Change d_hash so it may be called from lock-free RCU lookups. See similar
patch for d_compare for details.
For in-tree filesystems, this is just a mechanical change.
Signed-off-by: Nick Piggin <npiggin@kernel.dk>
Change d_delete from a dentry deletion notification to a dentry caching
advise, more like ->drop_inode. Require it to be constant and idempotent,
and not take d_lock. This is how all existing filesystems use the callback
anyway.
This makes fine grained dentry locking of dput and dentry lru scanning
much simpler.
There is no requirement to flush the delete workqueue before a
gfs2 filesystem is suspended. The workqueue's work will just
be suspended along with the rest of the tasks on the filesystem.
The resolves a deadlock situation where the transaction lock's
demotion code was trying to flush the delete workqueue while at
the same time, the workqueue was waiting for the transaction
lock.
The delete workqueue is flushed by gfs2_make_fs_ro() already, so
that umount/remount are correctly protected anyway.
Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
When you do gfs2_grow it failed to take the very last
rgrp into account when adding up the new free space due
to an off-by-one error. It was not reading the last
rgrp from the rindex because of a check for "<=" that
should have been "<". Therefore, fsck.gfs2 was finding
(and fixing) an error with the system statfs file.
Signed-off-by: Bob Peterson <rpeterso@redhat.com>
We can only merge the fields into a bitfield if the locking
rules for them are the same. In this case gl_spin covers all
of the fields (write side) but a couple of them are used
with GLF_LOCK as the read side lock, which should be ok
since we know that the field in question won't be changing
at the time.
The gl_req setting has to be done earlier (in glock.c) in order
to place it under gl_spin. The gl_reply setting also has to be
brought under gl_spin in order to comply with the new rules.
This saves 4*sizeof(unsigned int) per glock.
Cc: Bob Peterson <rpeterso@redhat.com>
When you truncate the rindex file, you need to avoid calling gfs2_rindex_hold,
since you already hold it. However, if you haven't already read in the
resource groups, you need to do that.
Signed-off-by: Benjamin Marzinski <bmarzins@redhat.com>
When GFS2 grew the filesystem, it was never rereading the rindex file during
the grow. This is necessary for large grows when the filesystem is almost full,
and GFS2 needs to use some of the space allocated earlier in the grow to
complete it. Now, if GFS2 fails to reserve the necessary space and the rindex
file is not uptodate, it rereads it. Also, the only difference between
gfs2_ri_update() and gfs2_ri_update_special() was that gfs2_ri_update_special()
didn't clear out the existing resource groups, since you knew that it was only
called when there were no resource groups. Attempting to clear out the
resource groups when there are none takes almost no time, and rarely happens,
so I simply removed gfs2_ri_update_special().
There are a number of duplicated #defines in glock.h
plus one which is unused. This removes the extra
definitions.
The DLM never returns -EAGAIN in response to dlm_lock(), and even
if it did, the test in gdlm_lock() was wrong anyway. Once that
test is removed, it is possible to greatly simplify this code
by simply using a "normal" error return code (0 for success).
We then no longer need the LM_OUT_ASYNC return code which can
be removed.
With this patch the gfs2_set_dqblk() function will be able to update the
quota usage block count (FS_DQ_BCOUNT) in addition to the already supported
FS_DQ_BHARD (limit) and FS_DQ_BSOFT (warn) fields of the dquot structure.
Signed-off-by: Abhi Das <adas@redhat.com>
Functions that use printf formatting, especially
those that use %pV, should have their uses of
printf format and arguments checked by the compiler.
Using %pV reduces the number of printk calls and
eliminates any possible message interleaving from
other printk calls.
While preparing the last patch I noticed that the gfs2_setattr_simple
code had been duplicated into two other places. This patch updates
those to call gfs2_setattr_simple rather than open coding it.
Suggested-by: Christoph Hellwig <hch@infradead.org>
The WQ_RESCUER flag should only be used internally to the
workqueue implementation.
Acked-by: Tejun Heo <tj@kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/tj/misc into for-2.6.38/core
Userland programs using the quotactl() syscall assume limit/warn/usage
block counts in 512b basic blocks which were instead being read/written
in fs blocksize in gfs2. With this patch, gfs2 correctly interacts with
the syscall using 512b blocks.
