path: root/fs/fuse/file.c
2019-11-06fuse: truncate pending writes on O_TRUNCMiklos Szeredi
commit e4648309b85a78f8c787457832269a8712a8673e upstream. Make sure cached writes are not reordered around open(..., O_TRUNC), with the obvious wrong results. Fixes: 4d99ff8f12eb ("fuse: Turn writeback cache on") Cc: <stable@vger.kernel.org> # v3.15+ Signed-off-by: Miklos Szeredi <mszeredi@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-10-05fuse: fix missing unlock_page in fuse_writepage()Vasily Averin
commit d5880c7a8620290a6c90ced7a0e8bd0ad9419601 upstream. unlock_page() was missing in case of an already in-flight write against the same page. Signed-off-by: Vasily Averin <vvs@virtuozzo.com> Fixes: ff17be086477 ("fuse: writepage: skip already in flight") Cc: <stable@vger.kernel.org> # v3.13 Signed-off-by: Miklos Szeredi <mszeredi@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-06-09fuse: copy_file_range needs to strip setuid bits and update timestampsAmir Goldstein
Like ->write_iter(), we update mtime and strip setuid of dst file before copy and like ->read_iter(), we update atime of src file after copy. Signed-off-by: Amir Goldstein <amir73il@gmail.com> Acked-by: Miklos Szeredi <miklos@szeredi.hu> Reviewed-by: Darrick J. Wong <darrick.wong@oracle.com> Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com>
2019-06-09vfs: allow copy_file_range to copy across devicesAmir Goldstein
We want to enable cross-filesystem copy_file_range functionality where possible, so push the "same superblock only" checks down to the individual filesystem callouts so they can make their own decisions about cross-superblock copy offload and fallack to generic_copy_file_range() for cross-superblock copy. [Amir] We do not call ->remap_file_range() in case the files are not on the same sb and do not call ->copy_file_range() in case the files do not belong to the same filesystem driver. This changes behavior of the copy_file_range(2) syscall, which will now allow cross filesystem in-kernel copy. CIFS already supports cross-superblock copy, between two shares to the same server. This functionality will now be available via the copy_file_range(2) syscall. Cc: Steve French <stfrench@microsoft.com> Signed-off-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Amir Goldstein <amir73il@gmail.com> Reviewed-by: Darrick J. Wong <darrick.wong@oracle.com> Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com>
2019-06-09vfs: no fallback for ->copy_file_rangeDave Chinner
Now that we have generic_copy_file_range(), remove it as a fallback case when offloads fail. This puts the responsibility for executing fallbacks on the filesystems that implement ->copy_file_range and allows us to add operational validity checks to generic_copy_file_range(). Rework vfs_copy_file_range() to call a new do_copy_file_range() helper to execute the copying callout, and move calls to generic_file_copy_range() into filesystem methods where they currently return failures. [Amir] overlayfs is not responsible of executing the fallback. It is the responsibility of the underlying filesystem. Signed-off-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Amir Goldstein <amir73il@gmail.com> Reviewed-by: Darrick J. Wong <darrick.wong@oracle.com> Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com>
2019-05-28fuse: extract helper for range writebackMiklos Szeredi
The fuse_writeback_range() helper flushes dirty data to the userspace filesystem. When the function returns, the WRITE requests for the data in the given range have all been completed. This is not equivalent to fsync() on the given range, since the userspace filesystem may not yet have the data on stable storage. Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
2019-05-28fuse: fix copy_file_range() in the writeback caseMiklos Szeredi
Prior to sending COPY_FILE_RANGE to userspace filesystem, we must flush all dirty pages in both the source and destination files. This patch adds the missing flush of the source file. Tested on libfuse-3.5.0 with: libfuse/example/passthrough_ll /mnt/fuse/ -o writeback libfuse/test/test_syscalls /mnt/fuse/tmp/test Fixes: 88bc7d5097a1 ("fuse: add support for copy_file_range()") Cc: <stable@vger.kernel.org> # v4.20 Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
2019-05-27fuse: add FUSE_WRITE_KILL_PRIVMiklos Szeredi
In the FOPEN_DIRECT_IO case the write path doesn't call file_remove_privs() and that means setuid bit is not cleared if unpriviliged user writes to a file with setuid bit set. pjdfstest chmod test 12.t tests this and fails. Fix this by adding a flag to the FUSE_WRITE message that requests clearing privileges on the given file. This needs This better than just calling fuse_remove_privs(), because the attributes may not be up to date, so in that case a write may miss clearing the privileges. Test case: $ passthrough_ll /mnt/pasthrough-mnt -o default_permissions,allow_other,cache=never $ mkdir /mnt/pasthrough-mnt/testdir $ cd /mnt/pasthrough-mnt/testdir $ prove -rv pjdfstests/tests/chmod/12.t Reported-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Miklos Szeredi <mszeredi@redhat.com> Tested-by: Vivek Goyal <vgoyal@redhat.com>
