path: root/fs/fuse
2012-01-05Linux 3.1.7Varun Wadekar
Change-Id: I99507d7cfdcee064f808856dc2ce99d806fd864f
2011-12-21fuse: fix llseek bugRoel Kluin
commit b48c6af2086ab2ba8a9c9b6ce9ecb34592ce500c upstream. The test in fuse_file_llseek() "not SEEK_CUR or not SEEK_SET" always evaluates to true. This was introduced in 3.1 by commit 06222e49 (fs: handle SEEK_HOLE/SEEK_DATA properly in all fs's that define their own llseek) and changed the behavior of SEEK_CUR and SEEK_SET to always retrieve the file attributes. This is a performance regression. Fix the test so that it makes sense. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> CC: Josef Bacik <josef@redhat.com> CC: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-21fuse: fix fuse_retrieveMiklos Szeredi
commit 48706d0a91583d08c56e7ef2a7602d99c8d4133f upstream. Fix two bugs in fuse_retrieve(): - retrieving more than one page would yield repeated instances of the first page - if more than FUSE_MAX_PAGES_PER_REQ pages were requested than the request page array would overflow fuse_retrieve() was added in 2.6.36 and these bugs had been there since the beginning. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-30fuse: Freeze client on suspend when request sent to userspaceTodd Poynor
Suspend attempts can abort when the FUSE daemon is already frozen and a client is waiting uninterruptibly for a response, causing freezing of tasks to fail. Use the freeze-friendly wait API, but disregard other signals. Change-Id: Icefb7e4bbc718ccb76bf3c04daaa5eeea7e0e63c Signed-off-by: Todd Poynor <toddpoynor@google.com>
2011-09-12fuse: fix memory leakMiklos Szeredi
kmemleak is reporting that 32 bytes are being leaked by FUSE: unreferenced object 0xe373b270 (size 32): comm "fusermount", pid 1207, jiffies 4294707026 (age 2675.187s) hex dump (first 32 bytes): 01 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ backtrace: [<b05517d7>] kmemleak_alloc+0x27/0x50 [<b0196435>] kmem_cache_alloc+0xc5/0x180 [<b02455be>] fuse_alloc_forget+0x1e/0x20 [<b0245670>] fuse_alloc_inode+0xb0/0xd0 [<b01b1a8c>] alloc_inode+0x1c/0x80 [<b01b290f>] iget5_locked+0x8f/0x1a0 [<b0246022>] fuse_iget+0x72/0x1a0 [<b02461da>] fuse_get_root_inode+0x8a/0x90 [<b02465cf>] fuse_fill_super+0x3ef/0x590 [<b019e56f>] mount_nodev+0x3f/0x90 [<b0244e95>] fuse_mount+0x15/0x20 [<b019d1bc>] mount_fs+0x1c/0xc0 [<b01b5811>] vfs_kern_mount+0x41/0x90 [<b01b5af9>] do_kern_mount+0x39/0xd0 [<b01b7585>] do_mount+0x2e5/0x660 [<b01b7966>] sys_mount+0x66/0xa0 This leak report is consistent and happens once per boot on 3.1.0-rc5-dirty. This happens if a FORGET request is queued after the fuse device was released. Reported-by: Sitsofe Wheeler <sitsofe@yahoo.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Tested-by: Sitsofe Wheeler <sitsofe@yahoo.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-09-12fuse: fix flock breakageMiklos Szeredi
Commit 37fb3a30b4 ("fuse: fix flock") added in 3.1-rc4 caused flock() to fail with ENOSYS with the kernel ABI version 7.16 or earlier. Fix by falling back to testing FUSE_POSIX_LOCKS for ABI versions 7.16 and earlier. Reported-by: Martin Ziegler <ziegler@email.mathematik.uni-freiburg.de> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Tested-by: Martin Ziegler <ziegler@email.mathematik.uni-freiburg.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-24Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse: fuse: check size of FUSE_NOTIFY_INVAL_ENTRY message fuse: mark pages accessed when written to fuse: delete dead .write_begin and .write_end aops fuse: fix flock fuse: fix non-ANSI void function notation
2011-08-24fuse: check size of FUSE_NOTIFY_INVAL_ENTRY messageMiklos Szeredi
FUSE_NOTIFY_INVAL_ENTRY didn't check the length of the write so the message processing could overrun and result in a "kernel BUG at fs/fuse/dev.c:629!" Reported-by: Han-Wen Nienhuys <hanwenn@gmail.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> CC: stable@kernel.org
2011-08-08fuse: mark pages accessed when written toJohannes Weiner
