This patch is a performance improvement for GFS2 in a clustered
environment. It makes the glock hold time self-adjusting.
Signed-off-by: Bob Peterson <rpeterso@redhat.com>
Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
This patch adds a cache for the hash table to the directory code
in order to help simplify the way in which the hash table is
accessed. This is intended to be a first step towards introducing
some performance improvements in the directory code.
There are two follow ups that I'm hoping to see fairly shortly. One
is to simplify the hash table reading code now that we always read the
complete hash table, whether we want one entry or all of them. The
other is to introduce readahead on the heads of the hash chains
which are referred to from the table.
The hash table is a maximum of 128k in size, so it is not worth trying
to read it in small chunks.
There is a potential race during filesystem mounting which has recently
been reported. It occurs when the userland gfs_controld is able to
process requests fast enough that it tries to use the sysfs interface
before the lock module is properly initialised. This is a pretty
unusual case as normally the lock module initialisation is very quick
compared with gfs_controld.
This patch adds an interruptible completion which is used to ensure that
userland will wait for the initialisation of the lock module to
complete.
There are other potential solutions to this problem, but this is the
quickest at this stage and has been tested both with and without
mount.gfs2 present in the system.
Reported-by: David Booher <dbooher@adams.net>
The VFS superblock structure now has a UUID field, so we can use that
in preference to the UUID field in the GFS2 superblock now.
This patch adds writeback_control to writing back the AIL
list. This means that we can then take advantage of the
information we get in ->write_inode() in order to set off
some pre-emptive writeback.
In addition, the AIL code is cleaned up a bit to make it
a bit simpler to understand.
There is still more which can usefully be done in this area,
but this is a good start at least.
The GLF_LRU flag introduced in the previous patch can be
used to check if a glock is on the lru list when a new
holder is queued and if so remove it, without having first
to get the lru_lock.
The main purpose of this patch however is to optimise the
glocks left over when an inode at end of life is being
evicted. Previously such glocks were left with the GLF_LFLUSH
flag set, so that when reclaimed, each one required a log flush.
This patch resets the GLF_LFLUSH flag when there is nothing
left to flush thus preventing later log flushes as glocks are
reused or demoted.
In order to do this, we need to keep track of the number of
revokes which are outstanding, and also to clear the GLF_LFLUSH
bit after a log commit when only revokes have been processed.
This adds support for two new flags. One keeps track of whether
the glock is on the LRU list or not. The other isn't really a
flag as such, but an indication of whether the glock has an
attached object or not. This indication is reported without
any locking, which is ok since we do not dereference the object
pointer but merely report whether it is NULL or not.
Also, this fixes one place where a tracepoint was missing, which
was at the point we remove deallocated blocks from the journal.
The log lock is currently used to protect the AIL lists and
the movements of buffers into and out of them. The lists
are self contained and no log specific items outside the
lists are accessed when starting or emptying the AIL lists.
Hence the operation of the AIL does not require the protection
of the log lock so split them out into a new AIL specific lock
to reduce the amount of traffic on the log lock. This will
also reduce the amount of serialisation that occurs when
the gfs2_logd pushes on the AIL to move it forward.
This reduces the impact of log pushing on sequential write
throughput.
Signed-off-by: Dave Chinner <dchinner@redhat.com>
Immediately after being synced to disk, cached quotas are zeroed out and a
subsequent access of the cached quotas results in incorrect zero values. This
meant that gfs2 assumed the actual usage to be the zero (or near-zero) usage
values it found in the cached quotas and comparison against warn/limits never
triggered a quota violation.
This patch adds a new flag QDF_REFRESH that is set after a sync so that the
cached quotas are forcefully refreshed from disk on a subsequent access on
seeing this flag set.
Resolves: rhbz#675944
Signed-off-by: Abhi Das <adas@redhat.com>
This has a number of advantages:
- Reduces contention on the hash table lock
- Makes the code smaller and simpler
- Should speed up glock dumps when under load
- Removes ref count changing in examine_bucket
- No longer need hash chain lock in glock_put() in common case
There are some further changes which this enables and which
we may do in the future. One is to look at using SLAB_RCU,
and another is to look at using a per-cpu counter for the
per-sb glock counter, since that is touched twice in the
lifetime of each glock (but only used at umount time).