2019-05-27fuse: fallocate: fix return with locked inodeMiklos Szeredi
Do the proper cleanup in case the size check fails. Tested with xfstests:generic/228 Reported-by: kbuild test robot <lkp@intel.com> Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Fixes: 0cbade024ba5 ("fuse: honor RLIMIT_FSIZE in fuse_file_fallocate") Cc: Liu Bo <bo.liu@linux.alibaba.com> Cc: <stable@vger.kernel.org> # v3.5 Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
2019-04-24fuse: Add ioctl flag for x32 compat ioctlIan Abbott
Currently, a CUSE server running on a 64-bit kernel can tell when an ioctl request comes from a process running a 32-bit ABI, but cannot tell whether the requesting process is using legacy IA32 emulation or x32 ABI. In particular, the server does not know the size of the client process's `time_t` type. For 64-bit kernels, the `FUSE_IOCTL_COMPAT` and `FUSE_IOCTL_32BIT` flags are currently set in the ioctl input request (`struct fuse_ioctl_in` member `flags`) for a 32-bit requesting process. This patch defines a new flag `FUSE_IOCTL_COMPAT_X32` and sets it if the 32-bit requesting process is using the x32 ABI. This allows the server process to distinguish between requests coming from client processes using IA32 emulation or the x32 ABI and so infer the size of the client process's `time_t` type and any other IA32/x32 differences. Signed-off-by: Ian Abbott <abbotti@mev.co.uk> Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
2019-04-24fuse: document fuse_fsync_in.fsync_flagsAlan Somers
The FUSE_FSYNC_DATASYNC flag was introduced by commit b6aeadeda22a ("[PATCH] FUSE - file operations") as a magic number. No new values have been added to fsync_flags since. Signed-off-by: Alan Somers <asomers@FreeBSD.org> Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
2019-04-24fuse: Add FOPEN_STREAM to use stream_open()Kirill Smelkov
Starting from commit 9c225f2655e3 ("vfs: atomic f_pos accesses as per POSIX") files opened even via nonseekable_open gate read and write via lock and do not allow them to be run simultaneously. This can create read vs write deadlock if a filesystem is trying to implement a socket-like file which is intended to be simultaneously used for both read and write from filesystem client. See commit 10dce8af3422 ("fs: stream_open - opener for stream-like files so that read and write can run simultaneously without deadlock") for details and e.g. commit 581d21a2d02a ("xenbus: fix deadlock on writes to /proc/xen/xenbus") for a similar deadlock example on /proc/xen/xenbus. To avoid such deadlock it was tempting to adjust fuse_finish_open to use stream_open instead of nonseekable_open on just FOPEN_NONSEEKABLE flags, but grepping through Debian codesearch shows users of FOPEN_NONSEEKABLE, and in particular GVFS which actually uses offset in its read and write handlers https://codesearch.debian.net/search?q=-%3Enonseekable+%3D https://gitlab.gnome.org/GNOME/gvfs/blob/1.40.0-6-gcbc54396/client/gvfsfusedaemon.c#L1080 https://gitlab.gnome.org/GNOME/gvfs/blob/1.40.0-6-gcbc54396/client/gvfsfusedaemon.c#L1247-1346 https://gitlab.gnome.org/GNOME/gvfs/blob/1.40.0-6-gcbc54396/client/gvfsfusedaemon.c#L1399-1481 so if we would do such a change it will break a real user. Add another flag (FOPEN_STREAM) for filesystem servers to indicate that the opened handler is having stream-like semantics; does not use file position and thus the kernel is free to issue simultaneous read and write request on opened file handle. This patch together with stream_open() should be added to stable kernels starting from v3.14+. This will allow to patch OSSPD and other FUSE filesystems that provide stream-like files to return FOPEN_STREAM | FOPEN_NONSEEKABLE in open handler and this way avoid the deadlock on all kernel versions. This should work because fuse_finish_open ignores unknown open flags returned from a filesystem and so passing FOPEN_STREAM to a kernel that is not aware of this flag cannot hurt. In turn the kernel that is not aware of FOPEN_STREAM will be < v3.14 where just FOPEN_NONSEEKABLE is sufficient to implement streams without read vs write deadlock. Cc: stable@vger.kernel.org # v3.14+ Signed-off-by: Kirill Smelkov <kirr@nexedi.com> Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
2019-04-24fuse: honor RLIMIT_FSIZE in fuse_file_fallocateLiu Bo
fstests generic/228 reported this failure that fuse fallocate does not honor what 'ulimit -f' has set. This adds the necessary inode_newsize_ok() check. Signed-off-by: Liu Bo <bo.liu@linux.alibaba.com> Fixes: 05ba1f082300 ("fuse: add FALLOCATE operation") Cc: <stable@vger.kernel.org> # v3.5 Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
