path: root/fs/gfs2/super.h
2008-03-31[GFS2] Remove lm.[ch] and distribute contentSteven Whitehouse
The functions in lm.c were just wrappers which were mostly only used in one other file. By moving the functions to the files where they are being used, they can be marked static and also this will usually result in them being inlined since they are often only used from one point in the code. A couple of really trivial functions have been inlined by hand into the function which called them as it makes the code clearer to do that. We also gain from one fewer function call in the glock lock and unlock paths. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2007-07-09[GFS2] Fix sign problem in quota/statfs and cleanup _host structuresSteven Whitehouse
This patch fixes some sign issues which were accidentally introduced into the quota & statfs code during the endianess annotation process. Also included is a general clean up which moves all of the _host structures out of gfs2_ondisk.h (where they should not have been to start with) and into the places where they are actually used (often only one place). Also those _host structures which are not required any more are removed entirely (which is the eventual plan for all of them). The conversion routines from ondisk.c are also moved into the places where they are actually used, which for almost every one, was just one single place, so all those are now static functions. This also cleans up the end of gfs2_ondisk.h which no longer needs the #ifdef __KERNEL__. The net result is a reduction of about 100 lines of code, many functions now marked static plus the bug fixes as mentioned above. For good measure I ran the code through sparse after making these changes to check that there are no warnings generated. This fixes Red Hat bz #239686 Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-11-30[GFS2] split and annotate gfs2_statfs_changeAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-11-30[GFS2] split gfs2_sbAl Viro
2006-10-02[GFS2] Remove duplicate sb reading codeSteven Whitehouse
For some reason we had two different sets of code for reading in the superblock. This removes one of them in favour of the other. Also we don't need the temporary buffer for the sb since we already have one in the gfs2 sb itself. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-09-05[GFS2] Make headers compile on their ownSteven Whitehouse
As per Jan Engelhardt's comments, this should make all the headers compile on their own by including and/or declaring structures early. Cc: Jan Engelhardt <jengelh@linux01.gwdg.de> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-09-04[GFS2] Change all types to uX styleSteven Whitehouse
This makes all fixed size types have consistent names. Cc: Jan Engelhardt <jengelh@linux01.gwdg.de> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-09-01[GFS2] Update copyright, tidy up incore.hSteven Whitehouse
As per comments from Jan Engelhardt <jengelh@linux01.gwdg.de> this updates the copyright message to say "version" in full rather than "v.2". Also incore.h has been updated to remove forward structure declarations which are not required. The gfs2_quota_lvb structure has now had endianess annotations added to it. Also quota.c has been updated so that we now store the lvb data locally in endian independant format to avoid needing a structure in host endianess too. As a result the endianess conversions are done as required at various points and thus the conversion routines in lvb.[ch] are no longer required. I've moved the one remaining constant in lvb.h thats used into lm.h and removed the unused lvb.[ch]. I have not changed the HIF_ constants. That is left to a later patch which I hope will unify the gh_flags and gh_iflags fields of the struct gfs2_holder. Cc: Jan Engelhardt <jengelh@linux01.gwdg.de> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-05-18[GFS2] Update copyright date to 2006Steven Whitehouse
2006-04-28[GFS2] [-mm patch] fs/gfs2/: possible cleanupsAdrian Bunk
This patch contains the following possible cleanups: - make needlessly global code static - #if 0 unused functions - remove the following global function that was both unused and unimplemented: - super.c: gfs2_do_upgrade() Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-03-01[GFS2] Tidy up mount code.Steven Whitehouse
We no longer lookup ".gfs2_admin" in the root directory in order to find it, but instead use the inode number given in the superblock. Both the root directory and the admin directory are now looked up using the same routine, so the redundant code is removed. Also, there is no longer a reference to the root inode in the GFS2 super block. When required this can be retreived via sb->s_root->d_inode instead. Assuming that we introduce a metadata filesystem type for GFS, then this is a first step towards that goal. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-01-16[GFS2] The core of GFS2David Teigland
This patch contains all the core files for GFS2. Signed-off-by: David Teigland <teigland@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