This area of the code has always been a bit delicate due to the
subtleties of lock ordering. The problem is that for "normal"
alloc/dealloc, we always grab the inode locks first and the rgrp lock
later.
In order to ensure no races in looking up the unlinked, but still
allocated inodes, we need to hold the rgrp lock when we do the lookup,
which means that we can't take the inode glock.
The solution is to borrow the technique already used by NFS to solve
what is essentially the same problem (given an inode number, look up
the inode carefully, checking that it really is in the expected
state).
We cannot do that directly from the allocation code (lock ordering
again) so we give the job to the pre-existing delete workqueue and
carry on with the allocation as normal.
If we find there is no space, we do a journal flush (required anyway
if space from a deallocation is to be released) which should block
against the pending deallocations, so we should always get the space
back.
After recent blkdev_get() modifications, open_by_devnum() and
open_bdev_exclusive() are simple wrappers around blkdev_get().
Replace them with blkdev_get_by_dev() and blkdev_get_by_path().
blkdev_get_by_dev() is identical to open_by_devnum().
blkdev_get_by_path() is slightly different in that it doesn't
automatically add %FMODE_EXCL to @mode.
All users are converted. Most conversions are mechanical and don't
introduce any behavior difference. There are several exceptions.
* btrfs now sets FMODE_EXCL in btrfs_device->mode, so there's no
reason to OR it explicitly on blkdev_put().
* gfs2, nilfs2 and the generic mount_bdev() now set FMODE_EXCL in
sb->s_mode.
* With the above changes, sb->s_mode now always should contain
FMODE_EXCL. WARN_ON_ONCE() added to kill_block_super() to detect
errors.
The new blkdev_get_*() functions are with proper docbook comments.
While at it, add function description to blkdev_get() too.
Cc: Philipp Reisner <philipp.reisner@linbit.com>
Cc: Neil Brown <neilb@suse.de>
Cc: Mike Snitzer <snitzer@redhat.com>
Cc: Joern Engel <joern@lazybastard.org>
Cc: Chris Mason <chris.mason@oracle.com>
Cc: Jan Kara <jack@suse.cz>
Cc: "Theodore Ts'o" <tytso@mit.edu>
Cc: KONISHI Ryusuke <konishi.ryusuke@lab.ntt.co.jp>
Cc: reiserfs-devel@vger.kernel.org
Cc: xfs-masters@oss.sgi.com
Over time, block layer has accumulated a set of APIs dealing with bdev
open, close, claim and release.
* blkdev_get/put() are the primary open and close functions.
* bd_claim/release() deal with exclusive open.
* open/close_bdev_exclusive() are combination of open and claim and
the other way around, respectively.
* bd_link/unlink_disk_holder() to create and remove holder/slave
symlinks.
* open_by_devnum() wraps bdget() + blkdev_get().
The interface is a bit confusing and the decoupling of open and claim
makes it impossible to properly guarantee exclusive access as
in-kernel open + claim sequence can disturb the existing exclusive
open even before the block layer knows the current open if for another
exclusive access. Reorganize the interface such that,
* blkdev_get() is extended to include exclusive access management.
@holder argument is added and, if is @FMODE_EXCL specified, it will
gain exclusive access atomically w.r.t. other exclusive accesses.
* blkdev_put() is similarly extended. It now takes @mode argument and
if @FMODE_EXCL is set, it releases an exclusive access. Also, when
the last exclusive claim is released, the holder/slave symlinks are
removed automatically.
* bd_claim/release() and close_bdev_exclusive() are no longer
necessary and either made static or removed.
* bd_link_disk_holder() remains the same but bd_unlink_disk_holder()
is no longer necessary and removed.
* open_bdev_exclusive() becomes a simple wrapper around lookup_bdev()
and blkdev_get(). It also has an unexpected extra bdev_read_only()
test which probably should be moved into blkdev_get().
* open_by_devnum() is modified to take @holder argument and pass it to
blkdev_get().