2019-04-24fuse: fix writepages on 32bitMiklos Szeredi
Writepage requests were cropped to i_size & 0xffffffff, which meant that mmaped writes to any file larger than 4G might be silently discarded. Fix by storing the file size in a properly sized variable (loff_t instead of size_t). Reported-by: Antonio SJ Musumeci <trapexit@spawn.link> Fixes: 6eaf4782eb09 ("fuse: writepages: crop secondary requests") Cc: <stable@vger.kernel.org> # v3.13 Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
2019-02-13fuse: cache readdir calls if filesystem opts out of opendirChad Austin
If a filesystem returns ENOSYS from opendir and thus opts out of opendir and releasedir requests, it almost certainly would also like readdir results cached. Default open_flags to FOPEN_KEEP_CACHE and FOPEN_CACHE_DIR in that case. With this patch, I've measured recursive directory enumeration across large FUSE mounts to be faster than native mounts. Signed-off-by: Chad Austin <chadaustin@fb.com> Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
2019-02-13fuse: support clients that don't implement 'opendir'Chad Austin
Allow filesystems to return ENOSYS from opendir, preventing the kernel from sending opendir and releasedir messages in the future. This avoids userspace transitions when filesystems don't need to keep track of state per directory handle. A new capability flag, FUSE_NO_OPENDIR_SUPPORT, parallels FUSE_NO_OPEN_SUPPORT, indicating the new semantics for returning ENOSYS from opendir. Signed-off-by: Chad Austin <chadaustin@fb.com> Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
2019-02-13fuse: lift bad inode checks into callersMiklos Szeredi
Bad inode checks were done done in various places, and move them into fuse_file_{read|write}_iter(). Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
2019-02-13fuse: multiplex cached/direct_io file operationsMiklos Szeredi
This is cleanup, as well as allowing switching between I/O modes while the file is open in the future. Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
2019-02-13fuse add copy_file_range to direct io fopsMiklos Szeredi
Nothing preventing copy_file_range to work on files opened with FOPEN_DIRECT_IO. Fixes: 88bc7d5097a1 ("fuse: add support for copy_file_range()") Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
2019-02-13fuse: use iov_iter based generic splice helpersMiklos Szeredi
The default splice implementation is grossly inefficient and the iter based ones work just fine, so use those instead. I've measured an 8x speedup for splice write (with len = 128k). Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
2019-02-13fuse: Switch to using async direct IO for FOPEN_DIRECT_IOMartin Raiber
Switch to using the async directo IO code path in fuse_direct_read_iter() and fuse_direct_write_iter(). This is especially important in connection with loop devices with direct IO enabled as loop assumes async direct io is actually async. Signed-off-by: Martin Raiber <martin@urbackup.org> Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
2019-02-13fuse: use atomic64_t for khctrMiklos Szeredi
...to get rid of one more fc->lock use. Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
2019-02-13fuse: Introduce fi->lock to protect write related fieldsKirill Tkhai
To minimize contention of fc->lock, this patch introduces a new spinlock for protection fuse_inode metadata: fuse_inode: writectr writepages write_files queued_writes attr_version inode: i_size i_nlink i_mtime i_ctime Also, it protects the fields changed in fuse_change_attributes_common() (too many to list). Signed-off-by: Kirill Tkhai <ktkhai@virtuozzo.com> Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
2019-02-13fuse: Convert fc->attr_version into atomic64_tKirill Tkhai
This patch makes fc->attr_version of atomic64_t type, so fc->lock won't be needed to read or modify it anymore. Signed-off-by: Kirill Tkhai <ktkhai@virtuozzo.com> Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
2019-02-13fuse: Add fuse_inode argument to fuse_prepare_release()Kirill Tkhai
Here is preparation for next patches, which introduce new fi->lock for protection of ff->write_entry linked into fi->write_files. This patch just passes new argument to the function. Signed-off-by: Kirill Tkhai <ktkhai@virtuozzo.com> Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
2019-02-13fuse: Replace page without copying in fuse_writepage_in_flight()Kirill Tkhai
It looks like we can optimize page replacement and avoid copying by simple updating the request's page. [SzM: swap with new request's tmp page to avoid use after free.] Signed-off-by: Kirill Tkhai <ktkhai@virtuozzo.com> Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
2019-02-13fuse: fix leaked aux requestsMiklos Szeredi
Auxiliary requests chained on req->misc.write.next may be leaked on truncate. Free these as well if the parent request was truncated off. Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