As fuse does not use the page cache library functions when userspace writes to a file, it did not benefit from 'c8236db mm: mark page accessed before we write_end()' that made sure pages are properly marked accessed when written to. Signed-off-by: Johannes Weiner <jweiner@redhat.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2011-08-08fuse: delete dead .write_begin and .write_end aopsJohannes Weiner
Ever since 'ea9b990 fuse: implement perform_write', the .write_begin and .write_end aops have been dead code. Their task - acquiring a page from the page cache, sending out a write request and releasing the page again - is now done batch-wise to maximize the number of pages send per userspace request. Signed-off-by: Johannes Weiner <jweiner@redhat.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2011-08-08fuse: fix flockMiklos Szeredi
Commit a9ff4f87 "fuse: support BSD locking semantics" overlooked a number of issues with supporing flock locks over existing POSIX locking infrastructure: - it's not backward compatible, passing flock(2) calls to userspace unconditionally (if userspace sets FUSE_POSIX_LOCKS) - it doesn't cater for the fact that flock locks are automatically unlocked on file release - it doesn't take into account the fact that flock exclusive locks (write locks) don't need an fd opened for write. The last one invalidates the original premise of the patch that flock locks can be emulated with POSIX locks. This patch fixes the first two issues. The last one needs to be fixed in userspace if the filesystem assumed that a write lock will happen only on a file operned for write (as in the case of the current fuse library). Reported-by: Sebastian Pipping <webmaster@hartwork.org> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2011-07-25Merge branch 'for-3.1' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-3.1' of git://linux-nfs.org/~bfields/linux: nfsd: don't break lease on CLAIM_DELEGATE_CUR locks: rename lock-manager ops nfsd4: update nfsv4.1 implementation notes nfsd: turn on reply cache for NFSv4 nfsd4: call nfsd4_release_compoundargs from pc_release nfsd41: Deny new lock before RECLAIM_COMPLETE done fs: locks: remove init_once nfsd41: check the size of request nfsd41: error out when client sets maxreq_sz or maxresp_sz too small nfsd4: fix file leak on open_downgrade nfsd4: remember to put RW access on stateid destruction NFSD: Added TEST_STATEID operation NFSD: added FREE_STATEID operation svcrpc: fix list-corrupting race on nfsd shutdown rpc: allow autoloading of gss mechanisms svcauth_unix.c: quiet sparse noise svcsock.c: include sunrpc.h to quiet sparse noise nfsd: Remove deprecated nfsctl system call and related code. NFSD: allow OP_DESTROY_CLIENTID to be only op in COMPOUND Fix up trivial conflicts in Documentation/feature-removal-schedule.txt
2011-07-20fs: push i_mutex and filemap_write_and_wait down into ->fsync() handlersJosef Bacik
Btrfs needs to be able to control how filemap_write_and_wait_range() is called in fsync to make it less of a painful operation, so push down taking i_mutex and the calling of filemap_write_and_wait() down into the ->fsync() handlers. Some file systems can drop taking the i_mutex altogether it seems, like ext3 and ocfs2. For correctness sake I just pushed everything down in all cases to make sure that we keep the current behavior the same for everybody, and then each individual fs maintainer can make up their mind about what to do from there. Thanks, Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20fs: handle SEEK_HOLE/SEEK_DATA properly in all fs's that define their own llseekJosef Bacik
This converts everybody to handle SEEK_HOLE/SEEK_DATA properly. In some cases we just return -EINVAL, in others we do the normal generic thing, and in others we're simply making sure that the properly due-dilligence is done. For example in NFS/CIFS we need to make sure the file size is update properly for the SEEK_HOLE and SEEK_DATA case, but since it calls the generic llseek stuff itself that is all we have to do. Thanks, Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20locks: rename lock-manager opsJ. Bruce Fields
