commit 0ad0b3255a08020eaf50e34ef0d6df5bdf5e09ed upstream.
fc->release is called from fuse_conn_put() which was used in the error
cleanup before fc->release was initialized.
[Jeremiah Mahler <jmmahler@gmail.com>: assign fc->release after calling
fuse_conn_init(fc) instead of before.]
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
Fixes: a325f9b92273 ("fuse: update fuse_conn_init() and separate out fuse_conn_kill()")
commit 233a01fa9c4c7c41238537e8db8434667ff28a2f upstream.
If the number in "user_id=N" or "group_id=N" mount options was larger than
INT_MAX then fuse returned EINVAL.
Fix this to handle all valid uid/gid values.
makes ->permission() and ->d_revalidate() safety in RCU mode independent
from vfsmount_lock.
...which just returns -EBUSY if a directory alias would be created.
This is to be used by fuse mkdir to make sure that a buggy or malicious
userspace filesystem doesn't do anything nasty. Previously fuse used a
private mutex for this purpose, which can now go away.
truncate_pagecache() doesn't care about old size since commit
cedabed49b39 ("vfs: Fix vmtruncate() regression"). Let's drop it.
Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
The feature prevents mistrusted filesystems (ie: FUSE mounts created by
unprivileged users) to grow a large number of dirty pages before
throttling. For such filesystems balance_dirty_pages always check bdi
counters against bdi limits. I.e. even if global "nr_dirty" is under
"freerun", it's not allowed to skip bdi checks. The only use case for now
is fuse: it sets bdi max_ratio to 1% by default and system administrators
are supposed to expect that this limit won't be exceeded.
The feature is on if a BDI is marked by BDI_CAP_STRICTLIMIT flag. A
filesystem may set the flag when it initializes its BDI.
The problematic scenario comes from the fact that nobody pays attention to
the NR_WRITEBACK_TEMP counter (i.e. number of pages under fuse
writeback). The implementation of fuse writeback releases original page
(by calling end_page_writeback) almost immediately. A fuse request queued
for real processing bears a copy of original page. Hence, if userspace
fuse daemon doesn't finalize write requests in timely manner, an
aggressive mmap writer can pollute virtually all memory by those temporary
fuse page copies. They are carefully accounted in NR_WRITEBACK_TEMP, but
nobody cares.
To make further explanations shorter, let me use "NR_WRITEBACK_TEMP
problem" as a shortcut for "a possibility of uncontrolled grow of amount
of RAM consumed by temporary pages allocated by kernel fuse to process
writeback".
The problem was very easy to reproduce. There is a trivial example
filesystem implementation in fuse userspace distribution: fusexmp_fh.c. I
added "sleep(1);" to the write methods, then recompiled and mounted it.
Then created a huge file on the mount point and run a simple program which
mmap-ed the file to a memory region, then wrote a data to the region. An
hour later I observed almost all RAM consumed by fuse writeback. Since
then some unrelated changes in kernel fuse made it more difficult to
reproduce, but it is still possible now.
Putting this theoretical happens-in-the-lab thing aside, there is another
thing that really hurts real world (FUSE) users. This is write-through
page cache policy FUSE currently uses. I.e. handling write(2), kernel
fuse populates page cache and flushes user data to the server
synchronously. This is excessively suboptimal. Pavel Emelyanov's patches
("writeback cache policy") solve the problem, but they also make resolving
NR_WRITEBACK_TEMP problem absolutely necessary. Otherwise, simply copying
a huge file to a fuse mount would result in memory starvation. Miklos,
the maintainer of FUSE, believes strictlimit feature the way to go.
And eventually putting FUSE topics aside, there is one more use-case for
strictlimit feature. Using a slow USB stick (mass storage) in a machine
with huge amount of RAM installed is a well-known pain. Let's make simple
computations. Assuming 64GB of RAM installed, existing implementation of
balance_dirty_pages will start throttling only after 9.6GB of RAM becomes
dirty (freerun == 15% of total RAM). So, the command "cp 9GB_file
/media/my-usb-storage/" may return in a few seconds, but subsequent
"umount /media/my-usb-storage/" will take more than two hours if effective
throughput of the storage is, to say, 1MB/sec.
After inclusion of strictlimit feature, it will be trivial to add a knob
(e.g. /sys/devices/virtual/bdi/x:y/strictlimit) to enable it on demand.
Manually or via udev rule. May be I'm wrong, but it seems to be quite a
natural desire to limit the amount of dirty memory for some devices we are
not fully trust (in the sense of sustainable throughput).