Most of bdev open/close operations are unified into blkdev_get/put()
and most exclusive accesses are tested atomically at the open time (as
it should). This cleans up code and removes some, both valid and
invalid, but unnecessary all the same, corner cases.
open_bdev_exclusive() and open_by_devnum() can use further cleanup -
rename to blkdev_get_by_path() and blkdev_get_by_devt() and drop
special features. Well, let's leave them for another day.
Most conversions are straight-forward. drbd conversion is a bit more
involved as there was some reordering, but the logic should stay the
same.
Acked-by: Neil Brown <neilb@suse.de>
Acked-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
Acked-by: Mike Snitzer <snitzer@redhat.com>
Acked-by: Philipp Reisner <philipp.reisner@linbit.com>
Cc: Peter Osterlund <petero2@telia.com>
Cc: Andreas Dilger <adilger.kernel@dilger.ca>
Cc: Mark Fasheh <mfasheh@suse.com>
Cc: Joel Becker <joel.becker@oracle.com>
Cc: Alex Elder <aelder@sgi.com>
Cc: dm-devel@redhat.com
Cc: drbd-dev@lists.linbit.com
Cc: Leo Chen <leochen@broadcom.com>
Cc: Scott Branden <sbranden@broadcom.com>
Cc: Steven Whitehouse <swhiteho@redhat.com>
Cc: Dave Kleikamp <shaggy@linux.vnet.ibm.com>
Cc: Joern Engel <joern@logfs.org>
The caller allocated it, the caller should free it.
The only issue so far is that we could change the flp pointer even on an
error return if the fl_change callback failed. But we can simply move
the flp assignment after the fl_change invocation, as the callers don't
care about the flp return value if the setlease call failed.
We modified setlease to require the caller to allocate the new lease in
the case of creating a new lease, but forgot to fix up the filesystem
methods.
Cc: Steve French <sfrench@samba.org>
Cc: Trond Myklebust <Trond.Myklebust@netapp.com>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (52 commits)
split invalidate_inodes()
fs: skip I_FREEING inodes in writeback_sb_inodes
fs: fold invalidate_list into invalidate_inodes
fs: do not drop inode_lock in dispose_list
fs: inode split IO and LRU lists
fs: switch bdev inode bdi's correctly
fs: fix buffer invalidation in invalidate_list
fsnotify: use dget_parent
smbfs: use dget_parent
exportfs: use dget_parent
fs: use RCU read side protection in d_validate
fs: clean up dentry lru modification
fs: split __shrink_dcache_sb
fs: improve DCACHE_REFERENCED usage
fs: use percpu counter for nr_dentry and nr_dentry_unused
fs: simplify __d_free
fs: take dcache_lock inside __d_path
fs: do not assign default i_ino in new_inode
fs: introduce a per-cpu last_ino allocator
new helper: ihold()
This removes more dead code that was somehow missed by commit 0d99519efef
(writeback: remove unused nonblocking and congestion checks). There are
no behavior change except for the removal of two entries from one of the
ext4 tracing interface.
The nonblocking checks in ->writepages are no longer used because the
flusher now prefer to block on get_request_wait() than to skip inodes on
IO congestion. The latter will lead to more seeky IO.
The nonblocking checks in ->writepage are no longer used because it's
redundant with the WB_SYNC_NONE check.
We no long set ->nonblocking in VM page out and page migration, because
a) it's effectively redundant with WB_SYNC_NONE in current code
b) it's old semantic of "Don't get stuck on request queues" is mis-behavior:
that would skip some dirty inodes on congestion and page out others, which
is unfair in terms of LRU age.
Inspired by Christoph Hellwig. Thanks!
Signed-off-by: Wu Fengguang <fengguang.wu@intel.com>
Cc: Theodore Ts'o <tytso@mit.edu>
Cc: Sage Weil <sage@newdream.net>
Clones an existing reference to inode; caller must already hold one.
In fill_super() we hadn't MS_ACTIVE set yet, so there won't
be any inodes with zero i_count sitting around.
In put_super() we already have MS_ACTIVE removed *and* we
had called invalidate_inodes() since then. So again there
won't be any inodes with zero i_count...
