember to put RW access on stateid destruction NFSD: Added TEST_STATEID operation NFSD: added FREE_STATEID operation svcrpc: fix list-corrupting race on nfsd shutdown rpc: allow autoloading of gss mechanisms svcauth_unix.c: quiet sparse noise svcsock.c: include sunrpc.h to quiet sparse noise nfsd: Remove deprecated nfsctl system call and related code. NFSD: allow OP_DESTROY_CLIENTID to be only op in COMPOUND Fix up trivial conflicts in Documentation/feature-removal-schedule.txt