[akpm@linux-foundation.org: fix warning in page-writeback.c]
Signed-off-by: Maxim Patlasov <MPatlasov@parallels.com>
Cc: Jan Kara <jack@suse.cz>
Cc: Miklos Szeredi <miklos@szeredi.hu>
Cc: Wu Fengguang <fengguang.wu@intel.com>
Cc: Pavel Emelyanov <xemul@parallels.com>
Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
The way how fuse calls truncate_pagecache() from fuse_change_attributes()
is completely wrong. Because, w/o i_mutex held, we never sure whether
'oldsize' and 'attr->size' are valid by the time of execution of
truncate_pagecache(inode, oldsize, attr->size). In fact, as soon as we
released fc->lock in the middle of fuse_change_attributes(), we completely
loose control of actions which may happen with given inode until we reach
truncate_pagecache. The list of potentially dangerous actions includes
mmap-ed reads and writes, ftruncate(2) and write(2) extending file size.
The typical outcome of doing truncate_pagecache() with outdated arguments
is data corruption from user point of view. This is (in some sense)
acceptable in cases when the issue is triggered by a change of the file on
the server (i.e. externally wrt fuse operation), but it is absolutely
intolerable in scenarios when a single fuse client modifies a file without
any external intervention. A real life case I discovered by fsx-linux
looked like this:
1. Shrinking ftruncate(2) comes to fuse_do_setattr(). The latter sends
FUSE_SETATTR to the server synchronously, but before getting fc->lock ...
2. fuse_dentry_revalidate() is asynchronously called. It sends FUSE_LOOKUP
to the server synchronously, then calls fuse_change_attributes(). The
latter updates i_size, releases fc->lock, but before comparing oldsize vs
attr->size..
3. fuse_do_setattr() from the first step proceeds by acquiring fc->lock and
updating attributes and i_size, but now oldsize is equal to
outarg.attr.size because i_size has just been updated (step 2). Hence,
fuse_do_setattr() returns w/o calling truncate_pagecache().
4. As soon as ftruncate(2) completes, the user extends file size by
write(2) making a hole in the middle of file, then reads data from the hole
either by read(2) or mmap-ed read. The user expects to get zero data from
the hole, but gets stale data because truncate_pagecache() is not executed
yet.
The scenario above illustrates one side of the problem: not truncating the
page cache even though we should. Another side corresponds to truncating
page cache too late, when the state of inode changed significantly.
Theoretically, the following is possible:
1. As in the previous scenario fuse_dentry_revalidate() discovered that
i_size changed (due to our own fuse_do_setattr()) and is going to call
truncate_pagecache() for some 'new_size' it believes valid right now. But
by the time that particular truncate_pagecache() is called ...
2. fuse_do_setattr() returns (either having called truncate_pagecache() or
not -- it doesn't matter).
3. The file is extended either by write(2) or ftruncate(2) or fallocate(2).
4. mmap-ed write makes a page in the extended region dirty.
The result will be the lost of data user wrote on the fourth step.
The patch is a hotfix resolving the issue in a simplistic way: let's skip
dangerous i_size update and truncate_pagecache if an operation changing
file size is in progress. This simplistic approach looks correct for the
cases w/o external changes. And to handle them properly, more sophisticated
and intrusive techniques (e.g. NFS-like one) would be required. I'd like to
postpone it until the issue is well discussed on the mailing list(s).
Changed in v2:
- improved patch description to cover both sides of the issue.
Signed-off-by: Maxim Patlasov <mpatlasov@parallels.com>
Cc: stable@vger.kernel.org
The global variable num_physpages is scheduled to be removed, so use
totalram_pages instead of num_physpages at runtime.
Signed-off-by: Jiang Liu <jiang.liu@huawei.com>
Cc: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru>
Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org>
Cc: Patrick McHardy <kaber@trash.net>
Fix bug introduced by commit 4582a4ab2a "FUSE: Adapt readdirplus to application
usage patterns".
We need to check for a positive dentry; negative dentries are not added by
readdirplus. Secondly we need to advise the use of readdirplus on the *parent*,
otherwise the whole thing is useless. Thirdly all this is only relevant if
"readdirplus_auto" mode is selected by the filesystem.
We advise the use of readdirplus only if the dentry was still valid. If we had
to redo the lookup then there was no use in doing the -plus version.