2019-02-13fuse: only reuse auxiliary request in fuse_writepage_in_flight()Miklos Szeredi
Don't reuse the queued request, even if it only contains a single page. This is needed because previous locking changes (spliting out fiq->waitq.lock from fc->lock) broke the assumption that request will remain in FR_PENDING at least until the new page contents are copied. This fix removes a slight optimization for a rare corner case, so we really shoudln't care. Reported-by: Kirill Tkhai <ktkhai@virtuozzo.com> Fixes: fd22d62ed0c3 ("fuse: no fc->lock for iqueue parts") Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
2019-02-13fuse: clean up fuse_writepage_in_flight()Miklos Szeredi
Restructure the function to better separate the locked and the unlocked parts. Use the "old_req" local variable to mean only the queued request, and not any auxiliary requests added onto its misc.write.next list. These changes are in preparation for the following patch. Also turn BUG_ON instances into WARN_ON and add a header comment explaining what the function does. Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
2019-02-13fuse: extract fuse_find_writeback() helperMiklos Szeredi
Call this from fuse_range_is_writeback() and fuse_writepage_in_flight(). Turn a BUG_ON() into a WARN_ON() in the process. Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
2019-01-16fuse: decrement NR_WRITEBACK_TEMP on the right pageMiklos Szeredi
NR_WRITEBACK_TEMP is accounted on the temporary page in the request, not the page cache page. Fixes: 8b284dc47291 ("fuse: writepages: handle same page rewrites") Cc: <stable@vger.kernel.org> # v3.13 Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
2018-12-11fuse: continue to send FUSE_RELEASEDIR when FUSE_OPEN returns ENOSYSChad Austin
When FUSE_OPEN returns ENOSYS, the no_open bit is set on the connection. Because the FUSE_RELEASE and FUSE_RELEASEDIR paths share code, this incorrectly caused the FUSE_RELEASEDIR request to be dropped and never sent to userspace. Pass an isdir bool to distinguish between FUSE_RELEASE and FUSE_RELEASEDIR inside of fuse_file_put. Fixes: 7678ac50615d ("fuse: support clients that don't implement 'open'") Cc: <stable@vger.kernel.org> # v3.14 Signed-off-by: Chad Austin <chadaustin@fb.com> Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
2018-12-03fuse: fix fsync on directoryMiklos Szeredi
Commit ab2257e9941b ("fuse: reduce size of struct fuse_inode") moved parts of fields related to writeback on regular file and to directory caching into a union. However fuse_fsync_common() called from fuse_dir_fsync() touches some writeback related fields, resulting in a crash. Move writeback related parts from fuse_fsync_common() to fuse_fysnc(). Reported-by: Brett Girton <btgirton@gmail.com> Tested-by: Brett Girton <btgirton@gmail.com> Fixes: ab2257e9941b ("fuse: reduce size of struct fuse_inode") Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
2018-11-09fuse: fix use-after-free in fuse_direct_IO()Lukas Czerner
In async IO blocking case the additional reference to the io is taken for it to survive fuse_aio_complete(). In non blocking case this additional reference is not needed, however we still reference io to figure out whether to wait for completion or not. This is wrong and will lead to use-after-free. Fix it by storing blocking information in separate variable. This was spotted by KASAN when running generic/208 fstest. Signed-off-by: Lukas Czerner <lczerner@redhat.com> Reported-by: Zorro Lang <zlang@redhat.com> Signed-off-by: Miklos Szeredi <mszeredi@redhat.com> Fixes: 744742d692e3 ("fuse: Add reference counting for fuse_io_priv") Cc: <stable@vger.kernel.org> # v4.6
2018-11-01Merge branch 'work.afs' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull AFS updates from Al Viro: "AFS series, with some iov_iter bits included" * 'work.afs' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (26 commits) missing bits of "iov_iter: Separate type from direction and use accessor functions" afs: Probe multiple fileservers simultaneously afs: Fix callback handling afs: Eliminate the address pointer from the address list cursor afs: Allow dumping of server cursor on operation failure afs: Implement YFS support in the fs client afs: Expand data structure fields to support YFS afs: Get the target vnode in afs_rmdir() and get a callback on it afs: Calc callback expiry in op reply delivery afs: Fix FS.FetchStatus delivery from updating wrong vnode afs: Implement the YFS cache manager service afs: Remove callback details from afs_callback_break struct afs: Commit the status on a new file/dir/symlink afs: Increase to 64-bit volume ID and 96-bit vnode ID for YFS afs: Don't invoke the server to read data beyond EOF afs: Add a couple of tracepoints to log I/O errors afs: Handle EIO from delivery function afs: Fix TTL on VL server and address lists afs: Implement VL server rotation afs: Improve FS server rotation error handling ...