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Remove kobject.h from files which don't need it, notably,
sched.h and fs.h.
We can only merge the fields into a bitfield if the locking
rules for them are the same. In this case gl_spin covers all
of the fields (write side) but a couple of them are used
with GLF_LOCK as the read side lock, which should be ok
since we know that the field in question won't be changing
at the time.
The gl_req setting has to be done earlier (in glock.c) in order
to place it under gl_spin. The gl_reply setting also has to be
brought under gl_spin in order to comply with the new rules.
This saves 4*sizeof(unsigned int) per glock.
Cc: Bob Peterson <rpeterso@redhat.com>
Recently a feature was added to GFS2 to allow journal id allocation
via sysfs. This patch builds upon that so that a negative journal id
will be treated as an error code to be passed back as the return code
from mount. This allows termination of the mount process if there is
a failure.
Also, the process has been updated so that the kernel will wait
for a journal id, even in the "spectator" case. This is required
in order to avoid mounting a filesystem in case there is an error
while joining the cluster. In the spectator case, 0 is written into
the file to indicate that all is well, and that mount should continue.
This option has never done anything useful. Also at the same time
this cleans up the sb checks which are done at mount time. The
debug option will be accepted, but ignored in future. Since it
didn't do anything, there didn't seem much point in retaining it.
This option defaulted to on for lock_nolock mounts and off
otherwise. The only function was to avoid the revalidation of
dentries. In the cluster case, that is entirely pointless and
liable to cause coherency problems.
The patch changes the revalidation to depend upon whether the
fs is a local or cluster fs (i.e. it follows the existing default
behaviour). I very much doubt anybody ever used this option as
there is no reason to. Even so we will continue to accept it
on the mount command line, but ignore it.
This is been a no-op for a very long time now. I'm pretty sure
nobody uses it, but just in case we'll still accept it on the
Due to the design of the VFS, it is quite usual for operations on GFS2
to consist of a lookup (requiring a shared lock) followed by an
operation requiring an exclusive lock. If a remote node has cached an
exclusive lock, then it will receive two demote events in rapid succession
firstly for a shared lock and then to unlocked. The existing min hold time
code was triggering in this case, even if the node was otherwise idle
since the state change time was being updated by the initial demote.
This patch introduces logic to skip the min hold timer in the case that
a "double demote" of this kind has occurred. The min hold timer will
still be used in all other cases.
A new glock flag is introduced which is used to keep track of whether
there have been any newly queued holders since the last glock state
change. The min hold time is only applied if the flag is set.
Tested-by: Abhijith Das <adas@redhat.com>
This patch adds support for fallocate to gfs2. Since the gfs2 does not support
uninitialized data blocks, it must write out zeros to all the blocks. However,
since it does not need to lock any pages to read from, gfs2 can write out the
zero blocks much more efficiently. On a moderately full filesystem, fallocate
works around 5 times faster on average. The fallocate call also allows gfs2 to
add blocks to the file without changing the filesize, which will make it
possible for gfs2 to preallocate space for the rindex file, so that gfs2 can
grow a completely full filesystem.