Reported-by: Bernd Schubert <bernd.schubert@itwm.fraunhofer.de>
CC: Feng Shuo <steve.shuo.feng@gmail.com>
CC: stable@vger.kernel.org
Without async DIO write requests to a single file were always serialized.
With async DIO that's no longer the case.
So don't turn on async DIO by default for fear of breaking backward
compatibility.
A task may have at most one synchronous request allocated. So these
requests need not be otherwise limited.
The patch re-works fuse_get_req() to follow this idea.
Existing flag fc->blocked is used to suspend request allocation both in case
of many background request submitted and period of time before init_reply
arrives from userspace. Next patch will skip blocking allocations of
synchronous request (disregarding fc->blocked). This is mostly OK, but
we still need to suspend allocations if init_reply is not arrived yet. The
patch introduces flag fc->initialized which will serve this purpose.
There are two types of processing requests in FUSE: synchronous (via
fuse_request_send()) and asynchronous (via adding to fc->bg_queue).
Fortunately, the type of processing is always known in advance, at the time
of request allocation. This preparatory patch utilizes this fact making
fuse_get_req() aware about the type. Next patches will use it.
Modify the request_module to prefix the file system type with "fs-"
and add aliases to all of the filesystems that can be built as modules
to match.
A common practice is to build all of the kernel code and leave code
that is not commonly needed as modules, with the result that many
users are exposed to any bug anywhere in the kernel.
Looking for filesystems with a fs- prefix limits the pool of possible
modules that can be loaded by mount to just filesystems trivially
making things safer with no real cost.
Using aliases means user space can control the policy of which
filesystem modules are auto-loaded by editing /etc/modprobe.d/*.conf
with blacklist and alias directives. Allowing simple, safe,
well understood work-arounds to known problematic software.
This also addresses a rare but unfortunate problem where the filesystem
name is not the same as it's module name and module auto-loading
would not work. While writing this patch I saw a handful of such
cases. The most significant being autofs that lives in the module
autofs4.
This is relevant to user namespaces because we can reach the request
module in get_fs_type() without having any special permissions, and
people get uncomfortable when a user specified string (in this case
the filesystem type) goes all of the way to request_module.
After having looked at this issue I don't think there is any
particular reason to perform any filtering or permission checks beyond
making it clear in the module request that we want a filesystem
module. The common pattern in the kernel is to call request_module()
without regards to the users permissions. In general all a filesystem
module does once loaded is call register_filesystem() and go to sleep.
Which means there is not much attack surface exposed by loading a
filesytem module unless the filesystem is mounted. In a user
namespace filesystems are not mounted unless .fs_flags = FS_USERNS_MOUNT,
which most filesystems do not set today.
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
Reported-by: Kees Cook <keescook@google.com>
Pull vfs pile (part one) from Al Viro:
"Assorted stuff - cleaning namei.c up a bit, fixing ->d_name/->d_parent
locking violations, etc.
The most visible changes here are death of FS_REVAL_DOT (replaced with
"has ->d_weak_revalidate()") and a new helper getting from struct file
to inode. Some bits of preparation to xattr method interface changes.
Misc patches by various people sent this cycle *and* ocfs2 fixes from
several cycles ago that should've been upstream right then.
PS: the next vfs pile will be xattr stuff."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (46 commits)
saner proc_get_inode() calling conventions
proc: avoid extra pde_put() in proc_fill_super()
fs: change return values from -EACCES to -EPERM
fs/exec.c: make bprm_mm_init() static
ocfs2/dlm: use GFP_ATOMIC inside a spin_lock
ocfs2: fix possible use-after-free with AIO
ocfs2: Fix oops in ocfs2_fast_symlink_readpage() code path
get_empty_filp()/alloc_file() leave both ->f_pos and ->f_version zero
target: writev() on single-element vector is pointless
export kernel_write(), convert open-coded instances
fs: encode_fh: return FILEID_INVALID if invalid fid_type
kill f_vfsmnt
vfs: kill FS_REVAL_DOT by adding a d_weak_revalidate dentry op
nfsd: handle vfs_getattr errors in acl protocol
switch vfs_getattr() to struct path
default SET_PERSONALITY() in linux/elf.h
ceph: prepopulate inodes only when request is aborted
d_hash_and_lookup(): export, switch open-coded instances
9p: switch v9fs_set_create_acl() to inode+fid, do it before d_instantiate()
9p: split dropping the acls from v9fs_set_create_acl()
This patch is a follow up on below patch:
[PATCH] exportfs: add FILEID_INVALID to indicate invalid fid_type
commit: 216b6cbdcbd86b1db0754d58886b466ae31f5a63
Signed-off-by: Namjae Jeon <namjae.jeon@samsung.com>
Signed-off-by: Vivek Trivedi <t.vivek@samsung.com>
Acked-by: Steven Whitehouse <swhiteho@redhat.com>
Acked-by: Sage Weil <sage@inktank.com>
For some filesystems (e.g. GlusterFS), the cost of performing a
normal readdir and readdirplus are identical. Since adaptively
using readdirplus has no benefit for those systems, give
users/filesystems the option to control adaptive readdirplus use.