Both the filesystem and the lock manager can associate operations with a lock. Confusingly, one of them (fl_release_private) actually has the same name in both operation structures. It would save some confusion to give the lock-manager ops different names. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-07-20no need to check for LOOKUP_OPEN in ->create() instancesAl Viro
... it will be set in nd->flag for all cases with non-NULL nd (i.e. when called from do_last()). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20don't transliterate lower bits of ->intent.open.flags to FMODE_...Al Viro
->create() instances are much happier that way... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20->permission() sanitizing: don't pass flags to ->permission()Al Viro
not used by the instances anymore. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20->permission() sanitizing: don't pass flags to generic_permission()Al Viro
redundant; all callers get it duplicated in mask & MAY_NOT_BLOCK and none of them removes that bit. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20kill check_acl callback of generic_permission()Al Viro
its value depends only on inode and does not change; we might as well store it in ->i_op->check_acl and be done with that. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-06-03more conservative S_NOSEC handlingAl Viro
Caching "we have already removed suid/caps" was overenthusiastic as merged. On network filesystems we might have had suid/caps set on another client, silently picked by this client on revalidate, all of that *without* clearing the S_NOSEC flag. AFAICS, the only reasonably sane way to deal with that is * new superblock flag; unless set, S_NOSEC is not going to be set. * local block filesystems set it in their ->mount() (more accurately, mount_bdev() does, so does btrfs ->mount(), users of mount_bdev() other than local block ones clear it) * if any network filesystem (or a cluster one) wants to use S_NOSEC, it'll need to set MS_NOSEC in sb->s_flags *AND* take care to clear S_NOSEC when inode attribute changes are picked from other clients. It's not an earth-shattering hole (anybody that can set suid on another client will almost certainly be able to write to the file before doing that anyway), but it's a bug that needs fixing. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-06-01fuse: fix non-ANSI void function notationRandy Dunlap
Fix void function parameter list sparse warning: fs/fuse/inode.c:74:44: warning: non-ANSI function declaration of function 'fuse_alloc_forget' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2011-05-28fuse: remove unnecessary dentry_unhash on rmdir, dir renameSage Weil
Fuse has no problems with references to unlinked directories. CC: Miklos Szeredi <miklos@szeredi.hu> CC: fuse-devel@lists.sourceforge.net Signed-off-by: Sage Weil <sage@newdream.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (25 commits) cifs: remove unnecessary dentry_unhash on rmdir/rename_dir ocfs2: remove unnecessary dentry_unhash on rmdir/rename_dir exofs: remove unnecessary dentry_unhash on rmdir/rename_dir nfs: remove unnecessary dentry_unhash on rmdir/rename_dir ext2: remove unnecessary dentry_unhash on rmdir/rename_dir ext3: remove unnecessary dentry_unhash on rmdir/rename_dir ext4: remove unnecessary dentry_unhash on rmdir/rename_dir btrfs: remove unnecessary dentry_unhash in rmdir/rename_dir ceph: remove unnecessary dentry_unhash calls vfs: clean up vfs_rename_other vfs: clean up vfs_rename_dir vfs: clean up vfs_rmdir vfs: fix vfs_rename_dir for FS_RENAME_DOES_D_MOVE filesystems libfs: drop unneeded dentry_unhash vfs: update dentry_unhash() comment vfs: push dentry_unhash on rename_dir into file systems vfs: push dentry_unhash on rmdir into file systems vfs: remove dget() from dentry_unhash() vfs: dentry_unhash immediately prior to rmdir vfs: Block mmapped writes while the fs is frozen ...