Signed-off-by: Benjamin Marzinski <bmarzins@redhat.com>
With the update of the truncate code, ip->i_disksize and
inode->i_size are merely copies of each other. This means
we can remove ip->i_disksize and use inode->i_size exclusively
reducing the size of a GFS2 inode by 8 bytes.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: (55 commits)
workqueue: mark init_workqueues() as early_initcall()
workqueue: explain for_each_*cwq_cpu() iterators
fscache: fix build on !CONFIG_SYSCTL
slow-work: kill it
gfs2: use workqueue instead of slow-work
drm: use workqueue instead of slow-work
cifs: use workqueue instead of slow-work
fscache: drop references to slow-work
fscache: convert operation to use workqueue instead of slow-work
fscache: convert object to use workqueue instead of slow-work
workqueue: fix how cpu number is stored in work->data
workqueue: fix mayday_mask handling on UP
workqueue: fix build problem on !CONFIG_SMP
workqueue: fix locking in retry path of maybe_create_worker()
async: use workqueue for worker pool
workqueue: remove WQ_SINGLE_CPU and use WQ_UNBOUND instead
workqueue: implement unbound workqueue
workqueue: prepare for WQ_UNBOUND implementation
libata: take advantage of cmwq and remove concurrency limitations
workqueue: fix worker management invocation without pending works
Fixed up conflicts in fs/cifs/* as per Tejun. Other trivial conflicts in
include/linux/workqueue.h, kernel/trace/Kconfig and kernel/workqueue.c
This patch implements a wait for the journal id in the case that it has
not been specified on the command line. This is to allow the future
removal of the mount.gfs2 helper. The journal id would instead be
directly communicated by gfs_controld to the file system. Here is a
comparison of the two systems:
Current:
1. mount calls mount.gfs2
2. mount.gfs2 connects to gfs_controld to retrieve the journal id
3. mount.gfs2 adds the journal id to the mount command line and calls
the mount system call
4. gfs_controld receives the status of the mount request via a uevent
Proposed:
1. mount calls the mount system call (no mount.gfs2 helper)
2. gfs_controld receives a uevent for a gfs2 fs which it doesn't know
about already
3. gfs_controld assigns a journal id to it via sysfs
4. the mount system call then completes as normal (sending a uevent
according to status)
The advantage of the proposed system is that it is completely backward
compatible with the current system both at the kernel and at the
userland levels. The "first" parameter can also be set the same way,
with the restriction that it must be set before the journal id is
assigned.
In addition, if mount becomes stuck waiting for a reply from
gfs_controld which never arrives, then it is killable and will abort the
mount gracefully.
Workqueue can now handle high concurrency. Convert gfs to use
workqueue instead of slow-work.
* Steven pointed out that recovery path might be run from allocation
path and thus requires forward progress guarantee without memory
allocation. Create and use gfs_recovery_wq with rescuer. Please
note that forward progress wasn't guaranteed with slow-work.
* Updated to use non-reentrant workqueue.
Acked-by: Steven Whitehouse <swhiteho@redhat.com>
The following patch adds a message to indicate when barriers have been
disabled due to a block device which doesn't support them. You could
already tell this via the mount options in /proc/mounts, but all the
other filesystems also log a message at the same time.
Also, the same mechanisms are used to indicate when the lock
demote interface has been used (only ever used for debugging)
which is a request from our support team.
This patch contains various tweaks to how log flushes and active item writeback
work. gfs2_logd is now managed by a waitqueue, and gfs2_log_reseve now waits
for gfs2_logd to do the log flushing. Multiple functions were rewritten to
remove the need to call gfs2_log_lock(). Instead of using one test to see if
gfs2_logd had work to do, there are now seperate tests to check if there
are two many buffers in the incore log or if there are two many items on the
active items list.
This patch is a port of a patch Steve Whitehouse wrote about a year ago, with
some minor changes. Since gfs2_ail1_start always submits all the active items,
it no longer needs to keep track of the first ai submitted, so this has been
removed. In gfs2_log_reserve(), the order of the calls to
prepare_to_wait_exclusive() and wake_up() when firing off the logd thread has
been switched. If it called wake_up first there was a small window for a race,
where logd could run and return before gfs2_log_reserve was ready to get woken
up. If gfs2_logd ran, but did not free up enough blocks, gfs2_log_reserve()
would be left waiting for gfs2_logd to eventualy run because it timed out.
Finally, gt_logd_secs, which controls how long to wait before gfs2_logd times
out, and flushes the log, can now be set on mount with ar_commit.
GFS2 tracks the number of revokes and unrevokes that are part of committed
transactions via sd_log_commited_revoke. It is possible for one process to add
revokes during its transaction, while another process unrevokes them during its
transaction. If the second process finishes its transaction first,
sd_log_commited_revoke will be decremented by the number of unrevokes that the
second process did, without first being incremented by the number of revokes
the first process did. This is fine, since all started transactions must be
completed before the journal can be flushed. However, sd_log_commited_revoke
is an unsigned integer, and log_refund() causes an assertion failure if it
would go negative at the end of a transaction. This patch makes
sd_log_commited_revoke a signed integer and allows it to go negative.