v2 of this patch incorporates Miklos's suggestion to simplify the code,
as well as improving consistency of macro names and documentation.
Signed-off-by: Eric Wong <normalperson@yhbt.net>
Use the same adaptive readdirplus mechanism as NFS:
http://permalink.gmane.org/gmane.linux.nfs/49299
If the user space implementation wants to disable readdirplus
temporarily, it could just return ENOTSUPP. Then kernel will
recall it with readdir.
Signed-off-by: Feng Shuo <steve.shuo.feng@gmail.com>
Commit c69e8d9c0 added rcu lock to fuse/dir.c It was assuming
that 'task' is some other process but in fact this parameter always
equals to 'current'. Inline this parameter to make it more readable
and remove RCU lock as it is not needed when access current process
credentials.
Signed-off-by: Anatol Pomozov <anatol.pomozov@gmail.com>
The patch categorizes all fuse_get_req() invocations into two categories:
- fuse_get_req_nopages(fc) - when caller doesn't care about req->pages
- fuse_get_req(fc, n) - when caller need n page pointers (n > 0)
Adding fuse_get_req_nopages() helps to avoid numerous fuse_get_req(fc, 0)
scattered over code. Now it's clear from the first glance when a caller need
fuse_req with page pointers.
The patch doesn't make any logic changes. In multi-page case, it silly
allocates array of FUSE_MAX_PAGES_PER_REQ page pointers. This will be amended
by future patches.
The patch removes inline array of FUSE_MAX_PAGES_PER_REQ page pointers from
fuse_req. Instead of that, req->pages may now point either to small inline
array or to an array allocated dynamically.
This essentially means that all callers of fuse_request_alloc[_nofs] should
pass the number of pages needed explicitly.
This patch implements readdirplus support in FUSE, similar to NFS.
The payload returned in the readdirplus call contains
'fuse_entry_out' structure thereby providing all the necessary inputs
for 'faking' a lookup() operation on the spot.
If the dentry and inode already existed (for e.g. in a re-run of ls -l)
then just the inode attributes timeout and dentry timeout are refreshed.
With a simple client->network->server implementation of a FUSE based
filesystem, the following performance observations were made:
Test: Performing a filesystem crawl over 20,000 files with
sh# time ls -lR /mnt
Without readdirplus:
Run 1: 18.1s
Run 2: 16.0s
Run 3: 16.2s
With readdirplus:
Run 1: 4.1s
Run 2: 3.8s
Run 3: 3.8s
The performance improvement is significant as it avoided 20,000 upcalls
calls (lookup). Cache consistency is no worse than what already is.
Signed-off-by: Anand V. Avati <avati@redhat.com>
Use kuid_t and kgid_t in struct fuse_conn and struct fuse_mount_data.
The connection between between a fuse filesystem and a fuse daemon is
established when a fuse filesystem is mounted and provided with a file
descriptor the fuse daemon created by opening /dev/fuse.
For now restrict the communication of uids and gids between the fuse
filesystem and the fuse daemon to the initial user namespace. Enforce
this by verifying the file descriptor passed to the mount of fuse was
opened in the initial user namespace. Ensuring the mount happens in
the initial user namespace is not necessary as mounts from non-initial
user namespaces are not yet allowed.
In fuse_req_init_context convert the currrent fsuid and fsgid into the
initial user namespace for the request that will be sent to the fuse
daemon.
In fuse_fill_attr convert the uid and gid passed from the fuse daemon
from the initial user namespace into kuids and kgids.
In iattr_to_fattr called from fuse_setattr convert kuids and kgids
into the uids and gids in the initial user namespace before passing
them to the fuse filesystem.
In fuse_change_attributes_common called from fuse_dentry_revalidate,
fuse_permission, fuse_geattr, and fuse_setattr, and fuse_iget convert
the uid and gid from the fuse daemon into a kuid and a kgid to store
on the fuse inode.