2011-05-26vfs: push dentry_unhash on rename_dir into file systemsSage Weil
Only a few file systems need this. Start by pushing it down into each rename method (except gfs2 and xfs) so that it can be dealt with on a per-fs basis. Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Sage Weil <sage@newdream.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-26vfs: push dentry_unhash on rmdir into file systemsSage Weil
Only a few file systems need this. Start by pushing it down into each fs rmdir method (except gfs2 and xfs) so it can be dealt with on a per-fs basis. This does not change behavior for any in-tree file systems. Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Sage Weil <sage@newdream.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-10fuse: fix oops in revalidate when called with NULL nameidataMiklos Szeredi
Some cases (e.g. ecryptfs) can call ->dentry_revalidate with NULL nameidata. https://bugzilla.kernel.org/show_bug.cgi?id=34732 Tyler Hicks pointed out that this bug was introduced by commit e7c0a16786 "fuse: make fuse_dentry_revalidate() RCU aware" Reported-by: Witold Baryluk <baryluk@smp.if.uj.edu.pl> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2011-03-24Merge branch 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-block: (65 commits) Documentation/iostats.txt: bit-size reference etc. cfq-iosched: removing unnecessary think time checking cfq-iosched: Don't clear queue stats when preempt. blk-throttle: Reset group slice when limits are changed blk-cgroup: Only give unaccounted_time under debug cfq-iosched: Don't set active queue in preempt block: fix non-atomic access to genhd inflight structures block: attempt to merge with existing requests on plug flush block: NULL dereference on error path in __blkdev_get() cfq-iosched: Don't update group weights when on service tree fs: assign sb->s_bdi to default_backing_dev_info if the bdi is going away block: Require subsystems to explicitly allocate bio_set integrity mempool jbd2: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging jbd: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging fs: make fsync_buffers_list() plug mm: make generic_writepages() use plugging blk-cgroup: Add unaccounted time to timeslice_used. block: fixup plugging stubs for !CONFIG_BLOCK block: remove obsolete comments for blkdev_issue_zeroout. blktrace: Use rq->cmd_flags directly in blk_add_trace_rq. ... Fix up conflicts in fs/{aio.c,super.c}
2011-03-22mm: add replace_page_cache_page() functionMiklos Szeredi
This function basically does: remove_from_page_cache(old); page_cache_release(old); add_to_page_cache_locked(new); Except it does this atomically, so there's no possibility for the "add" to fail because of a race. If memory cgroups are enabled, then the memory cgroup charge is also moved from the old page to the new. This function is currently used by fuse to move pages into the page cache on read, instead of copying the page contents. [minchan.kim@gmail.com: add freepage() hook to replace_page_cache_page()] Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Acked-by: Rik van Riel <riel@redhat.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Minchan Kim <minchan.kim@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse: fuse: make fuse_dentry_revalidate() RCU aware fuse: make fuse_permission() RCU aware fuse: wakeup pollers on connection release/abort fuse: reduce size of struct fuse_request
2011-03-21fuse: make fuse_dentry_revalidate() RCU awareMiklos Szeredi
Only bail out of fuse_dentry_revalidate() on LOOKUP_RCU when blocking is actually necessary. CC: Nick Piggin <npiggin@gmail.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2011-03-21fuse: make fuse_permission() RCU awareMiklos Szeredi
Only bail out of fuse_permission() on IPERM_FLAG_RCU when blocking is actually necessary. CC: Nick Piggin <npiggin@gmail.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2011-03-21fuse: wakeup pollers on connection release/abortBryan Green
If a fuse dev connection is broken, wake up any processes that are blocking, in a poll system call, on one of the files in the now defunct filesystem. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2011-03-21fuse: reduce size of struct fuse_requestMiklos Szeredi
Reduce the size of struct fuse_request by removing cuse_init_out from the request structure and allocating it dinamically instead. CC: Tejun Heo <tj@kernel.org> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2011-03-18Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (47 commits) doc: CONFIG_UNEVICTABLE_LRU doesn't exist anymore Update cpuset info & webiste for cgroups dcdbas: force SMI to happen when expected arch/arm/Kconfig: remove one to many l's in the word. asm-generic/user.h: Fix spelling in comment drm: fix printk typo 'sracth' Remove one to many n's in a word Documentation/filesystems/romfs.txt: fixing link to genromfs drivers:scsi Change printk typo initate -> initiate serial, pch uart: Remove duplicate inclusion of linux/pci.h header fs/eventpoll.c: fix spelling mm: Fix out-of-date comments which refers non-existent functions drm: Fix printk typo 'failled' coh901318.c: Change initate to initiate. mbox-db5500.c Change initate to initiate. edac: correct i82975x error-info reported edac: correct i82975x mci initialisation edac: correct commented info fs: update comments to point correct document target: remove duplicate include of target/target_core_device.h from drivers/target/target_core_hba.c ... Trivial conflict in fs/eventpoll.c (spelling vs addition)