__gfs2_log_flush() still checks that it mataches the actual number of revokes.
As a consequence of the previous patch, we can now remove the
loop which used to be required due to the circular dependency
between the inodes and glocks. Instead we can just invalidate
the inodes, and then clear up any glocks which are left.
Also we no longer need the rwsem since there is no longer any
danger of the inode invalidation calling back into the glock
code (and from there back into the inode code).
Since the start of GFS2, an "extra" inode has been used to store
the metadata belonging to each inode. The only reason for using
this inode was to have an extra address space, the other fields
were unused. This means that the memory usage was rather inefficient.
The reason for keeping each inode's metadata in a separate address
space is that when glocks are requested on remote nodes, we need to
be able to efficiently locate the data and metadata which relating
to that glock (inode) in order to sync or sync and invalidate it
(depending on the remotely requested lock mode).
This patch adds a new type of glock, which has in addition to
its normal fields, has an address space. This applies to all
inode and rgrp glocks (but to no other glock types which remain
as before). As a result, we no longer need to have the second
inode.
This results in three major improvements:
1. A saving of approx 25% of memory used in caching inodes
2. A removal of the circular dependency between inodes and glocks
3. No confusion between "normal" and "metadata" inodes in super.c
Although the first of these is the more immediately apparent, the
second is just as important as it now enables a number of clean
ups at umount time. Those will be the subject of future patches.
This patch adds a wait on umount between the point at which we
dispose of all glocks and the point at which we unmount the
lock protocol. This ensures that we've received all the replies
to our unlock requests before we stop the locking.
Reported-by: Fabio M. Di Nitto <fdinitto@redhat.com>
Currently gfs2 issues barrier unconditionally. There are various reasons
to disable them, be that just for testing or for stupid devices flushing
large battert backed caches. Add a nobarrier option that matches xfs and
btrfs for this. Also add a symmetric barrier option to turn it back on
at remount time.
GFS2 now has three new mount options, statfs_quantum, quota_quantum and
statfs_percent. statfs_quantum and quota_quantum simply allow you to
set the tunables of the same name. Setting setting statfs_quantum to 0
will also turn on the statfs_slow tunable. statfs_percent accepts an
integer between 0 and 100. Numbers between 1 and 100 will cause GFS2 to
do any early sync when the local number of blocks free changes by at
least statfs_percent from the totoal number of blocks free. Setting
statfs_percent to 0 disables this.
The /sys/fs/gfs2/<fsname>/lock_module/id file has been unused for
some time now, so we can remove it. We still accept the mount option
though, as userspace still sends that.
The inum structure used throughout GFS2 has two fields. One
no_addr is the disk block number of the inode in question and
is used everywhere as the inode number. The other, no_formal_ino,
is used only as the generation number for NFS.
Historically the no_formal_ino field was set using a complicated
system of one global and one per-node file containing inode numbers
in order to ensure that each no_formal_ino was unique. Also this
code made no provision for what would happen when eventually the
(64 bit) numbers ran out. Now I know that is pretty unlikely to
happen given the large space of numbers, but it is possible
nevertheless.
The only guarantee required for no_formal_ino is that, for any
single inode, the same number doesn't get reused too quickly.
We already have a generation number which is kept in the inode
and initialised from a counter in the resource group (almost
no overhead, since we have to touch the resource group anyway
in order to allocate an inode in the first place). Aside from
ensuring that we never use the value 0 in the no_formal_ino
field, we can use that counter directly.
As a result of that change, we lose about 200 lines of code and
also gain about 10 creates/sec on the postmark benchmark (on
my test machine).
This patch adds "-o errors=panic" and "-o errors=withdraw" to the
gfs2 mount options. The "errors=withdraw" option is today's
current behaviour, meaning to withdraw from the file system if a
non-serious gfs2 error occurs. The new "errors=panic" option
tells gfs2 to force a kernel panic if a non-serious gfs2 file
system error occurs. This may be useful, for example, where
fabric-level fencing is used that has no way to reboot (such as
fence_scsi).