2018-10-24iov_iter: Use accessor functionDavid Howells
Use accessor functions to access an iterator's type and direction. This allows for the possibility of using some other method of determining the type of iterator than if-chains with bitwise-AND conditions. Signed-off-by: David Howells <dhowells@redhat.com>
2018-10-15fuse: only invalidate atime in direct readMiklos Szeredi
After sending a synchronous READ request from __fuse_direct_read() we only need to invalidate atime; none of the other attributes should be changed by a read(). Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
2018-10-01fuse: realloc page arrayMiklos Szeredi
Writeback caching currently allocates requests with the maximum number of possible pages, while the actual number of pages per request depends on a couple of factors that cannot be determined when the request is allocated (whether page is already under writeback, whether page is contiguous with previous pages already added to a request). This patch allows such requests to start with no page allocation (all pages inline) and grow the page array on demand. If the max_pages tunable remains the default value, then this will mean just one allocation that is the same size as before. If the tunable is larger, then this adds at most 3 additional memory allocations (which is generously compensated by the improved performance from the larger request). Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
2018-10-01fuse: add max_pages to init_outConstantine Shulyupin
Replace FUSE_MAX_PAGES_PER_REQ with the configurable parameter max_pages to improve performance. Old RFC with detailed description of the problem and many fixes by Mitsuo Hayasaka (mitsuo.hayasaka.hu@hitachi.com): - https://lkml.org/lkml/2012/7/5/136 We've encountered performance degradation and fixed it on a big and complex virtual environment. Environment to reproduce degradation and improvement: 1. Add lag to user mode FUSE Add nanosleep(&(struct timespec){ 0, 1000 }, NULL); to xmp_write_buf in passthrough_fh.c 2. patch UM fuse with configurable max_pages parameter. The patch will be provided latter. 3. run test script and perform test on tmpfs fuse_test() { cd /tmp mkdir -p fusemnt passthrough_fh -o max_pages=$1 /tmp/fusemnt grep fuse /proc/self/mounts dd conv=fdatasync oflag=dsync if=/dev/zero of=fusemnt/tmp/tmp \ count=1K bs=1M 2>&1 | grep -v records rm fusemnt/tmp/tmp killall passthrough_fh } Test results: passthrough_fh /tmp/fusemnt fuse.passthrough_fh \ rw,nosuid,nodev,relatime,user_id=0,group_id=0 0 0 1073741824 bytes (1.1 GB) copied, 1.73867 s, 618 MB/s passthrough_fh /tmp/fusemnt fuse.passthrough_fh \ rw,nosuid,nodev,relatime,user_id=0,group_id=0,max_pages=256 0 0 1073741824 bytes (1.1 GB) copied, 1.15643 s, 928 MB/s Obviously with bigger lag the difference between 'before' and 'after' will be more significant. Mitsuo Hayasaka, in 2012 (https://lkml.org/lkml/2012/7/5/136), observed improvement from 400-550 to 520-740. Signed-off-by: Constantine Shulyupin <const@MakeLinux.com> Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
2018-10-01fuse: reduce size of struct fuse_inodeMiklos Szeredi
Do this by grouping fields used for cached writes and putting them into a union with fileds used for cached readdir (with obviously no overlap, since we don't have hybrid objects). Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
2018-10-01fuse: allow using readdir cacheMiklos Szeredi
The cache is only used if it's completed, not while it's still being filled; this constraint could be lifted later, if it turns out to be useful. Introduce state in struct fuse_file that indicates the position within the cache. After a seek, reset the position to the beginning of the cache and search the cache for the current position. If the current position is not found in the cache, then fall back to uncached readdir. It can also happen that page(s) disappear from the cache, in which case we must also fall back to uncached readdir. Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
2018-09-28fuse: do not take fc->lock in fuse_request_send_background()Kirill Tkhai