__block_write_begin and block_prepare_write are identical except for slightly
different calling conventions. Convert all callers to the __block_write_begin
calling conventions and drop block_prepare_write.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq:
workqueue: remove in_workqueue_context()
workqueue: Clarify that schedule_on_each_cpu is synchronous
memory_hotplug: drop spurious calls to flush_scheduled_work()
shpchp: update workqueue usage
pciehp: update workqueue usage
isdn/eicon: don't call flush_scheduled_work() from diva_os_remove_soft_isr()
workqueue: add and use WQ_MEM_RECLAIM flag
workqueue: fix HIGHPRI handling in keep_working()
workqueue: add queue_work and activate_work trace points
workqueue: prepare for more tracepoints
workqueue: implement flush[_delayed]_work_sync()
workqueue: factor out start_flush_work()
workqueue: cleanup flush/cancel functions
workqueue: implement alloc_ordered_workqueue()
Fix up trivial conflict in fs/gfs2/main.c as per Tejun
* 'for-2.6.37/barrier' of git://git.kernel.dk/linux-2.6-block: (46 commits)
xen-blkfront: disable barrier/flush write support
Added blk-lib.c and blk-barrier.c was renamed to blk-flush.c
block: remove BLKDEV_IFL_WAIT
aic7xxx_old: removed unused 'req' variable
block: remove the BH_Eopnotsupp flag
block: remove the BLKDEV_IFL_BARRIER flag
block: remove the WRITE_BARRIER flag
swap: do not send discards as barriers
fat: do not send discards as barriers
ext4: do not send discards as barriers
jbd2: replace barriers with explicit flush / FUA usage
jbd2: Modify ASYNC_COMMIT code to not rely on queue draining on barrier
jbd: replace barriers with explicit flush / FUA usage
nilfs2: replace barriers with explicit flush / FUA usage
reiserfs: replace barriers with explicit flush / FUA usage
gfs2: replace barriers with explicit flush / FUA usage
btrfs: replace barriers with explicit flush / FUA usage
xfs: replace barriers with explicit flush / FUA usage
block: pass gfp_mask and flags to sb_issue_discard
dm: convey that all flushes are processed as empty
* 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl:
vfs: make no_llseek the default
vfs: don't use BKL in default_llseek
llseek: automatically add .llseek fop
libfs: use generic_file_llseek for simple_attr
mac80211: disallow seeks in minstrel debug code
lirc: make chardev nonseekable
viotape: use noop_llseek
raw: use explicit llseek file operations
ibmasmfs: use generic_file_llseek
spufs: use llseek in all file operations
arm/omap: use generic_file_llseek in iommu_debug
lkdtm: use generic_file_llseek in debugfs
net/wireless: use generic_file_llseek in debugfs
drm: use noop_llseek
* 'vfs' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl: (30 commits)
BKL: remove BKL from freevxfs
BKL: remove BKL from qnx4
autofs4: Only declare function when CONFIG_COMPAT is defined
autofs: Only declare function when CONFIG_COMPAT is defined
ncpfs: Lock socket in ncpfs while setting its callbacks
fs/locks.c: prepare for BKL removal
BKL: Remove BKL from ncpfs
BKL: Remove BKL from OCFS2
BKL: Remove BKL from squashfs
BKL: Remove BKL from jffs2
BKL: Remove BKL from ecryptfs
BKL: Remove BKL from afs
BKL: Remove BKL from USB gadgetfs
BKL: Remove BKL from autofs4
BKL: Remove BKL from isofs
BKL: Remove BKL from fat
BKL: Remove BKL from ext2 filesystem
BKL: Remove BKL from do_new_mount()
BKL: Remove BKL from cgroup
BKL: Remove BKL from NTFS
block/blk-core.c
drivers/block/loop.c
mm/swapfile.c
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
Signed-off-by: Andrea Gelmini <andrea.gelmini@gelma.net>
All file_operations should get a .llseek operation so we can make
nonseekable_open the default for future file operations without a
.llseek pointer.
The three cases that we can automatically detect are no_llseek, seq_lseek
and default_llseek. For cases where we can we can automatically prove that
the file offset is always ignored, we use noop_llseek, which maintains
the current behavior of not returning an error from a seek.