By default fuse mounts are restricted to task whose uid, suid, and
euid matches the fuse user_id and whose gid, sgid, and egid matches
the fuse group id. Convert the user_id and group_id mount options
into kuids and kgids at mount time, and use uid_eq and gid_eq to
compare the in fuse_allow_task.
There's no reason to call rcu_barrier() on every
deactivate_locked_super(). We only need to make sure that all delayed rcu
free inodes are flushed before we destroy related cache.
Removing rcu_barrier() from deactivate_locked_super() affects some fast
paths. E.g. on my machine exit_group() of a last process in IPC
namespace takes 0.07538s. rcu_barrier() takes 0.05188s of that time.
fuse_conn_kill() removed fc->entry, called fuse_ctl_remove_conn() and
fuse_bdi_destroy(). None of which is appropriate for cuse cleanup.
The fuse_ctl_remove_conn() decrements the nlink on the control filesystem, which
is totally bogus. The others are harmless but unnecessary.
So move these out from fuse_conn_kill() to fuse_put_super() where they belong.
Add missing flags that userspace derived from the protocol version number. This
makes the protocol more flexible.
We currently invalidate the inode address space mapping
if the file size changes unexpectedly. In the case of a
fuse network filesystem, a portion of a file could be
overwritten remotely without changing the file size.
Compare the old mtime as well to detect this condition
and invalidate the mapping if the file has been updated.
The original logic (to ignore changes in mtime) is
preserved unless the client specifies FUSE_AUTO_INVAL_DATA
on init.
Signed-off-by: Brian Foster <bfoster@redhat.com>
FUSE_AUTO_INVAL_DATA is provided to enable updated/auto cache
invalidation logic.
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse
Pull fuse updates from Miklos Szeredi.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse:
fuse: fix blksize calculation
fuse: fix stat call on 32 bit platforms
fuse: optimize fallocate on permanent failure
fuse: add FALLOCATE operation
fuse: Convert to kstrtoul_from_user
pass inode + parent's inode or NULL instead of dentry + bool saying
whether we want the parent or not.
NOTE: that needs ceph fix folded in.
Pull writeback tree from Wu Fengguang:
"Mainly from Jan Kara to avoid iput() in the flusher threads."
* tag 'writeback' of git://git.kernel.org/pub/scm/linux/kernel/git/wfg/linux:
writeback: Avoid iput() from flusher thread
vfs: Rename end_writeback() to clear_inode()
vfs: Move waiting for inode writeback from end_writeback() to evict_inode()
writeback: Refactor writeback_single_inode()
writeback: Remove wb->list_lock from writeback_single_inode()
writeback: Separate inode requeueing after writeback
writeback: Move I_DIRTY_PAGES handling
writeback: Move requeueing when I_SYNC set to writeback_sb_inodes()
writeback: Move clearing of I_SYNC into inode_sync_complete()
writeback: initialize global_dirty_limit
fs: remove 8 bytes of padding from struct writeback_control on 64 bit builds
mm: page-writeback.c: local functions should not be exposed globally
Now we store attr->ino at inode->i_ino, return attr->ino at the
first time and then return inode->i_ino if the attribute timeout
isn't expired. That's wrong on 32 bit platforms because attr->ino
is 64 bit and inode->i_ino is 32 bit in this case.
Fix this by saving 64 bit ino in fuse_inode structure and returning
it every time we call getattr. Also squash attr->ino into inode->i_ino
explicitly.
Signed-off-by: Pavel Shilovsky <piastry@etersoft.ru>
After we moved inode_sync_wait() from end_writeback() it doesn't make sense
to call the function end_writeback() anymore. Rename it to clear_inode()
which well says what the function really does - set I_CLEAR flag.
Signed-off-by: Fengguang Wu <fengguang.wu@intel.com>
fuse: use flexible array in fuse.h
fuse: allow nanosecond granularity
fuse: O_DIRECT support for files
fuse: fix nlink after unlink
Derrik Pates reports that an utimensat with a NULL argument results in the
current time being sent from the kernel with 1 second granularity.
Reported-by: Derrik Pates <demon@now.ai>
Seeing that just about every destructor got that INIT_LIST_HEAD() copied into
it, there is no point whatsoever keeping this INIT_LIST_HEAD in inode_init_once();
the cost of taking it into inode_init_always() will be negligible for pipes
and sockets and negative for everything else. Not to mention the removal of
boilerplate code from ->destroy_inode() instances...
same story as with ubifs
Replace remaining direct i_nlink updates with a new set_nlink()
updater function.