When a file is deleted from a gfs2 filesystem on one node, a dcache
entry for it may still exist on other nodes in the cluster. If this
happens, gfs2 will be unable to free this file on disk. Because of this,
it's possible to have a gfs2 filesystem with no files on it and no free
space. With this patch, when a node receives a callback notifying it
that the file is being deleted on another node, it schedules a new
workqueue thread to remove the file's dcache entry.
This patch increases the frequency with which gfs2 looks
for unlinked, but still allocated inodes. Its the equivalent
operation to ext3's orphan list, but done with bitmaps in
the resource groups.
This also fixes a bug where a field in the rgrp was too small.
During block allocation, it is useful to know if sections of disk
are full on a finer grained basis than a single resource group.
This can make a performance difference when resource groups have
larger numbers of bitmap blocks, since we no longer have to search
them all block by block in each individual bitmap.
The full flag is set on a per-bitmap basis when it has been
searched and found to have no free space. It is then skipped in
subsequent searches until the flag is reset. The resetting
occurs if we have to drop the glock on the resource group for any
reason, or if we deallocate some blocks within that resource
group and thus free up some space.
This patch improves the error handling in the case where we
discover that the summary information in the resource group
doesn't match the bitmap information while in the process of
allocating blocks. Originally this resulted in a kernel bug,
but this patch changes that so that we return -EIO and print
some messages explaining what went wrong, and how to fix it.
We also remember locally not to try and allocate from the
same rgrp again, so that a subsequent allocation in a
different rgrp should succeed.
This patch fixes a race condition where we can receive recovery
requests part way through processing a umount. This was causing
problems since the recovery thread had already gone away.
Looking in more detail at the recovery code, it was really trying
to implement a slight variation on a work queue, and that happens to
align nicely with the recently introduced slow-work subsystem. As a
result I've updated the code to use slow-work, rather than its own home
grown variety of work queue.
When using the wait_on_bit() function, I noticed that the wait function
that was supplied as an argument was appearing in the WCHAN field, so
I've updated the function names in order to produce more meaningful
output.
It has always been possible to adjust the gfs2 log commit
interval, but only from the sysfs interface. This adds a
mount option, commit=<nn>, which will be familar to ext3
users.
The sysfs interface continues to be available as well, although
this might be removed in the future.
Also this patch cleans up some duplicated structures in the GFS2
sysfs code.
After calling out to the dlm, GFS2 sets the new state of a glock to
gl_target in gdlm_ast(). However, gl_target is not always the lock
state that was requested. If a conversion from shared to exclusive
fails, finish_xmote() will call do_xmote() with LM_ST_UNLOCKED, instead
of gl->gl_target, so that it can reacquire the lock in exlusive the next
time around. In this case, setting the lock to gl_target in gdlm_ast()
will make GFS2 think that it has the glock in exclusive mode, when
really, it doesn't have the glock locked at all. This patch adds a new
field to the gfs2_glock structure, gl_req, to track the mode that was
requested.
Since we have a UUID, we ought to expose it to the user via sysfs
and uevents. We already have the fs name in both of these places
(a combination of the lock proto and lock table name) so if we add
the UUID as well, we have a full set.
For older filesystems (i.e. those created before mkfs.gfs2 was writing
UUIDs by default) the sysfs file will appear zero length, and no UUID
env var will be added to the uevents.
This patch allows GFS2 to generate discard requests for blocks which are
no longer useful to the filesystem (i.e. those which have been freed as
the result of an unlink operation). The requests are generated at the
time which those blocks become available for reuse in the filesystem.
In order to use this new feature, you have to specify the "discard"
mount option. The code coalesces adjacent blocks into a single extent
when generating the discard requests, thus generating the minimum
number.
If an error occurs when the request has been sent to the block device,
then it will print a message and turn off the requests for that
filesystem. If the problem is temporary, then you can use remount to
turn the option back on again. There is also a nodiscard mount option
so that you can use remount to turn discard requests off, if required.