New drivers should normally not use noop_llseek but instead use no_llseek
and call nonseekable_open at open time. Existing drivers can be converted
to do the same when the maintainer knows for certain that no user code
relies on calling seek on the device file.
The generated code is often incorrectly indented and right now contains
comments that clarify for each added line why a specific variant was
chosen. In the version that gets submitted upstream, the comments will
be gone and I will manually fix the indentation, because there does not
seem to be a way to do that using coccinelle.
Some amount of new code is currently sitting in linux-next that should get
the same modifications, which I will do at the end of the merge window.
Many thanks to Julia Lawall for helping me learn to write a semantic
patch that does all this.
===== begin semantic patch =====
// This adds an llseek= method to all file operations,
// as a preparation for making no_llseek the default.
// The rules are
// - use no_llseek explicitly if we do nonseekable_open
// - use seq_lseek for sequential files
// - use default_llseek if we know we access f_pos
// - use noop_llseek if we know we don't access f_pos,
// but we still want to allow users to call lseek
@ open1 exists @
identifier nested_open;
nested_open(...)
nonseekable_open(...)
@ open exists@
identifier open_f;
identifier i, f;
identifier open1.nested_open;
int open_f(struct inode *i, struct file *f)
nested_open(...)
@ read disable optional_qualifier exists @
identifier read_f;
identifier f, p, s, off;
type ssize_t, size_t, loff_t;
expression E;
identifier func;
ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ read_no_fpos disable optional_qualifier exists @
identifier read_f;
... when != off
@ write @
identifier write_f;
expression E;
identifier func;
ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ write_no_fpos @
identifier write_f;
... when != off
@ fops0 @
identifier fops;
struct file_operations fops = {
@ has_llseek depends on fops0 @
identifier fops0.fops;
identifier llseek_f;
.llseek = llseek_f,
@ has_read depends on fops0 @
identifier read_f;
.read = read_f,
@ has_write depends on fops0 @
identifier write_f;
.write = write_f,
@ has_open depends on fops0 @
identifier open_f;
.open = open_f,
// use no_llseek if we call nonseekable_open
@ nonseekable1 depends on !has_llseek && has_open @
identifier nso ~= "nonseekable_open";
... .open = nso, ...
+.llseek = no_llseek, /* nonseekable */
@ nonseekable2 depends on !has_llseek @
identifier open.open_f;
... .open = open_f, ...
+.llseek = no_llseek, /* open uses nonseekable */
// use seq_lseek for sequential files
@ seq depends on !has_llseek @
identifier sr ~= "seq_read";
... .read = sr, ...
+.llseek = seq_lseek, /* we have seq_read */
// use default_llseek if there is a readdir
@ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier readdir_e;
// any other fop is used that changes pos
... .readdir = readdir_e, ...
+.llseek = default_llseek, /* readdir is present */
// use default_llseek if at least one of read/write touches f_pos
@ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read.read_f;
// read fops use offset
... .read = read_f, ...
+.llseek = default_llseek, /* read accesses f_pos */
@ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier write.write_f;
// write fops use offset
... .write = write_f, ...
+ .llseek = default_llseek, /* write accesses f_pos */
// Use noop_llseek if neither read nor write accesses f_pos
@ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read_no_fpos.read_f;
identifier write_no_fpos.write_f;
.write = write_f,
.read = read_f,
+.llseek = noop_llseek, /* read and write both use no f_pos */
@ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* write uses no f_pos */
@ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* read uses no f_pos */
@ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* no read or write fn */
===== End semantic patch =====
Cc: Julia Lawall <julia@diku.dk>
Add WQ_MEM_RECLAIM flag which currently maps to WQ_RESCUER, mark
WQ_RESCUER as internal and replace all external WQ_RESCUER usages to
WQ_MEM_RECLAIM.
This makes the API users express the intent of the workqueue instead
of indicating the internal mechanism used to guarantee forward
progress. This is also to make it cleaner to add more semantics to
WQ_MEM_RECLAIM. For example, if deemed necessary, memory reclaim
workqueues can be made highpri.