Tested-by: Toshiyuki Okajima <toshi.okajima@jp.fujitsu.com>
Commit 37fb3a30b4 ("fuse: fix flock") added in 3.1-rc4 caused flock() to
fail with ENOSYS with the kernel ABI version 7.16 or earlier.
Fix by falling back to testing FUSE_POSIX_LOCKS for ABI versions 7.16
and earlier.
Reported-by: Martin Ziegler <ziegler@email.mathematik.uni-freiburg.de>
Tested-by: Martin Ziegler <ziegler@email.mathematik.uni-freiburg.de>
fuse: check size of FUSE_NOTIFY_INVAL_ENTRY message
fuse: mark pages accessed when written to
fuse: delete dead .write_begin and .write_end aops
fuse: fix flock
fuse: fix non-ANSI void function notation
Commit a9ff4f87 "fuse: support BSD locking semantics" overlooked a
number of issues with supporing flock locks over existing POSIX
locking infrastructure:
- it's not backward compatible, passing flock(2) calls to userspace
unconditionally (if userspace sets FUSE_POSIX_LOCKS)
- it doesn't cater for the fact that flock locks are automatically
unlocked on file release
- it doesn't take into account the fact that flock exclusive locks
(write locks) don't need an fd opened for write.
The last one invalidates the original premise of the patch that flock
locks can be emulated with POSIX locks.
This patch fixes the first two issues. The last one needs to be fixed
in userspace if the filesystem assumed that a write lock will happen
only on a file operned for write (as in the case of the current fuse
library).
Reported-by: Sebastian Pipping <webmaster@hartwork.org>
Caching "we have already removed suid/caps" was overenthusiastic as merged.
On network filesystems we might have had suid/caps set on another client,
silently picked by this client on revalidate, all of that *without* clearing
the S_NOSEC flag.
AFAICS, the only reasonably sane way to deal with that is
* new superblock flag; unless set, S_NOSEC is not going to be set.
* local block filesystems set it in their ->mount() (more accurately,
mount_bdev() does, so does btrfs ->mount(), users of mount_bdev() other than
local block ones clear it)
* if any network filesystem (or a cluster one) wants to use S_NOSEC,
it'll need to set MS_NOSEC in sb->s_flags *AND* take care to clear S_NOSEC when
inode attribute changes are picked from other clients.
It's not an earth-shattering hole (anybody that can set suid on another client
will almost certainly be able to write to the file before doing that anyway),
but it's a bug that needs fixing.
Fix void function parameter list sparse warning:
fs/fuse/inode.c:74:44: warning: non-ANSI function declaration of function 'fuse_alloc_forget'
* 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-block: (65 commits)
Documentation/iostats.txt: bit-size reference etc.
cfq-iosched: removing unnecessary think time checking
cfq-iosched: Don't clear queue stats when preempt.
blk-throttle: Reset group slice when limits are changed
blk-cgroup: Only give unaccounted_time under debug
cfq-iosched: Don't set active queue in preempt
block: fix non-atomic access to genhd inflight structures
block: attempt to merge with existing requests on plug flush
block: NULL dereference on error path in __blkdev_get()
cfq-iosched: Don't update group weights when on service tree
fs: assign sb->s_bdi to default_backing_dev_info if the bdi is going away
block: Require subsystems to explicitly allocate bio_set integrity mempool
jbd2: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging
jbd: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging
fs: make fsync_buffers_list() plug
mm: make generic_writepages() use plugging
blk-cgroup: Add unaccounted time to timeslice_used.
block: fixup plugging stubs for !CONFIG_BLOCK
block: remove obsolete comments for blkdev_issue_zeroout.
blktrace: Use rq->cmd_flags directly in blk_add_trace_rq.
Fix up conflicts in fs/{aio.c,super.c}
The exportfs encode handle function should return the minimum required
handle size. This helps user to find out the handle size by passing 0
handle size in the first step and then redoing to the call again with
the returned handle size value.
Acked-by: Serge Hallyn <serue@us.ibm.com>
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Code has been converted over to the new explicit on-stack plugging,
and delay users have been converted to use the new API for that.
So lets kill off the old plugging along with aops->sync_page().
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
fuse: fix ioctl ABI
fuse: allow batching of FORGET requests
fuse: separate queue for FORGET requests
fuse: ioctl cleanup
Fix up trivial conflict in fs/fuse/inode.c due to RCU lookup having done
the RCU-freeing of the inode in fuse_destroy_inode().