Currently, we take fc->lock there only to check for fc->connected. But this flag is changed only on connection abort, which is very rare operation. So allow checking fc->connected under just fc->bg_lock and use this lock (as well as fc->lock) when resetting fc->connected. Signed-off-by: Kirill Tkhai <ktkhai@virtuozzo.com> Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
2018-09-28fuse: introduce fc->bg_lockKirill Tkhai
To reduce contention of fc->lock, this patch introduces bg_lock for protection of fields related to background queue. These are: max_background, congestion_threshold, num_background, active_background, bg_queue and blocked. This allows next patch to make async reads not requiring fc->lock, so async reads and writes will have better performance executed in parallel. Signed-off-by: Kirill Tkhai <ktkhai@virtuozzo.com> Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
2018-09-28fuse: add support for copy_file_range()Niels de Vos
There are several FUSE filesystems that can implement server-side copy or other efficient copy/duplication/clone methods. The copy_file_range() syscall is the standard interface that users have access to while not depending on external libraries that bypass FUSE. Signed-off-by: Niels de Vos <ndevos@redhat.com> Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
2018-08-21Merge tag 'fuse-update-4.19' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse Pull fuse update from Miklos Szeredi: "Various bug fixes and cleanups" * tag 'fuse-update-4.19' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse: fuse: reduce allocation size for splice_write fuse: use kvmalloc to allocate array of pipe_buffer structs. fuse: convert last timespec use to timespec64 fs: fuse: Adding new return type vm_fault_t fuse: simplify fuse_abort_conn() fuse: Add missed unlock_page() to fuse_readpages_fill() fuse: Don't access pipe->buffers without pipe_lock() fuse: fix initial parallel dirops fuse: Fix oops at process_init_reply() fuse: umount should wait for all requests fuse: fix unlocked access to processing queue fuse: fix double request_end()
2018-07-26fs: fuse: Adding new return type vm_fault_tSouptick Joarder
Use new return type vm_fault_t for fault handler in struct vm_operations_struct. For now, this is just documenting that the function returns a VM_FAULT value rather than an errno. Once all instances are converted, vm_fault_t will become a distinct type. commit 1c8f422059ae ("mm: change return type to vm_fault_t") Signed-off-by: Souptick Joarder <jrdr.linux@gmail.com> Reviewed-by: Matthew Wilcox <mawilcox@microsoft.com> Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
2018-07-26fuse: Add missed unlock_page() to fuse_readpages_fill()Kirill Tkhai
The above error path returns with page unlocked, so this place seems also to behave the same. Fixes: f8dbdf81821b ("fuse: rework fuse_readpages()") Signed-off-by: Kirill Tkhai <ktkhai@virtuozzo.com> Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
2018-07-21pids: Compute task_tgid using signal->leader_pidEric W. Biederman
The cost is the the same and this removes the need to worry about complications that come from de_thread and group_leader changing. __task_pid_nr_ns has been updated to take advantage of this change. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2018-02-11vfs: do bulk POLL* -> EPOLL* replacementLinus Torvalds
This is the mindless scripted replacement of kernel use of POLL* variables as described by Al, done by this script: for V in IN OUT PRI ERR RDNORM RDBAND WRNORM WRBAND HUP RDHUP NVAL MSG; do L=`git grep -l -w POLL$V | grep -v '^t' | grep -v /um/ | grep -v '^sa' | grep -v '/poll.h$'|grep -v '^D'` for f in $L; do sed -i "-es/^\([^\"]*\)\(\<POLL$V\>\)/\\1E\\2/" $f; done done with de-mangling cleanups yet to come. NOTE! On almost all architectures, the EPOLL* constants have the same values as the POLL* constants do. But they keyword here is "almost". For various bad reasons they aren't the same, and epoll() doesn't actually work quite correctly in some cases due to this on Sparc et al. The next patch from Al will sort out the final differences, and we should be all done. Scripted-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-11-29make kernel-side POLL... arch-independentAl Viro
mangle/demangle on the way to/from userland Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