The time stamp field is unused in the glock now that we are
using a shrinker, so that we can remove it and save sizeof(unsigned long)
bytes in each glock.
This is the big patch that I've been working on for some time
now. There are many reasons for wanting to make this change
such as:
o Reducing overhead by eliminating duplicated fields between structures
o Simplifcation of the code (reduces the code size by a fair bit)
o The locking interface is now the DLM interface itself as proposed
some time ago.
o Fewer lookups of glocks when processing replies from the DLM
o Fewer memory allocations/deallocations for each glock
o Scope to do further optimisations in the future (but this patch is
more than big enough for now!)
Please note that (a) this patch relates to the lock_dlm module and
not the DLM itself, that is still a separate module; and (b) that
we retain the ability to build GFS2 as a standalone single node
filesystem with out requiring the DLM.
This patch needs a lot of testing, hence my keeping it I restarted
my -git tree after the last merge window. That way, this has the maximum
exposure before its merged. This is (modulo a few minor bug fixes) the
same patch that I've been posting on and off the the last three months
and its passed a number of different tests so far.
We only really need a single spin lock for the quota data, so
lets just use the lru lock for now.
Cc: Abhijith Das <adas@redhat.com>
Deallocation of gfs2_quota_data objects now happens on-demand through a
shrinker instead of routinely deallocating through the quotad daemon.
Signed-off-by: Abhijith Das <adas@redhat.com>
This patch removes the two daemons, gfs2_scand and gfs2_glockd
and replaces them with a shrinker which is called from the VM.
The net result is that GFS2 responds better when there is memory
pressure, since it shrinks the glock cache at the same rate
as the VFS shrinks the dcache and icache. There are no longer
any time based criteria for shrinking glocks, they are kept
until such time as the VM asks for more memory and then we
demote just as many glocks as required.
There are potential future changes to this code, including the
possibility of sorting the glocks which are to be written back
into inode number order, to get a better I/O ordering. It would
be very useful to have an elevator based workqueue implementation
for this, as that would automatically deal with the read I/O cases
at the same time.
This patch is my answer to Andrew Morton's remark, made during
the initial review of GFS2, asking why GFS2 needs so many kernel
threads, the answer being that it doesn't :-) This patch is a
net loss of about 200 lines of code.
Following on from the recent clean up of gfs2_quotad, this patch moves
the processing of "truncate in progress" inodes from the glock workqueue
into gfs2_quotad. This fixes a hang due to the "truncate in progress"
processing requiring glocks in order to complete.
It might seem odd to use gfs2_quotad for this particular item, but
we have to use a pre-existing thread since creating a thread implies
a GFP_KERNEL memory allocation which is not allowed from the glock
workqueue context. Of the existing threads, gfs2_logd and gfs2_recoverd
may deadlock if used for this operation. gfs2_scand and gfs2_glockd are
both scheduled for removal at some (hopefully not too distant) future
point. That leaves only gfs2_quotad whose workload is generally fairly
light and is easily adapted for this extra task.
Also, as a result of this change, it opens the way for a future patch to
make the reading of the inode's information asynchronous with respect to
the glock workqueue, which is another improvement that has been on the list
for some time now.
This patch is a clean up of gfs2_quotad prior to giving it an
extra job to do in addition to the current portfolio of updating
the quota and statfs information from time to time.
As a result it has been moved into quota.c allowing one of the
functions it calls to be made static. Also the clean up allows
the two existing functions to have separate timeouts and also
to coexist with its future role of dealing with the "truncate in
progress" inode flag.
The (pointless) setting of gfs2_quotad_secs is removed since we
arrange to only wake up quotad when one of the two timers expires.
In addition the struct gfs2_quota_data is moved into a slab cache,
mainly for easier debugging. It should also be possible to use
a shrinker in the future, rather than the current scheme of scanning
the quota data entries from time to time.
This patch moves the final field so that we can get rid
of struct gfs2_rgrpd_host, as promised some time ago. Also
by rearranging the fields slightly, we are able to reduce
the size of the gfs2_rgrpd structure at the same time.