2011-03-14exportfs: Return the minimum required handle sizeAneesh Kumar K.V
The exportfs encode handle function should return the minimum required handle size. This helps user to find out the handle size by passing 0 handle size in the first step and then redoing to the call again with the returned handle size value. Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-10fuse: fix d_revalidate oopsen on NFS exportsAl Viro
can't blindly check nd->flags in ->d_revalidate() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-10Merge branch 'for-2.6.39/stack-plug' into for-2.6.39/coreJens Axboe
Conflicts: block/blk-core.c block/blk-flush.c drivers/md/raid1.c drivers/md/raid10.c drivers/md/raid5.c fs/nilfs2/btnode.c fs/nilfs2/mdt.c Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-10block: remove per-queue pluggingJens Axboe
Code has been converted over to the new explicit on-stack plugging, and delay users have been converted to use the new API for that. So lets kill off the old plugging along with aops->sync_page(). Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-02-25fuse: fix truncate after openMiklos Szeredi
Commit e1181ee6 "vfs: pass struct file to do_truncate on O_TRUNC opens" broke the behavior of open(O_TRUNC|O_RDONLY) in fuse. Fuse assumed that when called from open, a truncate() will be done, not an ftruncate(). Fix by restoring the old behavior, based on the ATTR_OPEN flag. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2011-02-25fuse: fix hang of single threaded fuseblk filesystemMiklos Szeredi
Single threaded NTFS-3G could get stuck if a delayed RELEASE reply triggered a DESTROY request via path_put(). Fix this by a) making RELEASE requests synchronous, whenever possible, on fuseblk filesystems b) if not possible (triggered by an asynchronous read/write) then do the path_put() in a separate thread with schedule_work(). Reported-by: Oliver Neukum <oneukum@suse.de> Cc: stable@kernel.org Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2011-02-15fuse/cuse: fix comment typo initilaizationPaul Bolle
Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Reviewed-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-01-12switch fuseAl Viro
2011-01-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse: fuse: fix ioctl ABI fuse: allow batching of FORGET requests fuse: separate queue for FORGET requests fuse: ioctl cleanup Fix up trivial conflict in fs/fuse/inode.c due to RCU lookup having done the RCU-freeing of the inode in fuse_destroy_inode().
2011-01-07fs: provide rcu-walk aware permission i_opsNick Piggin
Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: rcu-walk aware d_revalidate methodNick Piggin
Require filesystems be aware of .d_revalidate being called in rcu-walk mode (nd->flags & LOOKUP_RCU). For now do a simple push down, returning -ECHILD from all implementations. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: dcache reduce branches in lookup pathNick Piggin
Reduce some branches and memory accesses in dcache lookup by adding dentry flags to indicate common d_ops are set, rather than having to check them. This saves a pointer memory access (dentry->d_op) in common path lookup situations, and saves another pointer load and branch in cases where we have d_op but not the particular operation. Patched with: git grep -E '[.>]([[:space:]])*d_op([[:space:]])*=' | xargs sed -e 's/\([^\t ]*\)->d_op = \(.*\);/d_set_d_op(\1, \2);/' -e 's/\([^\t ]*\)\.d_op = \(.*\);/d_set_d_op(\&\1, \2);/' -i Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: icache RCU free inodesNick Piggin
RCU free the struct inode. This will allow: - Subsequent store-free path walking patch. The inode must be consulted for permissions when walking, so an RCU inode reference is a must. - sb_inode_list_lock to be moved inside i_lock because sb list walkers who want to take i_lock no longer need to take sb_inode_list_lock to walk the list in the first place. This will simplify and optimize locking. - Could remove some nested trylock loops in dcache code - Could potentially simplify things a bit in VM land. Do not need to take the page lock to follow page->mapping. The downsides of this is the performance cost of using RCU. In a simple creat/unlink microbenchmark, performance drops by about 10% due to inability to reuse cache-hot slab objects. As iterations increase and RCU freeing starts kicking over, this increases to about 20%. In cases where inode lifetimes are longer (ie. many inodes may be allocated during the average life span of a single inode), a lot of this cache reuse is not applicable, so the regression caused by this patch is smaller. The cache-hot regression could largely be avoided by using SLAB_DESTROY_BY_RCU, however this adds some complexity to list walking and store-free path walking, so I prefer to implement this at a later date, if it is shown to be a win in real situations. I haven't found a regression in any non-micro benchmark so I doubt it will be a problem. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2010-12-07fuse: fix ioctl ABIMiklos Szeredi
In kernel ABI version 7.16 and later FUSE_IOCTL_RETRY reply from a unrestricted IOCTL request shall return with an array of 'struct fuse_ioctl_iovec' instead of 'struct iovec'. This fixes the ABI ambiguity of 32bit vs. 64bit. Reported-by: "ccmail111" <ccmail111@yahoo.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> CC: Tejun Heo <tj@kernel.org>