This patch doesn't introduce any functional change.
Cc: Jeff Garzik <jgarzik@pobox.com>
Mostly the glock operations follow the type of the glock. The
one exception is the transaction glock, so we need to check for
that directly.
Reported-by: Dr. David Alan Gilbert <linux@treblig.org>
This prepares the removal of the big kernel lock from the
file locking code. We still use the BKL as long as fs/lockd
uses it and ceph might sleep, but we can flip the definition
to a private spinlock as soon as that's done.
All users outside of fs/lockd get converted to use
lock_flocks() instead of lock_kernel() where appropriate.
Based on an earlier patch to use a spinlock from Matthew
Wilcox, who has attempted this a few times before, the
earliest patch from over 10 years ago turned it into
a semaphore, which ended up being slower than the BKL
and was subsequently reverted.
Someone should do some serious performance testing when
this becomes a spinlock, since this has caused problems
before. Using a spinlock should be at least as good
as the BKL in theory, but who knows...
Acked-by: Matthew Wilcox <willy@linux.intel.com>
Cc: Trond Myklebust <trond.myklebust@fys.uio.no>
Cc: "J. Bruce Fields" <bfields@fieldses.org>
Cc: Miklos Szeredi <mszeredi@suse.cz>
Cc: John Kacur <jkacur@redhat.com>
Cc: linux-fsdevel@vger.kernel.org
This patch fixes a GFS2 problem whereby the first rename after a
mount can result in a file system consistency error being flagged
improperly and cause the file system to withdraw. The problem is
that the rename code tries to run the rgrp list with function
gfs2_blk2rgrpd before the rgrp list is guaranteed to be read in
from disk. The patch makes the rename function hold the rindex
glock (as the gfs2_unlink code does today) which reads in the rgrp
list if need be. There were a total of three places in the rename
code that improperly referenced the rgrp list without the rindex
glock and this patch fixes all three.
Recently a feature was added to GFS2 to allow journal id allocation
via sysfs. This patch builds upon that so that a negative journal id
will be treated as an error code to be passed back as the return code
from mount. This allows termination of the mount process if there is
a failure.
Also, the process has been updated so that the kernel will wait
for a journal id, even in the "spectator" case. This is required
in order to avoid mounting a filesystem in case there is an error
while joining the cluster. In the spectator case, 0 is written into
the file to indicate that all is well, and that mount should continue.
XFS supports the "norecovery" mount option which is basically the
same as the GFS2 spectator mode. This adds support for "norecovery"
as a synonym for spectator mode, which is hopefully a more obvious
description of what it actually does.
The tests further down the recovery function relating to
unlocking the journal need to be updated to match the
intial test. Also, a test in the umount code which was
surplus to requirements has been removed. Umounting
spectator mounts now works correctly, as expected.
This shouldn't really be required, but gcc can't tell that
"al" is only accessed when initialised.
Some of the functions in GFS2 were not reserving space in the transaction for
the resource group header and the resource groups bitblocks that get added
when you do allocation. GFS2 now makes sure to reserve space for the
resource group header and either all the bitblocks in the resource group, or
one for each block that it may allocate, whichever is smaller using the new
gfs2_rg_blocks() inline function.
When checking journals for spectator mounts, we cannot rely on the
journal being locked, whatever its jid might be. This patch
ensures that we always get the journal locks when checking
journals for a spectator mount.
This option has never done anything useful. Also at the same time
this cleans up the sb checks which are done at mount time. The
debug option will be accepted, but ignored in future. Since it
didn't do anything, there didn't seem much point in retaining it.
This option defaulted to on for lock_nolock mounts and off
otherwise. The only function was to avoid the revalidation of
dentries. In the cluster case, that is entirely pointless and
liable to cause coherency problems.
The patch changes the revalidation to depend upon whether the
fs is a local or cluster fs (i.e. it follows the existing default
behaviour). I very much doubt anybody ever used this option as
there is no reason to. Even so we will continue to accept it
on the mount command line, but ignore it.
This is been a no-op for a very long time now. I'm pretty sure
nobody uses it, but just in case we'll still accept it on the
